    4. [erledigt] Fehler nach Update js-controller auf v6.0.9
      paul53 last edited by paul53
      Folgende Fehlermeldung bei "iob status":
      ~$ iob status
      node:internal/modules/esm/resolve:265
          throw new ERR_MODULE_NOT_FOUND(
      Error [ERR_MODULE_NOT_FOUND]: Cannot find module '/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/esm/lib/setup/dbConnection.js' imported from /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/esm/index.js
      Das Verzeichnis "/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/esm/lib/setup" existiert nicht. Ein "iob fix" hat nichts geändert.
      Ausgabe von "iob diag":
      Skript v.2024-05-22
      *** BASE SYSTEM ***
       Static hostname: fred-internet
             Icon name: computer-vm
               Chassis: vm
        Virtualization: oracle
      Operating System: Ubuntu 22.04.4 LTS
                Kernel: Linux 5.15.0-117-generic
          Architecture: x86-64
       Hardware Vendor: innotek GmbH
        Hardware Model: VirtualBox
      model name	: Intel(R) Core(TM) i7-8565U CPU @ 1.80GHz
      Docker          : false
      Virtualization  : oracle
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
       16:12:22 up  1:14,  2 users,  load average: 0.06, 0.12, 0.20
      CPU threads: 2
      *** Time and Time Zones ***
                     Local time: Fri 2024-07-26 16:12:22 CEST
                 Universal time: Fri 2024-07-26 14:12:22 UTC
                       RTC time: Fri 2024-07-26 14:12:21
      System clock synchronized: no
                    NTP service: inactive
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      fred
      HOME=/home/fred
      GROUPS=fred adm cdrom sudo dip plugdev lpadmin sambashare vboxsf iobroker
      js-controller is not running
      *** Display-Server-Setup ***
      Display-Server: true
      Desktop: 	ubuntu
      Terminal: 	wayland
      Boot Target: 	graphical.target
      *** MEMORY ***
      Mem:            3.0G        722M        649M         36M        1.6G        2.0G
      Swap:           975M         52M        922M
      Total:          3.9G        774M        1.6G
      Active iob-Instances: 	0
               2968 M total memory
                722 M used memory
                591 M active memory
               1255 M inactive memory
                649 M free memory
                300 M buffer memory
               1296 M swap cache
                975 M total swap
                 52 M used swap
                922 M free swap
      top - 16:12:23 up  1:14,  2 users,  load average: 0.06, 0.12, 0.20
      Tasks: 206 total,   1 running, 205 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  6.1 us,  3.0 sy,  0.0 ni, 90.9 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   2968.8 total,    649.5 free,    721.7 used,   1597.5 buff/cache
      MiB Swap:    975.6 total,    922.8 free,     52.8 used.   2023.3 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      Filesystem     Type     Size  Used Avail Use% Mounted on
      tmpfs          tmpfs    297M  1.6M  296M   1% /run
      /dev/sda1      ext4      40G   27G   12G  70% /
      tmpfs          tmpfs    1.5G     0  1.5G   0% /dev/shm
      tmpfs          tmpfs    5.0M  4.0K  5.0M   1% /run/lock
      Exchange       vboxsf   119G   48G   72G  40% /media/sf_Exchange
      /dev/sr0       iso9660   51M   51M     0 100% /media/fred/VBox_GAs_7.0.18
      tmpfs          tmpfs    297M   92K  297M   1% /run/user/1000
      [Fri Jul 26 14:58:06 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      [Fri Jul 26 14:58:06 2024] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro. Quota mode: none.
