    5. Hilfe bei request -> http Umstellung Sonos Sprachausgabe
    • XBiT
      XBiT last edited by XBiT
      kann mir jemand an diesen Beispiel zeigen wie ich die neuen Bausteine richtig verwende?
      hier die Ausgangssituation:
      Code:
        <variables>
          <variable id=".Yvm,6)5C!N]^MT[`GAV">Datum</variable>
          <variable id=",i|ut(0wYas5^:/cgIlT">Stunde</variable>
          <variable id="Nao2zPy]Gh:tUN^{,?jw">Minute</variable>
          <variable id="^IgPDXdy#sa!2)?B34#b">Tag</variable>
          <variable id="6C%#L[`:Q.Jx1xcMSFWs">Aussentemperatur</variable>
        </variables>
        <block type="procedures_defcustomreturn" id="$RIGDIe%Xa8Rr#p]Kq%," x="138" y="63">
          <mutation statements="false"></mutation>
          <field name="NAME">Aussentemp_umwandeln</field>
          <field name="SCRIPT">Y29uc3Qgc3RhdGVWYWwgPSBnZXRTdGF0ZSgnaG0tcnBjLjAuS0VRMDE3NDYxOS4xLlRFTVBFUkFUVVJFJykudmFsOw0KLy8gIGxvZyhzdGF0ZVZhbCk7DQogICAgICAgIHZhciBUZW1wID0gKHN0YXRlVmFsLnRvU3RyaW5nKCkucmVwbGFjZSgnLicsICcsJykpOw0KLy8gbG9nKFRlbXApOw0KcmV0dXJuIFRlbXA7</field>
        <block type="on_ext" id="gU4C}VWBQ3v:IsY9!^eO" x="138" y="113">
          <value name="OID0">
            <shadow type="field_oid" id="l[Aiw@P%D?w*wb)Kr`Y8">
            <block type="field_oid" id="I0@5sm#%2w{/4tS2ry_J">
              <field name="oid">0_userdata.0.Testbereich.Sprachausgabe_Sonos_Test</field>
            <block type="variables_set" id=";toPl|v_k)-Tvh{jioUv">
              <field name="VAR" id=".Yvm,6)5C!N]^MT[`GAV">Datum</field>
                <block type="time_get" id="M5KC.YEQGB71]Rw^a|Ln">
                  <field name="OPTION">DD.MM.YYYY</field>
                <block type="variables_set" id="s4(uxbY$dv=ll;b/Y7i1">
                  <field name="VAR" id=",i|ut(0wYas5^:/cgIlT">Stunde</field>
                    <block type="time_get" id="]jWUOQ-5r6){HrrA_iU4">
                      <field name="OPTION">h</field>
                    <block type="variables_set" id="``pe:#@W+O;]OS(;y9QP">
                      <field name="VAR" id="Nao2zPy]Gh:tUN^{,?jw">Minute</field>
                        <block type="time_get" id="/Bf#x=pCr%ei:n2?Bx73">
                          <field name="OPTION">m</field>
                        <block type="variables_set" id="(Ky*8~7ISEs]7h$ah97n">
                          <field name="VAR" id="^IgPDXdy#sa!2)?B34#b">Tag</field>
                            <block type="time_get" id="C/j?%}+vntB=cg^g|)kn">
                              <mutation xmlns="http://www.w3.org/1999/xhtml" format="false" language="true"></mutation>
                              <field name="OPTION">wdt</field>
                              <field name="LANGUAGE">de</field>
                            <block type="variables_set" id="wM:Tpw:(q8(E?@Gh14PL">
                              <field name="VAR" id="6C%#L[`:Q.Jx1xcMSFWs">Aussentemperatur</field>
                                <block type="procedures_callcustomreturn" id="|x2g!an;a+E[m=xq21F7">
                                  <mutation name="Aussentemp_umwandeln"></mutation>
                                <block type="comment" id="]2RJfLK5VNnHW|-LIuw(">
                                  <field name="COMMENT">Infoansage Morgens</field>
                                    <block type="request" id="z9WeT4B%JknB[$Z%(=0F">
                                      <mutation xmlns="http://www.w3.org/1999/xhtml" with_statement="false"></mutation>
                                      <field name="WITH_STATEMENT">FALSE</field>
                                      <field name="LOG"></field>
                                      <value name="URL">
                                        <shadow type="text" id="YST]=PF|LPRU/lLH/pML">
                                        <block type="text_join" id="G+K/L1R:8z1exkQxdxP[">
                                          <mutation items="13"></mutation>
                                          <value name="ADD0">
                                            <block type="text" id="+|8T_n|oBQ*FB0epO^]i">
