    4. Nach Update auf js-controller 6.0.9 startet ECharts nicht
    • JoJo58
      JoJo58 last edited by
      Moin Zusammen
      ich habe eben auf meinem Raspberry den js-controller auf die Version 6.0.9 aktualisiert und seit dem startet der EChart Adapter nicht mehr.
      Es kommen folgende Meldungen im Protokoll:
      host.raspi4gb	2024-08-07 16:34:40.329	info	Rebuild for adapter system.adapter.echarts.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
      host.raspi4gb	2024-08-07 16:34:40.329	error	instance system.adapter.echarts.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.raspi4gb	2024-08-07 16:34:40.328	error	Caught by controller[0]: Node.js v20.16.0
      host.raspi4gb	2024-08-07 16:34:40.328	error	Caught by controller[0]: }
      host.raspi4gb	2024-08-07 16:34:40.328	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.echarts/main.js' ]
      host.raspi4gb	2024-08-07 16:34:40.328	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
      host.raspi4gb	2024-08-07 16:34:40.328	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:174:12) {
      host.raspi4gb	2024-08-07 16:34:40.328	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1024:12)
      host.raspi4gb	2024-08-07 16:34:40.328	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1208:32)
      host.raspi4gb	2024-08-07 16:34:40.327	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
      host.raspi4gb	2024-08-07 16:34:40.327	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1358:14)
      host.raspi4gb	2024-08-07 16:34:40.327	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.echarts/main.js:12:21)
      host.raspi4gb	2024-08-07 16:34:40.327	error	Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
      host.raspi4gb	2024-08-07 16:34:40.327	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1233:19)
      host.raspi4gb	2024-08-07 16:34:40.327	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:986:27)
      host.raspi4gb	2024-08-07 16:34:40.327	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1145:15)
      host.raspi4gb	2024-08-07 16:34:40.327	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.echarts/main.js
      host.raspi4gb	2024-08-07 16:34:40.326	error	Caught by controller[0]: Require stack:
      host.raspi4gb	2024-08-07 16:34:40.326	error	Caught by controller[0]: Error: Cannot find module '@iobroker/adapter-core'
      host.raspi4gb	2024-08-07 16:34:40.326	error	Caught by controller[0]: ^
      host.raspi4gb	2024-08-07 16:34:40.326	error	Caught by controller[0]: throw err;
      host.raspi4gb	2024-08-07 16:34:40.325	error	Caught by controller[0]: node:internal/modules/cjs/loader:1148
      host.raspi4gb	2024-08-07 16:34:39.909	info	instance system.adapter.echarts.0 in version "1.7.2" started with pid 3032
      Was kann ich da tun? Ich würde den ungerne deinstallieren und neu installieren, oder wären dann die vorhandenen Charts noch da?
      Gruß, Johannes
        Thomas Braun Most Active @JoJo58 last edited by
        @jojo58 sagte in Nach Update auf js-controller 6.0.9 startet ECharts nicht:
        Ich vermute, hier könnte mal die Beta-Version des Adapters angezeigt sein. Installier mal die
        latest: 1.9.0
        JoJo58 1 Reply Last reply Reply Quote 0
        • JoJo58
          JoJo58 @Thomas Braun last edited by
          Die Beta-Version und ein Reboot haben geholfen. Adapter ist wieder grün. Das Blöde ist, die angelegten Presets sind weg, kein einziger Chart mehr da 😧 😖
          M haus-automatisierung 2 Replies Last reply Reply Quote 0
            Maddm @JoJo58 last edited by
            @jojo58 @Thomas-Braun
            Ich habe glaube genau den gleichen Fehler:
            2024-08-28 12:37:02.920 - error: host.gm-ESPRIMO-Q556 Caught by controller[0]: node:internal/modules/cjs/loader:1228
            2024-08-28 12:37:02.920 - error: host.gm-ESPRIMO-Q556 Caught by controller[0]: throw err;
            2024-08-28 12:37:02.920 - error: host.gm-ESPRIMO-Q556 Caught by controller[0]: ^
            2024-08-28 12:37:02.920 - error: host.gm-ESPRIMO-Q556 Caught by controller[0]: Error: Cannot find module '@iobroker/adapter-core'
            2024-08-28 12:37:02.920 - error: host.gm-ESPRIMO-Q556 Caught by controller[0]: Require stack:
