    4. Fehler beim Node-Red Update auf 5.x
      jonesinho last edited by
      Hallo liebe Community,
      aktuell versuche ich im ioBroker (läuft in einem Docker-Container mit aktuellem Image) den Node-Red Adapter auf die aktuelle Version zu bringen. Momentan läuft 4.0.3 und leider habe ich nichts zu nachfolgender Problematik aus dem Log gefunden.
      Weiß hier jemand weiter? Besten Dank vorab!
      0 verbose cli /usr/bin/node /usr/bin/npm
      1 info using npm@10.8.1
      2 info using node@v18.20.4
      3 silly config load:file:/usr/lib/node_modules/npm/npmrc
      4 silly config load:file:/opt/iobroker/.npmrc
      5 silly config load:file:/usr/etc/npmrc
      6 verbose title npm install iobroker.node-red@5.2.1
      7 verbose argv "install" "--save-exact" "iobroker.node-red@5.2.1" "--unsafe-perm"
      8 verbose logfile logs-max:10 dir:/opt/iobroker/.npm/_logs/2024-07-20T22_34_10_354Z-
      9 verbose logfile /opt/iobroker/.npm/_logs/2024-07-20T22_34_10_354Z-debug-0.log
      10 silly packumentCache heap:1019740160 maxSize:254935040 maxEntrySize:127467520
      11 silly logfile start cleaning logs, removing 1 files
      12 silly logfile done cleaning log files
      13 silly idealTree buildDeps
      14 silly fetch manifest iobroker.node-red@5.2.1
      15 silly packumentCache full:https://registry.npmjs.org/iobroker.node-red cache-miss
      16 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules
      17 http fetch GET 200 https://registry.npmjs.org/iobroker.node-red 100ms (cache hit)
      18 silly packumentCache full:https://registry.npmjs.org/iobroker.node-red set size:205237 disposed:false
      19 silly placeDep ROOT iobroker.node-red@5.2.1 REPLACE for: iobroker.inst@3.0.0 want: 5.2.1
      20 silly fetch manifest @iobroker/adapter-core@^3.1.4
      21 silly packumentCache full:https://registry.npmjs.org/@iobroker%2fadapter-core cache-miss
      22 silly fetch manifest bcrypt@^5.1.1
      23 silly packumentCache full:https://registry.npmjs.org/bcrypt cache-miss
      24 silly fetch manifest node-red@^3.1.9
      25 silly packumentCache full:https://registry.npmjs.org/node-red cache-miss
      26 http fetch GET 200 https://registry.npmjs.org/bcrypt 275ms (cache hit)
      27 silly packumentCache full:https://registry.npmjs.org/bcrypt set size:217027 disposed:false
      28 silly fetch manifest node-red-dashboard@^3.6.5
      29 silly packumentCache full:https://registry.npmjs.org/node-red-dashboard cache-miss
      30 http fetch GET 200 https://registry.npmjs.org/node-red 462ms (cache hit)
      31 silly packumentCache full:https://registry.npmjs.org/node-red set size:532666 disposed:false
      32 silly fetch manifest node-red-node-email@^2.2.1
      33 silly packumentCache full:https://registry.npmjs.org/node-red-node-email cache-miss
      34 http fetch GET 200 https://registry.npmjs.org/@iobroker%2fadapter-core 1847ms (cache hit)
      35 silly packumentCache full:https://registry.npmjs.org/@iobroker%2fadapter-core set size:138388 disposed:false
      36 silly fetch manifest mongodb@^6.5.0
      37 silly packumentCache full:https://registry.npmjs.org/mongodb cache-miss
      38 http fetch GET 200 https://registry.npmjs.org/mongodb 1502ms (cache hit)
      39 silly packumentCache full:https://registry.npmjs.org/mongodb set size:2079075 disposed:false
      40 http fetch GET 200 https://registry.npmjs.org/node-red-dashboard 3462ms (cache revalidated)
      41 silly packumentCache full:https://registry.npmjs.org/node-red-dashboard set size:592118 disposed:false
      42 http fetch GET 200 https://registry.npmjs.org/node-red-node-email 3561ms (cache revalidated)
      43 silly packumentCache full:https://registry.npmjs.org/node-red-node-email set size:206373 disposed:false
      44 silly fetch manifest @iobroker/types@^6.0.0
      45 silly packumentCache full:https://registry.npmjs.org/@iobroker%2ftypes cache-miss
      46 http fetch GET 200 https://registry.npmjs.org/@iobroker%2ftypes 19ms (cache hit)
      47 silly packumentCache full:https://registry.npmjs.org/@iobroker%2ftypes set size:399555 disposed:false
      48 silly fetch manifest @aws-sdk/credential-providers@^3.188.0
      49 silly packumentCache full:https://registry.npmjs.org/@aws-sdk%2fcredential-providers cache-miss
      50 http fetch GET 200 https://registry.npmjs.org/@aws-sdk%2fcredential-providers 33ms (cache hit)
      51 silly packumentCache full:https://registry.npmjs.org/@aws-sdk%2fcredential-providers set size:1207706 disposed:false
      52 silly fetch manifest @mongodb-js/zstd@^1.1.0
      53 silly packumentCache full:https://registry.npmjs.org/@mongodb-js%2fzstd cache-miss
      54 http fetch GET 200 https://registry.npmjs.org/@mongodb-js%2fzstd 16ms (cache hit)
      55 silly packumentCache full:https://registry.npmjs.org/@mongodb-js%2fzstd set size:53253 disposed:false
      56 silly fetch manifest gcp-metadata@^5.2.0
      57 silly packumentCache full:https://registry.npmjs.org/gcp-metadata cache-miss
      58 http fetch GET 200 https://registry.npmjs.org/gcp-metadata 14ms (cache hit)
      59 silly packumentCache full:https://registry.npmjs.org/gcp-metadata set size:164247 disposed:false
      60 silly fetch manifest kerberos@^2.0.1
      61 silly packumentCache full:https://registry.npmjs.org/kerberos cache-miss
      62 http fetch GET 200 https://registry.npmjs.org/kerberos 13ms (cache hit)
      63 silly packumentCache full:https://registry.npmjs.org/kerberos set size:107494 disposed:false
      64 silly fetch manifest mongodb-client-encryption@>=6.0.0 <7
      65 silly packumentCache full:https://registry.npmjs.org/mongodb-client-encryption cache-miss
      66 http fetch GET 200 https://registry.npmjs.org/mongodb-client-encryption 28ms (cache hit)
      67 silly packumentCache full:https://registry.npmjs.org/mongodb-client-encryption set size:859022 disposed:false
      68 silly fetch manifest snappy@^7.2.2
      69 silly packumentCache full:https://registry.npmjs.org/snappy cache-miss
      70 http fetch GET 200 https://registry.npmjs.org/snappy 15ms (cache hit)
      71 silly packumentCache full:https://registry.npmjs.org/snappy set size:164250 disposed:false
      72 silly fetch manifest socks@^2.7.1
      73 silly packumentCache full:https://registry.npmjs.org/socks cache-miss
      74 http fetch GET 200 https://registry.npmjs.org/socks 79ms (cache revalidated)
      75 silly packumentCache full:https://registry.npmjs.org/socks set size:276457 disposed:false
      76 silly placeDep node_modules/iobroker.node-red @iobroker/adapter-core@3.1.6 OK for: iobroker.node-red@5.2.1 want: ^3.1.4
      77 silly placeDep node_modules/iobroker.node-red @iobroker/types@6.0.9 OK for: @iobroker/adapter-core@3.1.6 want: ^6.0.0
      78 silly placeDep ROOT bcrypt@5.1.1 OK for: iobroker.node-red@5.2.1 want: ^5.1.1
      79 silly placeDep node_modules/iobroker.node-red mongodb@6.8.0 OK for: iobroker.node-red@5.2.1 want: ^6.5.0
      80 silly placeDep node_modules/iobroker.node-red gcp-metadata@5.3.0 OK for: mongodb@6.8.0 want: ^5.2.0
      81 silly placeDep ROOT node-red@3.1.11 OK for: iobroker.node-red@5.2.1 want: ^3.1.9
      82 silly placeDep ROOT node-red-dashboard@3.6.5 OK for: iobroker.node-red@5.2.1 want: ^3.6.5
      83 silly placeDep ROOT node-red-node-email@2.2.1 OK for: iobroker.node-red@5.2.1 want: ^2.2.1
      84 silly fetch manifest node-addon-api@^5.0.0
      85 silly packumentCache full:https://registry.npmjs.org/node-addon-api cache-miss
      86 silly fetch manifest bson@^6.7.0
      87 silly packumentCache full:https://registry.npmjs.org/bson cache-miss
      88 silly fetch manifest @mongodb-js/saslprep@^1.1.5
      89 silly packumentCache full:https://registry.npmjs.org/@mongodb-js%2fsaslprep cache-miss
      90 http fetch GET 200 https://registry.npmjs.org/node-addon-api 48ms (cache hit)
      91 silly packumentCache full:https://registry.npmjs.org/node-addon-api set size:262335 disposed:false
      92 silly fetch manifest mongodb-connection-string-url@^3.0.0
      93 silly packumentCache full:https://registry.npmjs.org/mongodb-connection-string-url cache-miss
      94 http fetch GET 200 https://registry.npmjs.org/bson 73ms (cache hit)
      95 silly packumentCache full:https://registry.npmjs.org/bson set size:742665 disposed:false
      96 silly fetch manifest gaxios@^5.0.0
      97 silly packumentCache full:https://registry.npmjs.org/gaxios cache-miss
      98 http fetch GET 200 https://registry.npmjs.org/@mongodb-js%2fsaslprep 107ms (cache hit)
      99 silly packumentCache full:https://registry.npmjs.org/@mongodb-js%2fsaslprep set size:42375 disposed:false
      100 silly fetch manifest semver@7.5.4
      101 silly packumentCache full:https://registry.npmjs.org/semver cache-miss
      102 http fetch GET 200 https://registry.npmjs.org/mongodb-connection-string-url 76ms (cache hit)
      103 silly packumentCache full:https://registry.npmjs.org/mongodb-connection-string-url set size:111613 disposed:false
      104 silly fetch manifest bcryptjs@2.4.3
      105 silly packumentCache full:https://registry.npmjs.org/bcryptjs cache-miss
      106 http fetch GET 200 https://registry.npmjs.org/semver 35ms (cache hit)
      107 silly packumentCache full:https://registry.npmjs.org/semver set size:215887 disposed:false
      108 silly fetch manifest fs-extra@11.1.1
      109 silly packumentCache full:https://registry.npmjs.org/fs-extra cache-miss
      110 http fetch GET 200 https://registry.npmjs.org/gaxios 60ms (cache hit)
      111 silly packumentCache full:https://registry.npmjs.org/gaxios set size:304405 disposed:false
      112 silly fetch manifest basic-auth@2.0.1
      113 silly packumentCache full:https://registry.npmjs.org/basic-auth cache-miss
      114 http fetch GET 200 https://registry.npmjs.org/fs-extra 78ms (cache hit)
      115 silly packumentCache full:https://registry.npmjs.org/fs-extra set size:220826 disposed:false
      116 silly fetch manifest @node-red/util@3.1.11
      117 silly packumentCache full:https://registry.npmjs.org/@node-red%2futil cache-miss
      118 http fetch GET 200 https://registry.npmjs.org/basic-auth 71ms (cache hit)
      119 silly packumentCache full:https://registry.npmjs.org/basic-auth set size:21642 disposed:false
      120 silly fetch manifest node-red-admin@^3.1.3
      121 silly packumentCache full:https://registry.npmjs.org/node-red-admin cache-miss
      122 http fetch GET 200 https://registry.npmjs.org/node-red-admin 26ms (cache hit)
      123 silly packumentCache full:https://registry.npmjs.org/node-red-admin set size:74696 disposed:false
      124 silly fetch manifest @node-red/nodes@3.1.11
      125 silly packumentCache full:https://registry.npmjs.org/@node-red%2fnodes cache-miss
      126 http fetch GET 200 https://registry.npmjs.org/@node-red%2futil 47ms (cache hit)
      127 silly packumentCache full:https://registry.npmjs.org/@node-red%2futil set size:252507 disposed:false
      128 silly fetch manifest @node-red/runtime@3.1.11
      129 silly packumentCache full:https://registry.npmjs.org/@node-red%2fruntime cache-miss
      130 http fetch GET 200 https://registry.npmjs.org/bcryptjs 185ms (cache revalidated)
      131 silly packumentCache full:https://registry.npmjs.org/bcryptjs set size:69957 disposed:false
      132 silly fetch manifest @node-red/editor-api@3.1.11
      133 silly packumentCache full:https://registry.npmjs.org/@node-red%2feditor-api cache-miss
      134 http fetch GET 200 https://registry.npmjs.org/@node-red%2fruntime 65ms (cache hit)
