    5. [gel.] Script: Adresse ermitteln -> axios ändern in httpget
    • bahnuhr
      bahnuhr Forum Testing Most Active last edited by bahnuhr
      habe folgendes Script mit axios:
      var latitude = 48.46567;
      var longitude = 9.7107;
      const axios = require('axios');
      updateLocation(latitude, longitude);
      async function updateLocation(latitude, longitude) {
          const url = `https://nominatim.openstreetmap.org/reverse?lat=${latitude}&lon=${longitude}&format=json`;
          const response = await axios.get(url);
          if (response && response.data.display_name) {
            log (response.data)
            log (response.data.display_name);
            return(response.data.display_name);
      Dies funktioniert auch einwandfrei. Nun möchte ich dieses umbauen um den httpget zu nutzen.
      Bekomme dies aber nicht hin. Ob async, await notwendig ist, weiß ich auch nicht genau.
      Meine Versuche endeten in Fehlermeldung, ala:
      script.js.Scripte.System.Adresse: { statusCode: 403, data: '<html>\n' + '<head>\n' + '<title>Access blocked</title>\n' + '</head>\n' + '<body>\n' + '<h1>Access blocked</h1>\n' + '\n' + '<p>You have been blocked because you have violated the\n' + '<a href="https://operations.osmfoundation.org/policies/nominatim/">usage policy</a>\n' + "of OSM's Nominatim geocoding service. Please be aware that OSM's resources are\n" + 'limited and shared between many users. The usage policy is there to ensure that\n' + 'the service remains usable for everybody.</p>\n' + '\n' + '<p>Please review the terms and make sure that your\n' + 'software adheres to the terms. You should in particular verify that you have set a\n' + '<b>custom HTTP referrer or HTTP user agent</b> that identifies your application, and\n' + 'that you are not overusing the service with massive bulk requests.</p>\n' + '\n' + '<p>If you feel that this block is unjustified or remains after you have adopted\n' + 'your usage, you may contact the Nominatim system administrator at\n' + 'nominatim@openstreetmap.org to have this block lifted.</p>\n' + '</body>\n' + '</head>\n', headers: Object [AxiosHeaders] { server: 'nginx', date: 'Wed, 04 Sep 2024 12:58:37 GMT', 'content-type': 'text/html', 'content-length': '941', connection: 'keep-alive', 'keep-alive': 'timeout=20', etag: '"64c63660-3ad"' }, responseTime: 147 }
      Bitte mir mal auf die Sprünge helfen.
      Danke.
      Homoran 3 Replies Last reply Reply Quote 0
        @bahnuhr sagte in Script: Adresse ermitteln -> axios ändern in httpget:
        statusCode: 403,
        not permitted!
        • bahnuhr
          bahnuhr Forum Testing Most Active @Homoran last edited by
          Ja, das ist klar.
          Aber warum ?
          mit axios geht es.
          mit httpget geht es nicht.
          Kann ich gar nicht glauben.
            You have been blocked because you have violated the "https://operations.osmfoundation.org/policies/nominatim/
            ich fürchte du hast es zu oft versucht
              make sure that your 'software adheres to the terms. You should in particular verify that you have set a custom HTTP referrer or HTTP user agent that identifies your application, and 'that you are not overusing the service with massive bulk requests
                fastfoot @bahnuhr last edited by
                @bahnuhr warum überhaupt umstellen? httpGet nutzt unter der Haube eh axios, löscht aber den default user-agent den axios ohne Angabe desselben wohl setzt. Anyway:
                    const response = await httpGetAsync(url, { headers: { "user-agent": 'ioBroker script' } });
                    const data = JSON.parse(response.data);
                    if (response && data) {
                        log(data)
                        log(data.display_name);
                        return (data.display_name);
                • haus-automatisierung
                  haus-automatisierung Developer Most Active @fastfoot last edited by
                  @fastfoot Ich meine hier gab es irgendwo mal Scripts, welche bei jeder Anfrage einen anderen User-Agent generiert haben (um zu verhindern, dass OpenStreeMap einen aussperrt?). Scheint ja ein recht spezielles Thema zu sein.
