    4. Logeinträge: Ping und Host.*
      tklein last edited by
      folgendes finde ich minütlich im Log:
      A:
      host.raspberrypi-iob 2024-09-09 16:46:36.674	error	instance system.adapter.ping.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.raspberrypi-iob 2024-09-09 16:46:36.674	error	Caught by controller[1]: at processImmediate (node:internal/timers:473:21)
      host.raspberrypi-iob 2024-09-09 16:46:36.674	error	Caught by controller[1]: at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:5378:38)
      host.raspberrypi-iob 2024-09-09 16:46:36.674	error	Caught by controller[1]: at AdapterClass.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:7535:23)
      host.raspberrypi-iob 2024-09-09 16:46:36.674	error	Caught by controller[1]: at Function.assertBoolean (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/validator.ts:275:19)
      host.raspberrypi-iob 2024-09-09 16:46:36.674	error	Caught by controller[1]: Error: Parameter "ack" needs to be of type "boolean" but type "object" has been passed
      host.raspberrypi-iob 2024-09-09 16:46:36.673	error	Caught by controller[0]: (Use `node --trace-warnings ...` to show where the warning was created)
      host.raspberrypi-iob 2024-09-09 16:46:36.673	error	Caught by controller[0]: (node:22777) ExperimentalWarning: The Fetch API is an experimental feature. This feature could change at any time
      B:
      ping.0 22777	2024-09-09 16:46:36.142	error	Parameter "ack" needs to be of type "boolean" but type "object" has been passed
      ping.0 22777	2024-09-09 16:46:36.141	error	Error: Parameter "ack" needs to be of type "boolean" but type "object" has been passed at Function.assertBool (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/validator.ts:275:19) at AdapterClass.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:7535:23) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:5378:38) at processImmediate (node:internal/timers:473:21)
      ping.0 22777	2024-09-09 16:46:36.139	error	uncaught exception: Parameter "ack" needs to be of type "boolean" but type "object" has been passed
      Was kann ich machen, damit es nicht mehr im Log steht?
      Node ist v18.0.0.
      Thomas
      Homoran mcm1957 2 Replies Last reply Reply Quote 0
        Homoran Global Moderator Administrators @tklein last edited by
        @tklein sagte in Logeinträge: Ping und Host.*:
        Node ist v18.0.0.
        und der Rest?
        Bitte iob diag in der Langfassung.
        T 2 Replies Last reply Reply Quote 0
        • mcm1957
          mcm1957 @tklein last edited by
          @tklein said in Logeinträge: Ping und Host.*:
          A:
          B:
          Node ist v18.0.0.
          Thomas
          Bitte putz mal deine Glaskugel und schau welche Versionen da installiert sind:
          adapter
          admin
          js-controller
          node
          o/s
            tklein @Homoran last edited by
            @homoran said in Logeinträge: Ping und Host.*:
            iob diag
            done:
            Skript v.2024-05-22
            *** BASE SYSTEM ***
               Static hostname: raspberrypi-iob
                     Icon name: computer
              Operating System: Raspbian GNU/Linux 10 (buster)
                        Kernel: Linux 5.10.103-v7l+
                  Architecture: arm
            Model           : Raspberry Pi 4 Model B Rev 1.2
            Docker          : false
            Virtualization  : none
            Kernel          : armv7l
            Userland        : 32 bit
            Systemuptime and Load:
             16:58:19 up 8 days, 21:50,  2 users,  load average: 2.45, 2.18, 2.51
            CPU threads: 4
            *** RASPBERRY THROTTLING ***
            Current issues:
            Previously detected issues:
            *** Time and Time Zones ***
                           Local time: Mon 2024-09-09 16:58:19 CEST
                       Universal time: Mon 2024-09-09 14:58:19 UTC
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            *** Users and Groups ***
            User that called 'iob diag':
            pi
            HOME=/home/pi
            GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
            iobroker
            HOME=/home/iobroker
            *** Display-Server-Setup ***
            Display-Server: false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Mem:           3.8G        2.4G        994M         33M        491M        1.3G
            Swap:           10G        2.0G        8.3G
            Total:          14G        4.3G        9.3G
            Active iob-Instances:   36
                     3837 M total memory
                     2351 M used memory
                     1508 M active memory
                     1201 M inactive memory
                      994 M free memory
                       89 M buffer memory
                      402 M swap cache
                    10239 M total swap
                     1953 M used swap
                     8286 M free swap
            top - 16:58:20 up 8 days, 21:50,  2 users,  load average: 2.45, 2.18, 2.51
            Tasks: 172 total,   3 running, 169 sleeping,   0 stopped,   0 zombie
            %Cpu(s): 40.0 us,  8.6 sy,  0.0 ni, 47.1 id,  0.0 wa,  0.0 hi,  4.3 si,  0.0 st
            MiB Mem :   3837.7 total,    994.5 free,   2350.4 used,    492.8 buff/cache
            MiB Swap:  10240.0 total,   8286.5 free,   1953.5 used.   1319.8 avail Mem
            *** FAILED SERVICES ***
              UNIT            LOAD   ACTIVE SUB    DESCRIPTION
            * lightdm.service loaded failed failed Light Display Manager
            1 loaded units listed. Pass --all to see loaded but inactive units, too.
            To show all installed unit files use 'systemctl list-unit-files'.
