    5. Fehlermeldung beim ansteuern der Torsteuerung
      Balu 0 last edited by Homoran
      Hallo liebe Logiker,
      mein vorhaben klappt soweit, das tor fährt.
      Leider bekomme ich folgende Felermeldungen bei beinen Skripten :
      Zeit
      debug
      Nachricht
      javascript.0
      2024-09-02 18:46:59.607	info	State value to set for "openknx.0.Hausen.Packstation_.Hallentor_Motor_Auf_ZU_" has to be type "boolean" but received type "number"
      javascript.0
      2024-09-02 18:46:59.597	warn	at processImmediate (node:internal/timers:466:21)
      javascript.0
      2024-09-02 18:46:59.596	warn	at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5909:56)
      javascript.0
      2024-09-02 18:46:59.595	warn	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
      javascript.0
      2024-09-02 18:46:59.594	warn	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1266:38)
      javascript.0
      2024-09-02 18:46:59.594	warn	at Object.<anonymous> (script.js.Hallentor.Hallentor_Auf:4:3)
      javascript.0
      2024-09-02 18:46:59.593	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1740:20)
      javascript.0
      2024-09-02 18:46:59.590	warn	You are assigning a number to the state "openknx.0.Hausen.Packstation_.Hallentor_Motor_Auf_ZU_" which expects a boolean. Please fix your code to use a boolean or change the state type to number. This warning might become an error in future versions.
      web.0
      2024-09-02 18:46:59.583	info	State value to set for "0_userdata.0.Hallentor.Hallentor_Normal_Auf_" has to be stringified but received type "boolean"
      admin.0
      2024-09-02 18:46:34.755	info	<== Disconnect system.user.admin from ::ffff:192.168.168.137 javascript
      admin.0
      javascript.0
      2024-09-02 18:46:28.742	info	State value to set for "openknx.0.Hausen.Packstation_.Hallentor_Motor_Auf_ZU_" has to be type "boolean" but received type "number"
      javascript.0
      2024-09-02 18:46:28.732	warn	at processImmediate (node:internal/timers:466:21)
      javascript.0
      2024-09-02 18:46:28.731	warn	at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5909:56)
      javascript.0
      2024-09-02 18:46:28.731	warn	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
      javascript.0
      2024-09-02 18:46:28.730	warn	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1266:38)
      javascript.0
      2024-09-02 18:46:28.730	warn	at Object.<anonymous> (script.js.Hallentor.Hallentor_Zu:4:3)
      javascript.0
      2024-09-02 18:46:28.729	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1740:20)
      javascript.0
      2024-09-02 18:46:28.725	warn	You are assigning a number to the state "openknx.0.Hausen.Packstation_.Hallentor_Motor_Auf_ZU_" which expects a boolean. Please fix your code to use a boolean or change the state type to number. This warning might become an error in future versions.
      Ich habe folgenden Datenpunkt erstellt um ihn mit einem Button aus Vis mit true zu Aktualiesieren :
        "common": {
          "name": "Hallentor Normal Auf ",
          "desc": "Manuell erzeugt",
          "role": "state",
          "type": "object",
          "read": true,
          "write": true
        "type": "state",
        "native": {},
        "user": "system.user.admin",
        "ts": 1725295353606,
        "_id": "0_userdata.0.Hallentor.Hallentor_Normal_Auf_",
        "acl": {
          "object": 1636,
          "state": 1636,
          "owner": "system.user.admin",
      Der datenpunkt der für auf und ab zuständig ist ist der hier :
        "_id": "openknx.0.Hausen.Packstation_.Hallentor_Motor_Auf_ZU_",
        "type": "state",
        "common": {
          "type": "boolean",
          "read": true,
          "write": true,
          "desc": "Basetype: 1-bit value",
          "name": "Hallentor Motor Auf ZU ",
          "role": "switch",
          "states": {
            "0": "Up",
            "1": "Down"
        "native": {
          "address": "0/5/3",
          "answer_groupValueResponse": false,
          "autoread": true,
          "bitlength": 1,
          "dpt": "DPT1.008",
          "valuetype": "basic"
        "from": "system.adapter.openknx.0",
        "ts": 1723577363143,
        "acl": {
          "object": 1636,
          "state": 1636,
      Ich hoffe Ihr könnt mir helfen.
      hab da ewig rumgetan währe schön wen die Fehlermeldung auch noch weg währe.
