    4. [gelöst] VIS-2 Start über Instanzlink nicht möglich
      MCU last edited by MCU
      Ich habe VIS-2 hinzugefügt kann aber die VIS nicht starten über den Instanz-Link.
      Das zugehörige LOG ist sehr kurz, obwohl debug eingeschaltet.
      vis-2.0
      2024-07-26 00:21:10.862	info	vis-2 license is OK.
      vis-2.0
      2024-07-26 00:21:10.650	info	starting. Version 2.9.64 in /opt/iobroker/node_modules/iobroker.vis-2, node: v20.16.0, js-controller: 5.0.19
      vis-2.0
      2024-07-26 00:21:10.542	debug	Plugin sentry Initialize Plugin (enabled=true)
      iob diag
      Skript v.2024-05-22
      *** BASE SYSTEM ***
       Static hostname: iobrokerPROD
             Icon name: computer-container
               Chassis: container ☐
        Virtualization: lxc
                Kernel: Linux 6.8.8-3-pve
          Architecture: x86-64
      model name      : 11th Gen Intel(R) Core(TM) i7-1165G7 @ 2.80GHz
      Docker          : false
      Virtualization  : lxc
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
       00:24:42 up  1:09,  2 users,  load average: 1.35, 1.20, 1.17
      CPU threads: 6
      *** Time and Time Zones ***
                     Local time: Fri 2024-07-26 00:24:42 CEST
                 Universal time: Thu 2024-07-25 22:24:42 UTC
                       RTC time: n/a
                    NTP service: inactive
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      prox
      HOME=/home/prox
      GROUPS=prox adm sudo iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video
      *** Display-Server-Setup ***
      Display-Server: false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            8.6G        3.2G        4.5G        131K        980M        5.4G
      Swap:           536M          0B        536M
      Total:          9.1G        3.2G        5.0G
      Active iob-Instances:   47
               8192 M total memory
               3005 M used memory
               3019 M active memory
                746 M inactive memory
               4250 M free memory
                  0 M buffer memory
                935 M swap cache
                512 M total swap
                  0 M used swap
                512 M free swap
      top - 00:24:42 up  1:10,  2 users,  load average: 1.32, 1.20, 1.17
      Tasks:  77 total,   1 running,  76 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   8192.0 total,   4248.8 free,   3007.7 used,    935.7 buff/cache
      MiB Swap:    512.0 total,    512.0 free,      0.0 used.   5184.3 avail Mem
      *** FAILED SERVICES ***
        UNIT                                 LOAD   ACTIVE SUB    DESCRIPTION
      * run-rpc_pipefs.mount                 loaded failed failed RPC Pipe File System
      * sys-kernel-config.mount              loaded failed failed Kernel Configuration File System
      * systemd-networkd-wait-online.service loaded failed failed Wait for Network to be Configured
      3 loaded units listed.
