    4. Adapter Update funktioniert nicht "Generell"
      bishop last edited by
      ich wollte mal wieder teilweise paar Adapter aktualisieren z.b. Sonoff wird mir angebote von 3.1.0 auf 3.1.2 wenn ich das starte bekomme ich ein Error zurück.
      $ iobroker upgrade sonoff@3.1.2 --debug
      Update sonoff from @3.1.0 to @3.1.2
      Installing iobroker.sonoff@3.1.2... (System call)
      npm error Cannot read properties of null (reading 'match')
      npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-10-08T09_11_30_206Z-debug-0.log
      upload [0] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/words.js words.js application/javascript
      Process exited with code 0
      In der Log steht.
      0 verbose cli /usr/bin/node /usr/bin/npm
      1 info using npm@10.7.0
      2 info using node@v18.20.4
      3 silly config:load:file:/usr/lib/node_modules/npm/npmrc
      4 silly config:load:file:/opt/iobroker/.npmrc
      5 silly config:load:file:/home/iobroker/.npmrc
      6 silly config:load:file:/usr/etc/npmrc
      7 verbose title npm install iobroker.sonoff@3.1.2
      8 verbose argv "install" "--save-exact" "iobroker.sonoff@3.1.2" "--foreground-scripts"
      9 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs/2024-10-08T09_11_30_206Z-
      10 verbose logfile /home/iobroker/.npm/_logs/2024-10-08T09_11_30_206Z-debug-0.log
      11 silly logfile start cleaning logs, removing 1 files
      12 silly logfile done cleaning log files
      13 silly idealTree buildDeps
      14 silly fetch manifest iobroker.sonoff@3.1.2
      15 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules/iobroker.alexa2
      16 http fetch GET 200 https://registry.npmjs.org/iobroker.sonoff 1528ms (cache revalidated)
      17 silly placeDep ROOT iobroker.sonoff@3.1.2 REPLACE for: iobroker.inst@3.0.0 want: 3.1.2
      18 verbose stack TypeError: Cannot read properties of null (reading 'match')
      18 verbose stack     at getAction (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/diff.js:148:33)
      18 verbose stack     at diffNode (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/diff.js:240:18)
      18 verbose stack     at getChildren (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/diff.js:209:5)
      18 verbose stack     at kidNodes (/usr/lib/node_modules/npm/node_modules/treeverse/lib/depth.js:52:18)
      18 verbose stack     at visitNode (/usr/lib/node_modules/npm/node_modules/treeverse/lib/depth.js:47:14)
      18 verbose stack     at depth (/usr/lib/node_modules/npm/node_modules/treeverse/lib/depth.js:71:10)
      18 verbose stack     at Diff.calculate (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/diff.js:96:12)
      18 verbose stack     at [diffTrees] (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/reify.js:465:22)
      18 verbose stack     at Arborist.reify (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/reify.js:141:27)
      18 verbose stack     at async Install.exec (/usr/lib/node_modules/npm/lib/commands/install.js:150:5)
      19 verbose cwd /opt/iobroker
      20 verbose Linux 6.1.0-26-amd64
      21 verbose node v18.20.4
      22 verbose npm  v10.7.0
      23 error Cannot read properties of null (reading 'match')
      24 verbose exit 1
      25 verbose code 1
      26 silly unfinished npm timer reify 1728378690569
      27 silly unfinished npm timer reify:diffTrees 1728378694604
      28 error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-10-08T09_11_30_206Z-debug-0.log
      • Adaptername: Sonoff
      • Link zu Adapterrepository: www.github.com...
      • Adapterversion: 3.1.0
      • js-controller Version: 6.0.11
      • Admin Version: 7.1.2
      • Hardwaresystem: Proxmox VM
      • Arbeitsspeicher: ...16GB
      • Nodejs-Version: v18.20.4
      • NPM-Version: 10.7.0
      Wenn ich Admin aktualisieren möchte kommt ca. das gleiche, also funktioniert nicht.
      Danke schon mal
      • Codierknecht
        Codierknecht Developer Most Active @bishop last edited by
        @bishop
        Solltest Du doch wissen: Mit welchem Unterbau bist Du da unterwegs?
        iob diag
          bishop @Codierknecht last edited by
          @codierknecht
          sorry!!! na klar 🙂
          ```bash
          Skript v.2024-08-12
          *** BASE SYSTEM ***
           Static hostname: iobroker
                 Icon name: computer-vm
                   Chassis: vm 🖴
            Virtualization: kvm
                    Kernel: Linux 6.1.0-26-amd64
              Architecture: x86-64
           Hardware Vendor: QEMU
            Hardware Model: Standard PC _i440FX + PIIX, 1996_
          Firmware Version: rel-1.16.3-0-ga6ed6b701f0a-prebuilt.qemu.org
          OS is similar to:
          model name      : QEMU Virtual CPU version 2.5+
          Docker          : false
          Virtualization  : kvm
          Kernel          : x86_64
          Userland        : 64 bit
          Systemuptime and Load:
           11:17:39 up 14:19,  2 users,  load average: 0.69, 0.51, 0.45
          CPU threads: 2
          *** Time and Time Zones ***
                         Local time: Tue 2024-10-08 11:17:39 CEST
                     Universal time: Tue 2024-10-08 09:17:39 UTC
                           RTC time: Tue 2024-10-08 09:17:39
                        NTP service: active
                    RTC in local TZ: no
          *** Users and Groups ***
          User that called 'iob diag':
          zeus
          HOME=/home/zeus
          GROUPS=zeus cdrom floppy sudo audio dip video plugdev users netdev iobroker
          iobroker
          HOME=/home/iobroker
          GROUPS=iobroker tty dialout audio video plugdev
          *** Display-Server-Setup ***
          Display-Server: false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Mem:             33G        6.3G         26G        565K        985M         27G
          Swap:           1.0G          0B        1.0G
          Total:           34G        6.3G         27G
          Active iob-Instances:   55
                  32097 M total memory
                   6037 M used memory
                    355 M active memory
                   5913 M inactive memory
                  25430 M free memory
                    126 M buffer memory
                    813 M swap cache
                    974 M total swap
                      0 M used swap
                    974 M free swap
          top - 11:17:40 up 14:19,  2 users,  load average: 0.69, 0.51, 0.45
          Tasks: 146 total,   1 running, 145 sleeping,   0 stopped,   0 zombie
          %Cpu(s): 50.0 us, 25.0 sy,  0.0 ni,  0.0 id, 25.0 wa,  0.0 hi,  0.0 si,  0.0 st
          MiB Mem :  32097.1 total,  25429.9 free,   6037.7 used,    939.8 buff/cache
          MiB Swap:    975.0 total,    975.0 free,      0.0 used.  26059.4 avail Mem
          *** FAILED SERVICES ***
          0 loaded units listed.
          *** FILESYSTEM ***
          udev           devtmpfs   16G     0   16G   0% /dev
          tmpfs          tmpfs     3.2G  556K  3.2G   1% /run
          /dev/sda1      ext4       15G   14G  655M  96% /
          tmpfs          tmpfs      16G     0   16G   0% /dev/shm
          tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
          tmpfs          tmpfs     3.2G     0  3.2G   0% /run/user/1000
          [Mon Oct  7 20:57:59 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
          [Mon Oct  7 20:57:59 2024] EXT4-fs (sda1): re-mounted. Quota mode: none.
          Show mounted filesystems:
          TARGET SOURCE    FSTYPE OPTIONS
          /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
          /var:
          1.8G    /var/
          1.4G    /var/log/journal/cb15876e9b724693aa4be33c5fa0a5da
          1.4G    /var/log
          220M    /var/cache
          Archived and active journals take up 8.0M in the file system.