                  Ro75 DJMarc75 F 3 Replies Last reply Reply Quote 1
                  • Ro75
                    Ro75 @haus-automatisierung last edited by
                    das ist meine Lösung für einen Random-USER-Agent
                    function UAChrome() {
                        const Plattform = Math.floor(Math.random() * 2)
                        const chromeVersion = Math.floor(Math.random() * 20) + 60;
                        const webkitVersion = Math.floor(Math.random() * 700) + 500;
                        const osPlatform = Plattform == 1 ? 'Win64; x64' : 'Macintosh; Intel Mac OS X 10_15_0';
                        const userAgent = `Mozilla/5.0 (${osPlatform}) AppleWebKit/${webkitVersion}.36 (KHTML, like Gecko) Chrome/${chromeVersion}.0.3163.100 Safari/${webkitVersion}.36`;
                        return userAgent;
                    function UAFirefox() {
                        const firefoxVersion = Math.floor(Math.random() * 5) + 55;
                        const geckoVersion = Math.floor(Math.random() * 30) + 20100101;
                        const userAgent = `Mozilla/5.0 (${osPlatform}; rv: ${firefoxVersion}.0) Gecko/${geckoVersion} Firefox/${firefoxVersion}.0`;
                        return userAgent;
                    function UASafari() {
                        const safariVersion = Math.floor(Math.random() * 5) + 10;
                        const userAgent = `Mozilla/5.0 (${osPlatform}) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/${safariVersion}.1.15 Safari/605.1.15`;
                        return userAgent;
                    function UAAndroid() {
                        const androidVersion = Math.floor(Math.random() * 5) + 5;
                        const osPlatform = `Linux; Android ${androidVersion}.${Math.floor(Math.random() * 10)}; en-us; Nexus 6 Build/LYZ28M) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/${chromeVersion}.0.3163.98 Mobile Safari/${webkitVersion}.36`;
                        const userAgent = `Mozilla/5.0 (${osPlatform}`;
                        return userAgent;
                    function UAIos() {
                        const iosVersion = Math.floor(Math.random() * 5) + 9;
                        const safariVersion = Math.floor(Math.random() * 5) + 600;
                        const osPlatform = `CPU iPhone OS ${iosVersion}_${Math.floor(Math.random() * 10)} like Mac OS X) AppleWebKit/${webkitVersion}.60 (KHTML, like Gecko) Version/${safariVersion}.0 Mobile/15E148 Safari/${webkitVersion}.60`;
                        return userAgent;
                    function RUA() {
                        const UA = Math.floor(Math.random() * 4)
                        var UserAgent = '';
                        if (UA == 0) {
                            UserAgent = UAChrome();
                        } else if (UA == 1) {
                            UserAgent = UAFirefox();
                        } else if (UA == 2) {
                            UserAgent = UASafari();
                        } else if (UA == 3) {
                            UserAgent = UAAndroid();
                        } else if (UA == 4) {
                            UserAgent = UAIos();
                        return UserAgent;
                    console.log(RUA());
                    @homoran sagte in Script: Adresse ermitteln -> axios ändern in httpget:
                    Maximal pro Tag 2500 Aufrufe.
                    Ro75.
                    • DJMarc75
                      DJMarc75 @haus-automatisierung last edited by
                      @haus-automatisierung sagte in Script: Adresse ermitteln -> axios ändern in httpget:
                      ja, irgendwo war da was - und daraus hab ich mir ein Blockly mit Funktion gebaut.
