    4. [Erledigt] iob lässt sich nach Systembsturz nicht starten
    • amg_666
      amg_666 last edited by amg_666
      iobroker läuft bei mir unter proxmox auf einem nu, der ist nach Stromausfall neugestartet, jetzt kommt der iob nicht mehr hoch:
      Andreas@iobroker:~$ iob status
      node:internal/modules/package_json_reader:83
              throw new ERR_INVALID_PACKAGE_CONFIG(
      Error [ERR_INVALID_PACKAGE_CONFIG]: Invalid package config /opt/iobroker/node_modules/axios/package.json while importing "axios" from /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/esm/lib/setup/setupUpload.js. Unexpected end of JSON input
          at Object.read (node:internal/modules/package_json_reader:83:15)
          at packageResolve (node:internal/modules/esm/resolve:835:45)
          at moduleResolve (node:internal/modules/esm/resolve:927:18)
          at defaultResolve (node:internal/modules/esm/resolve:1169:11)
          at ModuleLoader.defaultResolve (node:internal/modules/esm/loader:383:12)
          at ModuleLoader.resolve (node:internal/modules/esm/loader:352:25)
          at ModuleLoader.getModuleJob (node:internal/modules/esm/loader:227:38)
          at ModuleWrap.<anonymous> (node:internal/modules/esm/module_job:87:39)
          at link (node:internal/modules/esm/module_job:86:36) {
        code: 'ERR_INVALID_PACKAGE_CONFIG'
      Node.js v20.16.0
      Andreas@iobroker:~$ ^C
      Andreas@iobroker:~$
      Was kann man da machen?
        Homoran Global Moderator Administrators @amg_666 last edited by Homoran
        @amg_666 sagte in iob lässt sich nach Systembsturz nicht mehr starten:
        Erst mal iob diag in der Langfassung!
        Strom weg gewesen?
        amg_666 1 Reply Last reply Reply Quote 0
        • amg_666
          amg_666 @Homoran last edited by amg_666
          @homoran iob diagmeckert auch erstmal rum:
          * *** iob diag is starting up, please wait ***
          * node:internal/modules/package_json_reader:83
          *         throw new ERR_INVALID_PACKAGE_CONFIG(
          * Error [ERR_INVALID_PACKAGE_CONFIG]: Invalid package config /opt/iobroker/node_modules/axios/package.json while importing "axios" from /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/esm/lib/setup/setupUpload.js. Unexpected end of JSON input
          *     at Object.read (node:internal/modules/package_json_reader:83:15)
          *     at packageResolve (node:internal/modules/esm/resolve:835:45)
          *     at moduleResolve (node:internal/modules/esm/resolve:927:18)
          *     at defaultResolve (node:internal/modules/esm/resolve:1169:11)
          *     at ModuleLoader.defaultResolve (node:internal/modules/esm/loader:383:12)
          *     at ModuleLoader.resolve (node:internal/modules/esm/loader:352:25)
          *     at ModuleLoader.getModuleJob (node:internal/modules/esm/loader:227:38)
          *     at ModuleWrap.<anonymous> (node:internal/modules/esm/module_job:87:39)
          *     at link (node:internal/modules/esm/module_job:86:36) {
          *   code: 'ERR_INVALID_PACKAGE_CONFIG'
          * Node.js v20.16.0
          * Node.js v20.16.0
          * Node.js v20.16.0
          * Node.js v20.16.0
          Ausgabe iob diag ist dann
          Skript v.2024-05-22
          *** BASE SYSTEM ***
           Static hostname: iobroker
                 Icon name: computer-container
                   Chassis: container ☐
            Virtualization: lxc
                    Kernel: Linux 6.8.12-1-pve
              Architecture: x86-64
          model name      : Intel(R) Celeron(R) CPU J3455 @ 1.50GHz
          Docker          : false
          Virtualization  : lxc
          Kernel          : x86_64
          Userland        : 64 bit
          Systemuptime and Load:
           19:47:13 up 26 min,  2 users,  load average: 1.40, 1.29, 0.76
          CPU threads: 4
          *** Time and Time Zones ***
                         Local time: Sun 2024-08-18 19:47:13 CEST
                     Universal time: Sun 2024-08-18 17:47:13 UTC
                           RTC time: n/a
                        NTP service: inactive
                    RTC in local TZ: no
          *** Users and Groups ***
          User that called 'iob diag':
          Andreas
          HOME=/home/Andreas
          GROUPS=Andreas sudo iobroker
          js-controller is not running
