    5. scripte analyse - welches script sendet viele änderungen
    • liv-in-sky
      liv-in-sky last edited by
      du hast hier ein script gepostet ( häufig sendende scripte)
      https://forum.iobroker.net/post/1178745
      const ids = $('javascript.0.scriptEnabled.*');
      const scripts = [];
      const objects = [];
      ids.each(function(id) {
         const script = id.replace('javascript.0.scriptEnabled.', 'script.js.');
         scripts.push(script);
         const obj = {script: script.replace('script.js.', ''), cnt: 0};
         objects.push(obj);
      on({id: /.*/, from: 'system.adapter.javascript.0'}, function(dp) {
         const script = dp.state.c;
         if(script) {
             const idx = scripts.indexOf(script);
             if(idx >= 0) objects[idx].cnt++;
      schedule('*/15 * * * * *', function() {
         setTimeout(function() {
             const sorted = [];
             for(let i = 0; i < objects.length; i++) {
                 sorted[i] = objects[i];
             sorted.sort(function(a,b) {
                 return b.cnt - a.cnt;
             sorted.length = 4;
             log(sorted);
         }, 100);
      ich finde das ist ein tolles script und habe schon einige übeltäter entdeckt -
      meine frage: was bedeutet "undefined" wenn ich hier loge, zeile 13
      script = dp.state.c; log(script);
      javascript.0
      2024-07-15 10:25:20.435	info	script.js.MYSTUFF.ALIAS.checkScriptHaeufigkeit: script.js.MYSTUFF.LEDuLUEFTERuLAMPE.LEDsSteuern
      javascript.0
      2024-07-15 10:25:20.023	info	script.js.MYSTUFF.ALIAS.checkScriptHaeufigkeit: script.js.common.HighestProccess
      javascript.0
      2024-07-15 10:25:20.022	info	script.js.MYSTUFF.ALIAS.checkScriptHaeufigkeit: script.js.common.HighestProccess
      javascript.0
      2024-07-15 10:25:19.308	info	script.js.MYSTUFF.ALIAS.checkScriptHaeufigkeit: script.js.MYSTUFF.MATRIX.MATRIX
      javascript.0
      2024-07-15 10:25:18.713	info	script.js.MYSTUFF.ALIAS.checkScriptHaeufigkeit: undefined
      javascript.0
      2024-07-15 10:25:18.712	info	script.js.MYSTUFF.ALIAS.checkScriptHaeufigkeit: undefined
      javascript.0
      2024-07-15 10:25:18.711	info	script.js.MYSTUFF.ALIAS.checkScriptHaeufigkeit: undefined
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      2024-07-15 10:25:18.710	info	script.js.MYSTUFF.ALIAS.checkScriptHaeufigkeit: undefined
      javascript.0
      2024-07-15 10:25:18.657	info	script.js.MYSTUFF.ALIAS.checkScriptHaeufigkeit: script.js.MYSTUFF.LEDuLUEFTERuLAMPE.LuxAufMatrix
      javascript.0
      2024-07-15 10:25:18.433	info	script.js.MYSTUFF.ALIAS.checkScriptHaeufigkeit: script.js.MYSTUFF.LEDuLUEFTERuLAMPE.LEDsSteuern
      javascript.0
      javascript.0
      2024-07-15 10:25:18.433	info	script.js.MYSTUFF.ALIAS.checkScriptHaeufigkeit: script.js.MYSTUFF.ALLERLEI.TemperaturWidget
      javascript.0
      2024-07-15 10:25:15.658	info	script.js.MYSTUFF.ALIAS.checkScriptHaeufigkeit: script.js.MYSTUFF.MATRIX.MATRIX
      javascript.0
      2024-07-15 10:25:15.100	info	script.js.MYSTUFF.ALIAS.checkScriptHaeufigkeit: [ { script: 'MYSTUFF.MATRIX.MATRIX', cnt: 52 }, { script: 'common.HighestProccess', cnt: 38 }, { script: 'MYSTUFF.LEDuLUEFTERuLAMPE.LuxAufMatrix', cnt: 33 }, { script: 'MYSTUFF.FUTRO.GetSwap', cnt: 30 }, { script: 'MYSTUFF.ALEXA.ALEXAEinkauf3Spalten', cnt: 28 }, { script: 'MYSTUFF.ALEXA.ALEXAToDo3Spalten', cnt: 28 }]
        paul53 @liv-in-sky last edited by paul53
        @liv-in-sky sagte: was bedeutet "undefined" wenn ich hier loge, zeile 13
        Das habe ich auch festgestellt und deshalb die Prüfung if(script) (Zeile 14) eingebaut. Offenbar liefern nicht alle DP den Skriptnamen unter dp.state.c.
        haus-automatisierung liv-in-sky 2 Replies Last reply Reply Quote 0
        • haus-automatisierung
          haus-automatisierung Developer Most Active @paul53 last edited by
          @paul53 sagte in scripte analyse - welches script sendet viele änderungen:
          Der Kommentar (ScriptName) wird immer geschrieben, wenn der JavaScript-Adapter einen State schreibt.
          Wird dieser aber z.B. unbestätigt geschrieben und dann von einem Adapter bestätigt, ist der Kommentar (logischerweise) weg.
            paul53 @haus-automatisierung last edited by
            @haus-automatisierung: dann von einem Adapter bestätigt, ist der Kommentar (logischerweise) weg.
            Bei Adapter-Bestätigung dürfte from: 'system.adapter.javascript.0' nicht erfüllt sein?
            • liv-in-sky
              liv-in-sky @paul53 last edited by
              danke - ok also wohl nix schlimmes
              mal angenommen, das script würde dauernd laufen und einmal am tag resettet und evtl alle 15 minuten in einen dp ausgegeben - wäre das ein problem - überlege gerade, was ich damit genau anfangen werde
              habe z.b 2 scripte entdeckt, wo ich vergessen hatte, das schedule wieder größer zurück zu setzen - nach einem test - so könnte ich das besser im auge behalten 🙂
                Ah richtig, hatte das Script oben nicht genau angeschaut.
                Aber es gibt ja auch noch States, welche der Adapter auch schreibt (z.B. variables.dayTime, die Astro states usw.). Diese werden ja nicht von Scripts geschrieben und damit ist der Kommentar dann auch leer.
                • liv-in-sky
                  liv-in-sky @haus-automatisierung last edited by
                  wäre das keine idee - einen dp zu haben, den der adapter schreibt mit den z.b. 10 meist-sendenden scripten ?
                    @liv-in-sky sagte: in einen dp ausgegeben - wäre das ein problem
                    Dann sollte der Name des Testskriptes ausgefiltert werden.
                       if(script && script != scriptName) {
                    @haus-automatisierung sagte in scripte analyse - welches script sendet viele änderungen:
                    An diese DP hatte ich nicht gedacht. Anscheinend werden diese dann per if(script) ausgefiltert.
                    haus-automatisierung 1 Reply Last reply Reply Quote 1
                      haus-automatisierung Developer Most Active @paul53 last edited by haus-automatisierung
                      Ja genau, weil state.c dann undefined ist.
                      1.0k
