    4. [gelöst] Netatmo funktioniert nicht mehr
      ManfredHi last edited by ManfredHi
      Hallo. Seit heute nach funktioniert der Netatmo-Adapter bei mir nicht mehr. Es kommen folgende FEhler im Log:
      2024-07-17 07:45:48.683 - info: netatmo.0 (1818329) Got terminate signal TERMINATE_YOURSELF
      2024-07-17 07:45:48.684 - info: netatmo.0 (1818329) cleaned everything up...
      2024-07-17 07:45:48.685 - info: netatmo.0 (1818329) terminating
      2024-07-17 07:45:48.685 - info: netatmo.0 (1818329) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2024-07-17 07:45:49.187 - info: netatmo.0 (1818329) terminating
      2024-07-17 07:45:53.035 - info: netatmo.0 (1819120) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.netatmo, node: v20.15.0, js-controller: 5.0.19
      2024-07-17 07:45:53.057 - info: netatmo.0 (1819120) Authenticating with Netatmo using individual client-ID 64ebxxxxxxxxxxxxxx913d
      2024-07-17 07:45:53.057 - warn: netatmo.0 (1819120) API Error: Please Authenticate manually once using the Admin UI of this instance.
      2024-07-17 07:46:54.575 - warn: admin.0 (78490) netatmo has an invalid jsonConfig: [{"instancePath":"/items/_authenticate","schemaPath":"#/definitions/sendToProps/additionalProperties","keyword":"additionalProperties","params":{"additionalProperty":"window"},"message":"must NOT have additional properties"},{"instancePath":"","schemaPath":"#/if","keyword":"if","params":{"failingKeyword":"else"},"message":"must match \"else\" schema"}]
      2024-07-17 07:46:56.100 - error: netatmo.0 (1819120) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2024-07-17 07:46:56.101 - error: netatmo.0 (1819120) unhandled promise rejection: Cannot read properties of undefined (reading 'netatmoCoach')
      2024-07-17 07:46:56.233 - error: netatmo.0 (1819120) TypeError: Cannot read properties of undefined (reading 'netatmoCoach')
      at getScopeList (/opt/iobroker/node_modules/iobroker.netatmo/main.js:232:16)
      at AdapterClass. (/opt/iobroker/node_modules/iobroker.netatmo/main.js:84:34)
      at AdapterClass.emit (node:events:519:28)
      at AdapterClass.emit (node:domain:488:12)
      at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11114:34)
      at Immediate. (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:381:37)
      at processImmediate (node:internal/timers:478:21)
      2024-07-17 07:46:56.234 - error: netatmo.0 (1819120) Cannot read properties of undefined (reading 'netatmoCoach')
      2024-07-17 07:46:56.246 - info: netatmo.0 (1819120) cleaned everything up...
      2024-07-17 07:46:56.246 - info: netatmo.0 (1819120) terminating
      2024-07-17 07:46:56.247 - warn: netatmo.0 (1819120) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2024-07-17 07:46:56.748 - info: netatmo.0 (1819120) terminating
      2024-07-17 07:46:56.893 - error: host.iobroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      2024-07-17 07:46:56.894 - error: host.iobroker Caught by controller[1]: TypeError: Cannot read properties of undefined (reading 'netatmoCoach')
      2024-07-17 07:46:56.894 - error: host.iobroker Caught by controller[1]: at getScopeList (/opt/iobroker/node_modules/iobroker.netatmo/main.js:232:16)
      2024-07-17 07:46:56.894 - error: host.iobroker Caught by controller[1]: at AdapterClass. (/opt/iobroker/node_modules/iobroker.netatmo/main.js:84:34)
      2024-07-17 07:46:56.894 - error: host.iobroker Caught by controller[1]: at AdapterClass.emit (node:events:519:28)
      2024-07-17 07:46:56.894 - error: host.iobroker Caught by controller[1]: at AdapterClass.emit (node:domain:488:12)
      2024-07-17 07:46:56.894 - error: host.iobroker Caught by controller[1]: at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11114:34)
      2024-07-17 07:46:56.894 - error: host.iobroker Caught by controller[1]: at Immediate. (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:381:37)
      2024-07-17 07:46:56.894 - error: host.iobroker Caught by controller[1]: at processImmediate (node:internal/timers:478:21)
      2024-07-17 07:46:56.895 - error: host.iobroker instance system.adapter.netatmo.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2024-07-17 07:46:56.895 - warn: host.iobroker Do not restart adapter system.adapter.netatmo.0 because restart loop detected
      Neue client-ID und client-Secret habe ich bereits erstellt und im Adapter eingetragen. Auch hab ich anschließend auf die Schaltfläche Authenticate Netamto geklickt. ohne Erfolg.
