    4. Regex liefert falschen Wert
      ck_coke last edited by
      ich habe ein paar (Anfänger)-Schwierigkeiten mit einer Regex und könnte etwas Hilfe gebrauchen.
      Folgendes ist das Ergebnis:
      javascript.0	22:24:00.130	info	script.js.common.Balkonkraftwerk_Shelly_Cloud_API: Found match, group 0: "total_power":-43.36,
      javascript.0	22:24:00.130	info	script.js.common.Balkonkraftwerk_Shelly_Cloud_API: Found match, group 1: -43.36
      javascript.0	22:24:00.130	info	script.js.common.Balkonkraftwerk_Shelly_Cloud_API: Found match, group 2: .36
      javascript.0	22:24:00.130	info	script.js.common.Balkonkraftwerk_Shelly_Cloud_API: {"isok":true,"data":{"online":true,"device_status":{"has_update":false,"fs_free":155118,"unixtime":1725530007,"emeter_n":{"current":0,"ixsum":0.9,"mismatch":false,"is_valid":false},"wifi_sta":{"connected":true,"ssid":"....","ip":"192.168.178.52","rssi":-72},"total_power":-43.36,"ct_calst":0,"relays":[{"ison":true,"has_timer":false,"timer_started":0,"timer_duration":0,"timer_remaining":0,"overpower":false,"is_valid":true,"source":"cloud"}],"v_data":1,"uptime":885115,"fs_size":233681,"_updated":"2024-09-05 20:16:00","cloud":{"enabled":true,"connected":true},"fs_mounted":true,"ram_free":32500,"actions_stats":{"skipped":0},"emeters":[{"power":-9.73,"pf":-0.1,"current":0.44,"voltage":233.55,"is_valid":true,"total":0,"total_returned":7844.1},{"power":-33.63,"pf":-0.62,"current":0.23,"voltage":235.21,"is_valid":true,"total":2419,"total_returned":28747.5},{"power":0,"pf":0,"current":0.44,"voltage":234.18,"is_valid":true,"total":10489.3,"total_returned":0.1}],"mac":"483FDAC3902E","mqtt":{"connected":false},"cfg_changed_cnt":0,"serial":62007,"getinfo":{"fw_info":{"device":"shellyem3-483FDAC3902E","fw":"20230913-114244/v1.14.0-gcb84623"}},"time":"22:16","update":{"status":"idle","has_update":false,"new_version":"20230913-114244/v1.14.0-gcb84623","old_version":"20230913-114244/v1.14.0-gcb84623","beta_version":"20231107-165007/v1.14.1-rc1-g0617c15"},"ram_total":49920}}} - % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 100 1500 100 1383 100 117 15896 1344 --:--:-- --:--:-- --:--:-- 17441
      javascript.0	22:24:00.130	info	script.js.common.Balkonkraftwerk_Shelly_Cloud_API: Leistung: 3
      So habe ich mir das Ganze zusammengebastelt:
      schedule("*/1 * * * *", function () {
          exec('curl -X POST https://shelly-89-eu.shelly.cloud/device/status -d "id=483fdac3902e&auth_key=MjBjN2JjdWlkB12AE36D401E9C6EC6573933F664EA9B25923B90241D5720122CC428B8........."',
      		function (error, stdout, stderr) {
                  const regex = /"total_power":(-?\d+(\.\d+)?),/gm;
                  const str = stdout;
                  let m;
                  while ((m = regex.exec(str)) !== null) {
                      // This is necessary to avoid infinite loops with zero-width matches
                      if (m.index === regex.lastIndex) {
                          regex.lastIndex++;
                      // The result can be accessed through the `m`-variable.
                      m.forEach((match, groupIndex) => {
                          console.log(`Found match, group ${groupIndex}: ${match}`);
                              if (groupIndex=1) {
                  P = match[1] // im match stehen die aktuelle parser ergebnisse ich brauch aber nur das der gruppe 1
                  log(stdout + " - " + stderr);
                  console.log('Leistung: ' + P);
      Die regex scheint wie man sieht zu funktionieren nur wird nicht das richtige verwendet.
      Ich hätte gerne group 1 als "Ergebnis". Wie bekomme ich das hin?
      Homoran M haus-automatisierung 3 Replies Last reply Reply Quote 0
        Homoran Global Moderator Administrators @ck_coke last edited by
        @ck_coke sagte in Regex liefert falschen Wert:
        ist das nicht [0]?
        kenne nich mit regex in js nicht aus
          MCU @ck_coke last edited by
          @ck_coke
          const regex = /"total_power":(-?\d+(\.\d+)?)/gm;     /* , entfernt */
          let m;
          m = regex.exec(str)  /* m ist ja "total_power":-43.36 */
          P = m.split(':')[1]
            ck_coke @MCU last edited by ck_coke
            @mcu
            Error in callback: TypeError: m.split is not a function
            M F 2 Replies Last reply Reply Quote 0
              @ck_coke Dann muss man vorher noch aus m einen String machen.
              m = String(m)
              P= m.split ......
                fastfoot @ck_coke last edited by
                @ck_coke
                let m;
                if ((m = regex.exec(str)) != null)
                    log('Leistung: ' + m[1])
                • haus-automatisierung
                  haus-automatisierung Developer Most Active @ck_coke last edited by
                  Warum überhaupt JSON-Strings mit einem regex auseinander nehmen?!
                    haus-automatisierung Developer Most Active @haus-automatisierung last edited by haus-automatisierung
                    Hier mal ein Beispiel-Script. Ohne exec, curl und regex 🙂
                    const server = 'https://shelly-67-eu.shelly.cloud';
                    const authKey = 'MTk3YjZhdWlkE6CD....';
                    const deviceId = 'b0b21c18d700';
                    httpPost(`${server}/device/status`,
                            auth_key: authKey,
                        (error, response) => {
                            if (!error) {
                                try {
                                    const obj = JSON.parse(response.data);
                                    // Daten extrahieren
                                } catch (e) {
                                    console.error(e);
                            } else {
                                console.error(error);
                    Du suchst ja scheinbar: obj.data.device_status.total_power.
