    3. Entwicklung
    4. Fehlermeldungen (dev-server) beim öffen der Config
    • Ben1983
      Ben1983 last edited by
      Hallo, wenn ich im dev-server den Adapter laufen lasse, bekomme ich seit heute folgende Fehlermeldungen beim Öffnen der Konfiguration des Adapters:
      strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/aliveProps" (strictTypes)
      strict mode: missing type "object" for keyword "properties" at "#/definitions/aliveProps" (strictTypes)
      strict mode: missing type "object" for keyword "required" at "#/definitions/qrCodeProps" (strictTypes)
      strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/qrCodeProps" (strictTypes)
      strict mode: missing type "object" for keyword "properties" at "#/definitions/qrCodeProps" (strictTypes)
      strict mode: missing type "object" for keyword "required" at "#/definitions/cronProps" (strictTypes)
      strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/cronProps" (strictTypes)
      strict mode: missing type "object" for keyword "properties" at "#/definitions/cronProps" (strictTypes)
      strict mode: missing type "object" for keyword "required" at "#/definitions/cronProps/oneOf/0" (strictTypes)
      strict mode: required property "complex" is not defined at "#/definitions/cronProps/oneOf/0" (strictRequired)
      strict mode: missing type "object" for keyword "required" at "#/definitions/cronProps/oneOf/1" (strictTypes)
      strict mode: required property "simple" is not defined at "#/definitions/cronProps/oneOf/1" (strictRequired)
      strict mode: missing type "object" for keyword "required" at "#/definitions/deviceManagerProps" (strictTypes)
      strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/deviceManagerProps" (strictTypes)
      strict mode: missing type "object" for keyword "properties" at "#/definitions/deviceManagerProps" (strictTypes)
      strict mode: missing type "object" for keyword "required" at "#" (strictTypes)
      strict mode: missing type "object" for keyword "additionalProperties" at "#" (strictTypes)
      strict mode: missing type "object" for keyword "properties" at "#" (strictTypes)
      strict mode: required property "en" is not defined at "#/definitions/multilingual" (strictRequired)
      strict mode: use allowUnionTypes to allow union type keyword at "#/properties/width" (strictTypes)
      strict mode: required property "items" is not defined at "#/items/allOf/10/then/allOf/1/oneOf/0" (strictRequired)
      strict mode: required property "#include" is not defined at "#/items/allOf/10/then/allOf/1/oneOf/1" (strictRequired)
      strict mode: missing type "object" for keyword "required" at "#/definitions/aliveProps" (strictTypes)
      Ist da was am Schema angepasst worden?
      MartinP OliverIO 2 Replies Last reply Reply Quote 0
      • MartinP
        MartinP @Ben1983 last edited by
        @ben1983 Sieht ja fast so aus, als ob da jemand untaugliche Auskommentierungen vorgenommen hat 😉
        Ben1983 2 Replies Last reply Reply Quote 0
        • Ben1983
          Ben1983 @MartinP last edited by
          @martinp OK, ich wüsste aber bei mir nicht wo.
          Auch der Lint check ist ok
          • Ben1983
            @martinp Also ich gehe mal ganz stark davon aus, dass es ein generelles schema problem ist, denn:
            Ich habe gerade einen anderen Adapter im dev-server gestartet, an dem ich schon ewig nichts geändert habe und da tritt es auch auf.
            • OliverIO
              OliverIO @Ben1983 last edited by
              @ben1983
              das ist schon eine ganze weile so
              Ben1983 1 Reply Last reply Reply Quote 0
              • Ben1983
                Ben1983 @OliverIO last edited by
                @oliverio OK. definiere ganze Weile.
                Letzte Woche war es zumindest bei mir definitiv noch nicht so.
                • OliverIO
                  @ben1983
                  exakt weiß ich es nicht, aber mehrere monate sind es schon.
                  ich habe das gefühl das es mit der build-kette react zu tun hat
                  • Ben1983
                    @oliverio OK. Ich habe es jetzt mal ignoriert und einen neuen patch erzeugt.
                    OliverIO mcm1957 2 Replies Last reply Reply Quote 0
                    • OliverIO
                      OliverIO @Ben1983 last edited by OliverIO
                      @ben1983
                      ja genau, so hab ich das auch gemacht.
                      ich habe auch gelernt das sich issue anlegen nicht lohnt, da es eh nicht bearbeitet wird bzw. einfach unbearbeitet geschlossen wird.
                      aber wahrscheinlich hab ich da einen fehler gemacht oder mich geirrt.
                      hatte zumindest auch was mit einem schema zu tun
                      • mcm1957
                        mcm1957 @Ben1983 last edited by
                        @ben1983 said in Fehlermeldungen (dev-server) beim öffen der Config:
                        Hast du den Fehler nur mit dem dev-server oder auch der normale Adapter?