      Show mounted filesystems:
      TARGET                                            SOURCE                         FSTYPE          OPTIONS
      /                                                 /dev/sda1                      ext4            rw,relatime,errors=remount-ro
      |-/sys                                            sysfs                          sysfs           rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/security                          securityfs                     securityfs      rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/cgroup                                cgroup2                        cgroup2         rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
      | |-/sys/fs/pstore                                pstore                         pstore          rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/bpf                                   bpf                            bpf             rw,nosuid,nodev,noexec,relatime,mode=700
      | |-/sys/kernel/debug                             debugfs                        debugfs         rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/tracing                           tracefs                        tracefs         rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/fuse/connections                      fusectl                        fusectl         rw,nosuid,nodev,noexec,relatime
      | `-/sys/kernel/config                            configfs                       configfs        rw,nosuid,nodev,noexec,relatime
      |-/proc                                           proc                           proc            rw,nosuid,nodev,noexec,relatime
      | `-/proc/sys/fs/binfmt_misc                      systemd-1                      autofs          rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=16711
      |   `-/proc/sys/fs/binfmt_misc                    binfmt_misc                    binfmt_misc     rw,nosuid,nodev,noexec,relatime
      |-/dev                                            udev                           devtmpfs        rw,nosuid,relatime,size=1483124k,nr_inodes=370781,mode=755,inode64
      | |-/dev/pts                                      devpts                         devpts          rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
      | |-/dev/shm                                      tmpfs                          tmpfs           rw,nosuid,nodev,inode64
      | |-/dev/mqueue                                   mqueue                         mqueue          rw,nosuid,nodev,noexec,relatime
      | `-/dev/hugepages                                hugetlbfs                      hugetlbfs       rw,relatime,pagesize=2M
      |-/run                                            tmpfs                          tmpfs           rw,nosuid,nodev,noexec,relatime,size=304004k,mode=755,inode64
      | |-/run/lock                                     tmpfs                          tmpfs           rw,nosuid,nodev,noexec,relatime,size=5120k,inode64
      | |-/run/credentials/systemd-sysusers.service     none                           ramfs           ro,nosuid,nodev,noexec,relatime,mode=700
      | |-/run/rpc_pipefs                               sunrpc                         rpc_pipefs      rw,relatime
      | |-/run/snapd/ns                                 tmpfs[/snapd/ns]               tmpfs           rw,nosuid,nodev,noexec,relatime,size=304004k,mode=755,inode64
      | | `-/run/snapd/ns/snapd-desktop-integration.mnt nsfs[mnt:[4026532462]]         nsfs            rw
      | `-/run/user/1000                                tmpfs                          tmpfs           rw,nosuid,nodev,relatime,size=304000k,nr_inodes=76000,mode=700,uid=1000,gid=1000,inode64
      |   |-/run/user/1000/doc                          portal                         fuse.portal     rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
      |   `-/run/user/1000/gvfs                         gvfsd-fuse                     fuse.gvfsd-fuse rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
      |-/snap/bare/5                                    /dev/loop0                     squashfs        ro,nodev,relatime,errors=continue
      |-/snap/bpytop/261                                /dev/loop1                     squashfs        ro,nodev,relatime,errors=continue
      |-/snap/bpytop/266                                /dev/loop2                     squashfs        ro,nodev,relatime,errors=continue
      |-/snap/core/16928                                /dev/loop3                     squashfs        ro,nodev,relatime,errors=continue