      135 silly packumentCache full:https://registry.npmjs.org/@node-red%2fruntime set size:261300 disposed:false
      136 silly fetch manifest bcrypt@5.1.0
      137 silly packumentCache full:https://registry.npmjs.org/bcrypt cache-hit
      138 silly fetch manifest gridstack@^0.6.4
      139 silly packumentCache full:https://registry.npmjs.org/gridstack cache-miss
      140 http fetch GET 200 https://registry.npmjs.org/@node-red%2fnodes 98ms (cache hit)
      141 silly packumentCache full:https://registry.npmjs.org/@node-red%2fnodes set size:292343 disposed:false
      142 silly fetch manifest socket.io@^4.7.4
      143 silly packumentCache full:https://registry.npmjs.org/socket.io cache-miss
      144 http fetch GET 200 https://registry.npmjs.org/@node-red%2feditor-api 104ms (cache hit)
      145 silly packumentCache full:https://registry.npmjs.org/@node-red%2feditor-api set size:292858 disposed:false
      146 http fetch GET 200 https://registry.npmjs.org/socket.io 121ms (cache revalidated)
      147 silly packumentCache full:https://registry.npmjs.org/socket.io set size:472708 disposed:false
      148 http fetch GET 200 https://registry.npmjs.org/gridstack 625ms (cache revalidated)
      149 silly packumentCache full:https://registry.npmjs.org/gridstack set size:436327 disposed:false
      150 silly placeDep node_modules/bcrypt node-addon-api@5.1.0 OK for: bcrypt@5.1.1 want: ^5.0.0
      151 silly placeDep ROOT @node-red/editor-api@3.1.11 OK for: node-red@3.1.11 want: 3.1.11
      152 silly placeDep ROOT @node-red/nodes@3.1.11 OK for: node-red@3.1.11 want: 3.1.11
      153 silly placeDep ROOT @node-red/runtime@3.1.11 OK for: node-red@3.1.11 want: 3.1.11
      154 silly placeDep ROOT @node-red/util@3.1.11 OK for: node-red@3.1.11 want: 3.1.11
      155 silly placeDep ROOT basic-auth@2.0.1 OK for: node-red@3.1.11 want: 2.0.1
      156 silly placeDep node_modules/node-red bcrypt@5.1.0 OK for: node-red@3.1.11 want: 5.1.0
      157 silly placeDep ROOT bcryptjs@2.4.3 OK for: node-red@3.1.11 want: 2.4.3
      158 silly placeDep node_modules/node-red fs-extra@11.1.1 OK for: node-red@3.1.11 want: 11.1.1
      159 silly placeDep ROOT node-red-admin@3.1.3 OK for: node-red@3.1.11 want: ^3.1.3
      160 silly placeDep node_modules/node-red semver@7.5.4 OK for: node-red@3.1.11 want: 7.5.4
      161 silly fetch manifest ws@7.5.10
      162 silly packumentCache full:https://registry.npmjs.org/ws cache-miss
      163 silly fetch manifest clone@2.1.2
      164 silly packumentCache full:https://registry.npmjs.org/clone cache-miss
      165 silly fetch manifest mustache@4.2.0
      166 silly packumentCache full:https://registry.npmjs.org/mustache cache-miss
      167 http fetch GET 200 https://registry.npmjs.org/clone 49ms (cache hit)
      168 silly packumentCache full:https://registry.npmjs.org/clone set size:82973 disposed:false
      169 silly fetch manifest passport@0.6.0
      170 silly packumentCache full:https://registry.npmjs.org/passport cache-miss
      171 http fetch GET 200 https://registry.npmjs.org/mustache 55ms (cache hit)
      172 silly packumentCache full:https://registry.npmjs.org/mustache set size:166974 disposed:false
      173 silly fetch manifest memorystore@1.6.7
      174 silly packumentCache full:https://registry.npmjs.org/memorystore cache-miss
      175 http fetch GET 200 https://registry.npmjs.org/passport 37ms (cache hit)
      176 silly packumentCache full:https://registry.npmjs.org/passport set size:75538 disposed:false
      177 silly fetch manifest oauth2orize@1.11.1
      178 silly packumentCache full:https://registry.npmjs.org/oauth2orize cache-miss
      179 http fetch GET 200 https://registry.npmjs.org/memorystore 34ms (cache hit)
      180 silly packumentCache full:https://registry.npmjs.org/memorystore set size:53542 disposed:false
      181 silly fetch manifest express-session@1.17.3
      182 silly packumentCache full:https://registry.npmjs.org/express-session cache-miss
      183 http fetch GET 200 https://registry.npmjs.org/ws 135ms (cache revalidated)
      184 silly packumentCache full:https://registry.npmjs.org/ws set size:403597 disposed:false
      185 silly fetch manifest passport-http-bearer@1.0.1
      186 silly packumentCache full:https://registry.npmjs.org/passport-http-bearer cache-miss
      187 http fetch GET 200 https://registry.npmjs.org/oauth2orize 62ms (cache hit)
      188 silly packumentCache full:https://registry.npmjs.org/oauth2orize set size:49754 disposed:false
      189 silly fetch manifest @node-red/editor-client@3.1.11
      190 silly packumentCache full:https://registry.npmjs.org/@node-red%2feditor-client cache-miss
      191 http fetch GET 200 https://registry.npmjs.org/express-session 64ms (cache hit)
      192 silly packumentCache full:https://registry.npmjs.org/express-session set size:190397 disposed:false
      193 silly fetch manifest passport-oauth2-client-password@0.1.2
      194 silly packumentCache full:https://registry.npmjs.org/passport-oauth2-client-password cache-miss
      195 http fetch GET 200 https://registry.npmjs.org/passport-http-bearer 79ms (cache hit)
      196 silly packumentCache full:https://registry.npmjs.org/passport-http-bearer set size:21050 disposed:false
      197 silly fetch manifest ajv@8.12.0
      198 silly packumentCache full:https://registry.npmjs.org/ajv cache-miss
      199 http fetch GET 200 https://registry.npmjs.org/@node-red%2feditor-client 73ms (cache hit)
      200 silly packumentCache full:https://registry.npmjs.org/@node-red%2feditor-client set size:246696 disposed:false
      201 silly fetch manifest uuid@9.0.0
      202 silly packumentCache full:https://registry.npmjs.org/uuid cache-miss
      203 http fetch GET 200 https://registry.npmjs.org/passport-oauth2-client-password 66ms (cache hit)
      204 silly packumentCache full:https://registry.npmjs.org/passport-oauth2-client-password set size:8633 disposed:false
      205 silly fetch manifest acorn@8.8.2
      206 silly packumentCache full:https://registry.npmjs.org/acorn cache-miss
      207 http fetch GET 200 https://registry.npmjs.org/ajv 59ms (cache hit)
      208 silly packumentCache full:https://registry.npmjs.org/ajv set size:1126072 disposed:false
      209 silly fetch manifest cookie@0.5.0
      210 silly packumentCache full:https://registry.npmjs.org/cookie cache-miss
      211 http fetch GET 200 https://registry.npmjs.org/acorn 82ms (cache hit)
      212 silly packumentCache full:https://registry.npmjs.org/acorn set size:402415 disposed:false
      213 silly fetch manifest denque@2.1.0
      214 silly packumentCache full:https://registry.npmjs.org/denque cache-miss
      215 http fetch GET 200 https://registry.npmjs.org/uuid 168ms (cache revalidated)
      216 silly packumentCache full:https://registry.npmjs.org/uuid set size:281614 disposed:false
      217 silly fetch manifest xml2js@0.6.2
      218 silly packumentCache full:https://registry.npmjs.org/xml2js cache-miss
      219 http fetch GET 200 https://registry.npmjs.org/cookie 158ms (cache revalidated)
      220 silly packumentCache full:https://registry.npmjs.org/cookie set size:56274 disposed:false
      221 silly fetch manifest cheerio@1.0.0-rc.10
      222 silly packumentCache full:https://registry.npmjs.org/cheerio cache-miss
      223 http fetch GET 200 https://registry.npmjs.org/xml2js 65ms (cache hit)
      224 silly packumentCache full:https://registry.npmjs.org/xml2js set size:198018 disposed:false
      225 silly fetch manifest hpagent@1.2.0
      226 silly packumentCache full:https://registry.npmjs.org/hpagent cache-miss
      227 http fetch GET 200 https://registry.npmjs.org/cheerio 41ms (cache hit)
      228 silly packumentCache full:https://registry.npmjs.org/cheerio set size:153380 disposed:false
      229 silly fetch manifest is-utf8@0.2.1
      230 silly packumentCache full:https://registry.npmjs.org/is-utf8 cache-miss
      231 http fetch GET 200 https://registry.npmjs.org/denque 197ms (cache revalidated)
      232 silly packumentCache full:https://registry.npmjs.org/denque set size:62908 disposed:false
      233 silly fetch manifest js-yaml@4.1.0
      234 silly packumentCache full:https://registry.npmjs.org/js-yaml cache-miss
      235 http fetch GET 200 https://registry.npmjs.org/hpagent 53ms (cache hit)
      236 silly packumentCache full:https://registry.npmjs.org/hpagent set size:21535 disposed:false
      237 silly fetch manifest cronosjs@1.7.1
      238 silly packumentCache full:https://registry.npmjs.org/cronosjs cache-miss
      239 http fetch GET 200 https://registry.npmjs.org/is-utf8 37ms (cache hit)
      240 silly packumentCache full:https://registry.npmjs.org/is-utf8 set size:4227 disposed:false
      241 silly fetch manifest hash-sum@2.0.0
      242 silly packumentCache full:https://registry.npmjs.org/hash-sum cache-miss
      243 http fetch GET 200 https://registry.npmjs.org/js-yaml 39ms (cache hit)
      244 silly packumentCache full:https://registry.npmjs.org/js-yaml set size:145975 disposed:false
      245 silly fetch manifest acorn-walk@8.2.0
      246 silly packumentCache full:https://registry.npmjs.org/acorn-walk cache-miss
      247 http fetch GET 200 https://registry.npmjs.org/cronosjs 47ms (cache hit)
      248 silly packumentCache full:https://registry.npmjs.org/cronosjs set size:50564 disposed:false
      249 silly fetch manifest iconv-lite@0.6.3
      250 silly packumentCache full:https://registry.npmjs.org/iconv-lite cache-miss
      251 http fetch GET 200 https://registry.npmjs.org/hash-sum 46ms (cache hit)
      252 silly packumentCache full:https://registry.npmjs.org/hash-sum set size:8930 disposed:false
      253 silly fetch manifest node-watch@0.7.4
      254 silly packumentCache full:https://registry.npmjs.org/node-watch cache-miss
      255 http fetch GET 200 https://registry.npmjs.org/acorn-walk 38ms (cache hit)
      256 silly packumentCache full:https://registry.npmjs.org/acorn-walk set size:46497 disposed:false
      257 silly fetch manifest media-typer@1.1.0
      258 silly packumentCache full:https://registry.npmjs.org/media-typer cache-miss
      259 http fetch GET 200 https://registry.npmjs.org/node-watch 35ms (cache hit)
      260 silly packumentCache full:https://registry.npmjs.org/node-watch set size:70587 disposed:false
      261 silly fetch manifest tough-cookie@4.1.3
      262 silly packumentCache full:https://registry.npmjs.org/tough-cookie cache-miss
      263 http fetch GET 200 https://registry.npmjs.org/media-typer 29ms (cache hit)
      264 silly packumentCache full:https://registry.npmjs.org/media-typer set size:20758 disposed:false
      265 silly fetch manifest async-mutex@0.4.0
      266 silly packumentCache full:https://registry.npmjs.org/async-mutex cache-miss
      267 http fetch GET 200 https://registry.npmjs.org/async-mutex 35ms (cache hit)
      268 silly packumentCache full:https://registry.npmjs.org/async-mutex set size:76106 disposed:false
      269 silly fetch manifest @node-red/registry@3.1.11
      270 silly packumentCache full:https://registry.npmjs.org/@node-red%2fregistry cache-miss
      271 http fetch GET 200 https://registry.npmjs.org/iconv-lite 109ms (cache revalidated)
      272 silly packumentCache full:https://registry.npmjs.org/iconv-lite set size:115994 disposed:false
      273 silly fetch manifest i18next@21.10.0
      274 silly packumentCache full:https://registry.npmjs.org/i18next cache-miss
      275 http fetch GET 200 https://registry.npmjs.org/@node-red%2fregistry 35ms (cache hit)