            *** FILESYSTEM ***
            /dev/root      ext4      220G   32G  180G  15% /
            devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
            tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
            tmpfs          tmpfs     1.9G  185M  1.7G  10% /run
            tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
            /dev/sda1      vfat      253M   49M  204M  20% /boot
            tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
            [Sat Aug 31 19:07:29 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:54:0B:45 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=74cbdb6a-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
            [Sat Aug 31 19:07:31 2024] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
            [Sat Aug 31 19:07:31 2024] EXT4-fs (sda2): write access will be enabled during recovery
            [Sat Aug 31 19:07:31 2024] EXT4-fs (sda2): orphan cleanup on readonly fs
            [Sat Aug 31 19:07:31 2024] EXT4-fs (sda2): 11 orphan inodes deleted
            [Sat Aug 31 19:07:31 2024] EXT4-fs (sda2): 1 truncate cleaned up
            [Sat Aug 31 19:07:31 2024] EXT4-fs (sda2): recovery complete
            [Sat Aug 31 19:07:31 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
            [Sat Aug 31 19:07:31 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
            [Sat Aug 31 19:07:33 2024] EXT4-fs (sda2): re-mounted. Opts: (null)
            Show mounted filesystems:
            TARGET                                SOURCE     FSTYPE     OPTIONS
            /                                     /dev/sda2  ext4       rw,noatime
            |-/dev                                devtmpfs   devtmpfs   rw,relatime,size=1800056k,nr_inodes=84157,mode=755
            | |-/dev/shm                          tmpfs      tmpfs      rw,nosuid,nodev
            | |-/dev/pts                          devpts     devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
            | `-/dev/mqueue                       mqueue     mqueue     rw,relatime
            |-/sys                                sysfs      sysfs      rw,nosuid,nodev,noexec,relatime
            | |-/sys/kernel/security              securityfs securityfs rw,nosuid,nodev,noexec,relatime
            | |-/sys/fs/cgroup                    tmpfs      tmpfs      ro,nosuid,nodev,noexec,mode=755
            | | |-/sys/fs/cgroup/unified          cgroup2    cgroup2    rw,nosuid,nodev,noexec,relatime,nsdelegate
            | | |-/sys/fs/cgroup/systemd          cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,xattr,name=systemd
            | | |-/sys/fs/cgroup/net_cls,net_prio cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,net_cls,net_prio
            | | |-/sys/fs/cgroup/cpu,cpuacct      cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,cpu,cpuacct
            | | |-/sys/fs/cgroup/cpuset           cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,cpuset
            | | |-/sys/fs/cgroup/pids             cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,pids
            | | |-/sys/fs/cgroup/devices          cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,devices
            | | |-/sys/fs/cgroup/freezer          cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,freezer
            | | |-/sys/fs/cgroup/blkio            cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,blkio
            | | `-/sys/fs/cgroup/perf_event       cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,perf_event
            | |-/sys/fs/bpf                       none       bpf        rw,nosuid,nodev,noexec,relatime,mode=700
            | |-/sys/kernel/debug                 debugfs    debugfs    rw,relatime
            | `-/sys/kernel/config                configfs   configfs   rw,relatime
            |-/proc                               proc       proc       rw,relatime
            | `-/proc/sys/fs/binfmt_misc          systemd-1  autofs     rw,relatime,fd=40,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
            |-/run                                tmpfs      tmpfs      rw,nosuid,nodev,mode=755
            | |-/run/lock                         tmpfs      tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k
            | |-/run/rpc_pipefs                   sunrpc     rpc_pipefs rw,relatime
            | `-/run/user/1000                    tmpfs      tmpfs      rw,nosuid,nodev,relatime,size=392984k,mode=700,uid=1000,gid=1000
            `-/boot                               /dev/sda1  vfat       rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
            /var:
            7.0G    /var/
            1.4G    /var/cache/apt/archives
            1.4G    /var/cache/apt
            1.4G    /var/cache
            1.3G    /var/lib
            Archived and active journals take up 183.9M in the file system.
            /opt/iobroker/backups:
            899M    /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            1.9G    /opt/iobroker/iobroker-data/
            1.1G    /opt/iobroker/iobroker-data/files
            618M    /opt/iobroker/iobroker-data/backup-objects
            441M    /opt/iobroker/iobroker-data/files/javascript.admin
            409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
            65M     /opt/iobroker/iobroker-data/objects.jsonl
            48M     /opt/iobroker/iobroker-data/states.jsonl
            42M     /opt/iobroker/iobroker-data/files/telegram-menu.admin/build/index.js.map
            38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
            35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
            USB-Devices by-id:
            /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2219042-if00
            /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A94ZVX1D-if00-port0
            Your zigbee.0 COM-Port is matching 'by-id'. Very good!
            *** NodeJS-Installation ***
            /usr/bin/nodejs         v18.0.0
            /usr/bin/node           v18.0.0
            /usr/bin/npm            8.6.0
            /usr/bin/npx            8.6.0
            /usr/bin/corepack       0.10.0
            nodejs:
              Installed: 18.0.0-1nodesource1
              Candidate: 18.20.4-1nodesource1
              Version table:
                 18.20.4-1nodesource1 1001
                    500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                 18.20.3-1nodesource1 1001
                 18.20.2-1nodesource1 1001
                 18.20.1-1nodesource1 1001
                 18.20.0-1nodesource1 1001
                 18.19.1-1nodesource1 1001
                 18.19.0-1nodesource1 1001
                 18.18.2-1nodesource1 1001
                 18.18.1-1nodesource1 1001
                 18.18.0-1nodesource1 1001
                 18.17.1-1nodesource1 1001
                 18.17.0-1nodesource1 1001
                 18.16.1-1nodesource1 1001
                 18.16.0-1nodesource1 1001
                 18.15.0-1nodesource1 1001
                 18.14.2-1nodesource1 1001
                 18.14.1-1nodesource1 1001
                 18.14.0-1nodesource1 1001
                 18.13.0-1nodesource1 1001
                 18.12.0-1nodesource1 1001
                 18.11.0-1nodesource1 1001
                 18.10.0-1nodesource1 1001
                 18.9.1-1nodesource1 1001
                 18.9.0-1nodesource1 1001
                 18.8.0-1nodesource1 1001
                 18.7.0-1nodesource1 1001
                 18.6.0-1nodesource1 1001
                 18.5.0-1nodesource1 1001
                 18.4.0-1nodesource1 1001
                 18.3.0-1nodesource1 1001
                 18.2.0-1nodesource1 1001
                 18.1.0-1nodesource1 1001
             *** 18.0.0-1nodesource1 1001
                    100 /var/lib/dpkg/status
                 10.24.0~dfsg-1~deb10u3 500
            No problems detected
            Errors in npm tree:
            *** ioBroker-Installation ***
            ioBroker Status
            (node:24672) ExperimentalWarning: The Fetch API is an experimental feature. This feature could change at any time
            Objects type: jsonl
            States  type: jsonl
            Core adapters versions
