    4. ZIGBEE: Ping Intervall ändern (DeviceAvailability)
      pluto8 last edited by
      Hallo!
      Habe ein Zigbee Rolladenmodul verbaut und soweit lässt es sich auch ansteuern. Mich stören 2 Dinge:
      1. Lässt sich das Ping-Intervall ändern? Das Modul wird exakt alle 5 Minuten abgefragt.
      2. Im gleichen Log taucht auch der Fehler "DeviceAvailability:Exception in readState" auf. Fragt IOBroker hier aktiv den Status des Moduls ab? Kann man das auch ausstellen, oder hängen Punkt 1 und 2 zusammen?
      Danke für eine Antwort!
      Rolladenmodul: QS-Zigbee-C03 / Quelle
      2024-08-05 14:04:48.800 - debug: zigbee.0 (16616) DeviceAvailability:Exception in readState of '0xa4c138a0a203ee06' - error : 'TypeError: converter.convertGet is not a function'
      2024-08-05 14:04:49.025 - debug: zigbee.0 (16616) handleMessage. {"type":"readResponse","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":2,"_applicationVersion":64,"_dateCode":"","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":514,"inputClusters":[4,5,6,258,0],"outputClusters":[25,10],"profileID":260,"ID":1,"clusters":{"genBasic":{"attributes":{"stackVersion":0,"dateCode":"","zclVersion":3}},"closuresWindowCovering":{"attributes":{"tuyaMovingState":1,"currentPositionLiftPercentage":0,"tuyaMotorReversal":0,"moesCalibrationTime":217,"tuyaCalibration":1}},"genOnOff":{"attributes":{"tuyaBacklightMode":0}}},"deviceIeeeAddress":"0xa4c138a0a203ee06","deviceNetworkAddress":65420,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0xa4c138a0a203ee06"}},{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":97,"inputClusters":[],"outputClusters":[33],"profileID":41440,"ID":242,"clusters":{},"deviceIeeeAddress":"0xa4c138a0a203ee06","deviceNetworkAddress":65420,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":242,"deviceIeeeAddress":"0xa4c138a0a203ee06"}}],"_hardwareVersion":1,"_ieeeAddr":"0xa4c138a0a203ee06","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1722859489024,"_manufacturerID":4417,"_manufacturerName":"_TZ3000_zirycpws","_modelID":"TS130F","_networkAddress":65420,"_powerSource":"Mains (single phase)","_stackVersion":0,"_type":"Router","_zclVersion":3,"_linkquality":32,"_skipDefaultResponse":false,"_deleted":false,"_lastDefaultResponseSequenceNumber":6,"_pendingRequestTimeout":0,"meta":{}},"endpoint":"[Circular]","data":{"zclVersion":3},"linkquality":32,"groupID":0,"cluster":"genBasic","meta":{"zclTransactionSequenceNumber":28,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
      2024-08-05 14:04:49.025 - debug: zigbee.0 (16616) Received Zigbee message from '0xa4c138a0a203ee06', type 'readResponse', cluster 'genBasic', data '{"zclVersion":3}' from endpoint 1 with groupID 0
      2024-08-05 14:04:49.026 - debug: zigbee.0 (16616) Type readResponse device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":2,"_applicationVersion":64,"_dateCode":"","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":514,"inputClusters":[4,5,6,258,0],"outputClusters":[25,10],"profileID":260,"ID":1,"clusters":{"genBasic":{"attributes":{"stackVersion":0,"dateCode":"","zclVersion":3}},"closuresWindowCovering":{"attributes":{"tuyaMovingState":1,"currentPositionLiftPercentage":0,"tuyaMotorReversal":0,"moesCalibrationTime":217,"tuyaCalibration":1}},"genOnOff":{"attributes":{"tuyaBacklightMode":0}}},"deviceIeeeAddress":"0xa4c138a0a203ee06","deviceNetworkAddress":65420,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0xa4c138a0a203ee06"}},{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":97,"inputClusters":[],"outputClusters":[33],"profileID":41440,"ID":242,"clusters":{},"deviceIeeeAddress":"0xa4c138a0a203ee06","deviceNetworkAddress":65420,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":242,"deviceIeeeAddress":"0xa4c138a0a203ee06"}}],"_hardwareVersion":1,"_ieeeAddr":"0xa4c138a0a203ee06","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1722859489024,"_manufacturerID":4417,"_manufacturerName":"_TZ3000_zirycpws","_modelID":"TS130F","_networkAddress":65420,"_powerSource":"Mains (single phase)","_stackVersion":0,"_type":"Router","_zclVersion":3,"_linkquality":32,"_skipDefaultResponse":false,"_deleted":false,"_lastDefaultResponseSequenceNumber":6,"_pendingRequestTimeout":0,"meta":{}},"mapped":{"fingerprint":[{"modelID":"TS130F","manufacturerName":"_TZ3000_zirycpws"},{"modelID":"TS130F","manufacturerName":"_TZ3210_ol1uhvza"}],"model":"QS-Zigbee-C03","vendor":"Lonsonho","description":"Curtain/blind motor controller","fromZigbee":[{"cluster":"closuresWindowCovering","type":["attributeReport","readResponse"],"options":[{"name":"invert_cover","label":"Invert cover","access":2,"type":"binary","property":"invert_cover","description":"Inverts the cover position, false: open=100,close=0, true: open=0,close=100 (default false).","value_on":true,"value_off":false}]},{"cluster":"closuresWindowCovering","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state"]},{"key":["position","tilt"],"options":[{"name":"invert_cover","label":"Invert cover","access":2,"type":"binary","property":"invert_cover","description":"Inverts the cover position, false: open=100,close=0, true: open=0,close=100 (default false).","value_on":true,"value_off":false}]},{"key":["calibration"]},{"key":["motor_reversal"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["scene_rename"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]},{"key":["zclcommand"]}],"meta":{"coverInverted":true},"exposes":[{"type":"cover","features":[{"name":"state","label":"State","access":3,"type":"enum","property":"state","values":["OPEN","CLOSE","STOP"]},{"name":"position","label":"Position","access":7,"type":"numeric","property":"position","description":"Position of this cover","unit":"%","value_max":100,"value_min":0}]},{"name":"moving","label":"Moving","access":1,"type":"enum","property":"moving","values":["UP","STOP","DOWN"]},{"name":"calibration","label":"Calibration","access":7,"type":"binary","property":"calibration","value_on":"ON","value_off":"OFF"},{"name":"motor_reversal","label":"Motor reversal","access":7,"type":"binary","property":"motor_reversal","value_on":"ON","value_off":"OFF"},{"name":"calibration_time","label":"Calibration time","access":1,"type":"numeric","property":"calibration_time","description":"Calibration time","unit":"s"},{"name":"linkquality","label":"Linkquality","access":1,"type":"numeric","property":"linkquality","description":"Link quality (signal strength)","category":"diagnostic","unit":"lqi","value_max":255,"value_min":0}],"options":["[Circular]"]},"name":"0xa4c138a0a203ee06"} incoming event: {"type":"readResponse","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":2,"_applicationVersion":64,"_dateCode":"","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":514,"inputClusters":[4,5,6,258,0],"outputClusters":[25,10],"profileID":260,"ID":1,"clusters":{"genBasic":{"attributes":{"stackVersion":0,"dateCode":"","zclVersion":3}},"closuresWindowCovering":{"attributes":{"tuyaMovingState":1,"currentPositionLiftPercentage":0,"tuyaMotorReversal":0,"moesCalibrationTime":217,"tuyaCalibration":1}},"genOnOff":{"attributes":{"tuyaBacklightMode":0}}},"deviceIeeeAddress":"0xa4c138a0a203ee06","deviceNetworkAddress":65420,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0xa4c138a0a203ee06"}},{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":97,"inputClusters":[],"outputClusters":[33],"profileID":41440,"ID":242,"clusters":{},"deviceIeeeAddress":"0xa4c138a0a203ee06","deviceNetworkAddress":65420,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":242,"deviceIeeeAddress":"0xa4c138a0a203ee06"}}],"_hardwareVersion":1,"_ieeeAddr":"0xa4c138a0a203ee06","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1722859489024,"_manufacturerID":4417,"_manufacturerName":"_TZ3000_zirycpws","_modelID":"TS130F","_networkAddress":65420,"_powerSource":"Mains (single phase)","_stackVersion":0,"_type":"Router","_zclVersion":3,"_linkquality":32,"_skipDefaultResponse":false,"_deleted":false,"_lastDefaultResponseSequenceNumber":6,"_pendingRequestTimeout":0,"meta":{}},"endpoint":"[Circular]","data":{"zclVersion":3},"linkquality":32,"groupID":0,"cluster":"genBasic","meta":{"zclTransactionSequenceNumber":28,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
