    4. RFLink Adapter Installation Fehler
      ccc.ggg73 last edited by
      kann mir jemand helfen? Ich bekomme den RFLink Adapter nicht installiert.
      Hier die Fehlermeldung bein installation über Admin Adapter:
      $ ./iobroker add rflink
      host.raspberrypi install adapter rflink
      npm install iobroker.rflink --production --prefix "/opt/iobroker" (System call)
      npm ERR! Linux 4.4.50-v7+npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.rflink" "--production" "--prefix" "/opt/iobroker"
      npm ERR! node v4.8.4
      npm ERR! npm  v2.15.11npm ERR! path /opt/iobroker/node_modules/iobroker.rflink/node_modules/serialport/node_modules/fstream/examples
      npm ERR! code ENOTEMPTY
      npm ERR! errno -39
      npm ERR! syscall rmdir
      npm ERR! ENOTEMPTY: directory not empty, rmdir '/opt/iobroker/node_modules/iobroker.rflink/node_modules/serialport/node_modules/fstream/examples'npm ERR!
      npm ERR! If you need help, you may report this error at:npm ERR!     <https: github.com/npm/issues="">
      npm ERR! error rolling back Error: ENOTEMPTY: directory not empty, rmdir '/opt/iobroker/node_modules/iobroker.rflink/node_modules/serialport/node_modules/fstream/examples'
      npm ERR! error rolling back     at Error (native)
      npm ERR! error rolling back  { [Error: ENOTEMPTY: directory not empty, rmdir '/opt/iobroker/node_modules/iobroker.rflink/node_modules/serialport/node_modules/fstream/examples']
      npm ERR! error rolling back   errno: -39,npm ERR! error rolling back   code: 'ENOTEMPTY',
      npm ERR! error rolling back   syscall: 'rmdir',
      npm ERR! error rolling back   path: '/opt/iobroker/node_modules/iobroker.rflink/node_modules/serialport/node_modules/fstream/examples' }
      npm ERR! Please include the following file with any support request:
      npm ERR!     /npm-debug.log
      ERROR: host.raspberrypi Cannot install iobroker.rflink: 217
      ERROR: process exited with code 25</https:>
      Hier wenn ich über Console versuche:
      pi@raspberrypi:/opt/iobroker $ sudo iobroker add rflink
      npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.rflink" "--production" "             --prefix" "/opt/iobroker"
      npm ERR! path /opt/iobroker/node_modules/iobroker.rflink/node_modules/serialport/node_modul             es/fstream/examples
      npm ERR! errno -39
      npm ERR! ENOTEMPTY: directory not empty, rmdir '/opt/iobroker/node_modules/iobroker.rflink/             node_modules/serialport/node_modules/fstream/examples'
      npm ERR!
      npm ERR!     <https: github.com/npm/issues="">npm ERR! error rolling back Error: ENOTEMPTY: directory not empty, rmdir '/opt/iobroker/nod             e_modules/iobroker.rflink/node_modules/serialport/node_modules/fstream/examples'
      npm ERR! error rolling back  { [Error: ENOTEMPTY: directory not empty, rmdir '/opt/iobroker             /node_modules/iobroker.rflink/node_modules/serialport/node_modules/fstream/examples']
      npm ERR! error rolling back   path: '/opt/iobroker/node_modules/iobroker.rflink/node_module             s/serialport/node_modules/fstream/examples' }
      npm ERR!     /opt/iobroker/npm-debug.log
      pi@raspberrypi:/opt/iobroker $ sudo npm install iobroker.rflink
      npm ERR! errno -39
      npm ERR!
      pi@raspberrypi:/opt/iobroker $</https:></https:>
      Vielen Dank im Voraus.
      • kmxak
        Bist du nach der Anleitung auf git hub vorgegangen? Hast du Serial Port installiert vorher?
        Gesendet von meinem SM-G930F mit Tapatalk
          @kmxak:
          Gesendet von meinem SM-G930F mit Tapatalk `
          Hallo kmxak,
          ich habe vorher:
          sudo atp-get update
          und
          sudo apt-get install build-essential -y
          ausgeführt. Der Pi hat gemeldet das die packete schon installiert waren.
          Von eine serial port habe ich im GitHub nix gefunden…
            OK ich glaube ich habe den RFLink Adapter verwechselt.
            Ich habe ein 433 Mhz Empfänger und ein sender die an GPIO von pi angeschlossen sind und über Pilight meine Funksteckdose und Rollladen steuern.
            Jetzt habe ich eine Renkforce AOK 5500 Funk-Wetterstation gekauft und wollte die Funksignale über mein PI empfangen und mit iobroker auswährten.
            Ich dachte das RFLink auch die billige 433 MHz sender/empfänger steuern kann aber habe eben gesehen das man dafür ein RFLink Hardware am USB angeschlossen braucht.
            Ups…
            • kmxak
              Ja RFLink braucht zusätzliche Hardware. Ob man diese auch an die GPIO vom PI bekommen kann weiß ich nicht. Bei hängt der RFLink (Arduino) per USB an einem PI3
