    4. Slave iobroker restore Fehler
      djsirius last edited by
      ich habe gerade mein Slave-System Raspberry Pi 3b auf Bookworm umgestellt.
      Ich habe den iobroker installiert und das Slave-System mit dem Master verbunden. Wird auch erkannt und richtig angezeigt.
      nun versuche ich das Backup auf dem Slave-System einzuspielen und bekomme die Fehlermeldung
      No connection to databases possible ...
      Kann mir bitte jemand weiter helfen?
      Vielen Dank!
      D Marc Berg 2 Replies Last reply Reply Quote 0
        djsirius @djsirius last edited by djsirius
        Skript v.2024-05-22
        *** BASE SYSTEM ***
         Static hostname: raspberrypi
               Icon name: computer
                  Kernel: Linux 6.6.47+rpt-rpi-v8
            Architecture: arm64
        Model           : Raspberry Pi 3 Model B Rev 1.2
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : 64 bit
        Systemuptime and Load:
         11:47:44 up  1:10,  2 users,  load average: 0.26, 0.12, 0.10
        CPU threads: 4
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** Time and Time Zones ***
                       Local time: Thu 2024-09-12 11:47:45 CEST
                   Universal time: Thu 2024-09-12 09:47:45 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        pi
        HOME=/home/pi
        GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi
        js-controller is not running
        *** Display-Server-Setup ***
        Display-Server: false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:            951M        148M        208M        909K        662M        802M
        Swap:           209M         23M        186M
        Total:          1.2G        172M        394M
        Active iob-Instances:   0
                  907 M total memory
                  142 M used memory
                  156 M active memory
                  426 M inactive memory
                  198 M free memory
                   28 M buffer memory
                  603 M swap cache
                  199 M total swap
                   22 M used swap
                  177 M free swap
        top - 11:47:45 up  1:10,  2 users,  load average: 0.26, 0.12, 0.10
        Tasks: 148 total,   1 running, 147 sleeping,   0 stopped,   0 zombie
        %Cpu(s): 11.1 us, 11.1 sy,  0.0 ni, 77.8 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :    907.3 total,    198.6 free,    149.7 used,    632.2 buff/cache
        MiB Swap:    200.0 total,    177.7 free,     22.2 used.    757.5 avail Mem
        *** FAILED SERVICES ***
          UNIT             LOAD   ACTIVE SUB    DESCRIPTION
        * iobroker.service loaded failed failed ioBroker Server
        1 loaded units listed.
        *** FILESYSTEM ***
        udev           devtmpfs  318M     0  318M   0% /dev
        tmpfs          tmpfs      91M  1.1M   90M   2% /run
        /dev/mmcblk0p2 ext4       59G  3.4G   52G   7% /
        tmpfs          tmpfs     454M     0  454M   0% /dev/shm
        tmpfs          tmpfs     5.0M   12K  5.0M   1% /run/lock
        /dev/mmcblk0p1 vfat      510M   64M  447M  13% /boot/firmware
        tmpfs          tmpfs      91M     0   91M   0% /run/user/1000
        [Thu Sep 12 10:36:52 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=b128265a-02 rootfstype=ext4 fsck.repair=yes rootwait
        [Thu Sep 12 10:36:56 2024] EXT4-fs (mmcblk0p2): mounted filesystem 56f80fa2-e005-4cca-86e6-19da1069914d ro with ordered data mode. Quota mode: none.
        [Thu Sep 12 10:36:59 2024] EXT4-fs (mmcblk0p2): re-mounted 56f80fa2-e005-4cca-86e6-19da1069914d r/w. Quota mode: none.
