    4. Node.js downgrade von 19.9.0 auf 18.x
      Manuel001 last edited by Manuel001
      Scheinbar habe ich mal unabsichtlich node.js 19.9 installiert.
      Das hat immer problemlos funktioniert.
      Aber gestern habe js-controller und ein paar Adapter aktualisiert.
      Seitdem erhalte ich folgende Meldungen:
      2024-08-16 21:24:43.494  - error: host.ioBrokerHeimspeicher Caught by controller[0]: /opt/iobroker/node_modules/iobroker.rpi2/main.js:19
      2024-08-16 21:24:43.497  - error: host.ioBrokerHeimspeicher Caught by controller[0]: const adapter = new utils.Adapter({
      2024-08-16 21:24:43.498  - error: host.ioBrokerHeimspeicher Caught by controller[0]:                 ^
      2024-08-16 21:24:43.499  - error: host.ioBrokerHeimspeicher Caught by controller[0]: TypeError: utils.Adapter is not a constructor
      2024-08-16 21:24:43.500  - error: host.ioBrokerHeimspeicher Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.rpi2/main.js:19:17)
      2024-08-16 21:24:43.501  - error: host.ioBrokerHeimspeicher Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1275:14)
      2024-08-16 21:24:43.502  - error: host.ioBrokerHeimspeicher Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1329:10)
      2024-08-16 21:24:43.503  - error: host.ioBrokerHeimspeicher Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1133:32)
      2024-08-16 21:24:43.504  - error: host.ioBrokerHeimspeicher Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:972:12)
      2024-08-16 21:24:43.505  - error: host.ioBrokerHeimspeicher Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:83:12)
      2024-08-16 21:24:43.506  - error: host.ioBrokerHeimspeicher Caught by controller[0]:     at node:internal/main/run_main_module:23:47
      2024-08-16 21:24:43.507  - error: host.ioBrokerHeimspeicher Caught by controller[0]: Node.js v19.9.0
      2024-08-16 21:24:43.508  - error: host.ioBrokerHeimspeicher instance system.adapter.rpi2.1 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2024-08-16 21:24:43.509  - info: host.ioBrokerHeimspeicher Restart adapter system.adapter.rpi2.1 because enabled
      Diese Meldungen wiederholen sich alle ca. 40 Sekunden.
      Da node.js 18.x empfohlen wird (wusste nicht, dass nur die geraden Zahlen stabile Versionen sind), weiß ich jetzt nicht ob es an der node.js 19.9 liegt oder ein anderes Problem besteht.
      Homoran mcm1957 2 Replies Last reply Reply Quote 0
        Homoran Global Moderator Administrators @Manuel001 last edited by
        @manuel001 sagte in Node.js downgrade von 19.9.0 auf 18.x:
        nein! node 20 ist im Moment empfohlen.
        was sagt denn die Langfassung von iob diag ?
          Manuel001 @Homoran last edited by
          @homoran sagte in Node.js downgrade von 19.9.0 auf 18.x:
          Ah OK, weil im Admin Infotab wird das angezeigt:
          v19.9.0 (Die Version v19.x von Node.js wird derzeit nicht vollständig unterstützt. - Empfohlene Version v18.20.4)
          Was ich vielleicht auch noch dazusagen muss, dass es sich hierbei um einen ioBroker Slave handelt.
          bahnuhr Homoran mcm1957 Thomas Braun 4 Replies Last reply Reply Quote 0
          • mcm1957
            mcm1957 @Manuel001 last edited by
            @manuel001 said in Node.js downgrade von 19.9.0 auf 18.x:
            Erstens:
            Bitte bei ALLEN Fehlermeldungen immer die im Einsatz befindlichen Versionen angeben
            Zweitens:
            Das Fehlerbild deutet ziemlich stark auf einen veralteten rpi2 Adapter hin. Installier mal die aktuelle Beta Version von LATEST (2.0.0 glaub ich)
            Wenn es nur um den rpi2 geht klink dich bitte in den rpi2 Test Thread ein. Der Adapter ist derzeit im Test / Umbau das sich am Unterbau (O/S, externe Libraries) einiges inkompatibel geändert hat. Schau auch in die existierenden Issues des Adapters.
            https://forum.iobroker.net/topic/75290/test-adapter-rpi2-2-x
            • bahnuhr
              bahnuhr Forum Testing Most Active @Manuel001 last edited by
              Kann eigentlich nicht sein.