      2024-08-05 14:04:49.026 - debug: zigbee.0 (16616) DeviceAvailability:Successfully pinged 0xa4c138a0a203ee06 TS130F
      2024-08-05 14:09:49.029 - debug: zigbee.0 (16616) DeviceAvailability:Exception in readState of '0xa4c138a0a203ee06' - error : 'TypeError: converter.convertGet is not a function'
      2024-08-05 14:09:49.301 - debug: zigbee.0 (16616) handleMessage. {"type":"readResponse","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":2,"_applicationVersion":64,"_dateCode":"","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":514,"inputClusters":[4,5,6,258,0],"outputClusters":[25,10],"profileID":260,"ID":1,"clusters":{"genBasic":{"attributes":{"stackVersion":0,"dateCode":"","zclVersion":3}},"closuresWindowCovering":{"attributes":{"tuyaMovingState":1,"currentPositionLiftPercentage":0,"tuyaMotorReversal":0,"moesCalibrationTime":217,"tuyaCalibration":1}},"genOnOff":{"attributes":{"tuyaBacklightMode":0}}},"deviceIeeeAddress":"0xa4c138a0a203ee06","deviceNetworkAddress":65420,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0xa4c138a0a203ee06"}},{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":97,"inputClusters":[],"outputClusters":[33],"profileID":41440,"ID":242,"clusters":{},"deviceIeeeAddress":"0xa4c138a0a203ee06","deviceNetworkAddress":65420,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":242,"deviceIeeeAddress":"0xa4c138a0a203ee06"}}],"_hardwareVersion":1,"_ieeeAddr":"0xa4c138a0a203ee06","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1722859789300,"_manufacturerID":4417,"_manufacturerName":"_TZ3000_zirycpws","_modelID":"TS130F","_networkAddress":65420,"_powerSource":"Mains (single phase)","_stackVersion":0,"_type":"Router","_zclVersion":3,"_linkquality":98,"_skipDefaultResponse":false,"_deleted":false,"_lastDefaultResponseSequenceNumber":6,"_pendingRequestTimeout":0,"meta":{}},"endpoint":"[Circular]","data":{"zclVersion":3},"linkquality":98,"groupID":0,"cluster":"genBasic","meta":{"zclTransactionSequenceNumber":29,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
      2024-08-05 14:09:49.301 - debug: zigbee.0 (16616) Received Zigbee message from '0xa4c138a0a203ee06', type 'readResponse', cluster 'genBasic', data '{"zclVersion":3}' from endpoint 1 with groupID 0
      2024-08-05 14:09:49.302 - debug: zigbee.0 (16616) Type readResponse device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":2,"_applicationVersion":64,"_dateCode":"","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":514,"inputClusters":[4,5,6,258,0],"outputClusters":[25,10],"profileID":260,"ID":1,"clusters":{"genBasic":{"attributes":{"stackVersion":0,"dateCode":"","zclVersion":3}},"closuresWindowCovering":{"attributes":{"tuyaMovingState":1,"currentPositionLiftPercentage":0,"tuyaMotorReversal":0,"moesCalibrationTime":217,"tuyaCalibration":1}},"genOnOff":{"attributes":{"tuyaBacklightMode":0}}},"deviceIeeeAddress":"0xa4c138a0a203ee06","deviceNetworkAddress":65420,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0xa4c138a0a203ee06"}},{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":97,"inputClusters":[],"outputClusters":[33],"profileID":41440,"ID":242,"clusters":{},"deviceIeeeAddress":"0xa4c138a0a203ee06","deviceNetworkAddress":65420,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":242,"deviceIeeeAddress":"0xa4c138a0a203ee06"}}],"_hardwareVersion":1,"_ieeeAddr":"0xa4c138a0a203ee06","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1722859789300,"_manufacturerID":4417,"_manufacturerName":"_TZ3000_zirycpws","_modelID":"TS130F","_networkAddress":65420,"_powerSource":"Mains (single phase)","_stackVersion":0,"_type":"Router","_zclVersion":3,"_linkquality":98,"_skipDefaultResponse":false,"_deleted":false,"_lastDefaultResponseSequenceNumber":6,"_pendingRequestTimeout":0,"meta":{}},"mapped":{"fingerprint":[{"modelID":"TS130F","manufacturerName":"_TZ3000_zirycpws"},{"modelID":"TS130F","manufacturerName":"_TZ3210_ol1uhvza"}],"model":"QS-Zigbee-C03","vendor":"Lonsonho","description":"Curtain/blind