    4. Installation
    5. Fataler Fehler nach Update (ioBroker Windows)
      markusma last edited by
      Hi
      wollte heute meine ioBroker Version mit Hilfe des Win-Installers auf die neuest Version heben.
      Das Upgrade ist leider fehlgeschlagen und ich bekomme seitdem keine Version mehr installiert (Auch ohne Import alter Konfigurationen nicht bzw. Uninstall/Install. Das Windows-Service iobroker scheint in der Service-Liste auch nicht mehr auf.)
      nodeJS wurde beim ersten Update mitaktualisiert.
      Folgendes zeigt das Logfile:
      Npm prefix path exists: C:\Users\Superuser\AppData\Roaming\npm ---> OK
      Executing:
      @echo off
      SET PATH=C:\Program Files\nodejs;%PATH:&=^&%
      "C:\Program Files\nodejs\npx" --yes @iobroker/install@latest
      Windows installation starting... (fixing = false)
      NPM version: 10.8.2
      npm warn config production Use `--omit=dev` instead.
      npm warn deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
      npm warn deprecated har-validator@5.1.5: this library is no longer supported
      npm warn deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
      npm warn deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
      added 549 packages, and audited 578 packages in 1m
      72 packages are looking for funding
        run `npm fund` for details
      29 vulnerabilities (22 moderate, 6 high, 1 critical)
      To address issues that do not require attention, run:
        npm audit fix
      To address all issues (including breaking changes), run:
        npm audit fix --force
      Run `npm audit` for details.
      Write "iobroker start" to start the ioBroker
      npm install dotenv@^16.4.5 --force --loglevel error --production --save --prefix "C:/ioBroker"
      up to date, audited 578 packages in 6s
        npm audit fix
      npm install windows-shortcuts@^0.1.6 --force --loglevel error --production --save --prefix "C:/ioBroker"
      up to date, audited 578 packages in 4s
        npm audit fix
      winget install --id Git.Git -e --source winget --silent --force --disable-interactivity --accept-source-agreements --accept-package-agreements
      'winget' is not recognized as an internal or external command,
      operable program or batch file.
      Error when installing GIT: Error: Command failed: winget install --id Git.Git -e --source winget --silent --force --disable-interactivity --accept-source-agreements --accept-package-agreements
      Register ioBroker as Service
      Written iobnodevars.bat successfully.
      Shortcut "C:\ProgramData\Microsoft\Windows\Start Menu\Programs\ioBroker automation platform\ioBroker Command line.lnk" created with Admin flag!
      Shortcut "C:\ProgramData\Microsoft\Windows\Start Menu\Programs\ioBroker automation platform\Start ioBroker Service.lnk" created with Admin flag!
      Shortcut "C:\ProgramData\Microsoft\Windows\Start Menu\Programs\ioBroker automation platform\ioBroker Admin.lnk" created!
      Shortcut "C:\ProgramData\Microsoft\Windows\Start Menu\Programs\ioBroker automation platform\Stop ioBroker Service.lnk" created with Admin flag!
      Shortcut "C:\ProgramData\Microsoft\Windows\Start Menu\Programs\ioBroker automation platform\Restart ioBroker Service.lnk" created with Admin flag!
      The process cannot access the file because it is being used by another process.
      Creation of Windows service failed!
      Starting Windows service failed!
      Running Admin shell
      ioBroker service name: ioBroker
      The service name is invalid.
      More help is available by typing NET HELPMSG 2185.
      ioBroker service installed and started. Go to http://localhost:8081 to open the admin UI.
      To see the outputs do not start the service, but write "node node_modules/iobroker.js-controller/controller"
      ioBroker installation/fixing completed!
      Waiting for ioBroker service ...
      ioBroker service ioBroker not started (timeout)!
      Bitte um Tipps, was ich tun könnte?!
      Markus
      mikeal created this issue in request/request
      open Request’s Past, Present and Future #3142
      mcm1957 OliverIO 2 Replies Last reply Reply Quote 0
      • mcm1957
        mcm1957 @markusma last edited by mcm1957
        @markusma
        Hast du den aktuellen Windows Installer verwendet?
        Ansonsten kann wahrscheinlich @Gaspode helfen.
        Edir
        Und hast du vor der Installation iobroker beendet? Sieht das so aus als würde da noch was laufen.
        • OliverIO
          OliverIO @markusma last edited by
          @markusma sagte in Fataler Fehler nach Update (ioBroker Windows):
          dir fehlt winget, das musst du installieren
          https://learn.microsoft.com/de-de/windows/package-manager/winget/
          Gaspode 1 Reply Last reply Reply Quote 0
          • Gaspode
            Gaspode @OliverIO last edited by
            @oliverio said in Fataler Fehler nach Update (ioBroker Windows):
            Das auch, das ist aber nicht der Grund für das Problem, dass der Service nicht mehr startet bzw. installiert wird.
            @markusma said in Fataler Fehler nach Update (ioBroker Windows):
            Ein Fix ist unterwegs, bis da hin kannst du das Problem (hoffentlich) so lösen:
            Im ioBroker Cmd Fenster folgendes eingeben:
            curl -L --output .\install_test.js --url https://raw.githubusercontent.com/Gaspode69/ioBroker/Gaspode69-Win-Install-Service/install/windows/install.js
            node install_test.js
            ansonsten, am Besten den Windows Installer Thread abonnieren, da werden aktuelle Probleme in der Regel als erstes besprochen:
            https://forum.iobroker.net/post/958230
            • Gaspode
              Gaspode @Gaspode last edited by
              @gaspode said in Fataler Fehler nach Update (ioBroker Windows):
              Die Korrektur ist inzwischen Online, d.h. der ioBroker Fixer sollte den Service jetzt wieder korrekt anlegen.
              Danke an @apollon77 und @Bluefox für das schnelle releasen der Korrektur.
              @mcm1957
              Und Danke, dass du mich immer so schnell auf Windows Probleme aufmerksam machst. 🙂
              mcm1957 sigi234 2 Replies Last reply Reply Quote 1
              • mcm1957
                mcm1957 @Gaspode last edited by
                @gaspode
                No Problem. Bin froh dass du es nicht als lästig empfindest.
                GEMEINSAM schaffen wir ioBroker benutzerfreundlich zu halten.
                Wünsch noch nen schönen Sonntag.
                • sigi234
                  sigi234 Forum Testing Most Active @Gaspode last edited by
                  @gaspode sagte in Fataler Fehler nach Update (ioBroker Windows):
                  Super, gerade heruntergeladen. Ist Version gleich geblieben? 3.3.0
                  • Gaspode
                    Gaspode @sigi234 last edited by Gaspode
                    @sigi234 said in Fataler Fehler nach Update (ioBroker Windows):
                    Die Korrektur ist im Script-Teil, der per npx aufgerufen wird, d.h. der Windows Installer hat sich nicht geändert und braucht nicht erneut heruntergeladen zu werden.
                    81.1k
