    4. Pflege des Betriebssystems
    5. Einige Betriebssystempakete können aktualisiert werden.
      Rushmed Most Active last edited by
      ich bekomme aktuell Meldungen dass Betriebssystempakete aktualisiert werden können.
      raspberrypi-sys-mods/stable 20240807 arm64 [upgradable from: 20240624]
      wpasupplicant/stable-security 2:2.10-12+deb12u2 arm64 [upgradable from: 2:2.10-12+deb12u1]
      Meine Update Ausgabe sieht so aus:
      pi@Smartazamba:~ $ sudo apt update && iob stop && sudo apt full-upgrade --yes && sudo reboot
      Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:3 http://security.debian.org/debian-security bookworm-security InRelease
      Ign:4 https://deb.nodesource.com/node_20.x nodistro InRelease
      Hit:5 http://archive.raspberrypi.org/debian bookworm InRelease
      Hit:6 https://repos.influxdata.com/debian stable InRelease
      Hit:7 https://apt.grafana.com stable InRelease
      Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists... Done
      Building dependency tree... Done
      All packages are up to date.
      N: Repository 'Debian bookworm' changed its 'non-free component' value from 'non-free' to 'non-free non-free-firmware'
      N: More information about this can be found online in the Release notes at: https://www.debian.org/releases/bookworm/arm64/release-notes/ch-information.html#non-free-split
      Calculating upgrade... Done
      The following packages were automatically installed and are no longer required:
        libcamera0.2 linux-headers-6.1.0-rpi8-common-rpi linux-headers-6.6.20+rpt-common-rpi linux-kbuild-6.1
        linux-kbuild-6.6.20+rpt
      Use 'sudo apt autoremove' to remove them.
      0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
      Broadcast message from root@Smartazamba on pts/1 (Fri 2024-08-09 18:03:55 CEST):
      The system will reboot now!
      Wie kann ich die Meldung im ioBroker loswerden. Generell würde ich im iobroker lieber nur Meldungen bekommen die den ioBroker direkt betreffen. Kann ich das iregndwo einstellen?
      sigi234 da_Woody 2 Replies Last reply Reply Quote 0
      • sigi234
        sigi234 Forum Testing Most Active @Rushmed last edited by
        @rushmed
        https://forum.iobroker.net/topic/75693/betriebssystem-paket-updates-linux-ist-auf-neustem-stand?_=1723219892317
        • da_Woody
          da_Woody @Rushmed last edited by
          @rushmed steht doch in der Ausgabe.
          sudo apt remove
          Würde integriert damit man aufmerksam gemacht wird, daß dein System versauert.
            Rushmed Most Active @da_Woody last edited by
            @da_woody sagte in Einige Betriebssystempakete können aktualisiert werden.:
            sudo apt remove
            In der Ausgabe steht dass alles aktuell ist.
            MartinP Homoran da_Woody 3 Replies Last reply Reply Quote 0
            • MartinP
              MartinP @Rushmed last edited by
              @rushmed und trotz des Reboot gibt es weiterhin diese Meldung im Iobroker?
                Homoran Global Moderator Administrators @Rushmed last edited by
                @rushmed sagte in Einige Betriebssystempakete können aktualisiert werden.:
                jetzt?
                nachdem du
                gemacht hattest?
                @martinp sagte in Einige Betriebssystempakete können aktualisiert werden.:
                Auch nach löschen des Browsercache?
                Wenn ja, bitte die Langfassung von iob diag
                • da_Woody
                  @rushmed alles lesen hilft...
                    Rushmed Most Active @MartinP last edited by
                    @martinp Ja, kommt jedes mal wieder wenn ich im Chrome strg+F5 drücke.
                    • mcm1957
                      mcm1957 @Rushmed last edited by mcm1957
                      @rushmed
                      Versuch mal "nach Updates suchen" im Adapter Tab anzuklicken.
                      Ist aber eher ein Schuss ins Blaue. Schaden kanns allerdings nicht.