      Kann mir bitte jemand helfen? Bis heute nach hat es einwandfrei funktioniert.
        ManfredHi @ManfredHi last edited by
        Aufgefallen ist mir, dass wenn man auf die Schaltfläche "Authenticate Netatmo" klickt kein Fenster aufgeht. Normalerweise sollte lt. Anleitung des Adapters ein neues Fenster mit dem Login zu Netatmo öffnen. Das tut es aber nicht. Habe es mit mehreren Browsers und auf verschiedenen Geräten probiert. Popupblocker usw. sind ausgeschalten.
          Komisch, verwendet niemand mehr diesen Adapter ?
          • Winni
            Winni last edited by
            Also hier läuft der Adapter. Ist dein System aktuell? Gib doch mal ein:
            iob diag
            und stelle das Ergebnis hier ein.
              Skript v.2024-05-22
              *** BASE SYSTEM ***
                 Static hostname: iobroker
                       Icon name: computer-vm
                         Chassis: vm
                  Virtualization: kvm
                Operating System: Debian GNU/Linux 11 (bullseye)
                          Kernel: Linux 5.10.0-30-amd64
                    Architecture: x86-64
              model name      : Intel(R) Core(TM) i5-7260U CPU @ 2.20GHz
              Docker          : false
              Virtualization  : kvm
              Kernel          : x86_64
              Userland        : 64 bit
              Systemuptime and Load:
               21:40:13 up 10 days,  3:15,  1 user,  load average: 0.73, 0.48, 0.62
              CPU threads: 4
              *** Time and Time Zones ***
                             Local time: Wed 2024-07-17 21:40:13 CEST
                         Universal time: Wed 2024-07-17 19:40:13 UTC
                               RTC time: Wed 2024-07-17 19:40:14
                              Time zone: Europe/Vienna (CEST, +0200)
                            NTP service: n/a
                        RTC in local TZ: no
              *** Users and Groups ***
              User that called 'iob diag':
              iobuser
              HOME=/home/iobuser
              GROUPS=iobuser cdrom floppy sudo audio dip video plugdev netdev iobroker
              iobroker
              HOME=/home/iobroker
              GROUPS=iobroker tty dialout audio video plugdev redis
              *** Display-Server-Setup ***
              Display-Server: false
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Mem:             11G        6.1G        3.2G        0.0K        2.7G        5.5G
              Swap:           974M          0B        974M
              Total:           12G        6.1G        4.1G
              Active iob-Instances:   67
                      11964 M total memory
                       6106 M used memory
                        689 M active memory
                       7671 M inactive memory
                       3162 M free memory
                        187 M buffer memory
                       2509 M swap cache
                        974 M total swap
                          0 M used swap
                        974 M free swap
              top - 21:40:14 up 10 days,  3:15,  1 user,  load average: 0.73, 0.48, 0.62
              Tasks: 179 total,   2 running, 177 sleeping,   0 stopped,   0 zombie
              %Cpu(s):  3.2 us,  0.0 sy,  0.0 ni, 96.8 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
              MiB Mem :  11964.9 total,   3162.0 free,   6106.5 used,   2696.4 buff/cache
              MiB Swap:    975.0 total,    975.0 free,      0.0 used.   5548.4 avail Mem
              *** FAILED SERVICES ***
              0 loaded units listed.
