    4. beta admin (v7.2.1) Cannot find i18n und Gui Fehler
    • crunchip
      crunchip Forum Testing Most Active last edited by crunchip
      beim Update heut morgen von v7.2.0 auf 7.2.1 ist mir diese Error Meldung aufgefallen, soweit funktioniert alles bzw noch nichts negatives aufgefallen, bis auf folgendes, siehe unter dem Log
      2024-10-06 09:05:47.538 - info: host.IoBroker "system.adapter.admin.0" disabled
      2024-10-06 09:05:47.538 - info: host.IoBroker stopInstance system.adapter.admin.0 (force=false, process=true)
      2024-10-06 09:05:47.547 - info: admin.0 (149) Got terminate signal TERMINATE_YOURSELF
      2024-10-06 09:05:47.548 - info: admin.0 (149) terminating http server on port 8081
      2024-10-06 09:05:47.550 - info: admin.0 (149) terminating
      2024-10-06 09:05:47.550 - info: admin.0 (149) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2024-10-06 09:05:47.581 - info: host.IoBroker stopInstance system.adapter.admin.0 send kill signal
      2024-10-06 09:05:48.051 - info: admin.0 (149) terminating
      2024-10-06 09:05:48.163 - info: host.IoBroker instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2024-10-06 09:05:50.552 - info: host.IoBroker [WEBSERVER_UPGRADE] (admin) Server is running on http://localhost:8081
      2024-10-06 09:06:01.710 - info: host.IoBroker [WEBSERVER_UPGRADE] (admin) Successfully upgraded admin to version 7.2.1
      2024-10-06 09:06:02.503 - info: host.IoBroker [WEBSERVER_UPGRADE] (admin) Final information delivered
      2024-10-06 09:06:02.541 - info: host.IoBroker "system.adapter.admin.0" enabled
      2024-10-06 09:06:02.543 - info: host.IoBroker [WEBSERVER_UPGRADE] (admin) Successfully started adapter
      2024-10-06 09:06:02.833 - info: host.IoBroker instance system.adapter.admin.0 in version "7.2.1" started with pid 5819
      2024-10-06 09:06:06.464 - info: admin.0 (5819) starting. Version 7.2.1 in /opt/iobroker/node_modules/iobroker.admin, node: v20.17.0, js-controller: 6.0.11
      2024-10-06 09:06:06.488 - info: admin.0 (5819) requesting all objects
      2024-10-06 09:06:06.521 - error: admin.0 (5819) Cannot init i18n: Error: Cannot find i18n directory
      2024-10-06 09:06:07.567 - info: admin.0 (5819) received all objects
      2024-10-06 09:06:07.820 - info: admin.0 (5819) socket.io server listening on port 8081
      2024-10-06 09:06:07.821 - info: admin.0 (5819) http server listening on port 8081
      2024-10-06 09:06:07.821 - info: admin.0 (5819) Use link "http://127.0.0.1:8081" to configure.