            (node:24724) ExperimentalWarning: The Fetch API is an experimental feature. This feature could change at any time
            js-controller:  5.0.19
            (node:24740) ExperimentalWarning: The Fetch API is an experimental feature. This feature could change at any time
            admin:          7.0.23
            (node:24753) ExperimentalWarning: The Fetch API is an experimental feature. This feature could change at any time
            javascript:     8.7.6
            nodejs modules from github:     6
            +-- iobroker.bmw@2.6.3 (git+ssh://git@github.com/TA2k/ioBroker.bmw.git#4d2becc9814575c1387493d403ee6b435578997c)
            +-- iobroker.govee@0.0.5 (git+ssh://git@github.com/nbuenger/ioBroker.govee.git#0d983c49135b87ac2f88f9d832a6d632c4889606)
            +-- iobroker.labcom@0.1.5 (git+ssh://git@github.com/100prznt/ioBroker.labcom.git#13ae01a87552c17f49fc39f49ae3dd5bde870906)
            | +-- node-milight-promise@0.3.2 (git+ssh://git@github.com/Steiger04/node-milight-promise.git#f1089feac9b7990727adf2016891029436729d33)
            | | +-- browser-serialport@2.0.3 (git+ssh://git@github.com/noopkat/browser-serialport.git#c8628c41c11890d3058875994c15f83f2df8185b)
            +-- iobroker.sourceanalytix@0.4.12-1 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#362346b297c0a21c717ec20bd8d16331bca3b22d)
            Adapter State
            + system.adapter.accuweather.0            : accuweather           : raspberrypi-iob                          -  enabled
            + system.adapter.admin.0                  : admin                 : raspberrypi-iob                          -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            + system.adapter.alexa2.0                 : alexa2                : raspberrypi-iob                          -  enabled
              system.adapter.alias-manager.0          : alias-manager         : raspberrypi-iob                          -  enabled
              system.adapter.apple-find-me.0          : apple-find-me         : raspberrypi-iob                          - disabled
              system.adapter.apple-find-me.1          : apple-find-me         : raspberrypi-iob                          - disabled
              system.adapter.apple-find-me.2          : apple-find-me         : raspberrypi-iob                          - disabled
              system.adapter.apple-find-me.3          : apple-find-me         : raspberrypi-iob                          - disabled
            + system.adapter.backitup.0               : backitup              : raspberrypi-iob                          -  enabled
              system.adapter.bmw.0                    : bmw                   : raspberrypi-iob                          - disabled
              system.adapter.bmw.1                    : bmw                   : raspberrypi-iob                          - disabled
              system.adapter.bring.0                  : bring                 : raspberrypi-iob                          - disabled
            + system.adapter.broadlink2.0             : broadlink2            : raspberrypi-iob                          -  enabled
            + system.adapter.cloud.0                  : cloud                 : raspberrypi-iob                          -  enabled
              system.adapter.coronavirus-statistics.0 : coronavirus-statistics: raspberrypi-iob                          - disabled
              system.adapter.daswetter.0              : daswetter             : raspberrypi-iob                          - disabled
              system.adapter.device-reminder.0        : device-reminder       : raspberrypi-iob                          - disabled
              system.adapter.device-watcher.0         : device-watcher        : raspberrypi-iob                          - disabled
              system.adapter.devices.0                : devices               : raspberrypi-iob                          -  enabled
              system.adapter.discovery.0              : discovery             : raspberrypi-iob                          - disabled
              system.adapter.dwd.0                    : dwd                   : raspberrypi-iob                          -  enabled
            + system.adapter.echarts.0                : echarts               : raspberrypi-iob                          -  enabled
            + system.adapter.email.0                  : email                 : raspberrypi-iob                          -  enabled
              system.adapter.enigma2.1                : enigma2               : raspberrypi-iob                          - disabled
              system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi-iob                          - disabled
              system.adapter.feiertage.0              : feiertage             : raspberrypi-iob                          -  enabled
            + system.adapter.fhem.0                   : fhem                  : raspberrypi-iob                          -  enabled, port: 7072
              system.adapter.firetv.0                 : firetv                : raspberrypi-iob                          - disabled
              system.adapter.flot.0                   : flot                  : raspberrypi-iob                          -  enabled
              system.adapter.followthesun.0           : followthesun          : raspberrypi-iob                          - disabled
              system.adapter.geofency.0               : geofency              : raspberrypi-iob                          - disabled, port: 7999, bind: 0.0.0.0
              system.adapter.govee.0                  : govee                 : raspberrypi-iob                          - disabled
              system.adapter.habpanel.0               : habpanel              : raspberrypi-iob                          -  enabled
            + system.adapter.ham.0                    : ham                   : raspberrypi-iob                          -  enabled
              system.adapter.history.0                : history               : raspberrypi-iob                          - disabled
            + system.adapter.homeconnect.0            : homeconnect           : raspberrypi-iob                          -  enabled
              system.adapter.homekit-controller.0     : homekit-controller    : raspberrypi-iob                          - disabled
              system.adapter.ical.0                   : ical                  : raspberrypi-iob                          -  enabled
              system.adapter.ico-cloud.0              : ico-cloud             : raspberrypi-iob                          -  enabled
            + system.adapter.influxdb.0               : influxdb              : raspberrypi-iob                          -  enabled, port: 8086
            + system.adapter.info.0                   : info                  : raspberrypi-iob                          -  enabled
            + system.adapter.iot.1                    : iot                   : raspberrypi-iob                          -  enabled
            + system.adapter.javascript.0             : javascript            : raspberrypi-iob                          -  enabled
              system.adapter.labcom.0                 : labcom                : raspberrypi-iob                          -  enabled
              system.adapter.linkeddevices.0          : linkeddevices         : raspberrypi-iob                          - disabled
            + system.adapter.linux-control.0          : linux-control         : raspberrypi-iob                          -  enabled
              system.adapter.meater.0                 : meater                : raspberrypi-iob                          - disabled
              system.adapter.meross.0                 : meross                : raspberrypi-iob                          - disabled
              system.adapter.milight-smart-light.0    : milight-smart-light   : raspberrypi-iob                          - disabled
              system.adapter.milight-smart-light.2    : milight-smart-light   : raspberrypi-iob                          - disabled
              system.adapter.milight-smart-light.3    : milight-smart-light   : raspberrypi-iob                          - disabled