motor controller","fromZigbee":[{"cluster":"closuresWindowCovering","type":["attributeReport","readResponse"],"options":[{"name":"invert_cover","label":"Invert cover","access":2,"type":"binary","property":"invert_cover","description":"Inverts the cover position, false: open=100,close=0, true: open=0,close=100 (default false).","value_on":true,"value_off":false}]},{"cluster":"closuresWindowCovering","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state"]},{"key":["position","tilt"],"options":[{"name":"invert_cover","label":"Invert cover","access":2,"type":"binary","property":"invert_cover","description":"Inverts the cover position, false: open=100,close=0, true: open=0,close=100 (default false).","value_on":true,"value_off":false}]},{"key":["calibration"]},{"key":["motor_reversal"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["scene_rename"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]},{"key":["zclcommand"]}],"meta":{"coverInverted":true},"exposes":[{"type":"cover","features":[{"name":"state","label":"State","access":3,"type":"enum","property":"state","values":["OPEN","CLOSE","STOP"]},{"name":"position","label":"Position","access":7,"type":"numeric","property":"position","description":"Position of this cover","unit":"%","value_max":100,"value_min":0}]},{"name":"moving","label":"Moving","access":1,"type":"enum","property":"moving","values":["UP","STOP","DOWN"]},{"name":"calibration","label":"Calibration","access":7,"type":"binary","property":"calibration","value_on":"ON","value_off":"OFF"},{"name":"motor_reversal","label":"Motor reversal","access":7,"type":"binary","property":"motor_reversal","value_on":"ON","value_off":"OFF"},{"name":"calibration_time","label":"Calibration time","access":1,"type":"numeric","property":"calibration_time","description":"Calibration time","unit":"s"},{"name":"linkquality","label":"Linkquality","access":1,"type":"numeric","property":"linkquality","description":"Link quality (signal strength)","category":"diagnostic","unit":"lqi","value_max":255,"value_min":0}],"options":["[Circular]"]},"name":"0xa4c138a0a203ee06"} incoming event: {"type":"readResponse","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":2,"_applicationVersion":64,"_dateCode":"","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":514,"inputClusters":[4,5,6,258,0],"outputClusters":[25,10],"profileID":260,"ID":1,"clusters":{"genBasic":{"attributes":{"stackVersion":0,"dateCode":"","zclVersion":3}},"closuresWindowCovering":{"attributes":{"tuyaMovingState":1,"currentPositionLiftPercentage":0,"tuyaMotorReversal":0,"moesCalibrationTime":217,"tuyaCalibration":1}},"genOnOff":{"attributes":{"tuyaBacklightMode":0}}},"deviceIeeeAddress":"0xa4c138a0a203ee06","deviceNetworkAddress":65420,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0xa4c138a0a203ee06"}},{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":97,"inputClusters":[],"outputClusters":[33],"profileID":41440,"ID":242,"clusters":{},"deviceIeeeAddress":"0xa4c138a0a203ee06","deviceNetworkAddress":65420,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":242,"deviceIeeeAddress":"0xa4c138a0a203ee06"}}],"_hardwareVersion":1,"_ieeeAddr":"0xa4c138a0a203ee06","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1722859789300,"_manufacturerID":4417,"_manufacturerName":"_TZ3000_zirycpws","_modelID":"TS130F","_networkAddress":65420,"_powerSource":"Mains (single phase)","_stackVersion":0,"_type":"Router","_zclVersion":3,"_linkquality":98,"_skipDefaultResponse":false,"_deleted":false,"_lastDefaultResponseSequenceNumber":6,"_pendingRequestTimeout":0,"meta":{}},"endpoint":"[Circular]","data":{"zclVersion":3},"linkquality":98,"groupID":0,"cluster":"genBasic","meta":{"zclTransactionSequenceNumber":29,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
      2024-08-05 14:09:49.302 - debug: zigbee.0 (16616) DeviceAvailability:Successfully pinged 0xa4c138a0a203ee06 TS130F