      276 silly packumentCache full:https://registry.npmjs.org/@node-red%2fregistry set size:256258 disposed:false
      277 silly fetch manifest jsonata@1.8.7
      278 silly packumentCache full:https://registry.npmjs.org/jsonata cache-miss
      279 http fetch GET 200 https://registry.npmjs.org/i18next 76ms (cache hit)
      280 silly packumentCache full:https://registry.npmjs.org/i18next set size:2034766 disposed:false
      281 silly fetch manifest moment-timezone@0.5.43
      282 silly packumentCache full:https://registry.npmjs.org/moment-timezone cache-miss
      283 http fetch GET 200 https://registry.npmjs.org/tough-cookie 234ms (cache revalidated)
      284 silly packumentCache full:https://registry.npmjs.org/tough-cookie set size:104042 disposed:false
      285 silly fetch manifest lodash.clonedeep@^4.5.0
      286 silly packumentCache full:https://registry.npmjs.org/lodash.clonedeep cache-miss
      287 http fetch GET 200 https://registry.npmjs.org/jsonata 151ms (cache hit)
      288 silly packumentCache full:https://registry.npmjs.org/jsonata set size:151042 disposed:false
      289 silly fetch manifest axios@^1.6.8
      290 silly packumentCache full:https://registry.npmjs.org/axios cache-miss
      291 http fetch GET 200 https://registry.npmjs.org/moment-timezone 50ms (cache hit)
      292 silly packumentCache full:https://registry.npmjs.org/moment-timezone set size:151083 disposed:false
      293 silly fetch manifest enquirer@^2.3.6
      294 silly packumentCache full:https://registry.npmjs.org/enquirer cache-miss
      295 http fetch GET 200 https://registry.npmjs.org/lodash.clonedeep 51ms (cache hit)
      296 silly packumentCache full:https://registry.npmjs.org/lodash.clonedeep set size:48192 disposed:false
      297 silly fetch manifest minimist@^1.2.8
      298 silly packumentCache full:https://registry.npmjs.org/minimist cache-miss
      299 http fetch GET 200 https://registry.npmjs.org/enquirer 39ms (cache hit)
      300 silly packumentCache full:https://registry.npmjs.org/enquirer set size:203040 disposed:false
      301 silly fetch manifest mustache@^4.2.0
      302 silly packumentCache full:https://registry.npmjs.org/mustache cache-hit
      303 silly fetch manifest cli-table@^0.3.11
      304 silly packumentCache full:https://registry.npmjs.org/cli-table cache-miss
      305 http fetch GET 200 https://registry.npmjs.org/minimist 42ms (cache hit)
      306 silly packumentCache full:https://registry.npmjs.org/minimist set size:77097 disposed:false
      307 silly fetch manifest ansi-colors@^4.1.3
      308 silly packumentCache full:https://registry.npmjs.org/ansi-colors cache-miss
      309 http fetch GET 200 https://registry.npmjs.org/cli-table 24ms (cache hit)
      310 silly packumentCache full:https://registry.npmjs.org/cli-table set size:41739 disposed:false
      311 http fetch GET 200 https://registry.npmjs.org/ansi-colors 27ms (cache hit)
      312 silly packumentCache full:https://registry.npmjs.org/ansi-colors set size:110876 disposed:false
      313 http fetch GET 200 https://registry.npmjs.org/axios 126ms (cache revalidated)
      314 silly packumentCache full:https://registry.npmjs.org/axios set size:738368 disposed:false
      315 silly fetch manifest bufferutil@^4.0.1
      316 silly packumentCache full:https://registry.npmjs.org/bufferutil cache-miss
      317 http fetch GET 200 https://registry.npmjs.org/bufferutil 81ms (cache revalidated)
      318 silly packumentCache full:https://registry.npmjs.org/bufferutil set size:49090 disposed:false
      319 silly fetch manifest utf-8-validate@^5.0.2
      320 silly packumentCache full:https://registry.npmjs.org/utf-8-validate cache-miss
      321 http fetch GET 200 https://registry.npmjs.org/utf-8-validate 77ms (cache revalidated)
      322 silly packumentCache full:https://registry.npmjs.org/utf-8-validate set size:73063 disposed:false
      323 silly placeDep ROOT @node-red/editor-client@3.1.11 OK for: @node-red/editor-api@3.1.11 want: 3.1.11
      324 silly placeDep node_modules/@node-red/editor-api bcrypt@5.1.0 OK for: @node-red/editor-api@3.1.11 want: 5.1.0
      325 silly placeDep ROOT clone@2.1.2 OK for: @node-red/editor-api@3.1.11 want: 2.1.2
      326 silly placeDep ROOT express-session@1.17.3 OK for: @node-red/editor-api@3.1.11 want: 1.17.3
      327 silly placeDep ROOT memorystore@1.6.7 OK for: @node-red/editor-api@3.1.11 want: 1.6.7
      328 silly placeDep ROOT mustache@4.2.0 OK for: @node-red/editor-api@3.1.11 want: 4.2.0
      329 silly placeDep ROOT oauth2orize@1.11.1 OK for: @node-red/editor-api@3.1.11 want: 1.11.1
      330 silly placeDep ROOT passport@0.6.0 OK for: @node-red/editor-api@3.1.11 want: 0.6.0
      331 silly placeDep ROOT passport-http-bearer@1.0.1 OK for: @node-red/editor-api@3.1.11 want: 1.0.1
      332 silly placeDep ROOT passport-oauth2-client-password@0.1.2 OK for: @node-red/editor-api@3.1.11 want: 0.1.2
      333 silly placeDep node_modules/@node-red/editor-api ws@7.5.10 OK for: @node-red/editor-api@3.1.11 want: 7.5.10
      334 silly fetch manifest cookie@0.4.2
      335 silly packumentCache full:https://registry.npmjs.org/cookie cache-hit
      336 silly fetch manifest safe-buffer@5.2.1
      337 silly packumentCache full:https://registry.npmjs.org/safe-buffer cache-miss
      338 silly fetch manifest debug@^4.3.0
      339 silly packumentCache full:https://registry.npmjs.org/debug cache-miss
      340 silly fetch manifest lru-cache@^4.0.3
      341 silly packumentCache full:https://registry.npmjs.org/lru-cache cache-miss
      342 http fetch GET 200 https://registry.npmjs.org/safe-buffer 108ms (cache revalidated)
      343 silly packumentCache full:https://registry.npmjs.org/safe-buffer set size:41183 disposed:false
      344 silly fetch manifest uid2@0.0.x
      345 silly packumentCache full:https://registry.npmjs.org/uid2 cache-miss
      346 http fetch GET 200 https://registry.npmjs.org/lru-cache 129ms (cache revalidated)
      347 silly packumentCache full:https://registry.npmjs.org/lru-cache set size:698785 disposed:false
      348 http fetch GET 200 https://registry.npmjs.org/uid2 61ms (cache hit)
      349 silly packumentCache full:https://registry.npmjs.org/uid2 set size:7931 disposed:false
      350 http fetch GET 200 https://registry.npmjs.org/debug 227ms (cache revalidated)
      351 silly packumentCache full:https://registry.npmjs.org/debug set size:273438 disposed:false
      352 silly placeDep ROOT acorn@8.8.2 OK for: @node-red/nodes@3.1.11 want: 8.8.2
      353 silly placeDep ROOT acorn-walk@8.2.0 OK for: @node-red/nodes@3.1.11 want: 8.2.0
      354 silly placeDep node_modules/@node-red/nodes ajv@8.12.0 OK for: @node-red/nodes@3.1.11 want: 8.12.0
      355 silly placeDep ROOT cheerio@1.0.0-rc.10 OK for: @node-red/nodes@3.1.11 want: 1.0.0-rc.10
      356 silly placeDep node_modules/@node-red/nodes cookie@0.5.0 OK for: @node-red/nodes@3.1.11 want: 0.5.0
      357 silly placeDep ROOT cronosjs@1.7.1 OK for: @node-red/nodes@3.1.11 want: 1.7.1
      358 silly placeDep node_modules/@node-red/nodes denque@2.1.0 OK for: @node-red/nodes@3.1.11 want: 2.1.0
      359 silly placeDep node_modules/@node-red/nodes fs-extra@11.1.1 OK for: @node-red/nodes@3.1.11 want: 11.1.1
      360 silly placeDep ROOT hash-sum@2.0.0 OK for: @node-red/nodes@3.1.11 want: 2.0.0
      361 silly placeDep ROOT hpagent@1.2.0 OK for: @node-red/nodes@3.1.11 want: 1.2.0
      362 silly placeDep node_modules/@node-red/nodes iconv-lite@0.6.3 OK for: @node-red/nodes@3.1.11 want: 0.6.3
      363 silly placeDep ROOT is-utf8@0.2.1 OK for: @node-red/nodes@3.1.11 want: 0.2.1
      364 silly placeDep ROOT js-yaml@4.1.0 OK for: @node-red/nodes@3.1.11 want: 4.1.0
      365 silly placeDep node_modules/@node-red/nodes media-typer@1.1.0 OK for: @node-red/nodes@3.1.11 want: 1.1.0
      366 silly placeDep ROOT node-watch@0.7.4 OK for: @node-red/nodes@3.1.11 want: 0.7.4
      367 silly placeDep node_modules/@node-red/nodes tough-cookie@4.1.3 OK for: @node-red/nodes@3.1.11 want: 4.1.3
      368 silly placeDep node_modules/@node-red/nodes uuid@9.0.0 OK for: @node-red/nodes@3.1.11 want: 9.0.0
      369 silly placeDep node_modules/@node-red/nodes ws@7.5.10 OK for: @node-red/nodes@3.1.11 want: 7.5.10
      370 silly placeDep ROOT xml2js@0.6.2 OK for: @node-red/nodes@3.1.11 want: 0.6.2
      371 silly fetch manifest json-schema-traverse@^1.0.0
      372 silly packumentCache full:https://registry.npmjs.org/json-schema-traverse cache-miss
      373 silly fetch manifest cheerio-select@^1.5.0
      374 silly packumentCache full:https://registry.npmjs.org/cheerio-select cache-miss
      375 silly fetch manifest dom-serializer@^1.3.2
      376 silly packumentCache full:https://registry.npmjs.org/dom-serializer cache-miss
      377 http fetch GET 200 https://registry.npmjs.org/json-schema-traverse 38ms (cache hit)
      378 silly packumentCache full:https://registry.npmjs.org/json-schema-traverse set size:23537 disposed:false
      379 silly fetch manifest domhandler@^4.2.0
      380 silly packumentCache full:https://registry.npmjs.org/domhandler cache-miss
      381 http fetch GET 200 https://registry.npmjs.org/cheerio-select 47ms (cache hit)
      382 silly packumentCache full:https://registry.npmjs.org/cheerio-select set size:36917 disposed:false
      383 silly fetch manifest htmlparser2@^6.1.0
      384 silly packumentCache full:https://registry.npmjs.org/htmlparser2 cache-miss
      385 http fetch GET 200 https://registry.npmjs.org/dom-serializer 54ms (cache hit)
      386 silly packumentCache full:https://registry.npmjs.org/dom-serializer set size:52163 disposed:false
      387 silly fetch manifest parse5@^6.0.1
      388 silly packumentCache full:https://registry.npmjs.org/parse5 cache-miss
      389 http fetch GET 200 https://registry.npmjs.org/domhandler 44ms (cache hit)
      390 silly packumentCache full:https://registry.npmjs.org/domhandler set size:73302 disposed:false
      391 silly fetch manifest parse5-htmlparser2-tree-adapter@^6.0.1
      392 silly packumentCache full:https://registry.npmjs.org/parse5-htmlparser2-tree-adapter cache-miss
      393 http fetch GET 200 https://registry.npmjs.org/htmlparser2 46ms (cache hit)
      394 silly packumentCache full:https://registry.npmjs.org/htmlparser2 set size:159025 disposed:false
      395 silly fetch manifest argparse@^2.0.1
      396 silly packumentCache full:https://registry.npmjs.org/argparse cache-miss
      397 http fetch GET 200 https://registry.npmjs.org/parse5 52ms (cache hit)
      398 silly packumentCache full:https://registry.npmjs.org/parse5 set size:112300 disposed:false
      399 silly fetch manifest universalify@^0.2.0
      400 silly packumentCache full:https://registry.npmjs.org/universalify cache-miss
      401 http fetch GET 200 https://registry.npmjs.org/parse5-htmlparser2-tree-adapter 51ms (cache hit)
      402 silly packumentCache full:https://registry.npmjs.org/parse5-htmlparser2-tree-adapter set size:17650 disposed:false
      403 silly fetch manifest xmlbuilder@~11.0.0
      404 silly packumentCache full:https://registry.npmjs.org/xmlbuilder cache-miss
      405 http fetch GET 200 https://registry.npmjs.org/argparse 55ms (cache hit)
      406 silly packumentCache full:https://registry.npmjs.org/argparse set size:49266 disposed:false
      407 http fetch GET 200 https://registry.npmjs.org/xmlbuilder 31ms (cache hit)
      408 silly packumentCache full:https://registry.npmjs.org/xmlbuilder set size:158707 disposed:false
      409 http fetch GET 200 https://registry.npmjs.org/universalify 80ms (cache revalidated)