                      "Bestätigen" od "Bestätigen und Schließen" hast du ja wahrscheinlich schon angeklickt. (Sorry wenn die Frage blöd rüber kommt - aber es gibt hier manchmal auch Dinge die es nicht gibt 🙂 )
                        Rushmed Most Active @Homoran last edited by
                        @homoran sagte in Einige Betriebssystempakete können aktualisiert werden.:
                        sudo apt autoremove
                        Mit anschließendem reboot hat nich geholfen.
                        Skript v.2024-05-22
                        *** BASE SYSTEM ***
                         Static hostname: Smartazamba
                               Icon name: computer
                                  Kernel: Linux 6.6.31+rpt-rpi-v8
                            Architecture: arm64
                        Model           : Raspberry Pi 4 Model B Rev 1.4
                        Docker          : false
                        Virtualization  : none
                        Kernel          : aarch64
                        Userland        : 64 bit
                        Systemuptime and Load:
                         19:24:41 up 16 min,  2 users,  load average: 2.60, 3.87, 2.94
                        CPU threads: 4
                        *** RASPBERRY THROTTLING ***
                        Current issues:
                        Previously detected issues:
                        *** Time and Time Zones ***
                                       Local time: Fri 2024-08-09 19:24:41 CEST
                                   Universal time: Fri 2024-08-09 17:24:41 UTC
                                         RTC time: n/a
                                      NTP service: active
                                  RTC in local TZ: no
                        *** Users and Groups ***
                        User that called 'iob diag':
                        pi
                        HOME=/home/pi
                        GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                        iobroker
                        HOME=/home/iobroker
                        *** Display-Server-Setup ***
                        Display-Server: false
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Mem:            8.2G        2.9G        2.8G        3.0M        2.5G        5.3G
                        Swap:             0B          0B          0B
                        Total:          8.2G        2.9G        2.8G
                        Active iob-Instances:   36
                                 7809 M total memory
                                 2800 M used memory
                                 3529 M active memory
                                 1286 M inactive memory
                                 2712 M free memory
                                  373 M buffer memory
                                 2055 M swap cache
                                    0 M total swap
                                    0 M used swap
                                    0 M free swap
                        top - 19:24:41 up 16 min,  2 users,  load average: 2.60, 3.87, 2.94
                        Tasks: 220 total,   2 running, 218 sleeping,   0 stopped,   0 zombie
                        %Cpu(s): 66.7 us, 33.3 sy,  0.0 ni,  0.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                        MiB Mem :   7809.0 total,   2701.2 free,   2811.7 used,   2429.1 buff/cache
                        MiB Swap:      0.0 total,      0.0 free,      0.0 used.   4997.3 avail Mem
                        *** FAILED SERVICES ***
                        0 loaded units listed.
                        *** FILESYSTEM ***
                        /dev/root      ext4      110G   24G   83G  23% /
                        devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
                        tmpfs          tmpfs     1.6G  2.9M  1.6G   1% /run
                        /dev/sda1      vfat      253M   44M  209M  18% /boot/firmware
                        /dev/sdc       ext4      5.5T  3.5T  1.8T  67% /media/HDD2
                        /dev/sdb1      ext4      4.6T  3.5T  875G  81% /media/HDD1
                        tmpfs          tmpfs     781M     0  781M   0% /run/user/1000
                        [Fri Aug  9 19:08:33 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:E2:C4:A5 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyAMA0,115200 console=tty1 root=PARTUUID=5bc7cbe7-02 rootfstype=ext4 fsck.repair=yes rootwait
                        [Fri Aug  9 19:08:36 2024] EXT4-fs (sda2): mounted filesystem 1943b829-a99b-45b8-9fe5-7136dbea4c4a ro with ordered data mode. Quota mode: none.
                        [Fri Aug  9 19:08:36 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                        [Fri Aug  9 19:08:52 2024] EXT4-fs (sda2): re-mounted 1943b829-a99b-45b8-9fe5-7136dbea4c4a r/w. Quota mode: none.