              *** FILESYSTEM ***
              Filesystem              Type      Size  Used Avail Use% Mounted on
              udev                    devtmpfs  5.9G     0  5.9G   0% /dev
              tmpfs                   tmpfs     1.2G  728K  1.2G   1% /run
              /dev/sda1               ext4       19G   12G  6.4G  65% /
              tmpfs                   tmpfs     5.9G     0  5.9G   0% /dev/shm
              tmpfs                   tmpfs     5.0M     0  5.0M   0% /run/lock
              //192.168.0.40/ioBroker cifs      1.3T  1.1T  223G  83% /media/ioBroker
              tmpfs                   tmpfs     1.2G     0  1.2G   0% /run/user/1000
              [Sun Jul  7 18:24:22 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
              [Sun Jul  7 18:24:22 2024] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
              Show mounted filesystems:
              TARGET                       SOURCE                  FSTYPE     OPTIONS
              /                            /dev/sda1               ext4       rw,relatime,errors=remount-ro
              |-/sys                       sysfs                   sysfs      rw,nosuid,nodev,noexec,relatime
              | |-/sys/kernel/security     securityfs              securityfs rw,nosuid,nodev,noexec,relatime
              | |-/sys/fs/cgroup           cgroup2                 cgroup2    rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
              | |-/sys/fs/pstore           pstore                  pstore     rw,nosuid,nodev,noexec,relatime
              | |-/sys/fs/bpf              none                    bpf        rw,nosuid,nodev,noexec,relatime,mode=700
              | |-/sys/kernel/debug        debugfs                 debugfs    rw,nosuid,nodev,noexec,relatime
              | |-/sys/kernel/tracing      tracefs                 tracefs    rw,nosuid,nodev,noexec,relatime
              | |-/sys/kernel/config       configfs                configfs   rw,nosuid,nodev,noexec,relatime
              | `-/sys/fs/fuse/connections fusectl                 fusectl    rw,nosuid,nodev,noexec,relatime
              |-/proc                      proc                    proc       rw,nosuid,nodev,noexec,relatime
              | `-/proc/sys/fs/binfmt_misc systemd-1               autofs     rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=11449
              |-/dev                       udev                    devtmpfs   rw,nosuid,relatime,size=6108208k,nr_inodes=1527052,mode=755
              | |-/dev/pts                 devpts                  devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
              | |-/dev/shm                 tmpfs                   tmpfs      rw,nosuid,nodev
              | |-/dev/hugepages           hugetlbfs               hugetlbfs  rw,relatime,pagesize=2M
              | `-/dev/mqueue              mqueue                  mqueue     rw,nosuid,nodev,noexec,relatime
              |-/run                       tmpfs                   tmpfs      rw,nosuid,nodev,noexec,relatime,size=1225212k,mode=755
              | |-/run/lock                tmpfs                   tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k
              | |-/run/rpc_pipefs          sunrpc                  rpc_pipefs rw,relatime
              | `-/run/user/1000           tmpfs                   tmpfs      rw,nosuid,nodev,relatime,size=1225208k,nr_inodes=306302,mode=700,uid=1000,gid=1000
              `-/media/ioBroker            //192.168.0.40/ioBroker cifs       rw,relatime,vers=3.0,cache=strict,username=Lokaler_User,uid=0,noforceuid,gid=0,noforcegid,addr=192.168.0.40,file_mode=0777,dir_mode=0777,soft,nounix,serverino,mapposix,rsize=4194304,wsize=4194304,bsize=1048576,echo_interval=60,actimeo=1
              /var:
              2.5G    /var/
              2.0G    /var/log
              1.9G    /var/log/journal/f3e74dfd154748e6b8f322b9b58612ad
              319M    /var/cache
              Archived and active journals take up 1.0G in the file system.
              /opt/iobroker/backups:
              82M     /opt/iobroker/backups/
              /opt/iobroker/iobroker-data:
              1.3G    /opt/iobroker/iobroker-data/
              1.1G    /opt/iobroker/iobroker-data/files
              299M    /opt/iobroker/iobroker-data/files/javascript.admin
              265M    /opt/iobroker/iobroker-data/files/javascript.admin/static
              264M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
              85M     /opt/iobroker/iobroker-data/objects.jsonl
              83M     /opt/iobroker/iobroker-data/objects.pretty.jsonl
              41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
              38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
              37M     /opt/iobroker/iobroker-data/files/telegram-menu.admin/build/index.js.map
              USB-Devices by-id:
              No Devices found 'by-id'
              *** NodeJS-Installation ***
              /usr/bin/nodejs         v20.15.0
              /usr/bin/node           v20.15.0
              /usr/bin/npm            10.7.0
              /usr/bin/npx            10.7.0
              /usr/bin/corepack       0.28.1
              nodejs:
                Installed: 20.15.0-1nodesource1
                Candidate: 20.15.0-1nodesource1
                Version table:
               *** 20.15.0-1nodesource1 1001
                      500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                      100 /var/lib/dpkg/status
                   20.14.0-1nodesource1 1001
                   20.13.1-1nodesource1 1001
                   20.13.0-1nodesource1 1001
                   20.12.2-1nodesource1 1001
                   20.12.1-1nodesource1 1001
                   20.12.0-1nodesource1 1001
                   20.11.1-1nodesource1 1001
                   20.11.0-1nodesource1 1001
                   20.10.0-1nodesource1 1001
                   20.9.0-1nodesource1 1001
                   20.8.1-1nodesource1 1001
                   20.8.0-1nodesource1 1001
                   20.7.0-1nodesource1 1001
                   20.6.1-1nodesource1 1001
                   20.6.0-1nodesource1 1001
                   20.5.1-1nodesource1 1001
                   20.5.0-1nodesource1 1001
                   20.4.0-1nodesource1 1001
                   20.3.1-1nodesource1 1001
                   20.3.0-1nodesource1 1001