          /opt/iobroker/backups:
          /opt/iobroker/iobroker-data:
          2.7G    /opt/iobroker/iobroker-data/
          1.2G    /opt/iobroker/iobroker-data/sonosCache
          1.1G    /opt/iobroker/iobroker-data/files
          441M    /opt/iobroker/iobroker-data/files/javascript.admin
          409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
          82M     /opt/iobroker/iobroker-data/states.jsonl
          74M     /opt/iobroker/iobroker-data/objects.jsonl
          38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
          36M     /opt/iobroker/iobroker-data/files/telegram-menu.admin/build/index.js.map
          35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
          USB-Devices by-id:
          /dev/serial/by-id/usb-Texas_Instruments_CC2538_USB_CDC-if00
          HINT:
          Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
          /dev/ttyACM0
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v18.20.4
          /usr/bin/node           v18.20.4
          /usr/bin/npm            10.7.0
          /usr/bin/npx            10.7.0
          /usr/bin/corepack       0.28.0
          nodejs:
            Installed: 18.20.4-1nodesource1
            Candidate: 18.20.4-1nodesource1
            Version table:
           *** 18.20.4-1nodesource1 500
                  500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                  100 /var/lib/dpkg/status
               18.20.3-1nodesource1 500
               18.20.2-1nodesource1 500
               18.20.1-1nodesource1 500
               18.20.0-1nodesource1 500
               18.19.1-1nodesource1 500
               18.19.0+dfsg-6~deb12u2 500
                  500 http://deb.debian.org/debian bookworm/main amd64 Packages
               18.19.0+dfsg-6~deb12u1 500
                  500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
               18.19.0-1nodesource1 500
               18.18.2-1nodesource1 500
               18.18.1-1nodesource1 500
               18.18.0-1nodesource1 500
               18.17.1-1nodesource1 500
               18.17.0-1nodesource1 500
               18.16.1-1nodesource1 500
               18.16.0-1nodesource1 500
               18.15.0-1nodesource1 500
               18.14.2-1nodesource1 500
               18.14.1-1nodesource1 500
               18.14.0-1nodesource1 500
               18.13.0-1nodesource1 500
               18.12.0-1nodesource1 500
               18.11.0-1nodesource1 500
               18.10.0-1nodesource1 500
               18.9.1-1nodesource1 500
               18.9.0-1nodesource1 500
               18.8.0-1nodesource1 500
               18.7.0-1nodesource1 500
               18.6.0-1nodesource1 500
               18.5.0-1nodesource1 500
               18.4.0-1nodesource1 500
               18.3.0-1nodesource1 500
               18.2.0-1nodesource1 500
               18.1.0-1nodesource1 500
               18.0.0-1nodesource1 500
          No problems detected
          Errors in npm tree:
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Core adapters versions
          js-controller:  6.0.11
          admin:          7.1.2
          javascript:     8.7.6
          nodejs modules from github:     7
          +-- iobroker.bambulab@0.3.2 (git+ssh://git@github.com/DrozmotiX/ioBroker.bambulab.git#fd28f98d7ec46f36f4a2dae2d9ac740966453704)
          +-- iobroker.govee-app@0.0.6 (git+ssh://git@github.com/TA2k/ioBroker.govee-app.git#6a0f84cfb34eb3a0ca647c7a519b9d5a48ccfb85)
          +-- iobroker.paperless-ngx@0.0.5 (git+ssh://git@github.com/BenAhrdt/ioBroker.paperless-ngx.git#494a186aee5d9b01de2117208a39f7e7c33addc7)
          +-- iobroker.sonos@3.0.0 (git+ssh://git@github.com/ioBroker/ioBroker.sonos.git#1d98195545b03129423bb575ba8aec7bf6ec105e)
          +-- iobroker.sun2000-modbus@0.1.3 (git+ssh://git@github.com/daolis/ioBroker.sun2000-modbus.git#8def037e7c12b2049f89d890d5f3121090f6d873)
          | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
          +-- iobroker.whatsapp-cmb@0.3.0 (git+ssh://git@github.com/ioBroker/ioBroker.whatsapp-cmb.git#56e3e5faad663ca4e2fc5b4117b4a000beb639a6)
          Adapter State
          + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.alarm.0                  : alarm                 : iobroker                                 -  enabled
          + system.adapter.alexa-shoppinglist.0     : alexa-shoppinglist    : iobroker                                 -  enabled
          + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
            system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
          + system.adapter.awtrix-light.0           : awtrix-light          : iobroker                                 -  enabled
            system.adapter.backitup.0               : backitup              : iobroker                                 - disabled
            system.adapter.bambulab.0               : bambulab              : iobroker                                 - disabled, port: 8883
          + system.adapter.bosch-ebike.0            : bosch-ebike           : iobroker                                 -  enabled
          + system.adapter.device-reminder.0        : device-reminder       : iobroker                                 -  enabled
          + system.adapter.device-watcher.0         : device-watcher        : iobroker                                 -  enabled
            system.adapter.devices.0                : devices               : iobroker                                 - disabled
            system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
            system.adapter.email.0                  : email                 : iobroker                                 - disabled
          + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 -  enabled
          + system.adapter.enigma2.0                : enigma2               : iobroker                                 -  enabled
          + system.adapter.enigma2.1                : enigma2               : iobroker                                 -  enabled
            system.adapter.espresense.0             : espresense            : iobroker                                 - disabled
            system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 - disabled
            system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
            system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
          + system.adapter.followthesun.0           : followthesun          : iobroker                                 -  enabled
          + system.adapter.fritzbox.0               : fritzbox              : iobroker                                 -  enabled
          + system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
          + system.adapter.govee-app.0              : govee-app             : iobroker                                 -  enabled
            system.adapter.habpanel.0               : habpanel              : iobroker                                 - disabled
            system.adapter.ham.0                    : ham                   : iobroker                                 - disabled
          + system.adapter.hass.0                   : hass                  : iobroker                                 -  enabled, port: 8123
          + system.adapter.history.0                : history               : iobroker                                 -  enabled
          + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
          + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
          + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
            system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
          + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
            system.adapter.intex.0                  : intex                 : iobroker                                 - disabled, port: 8990
          + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
          + system.adapter.iqontrol.0               : iqontrol              : iobroker                                 -  enabled
          + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
            system.adapter.lgtv.0                   : lgtv                  : iobroker                                 - disabled
            system.adapter.lgtv.1                   : lgtv                  : iobroker                                 - disabled
            system.adapter.lightcontrol.0           : lightcontrol          : iobroker                                 - disabled
            system.adapter.linkeddevices.0          : linkeddevices         : iobroker                                 - disabled
            system.adapter.linux-control.0          : linux-control         : iobroker                                 - disabled
            system.adapter.lovelace.0               : lovelace              : iobroker                                 - disabled, port: 8091, bind: 0.0.0.0, run as: admin
          + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
          + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
            system.adapter.octoprint.0              : octoprint             : iobroker                                 - disabled
          + system.adapter.paperless-ngx.0          : paperless-ngx         : iobroker                                 -  enabled, port: 8010
            system.adapter.ph803w.0                 : ph803w                : iobroker                                 - disabled
          + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
          + system.adapter.pixelit.0                : pixelit               : iobroker                                 -  enabled
          + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
          + system.adapter.reolink.0                : reolink               : iobroker                                 -  enabled
          + system.adapter.reolink.1                : reolink               : iobroker                                 -  enabled
          + system.adapter.sainlogic.0              : sainlogic             : iobroker                                 -  enabled, port: 25586, bind: 0.0.0.0
          + system.adapter.samsung_tizen.0          : samsung_tizen         : iobroker                                 -  enabled, port: 8002
          + system.adapter.samsung_tizen.1          : samsung_tizen         : iobroker                                 -  enabled, port: 8002
            system.adapter.scenes.0                 : scenes                : iobroker                                 - disabled
            system.adapter.schoolfree.0             : schoolfree            : iobroker                                 -  enabled
          + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1885, bind: 0.0.0.0
          + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
            system.adapter.signal-cmb.0             : signal-cmb            : iobroker                                 - disabled
          + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
          + system.adapter.smartthings.0            : smartthings           : iobroker                                 -  enabled
          + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1884, bind: 0.0.0.0
            system.adapter.sonoff.1                 : sonoff                : iobroker                                 - disabled, port: 2884, bind: 0.0.0.0
          + system.adapter.sonos.0                  : sonos                 : iobroker                                 -  enabled
          + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
          + system.adapter.statistics.0             : statistics            : iobroker                                 -  enabled
          + system.adapter.sun2000-modbus.0         : sun2000-modbus        : iobroker                                 -  enabled, port: 502
            system.adapter.synology.0               : synology              : iobroker                                 - disabled, port: 5000
          + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
            system.adapter.telegram-menu.0          : telegram-menu         : iobroker                                 - disabled
          + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
          + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
          + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
          + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
          + system.adapter.unifi.0                  : unifi                 : iobroker                                 -  enabled
          + system.adapter.viessmannapi.0           : viessmannapi          : iobroker                                 -  enabled
            system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : iobroker                                 -  enabled
            system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : iobroker                                 -  enabled
            system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 -  enabled
            system.adapter.vis-2.0                  : vis-2                 : iobroker                                 - disabled
            system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
            system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 - disabled
            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
            system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 - disabled
            system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
            system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
            system.adapter.vis-material.0           : vis-material          : iobroker                                 - disabled
            system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 - disabled
            system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
            system.adapter.vis-players.0            : vis-players           : iobroker                                 - disabled
            system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 - disabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
            system.adapter.vis.0                    : vis                   : iobroker                                 - disabled
            system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
          + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
            system.adapter.yr.0                     : yr                    : iobroker                                 -  enabled
          + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyACM0
          + instance is alive
          ioBroker-Repositories
          │ (index) │   name   │                           url                           │ auto upgrade │
          │    0    │ 'stable' │    'http://download.iobroker.net/sources-dist.json'     │    false     │
          │    1    │  'beta'  │ 'http://download.iobroker.net/sources-dist-latest.json' │    false     │
          Active repo(s): stable
          Upgrade policy: none
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "admin"        : 7.1.5    , installed 7.1.2  [Updatable]
          Adapter    "alarm"        : 3.6.2    , installed 3.6.0  [Updatable]
          Adapter    "alexa-shoppinglist": 1.0.0, installed 1.0.0
          Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