      410 silly packumentCache full:https://registry.npmjs.org/universalify set size:19431 disposed:false
      411 silly placeDep ROOT @node-red/registry@3.1.11 OK for: @node-red/runtime@3.1.11 want: 3.1.11
      412 silly placeDep ROOT async-mutex@0.4.0 OK for: @node-red/runtime@3.1.11 want: 0.4.0
      413 silly placeDep node_modules/@node-red/runtime fs-extra@11.1.1 OK for: @node-red/runtime@3.1.11 want: 11.1.1
      414 silly fetch manifest tar@6.2.1
      415 silly packumentCache full:https://registry.npmjs.org/tar cache-miss
      416 silly fetch manifest uglify-js@3.17.4
      417 silly packumentCache full:https://registry.npmjs.org/uglify-js cache-miss
      418 http fetch GET 200 https://registry.npmjs.org/uglify-js 43ms (cache hit)
      419 silly packumentCache full:https://registry.npmjs.org/uglify-js set size:668197 disposed:false
      420 http fetch GET 200 https://registry.npmjs.org/tar 82ms (cache hit)
      421 silly packumentCache full:https://registry.npmjs.org/tar set size:1052143 disposed:false
      422 silly placeDep node_modules/@node-red/registry fs-extra@11.1.1 OK for: @node-red/registry@3.1.11 want: 11.1.1
      423 silly placeDep node_modules/@node-red/registry semver@7.5.4 OK for: @node-red/registry@3.1.11 want: 7.5.4
      424 silly placeDep ROOT tar@6.2.1 REPLACE for: @node-red/registry@3.1.11 want: 6.2.1
      425 silly placeDep ROOT uglify-js@3.17.4 OK for: @node-red/registry@3.1.11 want: 3.17.4
      426 silly placeDep node_modules/@node-red/util fs-extra@11.1.1 OK for: @node-red/util@3.1.11 want: 11.1.1
      427 silly placeDep ROOT i18next@21.10.0 OK for: @node-red/util@3.1.11 want: 21.10.0
      428 silly placeDep ROOT jsonata@1.8.7 OK for: @node-red/util@3.1.11 want: 1.8.7
      429 silly placeDep ROOT lodash.clonedeep@4.5.0 OK for: @node-red/util@3.1.11 want: ^4.5.0
      430 silly placeDep ROOT moment-timezone@0.5.43 OK for: @node-red/util@3.1.11 want: 0.5.43
      431 silly placeDep ROOT cheerio-select@1.6.0 OK for: cheerio@1.0.0-rc.10 want: ^1.5.0
      432 silly placeDep ROOT dom-serializer@1.4.1 OK for: cheerio@1.0.0-rc.10 want: ^1.3.2
      433 silly placeDep ROOT domhandler@4.3.1 OK for: cheerio@1.0.0-rc.10 want: ^4.2.0
      434 silly placeDep ROOT htmlparser2@6.1.0 OK for: cheerio@1.0.0-rc.10 want: ^6.1.0
      435 silly placeDep ROOT parse5@6.0.1 OK for: cheerio@1.0.0-rc.10 want: ^6.0.1
      436 silly placeDep ROOT parse5-htmlparser2-tree-adapter@6.0.1 OK for: cheerio@1.0.0-rc.10 want: ^6.0.1
      437 silly fetch manifest css-select@^4.3.0
      438 silly packumentCache full:https://registry.npmjs.org/css-select cache-miss
      439 silly fetch manifest css-what@^6.0.1
      440 silly packumentCache full:https://registry.npmjs.org/css-what cache-miss
      441 silly fetch manifest domelementtype@^2.2.0
      442 silly packumentCache full:https://registry.npmjs.org/domelementtype cache-miss
      443 http fetch GET 200 https://registry.npmjs.org/css-select 32ms (cache hit)
      444 silly packumentCache full:https://registry.npmjs.org/css-select set size:93710 disposed:false
      445 silly fetch manifest domhandler@^4.3.1
      446 silly packumentCache full:https://registry.npmjs.org/domhandler cache-hit
      447 silly fetch manifest domutils@^2.8.0
      448 silly packumentCache full:https://registry.npmjs.org/domutils cache-miss
      449 http fetch GET 200 https://registry.npmjs.org/css-what 42ms (cache hit)
      450 silly packumentCache full:https://registry.npmjs.org/css-what set size:69087 disposed:false
      451 silly fetch manifest domelementtype@^2.0.1
      452 silly packumentCache full:https://registry.npmjs.org/domelementtype cache-miss
      453 http fetch GET 200 https://registry.npmjs.org/domelementtype 47ms (cache hit)
      454 silly packumentCache full:https://registry.npmjs.org/domelementtype set size:30947 disposed:false
      455 silly fetch manifest entities@^2.0.0
      456 silly packumentCache full:https://registry.npmjs.org/entities cache-miss
      457 http fetch GET 200 https://registry.npmjs.org/domelementtype 40ms (cache hit)
      458 silly packumentCache full:https://registry.npmjs.org/domelementtype set size:30947 disposed:false
      459 silly packumentCache full:https://registry.npmjs.org/domelementtype dispose
      460 silly fetch manifest domutils@^2.5.2
      461 silly packumentCache full:https://registry.npmjs.org/domutils cache-miss
      462 http fetch GET 200 https://registry.npmjs.org/domutils 60ms (cache hit)
      463 silly packumentCache full:https://registry.npmjs.org/domutils set size:94012 disposed:false
      464 silly fetch manifest entities@^2.0.0
      465 silly packumentCache full:https://registry.npmjs.org/entities cache-miss
      466 http fetch GET 200 https://registry.npmjs.org/entities 54ms (cache hit)
      467 silly packumentCache full:https://registry.npmjs.org/entities set size:84558 disposed:false
      468 http fetch GET 200 https://registry.npmjs.org/domutils 50ms (cache hit)
      469 silly packumentCache full:https://registry.npmjs.org/domutils set size:94012 disposed:false
      470 silly packumentCache full:https://registry.npmjs.org/domutils dispose
      471 http fetch GET 200 https://registry.npmjs.org/entities 45ms (cache hit)
      472 silly packumentCache full:https://registry.npmjs.org/entities set size:84558 disposed:false
      473 silly packumentCache full:https://registry.npmjs.org/entities dispose
      474 silly placeDep ROOT css-select@4.3.0 OK for: cheerio-select@1.6.0 want: ^4.3.0
      475 silly placeDep ROOT css-what@6.1.0 OK for: cheerio-select@1.6.0 want: ^6.0.1
      476 silly placeDep ROOT domelementtype@2.3.0 OK for: cheerio-select@1.6.0 want: ^2.2.0
      477 silly placeDep ROOT domutils@2.8.0 OK for: cheerio-select@1.6.0 want: ^2.8.0
      478 silly fetch manifest boolbase@^1.0.0
      479 silly packumentCache full:https://registry.npmjs.org/boolbase cache-miss
      480 silly fetch manifest nth-check@^2.0.1
      481 silly packumentCache full:https://registry.npmjs.org/nth-check cache-miss
      482 http fetch GET 200 https://registry.npmjs.org/boolbase 25ms (cache hit)
      483 silly packumentCache full:https://registry.npmjs.org/boolbase set size:2158 disposed:false
      484 http fetch GET 200 https://registry.npmjs.org/nth-check 22ms (cache hit)
      485 silly packumentCache full:https://registry.npmjs.org/nth-check set size:22975 disposed:false
      486 silly placeDep ROOT boolbase@1.0.0 OK for: css-select@4.3.0 want: ^1.0.0
      487 silly placeDep ROOT nth-check@2.1.1 OK for: css-select@4.3.0 want: ^2.0.1
      488 silly placeDep ROOT entities@2.2.0 OK for: dom-serializer@1.4.1 want: ^2.0.0
      489 silly placeDep node_modules/express-session cookie@0.4.2 OK for: express-session@1.17.3 want: 0.4.2
      490 silly placeDep node_modules/express-session safe-buffer@5.2.1 OK for: express-session@1.17.3 want: 5.2.1
      491 silly placeDep ROOT argparse@2.0.1 OK for: js-yaml@4.1.0 want: ^2.0.1
      492 silly placeDep node_modules/memorystore debug@4.3.5 OK for: memorystore@1.6.7 want: ^4.3.0
      493 silly placeDep node_modules/memorystore lru-cache@4.1.5 OK for: memorystore@1.6.7 want: ^4.0.3
      494 silly fetch manifest ms@2.1.2
      495 silly packumentCache full:https://registry.npmjs.org/ms cache-miss
      496 silly fetch manifest yallist@^2.1.2
      497 silly packumentCache full:https://registry.npmjs.org/yallist cache-miss
      498 silly fetch manifest pseudomap@^1.0.2
      499 silly packumentCache full:https://registry.npmjs.org/pseudomap cache-miss
      500 http fetch GET 200 https://registry.npmjs.org/pseudomap 34ms (cache hit)
      501 silly packumentCache full:https://registry.npmjs.org/pseudomap set size:7129 disposed:false
      502 http fetch GET 200 https://registry.npmjs.org/yallist 38ms (cache hit)
      503 silly packumentCache full:https://registry.npmjs.org/yallist set size:34610 disposed:false
      504 http fetch GET 200 https://registry.npmjs.org/ms 98ms (cache revalidated)
      505 silly packumentCache full:https://registry.npmjs.org/ms set size:84885 disposed:false
      506 silly placeDep ROOT ansi-colors@4.1.3 OK for: node-red-admin@3.1.3 want: ^4.1.3
      507 silly placeDep ROOT axios@1.7.2 OK for: node-red-admin@3.1.3 want: ^1.6.8
      508 silly placeDep ROOT cli-table@0.3.11 OK for: node-red-admin@3.1.3 want: ^0.3.11
      509 silly placeDep ROOT enquirer@2.4.1 OK for: node-red-admin@3.1.3 want: ^2.3.6
      510 silly placeDep node_modules/node-red-admin minimist@1.2.8 OK for: node-red-admin@3.1.3 want: ^1.2.8
      511 silly placeDep ROOT gridstack@0.6.4 OK for: node-red-dashboard@3.6.5 want: ^0.6.4
      512 silly placeDep node_modules/node-red-dashboard socket.io@4.7.5 OK for: node-red-dashboard@3.6.5 want: ^4.7.4
      513 silly fetch manifest jquery@^1.8 || 2 || 3
      514 silly packumentCache full:https://registry.npmjs.org/jquery cache-miss
      515 silly fetch manifest debug@~4.3.2
      516 silly packumentCache full:https://registry.npmjs.org/debug cache-hit
      517 silly fetch manifest base64id@~2.0.0
      518 silly packumentCache full:https://registry.npmjs.org/base64id cache-miss
      519 silly fetch manifest engine.io@~6.5.2
      520 silly packumentCache full:https://registry.npmjs.org/engine.io cache-miss
      521 http fetch GET 200 https://registry.npmjs.org/base64id 87ms (cache revalidated)
      522 silly packumentCache full:https://registry.npmjs.org/base64id set size:6136 disposed:false
      523 silly fetch manifest socket.io-parser@~4.2.4
      524 silly packumentCache full:https://registry.npmjs.org/socket.io-parser cache-miss
      525 http fetch GET 200 https://registry.npmjs.org/jquery 102ms (cache revalidated)
      526 silly packumentCache full:https://registry.npmjs.org/jquery set size:168076 disposed:false
      527 silly fetch manifest socket.io-adapter@~2.5.2
      528 silly packumentCache full:https://registry.npmjs.org/socket.io-adapter cache-miss
      529 http fetch GET 200 https://registry.npmjs.org/engine.io 113ms (cache revalidated)
      530 silly packumentCache full:https://registry.npmjs.org/engine.io set size:545313 disposed:false
      531 http fetch GET 200 https://registry.npmjs.org/socket.io-parser 116ms (cache revalidated)
      532 silly packumentCache full:https://registry.npmjs.org/socket.io-parser set size:129517 disposed:false
      533 http fetch GET 200 https://registry.npmjs.org/socket.io-adapter 129ms (cache revalidated)
      534 silly packumentCache full:https://registry.npmjs.org/socket.io-adapter set size:65427 disposed:false
      535 silly placeDep ROOT jquery@3.7.1 OK for: gridstack@0.6.4 want: ^1.8 || 2 || 3
      536 silly placeDep ROOT uid2@0.0.4 OK for: oauth2orize@1.11.1 want: 0.0.x
      537 silly placeDep ROOT xmlbuilder@11.0.1 OK for: xml2js@0.6.2 want: ~11.0.0
      538 silly placeDep node_modules/@node-red/editor-api node-addon-api@5.1.0 OK for: bcrypt@5.1.0 want: ^5.0.0
      539 silly placeDep node_modules/@node-red/nodes json-schema-traverse@1.0.0 OK for: ajv@8.12.0 want: ^1.0.0
      540 silly placeDep node_modules/@node-red/nodes/node_modules/tough-cookie universalify@0.2.0 OK for: tough-cookie@4.1.3 want: ^0.2.0
      541 silly placeDep node_modules/iobroker.node-red gaxios@5.1.3 OK for: gcp-metadata@5.3.0 want: ^5.0.0
      542 silly placeDep ROOT @mongodb-js/saslprep@1.1.8 OK for: mongodb@6.8.0 want: ^1.1.5
      543 silly placeDep ROOT bson@6.8.0 OK for: mongodb@6.8.0 want: ^6.7.0