                        [Fri Aug  9 19:08:55 2024] EXT4-fs (sdc): mounted filesystem b85c7b90-8154-43e5-bcae-a07f1c446bec r/w with ordered data mode. Quota mode: none.
                        [Fri Aug  9 19:08:56 2024] EXT4-fs (sdb1): mounted filesystem f79cb025-aab2-4bd5-bd49-84de9b0f60b4 r/w with ordered data mode. Quota mode: none.
                        Show mounted filesystems:
                        TARGET                                                  SOURCE      FSTYPE      OPTIONS
                        /                                                       /dev/sda2   ext4        rw,noatime
                        |-/dev                                                  devtmpfs    devtmpfs    rw,relatime,size=3733652k,nr_inodes=933413,mode=755
                        | |-/dev/shm                                            tmpfs       tmpfs       rw,nosuid,nodev
                        | |-/dev/pts                                            devpts      devpts      rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
                        | `-/dev/mqueue                                         mqueue      mqueue      rw,nosuid,nodev,noexec,relatime
                        |-/proc                                                 proc        proc        rw,relatime
                        | `-/proc/sys/fs/binfmt_misc                            systemd-1   autofs      rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=3405
                        |   `-/proc/sys/fs/binfmt_misc                          binfmt_misc binfmt_misc rw,nosuid,nodev,noexec,relatime
                        |-/sys                                                  sysfs       sysfs       rw,nosuid,nodev,noexec,relatime
                        | |-/sys/kernel/security                                securityfs  securityfs  rw,nosuid,nodev,noexec,relatime
                        | |-/sys/fs/cgroup                                      cgroup2     cgroup2     rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
                        | |-/sys/fs/pstore                                      pstore      pstore      rw,nosuid,nodev,noexec,relatime
                        | |-/sys/fs/bpf                                         bpf         bpf         rw,nosuid,nodev,noexec,relatime,mode=700
                        | |-/sys/kernel/debug                                   debugfs     debugfs     rw,nosuid,nodev,noexec,relatime
                        | |-/sys/kernel/tracing                                 tracefs     tracefs     rw,nosuid,nodev,noexec,relatime
                        | |-/sys/fs/fuse/connections                            fusectl     fusectl     rw,nosuid,nodev,noexec,relatime
                        | `-/sys/kernel/config                                  configfs    configfs    rw,nosuid,nodev,noexec,relatime
                        |-/run                                                  tmpfs       tmpfs       rw,nosuid,nodev,size=1599292k,nr_inodes=819200,mode=755
                        | |-/run/lock                                           tmpfs       tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k
                        | |-/run/credentials/systemd-sysctl.service             ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                        | |-/run/credentials/systemd-sysusers.service           ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                        | |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                        | |-/run/rpc_pipefs                                     sunrpc      rpc_pipefs  rw,relatime
                        | |-/run/credentials/systemd-tmpfiles-setup.service     ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                        | `-/run/user/1000                                      tmpfs       tmpfs       rw,nosuid,nodev,relatime,size=799644k,nr_inodes=199911,mode=700,uid=1000,gid=1000
                        |-/boot/firmware                                        /dev/sda1   vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
                        |-/media/HDD2                                           /dev/sdc    ext4        rw,nosuid,nodev,noexec,relatime
                        `-/media/HDD1                                           /dev/sdb1   ext4        rw,nosuid,nodev,noexec,relatime
                        /var:
                        6.6G    /var/
                        3.4G    /var/log
                        2.7G    /var/log/journal/3dd7c02f298247188f8650087c821e8c
                        616M    /var/cache
                        Archived and active journals take up 2.6G in the file system.