          Adapter    "awtrix-light" : 1.3.0    , installed 1.3.0
          Adapter    "backitup"     : 3.0.22   , installed 3.0.19 [Updatable]
          Adapter    "countdown"    : 2.2.0    , installed 2.2.0
          Adapter    "device-reminder": 3.1.2  , installed 3.1.2
          Adapter    "device-watcher": 2.12.1  , installed 2.12.1
          Adapter    "discovery"    : 5.0.0    , installed 4.4.0  [Updatable]
          Adapter    "email"        : 1.3.1    , installed 1.2.2  [Updatable]
          Adapter    "energiefluss-erweitert": 0.4.1, installed 0.4.1
          Adapter    "enigma2"      : 2.1.1    , installed 2.1.1
          Adapter    "espresense"   : 0.4.4    , installed 0.4.4
          Adapter    "fb-checkpresence": 1.2.4 , installed 1.2.4
          Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
          Adapter    "followthesun" : 0.5.1    , installed 0.5.1
          Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
          Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
          Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
          Adapter    "ham"          : 5.3.1    , installed 5.3.1
          Adapter    "hass"         : 1.4.0    , installed 1.4.0
          Adapter    "hm-rega"      : 5.0.0    , installed 5.0.0
          Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.0  [Updatable]
          Adapter    "ical"         : 1.15.0   , installed 1.15.0
          Adapter    "intex"        : 0.1.7    , installed 0.1.7
          Adapter    "iot"          : 3.3.0    , installed 3.3.0
          Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
          Adapter    "javascript"   : 8.8.3    , installed 8.7.6  [Updatable]
          Controller "js-controller": 6.0.11   , installed 6.0.11
          Adapter    "lgtv"         : 2.2.0    , installed 2.2.0
          Adapter    "lightcontrol" : 0.8.0    , installed 0.5.0  [Updatable]
          Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
          Adapter    "linux-control": 1.1.5    , installed 1.1.5
          Adapter    "lovelace"     : 4.1.10   , installed 4.1.10
          Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
          Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
          Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
          Adapter    "ph803w"       : 1.2.0    , installed 1.2.0
          Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
          Adapter    "pixelit"      : 1.1.4    , installed 1.1.3  [Updatable]
          Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
          Adapter    "reolink"      : 1.1.1    , installed 1.1.1
          Adapter    "sainlogic"    : 0.11.4   , installed 0.11.4
          Adapter    "samsung_tizen": 1.1.0    , installed 1.1.0
          Adapter    "scenes"       : 3.2.3    , installed 2.3.9  [Updatable]
          Adapter    "schoolfree"   : 1.1.4    , installed 1.1.4
          Adapter    "shelly"       : 8.2.1    , installed 7.0.0  [Updatable]
          Adapter    "shuttercontrol": 1.7.3   , installed 1.7.3
          Adapter    "signal-cmb"   : 0.3.0    , installed 0.3.0
          Adapter    "socketio"     : 6.7.1    , installed 6.7.1
          Adapter    "sonoff"       : 3.1.2    , installed 3.1.0  [Updatable]
          Adapter    "sonos"        : 3.0.0    , installed 3.0.0
          Adapter    "statistics"   : 2.4.0    , installed 2.4.0
          Adapter    "sun2000-modbus": 0.1.3   , installed 0.1.3
          Adapter    "synology"     : 3.1.0    , installed 3.1.0
          Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
          Adapter    "telegram"     : 3.9.0    , installed 3.9.0
          Adapter    "telegram-menu": 2.0.0    , installed 1.5.1  [Updatable]
          Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
          Adapter    "trashschedule": 3.3.0    , installed 3.3.0
          Adapter    "tuya"         : 3.16.0   , installed 3.16.0
          Adapter    "unifi"        : 0.7.0    , installed 0.7.0
          Adapter    "viessmannapi" : 2.3.0    , installed 2.3.0
          Adapter    "vis-2"        : 2.9.32   , installed 2.9.32
          Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.0 [Updatable]
          Adapter    "vis-2-widgets-gauges": 1.1.0, installed 1.1.0
          Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.8 [Updatable]
          Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.3  [Updatable]
          Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
          Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
          Adapter    "vis-material" : 0.1.3    , installed 0.1.3
          Adapter    "weatherunderground": 3.7.0, installed 3.7.0
          Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
          Adapter    "wled"         : 0.7.2    , installed 0.7.2
          Adapter    "ws"           : 2.6.2    , installed 2.6.2
          Adapter    "yr"           : 5.3.0    , installed 5.3.0
          Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
          Objects and States
          Objects:        67302
          States:         57777
          Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
          Hit:2 http://deb.debian.org/debian bookworm InRelease
          Hit:4 https://repos.influxdata.com/debian stable InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       15714      535/iobroker.js-con
          tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       15721      535/iobroker.js-con
          tcp        0      0 0.0.0.0:25586           0.0.0.0:*               LISTEN      1001       22902      1652/io.sainlogic.0
          tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       19646      1135/io.shelly.0
          tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       18403      1023/io.sonoff.0
          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       17886      912/io.mqtt.0
          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          869        1/init
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16638      494/sshd: /usr/sbin
          tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        16673      485/influxd
          tcp        0      0 192.168.1.8:2010        0.0.0.0:*               LISTEN      1001       17641      845/io.hm-rpc.1
          tcp        0      0 192.168.1.8:2001        0.0.0.0:*               LISTEN      1001       16379      830/io.hm-rpc.0
          tcp        0      0 0.0.0.0:5005            0.0.0.0:*               LISTEN      0          16681      481/node
          tcp6       0      0 :::111                  :::*                    LISTEN      0          871        1/init
          tcp6       0      0 :::22                   :::*                    LISTEN      0          16640      494/sshd: /usr/sbin
          tcp6       0      0 :::3501                 :::*                    LISTEN      1001       19578      1024/io.sonos.0
          tcp6       0      0 :::3500                 :::*                    LISTEN      0          16710      481/node
          tcp6       0      0 :::3502                 :::*                    LISTEN      1001       64276      1024/io.sonos.0
          tcp6       0      0 :::8087                 :::*                    LISTEN      1001       20332      1441/io.simple-api.
          tcp6       0      0 :::8086                 :::*                    LISTEN      999        15669      485/influxd
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       855052     23109/io.admin.0
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       22637      1552/io.web.0
          udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       18628      886/io.mihome-vacuu
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       22633      1571/io.wled.0
          udp        0      0 192.168.1.8:5353        0.0.0.0:*                           1001       20536      1048/io.tr-064.0
          udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       19704      1098/io.tuya.0
          udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       19705      1098/io.tuya.0
          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          870        1/init
          udp6       0      0 :::111                  :::*                                0          872        1/init
          2024-10-08 11:11:27.982  - info: host.iobroker iobroker upgrade sonoff@3.1.2 --debug
          2024-10-08 11:11:29.945  - info: host.iobroker iobroker Update sonoff from @3.1.0 to @3.1.2
          2024-10-08 11:11:30.088  - info: host.iobroker iobroker NPM version: 10.7.0
          2024-10-08 11:11:30.089  - info: host.iobroker iobroker Installing iobroker.sonoff@3.1.2... (System call)
          2024-10-08 11:11:34.634  - info: host.iobroker iobroker npm error Cannot read properties of null (reading 'match')
          2024-10-08 11:11:34.634  - info: host.iobroker iobroker npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-10-08T09_11_30_206Z-debug-0.log
          2024-10-08 11:11:35.115  - info: host.iobroker iobroker upload [15] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/de/translations.json i18n/de/translations.json application/json
          2024-10-08 11:11:35.121  - info: host.iobroker iobroker upload [14] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/en/translations.json i18n/en/translations.json application/json
          2024-10-08 11:11:35.124  - info: host.iobroker iobroker upload [13] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/es/translations.json i18n/es/translations.json application/json
          2024-10-08 11:11:35.127  - info: host.iobroker iobroker upload [12] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
          2024-10-08 11:11:35.130  - info: host.iobroker iobroker upload [11] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/it/translations.json i18n/it/translations.json application/json
          2024-10-08 11:11:35.138  - info: host.iobroker iobroker upload [10] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
          2024-10-08 11:11:35.141  - info: host.iobroker iobroker upload [9] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
          2024-10-08 11:11:35.145  - info: host.iobroker iobroker upload [8] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
          2024-10-08 11:11:35.149  - info: host.iobroker iobroker upload [7] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
          2024-10-08 11:11:35.152  - info: host.iobroker iobroker upload [6] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
          2024-10-08 11:11:35.157  - info: host.iobroker iobroker upload [5] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
          2024-10-08 11:11:35.160  - info: host.iobroker iobroker upload [4] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/index.html index.html text/html
          2024-10-08 11:11:35.164  - info: host.iobroker iobroker upload [3] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/index_m.html index_m.html text/html
          2024-10-08 11:11:35.168  - info: host.iobroker iobroker upload [2] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/jsonConfig.json jsonConfig.json application/json
          2024-10-08 11:11:35.172  - info: host.iobroker iobroker upload [1] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/sonoff.png sonoff.png image/png
          2024-10-08 11:11:35.175  - info: host.iobroker iobroker upload [0] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/words.js words.js application/javascript
          2024-10-08 11:11:36.195  - info: host.iobroker iobroker exit 0
          2024-10-08 11:17:00.510  - info: sonoff.0 (1023) Client [Garage_OmaOpa] connection closed: closed
          2024-10-08 11:18:03.604  - info: sonoff.0 (1023) Client [Garage_OmaOpa] connected with secret 1728379083603_5620
          Thomas Braun Ro75 2 Replies Last reply Reply Quote 0
            Thomas Braun Most Active @bishop last edited by Thomas Braun
            @bishop
            Bring den Rest erstmal auf Stand.
            iob update
            iob upgrade all -y
            Und installier zuvor nodejs@20:
            iob nodejs-upadate
              bishop @Thomas Braun last edited by Negalein
              alles erledigt
              === Mark text until here for copying ===
              zeus@iobroker:~$
              bash
              s.jsonl> Skript v.2024-08-12
              > *** BASE SYSTEM ***
              >          Chassis: vm 🖴
              >   Virtualization: kvm
              > Operating System: Debian GNU/Linux 12 (bookworm)
              > OS is similar to:
              > Docker          : false
              > Kernel          : x86_64
              > Userland        : 64 bit
              >  13:39:23 up 16:41,  2 users,  load average: 1.34, 1.34, 1.29
              > CPU threads: 2
              .> *** Time and Time Zones ***
              >                Local time: Tue 2024-10-08 13:39:23 CEST
              >            Universal time: Tue 2024-10-08 11:39:23 UTC
              >                  RTC time: Tue 2024-10-08 11:39:23
              >                 Time zone: Europe/Berlin (CEST, +0200)
              > System clock synchronized: yes
              >               NTP service: active
              >           RTC in local TZ: no
              > zeus
              > HOME=/home/zeus
              > User that is running 'js-controller':
              > iobroker
              > HOME=/home/iobroker
              o> *** Display-Server-Setup ***
              > Desktop:
              > Terminal:       tty
              > Boot Target:    graphical.target
              n> *** MEMORY ***
              >                total        used        free      shared  buff/cache   available
              0.x > Mem:             33G        5.0G         26G        565K        2.9G         28G
              > Swap:           1.0G          0B        1.0G
              > Total:           34G        5.0G         27G
              u>         32097 M total memory
              >          4806 M used memory
              >           883 M active memory
              >          5842 M inactive memory
              >         24925 M free memory
              >           278 M buffer memory
              >          2461 M swap cache
              >           974 M total swap
              >             0 M used swap
              >           974 M free swap
              > *** top - Table Of Processes  ***
              > top - 13:39:24 up 16:41,  2 users,  load average: 1.34, 1.34, 1.29
              > %Cpu(s):  0.0 us,100.0 sy,  0.0 ni,  0.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
              > MiB Mem :  32097.1 total,  24925.6 free,   4806.4 used,   2739.5 buff/cache
              > MiB Swap:    975.0 total,    975.0 free,      0.0 used.  27290.7 avail Mem
              >   UNIT LOAD ACTIVE SUB DESCRIPTION
              > *** FILESYSTEM ***
              > Filesystem     Type      Size  Used Avail Use% Mounted on
              > /dev/sda1      ext4       15G   14G  482M  97% /
              > Messages concerning ext4 filesystem in dmesg:
              > Files in neuralgic directories:
              > /var:
              > 1.8G    /var/
              > 1.4G    /var/log
              > 250M    /var/cache
              > Hint: You are currently not seeing messages from other users and the system.