          *** Display-Server-Setup ***
          Display-Server: false
          Desktop:
          Terminal:
          *** MEMORY ***
          Mem:             12G         33M         12G        114K        111M         12G
          Swap:           4.3G          0B        4.3G
          Total:           17G         33M         17G
          Active iob-Instances:   0
                  12288 M total memory
                     32 M used memory
                    123 M active memory
                      0 M inactive memory
                  12149 M free memory
                      0 M buffer memory
                    106 M swap cache
                   4096 M total swap
                      0 M used swap
                   4096 M free swap
          top - 19:47:13 up 26 min,  2 users,  load average: 1.29, 1.27, 0.75
          Tasks:  24 total,   1 running,  23 sleeping,   0 stopped,   0 zombie
          %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
          MiB Mem :  12288.0 total,  12148.0 free,     33.5 used,    106.6 buff/cache
          MiB Swap:   4096.0 total,   4096.0 free,      0.0 used.  12254.5 avail Mem
          *** FAILED SERVICES ***
            UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
          * run-rpc_pipefs.mount    loaded failed failed RPC Pipe File System
          * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
          2 loaded units listed.
          *** FILESYSTEM ***
          Filesystem                  Type      Size  Used Avail Use% Mounted on
          HA-Volume/subvol-100-disk-0 zfs       150G  9.6G  141G   7% /
          none                        tmpfs     492K  4.0K  488K   1% /dev
          udev                        devtmpfs  7.8G     0  7.8G   0% /dev/tty
          tmpfs                       tmpfs     7.8G     0  7.8G   0% /dev/shm
          tmpfs                       tmpfs     3.1G  108K  3.1G   1% /run
          tmpfs                       tmpfs     5.0M     0  5.0M   0% /run/lock
          dmesg: read kernel buffer failed: Operation not permitted
          Show mounted filesystems:
          TARGET                                                  SOURCE                         FSTYPE     OPTIONS
          /                                                       HA-Volume/subvol-100-disk-0    zfs        rw,relatime,xattr,posixacl,casesensitive
          |-/run                                                  tmpfs                          tmpfs      rw,nosuid,nodev,size=3245184k,nr_inodes=819200,mode=755,uid=100000,gid=100000,inode64
          | |-/run/lock                                           tmpfs                          tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k,uid=100000,gid=100000,inode64
          | |-/run/credentials/systemd-sysusers.service           ramfs                          ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
          | |-/run/credentials/systemd-sysctl.service             ramfs                          ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
          | |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs                          ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
          | `-/run/credentials/systemd-tmpfiles-setup.service     ramfs                          ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
          |-/dev                                                  none                           tmpfs      rw,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
          | |-/dev/shm                                            tmpfs                          tmpfs      rw,nosuid,nodev,uid=100000,gid=100000,inode64
          | |-/dev/console                                        devpts[/0]                     devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
          | |-/dev/tty1                                           devpts[/1]                     devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
          | |-/dev/tty2                                           devpts[/2]                     devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
          | |-/dev/.lxc/proc                                      proc                           proc       rw,relatime
          | |-/dev/.lxc/sys                                       sys                            sysfs      rw,relatime