        Show mounted filesystems:
        TARGET                                                  SOURCE         FSTYPE      OPTIONS
        /                                                       /dev/mmcblk0p2 ext4        rw,noatime
        |-/sys                                                  sysfs          sysfs       rw,nosuid,nodev,noexec,relatime
        | |-/sys/kernel/security                                securityfs     securityfs  rw,nosuid,nodev,noexec,relatime
        | |-/sys/fs/cgroup                                      cgroup2        cgroup2     rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
        | |-/sys/fs/pstore                                      pstore         pstore      rw,nosuid,nodev,noexec,relatime
        | |-/sys/fs/bpf                                         bpf            bpf         rw,nosuid,nodev,noexec,relatime,mode=700
        | |-/sys/kernel/debug                                   debugfs        debugfs     rw,nosuid,nodev,noexec,relatime
        | |-/sys/kernel/tracing                                 tracefs        tracefs     rw,nosuid,nodev,noexec,relatime
        | |-/sys/fs/fuse/connections                            fusectl        fusectl     rw,nosuid,nodev,noexec,relatime
        | `-/sys/kernel/config                                  configfs       configfs    rw,nosuid,nodev,noexec,relatime
        |-/proc                                                 proc           proc        rw,relatime
        | `-/proc/sys/fs/binfmt_misc                            systemd-1      autofs      rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=430
        |   `-/proc/sys/fs/binfmt_misc                          binfmt_misc    binfmt_misc rw,nosuid,nodev,noexec,relatime
        |-/dev                                                  udev           devtmpfs    rw,nosuid,relatime,size=325264k,nr_inodes=81316,mode=755
        | |-/dev/pts                                            devpts         devpts      rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
        | |-/dev/shm                                            tmpfs          tmpfs       rw,nosuid,nodev
        | `-/dev/mqueue                                         mqueue         mqueue      rw,nosuid,nodev,noexec,relatime
        |-/run                                                  tmpfs          tmpfs       rw,nosuid,nodev,noexec,relatime,size=92904k,mode=755
        | |-/run/lock                                           tmpfs          tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k
        | |-/run/credentials/systemd-sysctl.service             ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
        | |-/run/credentials/systemd-sysusers.service           ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
        | |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
        | |-/run/rpc_pipefs                                     sunrpc         rpc_pipefs  rw,relatime
        | |-/run/credentials/systemd-tmpfiles-setup.service     ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
        | `-/run/user/1000                                      tmpfs          tmpfs       rw,nosuid,nodev,relatime,size=92904k,nr_inodes=23226,mode=700,uid=1000,gid=1000
        `-/boot/firmware                                        /dev/mmcblk0p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        619M    /var/
        206M    /var/cache
        200M    /var/cache/apt
        166M    /var/lib
        133M    /var/lib/apt/lists
        Archived and active journals take up 47.6M in the file system.
        /opt/iobroker/backups:
        25M     /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        67M     /opt/iobroker/iobroker-data/
        62M     /opt/iobroker/iobroker-data/files
        31M     /opt/iobroker/iobroker-data/files/backitup.admin
        31M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
        14M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.2cca4954.js
        7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.0c96b194.chunk.js.map
        5.6M    /opt/iobroker/iobroker-data/files/backitup.admin/custom/static/js/vendors-node_modules_file-saver_dist_FileSaver_min_js-node_modules_react-icons_di_index_mjs-n-f0ed96.6c33ff1f.chunk.js
        5.5M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-2d33e4.42bb0640.chunk.js.map
        4.9M    /opt/iobroker/iobroker-data/objects.jsonl
        USB-Devices by-id:
        /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v20.17.0
        /usr/bin/node           v20.17.0
        /usr/bin/corepack       0.29.3
        nodejs:
          Installed: 20.17.0-1nodesource1
          Candidate: 20.17.0-1nodesource1
          Version table:
         *** 20.17.0-1nodesource1 1001
                500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                100 /var/lib/dpkg/status
             20.16.0-1nodesource1 1001
             20.15.1-1nodesource1 1001
             20.15.0-1nodesource1 1001
             20.14.0-1nodesource1 1001
             20.13.1-1nodesource1 1001
             20.13.0-1nodesource1 1001
             20.12.2-1nodesource1 1001
             20.12.1-1nodesource1 1001
             20.12.0-1nodesource1 1001
             20.11.1-1nodesource1 1001
             20.11.0-1nodesource1 1001
             20.10.0-1nodesource1 1001
             20.9.0-1nodesource1 1001
             20.8.1-1nodesource1 1001
             20.8.0-1nodesource1 1001
             20.7.0-1nodesource1 1001
             20.6.1-1nodesource1 1001
             20.6.0-1nodesource1 1001
             20.5.1-1nodesource1 1001
             20.5.0-1nodesource1 1001
             20.4.0-1nodesource1 1001
             20.3.1-1nodesource1 1001
             20.3.0-1nodesource1 1001
             20.2.0-1nodesource1 1001
             20.1.0-1nodesource1 1001
             20.0.0-1nodesource1 1001
             18.19.0+dfsg-6~deb12u2 500
             18.19.0+dfsg-6~deb12u1 500
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Core adapters versions
        js-controller:  6.0.11
        admin:          7.0.23
        javascript:     "javascript" not found
        Adapter State
        ioBroker-Repositories
        Installed ioBroker-Instances
        Objects and States
        Objects:        1
        States:         1
        Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
        Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          5414       610/sshd: /usr/sbin
        tcp6       0      0 :::22                   :::*                    LISTEN      0          5416       610/sshd: /usr/sbin
        udp        0      0 0.0.0.0:37187           0.0.0.0:*                           104        3060       456/avahi-daemon: r
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        3058       456/avahi-daemon: r
        udp6       0      0 :::43018                :::*                                104        3061       456/avahi-daemon: r
        udp6       0      0 fe80::2b0f:cce2:5d2:546 :::*                                0          6328       520/NetworkManager
        udp6       0      0 :::5353                 :::*                                104        3059       456/avahi-daemon: r
        2024-09-12 11:02:18.690  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 (force=false, process=true)
        2024-09-12 11:02:18.703  - info: enigma2.0 (9627) Got terminate signal TERMINATE_YOURSELF
        2024-09-12 11:02:18.703  - info: rpi2.1 (10367) Got terminate signal TERMINATE_YOURSELF
        2024-09-12 11:02:18.689  - info: zigbee.0 (10473) Zigbee: disabling joining new devices.
