    4. [gelöst] Performance nach Systemcrash problematisch
      m.schalk last edited by m.schalk
      Halo zusammen
      nach einem Systemabsturz ist mein iob total langsam, ich ich bekomme diese Fehlermeldungen:
       Cannot read system.config: undefined (OK when migrating or restoring)
      Server Configured backup period 7200000 is larger than the supported maximum of 35791 minutes. Defaulting to 120 minutes.
      /opt/iobroker/node_modules/standard-as-callback/built/index.js:6
              throw e;
      Error: Connection is closed.
          at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
          at Redis.scan (/opt/iobroker/node_modules/ioredis/built/commander.js:122:25)
          at ScanStream._read (/opt/iobroker/node_modules/ioredis/built/ScanStream.js:36:41)
          at Readable.read (node:internal/streams/readable:737:12)
          at resume_ (node:internal/streams/readable:1255:12)
          at process.processTicksAndRejections (node:internal/process/task_queues:82:21)
      Emitted 'error' event on ScanStream instance at:
          at /opt/iobroker/node_modules/ioredis/built/ScanStream.js:38:22
          at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:12:23)
          at /opt/iobroker/node_modules/standard-as-callback/built/index.js:33:51
          at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
      Node.js v20.16.0
        Thomas Braun Most Active @m.schalk last edited by
        @m-schalk
        Schau dir per
        iob diag
        an, wo es da vielleicht klemmt.
          Homoran Global Moderator Administrators @m.schalk last edited by
          @m-schalk sagte in Performance nach Systemcrash problematisch:
          heisst was genau??
          Du hattest ja auch bisher schon ständige reboots
            m.schalk @Thomas Braun last edited by
            @thomas-braun hier die Ausgabe:
            Skript v.2024-05-22
            *** BASE SYSTEM ***
             Static hostname: BU02SMART02-iobroker
                   Icon name: computer-container
                     Chassis: container
              Virtualization: lxc
            Operating System: Ubuntu 22.04.4 LTS
                      Kernel: Linux 6.8.8-3-pve
                Architecture: x86-64
            model name      : Intel(R) Core(TM) i3-5010U CPU @ 2.10GHz
            Docker          : false
            Virtualization  : lxc
            Kernel          : x86_64
            Userland        : 64 bit
            Systemuptime and Load:
             18:48:52 up  2:02,  3 users,  load average: 5.50, 7.11, 7.09
            CPU threads: 4
            *** Time and Time Zones ***
                           Local time: Sat 2024-08-03 18:48:52 CEST
                       Universal time: Sat 2024-08-03 16:48:52 UTC
                             RTC time: n/a
                          NTP service: inactive
                      RTC in local TZ: no
            *** Users and Groups ***
            User that called 'iob diag':
            mario
            HOME=/home/mario
            GROUPS=mario sudo iobroker
            iobroker
            HOME=/home/iobroker
            GROUPS=iobroker tty dialout audio video plugdev redis
            *** Display-Server-Setup ***
            Display-Server: false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Mem:            8.2G        5.3G        1.2G        0.0K        1.8G        2.9G
            Swap:           7.8G        684M        7.1G
            Total:           15G        5.9G        8.2G
            Active iob-Instances:   41
                     8192 M total memory
                     5257 M used memory
                     3861 M active memory
                     2647 M inactive memory
                     1155 M free memory
                        0 M buffer memory
                     1779 M swap cache
                     7759 M total swap
                      684 M used swap
                     7075 M free swap
            top - 18:48:53 up  2:02,  3 users,  load average: 5.50, 7.11, 7.09
            Tasks:  78 total,   6 running,  72 sleeping,   0 stopped,   0 zombie
            %Cpu(s): 75.8 us, 12.1 sy,  0.0 ni,  6.1 id,  0.0 wa,  0.0 hi,  6.1 si,  0.0 st
            MiB Mem :   8192.0 total,   1154.5 free,   5257.7 used,   1779.7 buff/cache
            MiB Swap:   7760.0 total,   7075.2 free,    684.8 used.   2934.2 avail Mem
            *** FAILED SERVICES ***
              UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
            * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
            1 loaded units listed.