                        Wenn der Fehler auch bei einem normal installierten Adapter auftritt, geh dem Problem bite nach . Da stimmte dann entweder was bei deinem jsonConfig nicht oder es ist ein Fehler im Prüfschema. Falls Letzteres vermutet wird, mach bitte ein Issue auf (https://github.com/ioBroker/adapter-react-v5/issues/new/choose) und ignorier mal OliversIO's unqualifizierten Output. Keine Ahnung was ihm über die Leber gelaufen ist - wie man so schön sagt.
                        • apollon77
                          apollon77 @OliverIO last edited by
                          @oliverio
                          Dann hast Du leider was falsches gelernt. Unbearbeitet schließen kenne ich an sich nicht. Lange Bearbeitungsgebühr hängen von verschiedenen details ab und das generell zu diskutieren macht wenig Sinn.
                          • OliverIO
                            OliverIO @apollon77 last edited by
                            @apollon77
                            https://github.com/ioBroker/ioBroker.js-controller/issues/2818
                            Ich habe gesehen, mcm hat mittlerweile dann wohl den Issue bei vis2 erfasst..
                            Wie gesagt, issue schließen, ohne commit oder entsprechenden Kommentar fördert nicht unbedingt die Motivationen oder Mitarbeit der community
                            Wenn ein issue im falschen Repo ist, könnt ihr ihn ja auch verschieben.
                            Aber wie gesagt, wahrscheinlich hab ich was falsch gemacht
                            oweitman created this issue in ioBroker/ioBroker.js-controller
                            closed [bug]: incorrect schema for io-package.json #2818
                              MCU last edited by MCU
                              Ich hänge mich mal hier dran.
                              Versuche mal ein wenig mit dem dev-server.
                              Mir fehlt so ein wenig die Info, in welcher Datei was drin stehen muss damit es ohne Probleme läuft.
                              Meine Problemchen sind:
                              • auch wie oben beschrieben jede Menge an error-Anzeigen
                              2024-11-02 00:41:59.275  - debug: host.dev-jarvis-extensions-iobroker-dev Incoming Host message getHostInfo
                              strict mode: missing type "object" for keyword "properties" at "#/if" (strictTypes)
                              strict mode: required property "items" is not defined at "#/properties/items/patternProperties/%5E.%2B/allOf/9/then/oneOf/0" (strictRequired)
                              strict mode: required property "#include" is not defined at "#/properties/items/patternProperties/%5E.%2B/allOf/9/then/oneOf/1" (strictRequired)
                              strict mode: required property "items" is not defined at "#/patternProperties/%5E.%2B/allOf/9/then/oneOf/0" (strictRequired)
                              strict mode: required property "#include" is not defined at "#/patternProperties/%5E.%2B/allOf/9/then/oneOf/1" (strictRequired)
                              strict mode: missing type "object" for keyword "required" at "#/definitions/sendToProps" (strictTypes)
                              strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/sendToProps" (strictTypes)
                              strict mode: missing type "object" for keyword "properties" at "#/definitions/sendToProps" (strictTypes)
                              strict mode: missing type "object" for keyword "required" at "#/definitions/stateProps" (strictTypes)
                              strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/stateProps" (strictTypes)
                              strict mode: missing type "object" for keyword "properties" at "#/definitions/stateProps" (strictTypes)
                              strict mode: missing type "object" for keyword "required" at "#/definitions/passwordProps" (strictTypes)
                              strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/passwordProps" (strictTypes)
                              strict mode: missing type "object" for keyword "properties" at "#/definitions/passwordProps" (strictTypes)
                              strict mode: missing type "object" for keyword "required" at "#/definitions/checkboxProps" (strictTypes)
                              strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/checkboxProps" (strictTypes)
                              strict mode: missing type "object" for keyword "properties" at "#/definitions/checkboxProps" (strictTypes)
                              strict mode: missing type "object" for keyword "required" at "#/definitions/fileSelectorProps" (strictTypes)
                              strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/fileSelectorProps" (strictTypes)
                              strict mode: missing type "object" for keyword "properties" at "#/definitions/fileSelectorProps" (strictTypes)
                              strict mode: missing type "object" for keyword "required" at "#/definitions/numberProps" (strictTypes)
                              strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/numberProps" (strictTypes)
                              strict mode: missing type "object" for keyword "properties" at "#/definitions/numberProps" (strictTypes)
                              strict mode: required property "complex" is not defined at "#/items/allOf/21/then/oneOf/0" (strictRequired)
                              strict mode: required property "simple" is not defined at "#/items/allOf/21/then/oneOf/1" (strictRequired)
                              strict mode: missing type "object" for keyword "required" at "#/definitions/certificatesProps" (strictTypes)