      |-/snap/core18/2823                               /dev/loop4                     squashfs        ro,nodev,relatime,errors=continue
      |-/snap/core18/2829                               /dev/loop5                     squashfs        ro,nodev,relatime,errors=continue
      |-/snap/core/17200                                /dev/loop6                     squashfs        ro,nodev,relatime,errors=continue
      |-/snap/core20/2264                               /dev/loop7                     squashfs        ro,nodev,relatime,errors=continue
      |-/snap/core20/2318                               /dev/loop8                     squashfs        ro,nodev,relatime,errors=continue
      |-/snap/core22/1122                               /dev/loop9                     squashfs        ro,nodev,relatime,errors=continue
      |-/snap/core22/1380                               /dev/loop10                    squashfs        ro,nodev,relatime,errors=continue
      |-/snap/gnome-3-26-1604/104                       /dev/loop12                    squashfs        ro,nodev,relatime,errors=continue
      |-/snap/firefox/4630                              /dev/loop13                    squashfs        ro,nodev,relatime,errors=continue
      |-/snap/firefox/4539                              /dev/loop11                    squashfs        ro,nodev,relatime,errors=continue
      |-/snap/gnome-3-26-1604/111                       /dev/loop16                    squashfs        ro,nodev,relatime,errors=continue
      |-/snap/gnome-3-28-1804/198                       /dev/loop14                    squashfs        ro,nodev,relatime,errors=continue
      |-/snap/gnome-3-28-1804/194                       /dev/loop15                    squashfs        ro,nodev,relatime,errors=continue
      |-/snap/gnome-3-34-1804/93                        /dev/loop19                    squashfs        ro,nodev,relatime,errors=continue
      |-/snap/gnome-42-2204/172                         /dev/loop20                    squashfs        ro,nodev,relatime,errors=continue
      |-/snap/gnome-3-38-2004/143                       /dev/loop18                    squashfs        ro,nodev,relatime,errors=continue
      |-/snap/gnome-system-monitor/184                  /dev/loop21                    squashfs        ro,nodev,relatime,errors=continue
      |-/snap/gnome-3-34-1804/90                        /dev/loop22                    squashfs        ro,nodev,relatime,errors=continue
      |-/snap/gnome-42-2204/176                         /dev/loop23                    squashfs        ro,nodev,relatime,errors=continue
      |-/snap/gnome-3-38-2004/140                       /dev/loop17                    squashfs        ro,nodev,relatime,errors=continue
      |-/snap/gnome-system-monitor/186                  /dev/loop24                    squashfs        ro,nodev,relatime,errors=continue
      |-/snap/gtk-common-themes/1534                    /dev/loop25                    squashfs        ro,nodev,relatime,errors=continue
      |-/snap/gtk-common-themes/1535                    /dev/loop26                    squashfs        ro,nodev,relatime,errors=continue
      |-/snap/hunspell-dictionaries-1-7-2004/2          /dev/loop27                    squashfs        ro,nodev,relatime,errors=continue
      |-/var/snap/firefox/common/host-hunspell          /dev/sda1[/usr/share/hunspell] ext4            ro,noexec,noatime,errors=remount-ro
      |-/snap/snapd-desktop-integration/157             /dev/loop28                    squashfs        ro,nodev,relatime,errors=continue
      |-/snap/ncdu/64                                   /dev/loop29                    squashfs        ro,nodev,relatime,errors=continue
      |-/snap/ncdu/66                                   /dev/loop30                    squashfs        ro,nodev,relatime,errors=continue
      |-/snap/snapd-desktop-integration/83              /dev/loop31                    squashfs        ro,nodev,relatime,errors=continue
      |-/media/sf_Exchange                              Exchange                       vboxsf          rw,nodev,relatime,iocharset=utf8,uid=0,gid=999,dmode=0770,fmode=0770,tag=VBoxAutomounter
      `-/media/fred/VBox_GAs_7.0.18                     /dev/sr0                       iso9660         ro,nosuid,nodev,relatime,nojoliet,check=s,map=n,blocksize=2048,uid=1000,gid=1000,dmode=500,fmode=400,iocharset=utf8
      /var:
      9.1G	/var/
      5.5G	/var/lib
      5.1G	/var/lib/snapd
      4.0G	/var/lib/snapd/snaps
      3.2G	/var/log/journal/b69dc24e7d334989b8127f57a179def6
      Archived and active journals take up 3.1G in the file system.
