    4. Microcontroller
    5. Tasmota -> Unterschied firmware
    • Kusselin
      Kusselin last edited by Kusselin
      Hallo Zusammen,
      ich habe eine Frage zu Tasmota und deren Firmware...
      Was ist der Unterschied von der tasmota- release-sensors zu der tasmota release-tasmota firmware?
      Über ne Info herzlichen Dank
      Und es wäre nett wenn mir jemand noch mitteilen kann was das für meldungen sind nach Update und wie ich die wegbekomme???
      sonoff.0
      	2024-08-13 20:39:25.200	warn	Client [LED-Gartenzaun-Nordseite] received pubcomp for unknown message ID: 29807
      sonoff.0
      	2024-08-13 20:39:25.200	warn	Client [LED-Gartenzaun-Nordseite] received puback for unknown message ID: 8748
      sonoff.0
      	2024-08-13 20:39:25.200	warn	Client [LED-Gartenzaun-Nordseite] received pubrec on LED-Gartenzaun-Nordseite for unknown message ID: 28777
      sonoff.0
      	2024-08-13 20:39:17.613	warn	Client [LED-Gartenzaun-Nordseite] received puback for unknown message ID: 8762
      sonoff.0
      	2024-08-13 20:39:17.613	warn	Client [LED-Gartenzaun-Nordseite] received pubcomp for unknown message ID: 26989
      sonoff.0
      	2024-08-13 20:39:17.613	warn	Client [LED-Gartenzaun-Nordseite] received pubcomp for unknown message ID: 29285
      sonoff.0
      	2024-08-13 20:39:17.613	warn	Client [LED-Gartenzaun-Nordseite] received pubrel on LED-Gartenzaun-Nordseite for unknown messageId 24940
      sonoff.0
      sonoff.0
      	2024-08-13 20:39:17.298	warn	Client [Brunnenpumpe] received pubrel on Brunnenpumpe for unknown messageId 30311
      sonoff.0
      	2024-08-13 20:39:03.272	info	Client [Gefrierschrank-KE] connected with secret 1723574341737_1668
      sonoff.0
      	2024-08-13 20:39:00.208	info	Client [Gefrierschrank-KE] connection closed: Error: Cannot parse topic
      sonoff.0
      	2024-08-13 20:39:00.207	warn	Client [Gefrierschrank-KE] received pubcomp for unknown message ID: 28757
      sonoff.0
      	2024-08-13 20:39:00.207	warn	Client [Gefrierschrank-KE] received pubcomp for unknown message ID: 29797
      sonoff.0
      	2024-08-13 20:39:00.207	warn	Client [Gefrierschrank-KE] received pubrel on Gefrierschrank-KE for unknown messageId 14896
      gelesen hier
      https://forum.iobroker.net/topic/58330/seltsame-warnung-beim-sonof-adapter/2
      heisst, wenn du @crunchip den tasmoAdmin wieder schliesst, kommen die Meldungen nicht mehr oder was?
      EDIT: Stimmt, sobald man den TasmoAdmin schliesst sind die Meldungen weg...
      Aber die Frage zu der Firmware hätte ich geren noch..ich mache eigentlich immer das Update über tasmoAdmin udn der ist voreingestellt auf sensor-tasmota... ich möchte aber geren den Unterschied wissen. danke
      ...weil wenn ich die release-r´tasmota aufspielen will manuell bringt mir das Update "zu wenig Speicher" ???
      • MartinP
        MartinP @Kusselin last edited by
        @kusselin mein Wissensstand ist, dass inzwischen je nach Chip eine Tasmota Firmware mit allen Features nicht mehr in das ROM passt.
        Also muss man sich einen Mix zusammenstellen, der passt.
          die sensors ist halt mehr für sensoren gedacht.. also keine Steckdosen oder Lichter..
          eher für Regensensoren oder Bodenfeuchte
          früher haben die alles in eine Datei gepackt .. aber inzwischen sind es so viele eventualitäten dass die das trennen
          also eigentlich machst du es falsch rum.. nimm eher die normale und speziel für einen sensor die sensors
            dirkhe Developer last edited by
            Also ich compiliere mittlerweile alle immer selber. Das hat auch den großen Vorteil, dass man Zugangsdaten für mqtt und wlan fest mit eincompilieren kann. Wenn man dann mal auf werksreset klickt, weil gar nichts mehr geht (hatte ich zum Glück schon lange nicht menr), ist er direkt sofort wieder ansprechbar über wlan.
            Man kann sich da wunderbar auch eigene profile bauen und dann in der config abfragen, was mit rein soll oder nicht.
              A Former User @dirkhe last edited by
              @dirkhe
              So kenne ich das auch aus Tasmota V4.x/V5.x Zeiten... da gabs noch keinen Webflasher oder wie jetzt ein Dockerimage (Tasmocompiler) mit dem man alles zusammenklicken kann..
              @Kusselin
              TasmoAdmin ist da sehr praktisch, pass aber auf, was du worauf flashst, manche Devices brauchen die Sensors unbedingt, andere dagegen eher die normale.
