    4. Wrong Type
    Wrong Type
    • kmxak
      Hi
      habe in den Logs folgende Fehlermeldung:
      javascript.0	2017-09-14 18:51:09.643	warn	Wrong type of javascript.0.User.Alarmserver.Treppenhaus: "boolean". Please fix, while deprecated and will not work in next versions.
        "common": {
          "name": "Treppenhaus",
          "type": "boolean",
          "role": "javascript",
          "read": true,
          "write": true
        "native": {
          "type": "undefined",
          "name": "Name",
          "read": true,
          "write": true
        "acl": {
          "object": 1636,
          "owner": "system.user.admin",
          "ownerGroup": "system.group.administrator",
          "state": 1636
        "_id": "javascript.0.User.Alarmserver.Treppenhaus",
        "type": "state"
      Das Script setzt bei dem Objekt true oder false
      Kann mir einer sagen was ich falsch gemacht habe und es mir ggf erklären wieso und warum?
      Hier das Blockly
      <block xmlns="http://www.w3.org/1999/xhtml" type="on" id="N6C2ZjF4]-0asMUuag4`" x="-112" y="-12"><field name="OID">javascript.0.User.Alarmserver.Treppenhaus</field>
      <statement name="STATEMENT"><block type="control_ex" id="LHY@M73y2DBgl9nNdV,%"><field name="TYPE">false</field>
      <value name="OID"><shadow type="field_oid" id="x9A+=[4oakX[Gp^DLn?v"><field name="oid">javascript.0.scriptEnabled.User.Telegram.Alarm_Bild_Treppenhaus</field></shadow></value>
      <value name="VALUE"><shadow type="logic_boolean" id="x.4(37R1r9*[7LewyXQ"><field name="BOOL">TRUE</field></shadow></value> <value name="DELAY_MS"><shadow type="math_number" id="3%1oXQ2lYz?hRe[]YrFP"><field name="NUM">0</field></shadow></value> <next><block type="control_ex" id="vpSJ;5:laVtc!X/TDs;p"><field name="TYPE">true</field> <field name="CLEAR_RUNNING">FALSE</field> <value name="OID"><shadow type="field_oid" id="vw;CuoF[N@gidGB_U9r"><field name="oid">javascript.0.User.Alarmserver.Treppenhaus</field></shadow></value>
      <value name="VALUE"><shadow type="logic_boolean" id=";gpo*/6nnO_RK``l5SQt"><field name="BOOL">FALSE</field></shadow></value>
      <value name="DELAY_MS"><shadow type="math_number" id="R{utQ?^!d#-lN[W/imNq"><field name="NUM">15000</field></shadow></value>
      <next><block type="debug" id="9Iul0^cpGL/CcnZPX#so"><field name="Severity">debug</field>
      <value name="TEXT"><shadow type="text" id="|LopY4TO7ir8*^T=FSY~"><field name="TEXT">test</field></shadow></value></block></next></block></next></block></statement></block>
        paul53 last edited by
        Sieh so das Objekt wirklich aus ? Wenn ja, dann ist eine öffnende geschweifte Klammer zu viel (1. oder 2. Zeile).
        • kmxak
          tippfehler sorry in den objekten ist es richtig
          • apollon77
            apollon77 last edited by
            Die Fehlermeldung bedeutet das ein anderer Wert geschrieben wird bei "setState".
            Schick mal den generierten JavaScript code bitte
            • kmxak
              on({id: "javascript.0.User.Alarmserver.Treppenhaus"/*Treppenhaus*/, val: true}, function (obj) {
                var value = obj.state.val;
                setStateDelayed('javascript.0.scriptEnabled.User.Telegram.Alarm_Bild_Treppenhaus', true, false, parseInt(0, 10), false);
                setStateDelayed('javascript.0.User.Alarmserver.Treppenhaus', false, true, parseInt(15000, 10), false);
                console.debug('test');
              Bitte