      2024-08-05 14:14:49.310 - debug: zigbee.0 (16616) DeviceAvailability:Exception in readState of '0xa4c138a0a203ee06' - error : 'TypeError: converter.convertGet is not a function'
      2024-08-05 14:14:49.715 - debug: zigbee.0 (16616) handleMessage. {"type":"readResponse","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":2,"_applicationVersion":64,"_dateCode":"","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":514,"inputClusters":[4,5,6,258,0],"outputClusters":[25,10],"profileID":260,"ID":1,"clusters":{"genBasic":{"attributes":{"stackVersion":0,"dateCode":"","zclVersion":3}},"closuresWindowCovering":{"attributes":{"tuyaMovingState":1,"currentPositionLiftPercentage":0,"tuyaMotorReversal":0,"moesCalibrationTime":217,"tuyaCalibration":1}},"genOnOff":{"attributes":{"tuyaBacklightMode":0}}},"deviceIeeeAddress":"0xa4c138a0a203ee06","deviceNetworkAddress":65420,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0xa4c138a0a203ee06"}},{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":97,"inputClusters":[],"outputClusters":[33],"profileID":41440,"ID":242,"clusters":{},"deviceIeeeAddress":"0xa4c138a0a203ee06","deviceNetworkAddress":65420,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":242,"deviceIeeeAddress":"0xa4c138a0a203ee06"}}],"_hardwareVersion":1,"_ieeeAddr":"0xa4c138a0a203ee06","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1722860089715,"_manufacturerID":4417,"_manufacturerName":"_TZ3000_zirycpws","_modelID":"TS130F","_networkAddress":65420,"_powerSource":"Mains (single phase)","_stackVersion":0,"_type":"Router","_zclVersion":3,"_linkquality":87,"_skipDefaultResponse":false,"_deleted":false,"_lastDefaultResponseSequenceNumber":6,"_pendingRequestTimeout":0,"meta":{}},"endpoint":"[Circular]","data":{"zclVersion":3},"linkquality":87,"groupID":0,"cluster":"genBasic","meta":{"zclTransactionSequenceNumber":30,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
      2024-08-05 14:14:49.716 - debug: zigbee.0 (16616) Received Zigbee message from '0xa4c138a0a203ee06', type 'readResponse', cluster 'genBasic', data '{"zclVersion":3}' from endpoint 1 with groupID 0
      2024-08-05 14:14:49.716 - debug: zigbee.0 (16616) Type readResponse device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":2,"_applicationVersion":64,"_dateCode":"","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":514,"inputClusters":[4,5,6,258,0],"outputClusters":[25,10],"profileID":260,"ID":1,"clusters":{"genBasic":{"attributes":{"stackVersion":0,"dateCode":"","zclVersion":3}},"closuresWindowCovering":{"attributes":{"tuyaMovingState":1,"currentPositionLiftPercentage":0,"tuyaMotorReversal":0,"moesCalibrationTime":217,"tuyaCalibration":1}},"genOnOff":{"attributes":{"tuyaBacklightMode":0}}},"deviceIeeeAddress":"0xa4c138a0a203ee06","deviceNetworkAddress":65420,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0xa4c138a0a203ee06"}},{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":97,"inputClusters":[],"outputClusters":[33],"profileID":41440,"ID":242,"clusters":{},"deviceIeeeAddress":"0xa4c138a0a203ee06","deviceNetworkAddress":65420,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":242,"deviceIeeeAddress":"0xa4c138a0a203ee06"}}],"_hardwareVersion":1,"_ieeeAddr":"0xa4c138a0a203ee06","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1722860089715,"_manufacturerID":4417,"_manufacturerName":"_TZ3000_zirycpws","_modelID":"TS130F","_networkAddress":65420,"_powerSource":"Mains (single phase)","_stackVersion":0,"_type":"Router","_zclVersion":3,"_linkquality":87,"_skipDefaultResponse":false,"_deleted":false,"_lastDefaultResponseSequenceNumber":6,"_pendingRequestTimeout":0,"meta":{}},"mapped":{"fingerprint":[{"modelID":"TS130F","manufacturerName":"_TZ3000_zirycpws"},{"modelID":"TS130F","manufacturerName":"_TZ3210_ol1uhvza"}],"model":"QS-Zigbee-C03","vendor":"Lonsonho","description":"Curtain/blind motor controller","fromZigbee":[{"cluster":"closuresWindowCovering","type":["attributeReport","readResponse"],"options":[{"name":"invert_cover","label":"Invert