              >       Users in groups 'adm', 'systemd-journal' can see all messages.
              main amd64 Packages
                   20.4.0-1nodesource1 1001
                      500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                   20.3.1-1nodesource1 1001
                   20.3.0-1nodesource1 1001
                      500 https://d>       Pass -q to turn off this notice.
              > 442M    /opt/iobroker/iobroker-data/files/javascript.admin
              > 410M    /opt/iobroker/iobroker-data/files/javascript.admin/static
              > The five largest files in iobroker-data are:
              > 92M     /opt/iobroker/iobroker-data/objects.jsonl
              > 52M     /opt/iobroker/iobroker-data/states.jsonl
              > USB-Devices by-id:
              > USB-Sticks -  Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id':
              > HINT:
              > /dev/ttyACM0
              > /usr/bin/nodejs         v20.18.0
              > /usr/bin/node           v20.18.0
              > /usr/bin/npm            10.8.2
              > /usr/bin/npx            10.8.2
              > /usr/bin/corepack       0.29.3
              > nodejs:
              >   Installed: 20.18.0-1nodesource1
              >   Candidate: 20.18.0-1nodesource1
              >   Version table:
              >  *** 20.18.0-1nodesource1 1001
              >      20.17.0-1nodesource1 1001
              >      20.16.0-1nodesource1 1001
              >      20.15.1-1nodesource1 1001
              >      20.15.0-1nodesource1 1001
              >      20.14.0-1nodesource1 1001
              >      20.13.1-1nodesource1 1001
              >      20.13.0-1nodesource1 1001
              >      20.12.2-1nodesource1 1001
              >      20.12.1-1nodesource1 1001
              >      20.12.0-1nodesource1 1001
              >      20.11.1-1nodesource1 1001
              >      20.11.0-1nodesource1 1001
              >      20.10.0-1nodesource1 1001
              >      20.9.0-1nodesource1 1001
              >      20.8.1-1nodesource1 1001
              >      20.8.0-1nodesource1 1001
              >      20.7.0-1nodesource1 1001
              >      20.6.1-1nodesource1 1001
              >      20.6.0-1nodesource1 1001
              >      20.5.1-1nodesource1 1001
              >      20.5.0-1nodesource1 1001
              >      20.2.0-1nodesource1 1001
              >      20.1.0-1nodesource1 1001
              >      20.0.0-1nodesource1 1001
              > Temp directories causing npm8 problem: 0
              > Errors in npm tree:
              > ioBroker Status
              > iobroker is running on this host.
              > Objects type: jsonl
              > States  type: jsonl
              > admin:          7.1.2
              > javascript:     8.7.6
              > Adapter State
              > + instance is alive
              > Enabled adapters with bindings
              > Adapter    "alias-manager": 1.2.6    , installed 1.2.6
              > Adapter    "devices"      : 1.1.5    , installed 1.1.5
              > Adapter    "flot"         : 1.12.0   , installed 1.12.0
              > Adapter    "history"      : 3.0.1    , installed 3.0.1
              //deb.nodesource.com/> Adapter    "iot"          : 3.3.0    , installed 3.3.0
              > Adapter    "ping"         : 1.6.2    , installed 1.6.2
              > Adapter    "vis"          : 1.5.6    , installed 1.5.6
              > Adapter    "vis-bars"     : 0.1.4    , installed 0.1.4
              > Adapter    "vis-fancyswitch": 1.1.0  , installed 1.1.0
              > Adapter    "vis-hqwidgets": 1.5.1    , installed 1.5.1
              > Adapter    "vis-materialdesign": 0.5.9, installed 0.5.9
              > Adapter    "vis-metro"    : 1.2.0    , installed 1.2.0
              > Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
              > Adapter    "vis-plumb"    : 1.0.2    , installed 1.0.2
              > Adapter    "vis-timeandweather": 1.2.2, installed 1.2.2
              > Objects and States
              > Please stand by - This may take a while
              > Objects:        67302
              > States:         57872
              > *** OS-Repositories and Updates ***
              dmin /o> Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
              > Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
              > Pending Updates: 0
              > Active Internet connections (only servers)
              > Proto Recv-Q Send-Q Local Address           Foreign Address         State       User       Inode      PID/Program name
              > tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       1001859    30144/iobroker.js-c
              > tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       1001864    30144/iobroker.js-c
              > tcp        0      0 0.0.0.0:25586           0.0.0.0:*               LISTEN      1001       1006587    31231/io.sainlogic.
              > tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       1005206    30761/io.shelly.0
              > tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       1004033    30630/io.sonoff.0
              > tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       1004623    30552/io.mqtt.0
              > tcp        0      0 192.168.1.8:2010        0.0.0.0:*               LISTEN      1001       1003561    30500/io.hm-rpc.1
              > tcp        0      0 192.168.1.8:2001        0.0.0.0:*               LISTEN      1001       1002491    30474/io.hm-rpc.0
              > tcp6       0      0 :::3501                 :::*                    LISTEN      1001       1004163    30632/io.sonos.0
              > tcp6       0      0 :::8087                 :::*                    LISTEN      1001       1006842    31013/io.simple-api
              > tcp6       0      0 :::8081                 :::*                    LISTEN      1001       1001959    30165/io.admin.0
              > tcp6       0      0 :::8082                 :::*                    LISTEN      1001       1006290    31128/io.web.0
              > udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       1003507    30541/io.mihome-vac
              > udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       1006261    31150/io.wled.0
              > udp        0      0 192.168.1.8:5353        0.0.0.0:*                           1001       1004278    30650/io.tr-064.0
              > udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       1005202    30684/io.tuya.0
              > udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       1005203    30684/io.tuya.0
              > *** Log File - Last 25 Lines ***
              > 2024-10-08 13:32:08.380  - info: host.iobroker iobroker upload [10] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
              > 2024-10-08 13:32:08.388  - info: host.iobroker iobroker upload [9] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
              > 2024-10-08 13:32:08.392  - info: host.iobroker iobroker upload [8] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
              > 2024-10-08 13:32:08.404  - info: host.iobroker iobroker upload [7] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
              > 2024-10-08 13:32:08.413  - info: host.iobroker iobroker upload [6] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
              > 2024-10-08 13:32:08.425  - info: host.iobroker iobroker upload [5] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
              > 2024-10-08 13:32:08.435  - info: host.iobroker iobroker upload [4] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/index.html index.html text/html
              > 2024-10-08 13:32:08.444  - info: host.iobroker iobroker upload [3] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/index_m.html index_m.html text/html
              > 2024-10-08 13:32:08.452  - info: host.iobroker iobroker upload [2] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/jsonConfig.json jsonConfig.json application/json
              > 2024-10-08 13:32:08.461  - info: host.iobroker iobroker upload [1] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/sonoff.png sonoff.png image/png
              > 2024-10-08 13:32:08.471  - info: host.iobroker iobroker upload [0] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/words.js words.js application/javascript
              > 2024-10-08 13:32:09.500  - info: host.iobroker iobroker exit 0
              > 2024-10-08 13:33:10.299  - info: web.0 (31128) <== Disconnect system.user.admin from ::ffff:192.168.1.205 iqontrol.0
              > 2024-10-08 13:33:12.340  - info: web.0 (31128) <== Disconnect system.user.admin from ::ffff:192.168.1.205
              > 2024-10-08 13:35:54.012  - info: host.iobroker instance system.adapter.weatherunderground.0 in version "3.7.0" started with pid 31476
              > 2024-10-08 13:35:55.941  - info: weatherunderground.0 (31476) starting. Version 3.7.0 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v20.18.0, js-controller: 6.0.11
              > 2024-10-08 13:36:12.372  - info: weatherunderground.0 (31476) Terminated (NO_ERROR): Without reason
              > 2024-10-08 13:36:12.887  - info: host.iobroker instance system.adapter.weatherunderground.0 having pid 31476 terminated with code 0 (NO_ERROR)
              > 2024-10-08 13:36:20.295  - info: admin.0 (30165) <== Disconnect system.user.admin from ::ffff:192.168.1.205 admin
              > 2024-10-08 13:37:55.308  - info: host.iobroker instance system.adapter.yr.0 in version "5.3.0" started with pid 31543
              > 2024-10-08 13:37:57.349  - info: yr.0 (31543) starting. Version 5.3.0 in /opt/iobroker/node_modules/iobroker.yr, node: v20.18.0, js-controller: 6.0.11
              > 2024-10-08 13:37:57.366  - info: yr.0 (31543) longitude/longitude will be set by self-Config - longitude: 9.236412048339844 latitude: 49.186699923402585
              > 2024-10-08 13:38:34.086  - info: yr.0 (31543) Data updated.
              > 2024-10-08 13:38:34.086  - info: yr.0 (31543) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              > 2024-10-08 13:38:34.606  - info: host.iobroker instance system.adapter.yr.0 having pid 31543 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              zeus@iobroker:~$
              zeus@iobroker:~$ ============ Mark until here for C&P =============
              [1] 32831
              bash: ============: Kommando nicht gefunden.
              bash: P: Kommando nicht gefunden.
              [1]+  Exit 127                ============ Mark until here for C
              zeus@iobroker:~$
              zeus@iobroker:~$ iob diag has finished.
              npm error code ELSPROBLEMS
              npm error missing: homebridge-samsung-air-conditioner-smart-things@^1.0.9, required by iobroker.ham@5.3.1
              npm error missing: homebridge@^1.5.0, required by iobroker.ham@5.3.1
              npm error A complete log of this run can be found in: /home/zeus/.npm/_logs/2024-10-08T11_42_12_128Z-debug-0.log
              Press any key for a summary
              Copy text starting here:
              ```bash
                                      v.2024-08-12
                       Chassis: vm 🖴
                Virtualization: kvm
              Installation:           kvm
              User-ID:                1000
              Pending OS-Updates:     0
              Pending iob updates:    16
              Nodejs-Installation:
              Recommended versions are nodejs 20.18.0 and npm 10.8.2
              MEMORY:
              Mem:             33G        5.2G         25G        569K        2.9G         28G
              Swap:           1.0G          0B        1.0G
              Total:           34G        5.2G         26G
              ioBroker Core:          js-controller           6.0.11
                                      admin                   7.1.2
              Objects type: jsonl
              States  type: jsonl
              Objects:                67302
              States:                 57872
              Size of iob-Database:
              56M     /opt/iobroker/iobroker-data/states.jsonl
              EDIT: sehe gerade, dass ich wenig Speicherplatz habe.