      *** FILESYSTEM ***
      Filesystem                       Type      Size  Used Avail Use% Mounted on
      /dev/mapper/pve-vm--150--disk--0 ext4       30G   15G   14G  52% /
      none                             tmpfs     492K  4.0K  488K   1% /dev
      udev                             devtmpfs   16G     0   16G   0% /dev/tty
      /dev/mapper/pve-root             ext4       94G   29G   61G  33% /mnt/windows
      tmpfs                            tmpfs      16G     0   16G   0% /dev/shm
      tmpfs                            tmpfs     6.2G  124K  6.2G   1% /run
      tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
      tmpfs                            tmpfs     3.1G     0  3.1G   0% /run/user/1001
      dmesg: read kernel buffer failed: Operation not permitted
      Show mounted filesystems:
      TARGET                                                  SOURCE                                  FSTYPE     OPTIONS
      /                                                       /dev/mapper/pve-vm--150--disk--0        ext4       rw,relatime,stripe=16
      |-/run                                                  tmpfs                                   tmpfs      rw,nosuid,nodev,size=6497012k,nr_inodes=819200,mode=755,uid=100000,gid=100000,inode64
      | |-/run/lock                                           tmpfs                                   tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k,uid=100000,gid=100000,inode64
      | |-/run/user/1001                                      tmpfs                                   tmpfs      rw,nosuid,nodev,relatime,size=3248504k,nr_inodes=812126,mode=700,uid=101001,gid=101001,inode64
      | |-/run/credentials/systemd-tmpfiles-setup.service     ramfs                                   ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
      | |-/run/credentials/systemd-sysctl.service             ramfs                                   ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
      | |-/run/credentials/systemd-sysusers.service           ramfs                                   ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
      | `-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs                                   ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
      |-/dev                                                  none                                    tmpfs      rw,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
      | |-/dev/shm                                            tmpfs                                   tmpfs      rw,nosuid,nodev,uid=100000,gid=100000,inode64
      | |-/dev/mqueue                                         mqueue                                  mqueue     rw,nosuid,nodev,noexec,relatime
      | |-/dev/ttyUSB0                                        udev[/ttyUSB0]                          devtmpfs   rw,nosuid,relatime,size=16208696k,nr_inodes=4052174,mode=755,inode64
      | |-/dev/.lxc/proc                                      proc                                    proc       rw,relatime
      | |-/dev/.lxc/sys                                       sys                                     sysfs      rw,relatime
      | |-/dev/full                                           udev[/full]                             devtmpfs   rw,nosuid,relatime,size=16208696k,nr_inodes=4052174,mode=755,inode64
      | |-/dev/null                                           udev[/null]                             devtmpfs   rw,nosuid,relatime,size=16208696k,nr_inodes=4052174,mode=755,inode64
      | |-/dev/random                                         udev[/random]                           devtmpfs   rw,nosuid,relatime,size=16208696k,nr_inodes=4052174,mode=755,inode64
      | |-/dev/tty                                            udev[/tty]                              devtmpfs   rw,nosuid,relatime,size=16208696k,nr_inodes=4052174,mode=755,inode64
      | |-/dev/urandom                                        udev[/urandom]                          devtmpfs   rw,nosuid,relatime,size=16208696k,nr_inodes=4052174,mode=755,inode64
      | |-/dev/zero                                           udev[/zero]                             devtmpfs   rw,nosuid,relatime,size=16208696k,nr_inodes=4052174,mode=755,inode64
      | |-/dev/pts                                            devpts                                  devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
      | |-/dev/ptmx                                           devpts[/ptmx]                           devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
      | |-/dev/console                                        devpts[/0]                              devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
      | |-/dev/tty1                                           devpts[/1]                              devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
      | `-/dev/tty2                                           devpts[/2]                              devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
      |-/proc                                                 proc                                    proc       rw,nosuid,nodev,noexec,relatime
      | |-/proc/sys                                           proc[/sys]                              proc       ro,relatime
      | | |-/proc/sys/net                                     proc[/sys/net]                          proc       rw,nosuid,nodev,noexec,relatime
      | | `-/proc/sys/kernel/random/boot_id                   none[/.lxc-boot-id]                     tmpfs      ro,nosuid,nodev,noexec,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
      | |-/proc/sysrq-trigger                                 proc[/sysrq-trigger]                    proc       ro,relatime
      | |-/proc/cpuinfo                                       lxcfs[/proc/cpuinfo]                    fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | |-/proc/diskstats                                     lxcfs[/proc/diskstats]                  fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | |-/proc/loadavg                                       lxcfs[/proc/loadavg]                    fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | |-/proc/meminfo                                       lxcfs[/proc/meminfo]                    fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | |-/proc/slabinfo                                      lxcfs[/proc/slabinfo]                   fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | |-/proc/stat                                          lxcfs[/proc/stat]                       fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | |-/proc/swaps                                         lxcfs[/proc/swaps]                      fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | `-/proc/uptime                                        lxcfs[/proc/uptime]                     fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      |-/sys                                                  sysfs                                   sysfs      ro,nosuid,nodev,noexec,relatime
      | |-/sys/fs/fuse/connections                            fusectl                                 fusectl    rw,nosuid,nodev,noexec,relatime
      | |-/sys/devices/virtual/net                            sysfs[/devices/virtual/net]             sysfs      rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/cgroup                                      none                                    cgroup2    rw,nosuid,nodev,noexec,relatime
      | `-/sys/devices/system/cpu                             lxcfs[/sys/devices/system/cpu]          fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      |-/mnt/windows                                          /dev/mapper/pve-root[/mnt/pve/windows]  ext4       rw,relatime,errors=remount-ro
      `-/mnt/nas                                              /dev/mapper/pve-root[/mnt/pve/fritznas] ext4       rw,relatime,errors=remount-ro
      /var:
      1.5G    /var/
      1.2G    /var/log/journal/69ffeed97a1945f88a51d8df571b2606
      1.2G    /var/log
      155M    /var/lib
      Archived and active journals take up 1.1G in the file system.