      /opt/iobroker/backups:
      14M	/opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      672M	/opt/iobroker/iobroker-data/
      568M	/opt/iobroker/iobroker-data/files
      299M	/opt/iobroker/iobroker-data/files/javascript.admin
      265M	/opt/iobroker/iobroker-data/files/javascript.admin/static
      264M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js
      23M	/opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.e1500458.js.map
      21M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.e564fb87.js.map
      19M	/opt/iobroker/iobroker-data/objects.jsonl
      19M	/opt/iobroker/iobroker-data/files/scheduler.admin/static/js/main.45986918.js.map
      17M	/opt/iobroker/iobroker-data/files/echarts/preview/static/js/main.8f15257e.js.map
      USB-Devices by-id:
      No Devices found 'by-id'
      *** NodeJS-Installation ***
      /usr/bin/nodejs 	v20.16.0
      /usr/bin/node 		v20.16.0
      /usr/bin/npm 		10.8.1
      /usr/bin/npx 		10.8.1
      /usr/bin/corepack 	0.28.2
      nodejs:
        Installed: 20.16.0-1nodesource1
        Candidate: 20.16.0-1nodesource1
        Version table:
       *** 20.16.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
              100 /var/lib/dpkg/status
           20.15.1-1nodesource1 1001
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           12.22.9~dfsg-1ubuntu3.6 500
              500 http://de.archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages
              500 http://security.ubuntu.com/ubuntu jammy-security/universe amd64 Packages
           12.22.9~dfsg-1ubuntu3 500
              500 http://de.archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
          at finalizeResolution (node:internal/modules/esm/resolve:265:11)
          at moduleResolve (node:internal/modules/esm/resolve:933:10)
          at defaultResolve (node:internal/modules/esm/resolve:1169:11)
          at ModuleLoader.defaultResolve (node:internal/modules/esm/loader:383:12)
          at ModuleLoader.resolve (node:internal/modules/esm/loader:352:25)
          at ModuleLoader.getModuleJob (node:internal/modules/esm/loader:227:38)
          at ModuleWrap.<anonymous> (node:internal/modules/esm/module_job:87:39)
          at link (node:internal/modules/esm/module_job:86:36) {
        code: 'ERR_MODULE_NOT_FOUND',
        url: 'file:///opt/iobroker/node_modules/@iobroker/js-controller-cli/build/esm/lib/setup/dbConnection.js'
      Node.js v20.16.0
      Core adapters versions
      Node.js v20.16.0
      js-controller:
      Node.js v20.16.0
      admin:
      Node.js v20.16.0
      javascript:
      nodejs modules from github: 	2
      |   `-- xmlbuilder@0.4.2 invalid: "https://github.com/hobbyquaker/xmlbuilder-js/tarball/29fe5030dc6852007dc8d1bfd5109d75f8da58d5" from node_modules/homematic-xmlrpc
      | `-- socksv5@0.0.6 invalid: "https://github.com/christophgysin/socksv5/tarball/7b4eba5b30ecdb6d9e656dcfede1e6884dc7c6d9" from node_modules/iobroker.telegram
      Adapter State
      ioBroker-Repositories
      Node.js v20.16.0
      Installed ioBroker-Instances
      Node.js v20.16.0
      Objects and States
      Objects: 	0
      States: 	0
      Hit:1 http://de.archive.ubuntu.com/ubuntu jammy InRelease
      Hit:2 http://de.archive.ubuntu.com/ubuntu jammy-updates InRelease
      Hit:3 http://de.archive.ubuntu.com/ubuntu jammy-backports InRelease
      Hit:4 http://security.ubuntu.com/ubuntu jammy-security InRelease
      Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          15537      1/init
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          20476      827/cupsd
      tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      101        18371      378/systemd-resolve
      tcp6       0      0 :::111                  :::*                    LISTEN      0          15539      1/init
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          20475      827/cupsd
      udp        0      0 127.0.0.53:53           0.0.0.0:*                           101        18370      378/systemd-resolve
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          15538      1/init
      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          21891      976/cups-browsed
      udp        0      0 0.0.0.0:45825           0.0.0.0:*                           116        20374      658/avahi-daemon: r
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           116        20372      658/avahi-daemon: r
      udp6       0      0 :::111                  :::*                                0          15540      1/init
      udp6       0      0 fe80::ded1:92b6:341:546 :::*                                0          23322      664/NetworkManager
      udp6       0      0 :::39652                :::*                                116        20375      658/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                116        20373      658/avahi-daemon: r
      2024-07-26 15:16:14.789  - warn: web.0 (4242) Timeout by termination of web-extensions!
