    4. Ikea Styrbar "long press arrow" wird nicht erkannt
    • E
      el-lutschi last edited by el-lutschi
      ich habe mir eine Ikea Styrbar Fernbedienung zugelegt. Nach einigem hin und her habe ich die Fernbedienung nun mit dem Sonoff Zigbee Dongle Plus und dem zigbee Adapter verbunden. Es funktioniert auch eigentlich alles, bis auf die beiden "long press arrow" Funktionen. Hier bleibt der Datenpunkt-Wert immer "null". Über die Logs des Zigbee Adapter konnte ich herausfinden, dass der long press zwar von der Fernbedienung gesendet wird, aber kein pubilsh stattfindet (siehe Logs).
      Logs
      Funktionierendes Tastendruck
      zigbee.0
      2024-10-01 11:22:18.989	debug	Publish {"action":"brightness_stop"} to "0ceff6fffeb5b04a"
      zigbee.0
      2024-10-01 11:22:18.977	debug	Type commandStop device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":26,"_applicationVersion":1,"_dateCode":"20221028","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":2080,"inputClusters":[0,1,3,32,4096,64599,64636],"outputClusters":[3,5,6,8,25,4096],"profileID":260,"ID":1,"clusters":{"genBasic":{"attributes":{"modelId":"Remote Control N2","manufacturerName":"IKEA of Sweden","powerSource":3,"zclVersion":8,"appVersion":1,"stackVersion":106,"hwVersion":1,"dateCode":"20221028","swBuildId":"2.4.5"}},"genPollCtrl":{"attributes":{"checkinInterval":172800}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":190}}},"deviceIeeeAddress":"0x0ceff6fffeb5b04a","deviceNetworkAddress":53947,"_binds":[{"cluster":32,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c0a9ae","endpointID":1},{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c0a9ae","endpointID":1},{"cluster":8,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c0a9ae","endpointID":1},{"cluster":5,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c0a9ae","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c0a9ae","endpointID":1}],"_configuredReportings":[{"cluster":1,"attrId":33,"minRepIntval":3600,"maxRepIntval":65000,"repChange":10,"manufacturerCode":null}],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x0ceff6fffeb5b04a"}}],"_hardwareVersion":1,"_ieeeAddr":"0x0ceff6fffeb5b04a","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1727774538973,"_manufacturerID":4476,"_manufacturerName":"IKEA of Sweden","_modelID":"Remote Control N2","_networkAddress":53947,"_powerSource":"Battery","_softwareBuildID":"2.4.5","_stackVersion":106,"_type":"EndDevice","_zclVersion":8,"_linkquality":127,"_skipDefaultResponse":false,"_lastDefaultResponseSequenceNumber":28,"_checkinInterval":43200,"_pendingRequestTimeout":43200000,"meta":{"configured":1889700129}},"mapped":{"toZigbee":[{"key":["identify"],"options":[{"name":"identify_timeout","label":"Identify timeout","access":2,"type":"numeric","property":"identify_timeout","description":"Sets the duration of the identification procedure in seconds (i.e., how long the device would flash).The value ranges from 1 to 30 seconds (default: 3).","value_max":30,"value_min":1}]},{"key":["battery"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["scene_rename"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]},{"key":["zclcommand"]}],"fromZigbee":[{"cluster":"genOnOff","type":"commandOn"},{"cluster":"genOnOff","type":["commandOn","commandOff","commandOffWithEffect","commandToggle"]},{"cluster":"genLevelCtrl","type":["commandMoveToLevel","commandMoveToLevelWithOnOff"],"options":[{"name":"simulated_brightness","label":"Simulated brightness","access":2,"type":"composite","property":"simulated_brightness","description":"Simulate a brightness value. If this device provides a brightness_move_up or brightness_move_down action it is possible to specify the update interval and delta. The action_brightness_delta indicates the delta for each interval. ","features":[{"name":"delta","label":"Delta","access":2,"type":"numeric","property":"delta","description":"Delta per interval, 20 by default","value_min":0},{"name":"interval","label":"Interval","access":2,"type":"numeric","property":"interval","description":"Interval duration","unit":"ms","value_min":0}]}]},{"cluster":"genLevelCtrl","type":["commandMove","commandMoveWithOnOff"],"options":[{"name":"simulated_brightness","label":"Simulated brightness","access":2,"type":"composite","property":"simulated_brightness","description":"Simulate a brightness value. If this device provides a brightness_move_up or brightness_move_down action it is possible to specify the update interval and delta. The action_brightness_delta indicates the delta for each interval. ","features":[{"name":"delta","label":"Delta","access":2,"type":"numeric","property":"delta","description":"Delta per interval, 20 by default","value_min":0},{"name":"interval","label":"Interval","access":2,"type":"numeric","property":"interval","description":"Interval duration","unit":"ms","value_min":0}]}]},{"cluster":"genLevelCtrl","type":["commandStep","commandStepWithOnOff"],"options":[{"name":"simulated_brightness","label":"Simulated brightness","access":2,"type":"composite","property":"simulated_brightness","description":"Simulate a brightness value. If this device provides a brightness_move_up or brightness_move_down action it is possible to specify the update interval and delta. The action_brightness_delta indicates the delta for each interval. ","features":[{"name":"delta","label":"Delta","access":2,"type":"numeric","property":"delta","description":"Delta per interval, 20 by default","value_min":0},{"name":"interval","label":"Interval","access":2,"type":"numeric","property":"interval","description":"Interval duration","unit":"ms","value_min":0}]}]},{"cluster":"genLevelCtrl","type":["commandStop","commandStopWithOnOff"],"options":[{"name":"simulated_brightness","label":"Simulated brightness","access":2,"type":"composite","property":"simulated_brightness","description":"Simulate a brightness value. If this device provides a brightness_move_up or brightness_move_down action it is possible to specify the update interval and delta. The action_brightness_delta indicates the delta for each interval. ","features":[{"name":"delta","label":"Delta","access":2,"type":"numeric","property":"delta","description":"Delta per interval, 20 by