                                              <field name="TEXT">http://192.168.1.251:5005/K%C3%BCche/say/</field>
                                          <value name="ADD1">
                                            <block type="text" id="/b1#$O(Srgf`?usOT^cx">
                                              <field name="TEXT">Guten Morgen, Heute ist</field>
                                          <value name="ADD2">
                                            <block type="variables_get" id="cYP}$.j)cSLchSN]#LDx">
                                          <value name="ADD3">
                                            <block type="text" id="E*gE507Aq/r0=qrl~2_Q">
                                              <field name="TEXT"> der </field>
                                          <value name="ADD4">
                                            <block type="variables_get" id="V6P-C-pa}SojJO=]KhLa">
                                          <value name="ADD5">
                                            <block type="text" id="~wx9zhxp76eBE#UpcOo#">
                                              <field name="TEXT"> es ist </field>
                                          <value name="ADD6">
                                            <block type="variables_get" id=",@24GC`!~}[shMtr[!w|">
                                          <value name="ADD7">
                                            <block type="text" id="}s}O!O%L8gTG4ajz_hG|">
                                              <field name="TEXT"> Uhr </field>
                                          <value name="ADD8">
                                            <block type="variables_get" id="Rye9.PNb{1V/s${n*:B;">
                                          <value name="ADD9">
                                            <block type="text" id="SerOxNp7CMWQ34lorOH9">
                                              <field name="TEXT">, Die Außentemperatur beträgt </field>
                                          <value name="ADD10">
                                            <block type="variables_get" id="$n*K.5Ryc/)mjRz|!uri">
                                          <value name="ADD11">
                                            <block type="text" id="ES{U_ZoXBKp5p=|hJqQ1">
                                              <field name="TEXT">°C </field>
                                          <value name="ADD12">
                                            <block type="text" id="5pr1s{0t$8Eun9.cQc=)">
                                              <field name="TEXT">/de-de</field>
      @haus-automatisierung kannst du mir einen Tipp zur Anwendung der neuen Blocke in diesen Fall geben?
      • haus-automatisierung
        haus-automatisierung Developer Most Active @XBiT last edited by
        @xbit Klar, habe ich überall ausführlich erklärt. Was fehlt dir?
        https://github.com/ioBroker/ioBroker.javascript/blob/master/docs/en/upgrade-guide.md#request-to-httpget
        https://www.youtube.com/watch?v=dS6vkX6Mvjo
        Gibt ja auch sonst auch schon viele Threads mit Beispielen dazu.
        XBiT 1 Reply Last reply Reply Quote 0
        • XBiT
          XBiT @haus-automatisierung last edited by XBiT
          ich bekomme nach Ablauf des Timeout folgenden Log Eintrag:
          Get
          javascript.0	16:33:21.108	error	script.js.common.0_userdata_0_.Testbereich.Sprechausgabe_Sonos_Test: httpGet(url=http://192.168.1.251:5005/K%C3%BCche/say/Guten Morgen, Heute istSonntag der 04.08.2024 es ist 16 Uhr 33, Die Außentemperatur beträgt 22,2°C /de-de, error=socket hang up)
          Post
          javascript.0	16:39:42.940	error	script.js.common.0_userdata_0_.Testbereich.Sprechausgabe_Sonos_Test: httpPost(url=http://192.168.1.251:5005/K%C3%BCche/say/Guten Morgen, Heute istSonntag der 04.08.2024 es ist 16 Uhr 39, Die Außentemperatur beträgt 22,5°C /de-de, error=timeout of 10000ms exceeded)
          gebe ich die URL im Browser ein erfolgt die Sprachausgabe am Lautsprecher.