                        /opt/iobroker/backups:
                        2.6G    /opt/iobroker/backups/
                        /opt/iobroker/iobroker-data:
                        987M    /opt/iobroker/iobroker-data/
                        650M    /opt/iobroker/iobroker-data/files
                        441M    /opt/iobroker/iobroker-data/files/javascript.admin
                        409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                        408M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                        60M     /opt/iobroker/iobroker-data/states.jsonl
                        38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
                        36M     /opt/iobroker/iobroker-data/objects.jsonl
                        27M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.ce422ec2.js.map
                        24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                        USB-Devices by-id:
                        /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_b875aef9f419ec118e7074e5f01c6278-if00-port0
                        /dev/serial/by-id/usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0052-if00-port0
                        /dev/serial/by-id/usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0063-if00-port0
                        Your zigbee.0 COM-Port is matching 'by-id'. Very good!
                        HINT:
                        Your zigbee.1 COM-Port is NOT matching 'by-id'. Please check your setting:
                        tcp
                        *** NodeJS-Installation ***
                        /usr/bin/nodejs         v20.16.0
                        /usr/bin/node           v20.16.0
                        /usr/bin/npm            10.8.1
                        /usr/bin/npx            10.8.1
                        /usr/bin/corepack       0.28.2
                        nodejs:
                          Installed: 20.16.0-1nodesource1
                          Candidate: 20.16.0-1nodesource1
                          Version table:
                         *** 20.16.0-1nodesource1 1001
                                500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                                100 /var/lib/dpkg/status
                             20.15.1-1nodesource1 1001
                             20.15.0-1nodesource1 1001
                             20.14.0-1nodesource1 1001
                             20.13.1-1nodesource1 1001
                             20.13.0-1nodesource1 1001
                             20.12.2-1nodesource1 1001
                             20.12.1-1nodesource1 1001
                             20.12.0-1nodesource1 1001
                             20.11.1-1nodesource1 1001
                             20.11.0-1nodesource1 1001
                             20.10.0-1nodesource1 1001
                             20.9.0-1nodesource1 1001
                             20.8.1-1nodesource1 1001
                             20.8.0-1nodesource1 1001
                             20.7.0-1nodesource1 1001
                             20.6.1-1nodesource1 1001
                             20.6.0-1nodesource1 1001
                             20.5.1-1nodesource1 1001
                             20.5.0-1nodesource1 1001
                             20.4.0-1nodesource1 1001
                             20.3.1-1nodesource1 1001
                             20.3.0-1nodesource1 1001
                             20.2.0-1nodesource1 1001
                             20.1.0-1nodesource1 1001
                             20.0.0-1nodesource1 1001
                             18.19.0+dfsg-6~deb12u2 500
                             18.19.0+dfsg-6~deb12u1 500
                                500 http://security.debian.org/debian-security bookworm-security/main arm64 Packages
                        No problems detected
                        Errors in npm tree:
                        *** ioBroker-Installation ***
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        Core adapters versions
                        js-controller:  6.0.9
                        admin:          7.0.22
                        javascript:     8.7.6
                        nodejs modules from github:     2
                        +-- iobroker.esphome@0.5.0-beta.10 (git+ssh://git@github.com/DrozmotiX/ioBroker.esphome.git#6b97f67d1d1ce6af3a0e598ba77eec8f570a0854)
                        | `-- kodi-ws@2.4.4 (git+https://git@github.com/iobroker-community-adapters/kodi-ws.git#ad5a1fdc5cd0a282e6818ff152594b5d32535103)
                        Adapter State
                        + system.adapter.admin.0                  : admin                 : Smartazamba                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                        + system.adapter.alexa2.0                 : alexa2                : Smartazamba                              -  enabled
                        + system.adapter.awtrix-light.0           : awtrix-light          : Smartazamba                              -  enabled
                        + system.adapter.awtrix-light.1           : awtrix-light          : Smartazamba                              -  enabled
                        + system.adapter.backitup.0               : backitup              : Smartazamba                              -  enabled
                          system.adapter.denon.0                  : denon                 : Smartazamba                              - disabled
                        + system.adapter.device-watcher.0         : device-watcher        : Smartazamba                              -  enabled
                        + system.adapter.deyeidc.0                : deyeidc               : Smartazamba                              -  enabled, port: 8899
                          system.adapter.esphome.0                : esphome               : Smartazamba                              - disabled