            *** FILESYSTEM ***
            Filesystem     Type   Size  Used Avail Use% Mounted on
            /dev/loop0     ext4    36G   24G   11G  69% /
            none           tmpfs  492K  4.0K  488K   1% /dev
            tmpfs          tmpfs  7.8G     0  7.8G   0% /dev/shm
            tmpfs          tmpfs  3.1G  152K  3.1G   1% /run
            tmpfs          tmpfs  5.0M     0  5.0M   0% /run/lock
            tmpfs          tmpfs  1.6G     0  1.6G   0% /run/user/1001
            dmesg: read kernel buffer failed: Operation not permitted
            Show mounted filesystems:
            TARGET                                        SOURCE                         FSTYPE      OPTIONS
            /                                             /dev/loop0                     ext4        rw,relatime
            |-/run                                        tmpfs                          tmpfs       rw,nosuid,nodev,size=3240840k,nr_inodes=819200,mode=755,uid=100000,gid=100000,inode64
            | |-/run/lock                                 tmpfs                          tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k,uid=100000,gid=100000,inode64
            | |-/run/credentials/systemd-sysusers.service ramfs                          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
            | `-/run/user/1001                            tmpfs                          tmpfs       rw,nosuid,nodev,relatime,size=1620416k,nr_inodes=405104,mode=700,uid=101001,gid=101001,inode64
            |-/dev                                        none                           tmpfs       rw,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
            | |-/dev/shm                                  tmpfs                          tmpfs       rw,nosuid,nodev,uid=100000,gid=100000,inode64
            | |-/dev/mqueue                               mqueue                         mqueue      rw,relatime
            | |-/dev/ttyUSB0                              udev[/ttyUSB0]                 devtmpfs    rw,nosuid,relatime,size=8068256k,nr_inodes=2017064,mode=755,inode64
            | | `-/dev/ttyUSB0                            udev[/ttyUSB0]                 devtmpfs    rw,nosuid,relatime,size=8068256k,nr_inodes=2017064,mode=755,inode64
            | |-/dev/.lxc/proc                            proc                           proc        rw,relatime
            | |-/dev/.lxc/sys                             sys                            sysfs       rw,relatime
            | |-/dev/full                                 udev[/full]                    devtmpfs    rw,nosuid,relatime,size=8068256k,nr_inodes=2017064,mode=755,inode64
            | |-/dev/null                                 udev[/null]                    devtmpfs    rw,nosuid,relatime,size=8068256k,nr_inodes=2017064,mode=755,inode64
            | |-/dev/random                               udev[/random]                  devtmpfs    rw,nosuid,relatime,size=8068256k,nr_inodes=2017064,mode=755,inode64
            | |-/dev/tty                                  udev[/tty]                     devtmpfs    rw,nosuid,relatime,size=8068256k,nr_inodes=2017064,mode=755,inode64
            | |-/dev/urandom                              udev[/urandom]                 devtmpfs    rw,nosuid,relatime,size=8068256k,nr_inodes=2017064,mode=755,inode64
            | |-/dev/zero                                 udev[/zero]                    devtmpfs    rw,nosuid,relatime,size=8068256k,nr_inodes=2017064,mode=755,inode64
            | |-/dev/pts                                  devpts                         devpts      rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
            | |-/dev/ptmx                                 devpts[/ptmx]                  devpts      rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
            | |-/dev/console                              devpts[/0]                     devpts      rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
            | |-/dev/tty1                                 devpts[/1]                     devpts      rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
            | `-/dev/tty2                                 devpts[/2]                     devpts      rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
            |-/proc                                       proc                           proc        rw,nosuid,nodev,noexec,relatime
            | |-/proc/sys                                 proc[/sys]                     proc        ro,relatime
            | | |-/proc/sys/net                           proc[/sys/net]                 proc        rw,nosuid,nodev,noexec,relatime
            | | |-/proc/sys/fs/binfmt_misc                binfmt_misc                    binfmt_misc rw,nosuid,nodev,noexec,relatime
            | | `-/proc/sys/kernel/random/boot_id         none[/.lxc-boot-id]            tmpfs       ro,nosuid,nodev,noexec,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
            | |-/proc/sysrq-trigger                       proc[/sysrq-trigger]           proc        ro,relatime
            | |-/proc/cpuinfo                             lxcfs[/proc/cpuinfo]           fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
            | |-/proc/diskstats                           lxcfs[/proc/diskstats]         fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