            TT-Tom @XBiT last edited by
            @xbit
            Wie sieht denn das Blockly jetzt aus??
            • XBiT
              XBiT @TT-Tom last edited by
              @tt-tom
              Code:
                <variables>
                </variables>
                  <value name="OID0">
                    <block type="debug" id="i9|c$D|9`yTcHQJ3L6:J">
                      <field name="Severity">info</field>
                      <value name="TEXT">
                        <shadow type="text" id="q:d;A=~;Bbw3Y37=xU3{">
                        <block type="text" id="+3aqtKX3C6fD;`MS^zlj">
                          <field name="TEXT">Los Geht´s</field>
                                                <block type="http_post" id="voR:kgZ5;u7kee=A^LfH">
                                                  <field name="TIMEOUT">10</field>
                                                  <field name="TYPE">text</field>
                                                  <value name="URL">
                                                    <shadow type="text" id="5H7)w3*?!jOQ_EbPxm++">
                                                      <field name="TEXT">http://</field>
                                                      <value name="ADD0">
                                                      <value name="ADD1">
                                                      <value name="ADD2">
                                                      <value name="ADD3">
                                                      <value name="ADD4">
                                                      <value name="ADD5">
                                                      <value name="ADD6">
                                                      <value name="ADD7">
                                                      <value name="ADD8">
                                                      <value name="ADD9">
                                                  <value name="DATA">
                                                    <shadow type="logic_null" id="P#Y|JSu3e/YZGPw/05Yk"></shadow>
                                                    <block type="debug" id="w*_%RYfi_x-/ZFvET*(t">
                                                      <value name="TEXT">
                                                        <shadow type="text" id="W2tH`bcycYh08hb3UM1|">
                                                        <block type="http_response" id="s,Gd$|rx4wr[GT`t,J5O">
                                                          <field name="ATTR">response.statusCode</field>
                                                    <block type="debug" id="Qv1,l${0#HBhRA^mVR.c">
                                                      <value name="TEXT">
                                                        <block type="text" id="HgkGqFbu-gZ@Vr?[Ol.2">
                                                          <field name="TEXT">Habe Fertig!</field>
              KA ob es so richtig ist er soll ja nur die URL so aufrufen ich benötige kein Ergebnis von der URL.
                @xbit Warum nimmst Du POST? Vorher war es doch auch ein GET-Request
                T XBiT 2 Replies Last reply Reply Quote 0
                  TT-Tom @haus-automatisierung last edited by
                  Hat auch ein Fehler gemeldet.
                  Vermutlich falsch konfiguriert
                  • XBiT
                    Weil ich getestet habe woran es liegt...
                    Habe es gefunden... die URL wird nicht aufgerufen sobald man "erstelle Text aus" verwendet.
                    Wird alles in einer Textzeile ohne Variable mit http-Get Baustein gemacht kommt auch die Ansage.
                    Ich benötige aber die Variablen...
                      haus-automatisierung Developer Most Active @XBiT last edited by haus-automatisierung
                      @xbit Das ergibt technisch aber keinen Sinn, weil der Code von innen nach außen aufgelöst wird. Der httpGet Block weiß also nichtmal dass der Text aus einzelnen Bestandteilen zusammengesetzt wurde.
                      Eventuell liegt es an einem fehlenden urlEncoding. Kann sein dass das alte request Paket das automatisch gemacht hat. Müsste ich in Ruhe testen.