              • Ro75
                Ro75 @bishop last edited by
                @bishop sagte in Adapter Update funktioniert nicht "Generell":
                Das wird und ist aber sehr eng und knapp. Dir geht der Speicherplatz aus.
                Ro75.
                  bishop @Ro75 last edited by bishop
                  so hab mal den Festplattenplatz erweitert.
                  @Thomas-Braun
                  iob update
                  iob upgrade all -y
                  scheint nicht zu fruchten.
                  Hab nochmal ein Diag gemacht:
                  ```bash
                  Skript v.2024-08-12
                  *** BASE SYSTEM ***
                           Chassis: vm 🖴
                    Virtualization: kvm
                  OS is similar to:
                  Docker          : false
                  Kernel          : x86_64
                  Userland        : 64 bit
                   17:09:30 up 12 min,  2 users,  load average: 0.72, 1.24, 0.90
                  CPU threads: 2
                                 Local time: Tue 2024-10-08 17:09:30 CEST
                             Universal time: Tue 2024-10-08 15:09:30 UTC
                                   RTC time: Tue 2024-10-08 15:09:30
                                NTP service: active
                            RTC in local TZ: no
                  zeus
                  HOME=/home/zeus
                  iobroker
                  HOME=/home/iobroker
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Mem:             16G        4.9G         11G        561K        785M         11G
                  Swap:             0B          0B          0B
                  Total:           16G        4.9G         11G
                          15993 M total memory
                           4669 M used memory
                            251 M active memory
                           4656 M inactive memory
                          10802 M free memory
                             66 M buffer memory
                            682 M swap cache
                              0 M total swap
                              0 M used swap
                              0 M free swap
                  top - 17:09:31 up 12 min,  2 users,  load average: 0.72, 1.24, 0.90
                  Tasks: 147 total,   1 running, 146 sleeping,   0 stopped,   0 zombie
                  %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                  MiB Mem :  15993.1 total,  10802.0 free,   4669.8 used,    749.1 buff/cache
                  MiB Swap:      0.0 total,      0.0 free,      0.0 used.  11323.3 avail Mem
                  *** FILESYSTEM ***
                  udev           devtmpfs  7.8G     0  7.8G   0% /dev
                  tmpfs          tmpfs     1.6G  556K  1.6G   1% /run
                  /dev/sda1      ext4       30G   11G   18G  39% /
                  tmpfs          tmpfs     7.9G     0  7.9G   0% /dev/shm
                  tmpfs          tmpfs     1.6G     0  1.6G   0% /run/user/1000
                  [Tue Oct  8 16:57:10 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
                  [Tue Oct  8 16:57:10 2024] EXT4-fs (sda1): re-mounted. Quota mode: none.
                  /var:
                  1.7G    /var/
                  1.4G    /var/log
                  200M    /var/lib
                  1.7G    /opt/iobroker/iobroker-data/
                  408M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                  122M    /opt/iobroker/iobroker-data/objects.jsonl
                  105M    /opt/iobroker/iobroker-data/states.jsonl
                  USB-Devices by-id:
                  HINT:
                  /dev/ttyACM0
                  nodejs:
                    Version table:
                  Errors in npm tree:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  admin:          7.1.2
                  javascript:     8.7.6
                  Adapter State
                  + instance is alive
                  Objects and States
                  Objects:        67302
                  States:         57872
                  Pending Updates: 0
                  tcp        0      0 0.0.0.0:5005            0.0.0.0:*               LISTEN      0          15078      653/node
                  tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        16383      658/influxd
                  tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       19545      1213/io.sonoff.0
                  tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       19117      1361/io.shelly.0
                  tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       18187      1146/io.mqtt.0
                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15057      666/sshd: /usr/sbin
                  tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          1722       1/init
                  tcp        0      0 0.0.0.0:25586           0.0.0.0:*               LISTEN      1001       21210      1836/io.sainlogic.0
                  tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       16443      709/iobroker.js-con
                  tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       16438      709/iobroker.js-con
                  tcp        0      0 192.168.1.8:2001        0.0.0.0:*               LISTEN      1001       17141      1068/io.hm-rpc.0
                  tcp        0      0 192.168.1.8:2010        0.0.0.0:*               LISTEN      1001       17192      1094/io.hm-rpc.1
                  tcp6       0      0 :::8086                 :::*                    LISTEN      999        15089      658/influxd
                  tcp6       0      0 :::8087                 :::*                    LISTEN      1001       20462      1620/io.simple-api.
                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       20964      1728/io.web.0
                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       17489      759/io.admin.0
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          15059      666/sshd: /usr/sbin
                  tcp6       0      0 :::111                  :::*                    LISTEN      0          1724       1/init
                  tcp6       0      0 :::3500                 :::*                    LISTEN      0          15091      653/node
                  tcp6       0      0 :::3501                 :::*                    LISTEN      1001       18779      1230/io.sonos.0
                  udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       17285      1135/io.mihome-vacu
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       21963      1746/io.wled.0
                  udp        0      0 192.168.1.8:5353        0.0.0.0:*                           1001       18913      1253/io.tr-064.0
                  udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       19701      1260/io.tuya.0
                  udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       19702      1260/io.tuya.0
                  udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1723       1/init
                  udp6       0      0 :::111                  :::*                                0          1725       1/init
                  2024-10-08 17:04:56.812  - info: javascript.0 (830) script.js.common.Ip.neugeraete-ermitteln: Neue Ip
                  192.168.1.113
                  2024-10-08 17:04:56.817  - info: javascript.0 (830) script.js.common.Ip.neugeraete-ermitteln: Neue Ip
                  192.168.1.2
                  2024-10-08 17:04:56.822  - info: javascript.0 (830) script.js.common.Ip.neugeraete-ermitteln: Neue Ip
                  192.168.1.92
                  2024-10-08 17:04:56.828  - info: javascript.0 (830) script.js.common.Ip.neugeraete-ermitteln: Neue Ip
                  192.168.1.6
                  2024-10-08 17:04:56.833  - info: javascript.0 (830) script.js.common.Ip.neugeraete-ermitteln: Neue Ip
                  192.168.1.39
                  2024-10-08 17:04:56.839  - info: javascript.0 (830) script.js.common.Ip.neugeraete-ermitteln: Neue Ip
                  192.168.1.124
                  2024-10-08 17:04:56.846  - info: javascript.0 (830) script.js.common.Ip.neugeraete-ermitteln: Neue Ip
                  192.168.1.222
                  2024-10-08 17:04:56.853  - info: javascript.0 (830) script.js.common.Ip.neugeraete-ermitteln: Neue Ip
                  192.168.1.31
                  2024-10-08 17:04:56.858  - info: javascript.0 (830) script.js.common.Ip.neugeraete-ermitteln: Neue Ip
                  192.168.1.30
                  2024-10-08 17:04:56.864  - info: javascript.0 (830) script.js.common.Ip.neugeraete-ermitteln: Neue Ip
                  192.168.1.246
                  2024-10-08 17:04:56.869  - info: javascript.0 (830) script.js.common.Ip.neugeraete-ermitteln: Neue Ip
                  192.168.1.55
                  2024-10-08 17:04:56.875  - info: javascript.0 (830) script.js.common.Ip.neugeraete-ermitteln: Neue Ip
                  192.168.1.8
                  2024-10-08 17:06:12.393  - info: admin.0 (759) ==> Connected system.user.admin from ::ffff:192.168.1.176
                    Was wird denn dazu gemeldet?
                      läuft durch ohne fehler
                        @bishop
                        iob update
                        iob upgrade admin@7.1.5
                        Bitte vollständig Ein- wie Ausgaben posten, nix nacherzählen.
                          @thomas-braun sagte in Adapter Update funktioniert nicht "Generell":
                          iob update
                          zeus@iobroker:~$ iob update
                          zeus@iobroker:~$ ^C
                          zeus@iobroker:~$ iob upgrade admin@7.1.5
                          This upgrade of "admin" will introduce the following changes:
                          -> 7.1.5:
                          Added the read-only flag to the `state` JSON Config component
                          -> 7.1.3:
                          improve appearance and standardization of some warning messages
                          indicate `alert` warnings by the badge color on the notification button
                          allow to distinguish between alert notifications and others for host notifications
                          do not automatically open the notification dialog without user interaction
                          fixed logging as socket client is now throwing real errors
                          Would you like to upgrade admin from @7.1.2 to @7.1.5 now? [(y)es, (n)o]: y
                          Update admin from @7.1.2 to @7.1.5
                          host.iobroker Adapter "system.adapter.admin.0" is stopped.