      /opt/iobroker/backups:
      451M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      1.3G    /opt/iobroker/iobroker-data/
      926M    /opt/iobroker/iobroker-data/files
      299M    /opt/iobroker/iobroker-data/files/javascript.admin
      265M    /opt/iobroker/iobroker-data/files/javascript.admin/static
      264M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
      87M     /opt/iobroker/iobroker-data/states.jsonl
      38M     /opt/iobroker/iobroker-data/objects.jsonl
      38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
      35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
      27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
      USB-Devices by-id:
      No Devices found 'by-id'
      HINT:
      Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
      /dev/ttyUSB0
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.16.0
      /usr/bin/node           v20.16.0
      /usr/bin/npm            10.8.1
      /usr/bin/npx            10.8.1
      /usr/bin/corepack       0.28.2
      nodejs:
        Installed: 20.16.0-1nodesource1
        Candidate: 20.16.0-1nodesource1
        Version table:
       *** 20.16.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
              100 /var/lib/dpkg/status
           20.15.1-1nodesource1 1001
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           18.19.0+dfsg-6~deb12u2 500
              500 http://ftp.debian.org/debian bookworm/main amd64 Packages
           18.19.0+dfsg-6~deb12u1 500
              500 http://security.debian.org bookworm-security/main amd64 Packages
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      admin:          7.0.19
      javascript:     8.6.0
      nodejs modules from github:     4
      +-- iobroker.alexa2@3.26.5 (git+ssh://git@github.com/Apollon77/ioBroker.alexa2.git#37160cf729a9c70ca70679d4b1d3c16ba51c6456)
      +-- iobroker.hue-extended@2.0.1 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.hue-extended.git#f3d1d9187fbc9bcdde5c39c1fbc80371ec7941f2)
      +-- iobroker.jarvis@3.2.0-beta.47 (git+ssh://git@github.com/Zefau/ioBroker.jarvis.git#b2aa6c5e163660c5447353ff595b6d93441915cd)
      +-- iobroker.meross@1.17.0 (git+ssh://git@github.com/Apollon77/ioBroker.meross.git#31fe999d84e17f0c79b2c5243f8227776035c718)
      Adapter State
      + system.adapter.admin.0                  : admin                 : iobrokerPROD                             -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
      + system.adapter.alexa2.0                 : alexa2                : iobrokerPROD                             -  enabled
      + system.adapter.backitup.0               : backitup              : iobrokerPROD                             -  enabled
        system.adapter.birthdays.0              : birthdays             : iobrokerPROD                             - disabled
      + system.adapter.bring.0                  : bring                 : iobrokerPROD                             -  enabled
      + system.adapter.broadlink2.0             : broadlink2            : iobrokerPROD                             -  enabled
      + system.adapter.cameras.0                : cameras               : iobrokerPROD                             -  enabled, port: 8200, bind: 127.0.0.1
      + system.adapter.chromecast.0             : chromecast            : iobrokerPROD                             -  enabled
      + system.adapter.cloud.0                  : cloud                 : iobrokerPROD                             -  enabled
        system.adapter.daswetter.0              : daswetter             : iobrokerPROD                             -  enabled
        system.adapter.devices.0                : devices               : iobrokerPROD                             -  enabled
      + system.adapter.discovery.0              : discovery             : iobrokerPROD                             -  enabled
        system.adapter.dwd.0                    : dwd                   : iobrokerPROD                             - disabled
      + system.adapter.echarts.0                : echarts               : iobrokerPROD                             -  enabled
      + system.adapter.email.0                  : email                 : iobrokerPROD                             -  enabled
      + system.adapter.fahrplan.0               : fahrplan              : iobrokerPROD                             -  enabled
        system.adapter.flot.0                   : flot                  : iobrokerPROD                             -  enabled
      + system.adapter.fritzdect.0              : fritzdect             : iobrokerPROD                             -  enabled