                      Aber dann dürfte es auch nicht gehen, wenn der gleiche String als Url direkt genutzt wird
                      • XBiT
                        Blockly in JS ohne "erstelle Text aus"
                          // Infoansage Morgens
                          httpGet('http://192.168.1.251:5005/K%C3%BCche/say/Guten Morgen, Heute istSonntag der 04.08.2024 es ist 16 Uhr 39, Die Außentemperatur beträgt 22,5°C /de-de', { timeout: 20000, responseType: 'text' }, async (err, response) => {
                            console.info(err);
                        Blockly in JS mit "erstelle Text aus"
                          httpGet((['http://192.168.1.251:5005/K%C3%BCche/say/','Guten Morgen Heute ist','Sonntag',' der ','04.08.2024',' es ist ','16',' Uhr ','39',' Die Außentemperatur beträgt ','22,5','°C','/de-de'].join('')), { timeout: 20000, responseType: 'text' }, async (err, response) => {
                            console.info(err);
                          paul53 @XBiT last edited by paul53
                          @xbit sagte: Blockly in JS mit "erstelle Text aus"
                          Da kommt der gleiche Text raus (ohne die zwei Kommata).
                          EDIT: Erstelle mal die URL mit Textzusammensetzung in eine Variable und übergebe die Variable an httpGet().
                          Kann es sein, dass httpGet() die zusätzliche runde Klammer stört?
                          • XBiT
                            XBiT @paul53 last edited by XBiT
                            danke @paul53 habe ich auch schon gemacht.
                            es geht dann ein mal danach wieder nicht starte ich das Script ein paar mal neu geht es wieder 1 mal... jedoch kommt die Sprachausgabe immer 2 mal hintereinander.
                            Log:
                            javascript.0	19:06:42.995	info	Stopping script script.js.common.0_userdata_0_.Testbereich.Sprechausgabe_Sonos_Test
                            javascript.0	19:06:43.041	info	Start JavaScript script.js.common.0_userdata_0_.Testbereich.Sprechausgabe_Sonos_Test (Blockly)
                            javascript.0	19:06:43.044	info	script.js.common.0_userdata_0_.Testbereich.Sprechausgabe_Sonos_Test: http://192.168.1.251:5005/K%C3%BCche/say/Guten Morgen, Heute ist Sonntag der 04.08.2024 es ist 19 Uhr 6 ,Die Außentemperatur beträgt 21,5 °C/de-de
                            javascript.0	19:06:43.045	info	script.js.common.0_userdata_0_.Testbereich.Sprechausgabe_Sonos_Test: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                            javascript.0	19:07:09.859	info	Stopping script script.js.common.0_userdata_0_.Testbereich.Sprechausgabe_Sonos_Test
                            javascript.0	19:07:09.906	info	Start JavaScript script.js.common.0_userdata_0_.Testbereich.Sprechausgabe_Sonos_Test (Blockly)
                            javascript.0	19:07:09.914	info	script.js.common.0_userdata_0_.Testbereich.Sprechausgabe_Sonos_Test: http://192.168.1.251:5005/K%C3%BCche/say/Guten Morgen, Heute ist Sonntag der 04.08.2024 es ist 19 Uhr 7 ,Die Außentemperatur beträgt 21,5 °C/de-de
