    4. Installation
    5. Installation bricht ab, chown: ungültige Gruppe: „uwe:uwe“
    • N
      Nr5lebt last edited by
      hallo zusammen,
      irgendwie ist der wurm drin. versuche auf einem neuen nas (amd64) und openmediavault 7 (debian) iobroker zu installieren.
      $ curl -sLf https://iobroker.net/install.sh | bash -
      library: loaded
      Library version=2024-05-24
          Welcome to the ioBroker installer!
          Installer version: 2024-01-04
          You might need to enter your password a couple of times.
          Installing prerequisites (1/4)
      Holen:1 file:/var/cache/openmediavault/archives  InRelease
      Ign:1 file:/var/cache/openmediavault/archives  InRelease
      Holen:2 file:/var/cache/openmediavault/archives  Release
      Ign:2 file:/var/cache/openmediavault/archives  Release
      Holen:3 file:/var/cache/openmediavault/archives  Packages
      Ign:3 file:/var/cache/openmediavault/archives  Packages
      Holen:4 file:/var/cache/openmediavault/archives  Translation-en
      Ign:4 file:/var/cache/openmediavault/archives  Translation-en
      Holen:5 file:/var/cache/openmediavault/archives  Translation-de
      Ign:5 file:/var/cache/openmediavault/archives  Translation-de
      Holen:6 file:/var/cache/openmediavault/archives  Translation-de_DE
      Ign:6 file:/var/cache/openmediavault/archives  Translation-de_DE
      OK:7 http://packages.openmediavault.org/public sandworm InRelease
      OK:8 http://deb.debian.org/debian bookworm InRelease
      OK:9 http://deb.debian.org/debian bookworm-updates InRelease
      OK:10 http://security.debian.org/debian-security bookworm-security InRelease
      OK:11 https://openmediavault-plugin-developers.github.io/packages/debian sandworm InRelease
      OK:12 https://download.docker.com/linux/debian bookworm InRelease
      OK:13 https://openmediavault.github.io/packages sandworm InRelease
      OK:14 https://deb.nodesource.com/node_20.x nodistro InRelease
      Paketlisten werden gelesen… Fertig
          Creating ioBroker user and directory (2/4)
      Created /etc/sudoers.d/iobroker
      Directory /opt/iobroker created
          Installing ioBroker (3/4)
      npm error code 22
      npm error path /opt/iobroker/node_modules/iobroker.js-controller
      npm error command failed
      npm error command sh -c node iobroker.js setup first
      npm error creating conf/iobroker.json
      npm error Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
      npm error A complete log of this run can be found in: /home/uwe/.npm/_logs/2024-09-15T14_04_09_867Z-debug-0.log
          Finalizing installation (4/4)
      Enabling autostart...
      Autostart enabled!
          ioBroker was installed successfully
          Open http://192.168.178.50:8081 in a browser and start configuring!
      You need to re-login before doing anything else on the console!
      da scheint was mit meinem user falsch zu sein
      Ro75 2 Replies Last reply Reply Quote 0
      • Ro75
        Ro75 @Nr5lebt last edited by Ro75
        @nr5lebt ich denke nicht, dass du OMV und iobroker auf der selben Linux-Installation installiert bekommst. Bei der Installation von OMV wird einiges "gebogen" bei der eigentlichen Linux-Installation. Von daher auch die Anzeige.
        Und wenn du dort drin "rumfriemelst", wird OMV nicht mehr laufen.
        Ro75.
        • N
          Nr5lebt @Ro75 last edited by
          @ro75 hmmm, mir ist meines altes nas kaputt gegangen und da hatte ich auch omv und iobroker drauf. allerdings noch unter root
          Ro75 1 Reply Last reply Reply Quote 0
          • Ro75
            @nr5lebt ich würde es trennen. Stabilität ist bei einem NAS das Wichtigste. Wenn du mal liest, hier im Forum, wie man so seinen ioBroker durch unbewusstes (nicht vorhandene Wissen oder Halbwissen) quälen und destabilisieren kann, ist es nur ratsam beides zu trennen.
            ioBroker neu aufsetzen ist im Notfall innerhalb von 2 Stunden erledigt. Ein NAS neu aufzusetzen (vor allem die Daten) das dürfte dann schon länger dauern.
            Ro75.
            • Ro75
              Ro75 @Ro75 last edited by
              ich habe auch OMV im Einsatz. Aber OMV und ioBroker befinden sich auf zwei getrennten Geräten.
              Ro75.
              • N
                @ro75 ich hatte vor jahren versucht iobroker über docker laufen zu lassen hatte aber nur probleme damit. hatte es dann unter omv jahre lang laufen aber wie gesagt unter root. ich denke nicht das das problem bei omv liegt sondern irgendeine einstellung.
                • Ro75
                  Die "Updateverwaltung" wurde bei der Installation umgebogen. Die primäre Kontrolle hat OMV, was für meine Begriffe auch korrekt ist.
                  Von meiner Seite nur ein Überlegung. Letztlich ist es deine Entscheidung.
                  Ro75.
                  81.1k