      544 silly placeDep ROOT mongodb-connection-string-url@3.0.1 OK for: mongodb@6.8.0 want: ^3.0.0
      545 silly fetch manifest sparse-bitfield@^3.0.3
      546 silly packumentCache full:https://registry.npmjs.org/sparse-bitfield cache-miss
      547 silly fetch manifest whatwg-url@^13.0.0
      548 silly packumentCache full:https://registry.npmjs.org/whatwg-url cache-miss
      549 silly fetch manifest @types/whatwg-url@^11.0.2
      550 silly packumentCache full:https://registry.npmjs.org/@types%2fwhatwg-url cache-miss
      551 http fetch GET 200 https://registry.npmjs.org/sparse-bitfield 29ms (cache hit)
      552 silly packumentCache full:https://registry.npmjs.org/sparse-bitfield set size:18366 disposed:false
      553 http fetch GET 200 https://registry.npmjs.org/@types%2fwhatwg-url 27ms (cache hit)
      554 silly packumentCache full:https://registry.npmjs.org/@types%2fwhatwg-url set size:23973 disposed:false
      555 http fetch GET 200 https://registry.npmjs.org/whatwg-url 35ms (cache hit)
      556 silly packumentCache full:https://registry.npmjs.org/whatwg-url set size:153452 disposed:false
      557 silly placeDep ROOT sparse-bitfield@3.0.3 OK for: @mongodb-js/saslprep@1.1.8 want: ^3.0.3
      558 silly fetch manifest memory-pager@^1.0.2
      559 silly packumentCache full:https://registry.npmjs.org/memory-pager cache-miss
      560 http fetch GET 200 https://registry.npmjs.org/memory-pager 20ms (cache hit)
      561 silly packumentCache full:https://registry.npmjs.org/memory-pager set size:21090 disposed:false
      562 silly placeDep ROOT @types/whatwg-url@11.0.5 OK for: mongodb-connection-string-url@3.0.1 want: ^11.0.2
      563 silly placeDep node_modules/mongodb-connection-string-url whatwg-url@13.0.0 OK for: mongodb-connection-string-url@3.0.1 want: ^13.0.0
      564 silly fetch manifest @types/webidl-conversions@*
      565 silly packumentCache full:https://registry.npmjs.org/@types%2fwebidl-conversions cache-miss
      566 silly fetch manifest tr46@^4.1.1
      567 silly packumentCache full:https://registry.npmjs.org/tr46 cache-miss
      568 silly fetch manifest webidl-conversions@^7.0.0
      569 silly packumentCache full:https://registry.npmjs.org/webidl-conversions cache-miss
      570 http fetch GET 200 https://registry.npmjs.org/@types%2fwebidl-conversions 33ms (cache hit)
      571 silly packumentCache full:https://registry.npmjs.org/@types%2fwebidl-conversions set size:22871 disposed:false
      572 http fetch GET 200 https://registry.npmjs.org/webidl-conversions 33ms (cache hit)
      573 silly packumentCache full:https://registry.npmjs.org/webidl-conversions set size:41857 disposed:false
      574 http fetch GET 200 https://registry.npmjs.org/tr46 40ms (cache hit)
      575 silly packumentCache full:https://registry.npmjs.org/tr46 set size:41044 disposed:false
      576 silly placeDep ROOT @types/webidl-conversions@7.0.3 OK for: @types/whatwg-url@11.0.5 want: *
      577 silly placeDep ROOT memory-pager@1.5.0 OK for: sparse-bitfield@3.0.3 want: ^1.0.2
      578 silly placeDep node_modules/memorystore ms@2.1.2 OK for: debug@4.3.5 want: 2.1.2
      579 silly placeDep ROOT pseudomap@1.0.2 OK for: lru-cache@4.1.5 want: ^1.0.2
      580 silly placeDep node_modules/memorystore yallist@2.1.2 OK for: lru-cache@4.1.5 want: ^2.1.2
      581 silly placeDep node_modules/mongodb-connection-string-url tr46@4.1.1 OK for: whatwg-url@13.0.0 want: ^4.1.1
      582 silly placeDep node_modules/mongodb-connection-string-url webidl-conversions@7.0.0 OK for: whatwg-url@13.0.0 want: ^7.0.0
      583 silly placeDep node_modules/node-red-dashboard base64id@2.0.0 OK for: socket.io@4.7.5 want: ~2.0.0
      584 silly placeDep node_modules/node-red-dashboard debug@4.3.5 OK for: socket.io@4.7.5 want: ~4.3.2
      585 silly placeDep node_modules/node-red-dashboard engine.io@6.5.5 OK for: socket.io@4.7.5 want: ~6.5.2
      586 silly placeDep node_modules/node-red-dashboard socket.io-adapter@2.5.5 OK for: socket.io@4.7.5 want: ~2.5.2
      587 silly placeDep node_modules/node-red-dashboard socket.io-parser@4.2.4 OK for: socket.io@4.7.5 want: ~4.2.4
      588 silly fetch manifest ws@~8.17.1
      589 silly packumentCache full:https://registry.npmjs.org/ws cache-hit
      590 silly fetch manifest @types/cors@^2.8.12
      591 silly packumentCache full:https://registry.npmjs.org/@types%2fcors cache-miss
      592 silly fetch manifest @types/cookie@^0.4.1
      593 silly packumentCache full:https://registry.npmjs.org/@types%2fcookie cache-miss
      594 silly fetch manifest engine.io-parser@~5.2.1
      595 silly packumentCache full:https://registry.npmjs.org/engine.io-parser cache-miss
      596 http fetch GET 200 https://registry.npmjs.org/@types%2fcors 150ms (cache revalidated)
      597 silly packumentCache full:https://registry.npmjs.org/@types%2fcors set size:53617 disposed:false
      598 silly fetch manifest @socket.io/component-emitter@~3.1.0
      599 silly packumentCache full:https://registry.npmjs.org/@socket.io%2fcomponent-emitter cache-miss
      600 http fetch GET 200 https://registry.npmjs.org/@types%2fcookie 203ms (cache revalidated)
      601 silly packumentCache full:https://registry.npmjs.org/@types%2fcookie set size:38525 disposed:false
      602 http fetch GET 200 https://registry.npmjs.org/engine.io-parser 214ms (cache revalidated)
      603 silly packumentCache full:https://registry.npmjs.org/engine.io-parser set size:116455 disposed:false
      604 http fetch GET 200 https://registry.npmjs.org/@socket.io%2fcomponent-emitter 178ms (cache revalidated)
      605 silly packumentCache full:https://registry.npmjs.org/@socket.io%2fcomponent-emitter set size:14099 disposed:false
      606 silly placeDep node_modules/node-red-dashboard ms@2.1.2 OK for: debug@4.3.5 want: 2.1.2
      607 silly fetch manifest utf-8-validate@>=5.0.2
      608 silly packumentCache full:https://registry.npmjs.org/utf-8-validate cache-hit
      609 silly placeDep ROOT @types/cookie@0.4.1 OK for: engine.io@6.5.5 want: ^0.4.1
      610 silly placeDep ROOT @types/cors@2.8.17 OK for: engine.io@6.5.5 want: ^2.8.12
      611 silly placeDep node_modules/node-red-dashboard engine.io-parser@5.2.3 OK for: engine.io@6.5.5 want: ~5.2.1
      612 silly placeDep node_modules/node-red-dashboard ws@8.17.1 OK for: engine.io@6.5.5 want: ~8.17.1
      613 silly placeDep ROOT @socket.io/component-emitter@3.1.2 OK for: socket.io-parser@4.2.4 want: ~3.1.0
      614 silly placeDep node_modules/node-red node-addon-api@5.1.0 OK for: bcrypt@5.1.0 want: ^5.0.0
      615 silly reify mark retired [
      615 silly reify   '/opt/iobroker/node_modules/acorn',
      615 silly reify   '/opt/iobroker/node_modules/.bin/acorn'
      615 silly reify ]
      616 silly reify mark retired [ '/opt/iobroker/node_modules/async-mutex' ]
      617 silly reify mark retired [ '/opt/iobroker/node_modules/axios' ]
      618 silly reify mark retired [ '/opt/iobroker/node_modules/bcrypt' ]
      619 silly reify mark retired [ '/opt/iobroker/node_modules/bowser' ]
      620 silly reify mark retired [ '/opt/iobroker/node_modules/bson' ]
      621 silly reify mark retired [ '/opt/iobroker/node_modules/hpagent' ]
      622 silly reify mark retired [ '/opt/iobroker/node_modules/i18next' ]
      623 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.admin/node_modules/axios' ]
      624 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.backitup/node_modules/axios' ]
      625 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/axios' ]
      626 silly reify mark retired [
      626 silly reify   '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/axios'
      626 silly reify ]
      627 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.mercedesme/node_modules/axios' ]
      628 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.node-red' ]
      629 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.solarmanpv/node_modules/axios' ]
      630 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.tuya/node_modules/axios' ]
      631 silly reify mark retired [ '/opt/iobroker/node_modules/jquery' ]
      632 silly reify mark retired [ '/opt/iobroker/node_modules/jsonata' ]
      633 silly reify mark retired [ '/opt/iobroker/node_modules/memorystore/node_modules/debug' ]
      634 silly reify mark retired [ '/opt/iobroker/node_modules/moment-timezone' ]
      635 silly reify mark retired [ '/opt/iobroker/node_modules/mongodb' ]
      636 silly reify mark retired [ '/opt/iobroker/node_modules/mongodb-connection-string-url' ]
      637 silly reify mark retired [
      637 silly reify   '/opt/iobroker/node_modules/node-red',
      637 silly reify   '/opt/iobroker/node_modules/.bin/node-red',
      637 silly reify   '/opt/iobroker/node_modules/.bin/node-red-pi'
      637 silly reify ]
      638 silly reify mark retired [
      638 silly reify   '/opt/iobroker/node_modules/node-red-admin',
      638 silly reify   '/opt/iobroker/node_modules/.bin/node-red-admin'
      638 silly reify ]
      639 silly reify mark retired [ '/opt/iobroker/node_modules/node-red-node-email' ]
      640 silly reify mark retired [ '/opt/iobroker/node_modules/node-watch' ]
      641 silly reify mark retired [ '/opt/iobroker/node_modules/saslprep' ]
      642 silly reify mark retired [ '/opt/iobroker/node_modules/tar' ]
      643 silly reify mark retired [
      643 silly reify   '/opt/iobroker/node_modules/uglify-js',
      643 silly reify   '/opt/iobroker/node_modules/.bin/uglifyjs'
      643 silly reify ]
      644 silly reify mark retired [ '/opt/iobroker/node_modules/node-red-dashboard' ]
      645 silly reify mark retired [ '/opt/iobroker/node_modules/xml2js' ]
      646 silly reify mark retired [
      646 silly reify   '/opt/iobroker/node_modules/@all-smart/all-smart-tools/node_modules/axios'
      646 silly reify ]
      647 silly reify mark retired [ '/opt/iobroker/node_modules/@aws-crypto/crc32' ]
      648 silly reify mark retired [ '/opt/iobroker/node_modules/@aws-crypto/ie11-detection' ]
      649 silly reify mark retired [ '/opt/iobroker/node_modules/@aws-crypto/sha256-browser' ]
      650 silly reify mark retired [ '/opt/iobroker/node_modules/@aws-crypto/sha256-js' ]
      651 silly reify mark retired [ '/opt/iobroker/node_modules/@aws-crypto/supports-web-crypto' ]
      652 silly reify mark retired [ '/opt/iobroker/node_modules/@aws-crypto/util' ]
      653 silly reify mark retired [ '/opt/iobroker/node_modules/@aws-sdk/client-cognito-identity' ]
      654 silly reify mark retired [ '/opt/iobroker/node_modules/@aws-sdk/client-sso' ]
      655 silly reify mark retired [ '/opt/iobroker/node_modules/@aws-sdk/client-sts' ]
      656 silly reify mark retired [
      656 silly reify   '/opt/iobroker/node_modules/@aws-sdk/credential-provider-cognito-identity'
      656 silly reify ]
      657 silly reify mark retired [ '/opt/iobroker/node_modules/@aws-sdk/credential-provider-env' ]
      658 silly reify mark retired [ '/opt/iobroker/node_modules/@aws-sdk/credential-provider-ini' ]
      659 silly reify mark retired [ '/opt/iobroker/node_modules/@aws-sdk/credential-provider-sso' ]
      660 silly reify mark retired [ '/opt/iobroker/node_modules/@aws-sdk/credential-provider-node' ]
      661 silly reify mark retired [ '/opt/iobroker/node_modules/@aws-sdk/credential-provider-process' ]
      662 silly reify mark retired [ '/opt/iobroker/node_modules/@aws-sdk/middleware-logger' ]
      663 silly reify mark retired [
      663 silly reify   '/opt/iobroker/node_modules/@aws-sdk/middleware-recursion-detection'