                            javascript.0	19:07:09.916	info	script.js.common.0_userdata_0_.Testbereich.Sprechausgabe_Sonos_Test: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                            javascript.0	19:07:11.063	error	script.js.common.0_userdata_0_.Testbereich.Sprechausgabe_Sonos_Test: httpGet(url=http://192.168.1.251:5005/K%C3%BCche/say/Guten Morgen, Heute ist Sonntag der 04.08.2024 es ist 19 Uhr 7 ,Die Außentemperatur beträgt 21,5 °C/de-de, error=socket hang up)
                            javascript.0	19:07:15.799	info	Stopping script script.js.common.0_userdata_0_.Testbereich.Sprechausgabe_Sonos_Test
                            javascript.0	19:07:15.848	info	Start JavaScript script.js.common.0_userdata_0_.Testbereich.Sprechausgabe_Sonos_Test (Blockly)
                            javascript.0	19:07:15.851	info	script.js.common.0_userdata_0_.Testbereich.Sprechausgabe_Sonos_Test: http://192.168.1.251:5005/K%C3%BCche/say/Guten Morgen, Heute ist Sonntag der 04.08.2024 es ist 19 Uhr 7 ,Die Außentemperatur beträgt 21,5 °C/de-de
                            javascript.0	19:07:15.852	info	script.js.common.0_userdata_0_.Testbereich.Sprechausgabe_Sonos_Test: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                            javascript.0	19:07:15.853	error	script.js.common.0_userdata_0_.Testbereich.Sprechausgabe_Sonos_Test: httpGet(url=http://192.168.1.251:5005/K%C3%BCche/say/Guten Morgen, Heute ist Sonntag der 04.08.2024 es ist 19 Uhr 7 ,Die Außentemperatur beträgt 21,5 °C/de-de, error=connect ECONNREFUSED 192.168.1.251:5005)
                            javascript.0	19:07:20.967	info	Stopping script script.js.common.0_userdata_0_.Testbereich.Sprechausgabe_Sonos_Test
                            javascript.0	19:07:21.014	info	Start JavaScript script.js.common.0_userdata_0_.Testbereich.Sprechausgabe_Sonos_Test (Blockly)
                            javascript.0	19:07:21.022	info	script.js.common.0_userdata_0_.Testbereich.Sprechausgabe_Sonos_Test: http://192.168.1.251:5005/K%C3%BCche/say/Guten Morgen, Heute ist Sonntag der 04.08.2024 es ist 19 Uhr 7 ,Die Außentemperatur beträgt 21,5 °C/de-de
                            javascript.0	19:07:21.024	info	script.js.common.0_userdata_0_.Testbereich.Sprechausgabe_Sonos_Test: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                            javascript.0	19:07:21.025	error	script.js.common.0_userdata_0_.Testbereich.Sprechausgabe_Sonos_Test: httpGet(url=http://192.168.1.251:5005/K%C3%BCche/say/Guten Morgen, Heute ist Sonntag der 04.08.2024 es ist 19 Uhr 7 ,Die Außentemperatur beträgt 21,5 °C/de-de, error=connect ECONNREFUSED 192.168.1.251:5005)
                            javascript.0	19:07:26.840	info	Stopping script script.js.common.0_userdata_0_.Testbereich.Sprechausgabe_Sonos_Test
                            javascript.0	19:07:26.936	info	Start JavaScript script.js.common.0_userdata_0_.Testbereich.Sprechausgabe_Sonos_Test (Blockly)
                            javascript.0	19:07:26.939	info	script.js.common.0_userdata_0_.Testbereich.Sprechausgabe_Sonos_Test: http://192.168.1.251:5005/K%C3%BCche/say/Guten Morgen, Heute ist Sonntag der 04.08.2024 es ist 19 Uhr 7 ,Die Außentemperatur beträgt 21,5 °C/de-de
                            javascript.0	19:07:26.940	info	script.js.common.0_userdata_0_.Testbereich.Sprechausgabe_Sonos_Test: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                            javascript.0	19:08:07.100	info	Stopping script script.js.common.0_userdata_0_.Testbereich.Sprechausgabe_Sonos_Test