                          NPM version: 10.8.2
                          Installing iobroker.admin@7.1.5... (System call)
                          upload [68] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
                          upload [60] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/it.json custom/i18n/it.json application/json
                          upload [50] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23730.1d6892ae.chunk.js custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23730.1d6892ae.chunk.js application/javascript
                          upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/src_bootstrap_jsx.aca93d2e.chunk.js custom/static/js/src_bootstrap_jsx.aca93d2e.chunk.js application/javascript
                          upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_FilledInput_FilledInput_js.9c980ca7.chunk.js custom/static/js/vendors-node_modules_mui_material_FilledInput_FilledInput_js.9c980ca7.chunk.js application/javascript
                          upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-ace_lib_index_js.55163eef.chunk.js custom/static/js/vendors-node_modules_react-ace_lib_index_js.55163eef.chunk.js application/javascript
                          upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-ace_lib_index_js.55163eef.chunk.js.map custom/static/js/vendors-node_modules_react-ace_lib_index_js.55163eef.chunk.js.map application/json
                          upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-color_es_index_js-node_modules_react-icons_lib_index_mjs.94169d3c.chunk.js custom/static/js/vendors-node_modules_react-color_es_index_js-node_modules_react-icons_lib_index_mjs.94169d3c.chunk.js application/javascript
                          upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-color_es_index_js-node_modules_react-icons_lib_index_mjs.94169d3c.chunk.js.map custom/static/js/vendors-node_modules_react-color_es_index_js-node_modules_react-icons_lib_index_mjs.94169d3c.chunk.js.map application/json
                          upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.8a166965.chunk.js custom/static/js/vendors-node_modules_react-dom_index_js.8a166965.chunk.js application/javascript
                          upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.8a166965.chunk.js.map custom/static/js/vendors-node_modules_react-dom_index_js.8a166965.chunk.js.map application/json
                          upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.91b1d9b3.chunk.js custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.91b1d9b3.chunk.js application/javascript
                          upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.91b1d9b3.chunk.js.map custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.91b1d9b3.chunk.js.map application/json
                          upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
                          upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
                          upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
                          upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
                          upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                          upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
                          upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                          upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                          upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                          upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                          upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                          upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                          upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5 jsonConfig.json5 application/json5
                          host.iobroker Adapter "system.adapter.admin.0" is started
                          zeus@iobroker:~$ ^C
                          zeus@iobroker:~$
                          Ro75 1 Reply Last reply Reply Quote 0
                          • Ro75
                            ^C
                            Warum "ABBRUCH"??
                            Ro75.
                              @ro75
                              strg + c
                              kopieren aus der Console raus
                              -> 7.1.5:
                              -> 7.1.3:
                              NPM version: 10.8.2
                              zeus@iobroker:~$
                              • Codierknecht
                                @bishop
                                Was passiert, wenn Du Dich in /opt/iobroker stellst und dort das Update anschubst?
                                B H 2 Replies Last reply Reply Quote 0
                                  bishop @Codierknecht last edited by bishop
                                  @codierknecht
                                  dank für die Hilfe 🙂
                                  zeus@iobroker:/opt/iobroker$ iob upgrade admin@7.1.5
                                  -> 7.1.5:
                                  -> 7.1.3:
                                  NPM version: 10.8.2
                                  zeus@iobroker:/opt/iobroker$ iob update
                                  aber er macht es einfach nicht
                                    bishop last edited by bishop
                                    so hab jetzt mal eine neue VM aufgesetz und alles komplett neu installiert.
                                    Cannot download repository hash file from "http://download.iobroker.net/sources-dist-hash.json":
                                    Adapter    "admin"        : 7.1.5    , installed 7.1.5
                                    Adapter    "alarm"        : 3.6.2    , installed 3.6.2
                                    Adapter    "backitup"     : 3.0.22   , installed 3.0.22
                                    Adapter    "discovery"    : 5.0.0    , installed 5.0.0
                                    Adapter    "email"        : 1.3.1    , installed 1.3.1
                                    Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
                                    Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
                                    Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                                    Adapter    "lightcontrol" : 0.8.0    , installed 0.8.0
                                    Adapter    "pixelit"      : 1.1.4    , installed 1.1.4
                                    Adapter    "scenes"       : 3.2.3    , installed 3.2.3
                                    Adapter    "shelly"       : 8.2.1    , installed 8.2.1
                                    Adapter    "shuttercontrol": 1.7.3   , installed 1.8.2
                                    Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
                                    Adapter    "telegram-menu": 2.0.0    , installed 2.0.0
                                    Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
                                    Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
                                    Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
                                    zeus@iobroker:~$
                                    muss ich mir um den repository hash sorgen machen?
                                    edit: jetzt kommt es nicht mehr 🙂
                                      HannoSch @Codierknecht last edited by Samson71
                                      @codierknecht Ich habe auch das Problem, dass sich Adapter nicht aktualisieren lassen. Habe den Tread mal durchgearbeitet, komme aber nicht weiter.
                                      hier mein System:
                                                              v.2025-02-23
                                             Icon name: computer
                                                Kernel: Linux 6.6.62+rpt-rpi-v8
                                          Architecture: arm64
                                      User-ID:                1000
                                      Pending OS-Updates:     1
                                      /usr/bin/nodejs         v20.19.0
                                      /usr/bin/node           v20.19.0
                                      /usr/bin/corepack       0.31.0
                                      Recommended versions are nodejs 20.19.0 and npm 10.8.2
                                      nodeJS installation is correct
                                      MEMORY:
                                      Mem:            8.2G        1.5G        619M        290K        6.2G        6.7G
                                      Swap:           536M        5.8M        531M
                                      Total:          8.7G        1.6G        1.2G
                                      Active iob-Instances:   19
                                      Upgrade policy: patch
                                      ioBroker Core:          js-controller           7.0.6
                                                              admin                   7.4.10
                                      Objects type: jsonl
                                      States  type: jsonl
                                      Objects:                3563
                                      States:                 2473
                                      15M     /opt/iobroker/iobroker-data/objects.jsonl
                                      1.2M    /opt/iobroker/iobroker-data/states.jsonl
                                      337 CRITICAL ERRORS DETECTED!
                                      Check 'sudo dmesg --level=emerg,alert,crit -T' for details
                                      Operating System is the current Debian stable version codenamed 'bookworm'!
                                      Das die letzte Fehlermeldung:
                                      hanno@iobroker:~ $ cd /opt/iobroker
                                      hanno@iobroker:/opt/iobroker $ iob stop
                                      hanno@iobroker:/opt/iobroker $ iob update
                                      Adapter    "admin"        : 7.4.10   , installed 7.4.10
                                      Adapter    "backitup"     : 3.0.31   , installed 3.0.31
                                      Adapter    "bsblan"       : 0.3.4    , installed 0.3.4
                                      Adapter    "bshb"         : 0.5.0    , installed 0.5.0
                                      Adapter    "chromecast"   : 4.0.0    , installed 4.0.0
                                      Adapter    "echarts"      : 1.9.2    , installed 1.9.2
                                      Adapter    "energiefluss-erweitert": 0.6.2, installed 0.6.2
                                      Adapter    "fb-checkpresence": 1.3.1 , installed 1.2.8  [Updatable]
                                      Adapter    "go-e"         : 1.0.41   , installed 1.0.41
                                      Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
                                      Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
                                      Controller "js-controller": 7.0.6    , installed 7.0.6
                                      Adapter    "modbus"       : 6.3.2    , installed 6.3.2
                                      Adapter    "node-red"     : 5.2.1    , installed 5.2.1
                                      Adapter    "shelly"       : 8.5.1    , installed 8.5.1
                                      Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
                                      Adapter    "vis-2-widgets-inventwo": 0.1.11, installed 0.1.11
                                      Adapter    "vis-2-widgets-jaeger-design": 1.2.7, installed 1.2.7
                                      hanno@iobroker:/opt/iobroker $ iob upgrade all -y
                                      Update fb-checkpresence from @1.2.8 to @1.3.1
                                      NPM version: 10.8.2
                                      Installing iobroker.fb-checkpresence@1.3.1... (System call)
                                      npm error code Unknown system error -74
                                      npm error syscall mkdir
                                      npm error path /opt/iobroker/node_modules/http-proxy-middleware/node_modules/is-plain-obj
                                      npm error errno -74
                                      npm error Unknown system error -74: Unknown system error -74, mkdir '/opt/iobroker/node_modules/http-proxy-middleware/node_modules/is-plain-obj'
                                      npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-03-23T12_42_27_746Z-debug-0.log
                                      host.iobroker Cannot install iobroker.fb-checkpresence@1.3.1: 182
                                      Vielleicht kannst du mir ja helfen. Vielen Dank.
                                        Thomas Braun Most Active @HannoSch last edited by
                                        @hannosch sagte in Adapter Update funktioniert nicht "Generell":
                                        Was ist denn da los?