      + system.adapter.fullybrowser.0           : fullybrowser          : iobrokerPROD                             -  enabled
      + system.adapter.history.0                : history               : iobrokerPROD                             -  enabled
      + system.adapter.hue-extended.0           : hue-extended          : iobrokerPROD                             -  enabled
        system.adapter.hue.0                    : hue                   : iobrokerPROD                             - disabled, port: 443
        system.adapter.ical.0                   : ical                  : iobrokerPROD                             -  enabled
      + system.adapter.info.0                   : info                  : iobrokerPROD                             -  enabled
      + system.adapter.iot.0                    : iot                   : iobrokerPROD                             -  enabled
      + system.adapter.jarvis.0                 : jarvis                : iobrokerPROD                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.jarvis.1                 : jarvis                : iobrokerPROD                             -  enabled
      + system.adapter.jarvis.2                 : jarvis                : iobrokerPROD                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.javascript.0             : javascript            : iobrokerPROD                             -  enabled
        system.adapter.javascript.1             : javascript            : iobrokerPROD                             - disabled
        system.adapter.meross.0                 : meross                : iobrokerPROD                             - disabled
      + system.adapter.mqtt.0                   : mqtt                  : iobrokerPROD                             -  enabled, port: 1885, bind: 0.0.0.0
      + system.adapter.notificationforandroidtv.0: notificationforandroidtv: iobrokerPROD                             -  enabled
      + system.adapter.onvif.0                  : onvif                 : iobrokerPROD                             -  enabled, port: 8000
      + system.adapter.onvif.1                  : onvif                 : iobrokerPROD                             -  enabled, port: 8000
        system.adapter.pegelalarm.0             : pegelalarm            : iobrokerPROD                             -  enabled
      + system.adapter.ping.0                   : ping                  : iobrokerPROD                             -  enabled
        system.adapter.proxy.0                  : proxy                 : iobrokerPROD                             -  enabled
      + system.adapter.pushover.0               : pushover              : iobrokerPROD                             -  enabled
      + system.adapter.rest-api.0               : rest-api              : iobrokerPROD                             -  enabled, port: 8093, bind: 0.0.0.0, run as: admin
      + system.adapter.rssfeed.0                : rssfeed               : iobrokerPROD                             -  enabled
      + system.adapter.simple-api.0             : simple-api            : iobrokerPROD                             -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.snmp.0                   : snmp                  : iobrokerPROD                             -  enabled
      + system.adapter.sonoff.0                 : sonoff                : iobrokerPROD                             -  enabled, port: 1883, bind: 0.0.0.0
        system.adapter.spotify-premium.0        : spotify-premium       : iobrokerPROD                             - disabled
      + system.adapter.tankerkoenig.0           : tankerkoenig          : iobrokerPROD                             -  enabled
      + system.adapter.telegram.0               : telegram              : iobrokerPROD                             -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.telegram.1               : telegram              : iobrokerPROD                             -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.terminal.0               : terminal              : iobrokerPROD                             -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
      + system.adapter.tr-064.0                 : tr-064                : iobrokerPROD                             -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : iobrokerPROD                             -  enabled
        system.adapter.tvspielfilm.0            : tvspielfilm           : iobrokerPROD                             -  enabled
        system.adapter.twinkly.0                : twinkly               : iobrokerPROD                             - disabled