                            javascript.0	19:08:07.238	info	Start JavaScript script.js.common.0_userdata_0_.Testbereich.Sprechausgabe_Sonos_Test (Blockly)
                            javascript.0	19:08:07.248	info	script.js.common.0_userdata_0_.Testbereich.Sprechausgabe_Sonos_Test: http://192.168.1.251:5005/K%C3%BCche/say/Guten Morgen, Heute ist Sonntag der 04.08.2024 es ist 19 Uhr 8 ,Die Außentemperatur beträgt 21,5 °C/de-de
                            javascript.0	19:08:07.249	info	script.js.common.0_userdata_0_.Testbereich.Sprechausgabe_Sonos_Test: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                            javascript.0	19:08:08.574	error	script.js.common.0_userdata_0_.Testbereich.Sprechausgabe_Sonos_Test: httpGet(url=http://192.168.1.251:5005/K%C3%BCche/say/Guten Morgen, Heute ist Sonntag der 04.08.2024 es ist 19 Uhr 8 ,Die Außentemperatur beträgt 21,5 °C/de-de, error=socket hang up)
                            javascript.0	19:08:18.406	info	Stopping script script.js.common.0_userdata_0_.Testbereich.Sprechausgabe_Sonos_Test
                            javascript.0	19:08:18.496	info	Start JavaScript script.js.common.0_userdata_0_.Testbereich.Sprechausgabe_Sonos_Test (Blockly)
                            javascript.0	19:08:18.499	info	script.js.common.0_userdata_0_.Testbereich.Sprechausgabe_Sonos_Test: http://192.168.1.251:5005/K%C3%BCche/say/Guten Morgen, Heute ist Sonntag der 04.08.2024 es ist 19 Uhr 8 ,Die Außentemperatur beträgt 21,5 °C/de-de
                            javascript.0	19:08:18.500	info	script.js.common.0_userdata_0_.Testbereich.Sprechausgabe_Sonos_Test: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                            javascript.0	19:08:18.502	error	script.js.common.0_userdata_0_.Testbereich.Sprechausgabe_Sonos_Test: httpGet(url=http://192.168.1.251:5005/K%C3%BCche/say/Guten Morgen, Heute ist Sonntag der 04.08.2024 es ist 19 Uhr 8 ,Die Außentemperatur beträgt 21,5 °C/de-de, error=connect ECONNREFUSED 192.168.1.251:5005)
                            javascript.0	19:08:20.327	info	Stopping script script.js.common.0_userdata_0_.Testbereich.Sprechausgabe_Sonos_Test
                            javascript.0	19:08:20.482	info	Start JavaScript script.js.common.0_userdata_0_.Testbereich.Sprechausgabe_Sonos_Test (Blockly)
                            javascript.0	19:08:20.485	info	script.js.common.0_userdata_0_.Testbereich.Sprechausgabe_Sonos_Test: http://192.168.1.251:5005/K%C3%BCche/say/Guten Morgen, Heute ist Sonntag der 04.08.2024 es ist 19 Uhr 8 ,Die Außentemperatur beträgt 21,5 °C/de-de
                            javascript.0	19:08:20.486	info	script.js.common.0_userdata_0_.Testbereich.Sprechausgabe_Sonos_Test: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                            da wo der error fehlt geht es (halt 2x hintereinander)
                            • XBiT
                              Da ich immer noch an einer Lösung suche...
                              Kann es sein, dass der Timeout nicht lang genug wartet?
                              Ich habe 200ms und auch 500ms eingestellt bekomme aber nach 1ms die Meldung das die 500ms überschritten sind.