                                          HannoSch @Thomas Braun last edited by Homoran
                                          @thomas-braun das hier:
                                          hanno@iobroker:~ $ sudo dmesg --level=emerg,alert,crit -T
                                          [Wed Feb 19 11:55:45 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #509363: comm find: Directory block failed checksum
                                          [Wed Feb 19 11:55:45 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #509361: comm find: Directory block failed checksum
                                          [Wed Feb 19 13:04:40 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #509363: comm chown: Directory block failed checksum
                                          [Wed Feb 19 13:04:40 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #509361: comm chown: Directory block failed checksum
                                          [Wed Feb 19 13:04:44 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #509363: comm chown: Directory block failed checksum
                                          [Wed Feb 19 13:04:44 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #509361: comm chown: Directory block failed checksum
                                          [Wed Feb 19 13:04:46 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #509363: comm setfacl: Directory block failed checksum
                                          [Wed Feb 19 13:04:46 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #509361: comm setfacl: Directory block failed checksum
                                          [Wed Feb 19 13:04:47 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #509363: comm setfacl: Directory block failed checksum
                                          [Wed Feb 19 13:04:47 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #509361: comm setfacl: Directory block failed checksum
                                          [Wed Feb 19 13:04:48 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #509363: comm find: Directory block failed checksum
                                          [Wed Feb 19 13:04:48 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #509361: comm find: Directory block failed checksum
                                          [Sun Mar  9 12:17:05 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                          [Sun Mar  9 12:17:11 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                          [Sun Mar  9 12:17:23 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                          [Sun Mar  9 12:18:05 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm npm: Directory block failed checksum
                                          [Sun Mar  9 12:18:05 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386735: comm npm: Directory block failed checksum
                                          [Sun Mar  9 12:18:07 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm npm: Directory block failed checksum
                                          [Sun Mar  9 12:18:07 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386735: comm npm: Directory block failed checksum
                                          [Sun Mar  9 12:18:09 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386733: comm npm: checksumming directory block 0
                                          [Sun Mar  9 12:18:09 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386735: comm npm: checksumming directory block 0
                                          [Sun Mar  9 12:18:42 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm npm: Directory block failed checksum
                                          [Sun Mar  9 12:18:42 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386735: comm npm: Directory block failed checksum
                                          [Sun Mar  9 12:18:43 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386733: comm npm: checksumming directory block 0
                                          [Sun Mar  9 12:18:43 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386735: comm npm: checksumming directory block 0
                                          [Sun Mar  9 12:19:09 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm npm: Directory block failed checksum
                                          [Sun Mar  9 12:19:09 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386735: comm npm: Directory block failed checksum
                                          [Sun Mar  9 12:19:10 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386733: comm npm: checksumming directory block 0
                                          [Sun Mar  9 12:19:10 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386735: comm npm: checksumming directory block 0
                                          [Sun Mar  9 12:19:16 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                          [Sun Mar  9 12:19:53 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                          [Sun Mar  9 12:20:33 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm npm: Directory block failed checksum
                                          [Sun Mar  9 12:20:33 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386735: comm npm: Directory block failed checksum
                                          [Sun Mar  9 12:20:34 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386733: comm npm: checksumming directory block 0
                                          [Sun Mar  9 12:20:34 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386735: comm npm: checksumming directory block 0
                                          [Sun Mar  9 12:20:48 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                          [Sun Mar  9 12:21:24 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm npm: Directory block failed checksum
                                          [Sun Mar  9 12:21:24 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386735: comm npm: Directory block failed checksum
                                          [Sun Mar  9 12:21:25 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386733: comm npm: checksumming directory block 0
                                          [Sun Mar  9 12:21:25 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386735: comm npm: checksumming directory block 0
                                          [Sun Mar  9 12:28:37 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                          [Sun Mar  9 12:28:54 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                          [Sun Mar  9 12:29:06 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                          [Sun Mar  9 12:29:15 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                          [Sun Mar  9 12:29:41 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                          [Sun Mar  9 12:30:06 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm npm: Directory block failed checksum
                                          [Sun Mar  9 12:30:06 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386735: comm npm: Directory block failed checksum
                                          [Sun Mar  9 12:30:07 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386733: comm npm: checksumming directory block 0
                                          [Sun Mar  9 12:30:07 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386735: comm npm: checksumming directory block 0
                                          [Sun Mar  9 12:32:28 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                          [Sun Mar  9 12:32:38 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                          [Sun Mar  9 12:33:39 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                          [Sun Mar  9 12:40:38 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                          [Sun Mar  9 12:41:32 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                          [Sun Mar  9 12:42:04 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                          [Sun Mar  9 12:42:35 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm npm: Directory block failed checksum
                                          [Sun Mar  9 12:42:36 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386735: comm npm: Directory block failed checksum
                                          [Sun Mar  9 12:42:37 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386733: comm npm: checksumming directory block 0
                                          [Sun Mar  9 12:42:37 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386735: comm npm: checksumming directory block 0
                                          [Sun Mar  9 12:43:07 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm npm: Directory block failed checksum
                                          [Sun Mar  9 12:43:07 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386735: comm npm: Directory block failed checksum
                                          [Sun Mar  9 12:43:08 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386735: comm npm: checksumming directory block 0
                                          [Sun Mar  9 12:43:08 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386733: comm npm: checksumming directory block 0
                                          [Sun Mar  9 12:45:18 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm npm: Directory block failed checksum
                                          [Sun Mar  9 12:45:18 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386735: comm npm: Directory block failed checksum
                                          [Sun Mar  9 12:45:19 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386733: comm npm: checksumming directory block 0
                                          [Sun Mar  9 12:45:19 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386735: comm npm: checksumming directory block 0
                                          [Sun Mar  9 14:59:16 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                          [Sun Mar  9 14:59:41 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                          [Sun Mar  9 14:59:43 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                          [Sun Mar  9 15:13:44 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                          [Sun Mar  9 16:07:04 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                          [Sun Mar  9 16:08:55 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                          [Sun Mar  9 16:09:58 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                          [Sun Mar  9 16:11:47 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                          [Sun Mar  9 16:11:53 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                          [Sun Mar  9 16:14:05 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                          [Tue Mar 11 17:34:32 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                          [Tue Mar 11 17:37:38 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                          [Thu Mar 13 12:53:17 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                          [Thu Mar 13 12:54:30 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                          [Thu Mar 13 17:52:22 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                          [Thu Mar 13 17:54:09 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm npm: Directory block failed checksum
                                          [Thu Mar 13 17:54:09 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386735: comm npm: Directory block failed checksum
                                          [Thu Mar 13 17:54:11 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386733: comm npm: checksumming directory block 0
                                          [Thu Mar 13 17:54:11 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386735: comm npm: checksumming directory block 0
                                          [Sun Mar 16 10:56:56 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                          [Sun Mar 16 11:09:15 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                          [Sun Mar 16 11:10:33 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                          [Sun Mar 16 11:10:41 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                          [Sun Mar 16 11:18:48 2025] EXT4-fs error (device mmcblk0p2): ext4_lookup:1858: inode #63889: comm dpkg: iget: bad extra_isize 59606 (inode size 256)
                                          [Sun Mar 16 11:21:10 2025] EXT4-fs error (device mmcblk0p2): ext4_lookup:1858: inode #63889: comm dpkg: iget: bad extra_isize 59606 (inode size 256)
                                          [Sun Mar 16 11:26:58 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #395917: comm chown: Directory block failed checksum
                                          [Sun Mar 16 11:26:59 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #509363: comm chown: Directory block failed checksum
                                          [Sun Mar 16 11:26:59 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #509361: comm chown: Directory block failed checksum
                                          [Sun Mar 16 11:26:59 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #395904: comm chown: Directory block failed checksum
                                          [Sun Mar 16 11:27:00 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407153: comm chown: Directory block failed checksum
                                          [Sun Mar 16 11:27:00 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407159: comm chown: Directory block failed checksum
                                          [Sun Mar 16 11:27:01 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #396063: comm chown: Directory block failed checksum
                                          [Sun Mar 16 11:27:01 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm chown: Directory block failed checksum
                                          [Sun Mar 16 11:27:01 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407143: comm chown: Directory block failed checksum
                                          [Sun Mar 16 11:27:02 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #395908: comm chown: Directory block failed checksum
                                          [Sun Mar 16 11:27:03 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407148: comm chown: Directory block failed checksum
                                          [Sun Mar 16 11:27:05 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #395917: comm chown: Directory block failed checksum
                                          [Sun Mar 16 11:27:05 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #509363: comm chown: Directory block failed checksum
                                          [Sun Mar 16 11:27:05 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #509361: comm chown: Directory block failed checksum
                                          [Sun Mar 16 11:27:06 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #395904: comm chown: Directory block failed checksum
                                          [Sun Mar 16 11:27:06 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407153: comm chown: Directory block failed checksum
                                          [Sun Mar 16 11:27:06 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407159: comm chown: Directory block failed checksum
                                          [Sun Mar 16 11:27:08 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #396063: comm chown: Directory block failed checksum
                                          [Sun Mar 16 11:27:09 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm chown: Directory block failed checksum
                                          [Sun Mar 16 11:27:09 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407143: comm chown: Directory block failed checksum
                                          [Sun Mar 16 11:27:09 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #395908: comm chown: Directory block failed checksum
                                          [Sun Mar 16 11:27:10 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386735: comm chown: Directory block failed checksum
                                          [Sun Mar 16 11:27:10 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407148: comm chown: Directory block failed checksum
                                          [Sun Mar 16 11:27:11 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407145: comm chown: Directory block failed checksum
                                          [Sun Mar 16 11:27:11 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #396073: comm chown: Directory block failed checksum
                                          [Sun Mar 16 11:27:12 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #396081: comm chown: Directory block failed checksum
                                          [Sun Mar 16 11:27:12 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #396057: comm chown: Directory block failed checksum
                                          [Sun Mar 16 11:27:12 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #396068: comm chown: Directory block failed checksum
                                          [Sun Mar 16 11:27:14 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm setfacl: Directory block failed checksum
                                          [Sun Mar 16 11:27:14 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407143: comm setfacl: Directory block failed checksum
                                          [Sun Mar 16 11:27:14 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #395908: comm setfacl: Directory block failed checksum
                                          [Sun Mar 16 11:27:14 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386735: comm setfacl: Directory block failed checksum
                                          [Sun Mar 16 11:27:14 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407148: comm setfacl: Directory block failed checksum
                                          [Sun Mar 16 11:27:14 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #395917: comm setfacl: Directory block failed checksum
                                          [Sun Mar 16 11:27:14 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #509363: comm setfacl: Directory block failed checksum
                                          [Sun Mar 16 11:27:14 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #509361: comm setfacl: Directory block failed checksum
                                          [Sun Mar 16 11:27:14 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #395904: comm setfacl: Directory block failed checksum
                                          [Sun Mar 16 11:27:15 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407153: comm setfacl: Directory block failed checksum
                                          [Sun Mar 16 11:27:19 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm npm: Directory block failed checksum
                                          [Sun Mar 16 11:27:19 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386735: comm npm: Directory block failed checksum
                                          [Sun Mar 16 11:29:53 2025] EXT4-fs error (device mmcblk0p2): ext4_lookup:1858: inode #63889: comm dpkg: iget: bad extra_isize 59606 (inode size 256)
                                          [Sun Mar 16 11:30:36 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm npm: Directory block failed checksum
                                          [Sun Mar 16 11:30:36 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386735: comm npm: Directory block failed checksum