              system.adapter.milight-smart-light.4    : milight-smart-light   : raspberrypi-iob                          - disabled
            + system.adapter.mqtt.0                   : mqtt                  : raspberrypi-iob                          -  enabled, port: 1888, bind: 192.168.0.20
              system.adapter.netatmo-crawler.0        : netatmo-crawler       : raspberrypi-iob                          -  enabled
            + system.adapter.nina.0                   : nina                  : raspberrypi-iob                          -  enabled
              system.adapter.openweathermap.0         : openweathermap        : raspberrypi-iob                          - disabled
              system.adapter.parcel.0                 : parcel                : raspberrypi-iob                          - disabled
              system.adapter.parser.0                 : parser                : raspberrypi-iob                          - disabled
              system.adapter.pegelalarm.0             : pegelalarm            : raspberrypi-iob                          - disabled
              system.adapter.ping.0                   : ping                  : raspberrypi-iob                          -  enabled
            + system.adapter.pollenflug.0             : pollenflug            : raspberrypi-iob                          -  enabled
            + system.adapter.pushover.0               : pushover              : raspberrypi-iob                          -  enabled
              system.adapter.reolink.0                : reolink               : raspberrypi-iob                          - disabled
            + system.adapter.ring.0                   : ring                  : raspberrypi-iob                          -  enabled
            + system.adapter.rpi2.0                   : rpi2                  : raspberrypi-iob                          -  enabled
            + system.adapter.sayit.0                  : sayit                 : raspberrypi-iob                          -  enabled
              system.adapter.schoolfree.0             : schoolfree            : raspberrypi-iob                          -  enabled
            + system.adapter.shelly.0                 : shelly                : raspberrypi-iob                          -  enabled, port: 1882, bind: 0.0.0.0
            + system.adapter.shelly.1                 : shelly                : raspberrypi-iob                          -  enabled, port: 1889, bind: 0.0.0.0
            + system.adapter.simple-api.0             : simple-api            : raspberrypi-iob                          -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
              system.adapter.smartcontrol.0           : smartcontrol          : raspberrypi-iob                          - disabled
              system.adapter.sonoff.0                 : sonoff                : raspberrypi-iob                          - disabled, port: 1883, bind: 0.0.0.0
              system.adapter.sonos.0                  : sonos                 : raspberrypi-iob                          - disabled
              system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi-iob                          - disabled
              system.adapter.spotify-premium.0        : spotify-premium       : raspberrypi-iob                          - disabled
              system.adapter.sql.0                    : sql                   : raspberrypi-iob                          - disabled, port: 3306
              system.adapter.systeminfo.0             : systeminfo            : raspberrypi-iob                          - disabled
            + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi-iob                          -  enabled
            + system.adapter.telegram-menu.0          : telegram-menu         : raspberrypi-iob                          -  enabled
            + system.adapter.telegram.0               : telegram              : raspberrypi-iob                          -  enabled, port: 8443, bind: 0.0.0.0
              system.adapter.terminal.0               : terminal              : raspberrypi-iob                          - disabled, port: 8089, bind: 192.168.0.20, run as: admin
              system.adapter.text2command.0           : text2command          : raspberrypi-iob                          - disabled
            + system.adapter.tibberlink.0             : tibberlink            : raspberrypi-iob                          -  enabled
              system.adapter.tr-064.0                 : tr-064                : raspberrypi-iob                          - disabled
            + system.adapter.trashschedule.0          : trashschedule         : raspberrypi-iob                          -  enabled
            + system.adapter.tuya.0                   : tuya                  : raspberrypi-iob                          -  enabled
              system.adapter.twinkly.0                : twinkly               : raspberrypi-iob                          - disabled
              system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi-iob                          -  enabled
              system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi-iob                          -  enabled
              system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi-iob                          - disabled
              system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi-iob                          -  enabled
              system.adapter.vis-weather.0            : vis-weather           : raspberrypi-iob                          -  enabled
              system.adapter.vis.0                    : vis                   : raspberrypi-iob                          - disabled
              system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi-iob                          - disabled
            + system.adapter.web.0                    : web                   : raspberrypi-iob                          -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            + system.adapter.wled.0                   : wled                  : raspberrypi-iob                          -  enabled
              system.adapter.yahka.0                  : yahka                 : raspberrypi-iob                          - disabled
            + system.adapter.zigbee.0                 : zigbee                : raspberrypi-iob                          -  enabled, port: /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2219042-if00
            + instance is alive
            ioBroker-Repositories
            (node:24770) ExperimentalWarning: The Fetch API is an experimental feature. This feature could change at any time
            Active repo(s): stable
            Installed ioBroker-Instances
            (node:24779) ExperimentalWarning: The Fetch API is an experimental feature. This feature could change at any time
            Used repository: stable
            Adapter    "accuweather"  : 1.5.0    , installed 1.5.0
            Adapter    "admin"        : 7.0.23   , installed 7.0.23
            Adapter    "alarm"        : 3.6.1    , installed 3.6.1
            Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
            Adapter    "backitup"     : 3.0.22   , installed 3.0.19 [Updatable]
            Adapter    "bring"        : 1.8.4    , installed 1.8.4
            Adapter    "broadlink2"   : 2.3.0    , installed 2.2.0  [Updatable]
            Adapter    "cloud"        : 5.0.1    , installed 5.0.1
            Adapter    "coronavirus-statistics": 0.9.0, installed 0.9.0
            Adapter    "daswetter"    : 3.1.16   , installed 3.1.15 [Updatable]
            Adapter    "deconz"       : 1.4.1    , installed 1.4.1
            Adapter    "device-reminder": 3.1.2  , installed 3.1.2
            Adapter    "device-watcher": 2.12.1  , installed 2.12.1
            Adapter    "discovery"    : 4.5.0    , installed 4.5.0
            Adapter    "echarts"      : 1.7.2    , installed 1.7.2
            Adapter    "email"        : 1.3.1    , installed 1.3.1
            Adapter    "enigma2"      : 2.1.1    , installed 2.1.1
            Adapter    "fb-checkpresence": 1.2.4 , installed 1.2.4
            Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
            Adapter    "fhem"         : 2.0.5    , installed 2.0.5
