    4. Installation
    5. Update js-controller from @6.0.7 to @6.0.11 nicht möglich
    • enzo
      enzo last edited by Homoran
      iobroker@iobroker:~ $ iob upgrade self
      Stopped Objects DB
      Stopped States DB
      NPM version: 10.8.2
      Installing iobroker.js-controller@6.0.11... (System call)
      npm error code 6
      npm error path /opt/iobroker/node_modules/iobroker.js-controller
      npm error command failed
      npm error command sh -c node iobroker.js setup first
      npm error Uncaught Rejection: TypeError: callback is not a function
      npm error     at /opt/iobroker/node_modules/iobroker.js-controller/node_modules/        @iobroker/plugin-base/lib/PluginBase.js:310:17
      npm error This error originated either by throwing inside of an async function w        ithout a catch block, or by rejecting a promise which was not handled with .catc        h(). The promise rejected with the reason:
      npm error TypeError: callback is not a function
      npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/        2024-08-27T11_43_53_132Z-debug-0.log
      host.iobroker Cannot install iobroker.js-controller@6.0.11: 6
      was kann ich machen um das zu fixen ?
      Homoran enzo 2 Replies Last reply Reply Quote 0
        Homoran Global Moderator Administrators @enzo last edited by
        @enzo sagte in Update js-controller from @6.0.7 to @6.0.11 nicht möglich:
        erstmal die notwendigsten Infos liefern.
        siehe
        zuallererst mal die Langfassung von iob diag
        • enzo
          enzo @enzo last edited by
          Copy text starting here:
                                  v.2024-05-22
             Static hostname: iobroker
                   Icon name: computer
            Operating System: Debian GNU/Linux 11 (bullseye)
                      Kernel: Linux 6.1.21-v8+
                Architecture: arm64
          User-ID:                1000
          Display-Server:         false
          Pending OS-Updates:     0
          Pending iob updates:    1
          Nodejs-Installation:
          /usr/bin/nodejs         v20.17.0
          /usr/bin/node           v20.17.0
          /usr/bin/corepack       0.29.3
          Recommended versions are nodejs 20.17.0 and npm 10.8.2
          MEMORY:
          Mem:            3.8G        102M        233M        0.0K        3.5G        3.6G
          Swap:            99M         18M         81M
          Total:          3.9G        120M        315M
          Active iob-Instances:   1
          Upgrade policy: none
          ioBroker Core:          js-controller           6.0.7
                                  admin                   7.0.25
          ioBroker Status:        iobroker is not running on this host.
          Objects type: jsonl
          States  type: jsonl
            system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          Objects:                9818
          States:                 7069
          Size of iob-Database:
          17M     /opt/iobroker/iobroker-data/objects.jsonl
          1.6M    /opt/iobroker/iobroker-data/states.jsonl
          === Mark text until here for copying ===
          iobroker@iobroker:~ $ Copy text starting here:
                                  v.2024-05-22
                   Icon name: computer
                Architecture: arm64
          User-ID:                1000
          ^C= Mark text until here for copying ==================nd: 0.0.0.0, run as: admi
          der iobroker leuft sehr gut.
          Nur js-controller 6.0.7 lässt sich nicht auf js-controller 6.0.11 bringen.
          Homoran ? 2 Replies Last reply Reply Quote 0
            @enzo 2x Summary ist immer noch nicht die Langfassung 😁
              A Former User @enzo last edited by
              @enzo
              Viiiiele Probleme.
              Erstmal. Dein OS solltest Du updaten -> Bookworm
              Dann kommst Du noch auf die Weboberfläche vom Iobroker?
              Als Nächstes. User und Host so zu benennen wie die Software selber . Schlechte Idee. Versuch das mal zu ändern.
              MartinP enzo Samson71 3 Replies Last reply Reply Quote 0
              • MartinP
                MartinP @Guest last edited by MartinP
                Auf welchem Repository bist Du? auf Beta?
                Ich bin auf "Stable" - mir wird angezeigt, 6.0.9 sei aktuell....