      663 silly reify ]
      664 silly reify mark retired [ '/opt/iobroker/node_modules/@aws-sdk/middleware-sdk-sts' ]
      665 silly reify mark retired [
      665 silly reify   '/opt/iobroker/node_modules/@aws-sdk/credential-provider-web-identity'
      665 silly reify ]
      666 silly reify mark retired [ '/opt/iobroker/node_modules/@aws-sdk/middleware-user-agent' ]
      667 silly reify mark retired [ '/opt/iobroker/node_modules/@aws-sdk/middleware-signing' ]
      668 silly reify mark retired [ '/opt/iobroker/node_modules/@aws-sdk/middleware-host-header' ]
      669 silly reify mark retired [ '/opt/iobroker/node_modules/@aws-sdk/util-endpoints' ]
      670 silly reify mark retired [ '/opt/iobroker/node_modules/@aws-sdk/types' ]
      671 silly reify mark retired [ '/opt/iobroker/node_modules/@aws-sdk/token-providers' ]
      672 silly reify mark retired [ '/opt/iobroker/node_modules/@aws-sdk/util-user-agent-browser' ]
      673 silly reify mark retired [ '/opt/iobroker/node_modules/@aws-sdk/util-user-agent-node' ]
      674 silly reify mark retired [ '/opt/iobroker/node_modules/@aws-sdk/util-utf8-browser' ]
      675 silly reify mark retired [ '/opt/iobroker/node_modules/@aws-sdk/util-locate-window' ]
      676 silly reify mark retired [
      676 silly reify   '/opt/iobroker/node_modules/@iobroker/js-controller-cli/node_modules/axios'
      676 silly reify ]
      677 silly reify mark retired [
      677 silly reify   '/opt/iobroker/node_modules/@iobroker/js-controller-common/node_modules/axios'
      677 silly reify ]
      678 silly reify mark retired [
      678 silly reify   '/opt/iobroker/node_modules/@iobroker/socket-classes/node_modules/axios'
      678 silly reify ]
      679 silly reify mark retired [ '/opt/iobroker/node_modules/@node-red/editor-api' ]
      680 silly reify mark retired [ '/opt/iobroker/node_modules/@node-red/editor-client' ]
      681 silly reify mark retired [ '/opt/iobroker/node_modules/@node-red/nodes' ]
      682 silly reify mark retired [ '/opt/iobroker/node_modules/@node-red/registry' ]
      683 silly reify mark retired [ '/opt/iobroker/node_modules/@node-red/runtime' ]
      684 silly reify mark retired [ '/opt/iobroker/node_modules/@node-red/util' ]
      685 silly reify mark retired [ '/opt/iobroker/node_modules/@smithy/abort-controller' ]
      686 silly reify mark retired [ '/opt/iobroker/node_modules/@smithy/credential-provider-imds' ]
      687 silly reify mark retired [ '/opt/iobroker/node_modules/@smithy/config-resolver' ]
      688 silly reify mark retired [ '/opt/iobroker/node_modules/@smithy/eventstream-codec' ]
      689 silly reify mark retired [ '/opt/iobroker/node_modules/@smithy/fetch-http-handler' ]
      690 silly reify mark retired [ '/opt/iobroker/node_modules/@smithy/hash-node' ]
      691 silly reify mark retired [ '/opt/iobroker/node_modules/@smithy/is-array-buffer' ]
      692 silly reify mark retired [ '/opt/iobroker/node_modules/@smithy/invalid-dependency' ]
      693 silly reify mark retired [ '/opt/iobroker/node_modules/@smithy/middleware-content-length' ]
      694 silly reify mark retired [ '/opt/iobroker/node_modules/@smithy/middleware-endpoint' ]
      695 silly reify mark retired [ '/opt/iobroker/node_modules/@smithy/middleware-retry' ]
      696 silly reify mark retired [ '/opt/iobroker/node_modules/@smithy/middleware-serde' ]
      697 silly reify mark retired [ '/opt/iobroker/node_modules/@smithy/middleware-stack' ]
      698 silly reify mark retired [ '/opt/iobroker/node_modules/@smithy/node-config-provider' ]
      699 silly reify mark retired [ '/opt/iobroker/node_modules/@smithy/node-http-handler' ]
      700 silly reify mark retired [ '/opt/iobroker/node_modules/@smithy/property-provider' ]
      701 silly reify mark retired [ '/opt/iobroker/node_modules/@smithy/protocol-http' ]
      702 silly reify mark retired [ '/opt/iobroker/node_modules/@smithy/querystring-builder' ]
      703 silly reify mark retired [ '/opt/iobroker/node_modules/@smithy/querystring-parser' ]
      704 silly reify mark retired [ '/opt/iobroker/node_modules/@smithy/service-error-classification' ]
      705 silly reify mark retired [ '/opt/iobroker/node_modules/@smithy/shared-ini-file-loader' ]
      706 silly reify mark retired [ '/opt/iobroker/node_modules/@smithy/signature-v4' ]
      707 silly reify mark retired [ '/opt/iobroker/node_modules/@smithy/smithy-client' ]
      708 silly reify mark retired [ '/opt/iobroker/node_modules/@smithy/types' ]
      709 silly reify mark retired [ '/opt/iobroker/node_modules/@smithy/util-base64' ]
      710 silly reify mark retired [ '/opt/iobroker/node_modules/@smithy/util-body-length-browser' ]
      711 silly reify mark retired [ '/opt/iobroker/node_modules/@smithy/url-parser' ]
      712 silly reify mark retired [ '/opt/iobroker/node_modules/@smithy/util-buffer-from' ]
      713 silly reify mark retired [ '/opt/iobroker/node_modules/@smithy/util-config-provider' ]
      714 silly reify mark retired [ '/opt/iobroker/node_modules/@smithy/util-defaults-mode-browser' ]
      715 silly reify mark retired [ '/opt/iobroker/node_modules/@aws-sdk/credential-providers' ]
      716 silly reify mark retired [ '/opt/iobroker/node_modules/@smithy/util-hex-encoding' ]
      717 silly reify mark retired [ '/opt/iobroker/node_modules/@smithy/util-middleware' ]
      718 silly reify mark retired [ '/opt/iobroker/node_modules/@smithy/util-defaults-mode-node' ]
      719 silly reify mark retired [ '/opt/iobroker/node_modules/@smithy/util-stream' ]
      720 silly reify mark retired [ '/opt/iobroker/node_modules/@smithy/util-body-length-node' ]
      721 silly reify mark retired [ '/opt/iobroker/node_modules/@smithy/util-utf8' ]
      722 silly reify mark retired [ '/opt/iobroker/node_modules/@smithy/util-uri-escape' ]
      723 silly reify mark retired [ '/opt/iobroker/node_modules/@smithy/util-retry' ]
      724 silly reify mark retired [ '/opt/iobroker/node_modules/@types/cors' ]
      725 silly reify mark retired [ '/opt/iobroker/node_modules/@socket.io/component-emitter' ]
      726 silly reify mark retired [ '/opt/iobroker/node_modules/@types/webidl-conversions' ]
      727 silly reify mark retired [ '/opt/iobroker/node_modules/@types/whatwg-url' ]
      728 silly reify moves {
      728 silly reify   '/opt/iobroker/node_modules/acorn': '/opt/iobroker/node_modules/.acorn-zHERliMH',
      728 silly reify   '/opt/iobroker/node_modules/.bin/acorn': '/opt/iobroker/node_modules/.bin/.acorn-opeYtUKW',
      728 silly reify   '/opt/iobroker/node_modules/async-mutex': '/opt/iobroker/node_modules/.async-mutex-v1UbUde2',
      728 silly reify   '/opt/iobroker/node_modules/axios': '/opt/iobroker/node_modules/.axios-5PaJDuuS',
      728 silly reify   '/opt/iobroker/node_modules/bcrypt': '/opt/iobroker/node_modules/.bcrypt-8Ovo54hd',
      728 silly reify   '/opt/iobroker/node_modules/bowser': '/opt/iobroker/node_modules/.bowser-56iUmeAs',
      728 silly reify   '/opt/iobroker/node_modules/bson': '/opt/iobroker/node_modules/.bson-a4WfR2fa',
      728 silly reify   '/opt/iobroker/node_modules/hpagent': '/opt/iobroker/node_modules/.hpagent-PUXuWBzq',
      728 silly reify   '/opt/iobroker/node_modules/i18next': '/opt/iobroker/node_modules/.i18next-VFNyugyK',
      728 silly reify   '/opt/iobroker/node_modules/iobroker.admin/node_modules/axios': '/opt/iobroker/node_modules/iobroker.admin/node_modules/.axios-Q9TUoZm1',
      728 silly reify   '/opt/iobroker/node_modules/iobroker.backitup/node_modules/axios': '/opt/iobroker/node_modules/iobroker.backitup/node_modules/.axios-i9L9XBwz',
      728 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/axios': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.axios-2R4cHyIW',
      728 silly reify   '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/axios': '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/.axios-TL0CRlAQ',
      728 silly reify   '/opt/iobroker/node_modules/iobroker.mercedesme/node_modules/axios': '/opt/iobroker/node_modules/iobroker.mercedesme/node_modules/.axios-vJNIurWP',
      728 silly reify   '/opt/iobroker/node_modules/iobroker.node-red': '/opt/iobroker/node_modules/.iobroker.node-red-lv0iVi6J',
      728 silly reify   '/opt/iobroker/node_modules/iobroker.solarmanpv/node_modules/axios': '/opt/iobroker/node_modules/iobroker.solarmanpv/node_modules/.axios-xMcIWHZ5',
      728 silly reify   '/opt/iobroker/node_modules/iobroker.tuya/node_modules/axios': '/opt/iobroker/node_modules/iobroker.tuya/node_modules/.axios-Cqczfzc8',
      728 silly reify   '/opt/iobroker/node_modules/jquery': '/opt/iobroker/node_modules/.jquery-ACeJZQfz',
      728 silly reify   '/opt/iobroker/node_modules/jsonata': '/opt/iobroker/node_modules/.jsonata-ac7WxDRN',
      728 silly reify   '/opt/iobroker/node_modules/memorystore/node_modules/debug': '/opt/iobroker/node_modules/memorystore/node_modules/.debug-U1L8CFgF',
      728 silly reify   '/opt/iobroker/node_modules/moment-timezone': '/opt/iobroker/node_modules/.moment-timezone-LVF6Tkme',
      728 silly reify   '/opt/iobroker/node_modules/mongodb': '/opt/iobroker/node_modules/.mongodb-9LMcV19S',
      728 silly reify   '/opt/iobroker/node_modules/mongodb-connection-string-url': '/opt/iobroker/node_modules/.mongodb-connection-string-url-iEu3f9Lf',
      728 silly reify   '/opt/iobroker/node_modules/node-red': '/opt/iobroker/node_modules/.node-red-Kvc6EPdV',
      728 silly reify   '/opt/iobroker/node_modules/.bin/node-red': '/opt/iobroker/node_modules/.bin/.node-red-sdXvnEer',
      728 silly reify   '/opt/iobroker/node_modules/.bin/node-red-pi': '/opt/iobroker/node_modules/.bin/.node-red-pi-ATJhhobv',
      728 silly reify   '/opt/iobroker/node_modules/node-red-admin': '/opt/iobroker/node_modules/.node-red-admin-97cICUzY',
      728 silly reify   '/opt/iobroker/node_modules/.bin/node-red-admin': '/opt/iobroker/node_modules/.bin/.node-red-admin-FCYEkrmv',
      728 silly reify   '/opt/iobroker/node_modules/node-red-node-email': '/opt/iobroker/node_modules/.node-red-node-email-1lk8B7Gi',
      728 silly reify   '/opt/iobroker/node_modules/node-watch': '/opt/iobroker/node_modules/.node-watch-wsk0f2Sy',
      728 silly reify   '/opt/iobroker/node_modules/saslprep': '/opt/iobroker/node_modules/.saslprep-yq5ZciVQ',
      728 silly reify   '/opt/iobroker/node_modules/tar': '/opt/iobroker/node_modules/.tar-NeTPgzH9',
      728 silly reify   '/opt/iobroker/node_modules/uglify-js': '/opt/iobroker/node_modules/.uglify-js-UrZ3Klfa',
      728 silly reify   '/opt/iobroker/node_modules/.bin/uglifyjs': '/opt/iobroker/node_modules/.bin/.uglifyjs-Uwoamhq6',
      728 silly reify   '/opt/iobroker/node_modules/node-red-dashboard': '/opt/iobroker/node_modules/.node-red-dashboard-CS23xq7j',
      728 silly reify   '/opt/iobroker/node_modules/xml2js': '/opt/iobroker/node_modules/.xml2js-Lfry6Pso',
      728 silly reify   '/opt/iobroker/node_modules/@all-smart/all-smart-tools/node_modules/axios': '/opt/iobroker/node_modules/@all-smart/all-smart-tools/node_modules/.axios-6AJNkIQu',
      728 silly reify   '/opt/iobroker/node_modules/@aws-crypto/crc32': '/opt/iobroker/node_modules/@aws-crypto/.crc32-2qvdxAXm',
      728 silly reify   '/opt/iobroker/node_modules/@aws-crypto/ie11-detection': '/opt/iobroker/node_modules/@aws-crypto/.ie11-detection-buBWtyK6',
      728 silly reify   '/opt/iobroker/node_modules/@aws-crypto/sha256-browser': '/opt/iobroker/node_modules/@aws-crypto/.sha256-browser-YHG7eKdP',
      728 silly reify   '/opt/iobroker/node_modules/@aws-crypto/sha256-js': '/opt/iobroker/node_modules/@aws-crypto/.sha256-js-UXukO4bx',