                          system.adapter.habpanel.0               : habpanel              : Smartazamba                              - disabled
                          system.adapter.hass.0                   : hass                  : Smartazamba                              - disabled, port: 8123
                        + system.adapter.hue.0                    : hue                   : Smartazamba                              -  enabled, port: 443
                          system.adapter.ical.0                   : ical                  : Smartazamba                              -  enabled
                        + system.adapter.influxdb.0               : influxdb              : Smartazamba                              -  enabled, port: 8086
                        + system.adapter.iot.0                    : iot                   : Smartazamba                              -  enabled
                        + system.adapter.javascript.0             : javascript            : Smartazamba                              -  enabled
                          system.adapter.kodi.0                   : kodi                  : Smartazamba                              - disabled, port: 9090
                        + system.adapter.logparser.0              : logparser             : Smartazamba                              -  enabled
                        + system.adapter.mihome-vacuum.0          : mihome-vacuum         : Smartazamba                              -  enabled, port: 54321
                        + system.adapter.mihome-vacuum.1          : mihome-vacuum         : Smartazamba                              -  enabled, port: 54321
                        + system.adapter.mqtt.0                   : mqtt                  : Smartazamba                              -  enabled, port: 1883, bind: 0.0.0.0
                        + system.adapter.philips-tv.0             : philips-tv            : Smartazamba                              -  enabled
                        + system.adapter.ping.0                   : ping                  : Smartazamba                              -  enabled
                        + system.adapter.pixelit.0                : pixelit               : Smartazamba                              -  enabled
                          system.adapter.pixelit.1                : pixelit               : Smartazamba                              - disabled
                          system.adapter.pixelit.2                : pixelit               : Smartazamba                              - disabled
                        + system.adapter.proxmox.0                : proxmox               : Smartazamba                              -  enabled, port: 8006
                        + system.adapter.shelly.0                 : shelly                : Smartazamba                              -  enabled, port: 1882, bind: 0.0.0.0
                        + system.adapter.shuttercontrol.0         : shuttercontrol        : Smartazamba                              -  enabled
                        + system.adapter.simple-api.0             : simple-api            : Smartazamba                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                        + system.adapter.smartmeter.0             : smartmeter            : Smartazamba                              -  enabled
                        + system.adapter.smartmeter.1             : smartmeter            : Smartazamba                              -  enabled
                        + system.adapter.sonoff.0                 : sonoff                : Smartazamba                              -  enabled, port: 1884, bind: 0.0.0.0
                        + system.adapter.sourceanalytix.0         : sourceanalytix        : Smartazamba                              -  enabled
                        + system.adapter.telegram.0               : telegram              : Smartazamba                              -  enabled, port: 8443, bind: 0.0.0.0
                        + system.adapter.telegram.1               : telegram              : Smartazamba                              -  enabled, port: 8443, bind: 0.0.0.0
                        + system.adapter.unifi.0                  : unifi                 : Smartazamba                              -  enabled
                          system.adapter.weatherunderground.0     : weatherunderground    : Smartazamba                              -  enabled
                        + system.adapter.web.0                    : web                   : Smartazamba                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                        + system.adapter.windows-control.0        : windows-control       : Smartazamba                              -  enabled
                          system.adapter.wiobrowser.0             : wiobrowser            : Smartazamba                              - disabled, port: 5000
                        + system.adapter.wled.0                   : wled                  : Smartazamba                              -  enabled
                        + system.adapter.ws.0                     : ws                    : Smartazamba                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                        + system.adapter.zigbee.0                 : zigbee                : Smartazamba                              -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_b875aef9f419ec118e7074e5f01c6278-if00-port0
                        + system.adapter.zigbee.1                 : zigbee                : Smartazamba                              -  enabled, port: tcp://192.168.178.42:6638
                        + instance is alive
                        ioBroker-Repositories
                        │ (index) │ name               │ url                                                     │ auto upgrade │
                        │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