                              strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/certificatesProps" (strictTypes)
                              strict mode: missing type "object" for keyword "properties" at "#/definitions/certificatesProps" (strictTypes)
                              strict mode: missing type "object" for keyword "required" at "#/definitions/instanceProps" (strictTypes)
                              strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/instanceProps" (strictTypes)
                              strict mode: missing type "object" for keyword "properties" at "#/definitions/instanceProps" (strictTypes)
                              strict mode: missing type "object" for keyword "required" at "#/definitions/objectIdProps" (strictTypes)
                              strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/objectIdProps" (strictTypes)
                              strict mode: missing type "object" for keyword "properties" at "#/definitions/objectIdProps" (strictTypes)
                              strict mode: missing type "object" for keyword "required" at "#/definitions/timePickerProps" (strictTypes)
                              strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/timePickerProps" (strictTypes)
                              strict mode: missing type "object" for keyword "properties" at "#/definitions/timePickerProps" (strictTypes)
                              strict mode: missing type "object" for keyword "required" at "#/definitions/coordinatesProps" (strictTypes)
                              strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/coordinatesProps" (strictTypes)
                              strict mode: missing type "object" for keyword "properties" at "#/definitions/coordinatesProps" (strictTypes)
                              strict mode: missing type "object" for keyword "required" at "#/definitions/interfaceProps" (strictTypes)
                              strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/interfaceProps" (strictTypes)
                              strict mode: missing type "object" for keyword "properties" at "#/definitions/interfaceProps" (strictTypes)
                              Als schema habe ich
                              "$schema": "http://json-schema.org/draft-07/schema#",
                              ist das richtig? oder muss da was anderes hinein?
                              https://github.com/ioBroker/adapter-react-v5/blob/main/schemas/jsonConfig.json
                              • habe beim Creator fälschlicherweise VIS angeklickt, jetzt bekomme ich den Fehler
                                -> wie bekomme ich den wieder weg? Möchte erstmal nicht mit / für VIS entwickeln
                                wo steht der entsprechende Eintrag in der io-package.json / package,json ?
                              2024-11-02 00:42:04.096  - error: host.dev-jarvis-extensions-iobroker-dev cannot call visUtils: Not exists
                              • Warum werden die Dateien im .devserver-Verzeichnis nicht aktualisiert? Bzw. wie werden sie dort aktualisiert?
                                Welcher Befehl muss genutzt werden?
                              .devserver
                              admin
                              ich ändere im admin-Verzeichnis und rufe dann dev-server watch im Adapter-Ordner auf.
                              • Wo finde ich die zugehörige Datei? dev-jarvis-extensions-iobroker-dev
                              startInstance system.adapter.jarvis-extensions.0 Adapter dependency not fulfilled on "dev-jarvis-extensions-iobroker-dev": required adapter "vis" not found!
                              /* es scheint mit der package.json im .devserver zusammenzuhängen */
                              /* package.json, dort muss der iobroker.vis-Eintrag sehr wahrscheinlich raus */
                                  "name":"dev-server.jarvis-extensions",
                                  "version":"1.0.0",
                                  "private":true,
                                  "dependencies":{
                                      "iobroker.admin":"latest",
                                      "iobroker.backitup":"3.0.26",
                                      "iobroker.jarvis-extensions":"file:../../iobroker.jarvis-extensions-0.0.1.tgz",
                                      "iobroker.js-controller":"latest",
                                      "iobroker.socketio":"6.7.1",
                                      "iobroker.vis":"1.5.6",
                                      "iobroker.web":"6.3.1",
                                      "iobroker.ws":"2.6.2"
                                  "dev-server":{
                                      "adminPort":8081,
                                      "useSymlinks":false
                                  "overrides":{
                                      "@iobroker/adapter-core":"^3.2.1"
                              /* irgendwie doch nicht */
                              system.adapter.jarvis-extensions.0 [sameHostDependency]: {"js-controller":">=3.3.22","vis":"*"}
                              Vielen Dank
                              • OliverIO
                                OliverIO @MCU last edited by
                                ich versuche mal, soweit ich weiß
                                @mcu sagte in Fehlermeldungen (dev-server) beim öffen der Config:
                                die erscheinen nur bei der entwicklung, die kannst du ignorieren. ich glaube, die müssten weg sein, wenn m,an auf "@iobroker/adapter-core": "^3.2.2", aktualisiert.