            Adapter    "firetv"       : 2.1.0    , installed 2.1.0
            Adapter    "followthesun" : 0.5.1    , installed 0.5.0  [Updatable]
            Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
            Adapter    "geofency"     : 1.2.4    , installed 1.2.4
            Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
            Adapter    "ham"          : 5.3.1    , installed 5.3.1
            Adapter    "homeconnect"  : 1.4.1    , installed 1.4.1
            Adapter    "homekit-controller": 0.5.10, installed 0.5.10
            Adapter    "ical"         : 1.15.0   , installed 1.15.0
            Adapter    "ico-cloud"    : 1.1.0    , installed 1.1.0
            Adapter    "iot"          : 3.3.0    , installed 3.3.0
            Adapter    "javascript"   : 8.7.6    , installed 8.7.6
            Controller "js-controller": 6.0.11   , installed 5.0.19 [Updatable]
            Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
            Adapter    "linux-control": 1.1.5    , installed 1.1.5
            Adapter    "luftdaten"    : 4.0.0    , installed 4.0.0
            Adapter    "meater"       : 1.1.1    , installed 1.1.1
            Adapter    "meross"       : 1.17.0   , installed 1.17.0
            Adapter    "milight"      : 0.4.0    , installed 0.4.0
            Adapter    "milight-smart-light": 1.2.2, installed 1.2.2
            Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
            Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
            Adapter    "nina"         : 0.0.25   , installed 0.0.25
            Adapter    "openweathermap": 1.1.2   , installed 1.1.2
            Adapter    "parser"       : 2.2.2    , installed 2.2.2
            Adapter    "pegelalarm"   : 1.3.3    , installed 1.3.3
            Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
            Adapter    "pushover"     : 3.0.6    , installed 3.0.6
            Adapter    "radar2"       : 2.2.0    , installed 2.2.0
            Adapter    "reolink"      : 1.1.1    , installed 1.1.1
            Adapter    "rest-api"     : 2.0.3    , installed 2.0.3
            Adapter    "rflink"       : 2.1.12   , installed 2.1.12
            Adapter    "ring"         : 5.1.0    , installed 5.0.10 [Updatable]
            Adapter    "rpi2"         : 1.3.2    , installed 1.3.2
            Adapter    "sayit"        : 5.0.0    , installed 5.0.0
            Adapter    "scenes"       : 3.2.1    , installed 3.2.1
            Adapter    "schoolfree"   : 1.1.4    , installed 1.1.4
            Adapter    "shelly"       : 7.0.0    , installed 6.8.0  [Updatable]
            Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
            Adapter    "socketio"     : 6.7.1    , installed 6.7.1
            Adapter    "sonoff"       : 3.1.0    , installed 3.1.0
            Adapter    "sonos"        : 3.0.0    , installed 3.0.0
            Adapter    "spotify-premium": 1.5.0  , installed 1.5.0
            Adapter    "sql"          : 3.0.1    , installed 3.0.1
            Adapter    "systeminfo"   : 1.2.0    , installed 1.2.0
            Adapter    "tankerkoenig" : 3.4.0    , installed 2.1.1  [Updatable]
            Adapter    "telegram"     : 3.9.0    , installed 3.9.0
            Adapter    "telegram-menu": 2.0.0    , installed 1.7.4  [Updatable]
            Adapter    "terminal"     : 1.0.0    , installed 1.0.0
            Adapter    "text2command" : 3.0.3    , installed 3.0.3
            Adapter    "tibberlink"   : 3.4.8    , installed 3.4.8
            Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
            Adapter    "trashschedule": 3.3.0    , installed 3.3.0
            Adapter    "tuya"         : 3.16.0   , installed 3.16.0
            Adapter    "twinkly"      : 1.0.14   , installed 1.0.14
            Adapter    "vis-2-widgets-energy": 1.0.0, installed 1.0.0
            Adapter    "vis-2-widgets-gauges": 1.1.0, installed 1.1.0
            Adapter    "vis-2-widgets-material": 1.4.8, installed 1.4.8
            Adapter    "vis-icontwo"  : 1.5.0    , installed 1.0.0  [Updatable]
            Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
            Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
            Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
            Adapter    "weatherunderground": 3.7.0, installed 3.7.0
            Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
            Adapter    "wled"         : 0.7.2    , installed 0.7.2
            Adapter    "ws"           : 2.6.2    , installed 2.6.2
            Adapter    "yahka"        : 1.0.3    , installed 1.0.3
            Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
            Objects and States
            Objects:        47310
            States:         3
            Hit:1 http://archive.raspberrypi.org/debian buster InRelease
            Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
            Hit:3 https://repos.influxdata.com/debian buster InRelease
            Reading package lists...
            E: Broken packages
            Pending Updates:
            *** Listening Ports ***
            tcp        0      0 0.0.0.0:8083            0.0.0.0:*               LISTEN      999        19638      653/perl
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17073      549/sshd
            tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          24749532   1565/cupsd
            tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      116        18835      506/influxd
            tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          19824      982/exim4
            tcp        0      0 192.168.0.20:1888       0.0.0.0:*               LISTEN      1001       26535      2032/io.mqtt.0
            tcp        0      0 0.0.0.0:7072            0.0.0.0:*               LISTEN      999        19670      653/perl
            tcp        0      0 0.0.0.0:1889            0.0.0.0:*               LISTEN      1001       32926      2073/io.shelly.1
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       23582      507/iobroker.js-con
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       20350      507/iobroker.js-con
            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       23510      1406/io.admin.0
            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       30869      2134/io.web.0
            tcp6       0      0 :::8086                 :::*                    LISTEN      116        21367      506/influxd
            tcp6       0      0 :::22                   :::*                    LISTEN      0          17083      549/sshd
            tcp6       0      0 ::1:631                 :::*                    LISTEN      0          24749531   1565/cupsd
            tcp6       0      0 :::8087                 :::*                    LISTEN      1001       30132      2234/io.simple-api.
            tcp6       0      0 ::1:25                  :::*                    LISTEN      0          19825      982/exim4
            tcp6       0      0 :::3306                 :::*                    LISTEN      115        18243      647/mysqld
            udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       32892      1916/io.tuya.0
            udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       32893      1916/io.tuya.0
            udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       33696      1668/io.shelly.0
            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          21700      419/dhcpcd
            udp        0      0 0.0.0.0:47191           0.0.0.0:*                           1001       26236      1639/io.broadlink2.
            udp        0      0 0.0.0.0:60531           0.0.0.0:*                           108        17643      401/avahi-daemon: r
            udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          24746963   1566/cups-browsed
            udp        0      0 0.0.0.0:60026           0.0.0.0:*                           1001       26235      1639/io.broadlink2.
            udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       28061      1639/io.broadlink2.
            udp        0      0 0.0.0.0:36572           0.0.0.0:*                           1001       26238      1639/io.broadlink2.