      geht man auf den Reiter Dateien, läde es für ein paar Sekunden, anschließend erschein folgende Seite
      entsprechende Browserconsole zeigt
      AdminUtils.tsx:244 Please add to "system.adapter.vis-inventwo" common.adminUI={"config":"materialize","custom":"json","tab":"materialize"}
      AdminUtils.tsx:244 Please add to "system.adapter.vis-jqui-mfd" common.adminUI={"config":"none"}
      AdminUtils.tsx:244 Please add to "system.adapter.vis-keyboard" common.adminUI={"config":"html"}
      AdminUtils.tsx:244 Please add to "system.adapter.vis-material-webfont" common.adminUI={"config":"none"}
      AdminUtils.tsx:244 Please add to "system.adapter.vis-material" common.adminUI={"config":"none"}
      AdminUtils.tsx:244 Please add to "system.adapter.vis-materialdesign" common.adminUI={"config":"materialize"}
      AdminUtils.tsx:244 Please add to "system.adapter.vis-players" common.adminUI={"config":"none"}
      AdminUtils.tsx:244 Please add to "system.adapter.vis-plumb" common.adminUI={"config":"none"}
      AdminUtils.tsx:244 Please add to "system.adapter.vis-rgraph" common.adminUI={"config":"html"}
      AdminUtils.tsx:244 Please add to "system.adapter.wallpanel" common.adminUI={"config":"materialize"}
      AdminUtils.tsx:244 Please add to "system.adapter.weatherunderground" common.adminUI={"config":"materialize"}
      AdminUtils.tsx:244 Please add to "system.adapter.whatsapp-cmb" common.adminUI={"config":"materialize"}
      AdminUtils.tsx:244 Please add to "system.adapter.wiffi-wz" common.adminUI={"config":"materialize"}
      AdminUtils.tsx:244 Please add to "system.adapter.wiobrowser" common.adminUI={"config":"materialize"}
      AdminUtils.tsx:244 Please add to "system.adapter.wled" common.adminUI={"config":"materialize"}
      AdminUtils.tsx:244 Please add to "system.adapter.yeelight-2" common.adminUI={"config":"materialize"}
      AdminUtils.tsx:292 Please modify "system.adapter.zigbee2mqtt" common.adminUI={"config":"json","tab":"html"}
      App.tsx:1654 Could not process news: Error: timeout
         at http://10.1.1.10:8081/static/js/491.f791ce33.chunk.js:2:162707
         at r (http://10.1.1.10:8081/static/js/491.f791ce33.chunk.js:2:229865)
      FileBrowser.tsx:804 Cannot read folder 0_userdata.0: undefined
      console.ts:40 Cannot read folder 0_userdata.0: undefined
      console.ts:40
      Error: Minified React error #62; visit https://reactjs.org/docs/error-decoder.html?invariant=62 for the full message or use the non-minified dev environment for full errors and additional helpful warnings.
         at ye (react-dom.production.min.js:50:341)
         at Ko (react-dom.production.min.js:229:311)
         at ks (react-dom.production.min.js:280:85)
         at bs (react-dom.production.min.js:279:450)
         at vs (react-dom.production.min.js:279:320)
         at gs (react-dom.production.min.js:279:180)
         at as (react-dom.production.min.js:270:88)
         at is (react-dom.production.min.js:272:300)
         at Hl (react-dom.production.min.js:127:105)
         at react-dom.production.min.js:266:273
      auch nach mehrmaligem Browser refresh
      wenn man allerdings beim laden kurz vorher die Ansicht ändert, läd die Seite
      allerdings beim öffnen des Benutzerdaten Ordners
      mit anschließender Meldung in der console
      klickt man erneut auf Ansichtsmodus umschalten, erscheint sofort wieder obiger screen "Error in Gui"
      CPU: 49.17 %
      RAM: 34 %
      Betriebszeit: 9h
      Verfügbar: 6.0.11
      Installiert: 6.0.11
      Ereignisse: ⇥45 / ↦13
      Plattform: docker (official image - v10.0.0)
      Betriebssystem: linux
      Architektur: x64
      CPUs: 16
      Geschwindigkeit: 4540 MHz
      Modell: AMD Ryzen 9 6900HX with Radeon Graphics
      RAM: 30.6 GB
      System-Betriebszeit: 10 T. 05:25:09
      Node.js: v20.17.0
      time: 1728210429259
      timeOffset: -120
      NPM: 10.8.2
      Adapter-Anzahl: 634
      Datenträgergröße: 953.9 GB
      Freier Festplattenspeicher: 492.8 GB
      Aktive Instanzen: 45
      Pfad: /opt/iobroker/
      Betriebszeit: 09:24:41
      auf github hab ich`s noch nicht gemeldet
        Thomas Braun Most Active @crunchip last edited by Thomas Braun
        @crunchip
        Die Meldung mit dem i18n-Verzeichnis habe ich auch, allerdings lädt auf meiner Kiste der Reiter 'Dateien' einwandfrei. Kein GUI-Fehler hier.