              Empfohlen wird 20
                @manuel001 dann zeig bitte die Langfassung von iob diag
                da ist irgendwas nicht richtig
                • mcm1957
                  Due redest aber nicht von der Anzeige des INFO Adapters ?
                  Dieser ist deprecated und zeigt tw. auch falsche Informationen an.
                  https://forum.iobroker.net/topic/72367/deprecated-abkündigung-adapter-iobroker-info
                    Thomas Braun Most Active @Manuel001 last edited by
                    Die Meldung kommt bei einer obsoleten Version des Admin daher. Da scheint also noch mehr pflegebedürftig zu sein.
                      Manuel001 @mcm1957 last edited by
                      @mcm1957 sagte in Node.js downgrade von 19.9.0 auf 18.x:
                      Ich fürchte doch. Habe ihn gleich deinstalliert.
                      Thomas Braun mcm1957 2 Replies Last reply Reply Quote 0
                        @manuel001
                        Zeig mal die Ausgabe von
                        iob diag
                        auf beiden Kisten.
                        • mcm1957
                          @manuel001
                          Bist nicht der erste der da reinfällt.
                          Nur zentrales Deinstallieren ist derzeit nicht möglich (und auch nicht geplant der auch nur angedacht)
                                                    v.2024-05-22
                               Static hostname: ioBrokerHeimspeicher
                                     Icon name: computer
                              Operating System: Raspbian GNU/Linux 10 (buster)
                                        Kernel: Linux 5.10.103-v7+
                                  Architecture: arm
                            Kernel:                 armv7l
                            Userland:               32 bit
                            User-ID:                1000
                            Display-Server:         false
                            Pending OS-Updates:     61
                            Pending iob updates:    6
                            Nodejs-Installation:
                            /usr/bin/nodejs         v19.9.0
                            /usr/bin/node           v19.9.0
                            /usr/bin/npm            9.6.3
                            /usr/bin/npx            9.6.3
                            /usr/bin/corepack       0.17.1
                            MEMORY:
                            Mem:           923M        330M        148M        6.0M        444M        509M
                            Swap:           99M         40M         59M
                            Total:         1.0G        371M        207M
                            Active iob-Instances:   21
                            Upgrade policy: none
                            ioBroker Core:          js-controller           6.0.9
                            At least one iobroker host is running.
                            Objects type: jsonl
                            States  type: jsonl
                            + system.adapter.admin.0                  : admin                 : odroidc4                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                            + system.adapter.web.0                    : web                   : odroidc4                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                            Objects:                3850
                            States:                 2945
                            Size of iob-Database:
                            256K    /opt/iobroker/iobroker-data/objects.jsonl
                            248K    /opt/iobroker/iobroker-data/objects.json.migrated
                            248K    /opt/iobroker/iobroker-data/objects.json.bak.migrated
                            244K    /opt/iobroker/iobroker-data/states.jsonl
                            236K    /opt/iobroker/iobroker-data/states.json.migrated
                            236K    /opt/iobroker/iobroker-data/states.json.bak.migrated
                            Skript v.2024-05-22
                            *** BASE SYSTEM ***
                                     Icon name: computer
                                  Architecture: arm
                            Model           : Raspberry Pi 2 Model B Rev 1.1
                            Docker          : false
                            Virtualization  : none
                            Kernel          : armv7l
                            Userland        : 32 bit
                            Systemuptime and Load:
                             21:44:05 up 22 days,  2:30,  1 user,  load average: 1.00, 1.39, 1.09
                            CPU threads: 4
                            *** RASPBERRY THROTTLING ***
                            Current issues:
                            Previously detected issues:
                            *** Time and Time Zones ***
                                           Local time: Fri 2024-08-16 21:44:05 CEST
                                       Universal time: Fri 2024-08-16 19:44:05 UTC
                                             RTC time: n/a
                                          NTP service: active
                                      RTC in local TZ: no
                            *** Users and Groups ***
                            User that called 'iob diag':
                            pi
                            HOME=/home/pi
                            GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
                            iobroker
                            HOME=/home/iobroker
                            *** Display-Server-Setup ***
                            Desktop:
                            Terminal:       tty
                            *** MEMORY ***
                            Mem:           923M        320M        231M        6.0M        370M        531M
                            Swap:           99M         40M         59M
                            Total:         1.0G        361M        291M
                            Active iob-Instances:   22
                                      923 M total memory
                                      320 M used memory
                                      208 M active memory
                                      406 M inactive memory
                                      231 M free memory
                                       84 M buffer memory
                                      285 M swap cache
                                       99 M total swap
                                       40 M used swap
                                       59 M free swap
                            top - 21:44:06 up 22 days,  2:30,  1 user,  load average: 1.00, 1.39, 1.09
                            Tasks: 115 total,   1 running, 114 sleeping,   0 stopped,   0 zombie
                            %Cpu(s):  2.6 us,  3.8 sy,  0.0 ni, 93.6 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                            MiB Mem :    923.2 total,    231.5 free,    321.0 used,    370.7 buff/cache
                            MiB Swap:    100.0 total,     59.2 free,     40.8 used.    531.3 avail Mem
                            *** FAILED SERVICES ***
                            0 loaded units listed. Pass --all to see loaded but inactive units, too.