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       30520      2020/io.ham.0
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       29903      2265/io.wled.0
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        17641      401/avahi-daemon: r
            udp        0      0 0.0.0.0:33143           0.0.0.0:*                           1001       26811587   1639/io.broadlink2.
            udp6       0      0 :::546                  :::*                                0          21724      419/dhcpcd
            udp6       0      0 :::5353                 :::*                                108        17642      401/avahi-daemon: r
            udp6       0      0 :::49409                :::*                                108        17644      401/avahi-daemon: r
            2024-09-09 16:59:49.516  - error: host.raspberrypi-iob Caught by controller[1]:     at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:5378:38)
            2024-09-09 16:59:49.516  - error: host.raspberrypi-iob Caught by controller[1]:     at processImmediate (node:internal/timers:473:21)
            2024-09-09 16:59:49.516  - error: host.raspberrypi-iob instance system.adapter.ping.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
            2024-09-09 16:59:49.516  - info: host.raspberrypi-iob Restart adapter system.adapter.ping.0 because enabled
            2024-09-09 17:00:08.903  - info: host.raspberrypi-iob instance system.adapter.dwd.0 started with pid 24837
            2024-09-09 17:00:14.186  - info: host.raspberrypi-iob instance system.adapter.netatmo-crawler.0 started with pid 24848
            2024-09-09 17:00:20.339  - info: host.raspberrypi-iob instance system.adapter.labcom.0 started with pid 24870
            2024-09-09 17:00:24.812  - info: host.raspberrypi-iob instance system.adapter.ping.0 started with pid 24881
            2024-09-09 17:00:26.757  - warn: netatmo-crawler.0 (24848) slow connection to states DB. Still waiting ...
            2024-09-09 17:00:30.245  - info: host.raspberrypi-iob instance system.adapter.ical.0 started with pid 24892
            2024-09-09 17:01:21.461  - info: host.raspberrypi-iob instance system.adapter.labcom.0 terminated with code 0 (NO_ERROR)
            2024-09-09 17:01:26.416  - error: ping.0 (24881) uncaught exception: Parameter "ack" needs to be of type "boolean" but type "object" has been passed
            2024-09-09 17:01:26.420  - error: ping.0 (24881) Error: Parameter "ack" needs to be of type "boolean" but type "object" has been passed
            2024-09-09 17:01:26.422  - error: ping.0 (24881) Parameter "ack" needs to be of type "boolean" but type "object" has been passed
            2024-09-09 17:01:27.942  - error: host.raspberrypi-iob Caught by controller[1]: Error: Parameter "ack" needs to be of type "boolean" but type "object" has been passed
            2024-09-09 17:01:27.943  - error: host.raspberrypi-iob Caught by controller[1]:     at Function.assertBoolean (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/validator.ts:275:19)
            2024-09-09 17:01:27.943  - error: host.raspberrypi-iob Caught by controller[1]:     at AdapterClass.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:7535:23)
            2024-09-09 17:01:27.944  - error: host.raspberrypi-iob Caught by controller[1]:     at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:5378:38)
            2024-09-09 17:01:27.944  - error: host.raspberrypi-iob Caught by controller[1]:     at processImmediate (node:internal/timers:473:21)
            2024-09-09 17:01:27.944  - error: host.raspberrypi-iob instance system.adapter.ping.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
            2024-09-09 17:01:27.945  - info: host.raspberrypi-iob Restart adapter system.adapter.ping.0 because enabled
            Meister Mopper Thomas Braun 2 Replies Last reply Reply Quote 0
            • Meister Mopper
              Meister Mopper @tklein last edited by
              Da weiß man ja gar nicht wo man mit der Hilfe anfangen soll. Hast du aktuelle Backups vom backitup-Adapter?
                tklein @Meister Mopper last edited by
                @meister-mopper oha, so schlimm? lasse gerade ein neues erstellen da ich von heute nacht (automatisch) bis gerade einiges gemacht habe
                  Thomas Braun Most Active @tklein last edited by
                  (buster)
                  Kannste nur neuinstallieren, diesmal in der 64Bit Lite-Version.
                  Denn das Dateisystem hat Einschläge:
                  nodejs total veraltet.
                  E: Broken packages
                  Paketverwaltung hin.
                  T paul53 2 Replies Last reply Reply Quote 0
                  • Meister Mopper
                    @tklein
                    Leider hat dein Dateisystem einen Turmtreffer, und buster ist auch nicht wiederbelebbar.
                    Da hilft nur eine Neuinstallation mit einer aktuellen Debian 12 (bookworm) lite mit 64 bit und anschließendem backitup restore.
                      tklein @Thomas Braun last edited by
                      @thomas-braun ja ich drück mich schon recht lange davor. habe ca 120 zigbee device die alle neu angelernt werden müssten... derzeit noch am conbee2 als coordinator
                      • Meister Mopper
                        Davor drücken bringt nix, wie du gerade erfährst. Selbst die Zigbee-Konfiguration kannst du super mit dem backitup Adapter sichern.
                          Je länger du dich 'drückst', umso komplizierter wird es.
                          Der einzige gangbare Weg ist die Neuinstallation, daher musst du dir über Alternativen erst gar nicht den Kopf zerbrechen.
