    4. Zigbee Batterie EndDevice als Router in shepherd.db
      Franko1278 last edited by Franko1278
      Hallo, ich habe bei 2 von 4 Rauchmeldern der Firma Heiman das Problem, dass diese als Router in der shepherd.db stehen.
      {"id":43,"type":"EndDevice","ieeeAddr":"0x005043c903350f69","nwkAddr":6139,"manufId":48042,"manufName":"Heiman","powerSource":"Battery","modelId":"SMOK_YDLV10","epList":[1],"endpoints":{"1":{"profId":260,"epId":1,"devId":1026,"inClusterList":[0,3,1280,1,9,1282],"outClusterList":[25],"clusters":{"genBasic":{"attributes":{"modelId":"SMOK_YDLV10","manufacturerName":"Heiman","powerSource":3,"zclVersion":1,"appVersion":3,"stackVersion":2,"hwVersion":1,"dateCode":"20150330"}},"ssIasZone":{"attributes":{"iasCieAddr":"0x00124b00219fbf9a","zoneState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}}},"binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00219fbf9a","endpointID":242}],"configuredReportings":[{"cluster":1,"attrId":33,"minRepIntval":3600,"maxRepIntval":62000,"repChange":0}],"meta":{}}},"appVersion":3,"stackVersion":2,"hwVersion":1,"dateCode":"20150330","zclVersion":1,"interviewCompleted":true,"meta":{"configured":1},"lastSeen":1716484370289}
      {"id":97,"type":"Router","ieeeAddr":"0x005043c90335698b","nwkAddr":51037,"manufId":48042,"manufName":"Heiman","powerSource":"Battery","modelId":"SMOK_YDLV10","epList":[1],"endpoints":{"1":{"profId":260,"epId":1,"devId":1026,"inClusterList":[0,3,1280,1,9,1282],"outClusterList":[25],"clusters":{"genBasic":{"attributes":{}},"ssIasZone":{"attributes":{"iasCieAddr":"0x00124b00219fbf9a","zoneState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}}},"binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00219fbf9a","endpointID":1}],"configuredReportings":[{"cluster":1,"attrId":33,"minRepIntval":3600,"maxRepIntval":65000,"repChange":0,"manufacturerCode":null}],"meta":{}}},"appVersion":3,"stackVersion":2,"hwVersion":1,"dateCode":"20150330","zclVersion":1,"interviewCompleted":true,"meta":{"configured":543112114},"lastSeen":1724769702139}
      {"id":98,"type":"EndDevice","ieeeAddr":"0x005043c90335690f","nwkAddr":13072,"manufId":48042,"manufName":"Heiman","powerSource":"Battery","modelId":"SMOK_YDLV10","epList":[1],"endpoints":{"1":{"profId":260,"epId":1,"devId":1026,"inClusterList":[0,3,1280,1,9,1282],"outClusterList":[25],"clusters":{"genBasic":{"attributes":{"modelId":"SMOK_YDLV10","manufacturerName":"Heiman","powerSource":3,"zclVersion":1,"appVersion":3,"stackVersion":2,"hwVersion":1,"dateCode":"20150330"}},"ssIasZone":{"attributes":{"iasCieAddr":"0x00124b00219fbf9a","zoneState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":200}}},"binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00219fbf9a","endpointID":1}],"configuredReportings":[{"cluster":1,"attrId":33,"minRepIntval":3600,"maxRepIntval":65000,"repChange":0,"manufacturerCode":null}],"meta":{}}},"appVersion":3,"stackVersion":2,"hwVersion":1,"dateCode":"20150330","zclVersion":1,"interviewCompleted":true,"meta":{"configured":543112114},"lastSeen":1724798743233}
      {"id":99,"type":"Router","ieeeAddr":"0x005043c903387f7e","nwkAddr":44582,"manufId":48042,"manufName":"Heiman","powerSource":"Battery","modelId":"SMOK_YDLV10","epList":[1],"endpoints":{"1":{"profId":260,"epId":1,"devId":1026,"inClusterList":[0,3,1280,1,9,1282],"outClusterList":[25],"clusters":{"genBasic":{"attributes":{}},"ssIasZone":{"attributes":{"iasCieAddr":"0x00124b00219fbf9a","zoneState":1}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":157}}},"binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b00219fbf9a","endpointID":1}],"configuredReportings":[{"cluster":1,"attrId":33,"minRepIntval":3600,"maxRepIntval":65000,"repChange":0,"manufacturerCode":null}],"meta":{}}},"appVersion":3,"stackVersion":2,"hwVersion":1,"dateCode":"20150330","zclVersion":1,"interviewCompleted":true,"meta":{"configured":543112114},"lastSeen":1724833299891}
      Auffällig war, dass die "Router" Rauchmelder sich 2 alle ca. 2 Minuten neu announcen.
      2024-08-28 10:25:40.571 - info: zigbee.0 (1605788) Device '0x005043c903387f7e' announced itself
      2024-08-28 10:27:41.075 - info: zigbee.0 (1605788) Device '0x005043c903387f7e' announced itself
      2024-08-28 10:29:41.607 - info: zigbee.0 (1605788) Device '0x005043c903387f7e' announced itself
      Die Meldung hat anfangs nicht gestört, allerdings war die Batterie des Rauchmelders schon nach einer Woche leer.
      Die beiden Rauchmelder wurden schon mehrfach gepairt, sowohl mit als auch mit Löschen.
      Der Rauchmelder kann sich auch selber aus dem System löschen, das wurde auch getestet, leider auch ohne Erfolg.
      Im Info Dialog weicht nur die Eigenschaft type voneinander ab.
      Zigbee Adapter Version : "1.10.3"
      Ich habe mich noch nicht getraut, die beiden Router Rauchmelder in der shepherd.db händisch zu editieren. Gibt es ggf. Tipps, wie das Falsche Erkennen verhindert werden kann oder der Device-Type anderweitig geändert werden kann?
      • Asgothian
        Asgothian Developer @Franko1278 last edited by
        @franko1278 sagte in Zigbee Batterie EndDevice als Router in shepherd.db:
        Nein - die Anbindung hängt davon ab was die Firmware des Gerätes meldet. Es ist zu prüfen ob besagte Geräte eine andere Firmware haben. Auch das Sendeverhalten ist vom Koordinator aus kaum zu beeinflussen, auch das macht die Firmware des Gerätes
        A.
          @asgothian in den Geräteinformationen sind die Geräte gleich, bis auf das Attribut type. Ich habe alle 4 zusammen gekauft, sodass es unwahrscheinlich ist, dass die Firmware verschieden ist.
          Leider kann ich die Firmware nicht auslesen, bekomme die Fehlermeldung:
          undefined "attributes.map is not a function"
          wenn ich es in der Konfiguration unter Entwickler versuche wie im Beispiel die die FW auszulesen.
          • Asgothian
            Asgothian Developer @Franko1278 last edited by Asgothian
            @franko1278 dafür brauchst du die version 1.10.5 von GitHub, dann sollte es gehen
            ansonsten kannst du auf zigbee2mqtt.io schauen ob da jemand was geschrieben hat das man die Geräte "umschalten" kann. Der Eintrag in der shepherd.db ist nicht relevant.
            A.