                            To show all installed unit files use 'systemctl list-unit-files'.
                            *** FILESYSTEM ***
                            /dev/root      ext4      7.1G  3.6G  3.2G  54% /
                            devtmpfs       devtmpfs  430M     0  430M   0% /dev
                            tmpfs          tmpfs     462M     0  462M   0% /dev/shm
                            tmpfs          tmpfs     462M   41M  421M   9% /run
                            tmpfs          tmpfs     462M     0  462M   0% /sys/fs/cgroup
                            /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
                            tmpfs          tmpfs      93M     0   93M   0% /run/user/1000
                            [Thu Jul 25 19:13:15 2024] Kernel command line: coherent_pool=1M snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyAMA0,115200 console=tty1 root=PARTUUID=99f5034b-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
                            [Thu Jul 25 19:13:19 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
                            [Thu Jul 25 19:13:19 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                            [Thu Jul 25 19:13:24 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
                            Show mounted filesystems:
                            TARGET                                SOURCE         FSTYPE     OPTIONS
                            /                                     /dev/mmcblk0p2 ext4       rw,noatime
                            |-/dev                                devtmpfs       devtmpfs   rw,relatime,size=439404k,nr_inodes=109851,mode=755
                            | |-/dev/shm                          tmpfs          tmpfs      rw,nosuid,nodev
                            | |-/dev/pts                          devpts         devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
                            | `-/dev/mqueue                       mqueue         mqueue     rw,relatime
                            |-/sys                                sysfs          sysfs      rw,nosuid,nodev,noexec,relatime
                            | |-/sys/kernel/security              securityfs     securityfs rw,nosuid,nodev,noexec,relatime
                            | |-/sys/fs/cgroup                    tmpfs          tmpfs      ro,nosuid,nodev,noexec,mode=755
                            | | |-/sys/fs/cgroup/unified          cgroup2        cgroup2    rw,nosuid,nodev,noexec,relatime,nsdelegate
                            | | |-/sys/fs/cgroup/systemd          cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,xattr,name=systemd
                            | | |-/sys/fs/cgroup/net_cls,net_prio cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,net_cls,net_prio
                            | | |-/sys/fs/cgroup/devices          cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,devices
                            | | |-/sys/fs/cgroup/blkio            cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,blkio
                            | | |-/sys/fs/cgroup/freezer          cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,freezer
                            | | |-/sys/fs/cgroup/cpu,cpuacct      cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,cpu,cpuacct
                            | | |-/sys/fs/cgroup/perf_event       cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,perf_event
                            | | |-/sys/fs/cgroup/cpuset           cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,cpuset
                            | | `-/sys/fs/cgroup/pids             cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,pids
                            | |-/sys/fs/bpf                       none           bpf        rw,nosuid,nodev,noexec,relatime,mode=700
                            | |-/sys/kernel/debug                 debugfs        debugfs    rw,relatime
                            | `-/sys/kernel/config                configfs       configfs   rw,relatime
                            |-/proc                               proc           proc       rw,relatime
                            | `-/proc/sys/fs/binfmt_misc          systemd-1      autofs     rw,relatime,fd=42,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
                            |-/run                                tmpfs          tmpfs      rw,nosuid,nodev,mode=755
                            | |-/run/lock                         tmpfs          tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k
                            | |-/run/rpc_pipefs                   sunrpc         rpc_pipefs rw,relatime
                            | `-/run/user/1000                    tmpfs          tmpfs      rw,nosuid,nodev,relatime,size=94536k,mode=700,uid=1000,gid=1000
                            `-/boot                               /dev/mmcblk0p1 vfat       rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                            /var:
                            484M    /var/
                            284M    /var/cache
                            278M    /var/cache/apt
                            219M    /var/cache/apt/archives
                            93M     /var/lib
                            Archived and active journals take up 40.4M in the file system.