          | |-/dev/full                                           udev[/full]                    devtmpfs   rw,nosuid,relatime,size=8079664k,nr_inodes=2019916,mode=755,inode64
          | |-/dev/null                                           udev[/null]                    devtmpfs   rw,nosuid,relatime,size=8079664k,nr_inodes=2019916,mode=755,inode64
          | |-/dev/random                                         udev[/random]                  devtmpfs   rw,nosuid,relatime,size=8079664k,nr_inodes=2019916,mode=755,inode64
          | |-/dev/tty                                            udev[/tty]                     devtmpfs   rw,nosuid,relatime,size=8079664k,nr_inodes=2019916,mode=755,inode64
          | |-/dev/urandom                                        udev[/urandom]                 devtmpfs   rw,nosuid,relatime,size=8079664k,nr_inodes=2019916,mode=755,inode64
          | |-/dev/zero                                           udev[/zero]                    devtmpfs   rw,nosuid,relatime,size=8079664k,nr_inodes=2019916,mode=755,inode64
          | |-/dev/pts                                            devpts                         devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
          | |-/dev/ptmx                                           devpts[/ptmx]                  devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
          | `-/dev/mqueue                                         mqueue                         mqueue     rw,nosuid,nodev,noexec,relatime
          |-/proc                                                 proc                           proc       rw,nosuid,nodev,noexec,relatime
          | |-/proc/sys                                           proc[/sys]                     proc       ro,relatime
          | | |-/proc/sys/kernel/random/boot_id                   none[/.lxc-boot-id]            tmpfs      ro,nosuid,nodev,noexec,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
          | | `-/proc/sys/net                                     proc[/sys/net]                 proc       rw,nosuid,nodev,noexec,relatime
          | |-/proc/sysrq-trigger                                 proc[/sysrq-trigger]           proc       ro,relatime
          | |-/proc/cpuinfo                                       lxcfs[/proc/cpuinfo]           fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
          | |-/proc/diskstats                                     lxcfs[/proc/diskstats]         fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
          | |-/proc/loadavg                                       lxcfs[/proc/loadavg]           fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
          | |-/proc/meminfo                                       lxcfs[/proc/meminfo]           fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
          | |-/proc/slabinfo                                      lxcfs[/proc/slabinfo]          fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
          | |-/proc/stat                                          lxcfs[/proc/stat]              fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
          | |-/proc/swaps                                         lxcfs[/proc/swaps]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
          | `-/proc/uptime                                        lxcfs[/proc/uptime]            fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
          `-/sys                                                  sysfs                          sysfs      ro,nosuid,nodev,noexec,relatime
            |-/sys/fs/fuse/connections                            fusectl                        fusectl    rw,nosuid,nodev,noexec,relatime
            |-/sys/devices/virtual/net                            sysfs[/devices/virtual/net]    sysfs      rw,nosuid,nodev,noexec,relatime
            |-/sys/fs/cgroup                                      none                           cgroup2    rw,nosuid,nodev,noexec,relatime
            `-/sys/devices/system/cpu                             lxcfs[/sys/devices/system/cpu] fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
          /var:
          354M    /var/
          279M    /var/cache
          277M    /var/cache/apt
          231M    /var/cache/apt/archives
          66M     /var/lib
          Archived and active journals take up 862.5K in the file system.