              Den Unterschied kann man auf der sehr gut dokumentierten Tasmota Seite https://tasmota.github.io/docs/Firmware-Builds/ nachlesen.
              • Kusselin
                Hallo , danke Jungs für die ausführliche Info.
                Ich mach das Update immer über TasmoAdmin und bin jetzt bei 14.1.0.
                Ich habe meistens die NOUS Stecker aber TasmoAdmin hat da bis auf einen die sensors immer draufgesflasht..wenn ich da jetzt auf einer NOUS auf release firmware wechsle und flashen will, kommt die Nachricht „ Speicher voll“ 😞
                Also da ich Stecker habe wäre hier ja die release Soft und nicht die sensors angedacht, was ja aber nicht geht wg Speicher…aber sie schalten ja und machen was sie sollen..
                Ist mir halt gestern aufgefallen…
                  arteck Developer Most Active @Kusselin last edited by arteck
                  @kusselin ja deshalb erst die minimale drauf dann erst die normale.
                  und die gepackte (gz) verwenden
                  bahnuhr Kusselin 2 Replies Last reply Reply Quote 0
                  • bahnuhr
                    bahnuhr Forum Testing Most Active @arteck last edited by
                    @arteck sagte in Tasmota -> Unterschied firmware:
                    klappt aber auch nicht immer.
                    Meine selbst kompilierten sind dann immer noch zu groß.
                    • Kusselin
                      Kusselin @arteck last edited by
                      Hi, was ist die minimale und was die normale? Wie sind die gekennzeichnet?
                      bahnuhr Ralla66 2 Replies Last reply Reply Quote 0
                      • bahnuhr
                        bahnuhr Forum Testing Most Active @Kusselin last edited by
                        @kusselin
                        @ilovegym sagte in Tasmota -> Unterschied firmware:
                        Dies hast du aber nicht gelesen !
                        oder doch ?
                        Da steht sogar minimal dabei.
                        Kusselin 1 Reply Last reply Reply Quote 1
                        • Ralla66
                          Ralla66 Most Active @Kusselin last edited by
                          @kusselin
                          Tante Google nach Tasmota Release fragen hilft immer
                          Link
                          • Kusselin
                            Kusselin @bahnuhr last edited by Kusselin
                            @bahnuhr sagte in Tasmota -> Unterschied firmware:
                            @kusselin
                            oder doch ?
                            Die habe ich gestern probiert draufzuflashen..die DE Version non englisch..wo steht da das das die kleine Firm ist oder die grosse..vor lauter Wald ist der Baum net zu sehen mal wieder😩
                            EDIT: ok es gibt die Tasmota. Lite und minimal..
                            Aber was ist dann besser für meine Stecker von NoUS?
                            Eigentlich würde ich für die Infos von Stromverbrauch diese benötigen oder?
                            tasmota-display.bin built for connecting displays but omits some features such as energy monitoring. If you need additional features, compile your own firmware (e.g.,
                            crunchip bahnuhr 2 Replies Last reply Reply Quote 0
                            • crunchip
                              crunchip Forum Testing Most Active @Kusselin last edited by
                              @kusselin sagte in Tasmota -> Unterschied firmware:
                              tasmota-display.bin
                              hat deine Steckdose ein Display?
                              einfach die minimal und dann die normale version drauf, sollte ohne Probleme funktionieren
                              • bahnuhr
                                @kusselin
                                kompilier deine Anforderungen doch selber.
                                Ich benutze dazu vsc
                                https://tasmota.github.io/docs/Visual-Studio-Code/
                                • Kusselin
                                  Kusselin @crunchip last edited by
                                  @crunchip sagte in Tasmota -> Unterschied firmware:
                                  tasmota-display.bin
                                  Ahh ok.. erst minimal..in englisch dann die normale…
                                  Nee natürlich nicht..mit Display meinte ich die angaben im WebIf🙈
                                  • Ralla66
                                    Ralla66 Most Active @Kusselin last edited by Ralla66
                                    @kusselin
                                    wenn die Normale dann geflasht ist und du ein bestimmtes Gerät benutzen möchtest muß du das Template anpassen.
                                    Template ist sowas wie Einstellungen für ein bestimmtes Gerät.
                                    Findest die Geräte hier :
                                    Link
                                    HowTo:
                                    so gehts
                                    • Kusselin
                                      Kusselin @Ralla66 last edited by
                                      @ralla66 sagte in Tasmota -> Unterschied firmware:
                                      @kusselin
                                      Link
                                      HowTo:
                                      so gehts
                                      Danke Dir..hab ja schon ein Template drauf..denke aber nicht das das mit dem Update auf minimal und dann normal gelöscht wird, oder?
                                        Dieter_P @Kusselin last edited by Dieter_P
                                        @kusselin said in Tasmota -> Unterschied firmware:
                                        @kusselin
                                        Link
                                        HowTo:
                                        so gehts
                                        Man weiß nie. Daher besser den Button nutzen-> Konfiguration sichern und dann hast Du etwas um sie mit 2 Klicks wieder aufspielen zu können.
                                        • Kusselin
                                          Updates haben super funktioniert. Danke nochmals.....für die Infos
                                          81.0k
                                          1698