      + system.adapter.virtualpowermeter.0      : virtualpowermeter     : iobrokerPROD                             -  enabled
      + system.adapter.vis-2.0                  : vis-2                 : iobrokerPROD                             -  enabled
      + system.adapter.web.0                    : web                   : iobrokerPROD                             -  enabled, port: 8082, bind: 0.0.0.0 (SSL), run as: admin
      + system.adapter.web.1                    : web                   : iobrokerPROD                             -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
      + system.adapter.wifilight.0              : wifilight             : iobrokerPROD                             -  enabled
      + system.adapter.wled.0                   : wled                  : iobrokerPROD                             -  enabled
      + system.adapter.zigbee.0                 : zigbee                : iobrokerPROD                             -  enabled, port: /dev/ttyUSB0
      + instance is alive
      ioBroker-Repositories
      Active repo(s): beta
      Installed ioBroker-Instances
      Used repository: beta
      Adapter    "admin"        : 7.0.19   , installed 7.0.19
      Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
      Adapter    "backitup"     : 3.0.10   , installed 3.0.10
      Adapter    "birthdays"    : 3.0.1    , installed 3.0.1
      Adapter    "bring"        : 1.8.4    , installed 1.8.4
      Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
      Adapter    "cameras"      : 2.1.2    , installed 2.1.2
      Adapter    "chromecast"   : 3.4.1    , installed 3.4.1
      Adapter    "cloud"        : 5.0.1    , installed 5.0.1
      Adapter    "daswetter"    : 3.1.15   , installed 3.1.15
      Adapter    "discovery"    : 5.0.0    , installed 5.0.0
      Adapter    "echarts"      : 1.8.4    , installed 1.8.4
      Adapter    "email"        : 1.3.1    , installed 1.3.1
      Adapter    "fahrplan"     : 1.2.3    , installed 1.2.3
      Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
      Adapter    "fullybrowser" : 3.0.12   , installed 2.2.0  [Updatable]
      Adapter    "hue"          : 3.12.0   , installed 3.12.0
      Adapter    "ical"         : 1.15.0   , installed 1.15.0
      Adapter    "iot"          : 3.3.0    , installed 3.3.0
      Adapter    "jarvis"       : 3.1.8    , installed 3.2.0-beta.47
      Adapter    "javascript"   : 8.7.3    , installed 8.6.0  [Updatable]
      Controller "js-controller": 6.0.9    , installed 5.0.19 [Updatable]
      Adapter    "meross"       : 1.17.0   , installed 1.17.0
      Adapter    "mqtt"         : 6.0.0    , installed 6.0.0
      Adapter    "notificationforandroidtv": 3.0.4, installed 3.0.4
      Adapter    "onvif"        : 1.1.4    , installed 1.1.4
      Adapter    "pegelalarm"   : 1.3.3    , installed 1.3.3
      Adapter    "proxy"        : 1.3.2    , installed 1.3.2
      Adapter    "pushover"     : 4.0.0    , installed 4.0.0
      Adapter    "reolink"      : 1.1.0    , installed 1.1.0
      Adapter    "rest-api"     : 2.0.3    , installed 2.0.3
      Adapter    "rssfeed"      : 3.0.0    , installed 3.0.0
      Adapter    "snmp"         : 3.2.0    , installed 3.2.0
      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
      Adapter    "sonoff"       : 3.1.0    , installed 3.1.0
      Adapter    "spotify-premium": 1.5.0  , installed 1.5.0
      Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
      Adapter    "telegram"     : 3.9.0    , installed 3.9.0
      Adapter    "terminal"     : 1.0.0    , installed 1.0.0
      Adapter    "tibberlink"   : 3.4.3    , installed 3.4.3
      Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
      Adapter    "trashschedule": 3.3.0    , installed 3.3.0
      Adapter    "tvspielfilm"  : 2.1.0    , installed 2.1.0
      Adapter    "twinkly"      : 1.0.14   , installed 1.0.14
      Adapter    "virtualpowermeter": 1.4.6, installed 1.4.6
      Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
      Adapter    "web"          : 6.3.0    , installed 6.3.0
      Adapter    "wifilight"    : 1.2.2    , installed 1.2.2
      Adapter    "wled"         : 0.7.3-beta.0, installed 0.7.2 [Updatable]
      Adapter    "ws"           : 2.6.2    , installed 2.6.2
      Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
      Objects and States
      Objects:        27922
      States:         22122
      Hit:1 http://security.debian.org bookworm-security InRelease
      Hit:2 http://ftp.debian.org/debian bookworm InRelease
      Hit:3 http://ftp.debian.org/debian bookworm-updates InRelease
      Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists...