                   20.2.0-1nodesource1 1001
                   20.1.0-1nodesource1 1001
                   20.0.0-1nodesource1 1001
                   12.22.12~dfsg-1~deb11u4 500
                      500 http://ftp.tu-graz.ac.at/mirror/debian bullseye/main amd64 Packages
                      500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
              No problems detected
              Errors in npm tree:
              *** ioBroker-Installation ***
              ioBroker Status
              Objects type: jsonl
              States  type: redis
              Core adapters versions
              admin:          7.0.11
              javascript:     8.6.0
              nodejs modules from github:     8
              +-- iobroker.blockly-plus@0.0.1 (git+ssh://git@github.com/excal-foley/ioBroker.blockly-plus.git#8487239d69fc53c13853013110da15b42bc487e9)
              | `-- kodi-ws@2.4.4 (git+https://git@github.com/iobroker-community-adapters/kodi-ws.git#ad5a1fdc5cd0a282e6818ff152594b5d32535103)
              +-- iobroker.linux-control@1.1.6 (git+ssh://git@github.com/Scrounger/ioBroker.linux-control.git#59f578f3402850684ba8767a24a9ff288b05a3f0)
              +-- iobroker.nut@1.6.0 (git+ssh://git@github.com/Apollon77/ioBroker.nut.git#b684261dd657bc315c638037c397e42db2c361e1)
              | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
              +-- iobroker.solaredge-modbus@0.0.25 (git+ssh://git@github.com/joergspoerl/ioBroker.solaredge-modbus.git#a17300b3182465292a476c4e0fbaa96c9706e14d)
              +-- iobroker.sourceanalytix@0.4.14 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#9c4635239c7b9321601dcf0fcdd8677a55a8b13f)
              +-- iobroker.vesync@0.0.7 (git+ssh://git@github.com/TA2k/ioBroker.vesync.git#b0109fb28c94f7a3664eb0e599fd8359808a7b3e)
              Adapter State
              + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
              + system.adapter.admin.1                  : admin                 : iobroker                                 -  enabled, port: 8079, bind: 192.168.0.30, run as: admin
              + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
                system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
              + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                system.adapter.birthdays.0              : birthdays             : iobroker                                 -  enabled
                system.adapter.blockly-plus.0           : blockly-plus          : iobroker                                 - disabled
              + system.adapter.bosch-ebike.0            : bosch-ebike           : iobroker                                 -  enabled
              + system.adapter.bydbatt.0                : bydbatt               : iobroker                                 -  enabled
              + system.adapter.bydhvs.0                 : bydhvs                : iobroker                                 -  enabled
              + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
                system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
              + system.adapter.denon.0                  : denon                 : iobroker                                 -  enabled
                system.adapter.device-reminder.0        : device-reminder       : iobroker                                 - disabled
                system.adapter.device-watcher.0         : device-watcher        : iobroker                                 - disabled
                system.adapter.devices.0                : devices               : iobroker                                 - disabled
              + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
              + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
              + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 -  enabled
                system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 - disabled
              + system.adapter.fritzbox.0               : fritzbox              : iobroker                                 -  enabled
              + system.adapter.fritzdect.1              : fritzdect             : iobroker                                 -  enabled
                system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 - disabled
              + system.adapter.harmony.0                : harmony               : iobroker                                 -  enabled
              + system.adapter.heatingcontrol.0         : heatingcontrol        : iobroker                                 -  enabled
              + system.adapter.history.0                : history               : iobroker                                 -  enabled
              + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
              + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
              + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
              + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 0
              + system.adapter.homeconnect.0            : homeconnect           : iobroker                                 -  enabled
                system.adapter.hue-extended.0           : hue-extended          : iobroker                                 - disabled
                system.adapter.hue.0                    : hue                   : iobroker                                 - disabled, port: 443
              + system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
                system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
              + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
              + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
                system.adapter.jarvis.0                 : jarvis                : iobroker                                 - disabled
              + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                system.adapter.javascript.1             : javascript            : iobroker                                 - disabled
              + system.adapter.kodi.0                   : kodi                  : iobroker                                 -  enabled, port: 9090
              + system.adapter.linux-control.0          : linux-control         : iobroker                                 -  enabled
              + system.adapter.logparser.0              : logparser             : iobroker                                 -  enabled