cover","access":2,"type":"binary","property":"invert_cover","description":"Inverts the cover position, false: open=100,close=0, true: open=0,close=100 (default false).","value_on":true,"value_off":false}]},{"cluster":"closuresWindowCovering","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state"]},{"key":["position","tilt"],"options":[{"name":"invert_cover","label":"Invert cover","access":2,"type":"binary","property":"invert_cover","description":"Inverts the cover position, false: open=100,close=0, true: open=0,close=100 (default false).","value_on":true,"value_off":false}]},{"key":["calibration"]},{"key":["motor_reversal"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["scene_rename"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]},{"key":["zclcommand"]}],"meta":{"coverInverted":true},"exposes":[{"type":"cover","features":[{"name":"state","label":"State","access":3,"type":"enum","property":"state","values":["OPEN","CLOSE","STOP"]},{"name":"position","label":"Position","access":7,"type":"numeric","property":"position","description":"Position of this cover","unit":"%","value_max":100,"value_min":0}]},{"name":"moving","label":"Moving","access":1,"type":"enum","property":"moving","values":["UP","STOP","DOWN"]},{"name":"calibration","label":"Calibration","access":7,"type":"binary","property":"calibration","value_on":"ON","value_off":"OFF"},{"name":"motor_reversal","label":"Motor reversal","access":7,"type":"binary","property":"motor_reversal","value_on":"ON","value_off":"OFF"},{"name":"calibration_time","label":"Calibration time","access":1,"type":"numeric","property":"calibration_time","description":"Calibration time","unit":"s"},{"name":"linkquality","label":"Linkquality","access":1,"type":"numeric","property":"linkquality","description":"Link quality (signal strength)","category":"diagnostic","unit":"lqi","value_max":255,"value_min":0}],"options":["[Circular]"]},"name":"0xa4c138a0a203ee06"} incoming event: {"type":"readResponse","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":2,"_applicationVersion":64,"_dateCode":"","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":514,"inputClusters":[4,5,6,258,0],"outputClusters":[25,10],"profileID":260,"ID":1,"clusters":{"genBasic":{"attributes":{"stackVersion":0,"dateCode":"","zclVersion":3}},"closuresWindowCovering":{"attributes":{"tuyaMovingState":1,"currentPositionLiftPercentage":0,"tuyaMotorReversal":0,"moesCalibrationTime":217,"tuyaCalibration":1}},"genOnOff":{"attributes":{"tuyaBacklightMode":0}}},"deviceIeeeAddress":"0xa4c138a0a203ee06","deviceNetworkAddress":65420,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0xa4c138a0a203ee06"}},{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":97,"inputClusters":[],"outputClusters":[33],"profileID":41440,"ID":242,"clusters":{},"deviceIeeeAddress":"0xa4c138a0a203ee06","deviceNetworkAddress":65420,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":242,"deviceIeeeAddress":"0xa4c138a0a203ee06"}}],"_hardwareVersion":1,"_ieeeAddr":"0xa4c138a0a203ee06","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1722860089715,"_manufacturerID":4417,"_manufacturerName":"_TZ3000_zirycpws","_modelID":"TS130F","_networkAddress":65420,"_powerSource":"Mains (single phase)","_stackVersion":0,"_type":"Router","_zclVersion":3,"_linkquality":87,"_skipDefaultResponse":false,"_deleted":false,"_lastDefaultResponseSequenceNumber":6,"_pendingRequestTimeout":0,"meta":{}},"endpoint":"[Circular]","data":{"zclVersion":3},"linkquality":87,"groupID":0,"cluster":"genBasic","meta":{"zclTransactionSequenceNumber":30,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
      2024-08-05 14:14:49.717 - debug: zigbee.0 (16616) DeviceAvailability:Successfully pinged 0xa4c138a0a203ee06 TS130F
      Asgothian arteck 2 Replies Last reply Reply Quote 0
      • Asgothian
        Asgothian Developer @pluto8 last edited by
        @pluto8 sagte in ZIGBEE: Ping Intervall ändern (DeviceAvailability):
        Hallo!
        Welche Version ?