      Pending Updates: 3
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1002       2908608    586/io.mqtt.0
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1002       2909656    409/io.sonoff.0
      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          2919832    1334/master
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          2899893    1/init
      tcp        0      0 127.0.0.1:8200          0.0.0.0:*               LISTEN      1002       2923868    1649/io.cameras.0
      tcp        0      0 0.0.0.0:8402            0.0.0.0:*               LISTEN      1002       2927763    1871/io.jarvis.2
      tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1002       2916360    725/io.jarvis.0
      tcp        0      0 0.0.0.0:8401            0.0.0.0:*               LISTEN      1002       2923337    1810/io.jarvis.1
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1002       2903826    155/iobroker.js-con
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1002       2904576    155/iobroker.js-con
      tcp6       0      0 :::8087                 :::*                    LISTEN      1002       2920853    1474/io.simple-api.
      tcp6       0      0 :::8082                 :::*                    LISTEN      1002       2912107    683/io.web.0
      tcp6       0      0 :::8083                 :::*                    LISTEN      1002       2927793    1892/io.web.1
      tcp6       0      0 :::8081                 :::*                    LISTEN      1002       2896741    181/io.admin.0
      tcp6       0      0 :::8093                 :::*                    LISTEN      1002       2923142    1740/io.rest-api.0
      tcp6       0      0 :::8088                 :::*                    LISTEN      1002       2917396    745/io.terminal.0
      tcp6       0      0 :::111                  :::*                    LISTEN      0          2899895    1/init
      tcp6       0      0 :::22                   :::*                    LISTEN      0          2904527    1/init
      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          2919833    1334/master
      udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1002       2912479    502/io.broadlink2.0
      udp        0      0 0.0.0.0:48534           0.0.0.0:*                           1002       2911519    480/io.snmp.0
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          2899894    1/init
      udp        0      0 0.0.0.0:50201           0.0.0.0:*                           1002       2912482    502/io.broadlink2.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1002       2922591    1564/io.wled.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1002       2913302    606/io.chromecast.0
      udp        0      0 0.0.0.0:57664           0.0.0.0:*                           1002       2912481    502/io.broadlink2.0
      udp        0      0 0.0.0.0:42730           0.0.0.0:*                           1002       2912483    502/io.broadlink2.0
      udp6       0      0 :::111                  :::*                                0          2899896    1/init
      2024-07-26 00:21:07.161  - info: host.iobrokerPROD stopInstance system.adapter.vis-2.0 send kill signal
      2024-07-26 00:21:07.558  - info: vis-2.0 (15962) terminating
      2024-07-26 00:21:07.588  - info: host.iobrokerPROD instance system.adapter.vis-2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2024-07-26 00:21:10.196  - info: host.iobrokerPROD instance system.adapter.vis-2.0 started with pid 17036
      2024-07-26 00:21:10.384  - debug: vis-2.0 (17036) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2024-07-26 00:21:10.405  - debug: vis-2.0 (17036) Objects client ready ... initialize now
      2024-07-26 00:21:10.405  - debug: vis-2.0 (17036) Objects create System PubSub Client
      2024-07-26 00:21:10.406  - debug: vis-2.0 (17036) Objects create User PubSub Client
      2024-07-26 00:21:10.439  - debug: vis-2.0 (17036) Objects client initialize lua scripts
      2024-07-26 00:21:10.441  - debug: vis-2.0 (17036) Objects connected to redis: 127.0.0.1:9001
      2024-07-26 00:21:10.459  - debug: vis-2.0 (17036) Redis States: Use Redis connection: 127.0.0.1:9000
      2024-07-26 00:21:10.469  - debug: vis-2.0 (17036) States create System PubSub Client
      2024-07-26 00:21:10.469  - debug: vis-2.0 (17036) States create User PubSub Client
      2024-07-26 00:21:10.527  - debug: vis-2.0 (17036) States connected to redis: 127.0.0.1:9000
      2024-07-26 00:21:10.542  - debug: vis-2.0 (17036) Plugin sentry Initialize Plugin (enabled=true)
      2024-07-26 00:21:10.650  - info: vis-2.0 (17036) starting. Version 2.9.64 in /opt/iobroker/node_modules/iobroker.vis-2, node: v20.16.0, js-controller: 5.0.19
      2024-07-26 00:21:10.862  - info: vis-2.0 (17036) vis-2 license is OK.