                system.adapter.material.0               : material              : iobroker                                 - disabled
              + system.adapter.meross.0                 : meross                : iobroker                                 -  enabled
              + system.adapter.meross.1                 : meross                : iobroker                                 -  enabled
              + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
              + system.adapter.modbus.1                 : modbus                : iobroker                                 -  enabled
                system.adapter.modbus.2                 : modbus                : iobroker                                 - disabled
              + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1886, bind: 192.168.0.30
              + system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                system.adapter.netatmo-crawler.0        : netatmo-crawler       : iobroker                                 -  enabled
                system.adapter.netatmo.0                : netatmo               : iobroker                                 - disabled
              + system.adapter.nuki-extended.0          : nuki-extended         : iobroker                                 -  enabled
              + system.adapter.nut.0                    : nut                   : iobroker                                 -  enabled
              + system.adapter.operating-hours.0        : operating-hours       : iobroker                                 -  enabled
                system.adapter.parser.0                 : parser                : iobroker                                 - disabled
                system.adapter.pi-hole.0                : pi-hole               : iobroker                                 - disabled
              + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
              + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
                system.adapter.proxy.0                  : proxy                 : iobroker                                 -  enabled
              + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
              + system.adapter.pushover.1               : pushover              : iobroker                                 -  enabled
              + system.adapter.samsung.0                : samsung               : iobroker                                 -  enabled
              + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
              + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1884, bind: 192.168.0.30
              + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 192.168.0.30, run as: admin
                system.adapter.socketio.0               : socketio              : iobroker                                 - disabled, port: 8085, bind: 192.168.0.30, run as: admin
              + system.adapter.solaredge-modbus.0       : solaredge-modbus      : iobroker                                 -  enabled, port: 1502
                system.adapter.solaredge.0              : solaredge             : iobroker                                 - disabled
              + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1885, bind: 192.168.0.30
              + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
              + system.adapter.sourceanalytix.1         : sourceanalytix        : iobroker                                 -  enabled
              + system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled, port: 3306
                system.adapter.systeminfo.0             : systeminfo            : iobroker                                 - disabled
                system.adapter.telegram-menu.0          : telegram-menu         : iobroker                                 - disabled
              + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
              + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
              + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
              + system.adapter.traccar.0                : traccar               : iobroker                                 -  enabled
              + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
              + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
                system.adapter.unifi.0                  : unifi                 : iobroker                                 - disabled
              + system.adapter.upnp.0                   : upnp                  : iobroker                                 -  enabled
              + system.adapter.valuetrackerovertime.0   : valuetrackerovertime  : iobroker                                 -  enabled
                system.adapter.vesync.0                 : vesync                : iobroker                                 - disabled
              + system.adapter.virtualpowermeter.0      : virtualpowermeter     : iobroker                                 -  enabled
                system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : iobroker                                 -  enabled
                system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : iobroker                                 -  enabled
                system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 -  enabled
                system.adapter.vis-2.0                  : vis-2                 : iobroker                                 - disabled
                system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
                system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 - disabled
                system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
                system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 -  enabled
                system.adapter.vis-metro.0              : vis-metro             : iobroker                                 -  enabled
                system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
                system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
              + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 192.168.0.30, run as: admin
              + system.adapter.web.1                    : web                   : iobroker                                 -  enabled, port: 9082, bind: 0.0.0.0, run as: admin
              + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker                                 -  enabled
              + system.adapter.windows-control.0        : windows-control       : iobroker                                 -  enabled
              + system.adapter.ws.0                     : ws                    : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
              + system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : iobroker                                 -  enabled
              + instance is alive
              ioBroker-Repositories
              Stable (default): http://download.iobroker.net/sources-dist.json
              Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
              Installed ioBroker-Instances
              Adapter    "admin"        : 6.17.14  , installed 7.0.11
              Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
              Adapter    "backitup"     : 2.11.0   , installed 2.11.0
              Adapter    "birthdays"    : 3.0.1    , installed 3.0.0  [Updatable]
              Adapter    "bydbatt"      : 1.1.0    , installed 1.1.0
              Adapter    "bydhvs"       : 1.5.0    , installed 1.5.0
              Adapter    "cloud"        : 5.0.1    , installed 5.0.1
              Adapter    "daswetter"    : 3.1.15   , installed 3.1.15
              Adapter    "denon"        : 1.15.5   , installed 1.15.5
              Adapter    "device-reminder": 3.1.2  , installed 3.1.2
              Adapter    "device-watcher": 2.12.1  , installed 2.12.1
              Adapter    "discovery"    : 4.5.0    , installed 4.5.0
              Adapter    "echarts"      : 1.7.2    , installed 1.7.2
              Adapter    "email"        : 1.3.1    , installed 1.3.1
              Adapter    "energiefluss-erweitert": 0.4.1, installed 0.4.1
              Adapter    "fb-checkpresence": 1.2.4 , installed 1.2.4
              Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
              Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
              Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
              Adapter    "harmony"      : 1.4.0    , installed 1.4.0
              Adapter    "heatingcontrol": 2.12.8  , installed 2.12.8
              Adapter    "hm-rpc"       : 1.17.0   , installed 1.17.0
              Adapter    "homeconnect"  : 1.4.0    , installed 1.4.0
              Adapter    "hue"          : 3.11.0   , installed 3.11.0
              Adapter    "ical"         : 1.15.0   , installed 1.15.0
              Adapter    "iot"          : 3.3.0    , installed 3.3.0
              Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
              Adapter    "javascript"   : 8.3.1    , installed 8.6.0
              Adapter    "kodi"         : 3.1.0    , installed 3.1.0
              Adapter    "linux-control": 1.1.5    , installed 1.1.6
              Adapter    "logparser"    : 2.2.2    , installed 2.2.2
              Adapter    "material"     : 1.3.1    , installed 1.3.1
              Adapter    "meross"       : 1.17.0   , installed 1.17.0
              Adapter    "modbus"       : 6.2.3    , installed 6.2.3
              Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
              Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
              Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
              Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
              Adapter    "nut"          : 1.6.0    , installed 1.6.0
              Adapter    "operating-hours": 1.0.6  , installed 1.0.6
              Adapter    "parser"       : 2.1.0    , installed 2.1.0
              Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
              Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
              Adapter    "proxy"        : 1.3.2    , installed 1.3.2
              Adapter    "pushover"     : 3.0.6    , installed 3.0.6
              Adapter    "samsung"      : 0.6.0    , installed 0.6.0
              Adapter    "scenes"       : 3.0.4    , installed 3.0.4
              Adapter    "shelly"       : 7.0.0    , installed 7.0.0
              Adapter    "socketio"     : 6.7.0    , installed 6.7.0
              Adapter    "solaredge"    : 1.4.1    , installed 1.4.1
              Adapter    "sonoff"       : 3.1.0    , installed 3.1.0
              Adapter    "sql"          : 2.2.0    , installed 2.2.0
              Adapter    "systeminfo"   : 1.2.0    , installed 1.2.0
              Adapter    "telegram"     : 3.3.2    , installed 3.3.2
              Adapter    "telegram-menu": 1.7.4    , installed 1.7.0  [Updatable]
              Adapter    "text2command" : 3.0.3    , installed 3.0.3
              Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
              Adapter    "traccar"      : 1.1.4    , installed 1.1.4
              Adapter    "trashschedule": 3.3.0    , installed 3.3.0
              Adapter    "tuya"         : 3.15.0   , installed 3.15.0
              Adapter    "unifi"        : 0.7.0    , installed 0.7.0
              Adapter    "upnp"         : 1.0.21   , installed 1.0.21
              Adapter    "valuetrackerovertime": 1.0.1, installed 1.0.1
              Adapter    "virtualpowermeter": 1.4.6, installed 1.4.6
              Adapter    "vis-2"        : 2.9.32   , installed 2.9.32
              Adapter    "vis-2-widgets-energy": 0.3.11, installed 0.3.11
              Adapter    "vis-2-widgets-gauges": 1.0.3, installed 1.0.3
              Adapter    "vis-2-widgets-material": 1.3.32, installed 1.3.32
              Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
              Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
              Adapter    "weatherunderground": 3.7.0, installed 3.7.0
              Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
              Adapter    "windows-control": 0.1.5  , installed 0.1.5
              Adapter    "ws"           : 2.6.1    , installed 2.6.1
              Adapter    "zigbee2mqtt"  : 2.13.6   , installed 2.13.6
              Objects and States
              Objects:        81909
              States:         75304
              Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
              Hit:2 http://ftp.tu-graz.ac.at/mirror/debian bullseye InRelease
              Hit:3 http://ftp.tu-graz.ac.at/mirror/debian bullseye-updates InRelease
              Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
              Reading package lists...