default","value_min":0},{"name":"interval","label":"Interval","access":2,"type":"numeric","property":"interval","description":"Interval duration","unit":"ms","value_min":0}]}]},{"cluster":"genScenes","type":"commandTradfriArrowSingle"},{"cluster":"genScenes","type":"commandTradfriArrowRelease","options":[{"name":"legacy","label":"Legacy","access":2,"type":"binary","property":"legacy","description":"Set to false to disable the legacy integration (highly recommended), will change structure of the published payload (default true).","value_on":true,"value_off":false}]},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"exposes":[{"name":"identify","label":"Identify","access":2,"type":"enum","property":"identify","description":"Initiate device identification. This device is asleep by default.You may need to wake it up first before sending the indetify command.","category":"config","values":["identify"]},{"name":"battery","label":"Battery","access":5,"type":"numeric","property":"battery","description":"Remaining battery in %","category":"diagnostic","unit":"%","value_max":100,"value_min":0},{"name":"action","label":"Action","access":1,"type":"enum","property":"action","description":"Triggered action (e.g. a button click)","category":"diagnostic","values":["on","off","brightness_move_up","brightness_move_down","brightness_stop","arrow_left_click","arrow_left_hold","arrow_left_release","arrow_right_click","arrow_right_hold","arrow_right_release"]},{"name":"linkquality","label":"Linkquality","access":1,"type":"numeric","property":"linkquality","description":"Link quality (signal strength)","category":"diagnostic","unit":"lqi","value_max":255,"value_min":0}],"ota":{},"zigbeeModel":["Remote Control N2"],"model":"E2001/E2002","vendor":"IKEA","description":"STYRBAR remote control","options":["[Circular]","[Circular]","[Circular]"]},"name":"0x0ceff6fffeb5b04a"} incoming event: {"type":"commandStop","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":26,"_applicationVersion":1,"_dateCode":"20221028","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":2080,"inputClusters":[0,1,3,32,4096,64599,64636],"outputClusters":[3,5,6,8,25,4096],"profileID":260,"ID":1,"clusters":{"genBasic":{"attributes":{"modelId":"Remote Control N2","manufacturerName":"IKEA of Sweden","powerSource":3,"zclVersion":8,"appVersion":1,"stackVersion":106,"hwVersion":1,"dateCode":"20221028","swBuildId":"2.4.5"}},"genPollCtrl":{"attributes":{"checkinInterval":172800}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":190}}},"deviceIeeeAddress":"0x0ceff6fffeb5b04a","deviceNetworkAddress":53947,"_binds":[{"cluster":32,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c0a9ae","endpointID":1},{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c0a9ae","endpointID":1},{"cluster":8,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c0a9ae","endpointID":1},{"cluster":5,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c0a9ae","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c0a9ae","endpointID":1}],"_configuredReportings":[{"cluster":1,"attrId":33,"minRepIntval":3600,"maxRepIntval":65000,"repChange":10,"manufacturerCode":null}],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x0ceff6fffeb5b04a"}}],"_hardwareVersion":1,"_ieeeAddr":"0x0ceff6fffeb5b04a","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1727774538973,"_manufacturerID":4476,"_manufacturerName":"IKEA of Sweden","_modelID":"Remote Control N2","_networkAddress":53947,"_powerSource":"Battery","_softwareBuildID":"2.4.5","_stackVersion":106,"_type":"EndDevice","_zclVersion":8,"_linkquality":127,"_skipDefaultResponse":false,"_lastDefaultResponseSequenceNumber":28,"_checkinInterval":43200,"_pendingRequestTimeout":43200000,"meta":{"configured":1889700129}},"endpoint":"[Circular]","data":{},"linkquality":127,"groupID":0,"cluster":"genLevelCtrl","meta":{"zclTransactionSequenceNumber":28,"manufacturerCode":null,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":false,"reservedBits":0}}}
      zigbee.0
      2024-10-01 11:22:18.975	debug	Received Zigbee message from '0x0ceff6fffeb5b04a', type 'commandStop', cluster 'genLevelCtrl', data '{}' from endpoint 1 with groupID 0
      zigbee.0
      2024-10-01 11:22:18.974	debug	handleMessage. {"type":"commandStop","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":26,"_applicationVersion":1,"_dateCode":"20221028","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":2080,"inputClusters":[0,1,3,32,4096,64599,64636],"outputClusters":[3,5,6,8,25,4096],"profileID":260,"ID":1,"clusters":{"genBasic":{"attributes":{"modelId":"Remote Control N2","manufacturerName":"IKEA of Sweden","powerSource":3,"zclVersion":8,"appVersion":1,"stackVersion":106,"hwVersion":1,"dateCode":"20221028","swBuildId":"2.4.5"}},"genPollCtrl":{"attributes":{"checkinInterval":172800}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":190}}},"deviceIeeeAddress":"0x0ceff6fffeb5b04a","deviceNetworkAddress":53947,"_binds":[{"cluster":32,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c0a9ae","endpointID":1},{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c0a9ae","endpointID":1},{"cluster":8,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c0a9ae","endpointID":1},{"cluster":5,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c0a9ae","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c0a9ae","endpointID":1}],"_configuredReportings":[{"cluster":1,"attrId":33,"minRepIntval":3600,"maxRepIntval":65000,"repChange":10,"manufacturerCode":null}],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x0ceff6fffeb5b04a"}}],"_hardwareVersion":1,"_ieeeAddr":"0x0ceff6fffeb5b04a","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1727774538973,"_manufacturerID":4476,"_manufacturerName":"IKEA of Sweden","_modelID":"Remote Control N2","_networkAddress":53947,"_powerSource":"Battery","_softwareBuildID":"2.4.5","_stackVersion":106,"_type":"EndDevice","_zclVersion":8,"_linkquality":127,"_skipDefaultResponse":false,"_lastDefaultResponseSequenceNumber":27,"_checkinInterval":43200,"_pendingRequestTimeout":43200000,"meta":{"configured":1889700129}},"endpoint":"[Circular]","data":{},"linkquality":127,"groupID":0,"cluster":"genLevelCtrl","meta":{"zclTransactionSequenceNumber":28,"manufacturerCode":null,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":false,"reservedBits":0}}}