      728 silly reify   '/opt/iobroker/node_modules/@aws-crypto/supports-web-crypto': '/opt/iobroker/node_modules/@aws-crypto/.supports-web-crypto-n0WmllSP',
      728 silly reify   '/opt/iobroker/node_modules/@aws-crypto/util': '/opt/iobroker/node_modules/@aws-crypto/.util-LbU717D6',
      728 silly reify   '/opt/iobroker/node_modules/@aws-sdk/client-cognito-identity': '/opt/iobroker/node_modules/@aws-sdk/.client-cognito-identity-DQz62nSx',
      728 silly reify   '/opt/iobroker/node_modules/@aws-sdk/client-sso': '/opt/iobroker/node_modules/@aws-sdk/.client-sso-jqbPaV54',
      728 silly reify   '/opt/iobroker/node_modules/@aws-sdk/client-sts': '/opt/iobroker/node_modules/@aws-sdk/.client-sts-LRuKFTID',
      728 silly reify   '/opt/iobroker/node_modules/@aws-sdk/credential-provider-cognito-identity': '/opt/iobroker/node_modules/@aws-sdk/.credential-provider-cognito-identity-JnTBQbmL',
      728 silly reify   '/opt/iobroker/node_modules/@aws-sdk/credential-provider-env': '/opt/iobroker/node_modules/@aws-sdk/.credential-provider-env-JPGCLPqz',
      728 silly reify   '/opt/iobroker/node_modules/@aws-sdk/credential-provider-ini': '/opt/iobroker/node_modules/@aws-sdk/.credential-provider-ini-zXh5SQbn',
      728 silly reify   '/opt/iobroker/node_modules/@aws-sdk/credential-provider-sso': '/opt/iobroker/node_modules/@aws-sdk/.credential-provider-sso-WMGiUccz',
      728 silly reify   '/opt/iobroker/node_modules/@aws-sdk/credential-provider-node': '/opt/iobroker/node_modules/@aws-sdk/.credential-provider-node-Mo2kb5bF',
      728 silly reify   '/opt/iobroker/node_modules/@aws-sdk/credential-provider-process': '/opt/iobroker/node_modules/@aws-sdk/.credential-provider-process-Wj43WFS4',
      728 silly reify   '/opt/iobroker/node_modules/@aws-sdk/middleware-logger': '/opt/iobroker/node_modules/@aws-sdk/.middleware-logger-2genaDhe',
      728 silly reify   '/opt/iobroker/node_modules/@aws-sdk/middleware-recursion-detection': '/opt/iobroker/node_modules/@aws-sdk/.middleware-recursion-detection-ORXn6T8A',
      728 silly reify   '/opt/iobroker/node_modules/@aws-sdk/middleware-sdk-sts': '/opt/iobroker/node_modules/@aws-sdk/.middleware-sdk-sts-qq2Tu11e',
      728 silly reify   '/opt/iobroker/node_modules/@aws-sdk/credential-provider-web-identity': '/opt/iobroker/node_modules/@aws-sdk/.credential-provider-web-identity-M11oJgIX',
      728 silly reify   '/opt/iobroker/node_modules/@aws-sdk/middleware-user-agent': '/opt/iobroker/node_modules/@aws-sdk/.middleware-user-agent-N2RtWtft',
      728 silly reify   '/opt/iobroker/node_modules/@aws-sdk/middleware-signing': '/opt/iobroker/node_modules/@aws-sdk/.middleware-signing-Ub4olEe4',
      728 silly reify   '/opt/iobroker/node_modules/@aws-sdk/middleware-host-header': '/opt/iobroker/node_modules/@aws-sdk/.middleware-host-header-9qzQCAKg',
      728 silly reify   '/opt/iobroker/node_modules/@aws-sdk/util-endpoints': '/opt/iobroker/node_modules/@aws-sdk/.util-endpoints-mAzEvP4G',
      728 silly reify   '/opt/iobroker/node_modules/@aws-sdk/types': '/opt/iobroker/node_modules/@aws-sdk/.types-qurPIL6Q',
      728 silly reify   '/opt/iobroker/node_modules/@aws-sdk/token-providers': '/opt/iobroker/node_modules/@aws-sdk/.token-providers-znWOHS5k',
      728 silly reify   '/opt/iobroker/node_modules/@aws-sdk/util-user-agent-browser': '/opt/iobroker/node_modules/@aws-sdk/.util-user-agent-browser-4OXT55JU',
      728 silly reify   '/opt/iobroker/node_modules/@aws-sdk/util-user-agent-node': '/opt/iobroker/node_modules/@aws-sdk/.util-user-agent-node-pfM2OfAB',
      728 silly reify   '/opt/iobroker/node_modules/@aws-sdk/util-utf8-browser': '/opt/iobroker/node_modules/@aws-sdk/.util-utf8-browser-mSlCXiLY',
      728 silly reify   '/opt/iobroker/node_modules/@aws-sdk/util-locate-window': '/opt/iobroker/node_modules/@aws-sdk/.util-locate-window-S2iYf9Xy',
      728 silly reify   '/opt/iobroker/node_modules/@iobroker/js-controller-cli/node_modules/axios': '/opt/iobroker/node_modules/@iobroker/js-controller-cli/node_modules/.axios-31kUdCD1',
      728 silly reify   '/opt/iobroker/node_modules/@iobroker/js-controller-common/node_modules/axios': '/opt/iobroker/node_modules/@iobroker/js-controller-common/node_modules/.axios-rqZYoONk',
      728 silly reify   '/opt/iobroker/node_modules/@iobroker/socket-classes/node_modules/axios': '/opt/iobroker/node_modules/@iobroker/socket-classes/node_modules/.axios-9M3r5m0C',
      728 silly reify   '/opt/iobroker/node_modules/@node-red/editor-api': '/opt/iobroker/node_modules/@node-red/.editor-api-Xk7v1FU7',
      728 silly reify   '/opt/iobroker/node_modules/@node-red/editor-client': '/opt/iobroker/node_modules/@node-red/.editor-client-FpqhSpDH',
      728 silly reify   '/opt/iobroker/node_modules/@node-red/nodes': '/opt/iobroker/node_modules/@node-red/.nodes-oC2yqxJN',
      728 silly reify   '/opt/iobroker/node_modules/@node-red/registry': '/opt/iobroker/node_modules/@node-red/.registry-ccnbcuRd',
      728 silly reify   '/opt/iobroker/node_modules/@node-red/runtime': '/opt/iobroker/node_modules/@node-red/.runtime-1jQRdxlO',
      728 silly reify   '/opt/iobroker/node_modules/@node-red/util': '/opt/iobroker/node_modules/@node-red/.util-sbKUIGKV',
      728 silly reify   '/opt/iobroker/node_modules/@smithy/abort-controller': '/opt/iobroker/node_modules/@smithy/.abort-controller-4wmJMSym',
      728 silly reify   '/opt/iobroker/node_modules/@smithy/credential-provider-imds': '/opt/iobroker/node_modules/@smithy/.credential-provider-imds-dElcmsmz',
      728 silly reify   '/opt/iobroker/node_modules/@smithy/config-resolver': '/opt/iobroker/node_modules/@smithy/.config-resolver-8Cpk4o9u',
      728 silly reify   '/opt/iobroker/node_modules/@smithy/eventstream-codec': '/opt/iobroker/node_modules/@smithy/.eventstream-codec-GulrrnS3',
      728 silly reify   '/opt/iobroker/node_modules/@smithy/fetch-http-handler': '/opt/iobroker/node_modules/@smithy/.fetch-http-handler-izuU0dgo',
      728 silly reify   '/opt/iobroker/node_modules/@smithy/hash-node': '/opt/iobroker/node_modules/@smithy/.hash-node-Z1CaPIGm',
      728 silly reify   '/opt/iobroker/node_modules/@smithy/is-array-buffer': '/opt/iobroker/node_modules/@smithy/.is-array-buffer-xuIKwdkA',
      728 silly reify   '/opt/iobroker/node_modules/@smithy/invalid-dependency': '/opt/iobroker/node_modules/@smithy/.invalid-dependency-51b0sycL',
      728 silly reify   '/opt/iobroker/node_modules/@smithy/middleware-content-length': '/opt/iobroker/node_modules/@smithy/.middleware-content-length-kkShKOWu',
      728 silly reify   '/opt/iobroker/node_modules/@smithy/middleware-endpoint': '/opt/iobroker/node_modules/@smithy/.middleware-endpoint-h6kLJyxX',
      728 silly reify   '/opt/iobroker/node_modules/@smithy/middleware-retry': '/opt/iobroker/node_modules/@smithy/.middleware-retry-MwysznO1',
      728 silly reify   '/opt/iobroker/node_modules/@smithy/middleware-serde': '/opt/iobroker/node_modules/@smithy/.middleware-serde-vbULXTWU',
      728 silly reify   '/opt/iobroker/node_modules/@smithy/middleware-stack': '/opt/iobroker/node_modules/@smithy/.middleware-stack-3ja6ACVh',
      728 silly reify   '/opt/iobroker/node_modules/@smithy/node-config-provider': '/opt/iobroker/node_modules/@smithy/.node-config-provider-jt3XDfsp',
      728 silly reify   '/opt/iobroker/node_modules/@smithy/node-http-handler': '/opt/iobroker/node_modules/@smithy/.node-http-handler-fv8Q5Gt6',
      728 silly reify   '/opt/iobroker/node_modules/@smithy/property-provider': '/opt/iobroker/node_modules/@smithy/.property-provider-XMwEHS4r',
      728 silly reify   '/opt/iobroker/node_modules/@smithy/protocol-http': '/opt/iobroker/node_modules/@smithy/.protocol-http-M7ETbcp0',
      728 silly reify   '/opt/iobroker/node_modules/@smithy/querystring-builder': '/opt/iobroker/node_modules/@smithy/.querystring-builder-slt60a6j',
      728 silly reify   '/opt/iobroker/node_modules/@smithy/querystring-parser': '/opt/iobroker/node_modules/@smithy/.querystring-parser-vz05HeYX',
      728 silly reify   '/opt/iobroker/node_modules/@smithy/service-error-classification': '/opt/iobroker/node_modules/@smithy/.service-error-classification-lLbcr4LZ',
      728 silly reify   '/opt/iobroker/node_modules/@smithy/shared-ini-file-loader': '/opt/iobroker/node_modules/@smithy/.shared-ini-file-loader-HYvGxjP2',
      728 silly reify   '/opt/iobroker/node_modules/@smithy/signature-v4': '/opt/iobroker/node_modules/@smithy/.signature-v4-c42bUsAz',
      728 silly reify   '/opt/iobroker/node_modules/@smithy/smithy-client': '/opt/iobroker/node_modules/@smithy/.smithy-client-RZkQSN4d',
      728 silly reify   '/opt/iobroker/node_modules/@smithy/types': '/opt/iobroker/node_modules/@smithy/.types-9plAkP9B',
      728 silly reify   '/opt/iobroker/node_modules/@smithy/util-base64': '/opt/iobroker/node_modules/@smithy/.util-base64-Otwj5Bbj',
      728 silly reify   '/opt/iobroker/node_modules/@smithy/util-body-length-browser': '/opt/iobroker/node_modules/@smithy/.util-body-length-browser-cdrehj1z',
      728 silly reify   '/opt/iobroker/node_modules/@smithy/url-parser': '/opt/iobroker/node_modules/@smithy/.url-parser-uqx7SKcq',
      728 silly reify   '/opt/iobroker/node_modules/@smithy/util-buffer-from': '/opt/iobroker/node_modules/@smithy/.util-buffer-from-B9mK3w8C',
      728 silly reify   '/opt/iobroker/node_modules/@smithy/util-config-provider': '/opt/iobroker/node_modules/@smithy/.util-config-provider-PDHJavRU',
      728 silly reify   '/opt/iobroker/node_modules/@smithy/util-defaults-mode-browser': '/opt/iobroker/node_modules/@smithy/.util-defaults-mode-browser-Y5niMThh',
      728 silly reify   '/opt/iobroker/node_modules/@aws-sdk/credential-providers': '/opt/iobroker/node_modules/@aws-sdk/.credential-providers-GrCTD1hg',
      728 silly reify   '/opt/iobroker/node_modules/@smithy/util-hex-encoding': '/opt/iobroker/node_modules/@smithy/.util-hex-encoding-QwHI1Cjv',
      728 silly reify   '/opt/iobroker/node_modules/@smithy/util-middleware': '/opt/iobroker/node_modules/@smithy/.util-middleware-aD5NuRr9',
      728 silly reify   '/opt/iobroker/node_modules/@smithy/util-defaults-mode-node': '/opt/iobroker/node_modules/@smithy/.util-defaults-mode-node-yG67kMv0',
      728 silly reify   '/opt/iobroker/node_modules/@smithy/util-stream': '/opt/iobroker/node_modules/@smithy/.util-stream-PkYRiV3Y',
      728 silly reify   '/opt/iobroker/node_modules/@smithy/util-body-length-node': '/opt/iobroker/node_modules/@smithy/.util-body-length-node-Hv9AuGxU',
      728 silly reify   '/opt/iobroker/node_modules/@smithy/util-utf8': '/opt/iobroker/node_modules/@smithy/.util-utf8-ZzRN3F0g',
      728 silly reify   '/opt/iobroker/node_modules/@smithy/util-uri-escape': '/opt/iobroker/node_modules/@smithy/.util-uri-escape-yBMZz3Jt',
      728 silly reify   '/opt/iobroker/node_modules/@smithy/util-retry': '/opt/iobroker/node_modules/@smithy/.util-retry-1YuisaMG',
      728 silly reify   '/opt/iobroker/node_modules/@types/cors': '/opt/iobroker/node_modules/@types/.cors-6truFcU9',
      728 silly reify   '/opt/iobroker/node_modules/@socket.io/component-emitter': '/opt/iobroker/node_modules/@socket.io/.component-emitter-XxrBKl6b',
      728 silly reify   '/opt/iobroker/node_modules/@types/webidl-conversions': '/opt/iobroker/node_modules/@types/.webidl-conversions-sTwlFPEN',
      728 silly reify   '/opt/iobroker/node_modules/@types/whatwg-url': '/opt/iobroker/node_modules/@types/.whatwg-url-st9gKEiR'
      728 silly reify }