      2024-07-26 00:21:27.605  - info: javascript.0 (208) script.js.HUE-EXTENDED.HUE-NEWAPI: running  function after change of hue-extended.0.lights.001-lampe_tisch.action.level
      2024-07-26 00:21:58.530  - info: javascript.0 (208) script.js.HUE-EXTENDED.HUE-NEWAPI: missing update instructions for scenes.status.status
      2024-07-26 00:21:58.530  - info: javascript.0 (208) script.js.HUE-EXTENDED.HUE-NEWAPI: {"status":{"status":{"active":"inactive"}}}
      2024-07-26 00:22:24.221  - info: javascript.0 (208) script.js.HUE-EXTENDED.HUE-NEWAPI: missing update instructions for scenes.status.status
      2024-07-26 00:22:24.221  - info: javascript.0 (208) script.js.HUE-EXTENDED.HUE-NEWAPI: {"status":{"status":{"active":"static"}}}
      2024-07-26 00:22:24.273  - info: javascript.0 (208) script.js.HUE-EXTENDED.HUE-NEWAPI: running  function after change of hue-extended.0.lights.001-lampe_tisch.action.level
      2024-07-26 00:23:18.639  - info: fahrplan.0 (1825) Updated 1 routes, 1 enabled and 0 disabled
      2024-07-26 00:23:18.936  - info: fahrplan.0 (1825) Updated 1 departure timetables, 1 enabled and 0 disabled
      Was kann ich tun? Wo muss ich ansetzen?
      Vielen Dank
      EDIT:
      Schau ich in die Übersicht dann sehe ich die Kacheln
      und kann diese auch nutzen.
      Welche Kachel soll man denn nutzen?
      Visualisierung Next Generation (sehr wahrscheinlich) für die Entwicklung
      Wofür hat man die "RunTime"-Kacheln? Um direkt ein fertiges Projekt zu starten?
      arteck sigi234 Bernd1967 3 Replies Last reply Reply Quote 0
        arteck Developer Most Active @MCU last edited by arteck
        @mcu ok und jetzt nochmal für die doofen(also mich)
        was willst du starten ?? was den für ein Instanz link ?
        ahhh jetzt weiss ich was du meinst
        der hier geht nicht
        • sigi234
          sigi234 Forum Testing Most Active @MCU last edited by sigi234
          @mcu
          Ja da stimmt was nicht:
          Ist seit Heute so, gestern ging es noch.
          Ev. hat es was mit den Updatest zu tun?
          Admin:7.0.19
          JS-Controller: 6.0.9
          Node.js: v20.16.0
          NPM: 10.8.1
            arteck Developer Most Active @sigi234 last edited by
            @sigi234 das wird am Admin liegen
              MCU @arteck last edited by
              @arteck Habe ein Issue eröffnet.
              https://github.com/ioBroker/ioBroker.admin/issues/2570
              mcuiobroker created this issue in ioBroker/ioBroker.admin
              closed [bug]: Instance link for VIS and VIS-2 doesn' t work anymore #2570
              Bernd1967 1 Reply Last reply Reply Quote 3
              • Bernd1967
                Bernd1967 @MCU last edited by
                @MCU
                Hatte Gestern auch mal zum testen vis-2 Adapter installiert.