      zigbee.0
      2024-10-01 11:22:18.077	debug	Publish {"action":"brightness_move_down","action_rate":83} to "0ceff6fffeb5b04a"
      zigbee.0
      2024-10-01 11:22:18.071	debug	Type commandMove device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":26,"_applicationVersion":1,"_dateCode":"20221028","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":2080,"inputClusters":[0,1,3,32,4096,64599,64636],"outputClusters":[3,5,6,8,25,4096],"profileID":260,"ID":1,"clusters":{"genBasic":{"attributes":{"modelId":"Remote Control N2","manufacturerName":"IKEA of Sweden","powerSource":3,"zclVersion":8,"appVersion":1,"stackVersion":106,"hwVersion":1,"dateCode":"20221028","swBuildId":"2.4.5"}},"genPollCtrl":{"attributes":{"checkinInterval":172800}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":190}}},"deviceIeeeAddress":"0x0ceff6fffeb5b04a","deviceNetworkAddress":53947,"_binds":[{"cluster":32,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c0a9ae","endpointID":1},{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c0a9ae","endpointID":1},{"cluster":8,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c0a9ae","endpointID":1},{"cluster":5,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c0a9ae","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c0a9ae","endpointID":1}],"_configuredReportings":[{"cluster":1,"attrId":33,"minRepIntval":3600,"maxRepIntval":65000,"repChange":10,"manufacturerCode":null}],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x0ceff6fffeb5b04a"}}],"_hardwareVersion":1,"_ieeeAddr":"0x0ceff6fffeb5b04a","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1727774538067,"_manufacturerID":4476,"_manufacturerName":"IKEA of Sweden","_modelID":"Remote Control N2","_networkAddress":53947,"_powerSource":"Battery","_softwareBuildID":"2.4.5","_stackVersion":106,"_type":"EndDevice","_zclVersion":8,"_linkquality":123,"_skipDefaultResponse":false,"_lastDefaultResponseSequenceNumber":27,"_checkinInterval":43200,"_pendingRequestTimeout":43200000,"meta":{"configured":1889700129}},"mapped":{"toZigbee":[{"key":["identify"],"options":[{"name":"identify_timeout","label":"Identify timeout","access":2,"type":"numeric","property":"identify_timeout","description":"Sets the duration of the identification procedure in seconds (i.e., how long the device would flash).The value ranges from 1 to 30 seconds (default: 3).","value_max":30,"value_min":1}]},{"key":["battery"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["scene_rename"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]},{"key":["zclcommand"]}],"fromZigbee":[{"cluster":"genOnOff","type":"commandOn"},{"cluster":"genOnOff","type":["commandOn","commandOff","commandOffWithEffect","commandToggle"]},{"cluster":"genLevelCtrl","type":["commandMoveToLevel","commandMoveToLevelWithOnOff"],"options":[{"name":"simulated_brightness","label":"Simulated brightness","access":2,"type":"composite","property":"simulated_brightness","description":"Simulate a brightness value. If this device provides a brightness_move_up or brightness_move_down action it is possible to specify the update interval and delta. The action_brightness_delta indicates the delta for each interval. ","features":[{"name":"delta","label":"Delta","access":2,"type":"numeric","property":"delta","description":"Delta per interval, 20 by default","value_min":0},{"name":"interval","label":"Interval","access":2,"type":"numeric","property":"interval","description":"Interval duration","unit":"ms","value_min":0}]}]},{"cluster":"genLevelCtrl","type":["commandMove","commandMoveWithOnOff"],"options":[{"name":"simulated_brightness","label":"Simulated brightness","access":2,"type":"composite","property":"simulated_brightness","description":"Simulate a brightness value. If this device provides a brightness_move_up or brightness_move_down action it is possible to specify the update interval and delta. The action_brightness_delta indicates the delta for each interval. ","features":[{"name":"delta","label":"Delta","access":2,"type":"numeric","property":"delta","description":"Delta per interval, 20 by default","value_min":0},{"name":"interval","label":"Interval","access":2,"type":"numeric","property":"interval","description":"Interval duration","unit":"ms","value_min":0}]}]},{"cluster":"genLevelCtrl","type":["commandStep","commandStepWithOnOff"],"options":[{"name":"simulated_brightness","label":"Simulated brightness","access":2,"type":"composite","property":"simulated_brightness","description":"Simulate a brightness value. If this device provides a brightness_move_up or brightness_move_down action it is possible to specify the update interval and delta. The action_brightness_delta indicates the delta for each interval. ","features":[{"name":"delta","label":"Delta","access":2,"type":"numeric","property":"delta","description":"Delta per interval, 20 by default","value_min":0},{"name":"interval","label":"Interval","access":2,"type":"numeric","property":"interval","description":"Interval duration","unit":"ms","value_min":0}]}]},{"cluster":"genLevelCtrl","type":["commandStop","commandStopWithOnOff"],"options":[{"name":"simulated_brightness","label":"Simulated brightness","access":2,"type":"composite","property":"simulated_brightness","description":"Simulate a brightness value. If this device provides a brightness_move_up or brightness_move_down action it is possible to specify the update interval and delta. The action_brightness_delta indicates the delta for each interval. ","features":[{"name":"delta","label":"Delta","access":2,"type":"numeric","property":"delta","description":"Delta per interval, 20 by default","value_min":0},{"name":"interval","label":"Interval","access":2,"type":"numeric","property":"interval","description":"Interval duration","unit":"ms","value_min":0}]}]},{"cluster":"genScenes","type":"commandTradfriArrowSingle"},{"cluster":"genScenes","type":"commandTradfriArrowRelease","options":[{"name":"legacy","label":"Legacy","access":2,"type":"binary","property":"legacy","description":"Set to false to disable the legacy integration (highly recommended), will change structure of the published payload (default