      729 verbose reify failed optional dependency /opt/iobroker/node_modules/fsevents
      730 silly reify mark deleted [ '/opt/iobroker/node_modules/fsevents' ]
      731 info run @serialport/bindings-cpp@12.0.1 install node_modules/@serialport/bindings-cpp node-gyp-build
      732 info run bcrypt@5.1.1 install node_modules/bcrypt node-pre-gyp install --fallback-to-build
      733 info run diskusage@1.2.0 install node_modules/diskusage node-gyp rebuild
      734 info run bcrypt@5.1.1 install { code: 1, signal: null }
      735 info run bcrypt@5.1.0 install node_modules/@node-red/editor-api/node_modules/bcrypt node-pre-gyp install --fallback-to-build
      736 info run diskusage@1.2.0 install { code: 1, signal: null }
      737 verbose reify failed optional dependency /opt/iobroker/node_modules/diskusage
      738 silly reify mark deleted [ '/opt/iobroker/node_modules/diskusage' ]
      739 verbose reify failed optional dependency /opt/iobroker/node_modules/es6-promise
      740 silly reify mark deleted [ '/opt/iobroker/node_modules/es6-promise' ]
      741 info run bcrypt@5.1.0 install node_modules/node-red/node_modules/bcrypt node-pre-gyp install --fallback-to-build
      742 info run bcrypt@5.1.0 install { code: 1, signal: null }
      743 verbose reify failed optional dependency /opt/iobroker/node_modules/@node-red/editor-api/node_modules/bcrypt
      744 silly reify mark deleted [
      744 silly reify   '/opt/iobroker/node_modules/@node-red/editor-api/node_modules/bcrypt'
      744 silly reify ]
      745 verbose reify failed optional dependency /opt/iobroker/node_modules/@node-red/editor-api/node_modules/node-addon-api
      746 silly reify mark deleted [
      746 silly reify   '/opt/iobroker/node_modules/@node-red/editor-api/node_modules/node-addon-api'
      746 silly reify ]
      747 info run bcrypt@5.1.0 install { code: 1, signal: null }
      748 verbose reify failed optional dependency /opt/iobroker/node_modules/node-red/node_modules/bcrypt
      749 silly reify mark deleted [ '/opt/iobroker/node_modules/node-red/node_modules/bcrypt' ]
      750 verbose reify failed optional dependency /opt/iobroker/node_modules/node-red/node_modules/node-addon-api
      751 silly reify mark deleted [ '/opt/iobroker/node_modules/node-red/node_modules/node-addon-api' ]
      752 info run @serialport/bindings-cpp@12.0.1 install { code: 1, signal: null }
      753 verbose reify failed optional dependency /opt/iobroker/node_modules/@serialport/bindings-cpp
      754 silly reify mark deleted [ '/opt/iobroker/node_modules/@serialport/bindings-cpp' ]
      755 verbose reify failed optional dependency /opt/iobroker/node_modules/serialport
      756 silly reify mark deleted [ '/opt/iobroker/node_modules/serialport' ]
      757 verbose reify failed optional dependency /opt/iobroker/node_modules/@serialport/bindings-interface
      758 silly reify mark deleted [ '/opt/iobroker/node_modules/@serialport/bindings-interface' ]
      759 verbose reify failed optional dependency /opt/iobroker/node_modules/@serialport/bindings-cpp/node_modules/@serialport/parser-readline
      760 silly reify mark deleted [
      760 silly reify   '/opt/iobroker/node_modules/@serialport/bindings-cpp/node_modules/@serialport/parser-readline'
      760 silly reify ]
      761 verbose reify failed optional dependency /opt/iobroker/node_modules/@serialport/bindings-cpp/node_modules/debug
      762 silly reify mark deleted [
      762 silly reify   '/opt/iobroker/node_modules/@serialport/bindings-cpp/node_modules/debug'
      762 silly reify ]
      763 verbose reify failed optional dependency /opt/iobroker/node_modules/node-addon-api
      764 silly reify mark deleted [ '/opt/iobroker/node_modules/node-addon-api' ]
      765 verbose reify failed optional dependency /opt/iobroker/node_modules/@serialport/binding-mock
      766 silly reify mark deleted [ '/opt/iobroker/node_modules/@serialport/binding-mock' ]
      767 verbose reify failed optional dependency /opt/iobroker/node_modules/@serialport/parser-byte-length
      768 silly reify mark deleted [ '/opt/iobroker/node_modules/@serialport/parser-byte-length' ]
      769 verbose reify failed optional dependency /opt/iobroker/node_modules/@serialport/parser-cctalk
      770 silly reify mark deleted [ '/opt/iobroker/node_modules/@serialport/parser-cctalk' ]
      771 verbose reify failed optional dependency /opt/iobroker/node_modules/@serialport/parser-delimiter
      772 silly reify mark deleted [ '/opt/iobroker/node_modules/@serialport/parser-delimiter' ]
      773 verbose reify failed optional dependency /opt/iobroker/node_modules/@serialport/parser-inter-byte-timeout
      774 silly reify mark deleted [ '/opt/iobroker/node_modules/@serialport/parser-inter-byte-timeout' ]
      775 verbose reify failed optional dependency /opt/iobroker/node_modules/@serialport/parser-packet-length
      776 silly reify mark deleted [ '/opt/iobroker/node_modules/@serialport/parser-packet-length' ]
      777 verbose reify failed optional dependency /opt/iobroker/node_modules/@serialport/parser-readline
      778 silly reify mark deleted [ '/opt/iobroker/node_modules/@serialport/parser-readline' ]
      779 verbose reify failed optional dependency /opt/iobroker/node_modules/@serialport/parser-ready
      780 silly reify mark deleted [ '/opt/iobroker/node_modules/@serialport/parser-ready' ]
      781 verbose reify failed optional dependency /opt/iobroker/node_modules/@serialport/parser-regex
      782 silly reify mark deleted [ '/opt/iobroker/node_modules/@serialport/parser-regex' ]
      783 verbose reify failed optional dependency /opt/iobroker/node_modules/@serialport/parser-slip-encoder
      784 silly reify mark deleted [ '/opt/iobroker/node_modules/@serialport/parser-slip-encoder' ]
      785 verbose reify failed optional dependency /opt/iobroker/node_modules/@serialport/parser-spacepacket
      786 silly reify mark deleted [ '/opt/iobroker/node_modules/@serialport/parser-spacepacket' ]
      787 verbose reify failed optional dependency /opt/iobroker/node_modules/@serialport/stream
      788 silly reify mark deleted [ '/opt/iobroker/node_modules/@serialport/stream' ]
      789 verbose reify failed optional dependency /opt/iobroker/node_modules/serialport/node_modules/debug
      790 silly reify mark deleted [ '/opt/iobroker/node_modules/serialport/node_modules/debug' ]
      791 verbose reify failed optional dependency /opt/iobroker/node_modules/@serialport/bindings-cpp/node_modules/@serialport/parser-delimiter
      792 silly reify mark deleted [
      792 silly reify   '/opt/iobroker/node_modules/@serialport/bindings-cpp/node_modules/@serialport/parser-delimiter'
      792 silly reify ]
      793 verbose reify failed optional dependency /opt/iobroker/node_modules/@serialport/bindings-cpp/node_modules/ms
      794 silly reify mark deleted [
      794 silly reify   '/opt/iobroker/node_modules/@serialport/bindings-cpp/node_modules/ms'
      794 silly reify ]
      795 verbose reify failed optional dependency /opt/iobroker/node_modules/@serialport/binding-mock/node_modules/debug
      796 silly reify mark deleted [
      796 silly reify   '/opt/iobroker/node_modules/@serialport/binding-mock/node_modules/debug'
      796 silly reify ]
      797 verbose reify failed optional dependency /opt/iobroker/node_modules/@serialport/stream/node_modules/debug
      798 silly reify mark deleted [ '/opt/iobroker/node_modules/@serialport/stream/node_modules/debug' ]
      799 verbose reify failed optional dependency /opt/iobroker/node_modules/serialport/node_modules/ms
      800 silly reify mark deleted [ '/opt/iobroker/node_modules/serialport/node_modules/ms' ]
      801 verbose reify failed optional dependency /opt/iobroker/node_modules/@serialport/binding-mock/node_modules/ms
      802 silly reify mark deleted [
      802 silly reify   '/opt/iobroker/node_modules/@serialport/binding-mock/node_modules/ms'
      802 silly reify ]
      803 verbose reify failed optional dependency /opt/iobroker/node_modules/@serialport/stream/node_modules/ms
      804 silly reify mark deleted [ '/opt/iobroker/node_modules/@serialport/stream/node_modules/ms' ]
      805 verbose stack Error: command failed
      805 verbose stack     at promiseSpawn (/usr/lib/node_modules/npm/node_modules/@npmcli/promise-spawn/lib/index.js:22:22)
      805 verbose stack     at spawnWithShell (/usr/lib/node_modules/npm/node_modules/@npmcli/promise-spawn/lib/index.js:124:10)
      805 verbose stack     at promiseSpawn (/usr/lib/node_modules/npm/node_modules/@npmcli/promise-spawn/lib/index.js:12:12)
      805 verbose stack     at runScriptPkg (/usr/lib/node_modules/npm/node_modules/@npmcli/run-script/lib/run-script-pkg.js:77:13)
      805 verbose stack     at runScript (/usr/lib/node_modules/npm/node_modules/@npmcli/run-script/lib/run-script.js:9:12)
      805 verbose stack     at /usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/rebuild.js:329:17
      805 verbose stack     at run (/usr/lib/node_modules/npm/node_modules/promise-call-limit/dist/commonjs/index.js:67:22)
      805 verbose stack     at /usr/lib/node_modules/npm/node_modules/promise-call-limit/dist/commonjs/index.js:84:9
      805 verbose stack     at new Promise (<anonymous>)
      805 verbose stack     at callLimit (/usr/lib/node_modules/npm/node_modules/promise-call-limit/dist/commonjs/index.js:35:69)
      806 verbose pkgid bcrypt@5.1.1
      807 error code 1
      808 error path /opt/iobroker/node_modules/bcrypt
      809 error command failed
      810 error command sh -c node-pre-gyp install --fallback-to-build
      811 error node:internal/modules/cjs/loader:1143
      811 error   throw err;
      811 error   ^
      811 error
      811 error Error: Cannot find module '../lib/main'
      811 error Require stack:
      811 error - /opt/iobroker/node_modules/.bin/node-pre-gyp
      811 error     at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
      811 error     at Module._load (node:internal/modules/cjs/loader:981:27)
      811 error     at Module.require (node:internal/modules/cjs/loader:1231:19)
      811 error     at require (node:internal/modules/helpers:177:18)
      811 error     at Object.<anonymous> (/opt/iobroker/node_modules/.bin/node-pre-gyp:4:1)
      811 error     at Module._compile (node:internal/modules/cjs/loader:1364:14)
      811 error     at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
      811 error     at Module.load (node:internal/modules/cjs/loader:1203:32)
      811 error     at Module._load (node:internal/modules/cjs/loader:1019:12)
      811 error     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) {
      811 error   code: 'MODULE_NOT_FOUND',
      811 error   requireStack: [ '/opt/iobroker/node_modules/.bin/node-pre-gyp' ]
      811 error }
      811 error
      811 error Node.js v18.20.4
      812 silly unfinished npm timer reify 1721514852619
      813 silly unfinished npm timer reify:build 1721514874084
      814 silly unfinished npm timer build 1721514874088
      815 silly unfinished npm timer build:deps 1721514874089
      816 silly unfinished npm timer build:run:install 1721514874137
      817 silly unfinished npm timer build:run:install:node_modules/bcrypt 1721514874163
      818 verbose cwd /opt/iobroker
      819 verbose os Linux 6.1.21-v8+
      820 verbose node v18.20.4
      821 verbose npm  v10.8.1
      822 verbose exit 1
      823 verbose code 1
      824 error A complete log of this run can be found in: /opt/iobroker/.npm/_logs/2024-07-20T22_34_10_354Z-debug-0.log