                      Ich selbst kann kein JS aber ich stelle mal den generierten JS-Code aus meinem Blockly rein:
                      var lon, lat, sDP, json, strasse, hausnummer, plz, stadt;
                      // Beschreibe diese Funktion …
                      async function osmResolve(lon, lat, sDP) {
                              return userAgent;
                              return userAgent;
                              return userAgent;
                              return userAgent;
                          function UAIos() {
                              return userAgent;
                          function RUA() {
                              const UA = Math.floor(Math.random() * 4);
                              if (UA == 0) {
                                  return UAChrome();
                                  return UAFirefox();
                                  return UASafari();
                                  return UAAndroid();
                                  return UAIos();
                              return '';
                          httpGet(
                              `https://nominatim.openstreetmap.org/reverse?format=geojson&lat=${lat}&lon=${lon}`,
                                  timeout: 15000,
                                  headers: {
                                      'User-Agent': RUA(),
                              (err, response) => {
                                  if (!err  && response.statusCode == 200) {
                                      const info = JSON.parse(response.data);
                                      const address = info.features[0].properties.address;
                                      setState(sDP, JSON.stringify(address), true);
                                  } else {
                                      console.error(`Nominatim: ${response.statusCode}`);
                      on({ id: [].concat(['0_userdata.0.GPS.Marc.Adressabfrage']), change: 'ne' }, async (obj) => {
                        let value = obj.state.val;
                        await osmResolve(getState('0_userdata.0.GPS.Marc.lon').val, getState('0_userdata.0.GPS.Marc.lat').val, '0_userdata.0.GPS.Marc.AdresseJson');
                        json = getState('0_userdata.0.GPS.Marc.AdresseJson').val;
                        strasse = getAttr(json, 'road');
                        hausnummer = getAttr(json, 'house_number');
                        plz = getAttr(json, 'postcode');
                        stadt = getAttr(json, 'town');
                        setState('0_userdata.0.GPS.Marc.Adresse' /* Adresse */, ([strasse,' ',hausnummer,', ',plz,' ',stadt].join('')), true);
                      und während ich schreibe war @Ro75 schneller 😉
                        fastfoot @haus-automatisierung last edited by
                        @haus-automatisierung also hier lag das Problem nur daran dass httpGet gar keinen user-agent mitsendet. Mit axios wurde er ja auch nie blockiert und das ändert den user-agent ja nicht. Ist halt alles schwierig für Nichtprogrammierer, aber immerhin gibt es ja das Forum...
                          @fastfoot sagte in Script: Adresse ermitteln -> axios ändern in httpget:
                          Natürlich wird im Standard ein Agent gesendet. Siehst Du ja im verbose mode sofort.
                            @haus-automatisierung upps, meine Annahme beruhte darauf dass ich ohne Angabe eines UA sofort gesperrt wurde, nach dem Setzen eines beliebigen UA (siehe codeschnipsel) ich aber sofort eine Antwort bekam. Tja, wieder was gelernt, man(ich!) sollte aus Schlussfolgerungen keine Tatsachen ableiten. Sorry for that! Dann bleibt nur die Vermutung dass der Inhalt des UA geprüft wird
                            haus-automatisierung bahnuhr 2 Replies Last reply Reply Quote 1
                              @fastfoot Alles gur. Ich wäre schon zufrieden, wenn viele Aussagen im Forum bei Unsicherheit als Frage formuliert würden 😉
                              • bahnuhr
                                bahnuhr Forum Testing Most Active @fastfoot last edited by
                                war bei mir auch so. Und 2500 Abfragen hab ich nie erreicht.
                                Ablehnung kam sofort.
                                @DJMarc75
                                @fastfoot
                                @Homoran
                                @Ro75
                                Danke an alle für die Antworten. Damit kann ich was anfangen.
                                mfg
                                Dieter
                                • OliverIO
                                  OliverIO @bahnuhr last edited by
                                  @bahnuhr
                                  Zum Testen, welche headers und sonstige Daten dein request so alles übermittelt, kannst du dir hier eine individuelle Server Adresse generieren lassen. Auf der Seite dann, siehst du dann die requests mit all seinen Daten Und headers
                                  https://webhook.site/
                                  Wenn du dann beide Informationen hast, kann man vergleichen, wo die Unterschiede liegen und ob man die eventuell über die Parameter von HTTPget beeinflussen kann.