            | |-/proc/loadavg                             lxcfs[/proc/loadavg]           fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
            | |-/proc/meminfo                             lxcfs[/proc/meminfo]           fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
            | |-/proc/slabinfo                            lxcfs[/proc/slabinfo]          fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
            | |-/proc/stat                                lxcfs[/proc/stat]              fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
            | |-/proc/swaps                               lxcfs[/proc/swaps]             fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
            | `-/proc/uptime                              lxcfs[/proc/uptime]            fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
            `-/sys                                        sysfs                          sysfs       ro,nosuid,nodev,noexec,relatime
              |-/sys/fs/fuse/connections                  fusectl                        fusectl     rw,nosuid,nodev,noexec,relatime
              |-/sys/devices/virtual/net                  sysfs[/devices/virtual/net]    sysfs       rw,nosuid,nodev,noexec,relatime
              |-/sys/kernel/debug                         debugfs                        debugfs     rw,nosuid,nodev,noexec,relatime
              |-/sys/kernel/security                      securityfs                     securityfs  rw,nosuid,nodev,noexec,relatime
              |-/sys/fs/pstore                            pstore                         pstore      rw,nosuid,nodev,noexec,relatime
              |-/sys/fs/cgroup                            none                           cgroup2     rw,nosuid,nodev,noexec,relatime
              `-/sys/devices/system/cpu                   lxcfs[/sys/devices/system/cpu] fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
            /var:
            5.2G    /var/
            3.7G    /var/log
            3.6G    /var/log/journal/a4cc250a83fe4944adccd8462a307fa7
            807M    /var/lib
            Archived and active journals take up 8.0M in the file system.
            /opt/iobroker/backups:
            777M    /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            9.3G    /opt/iobroker/iobroker-data/
            7.3G    /opt/iobroker/iobroker-data/history
            737M    /opt/iobroker/iobroker-data/files
            487M    /opt/iobroker/iobroker-data/esphome.0/.esphome/build
            136M    /opt/iobroker/iobroker-data/objects.jsonl
            98M     /opt/iobroker/iobroker-data/objects.json.migrated
            98M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
            97M     /opt/iobroker/iobroker-data/objects.json.broken
            41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
            USB-Devices by-id:
            /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_d653ffa49dc9eb11ade6914f1d69213e-if00-port0
            HINT:
            Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
            /dev/ttyUSB0
            *** NodeJS-Installation ***
            /usr/bin/nodejs         v20.16.0
            /usr/bin/node           v20.16.0
            /usr/bin/npm            10.8.1
            /usr/bin/npx            10.8.1
            /usr/bin/corepack       0.28.2
            nodejs:
              Installed: 20.16.0-1nodesource1
              Candidate: 20.16.0-1nodesource1
              Version table:
             *** 20.16.0-1nodesource1 1001
                    500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                    100 /var/lib/dpkg/status
                 20.15.1-1nodesource1 1001
                 20.15.0-1nodesource1 1001
                 20.14.0-1nodesource1 1001
                 20.13.1-1nodesource1 1001
                 20.13.0-1nodesource1 1001
                 20.12.2-1nodesource1 1001
                 20.12.1-1nodesource1 1001
                 20.12.0-1nodesource1 1001
                 20.11.1-1nodesource1 1001
                 20.11.0-1nodesource1 1001
                 20.10.0-1nodesource1 1001
                 20.9.0-1nodesource1 1001
                 20.8.1-1nodesource1 1001
                 20.8.0-1nodesource1 1001
                 20.7.0-1nodesource1 1001
                 20.6.1-1nodesource1 1001
                 20.6.0-1nodesource1 1001
                 20.5.1-1nodesource1 1001
                 20.5.0-1nodesource1 1001
                 20.4.0-1nodesource1 1001
                 20.3.1-1nodesource1 1001
                 20.3.0-1nodesource1 1001
                 20.2.0-1nodesource1 1001
                 20.1.0-1nodesource1 1001
                 20.0.0-1nodesource1 1001
                 12.22.9~dfsg-1ubuntu3.6 500
                    500 http://archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages
                    500 http://archive.ubuntu.com/ubuntu jammy-security/universe amd64 Packages
                 12.22.9~dfsg-1ubuntu3 500
                    500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
            No problems detected
            Errors in npm tree:
            *** ioBroker-Installation ***
            ioBroker Status
            Objects type: jsonl
            States  type: redis
            Core adapters versions