                                wo hast du das schema?
                                wenn du die vscode settings meinst, habe ich dort das drin stehen (ausschnitt).
                                das wirkt aber nur im editor. beim build prozess hat das keine auswirkungen
                                Als schema habe ich
                                    "json.schemas": [
                                            "fileMatch": ["io-package.json"],
                                            "url": "https://raw.githubusercontent.com/ioBroker/ioBroker.js-controller/master/schemas/io-package.json"
                                            "fileMatch": ["admin/jsonConfig.json", "admin/jsonCustom.json", "admin/jsonTab.json"],
                                            "url": "https://raw.githubusercontent.com/ioBroker/adapter-react-v5/main/schemas/jsonConfig.json"
                                verzeichnis widget löschen
                                und in datei io-package.json
                                bei dependencies vis entfernen
                                was soll dieser schnipfel sagen, wahrscheinlich hängt das mit der dependency in package.json weiter unten zusammen.
                                wann wird etwas nicht aktualisiert wenn du WAS machst?
                                package.json und io-package.json wird nicht automatisch im dev-server aktualisiert
                                da muss man dann mit dem dev-server upload machen.
                                ansonsten werden alle anderen dateien eigentlich schon aktualisiert (admin, adapter und auch widget-dateien für vis, bei letzterem muss man aber noch was machen, aber das brauchst du ja nicht.)
                                lokal auf der festplatte des erstellers. in der package.json siehst du ja die dependency
                                diese zeigt auf die eigene festplatte. das macht man aus gründen der dynamischen entwicklung, wenn man separate repositories für bestimmte anteile verwendet. sollte beim publish aber aufgelöst werden, da das nie für andere funktionieren kann.
                                • mcm1957
                                  mcm1957 @MCU last edited by
                                  @mcu
                                  Generell sind Fragen zur Entwicklung / Entwicklungsumgebung in unseren Telegram Channels (Invites unter hhtps://www.iobroker.dev) besser aufgehoben da sie dort Entwickeler gezielter erreichen.
                                  Inwieweit der dev-server zur Entwicklung von REACT taugt stell ich jetzt mal als Frage in den Raum. Wirkliche React Kenner gibt es nur seeehr wenige.
                                  OliverIO M 2 Replies Last reply Reply Quote 1
                                  • OliverIO
                                    OliverIO @mcm1957 last edited by
                                    @mcm1957
                                    Mit dem dev-Server kann man mit react entwickeln.
                                    Will er glaube ich auch nicht
                                      MCU @OliverIO last edited by MCU
                                      @oliverio
                                      Zunächst ein großes Dankeschön für die ganzen Infos. Ich taste mich langsam ran.
                                      package,json
                                      trotzdem kommen die Warnungen / Errors
                                      Ich musste das $schema in der iopackage.json eintragen, sonst kam immer ein Fehler beim Adapter-Check
                                      Ich dachte, wenn ich z.B. das Icon im admin-Verzeichnis ändere, dass dann mit dev-server watch, das Icon auch im dev-server angepasst wird. Anscheinend ja nur mit dev-server upload. Muss ich jetzt mal alles probleren.
                                      Ok, aber die Datei wird wodurch erzeugt? Ich finde diese nicht.
                                      Wird durch das build erstellt
                                        MCU @mcm1957 last edited by
                                        @mcm1957
                                        Ich will zunächst den Umgang mit Adapter-Entwicklung kennenlernen. Wenn dazu auch react notwendig ist, was ja auch in jarvis genutzt wird, werde ich dies auch versuchen.
                                        Den Telegram Channel werden ich nutzen, danke für die Info.
                                          @oliverio react ist sicherlich auch irgendwann ein Thema. Aber erstmal eins nach dem anderen.
                                          • mcm1957
                                            mcm1957 @MCU last edited by mcm1957
                                            @mcu said in Fehlermeldungen (dev-server) beim öffen der Config:
                                            $schema gehört definitiv NICHT in io-package.json. Schmeiß das wieder raus.
                                            Welchen Fehler lieferte der Adapter Checker?
                                            1911