                        │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
                        │ 2       │ 'latest live'      │ 'http://iobroker.live/repo/sources-dist-latest.json'    │ false        │
                        Upgrade policy: none
                        Installed ioBroker-Instances
                        Adapter    "admin"        : 7.0.22   , installed 7.0.22
                        Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                        Adapter    "awtrix-light" : 1.2.1    , installed 1.2.1
                        Adapter    "backitup"     : 3.0.16   , installed 3.0.16
                        Adapter    "denon"        : 1.15.12  , installed 1.15.12
                        Adapter    "device-watcher": 2.12.1  , installed 2.12.1
                        Adapter    "deyeidc"      : 0.0.16   , installed 0.0.16
                        Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
                        Adapter    "hass"         : 1.4.0    , installed 1.4.0
                        Adapter    "hue"          : 3.11.0   , installed 3.11.0
                        Adapter    "ical"         : 1.15.0   , installed 1.15.0
                        Adapter    "iot"          : 3.3.0    , installed 3.3.0
                        Adapter    "javascript"   : 8.7.6    , installed 8.7.6
                        Controller "js-controller": 6.0.9    , installed 6.0.9
                        Adapter    "kodi"         : 3.1.0    , installed 3.1.0
                        Adapter    "logparser"    : 2.2.2    , installed 2.2.2
                        Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
                        Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                        Adapter    "philips-tv"   : 0.5.3    , installed 0.5.3
                        Adapter    "pixelit"      : 1.1.3    , installed 1.1.3
                        Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
                        Adapter    "shelly"       : 7.0.0    , installed 7.0.0
                        Adapter    "shuttercontrol": 1.7.3   , installed 1.7.3
                        Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
                        Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                        Adapter    "sonoff"       : 3.1.0    , installed 3.1.0
                        Adapter    "telegram"     : 3.3.2    , installed 3.3.2
                        Adapter    "unifi"        : 0.7.0    , installed 0.7.0
                        Adapter    "weatherunderground": 3.7.0, installed 3.7.0
                        Adapter    "windows-control": 0.1.5  , installed 0.1.5
                        Adapter    "wiobrowser"   : 2.0.2    , installed 2.0.2
                        Adapter    "wled"         : 0.7.2    , installed 0.7.2
                        Adapter    "ws"           : 2.6.2    , installed 2.6.2
                        Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
                        Objects and States
                        Objects:        23225
                        States:         16314
                        Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
                        Hit:4 http://archive.raspberrypi.org/debian bookworm InRelease
                        Ign:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                        Hit:6 https://apt.grafana.com stable InRelease
                        Hit:7 https://repos.influxdata.com/debian stable InRelease
                        Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                        Pending Updates: 0
                        *** Listening Ports ***
                        tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          6850       822/smbd
                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          5761       643/sshd: /usr/sbin
                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1002       20643      4353/iobroker.js-co
                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1002       20648      4353/iobroker.js-co
                        tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          6851       822/smbd
                        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1002       25376      5248/io.shelly.0
                        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1002       22678      5217/io.mqtt.0
                        tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1002       21440      5602/io.sonoff.0
                        tcp6       0      0 :::445                  :::*                    LISTEN      0          6848       822/smbd
                        tcp6       0      0 :::21                   :::*                    LISTEN      0          1791       634/vsftpd
                        tcp6       0      0 :::22                   :::*                    LISTEN      0          5763       643/sshd: /usr/sbin
                        tcp6       0      0 :::139                  :::*                    LISTEN      0          6849       822/smbd
                        tcp6       0      0 :::3000                 :::*                    LISTEN      109        6901       952/grafana
                        tcp6       0      0 :::8081                 :::*                    LISTEN      1002       21773      4399/io.admin.0
                        tcp6       0      0 :::8082                 :::*                    LISTEN      1002       27718      6439/io.web.0
                        tcp6       0      0 :::8084                 :::*                    LISTEN      1002       26075      6757/io.ws.0
                        tcp6       0      0 :::8086                 :::*                    LISTEN      999        1966       742/influxd
                        tcp6       0      0 :::8087                 :::*                    LISTEN      1002       26660      6403/io.simple-api.