            js-controller:  6.0.9
            admin:          6.17.14
            javascript:     8.3.1
            nodejs modules from github:     1
            | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
            Adapter State
            + system.adapter.admin.0                  : admin                 : BU02SMART02-iobroker                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            + system.adapter.alarm.0                  : alarm                 : BU02SMART02-iobroker                     -  enabled
            + system.adapter.alexa2.0                 : alexa2                : BU02SMART02-iobroker                     -  enabled
              system.adapter.bosesoundtouch.0         : bosesoundtouch        : BU02SMART02-iobroker                     - disabled
            + system.adapter.daikin.0                 : daikin                : BU02SMART02-iobroker                     -  enabled
            + system.adapter.device-reminder.0        : device-reminder       : BU02SMART02-iobroker                     -  enabled
            + system.adapter.device-watcher.1         : device-watcher        : BU02SMART02-iobroker                     -  enabled
            + system.adapter.discovery.0              : discovery             : BU02SMART02-iobroker                     -  enabled
              system.adapter.dwd.0                    : dwd                   : BU02SMART02-iobroker                     -  enabled
              system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : BU02SMART02-iobroker                     - disabled
            + system.adapter.ems-esp.0                : ems-esp               : BU02SMART02-iobroker                     -  enabled
            + system.adapter.energiefluss.0           : energiefluss          : BU02SMART02-iobroker                     -  enabled
            + system.adapter.energiefluss.1           : energiefluss          : BU02SMART02-iobroker                     -  enabled
              system.adapter.feiertage.0              : feiertage             : BU02SMART02-iobroker                     -  enabled
              system.adapter.flot.0                   : flot                  : BU02SMART02-iobroker                     -  enabled
            + system.adapter.followthesun.0           : followthesun          : BU02SMART02-iobroker                     -  enabled
            + system.adapter.ford.0                   : ford                  : BU02SMART02-iobroker                     -  enabled
              system.adapter.hass-mqtt.0              : hass-mqtt             : BU02SMART02-iobroker                     -  enabled
            + system.adapter.history.0                : history               : BU02SMART02-iobroker                     -  enabled
            + system.adapter.homeconnect.0            : homeconnect           : BU02SMART02-iobroker                     -  enabled
              system.adapter.ical.0                   : ical                  : BU02SMART02-iobroker                     -  enabled
              system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: BU02SMART02-iobroker                     -  enabled
              system.adapter.icons-icons8.0           : icons-icons8          : BU02SMART02-iobroker                     -  enabled
              system.adapter.icons-material-png.0     : icons-material-png    : BU02SMART02-iobroker                     -  enabled
              system.adapter.icons-material-svg.0     : icons-material-svg    : BU02SMART02-iobroker                     -  enabled
              system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : BU02SMART02-iobroker                     -  enabled
              system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: BU02SMART02-iobroker                     -  enabled
              system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : BU02SMART02-iobroker                     -  enabled
            + system.adapter.influxdb.0               : influxdb              : BU02SMART02-iobroker                     -  enabled, port: 8086
            + system.adapter.info.0                   : info                  : BU02SMART02-iobroker                     -  enabled
            + system.adapter.iot.0                    : iot                   : BU02SMART02-iobroker                     -  enabled
              system.adapter.iwg-vpn.0                : iwg-vpn               : BU02SMART02-iobroker                     - disabled
            + system.adapter.javascript.0             : javascript            : BU02SMART02-iobroker                     -  enabled
            + system.adapter.linkeddevices.0          : linkeddevices         : BU02SMART02-iobroker                     -  enabled
              system.adapter.material.0               : material              : BU02SMART02-iobroker                     -  enabled
            + system.adapter.mercedesme.0             : mercedesme            : BU02SMART02-iobroker                     -  enabled
              system.adapter.mqtt-client.0            : mqtt-client           : BU02SMART02-iobroker                     - disabled, port: 1892
            + system.adapter.mqtt.0                   : mqtt                  : BU02SMART02-iobroker                     -  enabled, port: 1886, bind: 0.0.0.0