              Pending Updates: 2
              *** Listening Ports ***
              tcp        0      0 192.168.0.30:1885       0.0.0.0:*               LISTEN      1001       34737081   3345584/io.sonoff.0
              tcp        0      0 192.168.0.30:1886       0.0.0.0:*               LISTEN      1001       19394      1982/io.mqtt.0
              tcp        0      0 192.168.0.30:4197       0.0.0.0:*               LISTEN      1001       39560472   679560/io.modbus.1
              tcp        0      0 127.0.0.1:3493          0.0.0.0:*               LISTEN      0          13213      570/upsd
              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       13821      533/iobroker.js-con
              tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      109        14972      487/redis-server 12
              tcp        0      0 192.168.0.30:9292       0.0.0.0:*               LISTEN      1001       18985      1587/io.hm-rpc.2
              tcp        0      0 192.168.0.30:8079       0.0.0.0:*               LISTEN      1001       251671     78491/io.admin.1
              tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          12349      1/init
              tcp        0      0 192.168.0.30:2001       0.0.0.0:*               LISTEN      1001       20790      1417/io.hm-rpc.1
              tcp        0      0 192.168.0.30:8082       0.0.0.0:*               LISTEN      1001       225868     70302/io.web.0
              tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      0          15387      521/dnsmasq
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13777      511/sshd: /usr/sbin
              tcp        0      0 192.168.0.30:8087       0.0.0.0:*               LISTEN      1001       28802      3894/io.simple-api.
              tcp        0      0 192.168.0.30:2010       0.0.0.0:*               LISTEN      1001       16004      1397/io.hm-rpc.0
              tcp        0      0 192.168.0.30:1884       0.0.0.0:*               LISTEN      1001       21743      2217/io.shelly.0
              tcp6       0      0 :::8000                 :::*                    LISTEN      1001       68983      7556/io.upnp.0
              tcp6       0      0 ::1:3493                :::*                    LISTEN      0          13212      570/upsd
              tcp6       0      0 :::61991                :::*                    LISTEN      1001       20618      1203/io.harmony.0
              tcp6       0      0 :::10123                :::*                    LISTEN      1001       37846      7801/io.energieflus
              tcp6       0      0 ::1:6379                :::*                    LISTEN      109        14973      487/redis-server 12
              tcp6       0      0 :::111                  :::*                    LISTEN      0          12353      1/init
              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       249766     78490/io.admin.0
              tcp6       0      0 :::8084                 :::*                    LISTEN      1001       38030      7610/io.ws.0
              tcp6       0      0 :::53                   :::*                    LISTEN      0          15389      521/dnsmasq
              tcp6       0      0 :::22                   :::*                    LISTEN      0          13788      511/sshd: /usr/sbin
              tcp6       0      0 :::9082                 :::*                    LISTEN      1001       226870     70308/io.web.1
              udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       20352      2608/io.tuya.0
              udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       20353      2608/io.tuya.0
              udp        0      0 0.0.0.0:53              0.0.0.0:*                           0          15386      521/dnsmasq
              udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          12350      1/init
              udp        0      0 192.168.0.30:123        0.0.0.0:*                           0          14932      507/ntpd
              udp        0      0 127.0.0.1:123           0.0.0.0:*                           0          14930      507/ntpd
              udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          14926      507/ntpd
              udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       39139      7556/io.upnp.0
              udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       20619      1203/io.harmony.0
              udp        0      0 192.168.0.30:5353       0.0.0.0:*                           1001       22775      2412/io.tr-064.0
              udp6       0      0 :::53                   :::*                                0          15388      521/dnsmasq
              udp6       0      0 :::111                  :::*                                0          12356      1/init
              udp6       0      0 fe80::3417:62ff:fe4:123 :::*                                0          14938      507/ntpd
              udp6       0      0 fd34:8751:2f48:4dcc:123 :::*                                0          14936      507/ntpd
              udp6       0      0 ::1:123                 :::*                                0          14934      507/ntpd
              udp6       0      0 :::123                  :::*                                0          14923      507/ntpd
              2024-07-17 21:14:27.374  - info: javascript.0 (691) script.js.common.Beleuchtung.Lichter_zaehlen: Kellerstiege Licht ausgeschalten.