                P.S. Bullseye und Beta repository wäre eine interessante Kombi.
                enzo 1 Reply Last reply Reply Quote 0
                • enzo
                  enzo @Guest last edited by
                  @mrs-antje said in Update js-controller from @6.0.7 to @6.0.11 nicht möglich:
                  Bookworm
                  ja es läuft ganz gut nur Update auf js-controller 6.0.11 geht nicht.???
                  • enzo
                    enzo @MartinP last edited by
                    @martinp
                    ja auf Beta
                    Homoran MartinP 2 Replies Last reply Reply Quote 0
                      @enzo bitte die Langfassung!
                      @Mrs-Antje scheint ja eine Glaskugel deluxe zu haben.
                      ich leider nicht.
                      • Samson71
                        Samson71 Global Moderator @Guest last edited by
                        @mrs-antje sagte in Update js-controller from @6.0.7 to @6.0.11 nicht möglich:
                        Viiiiele Probleme.
                        Vermessene Aussage ohne Langfassung von iob diag
                        Grundsätzlich ist das korrekt aber hier sicher nicht die Ursache und auch nicht akut nötig. Zeitnah ja, aber nicht zwingend die erste Priorität.
                        • MartinP
                          MartinP @enzo last edited by
                          @enzo Dann hast Du aber längere Zeit keine Updates gemacht, wenn bei Dir 6.0.7 aktuell ist, und auf stable ist schon 6.0.9 draußen ...
                          Das ist alles eigentlich eine toxische Kombination:
                          • Veralteter Linux-Unterbau
                          • Beta Repository von ioBroker
                          • seltene Updates
                            @MartinP
                            was habt ihr alles für Glaskugeln?
                            @martinp sagte in Update js-controller from @6.0.7 to @6.0.11 nicht möglich:
                            bullseye ist nicht "veraltet", so dass es Probleme verursacht.
                            seltene Updates
                            woher weisst du das?
                            höchstens vom controller kannst du das wissen.
                            und auch hier 6.0.7 ist nicht soooo alt.
                              A Former User @Homoran last edited by
                              Hallo @homoran
                              Wo ist das Glaskugellesen? 🤔
                              Steht doch alles in den vom Threadersteller bereitgestellten Infos?!
                              Hallo @Samson71
                              Da im Forum Aktualität propagiert wird , was das OS angeht , habe ich das auch getan.
                              Vermutlich hat das nichts mit dem Problem zu tun.
                              Schließe mich da nur @Thomas-Braun an 😁
                                Homoran Global Moderator Administrators @Guest last edited by
                                aber wo sind die
                                Viiiiele Probleme.
                                aufgelistet???
                                Thomas Braun ? 2 Replies Last reply Reply Quote 0
                                  Meine Glaskugel sagt da gar nicht viel zu. Die würde die Langfassung benötigen.
                                  So auf den ersten Blick sieht das aber auch eigentlich gar nicht so verkehrt aus. Da hab ich schon andere Baustellen gesehen...
                                    Hallo @homoran
                                    Hab ich doch oben geschrieben?
                                    Wenn er wieder auf die Oberfläche kommt, kann er das Update ja per GUI machen.
                                    Und das Umbenennen von User und Host halte ich für sinnvoll.
                                    Genauso wie das OS Update.
                                      dem stimme ich ja auch zu, aber ohne harte Fakten kann ich vetmuten, dass es Fehler geben könnte, vielleicht auch ein paar, aber für viiiiele Fehler kann ich bisher keine Daten finden.
                                        Hallo @homoran
                                        Warten wir mal die Langfassung von iob diag ab …..
                                          das tue ich die ganze Zeit.
                                          • MartinP
                                            MartinP @Homoran last edited by
                                            @enzo Um die Langfassung zu kopieren, sollte man NICHT den angeforderten Tastendruck (press any key for summary) für die Zusammenfassung im Ablauf auslösen, sondern zuerst die Output-Kopie anfertigen. Für die Summary wird der Screen gelöscht, und man muss von vorne beginnen!
                                            Thomas Braun enzo 2 Replies Last reply Reply Quote 0
                                            4168