            + system.adapter.mqtt.1                   : mqtt                  : BU02SMART02-iobroker                     -  enabled, port: 1891, bind: 192.168.2.166
            + system.adapter.net-tools.0              : net-tools             : BU02SMART02-iobroker                     -  enabled
              system.adapter.netatmo-crawler.0        : netatmo-crawler       : BU02SMART02-iobroker                     -  enabled
              system.adapter.openweathermap.0         : openweathermap        : BU02SMART02-iobroker                     -  enabled
              system.adapter.pi-hole.0                : pi-hole               : BU02SMART02-iobroker                     - disabled
            + system.adapter.ping.0                   : ping                  : BU02SMART02-iobroker                     -  enabled
            + system.adapter.pvforecast.0             : pvforecast            : BU02SMART02-iobroker                     -  enabled
            + system.adapter.ring.0                   : ring                  : BU02SMART02-iobroker                     -  enabled
            + system.adapter.samsung.0                : samsung               : BU02SMART02-iobroker                     -  enabled
            + system.adapter.shelly.0                 : shelly                : BU02SMART02-iobroker                     -  enabled, port: 1890, bind: 0.0.0.0
            + system.adapter.shelly.1                 : shelly                : BU02SMART02-iobroker                     -  enabled, port: 1890, bind: 192.168.2.166
              system.adapter.shuttercontrol.0         : shuttercontrol        : BU02SMART02-iobroker                     - disabled
            + system.adapter.slideshow.0              : slideshow             : BU02SMART02-iobroker                     -  enabled
            + system.adapter.smartthings.0            : smartthings           : BU02SMART02-iobroker                     -  enabled
              system.adapter.snmp.0                   : snmp                  : BU02SMART02-iobroker                     - disabled
              system.adapter.socketio.0               : socketio              : BU02SMART02-iobroker                     - disabled, port: 8084, bind: 192.168.2.166, run as: admin
            + system.adapter.sourceanalytix.0         : sourceanalytix        : BU02SMART02-iobroker                     -  enabled
            + system.adapter.telegram.0               : telegram              : BU02SMART02-iobroker                     -  enabled, port: 8443, bind: 0.0.0.0
            + system.adapter.tuya.0                   : tuya                  : BU02SMART02-iobroker                     -  enabled
              system.adapter.tuya.1                   : tuya                  : BU02SMART02-iobroker                     - disabled
            + system.adapter.unifi.0                  : unifi                 : BU02SMART02-iobroker                     -  enabled
            + system.adapter.virtualpowermeter.0      : virtualpowermeter     : BU02SMART02-iobroker                     -  enabled
              system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : BU02SMART02-iobroker                     -  enabled
              system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : BU02SMART02-iobroker                     -  enabled
              system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: BU02SMART02-iobroker                     -  enabled
              system.adapter.vis-2.0                  : vis-2                 : BU02SMART02-iobroker                     - disabled
              system.adapter.vis-bars.0               : vis-bars              : BU02SMART02-iobroker                     -  enabled
              system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : BU02SMART02-iobroker                     -  enabled
              system.adapter.vis-colorpicker.0        : vis-colorpicker       : BU02SMART02-iobroker                     -  enabled
              system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : BU02SMART02-iobroker                     -  enabled
              system.adapter.vis-history.0            : vis-history           : BU02SMART02-iobroker                     -  enabled
              system.adapter.vis-homekittiles.0       : vis-homekittiles      : BU02SMART02-iobroker                     -  enabled
              system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : BU02SMART02-iobroker                     -  enabled
              system.adapter.vis-icontwo.0            : vis-icontwo           : BU02SMART02-iobroker                     -  enabled
            + system.adapter.vis-inventwo.0           : vis-inventwo          : BU02SMART02-iobroker                     -  enabled
              system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : BU02SMART02-iobroker                     -  enabled
              system.adapter.vis-justgage.0           : vis-justgage          : BU02SMART02-iobroker                     -  enabled
              system.adapter.vis-lcars.0              : vis-lcars             : BU02SMART02-iobroker                     -  enabled
              system.adapter.vis-material-advanced.0  : vis-material-advanced : BU02SMART02-iobroker                     -  enabled
              system.adapter.vis-material.0           : vis-material          : BU02SMART02-iobroker                     -  enabled