        Edit: Genauer lesen... Wenn man den Ansichtsmodus ändert lädt es sich bei mir auch tot. Ein GUI-Fehler erscheint aber nicht.
        • crunchip
          crunchip Forum Testing Most Active @Thomas Braun last edited by
          @thomas-braun sagte in beta admin (v7.2.1) Cannot find i18n directory:
          ja Ursprünglich fällt es nicht auf, ich hatte ja heute morgen schon probiert, allerdings war bei mir noch der Ansichtsmodus umgestellt, default wird ja der andere Ansichtsmodus geladen
          • Feuersturm
            Feuersturm last edited by
            Hier ist das dazugehörige issue https://github.com/ioBroker/ioBroker.admin/issues/2726 zur Verfolgung des Problems.
            Brainbug01 created this issue in ioBroker/ioBroker.admin
            closed [bug]: Cannot find i18n directory #2726
            crunchip 1 Reply Last reply Reply Quote 1
            • crunchip
              crunchip Forum Testing Most Active @Feuersturm last edited by crunchip
              @feuersturm ok und erstmal danke fürs raussuchen, jedoch hatte ich weder bei 7.2.0 diese "i18n" Fehlermeldung und auch kein js-controller v7 in Verwendung, daher auch das eigentliche Problem was darunter geschildert ist, im ersten Beitrag,
              allerdings weiß ich nicht seit wann dieses Problem mit dem Dateien/Gui Fehler besteht.
              Deswegen war meine Vermutung, es gibt einen Zusammenhang.
              Vllt sollte ich den Titel anpassen und aufs Dateien-Problem beschränken.
              Nach wie vor vermisse ich im Forum einen offiziellen Admin stable/beta Thread bezogen auf v7.x.
              Wenn es um admin Probleme geht, liest man immer unzählig viele Einzel Threads
              edit
              das issue dazu zwecks Gui Fehler ist ebenfalls zu finden, siehe https://github.com/ioBroker/ioBroker.admin/issues/2648
              mfelber63 created this issue in ioBroker/ioBroker.admin
              closed [bug]: Error in GUI! #2648
              • Codierknecht
                Codierknecht Developer Most Active @crunchip last edited by Codierknecht
                @crunchip
                Das Problem tritt in dieser Form in allen bislang getesteten Versionen von 7.1.0 bis 7.2.2 auf.
                Ich teste mal weiter ... Issue ist kommentiert.
                Edit
                ... auch auf meinem Produktivsystem mit Admin 7.1.5 und JS-Controller 6.0.11.
                da_Woody 1 Reply Last reply Reply Quote 1
                • da_Woody
                  da_Woody @Codierknecht last edited by
                  @codierknecht hmm, ich kenne die Error in GUI Fehler. Sehe ich eigentlich nur wenn ich ein Update mache und dann auf einem anderen Rechner (Männer Höhle oder Werkstatt Büro) den Tab aufrufe. Nach einem reload kommt sofort alles normal.
                  Darum hab ich mir das noch nie wirklich durchgelesen. Nächstes mal mach ich einen Screenshot...
                  7.2.1 macht bei mir keine Probleme.
                  • Codierknecht
                    Codierknecht Developer Most Active @da_Woody last edited by
                    @da_woody sagte in beta admin (v7.2.1) Cannot find i18n und Gui Fehler:
                    Prinzipiell bei mir auch nicht.
                    Ohne diesen Beitrag wäre ich aber auch nie auf die Idee gekommen, den Ansichtsmodus im Tab "Dateien" mal umzuschalten 😉
                    da_Woody 3 Replies Last reply Reply Quote 0
                    • da_Woody
                      @codierknecht hab ich latürnich auch getestet. Kein Problem. Kann's aber gerne zu Mittag noch mal probieren..