                              Habe für diesen Text das Blockly wie folgt aufgebaut:
                              Log:
                              javascript.0	20:06:57.237	error	script.js.common.0_userdata_0_.Testbereich.Sprechausgabe_Sonos_Test: httpGet(url=http://192.168.1.251:5005/K%C3%BCche/say/Guten Morgen, Heute ist /de-de, error=timeout of 200ms exceeded)
                              javascript.0	20:06:57.237	info	script.js.common.0_userdata_0_.Testbereich.Sprechausgabe_Sonos_Test: Status Code: null
                              javascript.0	20:06:57.237	info	script.js.common.0_userdata_0_.Testbereich.Sprechausgabe_Sonos_Test: Antwortzeit: undefined
                              javascript.0	20:06:57.237	info	script.js.common.0_userdata_0_.Testbereich.Sprechausgabe_Sonos_Test: response headers: [object Object]
                              javascript.0	20:06:57.237	info	script.js.common.0_userdata_0_.Testbereich.Sprechausgabe_Sonos_Test: Fehlermeldung: timeout of 200ms exceeded
                              javascript.0	20:07:11.688	info	Stopping script script.js.common.0_userdata_0_.Testbereich.Sprechausgabe_Sonos_Test
                              javascript.0	20:07:11.791	info	Start JavaScript script.js.common.0_userdata_0_.Testbereich.Sprechausgabe_Sonos_Test (Blockly)
                              javascript.0	20:07:11.801	info	script.js.common.0_userdata_0_.Testbereich.Sprechausgabe_Sonos_Test: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                              javascript.0	20:07:12.301	error	script.js.common.0_userdata_0_.Testbereich.Sprechausgabe_Sonos_Test: httpGet(url=http://192.168.1.251:5005/K%C3%BCche/say/Guten Morgen, Heute ist /de-de, error=timeout of 500ms exceeded)
                              javascript.0	20:07:12.302	info	script.js.common.0_userdata_0_.Testbereich.Sprechausgabe_Sonos_Test: Status Code: null
                              javascript.0	20:07:12.302	info	script.js.common.0_userdata_0_.Testbereich.Sprechausgabe_Sonos_Test: Antwortzeit: undefined
                              javascript.0	20:07:12.302	info	script.js.common.0_userdata_0_.Testbereich.Sprechausgabe_Sonos_Test: response headers: [object Object]
                              javascript.0	20:07:12.302	info	script.js.common.0_userdata_0_.Testbereich.Sprechausgabe_Sonos_Test: Fehlermeldung: timeout of 500ms exceeded
                              Irgendwie ist immer eine andere Meldung....
                                @xbit Kannst Du mal die Leerzeichen mit %20 ersetzen?
                                http://192.168.1.251:5005/K%C3%BCche/say/Guten%20Morgen%2C%20Heute%20ist%20/de-de
                                Klappt es dann?
                                • XBiT
                                  geht leider auch nicht.
                                  Ich muss aber dazu sagten das trotz der Fehlermeldung mit der Zeitüberschreitung der Text abgespielt wird.
                                  aber wenn der Text länger wird klappt es nicht mehr.
                                  Ich habe auch schon alle Sonderzeichen raus gemacht auch ohne Erfolg.
                                    @xbit Hab es gerade mal getestet und bekomme keinen Fehler. Timeout 5 Sek.
                                    • XBiT
                                      ich mit 5 sec auch nicht aber wenn das Script um 20:06:57.237 Startet und die Fehlermeldung 20:06:57.237 kommt das 200ms überschritten sind kann doch was nicht stimmen oder?
                                      aber wenn du auch Sonos hast und die http-api kannst du da nicht mal das Blockly bei dir testen?
                                        @xbit Da liegen doch exakt 500ms zwischen:
                                        • XBiT
                                          ja hast du recht bin bei dem testen schon ganz durch...
                                          Falls es möglich ist, da du ja augenscheinlich auch die Sonos http api hast könntest du ja mal den Code aus Post 1 testen ob er geht muss ja nur die IP und der Raumname geändert werden und eventuell die Außentemperatur ausschalten.
                                          Ansonsten müsste ich dann einen anderen Weg suchen um wieder die verschiedenen Ansagen zu erhalten.
                                          EDIT Sorry hier der Code oben ist ja der alte...