      2024-07-26 15:16:18.586  - error: admin.0 (4075) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
      2024-07-26 15:16:19.030  - error: ping.0 (4186) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
      2024-07-26 15:16:19.081  - warn: ping.0 (4186) get state error: Connection is closed.
      2024-07-26 15:16:19.201  - error: ecoflow-mqtt.0 (4301) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
      2024-07-26 15:16:19.233  - warn: ecoflow-mqtt.0 (4301) get state error: Connection is closed.
      2024-07-26 15:16:19.234  - warn: ecoflow-mqtt.0 (4301) get state error: DB closed
      2024-07-26 15:16:19.238  - warn: ecoflow-mqtt.0 (4301) get state error: DB closed
      2024-07-26 15:16:19.239  - warn: ecoflow-mqtt.0 (4301) get state error: DB closed
      2024-07-26 15:16:19.240  - warn: ecoflow-mqtt.0 (4301) get state error: DB closed
      2024-07-26 15:16:19.241  - warn: ecoflow-mqtt.0 (4301) get state error: DB closed
      2024-07-26 15:16:19.242  - warn: ecoflow-mqtt.0 (4301) get state error: DB closed
      2024-07-26 15:16:19.243  - warn: ecoflow-mqtt.0 (4301) get state error: DB closed
      2024-07-26 15:16:19.244  - warn: ecoflow-mqtt.0 (4301) get state error: DB closed
      2024-07-26 15:16:19.300  - error: web.0 (4242) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
      2024-07-26 15:16:19.314  - warn: web.0 (4242) get state error: Connection is closed.
      2024-07-26 15:16:19.290  - error: email.0 (4170) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
      2024-07-26 15:16:19.318  - warn: web.0 (4242) get state error: DB closed
      Das Verzeichnis, in dem das Verzeichnis "setup" fehlt:
      /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/esm/lib$ ls -l
      insgesamt 236
      -rw-rwxr--+ 1 iobroker iobroker    165 Jul 26 15:03 setup.d.ts
      -rw-rwxr--+ 1 iobroker iobroker    160 Jul 26 15:03 setup.d.ts.map
      -rw-rwxr--+ 1 iobroker iobroker 124044 Jul 26 15:03 setup.js
      -rw-rwxr--+ 1 iobroker iobroker  88535 Jul 26 15:03 setup.js.map
      -rw-rwxr--+ 1 iobroker iobroker   1316 Jul 26 15:03 _Types.d.ts
      -rw-rwxr--+ 1 iobroker iobroker   1260 Jul 26 15:03 _Types.d.ts.map
      -rw-rwxr--+ 1 iobroker iobroker     45 Jul 26 15:03 _Types.js
      -rw-rwxr--+ 1 iobroker iobroker    114 Jul 26 15:03 _Types.js.map
      Wie kann ich den Fehler am einfachsten beheben?
      M paul53 2 Replies Last reply Reply Quote 0
        MCU @paul53 last edited by
        Die scheint voll zu sein. Ist die Systemrelevant?
        paul53 Thomas Braun 2 Replies Last reply Reply Quote 0
          paul53 @MCU last edited by
          @mcu sagte: Ist die Systemrelevant?
          Sicherlich nicht für ioBroker.
            paul53 @paul53 last edited by paul53
            npm install iobroker.js-controller
            im Verzeichnis "/opt/iobroker" hat es repariert. Das vermisste Verzeichnis existiert nun.
              Thomas Braun Most Active @MCU last edited by
              @mcu sagte in [erledigt] Fehler nach Update js-controller auf v6.0.9:
              Das ist ein ISO, welches die GuestAuditions für VBox enthält. Das ist natürlich immer zu 100% voll.