                            paul53 @Thomas Braun last edited by
                            @thomas-braun sagte: das Dateisystem hat Einschläge:
                            Sieht ganz danach aus:
                            Objects:        47310
                            States:         3
                            T Thomas Braun 2 Replies Last reply Reply Quote 0
                              @meister-mopper ich dachte, dass die zigbee devices neu gepairt werden müssten
                                tklein @paul53 last edited by
                                @paul53 was soll/kann mir das sagen? ssd-fehler?
                                  Thomas Braun Most Active @paul53 last edited by
                                  @paul53 sagte in Logeinträge: Ping und Host.*:
                                  Da stellt sich auch die Frage, ob man aus dem wurmstichigen Ding überhaupt noch ein solides Backup ziehen kann.
                                    paul53 @tklein last edited by
                                    @tklein sagte: was soll/kann mir das sagen?
                                    Offenbar kann die Datei "states.jsonl" nicht gelesen werden, denn nur 3 States gibt es nicht.
                                      da muss ich mich wohl nach einer zweiten ssd und einem neuen zigbee coordinator umschauen.
                                      Der Raspi sollte wohl nur für den iob ohne grafana reichen, oder?
                                        hier ein Update nach Neustart mit 40 K states 🙂
                                        Skript v.2024-05-22
                                        *** BASE SYSTEM ***
                                                 Icon name: computer
                                              Architecture: arm
                                        Docker          : false
                                        Kernel          : armv7l
                                        Userland        : 32 bit
                                         17:36:47 up 5 min,  2 users,  load average: 5.36, 3.22, 1.39
                                        CPU threads: 4
                                        Current issues:
                                                       Local time: Mon 2024-09-09 17:36:47 CEST
                                                   Universal time: Mon 2024-09-09 15:36:47 UTC
                                                         RTC time: n/a
                                                      NTP service: active
                                                  RTC in local TZ: no
                                        pi
                                        HOME=/home/pi
                                        iobroker
                                        HOME=/home/iobroker
                                        Desktop:
                                        Terminal:       tty
                                        *** MEMORY ***
                                        Mem:           3.8G        3.0G        506M        2.0M        356M        728M
                                        Swap:           10G         16M         10G
                                        Total:          14G        3.0G         10G
                                        Active iob-Instances:   37
                                                 3837 M total memory
                                                 2976 M used memory
                                                  198 M active memory
                                                 3011 M inactive memory
                                                  505 M free memory
                                                   92 M buffer memory
                                                  263 M swap cache
                                                10239 M total swap
                                                   16 M used swap
                                                10223 M free swap
                                        top - 17:36:48 up 5 min,  2 users,  load average: 5.36, 3.22, 1.39
                                        Tasks: 168 total,   5 running, 163 sleeping,   0 stopped,   0 zombie
                                        %Cpu(s): 39.2 us,  4.1 sy,  0.0 ni, 54.1 id,  0.0 wa,  0.0 hi,  2.7 si,  0.0 st
                                        MiB Mem :   3837.7 total,    508.3 free,   2973.2 used,    356.2 buff/cache
                                        MiB Swap:  10240.0 total,  10223.7 free,     16.3 used.    730.8 avail Mem
                                        *** FILESYSTEM ***
                                        /dev/root      ext4      220G   32G  180G  16% /
                                        tmpfs          tmpfs     1.9G  8.6M  1.9G   1% /run
                                        [Mon Sep  9 17:31:28 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:54:0B:45 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=74cbdb6a-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                                        [Mon Sep  9 17:31:30 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
                                        [Mon Sep  9 17:31:30 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                                        [Mon Sep  9 17:31:32 2024] EXT4-fs (sda2): re-mounted. Opts: (null)
                                        | | `-/sys/fs/cgroup/devices          cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,devices
                                        | `-/proc/sys/fs/binfmt_misc          systemd-1  autofs     rw,relatime,fd=25,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
                                        /var:
                                        7.0G    /var/
                                        1.4G    /var/lib
                                        1.4G    /var/cache/apt
                                        1.4G    /var/cache
                                        Archived and active journals take up 8.0M in the file system.
                                        1.3G    /opt/iobroker/backups/
                                        18M     /opt/iobroker/backups/tmpScripts
                                        80M     /opt/iobroker/iobroker-data/objects.jsonl
                                        52M     /opt/iobroker/iobroker-data/states.jsonl
                                        USB-Devices by-id:
                                        /usr/bin/npm            8.6.0
                                        /usr/bin/npx            8.6.0
                                        nodejs:
                                          Version table:
                                        Errors in npm tree:
                                        ioBroker Status
                                        (node:2655) ExperimentalWarning: The Fetch API is an experimental feature. This feature could change at any time
                                         Cannot determine Set feature status: Connection is closed.
                                         Unable to subscribe to expiry Keyspace events from Redis Server: Connection is closed.
                                         Unable to subscribe to evicted Keyspace events from Redis Server: Connection is closed.
                                         Unable to subscribe to meta namespace "meta." changes: Connection is closed.
                                        Server Cannot start inMem-states on port 9000: Failed to lock DB file "/opt/iobroker/iobroker-data/states.jsonl"!
                                        (node:2693) ExperimentalWarning: The Fetch API is an experimental feature. This feature could change at any time
                                        (node:2710) ExperimentalWarning: The Fetch API is an experimental feature. This feature could change at any time
                                        admin:          7.0.23
                                        (node:2725) ExperimentalWarning: The Fetch API is an experimental feature. This feature could change at any time
                                        javascript:     8.7.6
                                        Adapter State
                                        + system.adapter.dwd.0                    : dwd                   : raspberrypi-iob                          -  enabled
                                        + system.adapter.netatmo-crawler.0        : netatmo-crawler       : raspberrypi-iob                          -  enabled
                                        + system.adapter.schoolfree.0             : schoolfree            : raspberrypi-iob                          -  enabled
                                        + instance is alive
                                        (node:2742) ExperimentalWarning: The Fetch API is an experimental feature. This feature could change at any time
                                        (node:2761) ExperimentalWarning: The Fetch API is an experimental feature. This feature could change at any time
                                        Objects and States
                                        Objects:        47312
                                        States:         40875
                                        Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                                        Hit:2 http://archive.raspberrypi.org/debian buster InRelease
                                        E: Broken packages
                                        Pending Updates:
                                        tcp        0      0 0.0.0.0:8083            0.0.0.0:*               LISTEN      999        17916      631/perl
                                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          18710      509/sshd
                                        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          17539      386/cupsd
                                        tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      116        18730      487/influxd
                                        tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          19104      939/exim4
                                        tcp        0      0 192.168.0.20:1888       0.0.0.0:*               LISTEN      1001       28325      1484/io.mqtt.0
                                        tcp        0      0 0.0.0.0:7072            0.0.0.0:*               LISTEN      999        17925      631/perl
                                        tcp        0      0 0.0.0.0:1889            0.0.0.0:*               LISTEN      1001       31851      1560/io.shelly.1
                                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       23723      490/iobroker.js-con
                                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       21315      490/iobroker.js-con
                                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       21479      1232/io.admin.0
                                        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       27435      1651/io.web.0
                                        tcp6       0      0 :::8086                 :::*                    LISTEN      116        21325      487/influxd
                                        tcp6       0      0 :::22                   :::*                    LISTEN      0          17176      509/sshd
                                        tcp6       0      0 :::8087                 :::*                    LISTEN      1001       28482      1718/io.simple-api.