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1002       23492      6469/io.wled.0
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        3851       492/avahi-daemon: r
                        udp        0      0 0.0.0.0:56360           0.0.0.0:*                           108        3853       492/avahi-daemon: r
                        udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          4939       799/nmbd
                        udp        0      0 192.168.178.20:137      0.0.0.0:*                           0          4938       799/nmbd
                        udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          4926       799/nmbd
                        udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          4941       799/nmbd
                        udp        0      0 192.168.178.20:138      0.0.0.0:*                           0          4940       799/nmbd
                        udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          4927       799/nmbd
                        udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1002       25089      5648/io.mihome-vacu
                        udp        0      0 0.0.0.0:53422           0.0.0.0:*                           1002       23094      5668/io.mihome-vacu
                        udp6       0      0 :::58325                :::*                                108        3854       492/avahi-daemon: r
                        udp6       0      0 :::5353                 :::*                                108        3852       492/avahi-daemon: r
                        udp6       0      0 fe80::7572:1640:817:546 :::*                                0          1926       578/NetworkManager
                        2024-08-09 19:21:30.472  - info: mihome-vacuum.0 (5648) change states from State control.fan_power mihome-vacuum.0.rooms.275001039118.roomFanPower
                        2024-08-09 19:21:30.473  - info: mihome-vacuum.0 (5648) change states from State control.fan_power mihome-vacuum.0.rooms.275001043945.roomFanPower
                        2024-08-09 19:21:30.474  - info: mihome-vacuum.0 (5648) change states from State control.fan_power mihome-vacuum.0.rooms.275001043946.roomFanPower
                        2024-08-09 19:22:01.200  - info: alexa2.0 (4856) Unknown Device, but enabling commands, Try it and report back if commands work.
                        2024-08-09 19:22:01.208  - info: alexa2.0 (4856) Report to developer as GitHub issue with details for device. Please grab full next line pot. from logfile on disk if cutted
                        2024-08-09 19:22:01.209  - info: alexa2.0 (4856)     Device-type:A203FC0H3THJQH - Kateryna's Alexa app for WearOS watch (Alexa on Wear) (SPEECH_RECOGNIZER_USS,DIALOG_INTERFACE_VERSION,MICROPHONE,TIMERS_ALARMS_NOTIFICATIONS_VOLUME,SUPPORTS_LOCALE_SWITCH,PEONY,ADAPTIVE_LISTENING,SET_LOCALE,ASCENDING_ALARM_VOLUME,REMINDERS,SUPPORTS_LOCALE,SOUND_SETTINGS,VOLUME_SETTING,GEOLOCATION,SET_TIME_ZONE,CUSTOM_ALARM_TONE,TIMERS_AND_ALARMS,MULTI_WAKEWORDS_SUPPORTED,EARCONS)
                        2024-08-09 19:23:02.830  - error: javascript.0 (4799) script.js.Alexa: Cannot parse "": SyntaxError: Unexpected end of JSON input
                        2024-08-09 19:23:02.832  - error: javascript.0 (4799) script.js.Alexa: Cannot parse "": SyntaxError: Unexpected end of JSON input
                        2024-08-09 19:23:02.834  - error: javascript.0 (4799) script.js.Alexa: Cannot parse "": SyntaxError: Unexpected end of JSON input
                        2024-08-09 19:23:02.835  - error: javascript.0 (4799) script.js.Alexa: Cannot parse "": SyntaxError: Unexpected end of JSON input
                        2024-08-09 19:23:02.837  - error: javascript.0 (4799) script.js.Alexa: Cannot parse "": SyntaxError: Unexpected end of JSON input
                        2024-08-09 19:23:03.094  - error: javascript.0 (4799) script.js.Alexa: TypeError: Cannot read properties of null (reading 'indexOf')
                        2024-08-09 19:23:03.096  - error: javascript.0 (4799)     at Object.<anonymous> (script.js.Alexa:41:84)
                        2024-08-09 19:23:03.096  - error: javascript.0 (4799)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1452:38)
                        2024-08-09 19:23:03.097  - error: javascript.0 (4799)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
                        2024-08-09 19:23:03.097  - error: javascript.0 (4799)     at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11053:62)
                        2024-08-09 19:23:03.098  - error: javascript.0 (4799)     at processImmediate (node:internal/timers:483:21)
                        2024-08-09 19:23:06.092  - info: alexa2.0 (4856) Subscribing to states...