                    C 1 Reply Last reply Reply Quote 2
                      ck_coke @haus-automatisierung last edited by
                      Vielen Dank! So ist es natürlich noch besser gelöst.
                        ck_coke @ck_coke last edited by ck_coke
                        Jetzt habe ich das Problem, dass es bei einem Gerät funktioniert und bei einem anderen
                        {"ack":true}
                        als Wert gesetzt wird.
                        So sieht das Skript aus:
                        schedule("*/10 * * * * *", function () {
                        const server = 'https://shelly-89-eu.shelly.cloud';
                        const authKey = 'XjBjN2JjdWlkB12AE36D401E9C6EC6573933F664EA9B25923B90241D5720122CC428B82EF7477624E84B517133E2';
                        const deviceId = 'a0a3b3e7d67c';
                                auth_key: authKey,
                                if (!error) {
                                    try {
                                        console.log(obj.data);
                                                   setState('0_userdata.0.Leistung-Entladen', obj.data.device_status.voltage, true);
                                    } catch (e) {
                                        console.error(e);
                                } else {
                        Folgendes bekomme ich im Log angezeigt:
                        javascript.0
                        	2024-09-09 20:34:40.074	info	script.js.common.Balkonkraftwerk.Skript_1: setForeignState(id=0_userdata.0.Leistung-Entladen, state={"val":{"ack":true},"ack":true,"ts":1725906880074,"q":0,"from":"system.adapter.javascript.0","lc":1725906880074,"c":"script.js.common.Balkonkraftwerk.Skript_1"})
                        javascript.0
                        	2024-09-09 20:34:40.074	info	script.js.common.Balkonkraftwerk.Skript_1: { online: true, device_status: { sys: { available_updates: [Object], mac: 'A0A3B3E7D67C', restart_required: false, time: '11:48', unixtime: 1725788939, uptime: 3, ram_size: 246876, ram_free: 134944, fs_size: 458752, fs_free: 122880, cfg_rev: 19, kvs_rev: 0, schedule_rev: 10, webhook_rev: 0, reset_reason: 1 }, ts: 1725906873.77, plugs_ui: {}, id: 'a0a3b3e7d67c', code: 'SNPL-00112EU', ws: { connected: false }, wifi: { sta_ip: '192.168.33.67', status: 'got ip', ssid: 'ShellyPlusPlugS-E465B8B3A57C', rssi: -29, ap_client_count: 0 }, mqtt: { connected: false }, serial: 3566, ffs: { ts: 0 }, 'switch:0': { id: 0, current: 0.021, source: 'SHC', output: true, apower: 0, voltage: 232.9, aenergy: [Object], temperature: [Object] }, cloud: { connected: true }, _updated: '2024-09-09 18:34:34', ble: {} } }
                        javascript.0
                        	2024-09-09 20:34:40.074	info	script.js.common.Balkonkraftwerk.Skript_1: httpPost(url=https://shelly-89-eu.shelly.cloud/device/status, responseTime=66ms)
                        javascript.0
                        	2024-09-09 20:34:40.007	info	script.js.common.Balkonkraftwerk.Skript_1: httpPost(config={"method":"post","url":"https://shelly-89-eu.shelly.cloud/device/status","responseType":"text","responseEncoding":"utf8","timeout":2000,"headers":{"User-Agent":"Mozilla/5.0 (X11; Linux i686; rv:109.0) Gecko/20100101 Firefox/121.0"},"data":{"id":"a0a3b3e7d67c","auth_key":"XjBjN2JjdWlkB12AE36D401E9C6EC6573933F664EA9B25923B90241D5720122CC428B82EF7477624E84B517133E2"}}, data=[object Object])
                        ```z
                          @ck_coke In deinem Scripts sind Klammerfehler. Das kann so gar nicht klappen. Da fehlt etwas.
                          voltage, true);
                            Das ist wohl beim hier ins Forum kopieren passiert.
                            Die Zeile sieht so aus:
                              Kann es daran liegen das der Datenpunkt hinter switch:0, also eine Ebene tiefer liegt?
                              Zumindest habe ich das nach Internetrechersche in anderen Foren so gesehen.
                                haus-automatisierung Developer Most Active @ck_coke last edited by haus-automatisierung
                                Ich hab das Thema JSON vs. Objekt in zig kostenlosen Inhalten super ausführlich erklärt.
                                Du musst schon den kompletten Pfad angeben. Im Falle von switch:0 muss das dann aber in eckige Klammern und kann nicht mit der einfachen Punkt-Notation erreicht werden.
                                obj.data.device_status['switch:0'].voltage
                                789