      Balu
        paul53 @Balu 0 last edited by paul53
        @balu-0 sagte: You are assigning a number to the state "openknx.0.Hausen.Packstation_.Hallentor_Motor_Auf_ZU_" which expects a boolean. Please fix your code to use a boolean or change the state type to number. This warning might become an error in future versions.
        Du schreibst eine Zahl (number) in einen Datenpunkt vom Typ "Logikwert".
        @balu-0 sagte in Fehlermeldung beim ansteuern der Torsteuerung:
        "type": "object"
        ist falsch. Typ muss "boolean" sein, wenn mit true gesteuert werden soll.
          Homoran Global Moderator Administrators @Balu 0 last edited by
          dann darf
          "type": "object",
          nicht sein.
          der typ muss Logikwert (bool) sein
          "type": "boolean",
          kann man machen.
          Dann muss auf=true und ab = false sein oder umgekehrt.
          dein Skript schreibt jefoch eine Zahl in
                                  2024-09-02 18:46:59.590	warn	You are assigning a number to the state "**openknx.0.Hausen.Packstation_.Hallentor_Motor_Auf_ZU_"** which expects a boolean. Please fix your code to use a boolean or change the state type to number. This warning might become an error in future versions.
          da muss ein bool gesendet werden.
          javascript.0
          was steht denn in Zeile 4?
            Balu 0 @Homoran last edited by
            danke mal wieder für eure Hilfe.
            ich tue mir gerade ein wenig schwehr.
            Muss ich nun einen oder 2 Datenpunkte ändern.
            Der Datenpunkt vom TOR :
              "common": {
                "role": "state",
                "type": "object",
                "read": true,
                "write": true
              "type": "state",
              "native": {},
              "acl": {
                "object": 1636,
                "state": 1636,
            Copy to Clipboard
              "type": "state",
              "common": {
                "type": "boolean",
                "read": true,
                "write": true,
                "role": "switch",
                "states": {
                  "0": "Up",
                  "1": "Down"
              "native": {
                "address": "0/5/3",
                "autoread": true,
                "bitlength": 1,
                "dpt": "DPT1.008",
              "acl": {
                "object": 1636,
                "state": 1636,
            Hat irgendwie nicht auf true und false reagiert.
            Ich würde jetz wenn ich euch richtig verstanden habe im dropdown in meinem erstellten datenpunkt von objekt auf boolean umstellen ?
              @balu-0 ja
                ok hab ich geändert fehlermeldungen bestehen weiterhin tor fährt noch wie es soll :
                javascript.0
                2024-09-02 21:36:28.583	info	State value to set for "openknx.0.Hausen.Packstation_.Hallentor_Motor_Auf_ZU_" has to be type "boolean" but received type "number"
                javascript.0
                2024-09-02 21:36:28.567	warn	at processImmediate (node:internal/timers:466:21)
                javascript.0
                2024-09-02 21:36:28.567	warn	at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5909:56)
                javascript.0
                2024-09-02 21:36:28.566	warn	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
                javascript.0
                2024-09-02 21:36:28.565	warn	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1266:38)
                javascript.0
                2024-09-02 21:36:28.565	warn	at Object.<anonymous> (script.js.Hallentor.Hallentor_Auf:4:3)
                javascript.0
                2024-09-02 21:36:28.564	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1740:20)
                javascript.0
                2024-09-02 21:36:28.560	warn	You are assigning a number to the state "openknx.0.Hausen.Packstation_.Hallentor_Motor_Auf_ZU_" which expects a boolean. Please fix your code to use a boolean or change the state type to number. This warning might become an error in future versions.
                Jetzt soll ich noch 0 und 1 in true und false umändern oder ?
                Hier noch mei skript..
                sind 2 skripte und auch 2 datenpunkte
                einer für rauf einer für runter
                  @balu-0 sagte: Jetzt soll ich noch 0 und 1 in true und false umändern oder ?
                  Richtig. Der Datenpunkt ist vom Typ "boolean". Den hat der KNX-Adapter so erzeugt, aber mit falschen "states".