true).","value_on":true,"value_off":false}]},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"exposes":[{"name":"identify","label":"Identify","access":2,"type":"enum","property":"identify","description":"Initiate device identification. This device is asleep by default.You may need to wake it up first before sending the indetify command.","category":"config","values":["identify"]},{"name":"battery","label":"Battery","access":5,"type":"numeric","property":"battery","description":"Remaining battery in %","category":"diagnostic","unit":"%","value_max":100,"value_min":0},{"name":"action","label":"Action","access":1,"type":"enum","property":"action","description":"Triggered action (e.g. a button click)","category":"diagnostic","values":["on","off","brightness_move_up","brightness_move_down","brightness_stop","arrow_left_click","arrow_left_hold","arrow_left_release","arrow_right_click","arrow_right_hold","arrow_right_release"]},{"name":"linkquality","label":"Linkquality","access":1,"type":"numeric","property":"linkquality","description":"Link quality (signal strength)","category":"diagnostic","unit":"lqi","value_max":255,"value_min":0}],"ota":{},"zigbeeModel":["Remote Control N2"],"model":"E2001/E2002","vendor":"IKEA","description":"STYRBAR remote control","options":["[Circular]","[Circular]","[Circular]"]},"name":"0x0ceff6fffeb5b04a"} incoming event: {"type":"commandMove","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":26,"_applicationVersion":1,"_dateCode":"20221028","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":2080,"inputClusters":[0,1,3,32,4096,64599,64636],"outputClusters":[3,5,6,8,25,4096],"profileID":260,"ID":1,"clusters":{"genBasic":{"attributes":{"modelId":"Remote Control N2","manufacturerName":"IKEA of Sweden","powerSource":3,"zclVersion":8,"appVersion":1,"stackVersion":106,"hwVersion":1,"dateCode":"20221028","swBuildId":"2.4.5"}},"genPollCtrl":{"attributes":{"checkinInterval":172800}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":190}}},"deviceIeeeAddress":"0x0ceff6fffeb5b04a","deviceNetworkAddress":53947,"_binds":[{"cluster":32,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c0a9ae","endpointID":1},{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c0a9ae","endpointID":1},{"cluster":8,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c0a9ae","endpointID":1},{"cluster":5,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c0a9ae","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c0a9ae","endpointID":1}],"_configuredReportings":[{"cluster":1,"attrId":33,"minRepIntval":3600,"maxRepIntval":65000,"repChange":10,"manufacturerCode":null}],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x0ceff6fffeb5b04a"}}],"_hardwareVersion":1,"_ieeeAddr":"0x0ceff6fffeb5b04a","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1727774538067,"_manufacturerID":4476,"_manufacturerName":"IKEA of Sweden","_modelID":"Remote Control N2","_networkAddress":53947,"_powerSource":"Battery","_softwareBuildID":"2.4.5","_stackVersion":106,"_type":"EndDevice","_zclVersion":8,"_linkquality":123,"_skipDefaultResponse":false,"_lastDefaultResponseSequenceNumber":27,"_checkinInterval":43200,"_pendingRequestTimeout":43200000,"meta":{"configured":1889700129}},"endpoint":"[Circular]","data":{"movemode":1,"rate":83},"linkquality":123,"groupID":0,"cluster":"genLevelCtrl","meta":{"zclTransactionSequenceNumber":27,"manufacturerCode":null,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":false,"reservedBits":0}}}
      zigbee.0
      2024-10-01 11:22:18.070	debug	Received Zigbee message from '0x0ceff6fffeb5b04a', type 'commandMove', cluster 'genLevelCtrl', data '{"movemode":1,"rate":83}' from endpoint 1 with groupID 0
      zigbee.0
      2024-10-01 11:22:18.067	debug	handleMessage. {"type":"commandMove","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":26,"_applicationVersion":1,"_dateCode":"20221028","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":2080,"inputClusters":[0,1,3,32,4096,64599,64636],"outputClusters":[3,5,6,8,25,4096],"profileID":260,"ID":1,"clusters":{"genBasic":{"attributes":{"modelId":"Remote Control N2","manufacturerName":"IKEA of Sweden","powerSource":3,"zclVersion":8,"appVersion":1,"stackVersion":106,"hwVersion":1,"dateCode":"20221028","swBuildId":"2.4.5"}},"genPollCtrl":{"attributes":{"checkinInterval":172800}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":190}}},"deviceIeeeAddress":"0x0ceff6fffeb5b04a","deviceNetworkAddress":53947,"_binds":[{"cluster":32,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c0a9ae","endpointID":1},{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c0a9ae","endpointID":1},{"cluster":8,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c0a9ae","endpointID":1},{"cluster":5,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c0a9ae","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c0a9ae","endpointID":1}],"_configuredReportings":[{"cluster":1,"attrId":33,"minRepIntval":3600,"maxRepIntval":65000,"repChange":10,"manufacturerCode":null}],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x0ceff6fffeb5b04a"}}],"_hardwareVersion":1,"_ieeeAddr":"0x0ceff6fffeb5b04a","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1727774538067,"_manufacturerID":4476,"_manufacturerName":"IKEA of Sweden","_modelID":"Remote Control N2","_networkAddress":53947,"_powerSource":"Battery","_softwareBuildID":"2.4.5","_stackVersion":106,"_type":"EndDevice","_zclVersion":8,"_linkquality":123,"_skipDefaultResponse":false,"_lastDefaultResponseSequenceNumber":26,"_checkinInterval":43200,"_pendingRequestTimeout":43200000,"meta":{"configured":1889700129}},"endpoint":"[Circular]","data":{"movemode":1,"rate":83},"linkquality":123,"groupID":0,"cluster":"genLevelCtrl","meta":{"zclTransactionSequenceNumber":27,"manufacturerCode":null,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":false,"reservedBits":0}}}
      Long press arrow
      zigbee.0