                        hotspot_2 @da_Woody last edited by hotspot_2
                        ich habe mir gerade 7.2.1 installiert und konnte mich nun nicht mehr einloggen. Ich habe ein Update über die Konsole auf 7.2.2 gemacht aber auch da kann ich mich nicht mehr einloggen. Das ioBroker Logo dreht sich dauerhaft im Kreis.
                        Hat jemand einen Tipp was ich tun kann?
                          Thomas Braun Most Active @hotspot_2 last edited by
                          @hotspot_2 sagte in beta admin (v7.2.1) Cannot find i18n und Gui Fehler:
                          Schalt mal die Authentifizierung per https/ssl ab.
                            hotspot_2 @Thomas Braun last edited by
                            @thomas-braun Wie geht das?
                              paul53 @hotspot_2 last edited by paul53
                              @hotspot_2 sagte: Wie geht das?
                              Siehe Doku
                                hotspot_2 @paul53 last edited by
                                vielen Dank, geht wieder.
                                Für alle die nicht in der Doku suchen möchten und das gleiche Problem haben:
                                iobroker set admin --auth false
                                da_Woody H 2 Replies Last reply Reply Quote 0
                                • da_Woody
                                  da_Woody @hotspot_2 last edited by
                                  woody@ioBroker:~$ iobroker set admin --auth false
                                  please specify instance, like "admin.0"
                                  woody@ioBroker:~$ iobroker set admin.0 --auth false
                                  New auth for "admin.0" is: false
                                  Instance settings for "admin.0" are changed.
                                  • da_Woody
                                    @codierknecht so, getestet. ja spinnt, aber kein gui-error.
                                      TT-Tom @da_Woody last edited by
                                      @da_woody
                                      es liegt nicht am https sondern nur an der Authentifizierung, habe es mal durch getestet. siehe hier
                                      • da_Woody
                                        da_Woody @TT-Tom last edited by
                                        @tt-tom ok, die auth hab ich nicht angehakt, auch keine verschlüsselung.
                                        mag auch daran liegen, daß ich mich nie abmelde. die 2 wichtigen rechner laufen 24/7 und die tabs sind immer offen.
                                        gerade reingekommen:
                                        • da_Woody
                                          @codierknecht ha! gerade bekommen vor dem update!
                                          unten dran noch:
                                          Loading chunk 2534 failed. (error: http://192.168.0.250:8081/static/js/2534.b7665a2f.chunk.js)
                                          t.f.j@http://192.168.0.250:8081/static/js/main.7300b7a8.js:1:14218
                                          t.e/<@http://192.168.0.250:8081/static/js/main.7300b7a8.js:1:1161
                                          t.e@http://192.168.0.250:8081/static/js/main.7300b7a8.js:1:1139
                                          44321/Pa<@http://192.168.0.250:8081/static/js/4684.e66c5656.chunk.js:1:1647587
                                          P@http://192.168.0.250:8081/static/js/4905.33747b16.chunk.js:2:3345
                                          xi@http://192.168.0.250:8081/static/js/5096.3a6e8bdb.chunk.js:2:120729
                                          bs@http://192.168.0.250:8081/static/js/5096.3a6e8bdb.chunk.js:2:109363
                                          vs@http://192.168.0.250:8081/static/js/5096.3a6e8bdb.chunk.js:2:109291
                                          gs@http://192.168.0.250:8081/static/js/5096.3a6e8bdb.chunk.js:2:109152
                                          is@http://192.168.0.250:8081/static/js/5096.3a6e8bdb.chunk.js:2:106270
                                          Hl@http://192.168.0.250:8081/static/js/5096.3a6e8bdb.chunk.js:2:46915
                                          62280/rs/<@http://192.168.0.250:8081/static/js/5096.3a6e8bdb.chunk.js:2:103865
                                            @da_Woody
                                            GUI Fehler hatte ich beim Update nicht, erst als ich versucht hatte die Auth wieder zu aktivieren
                                            admin beta browserconsole error in gui
                                            2244