                            /opt/iobroker/backups:
                            du: cannot access '/opt/iobroker/backups/': No such file or directory
                            /opt/iobroker/iobroker-data:
                            16M     /opt/iobroker/iobroker-data/
                            11M     /opt/iobroker/iobroker-data/node-red
                            10M     /opt/iobroker/iobroker-data/node-red/node_modules
                            6.8M    /opt/iobroker/iobroker-data/node-red/node_modules/node-red-contrib-blockly
                            5.3M    /opt/iobroker/iobroker-data/node-red/node_modules/node-red-contrib-blockly/lib
                            860K    /opt/iobroker/iobroker-data/node-red/node_modules/node-red-contrib-blockly/images/blockly_intro.gif
                            780K    /opt/iobroker/iobroker-data/node-red/node_modules/node-red-contrib-blockly/lib/basic/blockly_accessible_compressed.js
                            736K    /opt/iobroker/iobroker-data/node-red/node_modules/node-red-contrib-blockly/lib/basic/blockly_compressed.js
                            440K    /opt/iobroker/iobroker-data/files/info.admin/lib/fonts/fontawesome-webfont.svg
                            428K    /opt/iobroker/iobroker-data/node-red/node_modules/node-red-contrib-blockly/images/blockly_hello_world.gif
                            USB-Devices by-id:
                            /dev/serial/by-id/usb-1a86_USB2.0-Serial-if00-port0
                            *** NodeJS-Installation ***
                            /usr/bin/npm            9.6.3
                            /usr/bin/npx            9.6.3
                            nodejs:
                              Installed: 19.9.0-deb-1nodesource1
                              Candidate: 19.9.0-deb-1nodesource1
                              Version table:
                             *** 19.9.0-deb-1nodesource1 100
                                    100 /var/lib/dpkg/status
                                 18.20.4-1nodesource1 600
                                    500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                                 18.20.3-1nodesource1 600
                                 18.20.2-1nodesource1 600
                                 18.20.1-1nodesource1 600
                                 18.20.0-1nodesource1 600
                                 18.19.1-1nodesource1 600
                                 18.19.0-1nodesource1 600
                                 18.18.2-1nodesource1 600
                                 18.18.1-1nodesource1 600
                                 18.18.0-1nodesource1 600
                                 18.17.1-1nodesource1 600
                                 18.17.0-1nodesource1 600
                                 18.16.1-1nodesource1 600
                                 18.16.0-1nodesource1 600
                                 18.15.0-1nodesource1 600
                                 18.14.2-1nodesource1 600
                                 18.14.1-1nodesource1 600
                                 18.14.0-1nodesource1 600
                                 18.13.0-1nodesource1 600
                                 18.12.0-1nodesource1 600
                                 18.11.0-1nodesource1 600
                                 18.10.0-1nodesource1 600
                                 18.9.1-1nodesource1 600
                                 18.9.0-1nodesource1 600
                                 18.8.0-1nodesource1 600
                                 18.7.0-1nodesource1 600
                                 18.6.0-1nodesource1 600
                                 18.5.0-1nodesource1 600
                                 18.4.0-1nodesource1 600
                                 18.3.0-1nodesource1 600
                                 18.2.0-1nodesource1 600
                                 18.1.0-1nodesource1 600
                                 18.0.0-1nodesource1 600
                                 10.24.0~dfsg-1~deb10u3 500
                            No problems detected
                            Errors in npm tree:
                            *** ioBroker-Installation ***
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            Core adapters versions
                            js-controller:  6.0.9
                            admin:          6.12.0
                            javascript:     7.1.4
                            Adapter State
                            + system.adapter.backitup.0               : backitup              : odroidc4                                 -  enabled
                            + system.adapter.cloud.0                  : cloud                 : odroidc4                                 -  enabled
                              system.adapter.discovery.0              : discovery             : ioBrokerWallbox                          -  enabled
                            + system.adapter.email.0                  : email                 : odroidc4                                 -  enabled
                            + system.adapter.email.1                  : email                 : odroidc4                                 -  enabled
