    5. Aktien Blockly umbauen (request deprecated)
    • Olli_M
      Olli_M last edited by
      ich habe ein Aktienblockly mal hier gefunden. Jetzt gibts doch die neue Funktion mit http(Get).
      Habe es bei Aktie 01 versucht umzubauen aber aktualisiert sich nicht.
      Kann mir da jemand helfen?
      Hab das ganze Script mal angehangen.
      common.Wohnzimmer.Aktien.xml
        Homoran Global Moderator Administrators @Olli_M last edited by Homoran
        @olli_m nicht result sondern fertige Variable data (mit Weltkugel)
        Olli_M 1 Reply Last reply Reply Quote 1
        • Olli_M
          @homoran okay probiert ich mal danke dir
          • Olli_M
            Olli_M @Homoran last edited by
            Also laut Debug hat er neue Daten bekommen:
            script.js.common.Wohnzimmer.Aktien: {"id":994529,"name":"NVIDIA","price":114.88,"close":114.38000000,"bid":114.8,"bidDate":"2024-08-21T18:59:48+02:00","ask":114.88,"askDate":"2024-08-21T18:59:48+02:00","changePercent":0.4371393600279769190417905200,"changeAbsolute":0.50000000,"instrumentType":{"mainType":"Share"},"instrumentTypeDisplayName":"Aktie","wkn":"918422","isin":"US67066G1040","internalIsin":"US67066G1040","stockMarket":"Direkthandel","priceChangeDate":"2024-08-21T18:59:21+02:00","currency":"EUR","currencySign":"EUR","pushSymbol":"X000ADB0200994529","labels":{"buttonWatch":"Beobachten"},"webtrekkPixelSettings":{"observe":"beobachten__header__sh.content.link_intern"},"formatDefinitions":[{"propertyName":"price","formatString":"0,0.00[00]","valueType":"Number","name":"TwoToFourDecimals"},{"propertyName":"bid","formatString":"0,0.00[00]","valueType":"Number","name":"TwoToFourDecimals"},{"propertyName":"ask","formatString":"0,0.00[00]","valueType":"Number","name":"TwoToFourDecimals"},{"propertyName":"changePercent","formatString":"0,0.00","valueType":"Number","name":"TwoDecimals"},{"propertyName":"changeAbsolute","formatString":"0,0.00[00]","valueType":"Number","name":"TwoToFourDecimals"}]}
            aber er hat zuviel in den DP geschrieben:
            hab alle result mit dem anderen Attribut ersetzt, war wohl zuviel?
            Homoran Codierknecht haus-automatisierung 3 Replies Last reply Reply Quote 0
              @olli_m ich hab hier am Handy nicht so ganz den Überblick.
              @olli_m sagte in Aktien Blockly umbauen (request deprecated):
              Welchen?
              change percent
              und change absolut dürften anders aussehen.
              und das sieht genauso aus wie bei request?
              EDIT: Ach "Kurs"
              da fehlt beim "bis" das Data
              • Codierknecht
                Codierknecht Developer Most Active @Olli_M last edited by
                @olli_m
                Sind das eigene DP unterhalb von 0_userdata.o?
                Dann solltest Du die mit "Aktualisiere" beschreiben.
                Ist aber nur Kosmetik, damit die nicht in rot dargestellt werden.
                Homoran Olli_M 2 Replies Last reply Reply Quote 1
                  Homoran Global Moderator Administrators @Codierknecht last edited by
                  @codierknecht
                  @Olli_M hat sich leider nicht wieder gemeldet.
                  Aber wenn es um den Datenpunkt "....Kurs" gehen sollte, dann fehlt hier
                  der Block "Data"
                  Codierknecht 1 Reply Last reply Reply Quote 1
                  • Codierknecht
                    Codierknecht Developer Most Active @Homoran last edited by
                    Dann ist's ja nicht dringend 😁
                    Wo der Fehler steckt, habe ich schon verstanden.
                    Wollte ihn nur zusätzlich noch auf das korrekte Beschreiben eigener DP hinweisen. 😉
                      mading last edited by
                      Nutze doch den adapter yahoo-stock-market
                      Olli_M 1 Reply Last reply Reply Quote 0
                      • haus-automatisierung
                        haus-automatisierung Developer Most Active @Olli_M last edited by haus-automatisierung
                        Was treibst Du da eigentlich? Du bekommst doch JSON zurück und kannst die Attribute doch einfach extrahieren. Warum zerlegst Du den String mit Text-Funktionen?
                        Bei name hast Du doch auch das Attribut direkt geholt.
                        Olli_M 1 Reply Last reply Reply Quote 2
                        • Olli_M
                          Olli_M @haus-automatisierung last edited by Olli_M
                          danke dir
                          ich habe das script ja nicht gebaut ich wollte es nur abändern 🙂 aber es läuft jetzt so
                          aber du hast recht man könnte es wirklich Einkürzen mit dem Attribut
                          na weil manche stellen gerundet werden müssen 🙂
                          • Olli_M
                            Olli_M @Codierknecht last edited by
                            @codierknecht
                            okay danke für den tipp
                            • Olli_M
                              Olli_M @mading last edited by
                              @mading
                              ne yahoo ist furchtbar 🙂 so läuft das script 1A
                              581