                                           <variables>
                                             <variable id="u.Y-DN^swG=N._[)_Ou;">URL</variable>
                                           </variables>
                                           <block type="variables_set" id=";toPl|v_k)-Tvh{jioUv" x="138" y="139">
                                                               <block type="variables_set" id="}O4.1lMB$3{U9PIQfK2=">
        <field name="VAR" id="u.Y-DN^swG=N._[)_Ou;">URL</field>
        <block type="text_join" id="BlNtE64ngY`sL9,6K2c1">
        <value name="ADD0">
        <value name="ADD1">
        <field name="TEXT">Guten Morgen, Heute ist </field>
        <value name="ADD2">
        <value name="ADD3">
        <value name="ADD4">
        <value name="ADD5">
        <value name="ADD6">
        <value name="ADD7">
        <value name="ADD8">
        <value name="ADD9">
        <field name="TEXT"> ,Die Außentemperatur beträgt </field>
        <field name="TEXT"> °C</field>
        <block type="http_get" id="HZyjDv(_WWtZJ/N~r)n#">
        <field name="TIMEOUT">5000</field>
        <value name="URL">
        <shadow type="text" id="]QqbnelmljagyO6(JuII">
        <block type="variables_get" id="oG[T`sBKo,TF)U9L=#$l">
        <block type="debug" id="`{4Q:A_;0/;v5ObGz@}V">
        <value name="TEXT">
        <shadow type="text" id="/t~R~V7vjx6C`.#64r#7">
        <block type="text_join" id="ejOhZtZ3{#s9#$R]]gY(">
        <value name="ADD0">
        <block type="text" id="]YJDuc77F}fO!;khXoT:">
        <field name="TEXT">Status Code: </field>
        <value name="ADD1">
        <block type="http_response" id="v~s/TH4lLH(9]rp!c!5G">
        <block type="debug" id="Nm$c*oKwv-mg^-!CHgZ%">
        <value name="TEXT">
        <block type="text_join" id="wU{//STC-,^TKv,~rW1G">
        <value name="ADD0">
        <block type="text" id="l.oO)Ds5u+Q|hvr@t2br">
        <field name="TEXT">Antwortzeit: </field>
        <value name="ADD1">
        <block type="http_response" id="1~;L#P0yMQ.n![GZRat$">
        <field name="ATTR">response.responseTime</field>
        <block type="debug" id="65R*P%4ZDntHrdpaY%vI">
        <value name="TEXT">
        <shadow type="text" id="tLR}z4`p(!vqnl85yERd">
        <block type="text_join" id=":/IHh3YZVby/HDYu}vn6">
        <value name="ADD0">
        <block type="text" id="r|=EmI]2L|Ww`-Ek}R}4">
        <field name="TEXT">response headers: </field>
        <value name="ADD1">
        <block type="http_response" id="~80D7|Xs2T66ZnBojvRb">
        <field name="ATTR">response.headers</field>
        <block type="debug" id=":4IF62d+X?nzq*}dD0%$">
        <value name="TEXT">
        <block type="text_join" id="t?crVa1);ldCM{RRPR2K">
        <value name="ADD0">
        <block type="text" id="#JtLY!ix`OLR-3F4XeDN">
        <field name="TEXT">Fehlermeldung: </field>
        <value name="ADD1">
        <block type="http_response" id="C7YLZ{m}C6#$}Bcxu^2b">
        <field name="ATTR">err</field>
                                            jwerlsdf @XBiT last edited by jwerlsdf
                                            @xbit
                                            Den Fehler "error=socket hang up" habe ich auch manchmal. Und zwar dann, wenn ich mehrere Befehle hintereinander abfeuere, z.b. wenn ich dir Lautstärke schrittweise verändere.
                                            Das hat meines Wissens aber nicht mi blockly zu tun oder mit dem httpget Block, sonder an sonos selbst. Ich habe diese Probleme erst seitdem ich damals die neues Software, die nur Probleme macht, installiert habe. Mit der alten Software hatte ich mit meinen blocklys nie Probleme gehabt.
                                            1345
