    4. Nach Neustart läuft iobroker nicht mehr
      thoduh last edited by
      Nach dem heutigen Neustart meines Macs, startet iobroker nicht mehr, es kommt nur diese Fehlermeldung:
      MacMini-LAN:iobroker.js-controller MacMini$ node controller.js
      host.MacMini-LAN.fritz.box check instance "system.adapter.admin.0" for host "MacMini-LAN.fritz.box"
      host.MacMini-LAN.fritz.box check instance "system.adapter.hm-rpc.0" for host "MacMini-LAN.fritz.box"
      host.MacMini-LAN.fritz.box check instance "system.adapter.hm-rega.0" for host "MacMini-LAN.fritz.box"
      host.MacMini-LAN.fritz.box check instance "system.adapter.javascript.0" for host "MacMini-LAN.fritz.box"
      host.MacMini-LAN.fritz.box check instance "system.adapter.discovery.0" for host "MacMini-LAN.fritz.box"
      host.MacMini-LAN.fritz.box check instance "system.adapter.ping.0" for host "MacMini-LAN.fritz.box"
      host.MacMini-LAN.fritz.box check instance "system.adapter.web.0" for host "MacMini-LAN.fritz.box"
      host.MacMini-LAN.fritz.box check instance "system.adapter.history.0" for host "MacMini-LAN.fritz.box"
      host.MacMini-LAN.fritz.box check instance "system.adapter.sonos.0" for host "MacMini-LAN.fritz.box"
      host.MacMini-LAN.fritz.box check instance "system.adapter.mobile.0" for host "MacMini-LAN.fritz.box"
      host.MacMini-LAN.fritz.box check instance "system.adapter.vis.0" for host "MacMini-LAN.fritz.box"
      host.MacMini-LAN.fritz.box check instance "system.adapter.harmony.0" for host "MacMini-LAN.fritz.box"
      host.MacMini-LAN.fritz.box check instance "system.adapter.hue.0" for host "MacMini-LAN.fritz.box"
      host.MacMini-LAN.fritz.box check instance "system.adapter.yahka.0" for host "MacMini-LAN.fritz.box"
      host.MacMini-LAN.fritz.box check instance "system.adapter.tr-064.0" for host "MacMini-LAN.fritz.box"
      host.MacMini-LAN.fritz.box check instance "system.adapter.feiertage.0" for host "MacMini-LAN.fritz.box"
      host.MacMini-LAN.fritz.box check instance "system.adapter.pushover.0" for host "MacMini-LAN.fritz.box"
      host.MacMini-LAN.fritz.box check instance "system.adapter.openhab.0" for host "MacMini-LAN.fritz.box"
      host.MacMini-LAN.fritz.box check instance "system.adapter.dwd.0" for host "MacMini-LAN.fritz.box"
      host.MacMini-LAN.fritz.box check instance "system.adapter.amazon-dash.0" for host "MacMini-LAN.fritz.box"
      { Error: EACCES: permission denied, open '/Users/MacMini/Documents/ioBrokerMac/log/iobroker.2017-09-13.log'
        errno: -13,
        code: 'EACCES',
        syscall: 'open',
        path: '/Users/MacMini/Documents/ioBrokerMac/log/iobroker.2017-09-13.log' }
      Es wurde gar nichts geändert, es gab kein Update oder ähnliches, nur ein Neustart des iMac…
      Kann jemand helfen?
        Stelle gerade fest, dass ich jetzt plötzlich mit
        sudo node controller.js
        starten muss.
        Bisher ging es immer ohne sudo.
        Mal wieder etwas unerklärliches mit iobroker…
        Wie gesagt, es wurde rein gar nichts am System geändert und plötzlich verhält es sich anders.
          @thoduh:
          Mal wieder etwas unerklärliches mit iobroker… `
          Oder eher mit Apfelware.
          Bist du denn heute mit Administratorrechten in der Konsole gewesen?
            Ich musste iobroker bisher nie mit Adminrechten starten.
            Und ich war auch wie immer in der Konsole…
            Und auch der Mac hatte in letzter Zeit keine updates erhalten.
            • eric2905
              eric2905 last edited by
              Das Verhalten liegt aber nicht an ioBroker.
              Das ist die Rechteverwaltung des Hosts.
              Bist Du mit dem User „MacMini“ angemeldet?
              Gruß,
              Eric
              Von unterwegs getippert