                    Balu 0 @paul53 last edited by Balu 0
                    ich habe gesehen das ich den Datenpunkt selber auch umstellen kann.
                    soll ich das machen ?
                      @balu-0 sagte: ich habe gesehen das ich den Datenpunkt selber auch umstellen kann.
                      Der KNX-Datenpunkt wird vom Adapter erzeugt und deine Änderungen werden beim nächsten Neustart der Instanz wahrscheinlich wieder überschrieben.
                      Den eigenen Datenpunkt unter "0_userdata.0" hast du in der Hand.
                        Perfekt Läuft !!
                        Danke euch !!
                          Balu 0 @Balu 0 last edited by
                          @balu-0
                          Ich würde gerne über einen weiteren button das Hallentor bis zu einer bestimmten höhe fahren.
                          als Referenz hätte ich diesen Datenpunkt.
                            "_id": "openknx.0.Hausen.Packstation_.Hallentor_Status_Teilposition",
                            "type": "state",
                            "common": {
                              "desc": "Basetype: 8-bit unsigned value",
                              "min": 0,
                              "max": 100,
                              "name": "Hallentor Status Teilposition",
                              "read": true,
                              "role": "state",
                              "type": "number",
                              "unit": "%",
                              "write": true
                            "native": {
                              "address": "0/5/8",
                              "autoread": true,
                              "bitlength": 8,
                              "dpt": "DPT5.001",
                            "ts": 1723577363214,
                            "acl": {
                              "object": 1636,
                              "state": 1636,
                          Allerdings kommt es mir so vor als wurde der nicht sauber alle % sauber durchgehend anzeigen.
                          Ich denke es sollte deshalb lauten wenn das Tor größer als 50 % ist stoppen.
                          Bring das Skript nich zusammen hoffe ihr wollt mir helfen.
                          Balu
                            @balu-0 sagte: diesen Datenpunkt.
                            Dann kennt man schonmal die Position und kann mit der Laufzeit arbeiten.
                            Der Trigger rechts dient nur zur Kontrolle, ob die Zeiten passen.
                            Wenn ich lese
                                "write": true
                            , gehe ich normalerweise davon aus, dass man darüber die Position vorgeben kann, was aber wohl nicht der Fall ist?
                            Wenn das Anfahren 50 % auch aus gestoppten Positionen heraus erfolgen soll:
                              ja richtig das tor läst sich mit der % angabe leider nicht steuern.
                              Eine frage.
                              Da der button auf einen Tablett auch mit Pfeil nach oben gekennzeichnet ist,
                              währe es nicht gut wenn das tor ( wenn es über den 50 % ist ) nach unten fährt.
                              würde es auch gehen das es nur aus anderen stopps nach oben fährt ?
                              Super skript mal wieder Danke !!
                                @balu-0 sagte: währe es nicht gut wenn das tor ( wenn es über den 50 % ist ) nach unten fährt.
                                Das soll es im Skript machen (bei über 55 % Ausgangsposition).
                                Ich verstehe die Frage nicht.
                                  also ich verstehe es so das das zweite skript es möglich macht das das tor aus allen möglichen Positionen auf die Teilöffnung fährt.
                                  Wenn beispielsweise das Tor ganz offen steht würde es zu fahren.
                                  Es soll aber nicht nach unten fahren sondern nur nach oben.
                                  Wenn 55 die sollposition ist...
                                  und es in einer position von 0 bis 44 ist soll es hoch fahren.
                                  bei einer Position von 56 bis 100 soll es nicht runterfahren.
                                    @balu-0 sagte: bei einer Position von 56 bis 100 soll es nicht runterfahren.
                                    Dann lasse den Teil einfach weg.
                                      OK Habe es verstanden
                                      trotzdem läufts irgendwie nicht.
                                      kannst du mal drüber schauen ?
                                        und irgendwie wie läufts?
                                          Balu 0 @Homoran last edited by Balu 0
                                          HÄ ? 🙂
                                          es fährt jedenfalls nicht
                                            @balu-0 sagte: es fährt jedenfalls nicht
                                            Ohne Steuerung des Datenpunktes für "Auf" kann es auch nicht fahren.
                                            943