                                          [Sun Mar 16 11:30:37 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386733: comm npm: checksumming directory block 0
                                          [Sun Mar 16 11:30:37 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386735: comm npm: checksumming directory block 0
                                          [Sun Mar 16 11:36:20 2025] EXT4-fs error (device mmcblk0p2): ext4_lookup:1858: inode #63889: comm dpkg: iget: bad extra_isize 59606 (inode size 256)
                                          [Sun Mar 16 11:41:29 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                          [Sun Mar 16 11:53:14 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                          [Sun Mar 16 11:58:20 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm npm: Directory block failed checksum
                                          [Sun Mar 16 11:58:20 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386735: comm npm: Directory block failed checksum
                                          [Sun Mar 16 11:58:20 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386733: comm npm: checksumming directory block 0
                                          [Sun Mar 16 11:58:20 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386735: comm npm: checksumming directory block 0
                                          [Sun Mar 16 11:59:32 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm npm: Directory block failed checksum
                                          [Sun Mar 16 11:59:32 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386735: comm npm: Directory block failed checksum
                                          [Sun Mar 16 11:59:33 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386733: comm npm: checksumming directory block 0
                                          [Sun Mar 16 11:59:33 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386735: comm npm: checksumming directory block 0
                                          [Sun Mar 16 12:00:42 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                          [Sun Mar 16 12:00:57 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                          [Sun Mar 16 12:01:33 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm npm: Directory block failed checksum
                                          [Sun Mar 16 12:01:33 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386735: comm npm: Directory block failed checksum
                                          [Sun Mar 16 12:01:34 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386733: comm npm: checksumming directory block 0
                                          [Sun Mar 16 12:01:35 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386733: comm npm: checksumming directory block 0
                                          [Sun Mar 16 12:02:23 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                          [Sun Mar 16 12:02:46 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm npm: Directory block failed checksum
                                          [Sun Mar 16 12:02:46 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386735: comm npm: Directory block failed checksum
                                          [Sun Mar 16 12:02:48 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386733: comm npm: checksumming directory block 0
                                          [Sun Mar 16 12:02:48 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386735: comm npm: checksumming directory block 0
                                          [Tue Mar 18 18:02:22 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                          [Tue Mar 18 18:04:43 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                          [Tue Mar 18 18:04:58 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                          [Tue Mar 18 18:11:17 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                          [Tue Mar 18 18:14:45 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                          [Tue Mar 18 18:20:38 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                          [Tue Mar 18 19:02:27 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                          [Tue Mar 18 19:07:25 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                          [Tue Mar 18 19:07:57 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                          [Tue Mar 18 19:08:01 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                          [Tue Mar 18 19:08:08 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                          [Tue Mar 18 19:08:12 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                          [Tue Mar 18 19:08:14 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                          [Tue Mar 18 19:08:37 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm npm: Directory block failed checksum
                                          [Tue Mar 18 19:08:37 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386735: comm npm: Directory block failed checksum
                                          [Tue Mar 18 19:08:38 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386733: comm npm: checksumming directory block 0
                                          [Tue Mar 18 19:08:38 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386735: comm npm: checksumming directory block 0
                                          [Tue Mar 18 19:09:03 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                          [Tue Mar 18 19:09:48 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                          [Tue Mar 18 19:22:40 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                          [Tue Mar 18 19:49:23 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                          [Tue Mar 18 21:05:07 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                          [Tue Mar 18 21:06:04 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                          [Tue Mar 18 21:06:14 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm npm: Directory block failed checksum
                                          [Tue Mar 18 21:06:14 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386735: comm npm: Directory block failed checksum
                                          [Tue Mar 18 21:06:15 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386733: comm npm: checksumming directory block 0
                                          [Tue Mar 18 21:06:15 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386735: comm npm: checksumming directory block 0
                                          [Tue Mar 18 21:06:52 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm npm: Directory block failed checksum
                                          [Tue Mar 18 21:06:52 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386735: comm npm: Directory block failed checksum
                                          [Tue Mar 18 21:06:54 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386733: comm npm: checksumming directory block 0
                                          [Tue Mar 18 21:06:54 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386735: comm npm: checksumming directory block 0
                                          [Wed Mar 19 12:14:27 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                          [Wed Mar 19 12:22:13 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                          [Wed Mar 19 12:25:01 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                          [Wed Mar 19 12:27:54 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                          [Wed Mar 19 16:18:32 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                          [Wed Mar 19 16:19:55 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                          [Wed Mar 19 17:19:58 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                          [Wed Mar 19 17:20:03 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                          [Wed Mar 19 18:08:36 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                          [Fri Mar 21 18:25:54 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                          [Fri Mar 21 18:26:59 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                          [Fri Mar 21 18:31:58 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                          [Fri Mar 21 18:32:49 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                          [Sun Mar 23 12:57:36 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                          [Sun Mar 23 12:58:59 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                          [Sun Mar 23 13:00:44 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #407148: comm iobroker.js-con: checksumming directory block 0
                                          [Sun Mar 23 13:02:44 2025] EXT4-fs error (device mmcblk0p2): ext4_lookup:1858: inode #63889: comm dpkg: iget: bad extra_isize 59606 (inode size 256)
                                          [Sun Mar 23 13:11:29 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm npm: Directory block failed checksum
                                          [Sun Mar 23 13:11:29 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386735: comm npm: Directory block failed checksum
                                          [Sun Mar 23 13:11:30 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386733: comm npm: checksumming directory block 0
                                          [Sun Mar 23 13:11:30 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386735: comm npm: checksumming directory block 0
                                          [Sun Mar 23 13:18:44 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #395917: comm chown: Directory block failed checksum
                                          [Sun Mar 23 13:18:45 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #509363: comm chown: Directory block failed checksum
                                          [Sun Mar 23 13:18:45 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #509361: comm chown: Directory block failed checksum
                                          [Sun Mar 23 13:18:46 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #525089: comm chown: Directory block failed checksum
                                          [Sun Mar 23 13:18:46 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #395904: comm chown: Directory block failed checksum
                                          [Sun Mar 23 13:18:46 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407153: comm chown: Directory block failed checksum
                                          [Sun Mar 23 13:18:46 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407159: comm chown: Directory block failed checksum
                                          [Sun Mar 23 13:18:47 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #396063: comm chown: Directory block failed checksum
                                          [Sun Mar 23 13:18:48 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm chown: Directory block failed checksum
                                          [Sun Mar 23 13:18:48 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407143: comm chown: Directory block failed checksum
                                          [Sun Mar 23 13:18:50 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #395917: comm chown: Directory block failed checksum
                                          [Sun Mar 23 13:18:50 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #509363: comm chown: Directory block failed checksum
                                          [Sun Mar 23 13:18:50 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #509361: comm chown: Directory block failed checksum
                                          [Sun Mar 23 13:18:51 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #525089: comm chown: Directory block failed checksum
                                          [Sun Mar 23 13:18:51 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #395904: comm chown: Directory block failed checksum
                                          [Sun Mar 23 13:18:51 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407153: comm chown: Directory block failed checksum
                                          [Sun Mar 23 13:18:51 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407159: comm chown: Directory block failed checksum
                                          [Sun Mar 23 13:18:53 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #396063: comm chown: Directory block failed checksum
                                          [Sun Mar 23 13:18:54 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm chown: Directory block failed checksum
                                          [Sun Mar 23 13:18:54 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407143: comm chown: Directory block failed checksum
                                          [Sun Mar 23 13:18:56 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407145: comm chown: Directory block failed checksum
                                          [Sun Mar 23 13:18:56 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #396073: comm chown: Directory block failed checksum
                                          [Sun Mar 23 13:18:56 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #525085: comm chown: Directory block failed checksum
                                          [Sun Mar 23 13:18:56 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #525070: comm chown: Directory block failed checksum
                                          [Sun Mar 23 13:18:57 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #396081: comm chown: Directory block failed checksum
                                          [Sun Mar 23 13:18:57 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #396057: comm chown: Directory block failed checksum
                                          [Sun Mar 23 13:18:57 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #525082: comm chown: Directory block failed checksum
                                          [Sun Mar 23 13:18:57 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #396068: comm chown: Directory block failed checksum
                                          [Sun Mar 23 13:18:57 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407146: comm chown: Directory block failed checksum
                                          [Sun Mar 23 13:18:57 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #395906: comm chown: Directory block failed checksum
                                          [Sun Mar 23 13:19:03 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm npm: Directory block failed checksum
                                          [Sun Mar 23 13:19:03 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386735: comm npm: Directory block failed checksum
                                          [Sun Mar 23 13:20:59 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #395917: comm find: Directory block failed checksum
                                          [Sun Mar 23 13:20:59 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #509363: comm find: Directory block failed checksum
                                          [Sun Mar 23 13:20:59 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #509361: comm find: Directory block failed checksum
                                          [Sun Mar 23 13:20:59 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #525089: comm find: Directory block failed checksum
                                          [Sun Mar 23 13:20:59 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #395904: comm find: Directory block failed checksum
                                          [Sun Mar 23 13:20:59 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407153: comm find: Directory block failed checksum
                                          [Sun Mar 23 13:20:59 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407159: comm find: Directory block failed checksum
                                          [Sun Mar 23 13:20:59 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #396063: comm find: Directory block failed checksum
                                          [Sun Mar 23 13:20:59 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm find: Directory block failed checksum
                                          [Sun Mar 23 13:20:59 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407143: comm find: Directory block failed checksum
                                          [Sun Mar 23 13:22:53 2025] EXT4-fs error (device mmcblk0p2): ext4_lookup:1858: inode #63889: comm dpkg: iget: bad extra_isize 59606 (inode size 256)
                                          [Sun Mar 23 13:24:50 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm npm: Directory block failed checksum
                                          [Sun Mar 23 13:24:50 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386735: comm npm: Directory block failed checksum
                                          [Sun Mar 23 13:24:51 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386733: comm npm: checksumming directory block 0
                                          [Sun Mar 23 13:24:51 2025] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1694: inode #386735: comm npm: checksumming directory block 0
                                          [Sun Mar 23 13:28:15 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386733: comm npm: Directory block failed checksum
                                          [Sun Mar 23 13:28:15 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #386735: comm npm: Directory block failed checksum
                                          [Sun Mar 23 13:28:25 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407148: comm du: Directory block failed checksum
                                          [Sun Mar 23 13:28:25 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407148: comm find: Directory block failed checksum
                                          [Sun Mar 23 13:28:28 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #395917: comm find: Directory block failed checksum
                                          [Sun Mar 23 13:28:28 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #509363: comm find: Directory block failed checksum
                                          [Sun Mar 23 13:28:28 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #509361: comm find: Directory block failed checksum
                                          [Sun Mar 23 13:28:28 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #525089: comm find: Directory block failed checksum
                                          [Sun Mar 23 13:28:28 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #395904: comm find: Directory block failed checksum
                                          [Sun Mar 23 13:28:28 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407153: comm find: Directory block failed checksum
                                          [Sun Mar 23 13:28:28 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #407159: comm find: Directory block failed checksum
                                          [Sun Mar 23 13:28:28 2025] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1083: inode #396063: comm find: Directory block failed checksum
                                            @hannosch
                                            Dein Dateisystem hat 'nen Schuss. Und deswegen kann bei der Installation auch das Verzeichnis nicht angelegt werden.
                                            2328
