    4. Installation
    5. Tokenerstellung, Importfehler
      mpfistda last edited by mpfistda
      Guten Tag,
      Rasphberrypi 5
      Plattform: linux
      RAM: 3.9 GB
      Node.js: v20.17.0
      NPM: 10.8.2
      Mehrere Neuinstallationen des Homematic IP Adapters Version 1.23.3
      Der Button Token Erstellung erscheint einfach nicht !
      Hier das Logfile:
      Nachricht
      host.raspberrypi
      2024-09-17 08:18:22.555	info	instance system.adapter.hmip.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      hmip.0
      2024-09-17 08:18:22.539	info	terminating
      host.raspberrypi
      2024-09-17 08:18:22.077	info	stopInstance system.adapter.hmip.0 send kill signal
      hmip.0
      2024-09-17 08:18:22.038	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      hmip.0
      2024-09-17 08:18:22.037	info	terminating
      hmip.0
      2024-09-17 08:18:22.037	info	cleaned everything up...
      hmip.0
      2024-09-17 08:18:22.036	info	Got terminate signal TERMINATE_YOURSELF
      host.raspberrypi
      2024-09-17 08:18:22.033	info	stopInstance system.adapter.hmip.0 (force=false, process=true)
      host.raspberrypi
      2024-09-17 08:18:22.033	info	"system.adapter.hmip.0" disabled
      hmip.0
      2024-09-17 08:18:13.935	info	token not yet created
      hmip.0
      2024-09-17 08:18:13.925	info	starting. Version 1.23.3 in /opt/iobroker/node_modules/iobroker.hmip, node: v20.17.0, js-controller: 6.0.11
      host.raspberrypi
      2024-09-17 08:18:13.198	info	instance system.adapter.hmip.0 in version "1.23.3" started with pid 2781
      host.raspberrypi
      2024-09-17 08:18:13.007	info	"system.adapter.hmip.0" enabled
      Ich habe noch folgenden Fehler als Text im Fenster bekommen:
      Cannot import from custom/customComponents.js: ChunkLoadError: Loading chunk vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_capitalize_capitalize_js-node-bfcaa8 failed. (error: http://192.168.2.54:8081/adapter/hmip/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_capitalize_capitalize_js-node-bfcaa8.475177e7.chunk.js)
      HMIP Token-Daten
      Auch andere Versionen wollen nicht funktionieren, welchem Problem sitze ich auf ??
        Homoran Global Moderator Administrators @mpfistda last edited by
        @mpfistda sagte in Keine Tokenerstellung möglich:
        bitte Threadtitel anpassen.
        zu diesem Thema gibt es bereits einige Beiträge.
        81.1k