                Hier funktioniert es mit beiden Instanz Link (vis und vis-2)
                Könnte es vielleicht mit HTTPS zusammenhängen ?
                Ich benutzte weiterhin unverschlüsselte Verbindung.
                Oder Browser cache löschen ?
                Fehler in der Konsole ?
                Admin:7.0.19
                Node.js: v20.16.0
                NPM: 10.8.1
                Bernd1967 M 2 Replies Last reply Reply Quote 0
                • Bernd1967
                  Bernd1967 @Bernd1967 last edited by Bernd1967
                  Was mir noch aufgefallen ist das bei mir der vis-2 Adapter die selbe Portnummer hat wie der vis Adapter.
                  Bei Euch ist eine ander Portnummer.
                  vis Link:
                  http://xxx.xxx.xxx:8082/vis/edit.html#DemoView
                  vis-2 Link:
                  http://xxx.xxx.xxx:8082/vis-2/edit.html#DemoView
                  • Bernd1967
                    Bernd1967 @MCU last edited by Bernd1967
                    @mcu sagte in VIS-2 Start über Instanzlink nicht möglich Voraussetzungen?:
                    Korrekt, bei mir öffnet sich dann die DemoView
                      MCU @Bernd1967 last edited by MCU
                      @bernd1967 Die unterschiedlichen Port nummern kommen von den Web-Instanzen.
                      Das könnte aber der Grund sein, dafür das der Instanzlink nicht funktioniert?
                      Da mehrere Web-Instanzen vorhanden sind, weiß er nicht welche er nehmen soll?
                        @bernd1967 Cache gelöscht bringt aber nichts. Instanz-Links funktionieren nicht.
                        • sigi234
                          Nein, habe auch mehrere Web Instanzen und es hat bis gestern immer funktioniert
                            MCU @sigi234 last edited by
                            @sigi234 Hatte man nicht früher eine Auswahl, wenn man drauf geklickt, welche Web-Instanz man nutzen möchte?
                            sigi234 2 Replies Last reply Reply Quote 0
                            • sigi234
                              Ja
                              Bernd1967 1 Reply Last reply Reply Quote 0
                              • Bernd1967
                                Bernd1967 @sigi234 last edited by
                                Wenn ich versuche eine zweite Instanz vom vis-2 Adapter hinzuzufügen kommt folgender Fehler:
                                ERROR: Process exited with code 19
                                $ iobroker add vis-2 auto --host Server(SmartHome) --debug
                                host.Server(SmartHome) error: this adapter does not allow multiple instances
                                  MCU last edited by
                                  @bernd1967 Ich habe keine 2. VIS-2- Instanz sondern eine 2. WEB-Instanz
                                    Homoran Global Moderator Administrators @Bernd1967 last edited by
                                    @bernd1967 sagte in VIS-2 Start über Instanzlink nicht möglich Voraussetzungen?:
                                    klar doch!
                                    Das tut man ja auch nicht.
                                    • Bernd1967
                                      Bernd1967 @Homoran last edited by
                                      Hab ich mir gedacht 🙂 aktuell kann ich mit Admin 7 aber auch keine zweite web Instanz hinzufügen.
                                      Aber dafür gibt es auf Github schon ein Issue....
                                      • sigi234
                                        Hallo, bin mal auf die Stable vom Admin gegangen, gleicher Fehler.
                                        Doch kein Admin Problem? JS-Controller?
                                        • Bernd1967
                                          Mit Admin 7.0.21 funktioniert das hinzufügen wieder.
                                          Vielleicht gehts dann auch mit dem Instanz LInk bei Euch ?
                                            MCU last edited by
                                            @bernd1967 Nein, keine Änderung.
                                            3736