      2024-10-01 11:23:31.248	debug	Type commandOn device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":26,"_applicationVersion":1,"_dateCode":"20221028","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":2080,"inputClusters":[0,1,3,32,4096,64599,64636],"outputClusters":[3,5,6,8,25,4096],"profileID":260,"ID":1,"clusters":{"genBasic":{"attributes":{"modelId":"Remote Control N2","manufacturerName":"IKEA of Sweden","powerSource":3,"zclVersion":8,"appVersion":1,"stackVersion":106,"hwVersion":1,"dateCode":"20221028","swBuildId":"2.4.5"}},"genPollCtrl":{"attributes":{"checkinInterval":172800}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":190}}},"deviceIeeeAddress":"0x0ceff6fffeb5b04a","deviceNetworkAddress":53947,"_binds":[{"cluster":32,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c0a9ae","endpointID":1},{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c0a9ae","endpointID":1},{"cluster":8,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c0a9ae","endpointID":1},{"cluster":5,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c0a9ae","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c0a9ae","endpointID":1}],"_configuredReportings":[{"cluster":1,"attrId":33,"minRepIntval":3600,"maxRepIntval":65000,"repChange":10,"manufacturerCode":null}],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x0ceff6fffeb5b04a"}}],"_hardwareVersion":1,"_ieeeAddr":"0x0ceff6fffeb5b04a","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1727774611246,"_manufacturerID":4476,"_manufacturerName":"IKEA of Sweden","_modelID":"Remote Control N2","_networkAddress":53947,"_powerSource":"Battery","_softwareBuildID":"2.4.5","_stackVersion":106,"_type":"EndDevice","_zclVersion":8,"_linkquality":131,"_skipDefaultResponse":false,"_lastDefaultResponseSequenceNumber":30,"_checkinInterval":43200,"_pendingRequestTimeout":43200000,"meta":{"configured":1889700129}},"mapped":{"toZigbee":[{"key":["identify"],"options":[{"name":"identify_timeout","label":"Identify timeout","access":2,"type":"numeric","property":"identify_timeout","description":"Sets the duration of the identification procedure in seconds (i.e., how long the device would flash).The value ranges from 1 to 30 seconds (default: 3).","value_max":30,"value_min":1}]},{"key":["battery"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["scene_rename"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]},{"key":["zclcommand"]}],"fromZigbee":[{"cluster":"genOnOff","type":"commandOn"},{"cluster":"genOnOff","type":["commandOn","commandOff","commandOffWithEffect","commandToggle"]},{"cluster":"genLevelCtrl","type":["commandMoveToLevel","commandMoveToLevelWithOnOff"],"options":[{"name":"simulated_brightness","label":"Simulated brightness","access":2,"type":"composite","property":"simulated_brightness","description":"Simulate a brightness value. If this device provides a brightness_move_up or brightness_move_down action it is possible to specify the update interval and delta. The action_brightness_delta indicates the delta for each interval. ","features":[{"name":"delta","label":"Delta","access":2,"type":"numeric","property":"delta","description":"Delta per interval, 20 by default","value_min":0},{"name":"interval","label":"Interval","access":2,"type":"numeric","property":"interval","description":"Interval duration","unit":"ms","value_min":0}]}]},{"cluster":"genLevelCtrl","type":["commandMove","commandMoveWithOnOff"],"options":[{"name":"simulated_brightness","label":"Simulated brightness","access":2,"type":"composite","property":"simulated_brightness","description":"Simulate a brightness value. If this device provides a brightness_move_up or brightness_move_down action it is possible to specify the update interval and delta. The action_brightness_delta indicates the delta for each interval. ","features":[{"name":"delta","label":"Delta","access":2,"type":"numeric","property":"delta","description":"Delta per interval, 20 by default","value_min":0},{"name":"interval","label":"Interval","access":2,"type":"numeric","property":"interval","description":"Interval duration","unit":"ms","value_min":0}]}]},{"cluster":"genLevelCtrl","type":["commandStep","commandStepWithOnOff"],"options":[{"name":"simulated_brightness","label":"Simulated brightness","access":2,"type":"composite","property":"simulated_brightness","description":"Simulate a brightness value. If this device provides a brightness_move_up or brightness_move_down action it is possible to specify the update interval and delta. The action_brightness_delta indicates the delta for each interval. ","features":[{"name":"delta","label":"Delta","access":2,"type":"numeric","property":"delta","description":"Delta per interval, 20 by default","value_min":0},{"name":"interval","label":"Interval","access":2,"type":"numeric","property":"interval","description":"Interval duration","unit":"ms","value_min":0}]}]},{"cluster":"genLevelCtrl","type":["commandStop","commandStopWithOnOff"],"options":[{"name":"simulated_brightness","label":"Simulated brightness","access":2,"type":"composite","property":"simulated_brightness","description":"Simulate a brightness value. If this device provides a brightness_move_up or brightness_move_down action it is possible to specify the update interval and delta. The action_brightness_delta indicates the delta for each interval. ","features":[{"name":"delta","label":"Delta","access":2,"type":"numeric","property":"delta","description":"Delta per interval, 20 by default","value_min":0},{"name":"interval","label":"Interval","access":2,"type":"numeric","property":"interval","description":"Interval duration","unit":"ms","value_min":0}]}]},{"cluster":"genScenes","type":"commandTradfriArrowSingle"},{"cluster":"genScenes","type":"commandTradfriArrowRelease","options":[{"name":"legacy","label":"Legacy","access":2,"type":"binary","property":"legacy","description":"Set to false to disable the legacy integration (highly recommended), will change structure of the published payload (default true).","value_on":true,"value_off":false}]},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"exposes":[{"name":"identify","label":"Identify","access":2,"type":"enum","property":"identify","description":"Initiate device identification. This device is asleep by default.You may need to wake it up first before sending the indetify command.","category":"config","values":["identify"]},{"name":"battery","label":"Battery","access":5,"type":"numeric","property":"battery","description":"Remaining battery in %","category":"diagnostic","unit":"%","value_max":100,"value_min":0},{"name":"action","label":"Action","access":1,"type":"enum","property":"action","description":"Triggered action (e.g. a button click)","category":"diagnostic","values":["on","off","brightness_move_up","brightness_move_down","brightness_stop","arrow_left_click","arrow_left_hold","arrow_left_release","arrow_right_click","arrow_right_hold","arrow_right_release"]},{"name":"linkquality","label":"Linkquality","access":1,"type":"numeric","property":"linkquality","description":"Link quality (signal strength)","category":"diagnostic","unit":"lqi","value_max":255,"value_min":0}],"ota":{},"zigbeeModel":["Remote Control N2"],"model":"E2001/E2002","vendor":"IKEA","description":"STYRBAR remote control","options":["[Circular]","[Circular]","[Circular]"]},"name":"0x0ceff6fffeb5b04a"} incoming event: {"type":"commandOn","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":26,"_applicationVersion":1,"_dateCode":"20221028","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":2080,"inputClusters":[0,1,3,32,4096,64599,64636],"outputClusters":[3,5,6,8,25,4096],"profileID":260,"ID":1,"clusters":{"genBasic":{"attributes":{"modelId":"Remote Control N2","manufacturerName":"IKEA of Sweden","powerSource":3,"zclVersion":8,"appVersion":1,"stackVersion":106,"hwVersion":1,"dateCode":"20221028","swBuildId":"2.4.5"}},"genPollCtrl":{"attributes":{"checkinInterval":172800}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":190}}},"deviceIeeeAddress":"0x0ceff6fffeb5b04a","deviceNetworkAddress":53947,"_binds":[{"cluster":32,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c0a9ae","endpointID":1},{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c0a9ae","endpointID":1},{"cluster":8,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c0a9ae","endpointID":1},{"cluster":5,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c0a9ae","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c0a9ae","endpointID":1}],"_configuredReportings":[{"cluster":1,"attrId":33,"minRepIntval":3600,"maxRepIntval":65000,"repChange":10,"manufacturerCode":null}],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x0ceff6fffeb5b04a"}}],"_hardwareVersion":1,"_ieeeAddr":"0x0ceff6fffeb5b04a","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1727774611246,"_manufacturerID":4476,"_manufacturerName":"IKEA of Sweden","_modelID":"Remote Control N2","_networkAddress":53947,"_powerSource":"Battery","_softwareBuildID":"2.4.5","_stackVersion":106,"_type":"EndDevice","_zclVersion":8,"_linkquality":131,"_skipDefaultResponse":false,"_lastDefaultResponseSequenceNumber":30,"_checkinInterval":43200,"_pendingRequestTimeout":43200000,"meta":{"configured":1889700129}},"endpoint":"[Circular]","data":{},"linkquality":131,"groupID":0,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":30,"manufacturerCode":null,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":false,"reservedBits":0}}}
      zigbee.0
      2024-10-01 11:23:31.247	debug	Received Zigbee message from '0x0ceff6fffeb5b04a', type 'commandOn', cluster 'genOnOff', data '{}' from endpoint 1 with groupID 0
      zigbee.0
      2024-10-01 11:23:31.246	debug	handleMessage. {"type":"commandOn","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":26,"_applicationVersion":1,"_dateCode":"20221028","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":2080,"inputClusters":[0,1,3,32,4096,64599,64636],"outputClusters":[3,5,6,8,25,4096],"profileID":260,"ID":1,"clusters":{"genBasic":{"attributes":{"modelId":"Remote Control N2","manufacturerName":"IKEA of Sweden","powerSource":3,"zclVersion":8,"appVersion":1,"stackVersion":106,"hwVersion":1,"dateCode":"20221028","swBuildId":"2.4.5"}},"genPollCtrl":{"attributes":{"checkinInterval":172800}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":190}}},"deviceIeeeAddress":"0x0ceff6fffeb5b04a","deviceNetworkAddress":53947,"_binds":[{"cluster":32,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c0a9ae","endpointID":1},{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c0a9ae","endpointID":1},{"cluster":8,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c0a9ae","endpointID":1},{"cluster":5,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c0a9ae","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c0a9ae","endpointID":1}],"_configuredReportings":[{"cluster":1,"attrId":33,"minRepIntval":3600,"maxRepIntval":65000,"repChange":10,"manufacturerCode":null}],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x0ceff6fffeb5b04a"}}],"_hardwareVersion":1,"_ieeeAddr":"0x0ceff6fffeb5b04a","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1727774611246,"_manufacturerID":4476,"_manufacturerName":"IKEA of Sweden","_modelID":"Remote Control N2","_networkAddress":53947,"_powerSource":"Battery","_softwareBuildID":"2.4.5","_stackVersion":106,"_type":"EndDevice","_zclVersion":8,"_linkquality":131,"_skipDefaultResponse":false,"_lastDefaultResponseSequenceNumber":29,"_checkinInterval":43200,"_pendingRequestTimeout":43200000,"meta":{"configured":1889700129}},"endpoint":"[Circular]","data":{},"linkquality":131,"groupID":0,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":30,"manufacturerCode":null,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":false,"reservedBits":0}}}
      zigbee.0
      2024-10-01 11:23:30.751	debug	Type commandTradfriArrowRelease device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":26,"_applicationVersion":1,"_dateCode":"20221028","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":2080,"inputClusters":[0,1,3,32,4096,64599,64636],"outputClusters":[3,5,6,8,25,4096],"profileID":260,"ID":1,"clusters":{"genBasic":{"attributes":{"modelId":"Remote Control N2","manufacturerName":"IKEA of Sweden","powerSource":3,"zclVersion":8,"appVersion":1,"stackVersion":106,"hwVersion":1,"dateCode":"20221028","swBuildId":"2.4.5"}},"genPollCtrl":{"attributes":{"checkinInterval":172800}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":190}}},"deviceIeeeAddress":"0x0ceff6fffeb5b04a","deviceNetworkAddress":53947,"_binds":[{"cluster":32,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c0a9ae","endpointID":1},{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c0a9ae","endpointID":1},{"cluster":8,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c0a9ae","endpointID":1},{"cluster":5,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c0a9ae","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c0a9ae","endpointID":1}],"_configuredReportings":[{"cluster":1,"attrId":33,"minRepIntval":3600,"maxRepIntval":65000,"repChange":10,"manufacturerCode":null}],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x0ceff6fffeb5b04a"}}],"_hardwareVersion":1,"_ieeeAddr":"0x0ceff6fffeb5b04a","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1727774610748,"_manufacturerID":4476,"_manufacturerName":"IKEA