                              system.adapter.flot.0                   : flot                  : odroidc4                                 - disabled
                            + system.adapter.fronius.0                : fronius               : odroidc4                                 -  enabled
                            + system.adapter.history.0                : history               : odroidc4                                 -  enabled
                            + system.adapter.info.0                   : info                  : odroidc4                                 -  enabled
                            + system.adapter.javascript.0             : javascript            : ioBrokerHeimspeicher                     -  enabled
                            + system.adapter.javascript.1             : javascript            : odroidc4                                 -  enabled
                            + system.adapter.modbus.0                 : modbus                : odroidc4                                 -  enabled
                            + system.adapter.modbus.1                 : modbus                : odroidc4                                 -  enabled
                            + system.adapter.mqtt.0                   : mqtt                  : odroidc4                                 -  enabled, port: 1886, bind: 0.0.0.0
                              system.adapter.netatmo-crawler.0        : netatmo-crawler       : odroidc4                                 -  enabled
                            + system.adapter.node-red.0               : node-red              : ioBrokerHeimspeicher                     -  enabled, port: 1880, bind: 0.0.0.0
                              system.adapter.node-red.2               : node-red              : ioBrokerWallbox                          -  enabled, port: 1880, bind: 0.0.0.0
                            + system.adapter.node-red.3               : node-red              : odroidc4                                 -  enabled, port: 1880, bind: 0.0.0.0
                            + system.adapter.ping.0                   : ping                  : odroidc4                                 -  enabled
                            + system.adapter.rpi2.1                   : rpi2                  : ioBrokerHeimspeicher                     -  enabled
                            + system.adapter.sonoff.0                 : sonoff                : odroidc4                                 -  enabled, port: 1883, bind: 0.0.0.0
                              system.adapter.vis-history.0            : vis-history           : odroidc4                                 - disabled
                              system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : odroidc4                                 - disabled
                              system.adapter.vis-justgage.0           : vis-justgage          : odroidc4                                 - disabled
                              system.adapter.vis-timeandweather.0     : vis-timeandweather    : odroidc4                                 - disabled
                              system.adapter.vis.0                    : vis                   : odroidc4                                 -  enabled
                            + system.adapter.vw-connect.0             : vw-connect            : odroidc4                                 -  enabled
                            + system.adapter.worx.0                   : worx                  : odroidc4                                 -  enabled
                            + instance is alive
                            ioBroker-Repositories
                            │ (index) │   name   │                           url                           │ auto upgrade │
                            │    0    │ 'stable' │    'http://download.iobroker.net/sources-dist.json'     │    false     │
                            │    1    │  'beta'  │ 'http://download.iobroker.net/sources-dist-latest.json' │    false     │
                            Active repo(s): stable
                            Installed ioBroker-Instances
                            Used repository: stable
                            Adapter    "admin"        : 7.0.22   , installed 6.12.0 [Updatable]
                            Adapter    "discovery"    : 4.5.0    , installed 3.1.0  [Updatable]
                            Adapter    "javascript"   : 8.7.6    , installed 7.1.4  [Updatable]
                            Controller "js-controller": 6.0.9    , installed 6.0.9
                            Adapter    "modbus"       : 6.2.3    , installed 5.0.11 [Updatable]
                            Adapter    "node-red"     : 5.2.1    , installed 4.0.3  [Updatable]
                            Adapter    "rpi2"         : 1.3.2    , installed 1.3.2
                            Adapter    "simple-api"   : 2.8.0    , installed 2.7.2  [Updatable]
                            Objects and States
                            Objects:        3850
                            States:         2939
                            Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                            Hit:2 http://archive.raspberrypi.org/debian buster InRelease
                            Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
                            Reading package lists...