              system.adapter.vis-materialdesign.0     : vis-materialdesign    : BU02SMART02-iobroker                     -  enabled
              system.adapter.vis-plumb.0              : vis-plumb             : BU02SMART02-iobroker                     -  enabled
              system.adapter.vis-rgraph.0             : vis-rgraph            : BU02SMART02-iobroker                     -  enabled
              system.adapter.vis-timeandweather.0     : vis-timeandweather    : BU02SMART02-iobroker                     -  enabled
              system.adapter.vis-weather.0            : vis-weather           : BU02SMART02-iobroker                     -  enabled
              system.adapter.vis.0                    : vis                   : BU02SMART02-iobroker                     -  enabled
            + system.adapter.web.0                    : web                   : BU02SMART02-iobroker                     -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
              system.adapter.ws.0                     : ws                    : BU02SMART02-iobroker                     - disabled, port: 8087, bind: 192.168.2.166, run as: admin
            + system.adapter.yahka.0                  : yahka                 : BU02SMART02-iobroker                     -  enabled
              system.adapter.yahka.1                  : yahka                 : BU02SMART02-iobroker                     - disabled
            + system.adapter.zigbee.0                 : zigbee                : BU02SMART02-iobroker                     -  enabled, port: /dev/ttyUSB0
            + instance is alive
            ioBroker-Repositories
            │ (index) │ name               │ url                                                     │ auto upgrade │
            │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
            │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
            Upgrade policy: none
            Installed ioBroker-Instances
            Adapter    "admin"        : 7.0.22   , installed 6.17.14 [Updatable]
            Adapter    "alarm"        : 3.6.1    , installed 3.6.0  [Updatable]
            Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
            Adapter    "bosesoundtouch": 0.11.1  , installed 0.11.1
            Adapter    "daikin"       : 1.4.2    , installed 1.4.2
            Adapter    "device-reminder": 3.1.2  , installed 3.1.2
            Adapter    "device-watcher": 2.12.1  , installed 2.12.1
            Adapter    "discovery"    : 4.5.0    , installed 4.5.0
            Adapter    "ecovacs-deebot": 1.4.15  , installed 1.4.15
            Adapter    "ems-esp"      : 3.5.0    , installed 3.5.0
            Adapter    "energiefluss" : 3.6.0    , installed 3.6.0
            Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
            Adapter    "followthesun" : 0.5.0    , installed 0.5.0
            Adapter    "ford"         : 1.0.2    , installed 1.0.4
            Adapter    "homeconnect"  : 1.4.1    , installed 1.4.0  [Updatable]
            Adapter    "ical"         : 1.15.0   , installed 1.15.0
            Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
            Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.3
            Adapter    "iot"          : 3.3.0    , installed 3.3.0
            Adapter    "iwg-vpn"      : 3.0.0    , installed 3.0.0
            Adapter    "javascript"   : 8.7.6    , installed 8.3.1  [Updatable]
            Controller "js-controller": 6.0.9    , installed 6.0.9
            Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
            Adapter    "material"     : 1.3.1    , installed 1.3.1
            Adapter    "megaesp"      : 0.1.0    , installed 0.1.0
            Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
            Adapter    "mqtt-client"  : 2.0.0    , installed 1.8.0  [Updatable]
            Adapter    "net-tools"    : 1.0.11   , installed 1.0.11
            Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
            Adapter    "openweathermap": 1.0.4   , installed 1.0.4
            Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
            Adapter    "pvforecast"   : 3.0.0    , installed 2.9.1  [Updatable]
            Adapter    "ring"         : 5.1.0    , installed 5.0.10 [Updatable]
            Adapter    "samsung"      : 0.6.0    , installed 0.6.0
            Adapter    "shelly"       : 7.0.0    , installed 7.0.0
            Adapter    "shuttercontrol": 1.7.3   , installed 1.7.0  [Updatable]
            Adapter    "snmp"         : 3.2.0    , installed 3.2.0
            Adapter    "socketio"     : 6.7.0    , installed 6.7.0
            Adapter    "statistics"   : 2.4.0    , installed 2.4.0
            Adapter    "telegram"     : 3.3.2    , installed 3.3.2
            Adapter    "tuya"         : 3.15.0   , installed 3.15.0
            Adapter    "unifi"        : 0.7.0    , installed 0.7.0
            Adapter    "virtualpowermeter": 1.4.6, installed 1.4.6
            Adapter    "vis-2"        : 2.9.32   , installed 2.9.51
            Adapter    "vis-2-widgets-energy": 0.3.11, installed 0.3.11
            Adapter    "vis-2-widgets-gauges": 1.0.3, installed 1.0.3
            Adapter    "vis-2-widgets-material": 1.3.32, installed 1.3.32
            Adapter    "vis-homekittiles": 0.3.1 , installed 0.0.13 [Updatable]
            Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
            Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
            Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
            Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
            Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
            Adapter    "vis-material" : 0.1.3    , installed 0.1.3
            Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
            Adapter    "ws"           : 2.6.1    , installed 2.6.1
            Adapter    "yahka"        : 1.0.3    , installed 1.0.3
            Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
            Objects and States
            Objects:        187587
            States:         143163
            Hit:1 http://archive.ubuntu.com/ubuntu jammy InRelease
            Hit:2 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
            Hit:3 https://apt.grafana.com stable InRelease
            Hit:4 http://archive.ubuntu.com/ubuntu jammy-security InRelease
            Hit:5 https://repos.influxdata.com/debian stable InRelease
            Hit:6 https://deb.nodesource.com/node_20.x nodistro InRelease
            Hit:7 https://packagecloud.io/ookla/speedtest-cli/ubuntu jammy InRelease
            Reading package lists...
            Pending Updates: 0
            *** Listening Ports ***
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       882653     18458/iobroker.js-c
            tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1000       901411     18626/io.mqtt.0
            tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          255566     281/master
            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          254112     1/systemd
            tcp        0      0 192.168.2.166:1890      0.0.0.0:*               LISTEN      1000       911405     18716/io.shelly.1
            tcp        0      0 192.168.2.166:1891      0.0.0.0:*               LISTEN      1000       900734     18643/io.mqtt.1
            tcp        0      0 0.0.0.0:43187           0.0.0.0:*               LISTEN      1000       907056     19010/io.yahka.0
            tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      106        253717     100/systemd-resolve
            tcp        0      0 127.0.0.1:6010          0.0.0.0:*               LISTEN      1001       500980     8227/sshd: mario@pt
            tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      113        254487     116/redis-server 12
            tcp6       0      0 ::1:25                  :::*                    LISTEN      0          255567     281/master
            tcp6       0      0 :::22                   :::*                    LISTEN      0          580349     1/systemd
            tcp6       0      0 :::111                  :::*                    LISTEN      0          254114     1/systemd
            tcp6       0      0 :::3000                 :::*                    LISTEN      112        581673     11836/grafana
            tcp6       0      0 ::1:6010                :::*                    LISTEN      1001       500979     8227/sshd: mario@pt
            tcp6       0      0 :::8082                 :::*                    LISTEN      1000       915640     19139/io.web.0
            tcp6       0      0 :::8081                 :::*                    LISTEN      1000       889125     18477/io.admin.0
            tcp6       0      0 ::1:6379                :::*                    LISTEN      113        254488     116/redis-server 12
            udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       918452     18710/io.shelly.0
            udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       917833     18681/io.tuya.0
            udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       917834     18681/io.tuya.0
            udp        0      0 127.0.0.53:53           0.0.0.0:*                           106        253716     100/systemd-resolve
            udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          254113     1/systemd
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       907053     19010/io.yahka.0
            udp6       0      0 :::111                  :::*                                0          254115     1/systemd
            2024-08-03 18:49:59.641  - error: host.BU02SMART02-iobroker instance system.adapter.hass-mqtt.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
            2024-08-03 18:50:24.054  - error: unifi.0 (18695) Error site default (data): {"meta":{"rc":"error","msg":"api.err.LoginRequired"},"data":[]}
            2024-08-03 18:50:24.055  - error: unifi.0 (18695) [updateUnifiData site default] error: Request failed with status code 401, stack: AxiosError: Request failed with status code 401
                at settle (/opt/iobroker/node_modules/axios/lib/core/settle.js:19:12)
                at IncomingMessage.handleStreamEnd (/opt/iobroker/node_modules/axios/lib/adapters/http.js:585:11)
                at IncomingMessage.emit (node:events:531:35)
                at IncomingMessage.emit (node:domain:488:12)
                at endReadableNT (node:internal/streams/readable:1696:12)
                at processTicksAndRejections (node:internal/process/task_queues:82:21)
            2024-08-03 18:51:00.180  - warn: dwd.0 (22516) slow connection to objects DB. Still waiting ...