                                        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          17538      386/cupsd
                                        tcp6       0      0 ::1:25                  :::*                    LISTEN      0          19105      939/exim4
                                        tcp6       0      0 :::3306                 :::*                    LISTEN      115        17362      610/mysqld
                                        udp        0      0 0.0.0.0:48541           0.0.0.0:*                           1001       23439      1342/io.broadlink2.
                                        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       29396      1406/io.tuya.0
                                        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       29397      1406/io.tuya.0
                                        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       32260      1356/io.shelly.0
                                        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          19413      428/dhcpcd
                                        udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          17755      500/cups-browsed
                                        udp        0      0 0.0.0.0:38536           0.0.0.0:*                           1001       23440      1342/io.broadlink2.
                                        udp        0      0 0.0.0.0:54408           0.0.0.0:*                           108        17006      378/avahi-daemon: r
                                        udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       24717      1342/io.broadlink2.
                                        udp        0      0 0.0.0.0:58599           0.0.0.0:*                           1001       38025      1342/io.broadlink2.
                                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       27151      1450/io.ham.0
                                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       25363      1788/io.wled.0
                                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        17004      378/avahi-daemon: r
                                        udp        0      0 0.0.0.0:55640           0.0.0.0:*                           1001       23438      1342/io.broadlink2.
                                        udp6       0      0 :::546                  :::*                                0          21565      428/dhcpcd
                                        udp6       0      0 :::5353                 :::*                                108        17005      378/avahi-daemon: r
                                        udp6       0      0 :::55692                :::*                                108        17007      378/avahi-daemon: r
                                         / "{\"error\":\"timeout\"}\n""
                                        2024-09-09 17:40:21.500  - warn: influxdb.0 (1280) Error on writePoint("{"value":180,"time":"2024-09-09T15:40:01.410Z","from":"system.adapter.mqtt.0","q":0,"ack":true}): Error: {"error":"timeout"}
                                        2024-09-09 17:40:21.877  - warn: influxdb.0 (1280) Error on writePoint("{"value":47.4,"time":"2024-09-09T15:40:01.769Z","from":"system.adapter.mqtt.0","q":0,"ack":true}): Error: {"error":"timeout"}
                                        2024-09-09 17:40:21.901  - warn: influxdb.0 (1280) Error on writePoint("{"value":189.3,"time":"2024-09-09T15:40:01.778Z","from":"system.adapter.mqtt.0","q":0,"ack":true}): Error: {"error":"timeout"}
                                        2024-09-09 17:40:21.914  - warn: influxdb.0 (1280) Error on writePoint("{"value":95.087,"time":"2024-09-09T15:40:01.780Z","from":"system.adapter.mqtt.0","q":0,"ack":true}): Error: {"error":"timeout"}
                                        2024-09-09 17:40:22.061  - info: host.raspberrypi-iob instance system.adapter.netatmo-crawler.0 started with pid 2977
                                        2024-09-09 17:40:23.819  - warn: influxdb.0 (1280) Error on writePoint("{"value":0.78,"time":"2024-09-09T15:39:53.553Z","from":"system.adapter.mqtt.0","q":0,"ack":true}): Error: {"error":"timeout"}
                                        2024-09-09 17:40:23.840  - warn: influxdb.0 (1280) Error on writePoint("{"value":178.5,"time":"2024-09-09T15:39:53.553Z","from":"system.adapter.mqtt.0","q":0,"ack":true}): Error: {"error":"timeout"}
                                        2024-09-09 17:40:23.913  - warn: influxdb.0 (1280) Error on writePoint("{"value":47,"time":"2024-09-09T15:39:53.558Z","from":"system.adapter.mqtt.0","q":0,"ack":true}): Error: {"error":"timeout"}
                                        2024-09-09 17:40:23.927  - warn: influxdb.0 (1280) Error on writePoint("{"value":187.8,"time":"2024-09-09T15:39:53.558Z","from":"system.adapter.mqtt.0","q":0,"ack":true}): Error: {"error":"timeout"}
                                        2024-09-09 17:40:23.945  - warn: influxdb.0 (1280) Error on writePoint("{"value":95.048,"time":"2024-09-09T15:39:53.559Z","from":"system.adapter.mqtt.0","q":0,"ack":true}): Error: {"error":"timeout"}
                                        2024-09-09 17:40:23.960  - warn: influxdb.0 (1280) Error on writePoint("{"value":187.8,"time":"2024-09-09T15:39:53.560Z","from":"system.adapter.mqtt.0","q":0,"ack":true}): Error: {"error":"timeout"}
                                        2024-09-09 17:40:35.930  - warn: dwd.0 (2956) slow connection to objects DB. Still waiting ...
                                        2024-09-09 17:40:37.402  - warn: netatmo-crawler.0 (2977) slow connection to objects DB. Still waiting ...
                                        2024-09-09 17:40:46.034  - warn: netatmo-crawler.0 (2977) slow connection to states DB. Still waiting ...
                                          @tklein
                                          Verbessert die Gesamtsituation aber nur marginalst.
                                          363