              2024-07-17 21:15:05.209  - info: netatmo-crawler.0 (2666540) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v20.15.0, js-controller: 5.0.19
              2024-07-17 21:15:05.235  - info: netatmo-crawler.0 (2666540) Getting data for stationid:70:ee:50:a5:86:0a
              2024-07-17 21:15:06.494  - info: netatmo-crawler.0 (2666540) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
              2024-07-17 21:15:09.095  - info: daswetter.0 (2666562) starting. Version 3.1.15 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.15.0, js-controller: 5.0.19
              2024-07-17 21:15:14.328  - info: daswetter.0 (2666562) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
              2024-07-17 21:15:14.839  - info: daswetter.0 (2666562) cleaned everything up...
              2024-07-17 21:20:01.233  - info: netatmo-crawler.0 (2671646) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v20.15.0, js-controller: 5.0.19
              2024-07-17 21:20:01.262  - info: netatmo-crawler.0 (2671646) Getting data for stationid:70:ee:50:a5:86:0a
              2024-07-17 21:20:02.212  - info: netatmo-crawler.0 (2671646) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
              2024-07-17 21:25:05.038  - info: netatmo-crawler.0 (2677093) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v20.15.0, js-controller: 5.0.19
              2024-07-17 21:25:05.063  - info: netatmo-crawler.0 (2677093) Getting data for stationid:70:ee:50:a5:86:0a
              2024-07-17 21:25:06.266  - info: netatmo-crawler.0 (2677093) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
              2024-07-17 21:30:01.402  - info: netatmo-crawler.0 (2682159) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v20.15.0, js-controller: 5.0.19
              2024-07-17 21:30:01.465  - info: netatmo-crawler.0 (2682159) Getting data for stationid:70:ee:50:a5:86:0a
              2024-07-17 21:30:03.810  - info: netatmo-crawler.0 (2682159) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
              2024-07-17 21:30:09.120  - info: daswetter.0 (2682356) starting. Version 3.1.15 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.15.0, js-controller: 5.0.19
              2024-07-17 21:30:14.348  - info: daswetter.0 (2682356) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
              2024-07-17 21:30:14.855  - info: daswetter.0 (2682356) cleaned everything up...
              2024-07-17 21:35:05.214  - info: netatmo-crawler.0 (2687611) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v20.15.0, js-controller: 5.0.19
              2024-07-17 21:35:05.235  - info: netatmo-crawler.0 (2687611) Getting data for stationid:70:ee:50:a5:86:0a
              2024-07-17 21:35:06.246  - info: netatmo-crawler.0 (2687611) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
              2024-07-17 21:40:01.809  - info: netatmo-crawler.0 (2692702) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v20.15.0, js-controller: 5.0.19
              2024-07-17 21:40:01.837  - info: netatmo-crawler.0 (2692702) Getting data for stationid:70:ee:50:a5:86:0a
              2024-07-17 21:40:02.789  - info: netatmo-crawler.0 (2692702) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
              iob diag has finished.
              Press any key for a summary
              • Winni
                @manfredhi Guten Morgen, was mir auffällt, Bullseye ist nicht mehr aktuell und für Node gibt es die Version 20.15.1. Ob das etwas deinem Adapter Problem zu tun hat glaube ich aber eher nicht. Vielleicht kann da noch jemand darüber schauen der mehr Ahnung hat als ich. Trotzdem würde ich node updaten und auch mal den fixer laufen lassen.
                  ManfredHi @Winni last edited by ManfredHi
                  @Winni
                  Hab beim Admin-Adapter ein Downgrade von 7.0.11 auf 6.7.14 gemacht und jetzt funktioniert es wieder.
                  DAs Problem dürfte beim Admin-Adapter auftreten, weil wenn man im Netatmo-Adapter auf "authenticate Netatmo" klickt geht das FEnster für die Anmeldung bei Netatmo nicht auf. Mit dem Admin 6.7.14 sehr wohl.
                    Thomas Braun Most Active @ManfredHi last edited by Thomas Braun
                    @manfredhi
                    Das ist dann eine Regression.
                    Hast du ein Issue geloggt?
                    Wobei das vielleicht auch mit
                    admin
                    latest:	7.0.17
                    auch schon behoben ist...
                    Du betreibst ja Beta-Testing mit einer alten Version:
                    Das ist natürlich wenig sinnvoll.
                      ManfredHi @Thomas Braun last edited by
                      @thomas-braun sagte in Netatmo funktioniert nicht mehr:
                      stimmt. hab die 7.0.11 vor ca. 2 Wochen installiert.
                      Werd jetzt mal bei der 6.17.14 bleiben bis die 7.x offiziell und nicht mehr im beta-stadium ist.
                        Copy to Clipboard admin latest: 7.0.17
                        Hab doch die 7.0.17 installiert. Dort ist das Problem nicht mehr vorhanden,
                        380