        2024-09-12 11:02:18.725  - info: zigbee.0 (10473) Got terminate signal TERMINATE_YOURSELF
        2024-09-12 11:02:18.750  - info: host.raspberrypi stopInstance system.adapter.enigma2.0 send kill signal
        2024-09-12 11:02:18.754  - info: host.raspberrypi stopInstance system.adapter.rpi2.1 send kill signal
        2024-09-12 11:02:18.755  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal
        2024-09-12 11:02:19.192  - info: rpi2.1 (10367) terminating
        2024-09-12 11:02:19.194  - info: enigma2.0 (9627) terminating
        2024-09-12 11:02:19.197  - info: enigma2.0 (9627) Terminated (NO_ERROR): Without reason
        2024-09-12 11:02:19.240  - info: zigbee.0 (10473) terminating
        2024-09-12 11:02:19.248  - info: zigbee.0 (10473) Terminated (NO_ERROR): Without reason
        2024-09-12 11:02:19.790  - info: host.raspberrypi instance system.adapter.rpi2.1 terminated with code 0 (NO_ERROR)
        2024-09-12 11:02:19.793  - info: host.raspberrypi stopInstance timeout system.adapter.enigma2.0 killing pid 9627
        2024-09-12 11:02:19.796  - info: host.raspberrypi stopInstance timeout system.adapter.zigbee.0 killing pid 10473
        2024-09-12 11:02:20.167  - info: host.raspberrypi instance system.adapter.enigma2.0 terminated with code 0 (NO_ERROR)
        2024-09-12 11:02:20.169  - info: host.raspberrypi All instances are stopped.
        2024-09-12 11:02:20.511  - error: host.raspberrypi Caught by controller[0]: zhc:lixee: Was not able to detect the Linky linky_mode. Default to historique
        2024-09-12 11:02:20.512  - error: host.raspberrypi Caught by controller[1]: zhc:lixee: Was not able to detect the Linky energy_phase. Default to single_phase
        2024-09-12 11:02:20.513  - error: host.raspberrypi Caught by controller[1]: zhc:lixee: Not able to detect the current tarif. Not filtering any expose...
        2024-09-12 11:02:20.514  - warn: host.raspberrypi instance system.adapter.zigbee.0 terminated due to SIGKILL
        2024-09-12 11:02:20.514  - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code null ()
        2024-09-12 11:02:20.515  - info: host.raspberrypi All instances are stopped.
        2024-09-12 11:02:20.622  - info: host.raspberrypi terminated
        • Marc Berg
          Marc Berg Most Active @djsirius last edited by
          @djsirius sagte in Slave iobroker restore Fehler:
          Damit wäre doch alles gut gewesen!?
          Welche Daten möchtest du noch zurückspielen? Die Datenbank liegt auf dem Master und nur dort. Der Slave hat keine eigene Datenbank.
            djsirius @Marc Berg last edited by
            @marc-berg Oh......., SORRY! Das wusste ich nicht! 😞
            Vielen Dank für die Info!
              Homoran Global Moderator Administrators @djsirius last edited by Homoran
              Das sollte so sein!
              Wenn du den Multihost allerdings nicht korrekt aufgesetzt hast, kann es auch anders sein.
              So sollten sich vor der Kopplung an den Master auf dem Slave keinerlei Adapter befinden.
              Die später dort laufenden Instanzen werden über den admin des Masters installiert.
              Dann sind sie auch im Backup des Masters enthalten.