        Bleibt der Fehler auch bei der 1.10.5 von github erhalten ?
          pluto8 @Asgothian last edited by
          Welche Version ?
          ioBroker v7.0.22
          Zigbee jetzt manuell auf 1.10.5 geupdated
          Leider sind Fehlermeldungen und Abstand zwischen den (unerwünschten) Reports gleich geblieben. Gibt es keine Möglichkeit diese DeviceAvalability-Anfragen abzuschalten?
          • mcm1957
            mcm1957 @pluto8 last edited by
            @pluto8
            Ähmmm
            ist ein DEBUG Meldung. Was stört dich an der?
            Wenn du keine Debug Meldungen sehen willst, stell den Adapter einfach auf die normale Einstellung (Info) zurück.
            Und was das Intervall betrifft:
            Was ist da das Problem? Ist dir die Abfrage zu selten? Zu oft ? Und warum?
              arteck Developer Most Active @pluto8 last edited by arteck
              @pluto8 das sind alles DEBUG Meldungen.. warum steht der Adapter auf Debug ???
              ioBroker v7.0.22
              ich weiss zwar nicht aus welchen Jahrhundert du schreibst aber.. 7.x Version von iobroker ist sehr weit in der Zukunft
              wir sind gerade bei 6.x seid paar Tagen
              • Codierknecht
                Codierknecht Developer Most Active @arteck last edited by Codierknecht
                @arteck
                Er meint wohl den Admin 😉
                @pluto8
                Der Admin-Adapter ist für die Verwaltung und Einstellung Deines ioBroker zuständig.
                Viel interessanter und wichtiger ist die Version des JS-Controllers. Die wird Dir beim Host angezeigt.
                  pluto8 @mcm1957 last edited by
                  @mcm1957 said in ZIGBEE: Ping Intervall ändern (DeviceAvailability):
                  Ich möchte noch viele Rolladen und weitere Dinge im Haus mit Zigbee regeln. Da sind schnell mal 30 bis 40 Zigbee-Module verbaut.
                  Zigbee sendet im Gegensatz zu Wlan nur bei Anforderung, sonst im Ruhe im Bus. 😉
                  Es ist jetzt kein Problem, wenn das System alle 5 Minuten den Status ermittelt, aber bevorzugen würde ich längere Intervalle oder auch niemals. Daher noch meine Fragen:
                  • Sind diese 5 Minuten fix programmiert und lassen sich nicht ändern?
                  • Werden batteriebetriebene Module dann auch in dem Intervall abgefragt?
                  • Ich hatte auch mal Z2M über HA laufen. Da war tatsächlich Ruhe im Bus (auch im Debug) 😉
                  Ansonsten Danke für die Rückmeldung.
                  Übrigens: js-controller: 6.0.9
                  • Asgothian
                    • die Ping-Zeit lässt sich (absichtlich) nicht einstellen, sie ist aber dynamisch, und wird mit Grösse des Netzes langsamer, um den Netztraffic zu begrenzen
                    • die Batteriebetriebenen Geräte werden per Definition nicht angeping, da diese im Normalfall sowieso nicht antworten. Bei denen wird die Erreichbarkeit anders festgestellt.
                    • Z2M nutzt prinzipiell ein ähnliches verfahren, allerdings hatten wir Probleme bei der Übernahme der Erreichbarkeit der Geräte so das wir das selber neu programmieren mussten. Dazu nutzen wir vom z2m gemeldete Abfragbare Werte - wobei bei Deinem Gerät da offensichtlich ein Fehler in der Definition vorliegt. Um was für ein Gerät handelt es sich - dann nehmen wir das mit in die nicht abfragbaren Geräte auf.
                      @asgothian
                      Schade, dass man das nicht einstellen kann. Es geht um das schon oben beschriebene Rolladenmodul.
                      Geräteinformation:
                      model:QS-Zigbee-C03
                      description:Curtain/blind motor controller
                      modelZigbee:TS130F
                      type:Router
                      nwk:65420
                      manuf id:4417
                      manufacturer:_TZ3000_zirycpws
                      power:Mains (single phase)
                      app version:64
                      hard version:1
                      zcl version:3
                      stack version:0
                      date code:
                      interviewed:true
                      configured:false
                      endpoint:1
                      profile:260
                      input clusters:genGroups (4)
                      genScenes (5)
                      genOnOff (6)
                      closuresWindowCovering (258)
                      genBasic (0)
                      output clusters:genOta (25)
                      genTime (10)
                      endpoint:242
                      profile:41440
                      output clusters:greenPower (33)