                                  • bahnuhr
                                    bahnuhr Forum Testing Most Active @OliverIO last edited by
                                    @oliverio sagte in Script: Adresse ermitteln -> axios ändern in httpget:
                                    starker Text.
                                    Hab ich so auf Anhieb nicht verstanden.
                                    Komm ich aber noch dahinter 😉
                                    Danke dir.
                                    • OliverIO
                                      @bahnuhr
                                      Axios oder httpget sendet Daten.
                                      Irgendwo wohl auch unterschiedlich, obwohl hinter httpget auch axios steht.
                                      Genau anhand diesem Unterschied wird der request aber abgelehnt.
                                      Das es der User Agent String ist ist nur eine Vermutung. Serverbetreiber geben meistens nicht bekannt anhand welchen Kriterien sie ablehnen.
                                      Mit diesem Test findest du hoffentlich dann den Unterschied auch wirklich raus, weil du siehst, was am anderen Ende ankommt und nicht nur was du weg sendest.
                                      Ro75 F 2 Replies Last reply Reply Quote 1
                                      • bahnuhr
                                        So, habe mal als Muster das von @DJMarc75 genommen.
                                        Also ohne dieses async und await; aber mit random
                                        sieht so aus:
                                        var lat = 48.46567; var lon = 9.7107;
                                        var v_random = String(Math.floor(Math.random() * 100)); log (v_random);
                                            httpGet(`https://nominatim.openstreetmap.org/reverse?format=geojson&lat=${lat}&lon=${lon}`,
                                                { timeout: 15000, headers: { 'User-Agent': "iob" + v_random, }, },
                                                    if (!err  && response.statusCode == 200) { const info = JSON.parse(response.data); const address = info.features[0].properties.address;
                                                        log ("Str= " + address.road); log ("Nr= " + address.house_number);
                                                        log ("Plz= " + address.postcode); log ("Ort= " + address.municipality);
                                                    } else { console.error(`Nominatim: ${response.statusCode}`); }
                                        • Ro75
                                          Ro75 @OliverIO last edited by Ro75
                                          Da bin ich für mich weiter. Für mich steht es fest, dass der USER-Agent zu 95% daran beteiligt ist. Ich hatte, als ich gesperrt wurde mein Abfrage-URL in meinen Windows-Browser eingegeben und da ging es. Im iobroker wiederholt mit dem Ergebnis = NO.
                                          Also mal die IP gewechselt. Ein Teil war anders, aber selbiges Ergebnis 1xJa und 1xNein. Nochmal die IP gewechselt. Komplett anderer Bereich, aber auch hier war das Ergebnis identisch.
                                          Für mich steht also fest, die prüfen IP ind Verbindung mit USER-Agent und Anzahl Aufrufe.
                                          Ich wechsel aller 6 Stunden den USER-Agent für Nominatim.
                                          httpGet('https://nominatim.openstreetmap.org/reverse?format=geojson&lat='+lat+'&lon='+lon, { timeout: 15000,"headers":{"User-Agent":"'" + RUA() + "'"}}, (error, response) => {
                                          Ro75.
                                            fastfoot @OliverIO last edited by
                                            @oliverio also der einzige Unterschied auf der Seite ist der UA. axios sendet da als default nur axios/1.7.7 während httpGet da einen UA sendet der für mich wie der eines Browsers aussieht. Ich sehe keinen Grund den UA zu wechseln wie es einige hier tun, das ist nur der Versuch Restriktionen zu umgehen und schadet somit letztlich der Community
                                            OliverIO bahnuhr 2 Replies Last reply Reply Quote 0
                                            2623