            2024-08-28 12:37:02.920 - error: host.gm-ESPRIMO-Q556 Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.echarts/main.js
            2024-08-28 12:37:02.920 - error: host.gm-ESPRIMO-Q556 Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1225:15)
            2024-08-28 12:37:02.920 - error: host.gm-ESPRIMO-Q556 Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1051:27)
            2024-08-28 12:37:02.920 - error: host.gm-ESPRIMO-Q556 Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1311:19)
            2024-08-28 12:37:02.920 - error: host.gm-ESPRIMO-Q556 Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
            2024-08-28 12:37:02.920 - error: host.gm-ESPRIMO-Q556 Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.echarts/main.js:12:21)
            2024-08-28 12:37:02.921 - error: host.gm-ESPRIMO-Q556 Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1469:14)
            2024-08-28 12:37:02.921 - error: host.gm-ESPRIMO-Q556 Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
            2024-08-28 12:37:02.921 - error: host.gm-ESPRIMO-Q556 Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1288:32)
            2024-08-28 12:37:02.921 - error: host.gm-ESPRIMO-Q556 Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1104:12)
            2024-08-28 12:37:02.921 - error: host.gm-ESPRIMO-Q556 Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:174:12) {
            2024-08-28 12:37:02.921 - error: host.gm-ESPRIMO-Q556 Caught by controller[0]: code: 'MODULE_NOT_FOUND',
            2024-08-28 12:37:02.921 - error: host.gm-ESPRIMO-Q556 Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.echarts/main.js' ]
            2024-08-28 12:37:02.921 - error: host.gm-ESPRIMO-Q556 Caught by controller[0]: }
            2024-08-28 12:37:02.921 - error: host.gm-ESPRIMO-Q556 Caught by controller[1]: Node.js v20.17.0
            2024-08-28 12:37:02.921 - error: host.gm-ESPRIMO-Q556 instance system.adapter.echarts.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
            2024-08-28 12:37:02.921 - info: host.gm-ESPRIMO-Q556 Adapter system.adapter.echarts.0 needs rebuild and will be restarted afterwards.
            2024-08-28 12:37:02.921 - info: host.gm-ESPRIMO-Q556 system.adapter.echarts.0 will be rebuilt
            2024-08-28 12:37:02.921 - warn: host.gm-ESPRIMO-Q556 adapter "echarts" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
            Interessanterweise werden alle meine Charts weiterhin geschrieben und aktualisiert...
            Wenn ich jetzt auf eine andere Version gehe (Beta, wie geht das?) und meine Presets weg sind und damit auch meine Charts - wäre es dann nicht einfacher zu warten, bis eine neue "stable" Version von echarts erscheint, bei dem der Fehler dann nicht mehr da ist?
            • haus-automatisierung
              haus-automatisierung Developer Most Active @JoJo58 last edited by
              Presets sind ja auch nur Objekte im System vom Typ chart. Expertenmodus einschalten und schauen, ob die Objekte wirklich nicht mehr da sind.
                Maddm @haus-automatisierung last edited by
                Danke fürs schnelle Feedback.
                Mir ist gerade aufgefallen: im Forum gibts Beiträge über echarts 1.84 und echarts 1.90 --> habe "nur" die 1.72 und mir wird auch keine aktuellere Version angeboten, woher kommt die Diskrepanz?
                Thomas Braun haus-automatisierung 2 Replies Last reply Reply Quote 0
                  Thomas Braun Most Active @Maddm last edited by
                  @maddm
                  echarts
                  github:	1.9.0
                  latest:	1.9.0 for 22 days
                  stable:	1.7.2 for 9 months
                  Alles > 1.7.2 ist also eine Beta-Version.
                    haus-automatisierung Developer Most Active @Maddm last edited by
                    @maddm Grundlagen zu Repositories anschauen (beta vs. stable). Und wie man ggf die neuesten Versionen von npm installieren kann.
                    metaxa 1 Reply Last reply Reply Quote 0
                    • metaxa
                      metaxa @haus-automatisierung last edited by
                      Bei mir hat die npm installation auf 1.9.0 den Erfolg gebracht! Adapter ist wieder grün, charts laden nach wie vor aktuell.