          /opt/iobroker/backups:
          2.8G    /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          1.9G    /opt/iobroker/iobroker-data/
          1.4G    /opt/iobroker/iobroker-data/history
          414M    /opt/iobroker/iobroker-data/files
          203M    /opt/iobroker/iobroker-data/files/javascript.admin
          186M    /opt/iobroker/iobroker-data/files/javascript.admin/static
          15M     /opt/iobroker/iobroker-data/objects.jsonl
          15M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
          11M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.ce422ec2.js.map
          9.6M    /opt/iobroker/iobroker-data/files/echarts/static/js/main.bad2715c.js.map
          9.6M    /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.bad2715c.js.map
          USB-Devices by-id:
          No Devices found 'by-id'
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v20.16.0
          /usr/bin/node           v20.16.0
          /usr/bin/npm            10.8.1
          /usr/bin/npx            10.8.1
          /usr/bin/corepack       0.28.2
          nodejs:
            Installed: 20.16.0-1nodesource1
            Candidate: 20.16.0-1nodesource1
            Version table:
           *** 20.16.0-1nodesource1 1001
                  500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                  100 /var/lib/dpkg/status
               20.15.1-1nodesource1 1001
               20.15.0-1nodesource1 1001
               20.14.0-1nodesource1 1001
               20.13.1-1nodesource1 1001
               20.13.0-1nodesource1 1001
               20.12.2-1nodesource1 1001
               20.12.1-1nodesource1 1001
               20.12.0-1nodesource1 1001
               20.11.1-1nodesource1 1001
               20.11.0-1nodesource1 1001
               20.10.0-1nodesource1 1001
               20.9.0-1nodesource1 1001
               20.8.1-1nodesource1 1001
               20.8.0-1nodesource1 1001
               20.7.0-1nodesource1 1001
               20.6.1-1nodesource1 1001
               20.6.0-1nodesource1 1001
               20.5.1-1nodesource1 1001
               20.5.0-1nodesource1 1001
               20.4.0-1nodesource1 1001
               20.3.1-1nodesource1 1001
               20.3.0-1nodesource1 1001
               20.2.0-1nodesource1 1001
               20.1.0-1nodesource1 1001
               20.0.0-1nodesource1 1001
               18.19.0+dfsg-6~deb12u2 500
                  500 http://deb.debian.org/debian bookworm/main amd64 Packages
               18.19.0+dfsg-6~deb12u1 500
                  500 http://security.debian.org bookworm-security/main amd64 Packages
          No problems detected
          Errors in npm tree:
          *** ioBroker-Installation ***
          ioBroker Status
          Node.js v20.16.0
          Core adapters versions
          Node.js v20.16.0
          js-controller:
          Node.js v20.16.0
          admin:
          Node.js v20.16.0
          javascript:
          nodejs modules from github:     1
          | +-- node-milight-promise@0.3.2 (git+ssh://git@github.com/Steiger04/node-milight-promise.git#f1089feac9b7990727adf2016891029436729d33)
          Adapter State
          ioBroker-Repositories
          Node.js v20.16.0
          Installed ioBroker-Instances
          Node.js v20.16.0
          Objects and States
          Objects:        0
          States:         0
          Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
          Hit:3 http://security.debian.org bookworm-security InRelease
          Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          11975      1/init
          tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          13212      338/master
          tcp6       0      0 :::22                   :::*                    LISTEN      0          15779      1/init
          tcp6       0      0 :::111                  :::*                    LISTEN      0          11977      1/init
          tcp6       0      0 ::1:25                  :::*                    LISTEN      0          13213      338/master
          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          11976      1/init
          udp6       0      0 :::111                  :::*                                0          11978      1/init
            Thomas Braun Most Active @amg_666 last edited by
            @amg_666
            Knall den js-controller einfach nochmal drauf.
            • amg_666
              amg_666 @Thomas Braun last edited by
              @thomas-braun in der Konsole js-controller neu installieren ?
                @amg_666
                Ja.
                • amg_666
                  @thomas-braun Danke, das sieht gut aus:
                  Andreas@iobroker:/opt/iobroker$ iobroker stop
                  Andreas@iobroker:/opt/iobroker$ npm install iobroker.js-controller
                  changed 2 packages in 14s
                  300 packages are looking for funding
                    run `npm fund` for details
                  Andreas@iobroker:/opt/iobroker$ iob start
                  Andreas@iobroker:/opt/iobroker$ iob status
                  Objects type: jsonl
                  States  type: redis
                  • Codierknecht
                    Codierknecht Developer Most Active @amg_666 last edited by
                    @amg_666
                    Hat es einen speziellen Grund, warum Du da mixt?
                    Objects type: jsonl
                    States  type: redis
                    • amg_666
                      amg_666 @Codierknecht last edited by
                      @codierknecht ich habe die objects (noch) nicht auf redis umgestellt. Redis läuft auf einem eigenen Server und ich wollte erstmal sehen ob und wie stabil das läuft. Objects kommen noch dran 🙂