                        2024-08-09 19:23:08.440  - info: alexa2.0 (4856) Alexa-Push-Connection (macDms = true) established. Disable Polling
                        2024-08-09 19:23:40.106  - info: alexa2.0 (4856) Initialization Done ...
                        2024-08-09 19:25:21.649  - info: host.Smartazamba instance system.adapter.weatherunderground.0 in version "3.7.0" started with pid 14168
                        2024-08-09 19:25:32.942  - info: weatherunderground.0 (14168) starting. Version 3.7.0 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v20.16.0, js-controller: 6.0.9
                        2024-08-09 19:25:46.938  - info: weatherunderground.0 (14168) Terminated (NO_ERROR): Without reason
                        2024-08-09 19:25:47.454  - warn: weatherunderground.0 (14168) get state error: Connection is closed.
                        2024-08-09 19:25:47.542  - info: host.Smartazamba instance system.adapter.weatherunderground.0 having pid 14168 terminated with code 0 (NO_ERROR)
                          Homoran Global Moderator Administrators @Rushmed last edited by Homoran
                          Pending Updates: 0
                          da ist nichts mehr offen.
                          Warum der admin darauf besteht ist mir ein Rätsel
                          Auch sonst sehe ich nichts besorgniserregendes, lediglich ein kleiner Hinweis
                          tcp
                          dürfte aber ein LAN Interface sein, oder?
                            Ja genau. Danke für die Prüfung.
                              Thomas Braun Most Active @Rushmed last edited by
                              @rushmed
                              Und wenn du die Meldung einfach nur 'Bestätigst'?
                              Die dürfte aktuell dann nicht mehr aufpoppen.
                              OT: Ich freu mich, das der Code für zigbee-Sticks auch in komplexeren Setups funktioniert.
                              Das konnte ich nämlich nicht so gut testen.
                              MartinP R 2 Replies Last reply Reply Quote 0
                              • MartinP
                                MartinP @Thomas Braun last edited by
                                @thomas-braun fehlt da ggfs eine apt paketquelle?
                                  Thomas Braun Most Active @MartinP last edited by
                                  @martinp
                                  Ich denke, da lügt einfach mal wieder die GUI.
                                  Die Meldungen zu Updates werden nicht in 'Echtzeit' abgeglichen. Ich glaube, die setzen sich nicht mal von alleine zurück. Da muss man aktiv 'Bestätigen und schließen' klick0rn.
                                    Rushmed Most Active @Thomas Braun last edited by
                                    @thomas-braun sagte in Einige Betriebssystempakete können aktualisiert werden.:
                                    Das hat geklappt.
                                    • mcm1957
                                      Ja
                                      Notifications (nicht nur bezüglich Updates) müssen bestätigt werden und verschwinden nicht von selbst.
                                        Kurze Frage noch. Wäre mein Updatebefehl so okay oder mache ich mir da etwas kaputt?
                                        sudo apt update && iob stop && sudo apt full-upgrade --yes && sudo apt autoremove -y && sudo reboot
                                          @rushmed
                                          Technisch funktionert das.
                                          Würde ich aber niemals so machen lassen. Da gibst du viel zu sehr die Zügel aus der Hand.
                                          Gerade beim autoremove besser 2x hinschauen, was da entfernt werden soll. Manchmal haut es dir nämlich auch wesentliche Pakete raus.
                                            Linedancer @Thomas Braun last edited by
                                            Und wie erkenne ich als Nichtfachmann welche Pakete wesentlich sind?
                                            iobroker meldung update
                                            11
                                            35
                                            3358