            2024-08-03 18:51:06.143  - warn: netatmo-crawler.0 (22533) slow connection to objects DB. Still waiting ...
            2024-08-03 18:51:06.972  - error: host.BU02SMART02-iobroker Caught by controller[0]: /opt/iobroker/node_modules/iobroker.hass-mqtt/build/main.js:18
            2024-08-03 18:51:06.975  - error: host.BU02SMART02-iobroker Caught by controller[0]: class HassMqtt extends utils.Adapter {
            2024-08-03 18:51:06.976  - error: host.BU02SMART02-iobroker Caught by controller[0]:                              ^
            2024-08-03 18:51:06.976  - error: host.BU02SMART02-iobroker Caught by controller[0]: TypeError: Class extends value #<Object> is not a constructor or null
            2024-08-03 18:51:06.976  - error: host.BU02SMART02-iobroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.hass-mqtt/build/main.js:18:30)
            2024-08-03 18:51:06.976  - error: host.BU02SMART02-iobroker Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1358:14)
            2024-08-03 18:51:06.976  - error: host.BU02SMART02-iobroker Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
            2024-08-03 18:51:06.976  - error: host.BU02SMART02-iobroker Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1208:32)
            2024-08-03 18:51:06.976  - error: host.BU02SMART02-iobroker Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1024:12)
            2024-08-03 18:51:06.976  - error: host.BU02SMART02-iobroker Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:174:12)
            2024-08-03 18:51:06.976  - error: host.BU02SMART02-iobroker Caught by controller[0]:     at node:internal/main/run_main_module:28:49
            2024-08-03 18:51:06.976  - error: host.BU02SMART02-iobroker Caught by controller[0]: Node.js v20.16.0
            2024-08-03 18:51:06.976  - error: host.BU02SMART02-iobroker instance system.adapter.hass-mqtt.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
            2024-08-03 18:51:34.454  - warn: zigbee.0 (18736) DeviceAvailability:Failed to ping 0x5c0272fffe6e55ea TRADFRI Signal Repeater
              m.schalk @Homoran last edited by m.schalk
              @homoran das Problem konnte ich fixen.
                hier die Log Ausgabe:
                Zeit
                info
                Nachricht
                2024-08-03 18:55:16.662	error	instance system.adapter.hass-mqtt.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                2024-08-03 18:55:16.662	error	Caught by controller[0]: Node.js v20.16.0
                2024-08-03 18:55:16.662	error	Caught by controller[0]: at node:internal/main/run_main_module:28:49
                2024-08-03 18:55:16.662	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:174:12)
                2024-08-03 18:55:16.662	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1024:12)
                2024-08-03 18:55:16.662	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1208:32)
                2024-08-03 18:55:16.662	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                2024-08-03 18:55:16.661	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1358:14)
                2024-08-03 18:55:16.661	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.hass-mqtt/build/main.js:18:30)
                2024-08-03 18:55:16.661	error	Caught by controller[0]: TypeError: Class extends value #<Object> is not a constructor or null
                2024-08-03 18:55:16.661	error	Caught by controller[0]: ^
                2024-08-03 18:55:16.661	error	Caught by controller[0]: class HassMqtt extends utils.Adapter {
                2024-08-03 18:55:16.661	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.hass-mqtt/build/main.js:18
                  sicher?
                  sieht nicht wirklich besser aus.
                  schade, wäre höchst interessant
                    @m-schalk
                    Roll da halt einen frischen Container rein.
                    Dafür sind die Dinger doch da.
                      @homoran said in Performance nach Systemcrash problematisch:
                      sicher?
                      @Homoran bis vor 120 min war alles ok, ich kann hat nicht sagen woher die hohe Last kommt
                      @Homoran keine Ahnung warum es nicht funktioniert
                        @thomas-braun said in Performance nach Systemcrash problematisch:
                        @m-schalk
                        @Thomas-Braun
                        schade ich dachte ich kann was retten
                          @m-schalk
                          Was willste denn retten? Du hast doch ein Backup für sowas.
                          Bist du eigentlich sicher, das nicht das Host-System einen Schaden hat?
                          279