                            Pending Updates: 61
                            *** Listening Ports ***
                            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16438      416/sshd
                            tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       257398     28192/node-red
                            tcp6       0      0 :::22                   :::*                    LISTEN      0          16440      416/sshd
                            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14359      406/dhcpcd
                            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12150      304/avahi-daemon: r
                            udp        0      0 0.0.0.0:33669           0.0.0.0:*                           108        12152      304/avahi-daemon: r
                            udp6       0      0 :::5353                 :::*                                108        12151      304/avahi-daemon: r
                            udp6       0      0 :::48595                :::*                                108        12153      304/avahi-daemon: r
                            2024-08-16 21:41:46.463  - info: node-red.0 (28192) State value to set for "node-red.0.arduino.serial" has to be type "string" but received type "object"
                            2024-08-16 21:41:54.484  - warn: host.ioBrokerHeimspeicher "system.host.ioBrokerWallbox" is offline
                            2024-08-16 21:41:58.086  - info: host.ioBrokerHeimspeicher Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                            2024-08-16 21:42:13.674  - info: javascript.0 (28159) script.js.Heimspeicher.Debug: Überschuss -106.56666666666672
                            2024-08-16 21:42:13.901  - warn: host.ioBrokerHeimspeicher "system.host.ioBrokerWallbox" is offline
                            2024-08-16 21:42:25.736  - warn: host.ioBrokerHeimspeicher "system.host.ioBrokerWallbox" is offline
                            2024-08-16 21:42:31.535  - info: host.ioBrokerHeimspeicher Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                            2024-08-16 21:42:43.437  - info: javascript.0 (28159) script.js.Heimspeicher.Debug: Überschuss -124.22222222222227
                            2024-08-16 21:42:53.222  - warn: host.ioBrokerHeimspeicher "system.host.ioBrokerWallbox" is offline
                            2024-08-16 21:43:14.319  - info: javascript.0 (28159) script.js.Heimspeicher.Debug: Überschuss -142.65555555555562
                            2024-08-16 21:43:46.307  - info: javascript.0 (28159) script.js.Heimspeicher.Debug: Überschuss -161.54444444444457
                            2024-08-16 21:44:18.273  - info: javascript.0 (28159) script.js.Heimspeicher.Debug: Überschuss -180.81111111111122
                            2024-08-16 21:44:50.247  - info: javascript.0 (28159) script.js.Heimspeicher.Debug: Überschuss -199.40555555555568
                            2024-08-16 21:45:22.310  - info: javascript.0 (28159) script.js.Heimspeicher.Debug: Überschuss -195.78333333333347
                            2024-08-16 21:45:54.290  - info: javascript.0 (28159) script.js.Heimspeicher.Debug: Überschuss -196.42222222222236
                            2024-08-16 21:46:26.268  - info: javascript.0 (28159) script.js.Heimspeicher.Debug: Überschuss -196.0555555555557
                            2024-08-16 21:46:45.349  - info: node-red.0 (28166) 16 Aug 21:46:45 - [info] [debug:Eingang Arduino]
                            Batteriespannung 11.83V
                            16 Aug 21:46:45 - [info] [debug:dbacb8a3.876758]
                            11.83
                            Ich werde erstmal alles aktualisieren und mich dann wieder melden.
                            Danke erstmal.
                            mcm1957 Codierknecht Homoran 3 Replies Last reply Reply Quote 0
                            • mcm1957
                              mcm1957 @Manuel001 last edited by mcm1957
                              adapter "rpi2" : 1.3.2
                              https://github.com/iobroker-community-adapters/ioBroker.rpi2/issues/191
                              LastPerfectTobi created this issue in iobroker-community-adapters/ioBroker.rpi2
                              closed Adapter not starting with JS-Controller 6.0.1 #191
                              • Codierknecht
                                Codierknecht Developer Most Active @Manuel001 last edited by
                                @manuel001
                                Das kannst Du nicht weiter aktualisieren. Da muss was neues drauf.
                                Weiß aber nicht, ob das bei 'nem Pi 2 funktioniert und/oder Sinn macht.
                                Und ein Desktop hat auf 'nem Server auch nix zu suchen.
                                  auf jeden Fall, nur
                                  kannst du nicht mehr aktualisieren.
                                  ist schon lange tot und raspbian12 (bookworm) ist dermaßen komplett neu gestrickt, dass du das nur per Neuinstallation unfallfrei hinbekommst
                                    @homoran Ok, dann muss es so wie es ist noch ein paar Monate durchhalten.
                                    Der Master ist eh aktuell und der Slave wird in ein paar Monaten ohnehin ersetzt.
                                    Danke erstmal.
                                      und warum nicht jetzt?
                                      und ein Neuaufbau dauert 1h. am besten mit zweiter SD Card, dann hast du noch das Hardwarebackup.
                                      geht nicht!
                                      für buster gibt es kein aktuelles node mehr.
                                        Ich habe mich etwas falsch ausgedrückt. Es wird nicht der Slave ersetzt, sondern der ganze Speicher inkl. dem Raspi mit ioBroker Slave. Der Slave wird dann gar nicht mehr benötigt, weil der Speicher direkt ausgelesen werden kann (vom Haupt-ioBroker).
                                          geht nicht!
                                          Ich habe jetzt auch noch rausgefunden, was die Probleme verursacht hat.
                                          Es ist reproduzierbar das Update vom js-controller von 5.0.16 auf 6.0.9
                                          Ich bleibe die paar Monate einfach noch auf 5.0.16
                                          Der Haupt-ioBroker läuft eh schon mit 6.0.9 problemlos.
                                          446
