    5. LaMetric - Blockly Notification
    • E
      eve11 last edited by eve11
      ich habe hier ein Problem mit der Notification für die LaMetric Time.
        <block type="schedule" id="^jv%S#*PP?(7ibqQ/aWF" x="38" y="-412">
          <field name="SCHEDULE">* * * * *</field>
            <block type="lametric" id="t=qtCVNG/Zma@bjlfCOT">
              <field name="SOUND">cat</field>
              <field name="PRIORITY"></field>
              <field name="ICON_TYPE">none</field>
              <value name="MESSAGE">
                <shadow type="text" id="ftJn{_+6gvhkSQu}F#I|">
                  <field name="TEXT">haus-automatisierung.com</field>
              <value name="ICON">
                <shadow type="text" id="YPudZO2o{2mU4eAvs)^t">
                  <field name="TEXT">i31820</field>
              <value name="LIFETIME">
                <shadow type="math_number" id="mE}M{bEc.116O,P9X+$]">
                  <field name="NUM">1000</field>
              <value name="CYCLES">
                <shadow type="math_number" id="Fe0/jCiw#lZnW2|(wXWg">
                  <field name="NUM">1</field>
      Aber es kommt immer die Fehlermeldung:
      javascript.0 13:16:41.791 error script.js.Gartenwasser.Lametric_test compile failed: at script.js.Gartenwasser.Lametric_test:4
      javascript.0
      2024-07-21 13:16:41.792	error	at processImmediate (node:internal/timers:480:21)
      javascript.0
      2024-07-21 13:16:41.792	error	at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.javascript/main.js:1722:17)
      javascript.0
      2024-07-21 13:16:41.791	error	at /opt/iobroker/node_modules/iobroker.javascript/main.js:2307:17
      javascript.0
      2024-07-21 13:16:41.791	error	at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:2209:37)
      javascript.0
      2024-07-21 13:16:41.791	error	at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1943:21)
      javascript.0
      2024-07-21 13:16:41.791	error	at new Script (node:vm:116:7)
      javascript.0
      2024-07-21 13:16:41.791	error	SyntaxError: Unexpected token '}'
      javascript.0
      2024-07-21 13:16:41.791	error	^
      javascript.0
      2024-07-21 13:16:41.791	error	});
      javascript.0
      2024-07-21 13:16:41.791	error	script.js.Gartenwasser.Lametric_test compile failed: at script.js.Gartenwasser.Lametric_test:4
      Ist dies ein Bug oder mache ich hier etwas falsch.
      Ich habe auch schon ein Issue auf Github hierzu erstellt. Möchte aber noch einmal sicherstellen, dass es nicht ein Problem meinerseits ist. Was auch komisch ist, wenn ich von Blockly auf Javascript umstelle erscheint folgendes:
      schedule("* * * * *", async () => {
          priority: '',
      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
      Als ob der Notification Block gar nicht existieren würde.
      Vielen Dank für etwaige Rückmeldungen.
      Heiko
      LaMetric Adapter: V 3.2.2
      Javascript Adapter: V 8.6.0
      Node.js: 20.15.0
      Admin: 7.0.7
      • haus-automatisierung
        haus-automatisierung Developer Most Active @eve11 last edited by
        @eve11 sagte in LaMetric - Blockly Notification:
        Da ist ein bisschen kurz. Danke, schaue ich mir in Ruhe nochmal an.