of Sweden","_modelID":"Remote Control N2","_networkAddress":53947,"_powerSource":"Battery","_softwareBuildID":"2.4.5","_stackVersion":106,"_type":"EndDevice","_zclVersion":8,"_linkquality":131,"_skipDefaultResponse":false,"_lastDefaultResponseSequenceNumber":29,"_checkinInterval":43200,"_pendingRequestTimeout":43200000,"meta":{"configured":1889700129}},"mapped":{"toZigbee":[{"key":["identify"],"options":[{"name":"identify_timeout","label":"Identify timeout","access":2,"type":"numeric","property":"identify_timeout","description":"Sets the duration of the identification procedure in seconds (i.e., how long the device would flash).The value ranges from 1 to 30 seconds (default: 3).","value_max":30,"value_min":1}]},{"key":["battery"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["scene_rename"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]},{"key":["zclcommand"]}],"fromZigbee":[{"cluster":"genOnOff","type":"commandOn"},{"cluster":"genOnOff","type":["commandOn","commandOff","commandOffWithEffect","commandToggle"]},{"cluster":"genLevelCtrl","type":["commandMoveToLevel","commandMoveToLevelWithOnOff"],"options":[{"name":"simulated_brightness","label":"Simulated brightness","access":2,"type":"composite","property":"simulated_brightness","description":"Simulate a brightness value. If this device provides a brightness_move_up or brightness_move_down action it is possible to specify the update interval and delta. The action_brightness_delta indicates the delta for each interval. ","features":[{"name":"delta","label":"Delta","access":2,"type":"numeric","property":"delta","description":"Delta per interval, 20 by default","value_min":0},{"name":"interval","label":"Interval","access":2,"type":"numeric","property":"interval","description":"Interval duration","unit":"ms","value_min":0}]}]},{"cluster":"genLevelCtrl","type":["commandMove","commandMoveWithOnOff"],"options":[{"name":"simulated_brightness","label":"Simulated brightness","access":2,"type":"composite","property":"simulated_brightness","description":"Simulate a brightness value. If this device provides a brightness_move_up or brightness_move_down action it is possible to specify the update interval and delta. The action_brightness_delta indicates the delta for each interval. ","features":[{"name":"delta","label":"Delta","access":2,"type":"numeric","property":"delta","description":"Delta per interval, 20 by default","value_min":0},{"name":"interval","label":"Interval","access":2,"type":"numeric","property":"interval","description":"Interval duration","unit":"ms","value_min":0}]}]},{"cluster":"genLevelCtrl","type":["commandStep","commandStepWithOnOff"],"options":[{"name":"simulated_brightness","label":"Simulated brightness","access":2,"type":"composite","property":"simulated_brightness","description":"Simulate a brightness value. If this device provides a brightness_move_up or brightness_move_down action it is possible to specify the update interval and delta. The action_brightness_delta indicates the delta for each interval. ","features":[{"name":"delta","label":"Delta","access":2,"type":"numeric","property":"delta","description":"Delta per interval, 20 by default","value_min":0},{"name":"interval","label":"Interval","access":2,"type":"numeric","property":"interval","description":"Interval duration","unit":"ms","value_min":0}]}]},{"cluster":"genLevelCtrl","type":["commandStop","commandStopWithOnOff"],"options":[{"name":"simulated_brightness","label":"Simulated brightness","access":2,"type":"composite","property":"simulated_brightness","description":"Simulate a brightness value. If this device provides a brightness_move_up or brightness_move_down action it is possible to specify the update interval and delta. The action_brightness_delta indicates the delta for each interval. ","features":[{"name":"delta","label":"Delta","access":2,"type":"numeric","property":"delta","description":"Delta per interval, 20 by default","value_min":0},{"name":"interval","label":"Interval","access":2,"type":"numeric","property":"interval","description":"Interval duration","unit":"ms","value_min":0}]}]},{"cluster":"genScenes","type":"commandTradfriArrowSingle"},{"cluster":"genScenes","type":"commandTradfriArrowRelease","options":[{"name":"legacy","label":"Legacy","access":2,"type":"binary","property":"legacy","description":"Set to false to disable the legacy integration (highly recommended), will change structure of the published payload (default true).","value_on":true,"value_off":false}]},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"exposes":[{"name":"identify","label":"Identify","access":2,"type":"enum","property":"identify","description":"Initiate device identification. This device is asleep by default.You may need to wake it up first before sending the indetify command.","category":"config","values":["identify"]},{"name":"battery","label":"Battery","access":5,"type":"numeric","property":"battery","description":"Remaining battery in %","category":"diagnostic","unit":"%","value_max":100,"value_min":0},{"name":"action","label":"Action","access":1,"type":"enum","property":"action","description":"Triggered action (e.g. a button click)","category":"diagnostic","values":["on","off","brightness_move_up","brightness_move_down","brightness_stop","arrow_left_click","arrow_left_hold","arrow_left_release","arrow_right_click","arrow_right_hold","arrow_right_release"]},{"name":"linkquality","label":"Linkquality","access":1,"type":"numeric","property":"linkquality","description":"Link quality (signal strength)","category":"diagnostic","unit":"lqi","value_max":255,"value_min":0}],"ota":{},"zigbeeModel":["Remote Control N2"],"model":"E2001/E2002","vendor":"IKEA","description":"STYRBAR remote control","options":["[Circular]","[Circular]","[Circular]"]},"name":"0x0ceff6fffeb5b04a"} incoming event: {"type":"commandTradfriArrowRelease","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":26,"_applicationVersion":1,"_dateCode":"20221028","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":2080,"inputClusters":[0,1,3,32,4096,64599,64636],"outputClusters":[3,5,6,8,25,4096],"profileID":260,"ID":1,"clusters":{"genBasic":{"attributes":{"modelId":"Remote Control N2","manufacturerName":"IKEA of Sweden","powerSource":3,"zclVersion":8,"appVersion":1,"stackVersion":106,"hwVersion":1,"dateCode":"20221028","swBuildId":"2.4.5"}},"genPollCtrl":{"attributes":{"checkinInterval":172800}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":190}}},"deviceIeeeAddress":"0x0ceff6fffeb5b04a","deviceNetworkAddress":53947,"_binds":[{"cluster":32,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c0a9ae","endpointID":1},{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c0a9ae","endpointID":1},{"cluster":8,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c0a9ae","endpointID":1},{"cluster":5,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c0a9ae","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c0a9ae","endpointID":1}],"_configuredReportings":[{"cluster":1,"attrId":33,"minRepIntval":3600,"maxRepIntval":65000,"repChange":10,"manufacturerCode":null}],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x0ceff6fffeb5b04a"}}],"_hardwareVersion":1,"_ieeeAddr":"0x0ceff6fffeb5b04a","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1727774610748,"_manufacturerID":4476,"_manufacturerName":"IKEA of Sweden","_modelID":"Remote Control N2","_networkAddress":53947,"_powerSource":"Battery","_softwareBuildID":"2.4.5","_stackVersion":106,"_type":"EndDevice","_zclVersion":8,"_linkquality":131,"_skipDefaultResponse":false,"_lastDefaultResponseSequenceNumber":29,"_checkinInterval":43200,"_pendingRequestTimeout":43200000,"meta":{"configured":1889700129}},"endpoint":"[Circular]","data":{"value":0},"linkquality":131,"groupID":0,"cluster":"genScenes","meta":{"zclTransactionSequenceNumber":29,"manufacturerCode":4476,"frameControl":{"frameType":1,"manufacturerSpecific":true,"direction":0,"disableDefaultResponse":false,"reservedBits":0}}}
      zigbee.0
      2024-10-01 11:23:30.750	debug	Received Zigbee message from '0x0ceff6fffeb5b04a', type 'commandTradfriArrowRelease', cluster 'genScenes', data '{"value":0}' from endpoint 1 with groupID 0
      zigbee.0
      2024-10-01 11:23:30.748	debug	handleMessage. {"type":"commandTradfriArrowRelease","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":26,"_applicationVersion":1,"_dateCode":"20221028","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":2080,"inputClusters":[0,1,3,32,4096,64599,64636],"outputClusters":[3,5,6,8,25,4096],"profileID":260,"ID":1,"clusters":{"genBasic":{"attributes":{"modelId":"Remote Control N2","manufacturerName":"IKEA of Sweden","powerSource":3,"zclVersion":8,"appVersion":1,"stackVersion":106,"hwVersion":1,"dateCode":"20221028","swBuildId":"2.4.5"}},"genPollCtrl":{"attributes":{"checkinInterval":172800}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":190}}},"deviceIeeeAddress":"0x0ceff6fffeb5b04a","deviceNetworkAddress":53947,"_binds":[{"cluster":32,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c0a9ae","endpointID":1},{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c0a9ae","endpointID":1},{"cluster":8,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c0a9ae","endpointID":1},{"cluster":5,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c0a9ae","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c0a9ae","endpointID":1}],"_configuredReportings":[{"cluster":1,"attrId":33,"minRepIntval":3600,"maxRepIntval":65000,"repChange":10,"manufacturerCode":null}],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x0ceff6fffeb5b04a"}}],"_hardwareVersion":1,"_ieeeAddr":"0x0ceff6fffeb5b04a","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1727774610748,"_manufacturerID":4476,"_manufacturerName":"IKEA of Sweden","_modelID":"Remote Control N2","_networkAddress":53947,"_powerSource":"Battery","_softwareBuildID":"2.4.5","_stackVersion":106,"_type":"EndDevice","_zclVersion":8,"_linkquality":131,"_skipDefaultResponse":false,"_lastDefaultResponseSequenceNumber":28,"_checkinInterval":43200,"_pendingRequestTimeout":43200000,"meta":{"configured":1889700129}},"endpoint":"[Circular]","data":{"value":0},"linkquality":131,"groupID":0,"cluster":"genScenes","meta":{"zclTransactionSequenceNumber":29,"manufacturerCode":4476,"frameControl":{"frameType":1,"manufacturerSpecific":true,"direction":0,"disableDefaultResponse":false,"reservedBits":0}}}
      Ausgabe von zigbee.0.0ceff6fffeb5b04a.msg_from_zigbee
        "type": "commandTradfriArrowHold",
        "data": {
          "value": 3329
        "linkquality": 127,
        "groupID": 0,
        "cluster": "genScenes",
        "meta": {
          "zclTransactionSequenceNumber": 49,
          "manufacturerCode": 4476,
          "frameControl": {
            "frameType": 1,
            "manufacturerSpecific": true,
            "direction": 0,
            "disableDefaultResponse": false,
            "reservedBits": 0
        "endpoint_id": 1
      Hat jemand ne Idee wie ich das beheben könnte oder wo der Fehler liegt?
      Gruss
      Chris
      • Asgothian
        Asgothian Developer @el-lutschi last edited by
        @el-lutschi
        • welche Adapter-Version nutzt du ?
        • ist das Styrbar unter den "auszuschliessenden" Geräten eingetragen ?
        A.
        • E
          el-lutschi @Asgothian last edited by
          @asgothian Danke für die Rückmeldung.
          Adapter: 1.10.3
          Ist nicht eingetragen.
          • Asgothian
            @el-lutschi
            • Bitte eintragen
            • Bitte die aktuelle 1.10.9 von Github installieren und schauen ob damit das Problem behoben ist.
            A.
            • E
              @asgothian Hat leider nicht geholfen.
              • Asgothian
                @el-lutschi Bitte zusätzlich noch einmal einen state cleanup im Zigbee-Adapter durchführen (Roter Kreis mit ringartigen Pfeilen). Bitte das Log vom State-Cleanup posten.
                A.
                • E
                  @asgothian Super! Das und das Gerät rekonfigurieren hat geholfen. Jetzt erkennt er bisher alle Tasten richtig. Vielen Dank!
