    4. [gelöst] "Gestylt" "Aus Liste ausw...": Textfarbe unwirksam
    • I
      iobroker2001 last edited by iobroker2001
      Guten Tag,
      nach der Übernahme meiner VIS1-Visualisierung schaffe ich es nicht, in VIS2 beim Widgettyp
      "Gestylt" -> "Aus Liste auswählen" die Textfarbe von schwarz auf irgendeine andere Farbe zu ändern.
      Die Farbe habe ich unter "CSS Font & Text" -> "Farbe" versucht einzustellen, vergeblich.
      Auf dunkelblauem Hintergrund kann man deshalb nichts erkennen:
      Falls dieser Widgettyp nicht mehr unterstützt wird, welches andere könnte ich verwenden?
      Vielen Dank!
          "tpl": "tplJquiSelectList",
          "data": {
            "oid": "hm-rpc.0.MEQ0089257.2.SET_TEMPERATURE",
            "g_css_font_text": true,
            "g_css_background": true,
            "g_css_shadow_padding": false,
            "g_css_border": false,
            "g_gestures": false,
            "height": "240",
            "signals-cond-1": "==",
            "signals-val-1": true,
            "signals-icon-1": "/vis/signals/lowbattery.png",
            "signals-icon-size-1": 0,
            "signals-blink-1": false,
            "signals-horz-1": 0,
            "signals-vert-1": 0,
            "signals-hide-edit-1": false,
            "signals-cond-2": "==",
            "signals-val-2": true,
            "signals-icon-2": "/vis/signals/lowbattery.png",
            "signals-icon-size-2": 0,
            "signals-blink-2": false,
            "signals-horz-2": 0,
            "signals-vert-2": 0,
            "signals-hide-edit-2": false,
            "bindings": [],
            "count": 14,
            "value1": "4.0",
            "text1": "off",
            "g_states-1": true,
            "value2": "4.5",
            "text2": "4.5",
            "g_states-2": true,
            "value3": "12",
            "text3": "12",
            "g_states-3": true,
            "value4": "18",
            "text4": "18",
            "g_states-4": true,
            "value5": "18.5",
            "text5": "18.5",
            "g_states-5": true,
            "value6": "19",
            "text6": "19",
            "g_states-6": true,
            "value7": "19.5",
            "text7": "19.5",
            "g_states-7": true,
            "value8": "20",
            "text8": "20",
            "g_states-8": true,
            "value9": "20.5",
            "text9": "20.5",
            "g_states-9": true,
            "value10": "21",
            "text10": "21",
            "g_states-10": true,
            "value11": "21.5",
            "text11": "21.5",
            "g_states-11": true,
            "value12": "22",
            "text12": "22",
            "g_states-12": true,
            "value13": "30",
            "text13": "30",
            "g_states-13": true,
            "value14": "30.5",
            "text14": "on",
            "g_states-14": true,
            "type": "select"
          "style": {
            "left": 181,
            "top": 114,
            "width": "60px",
            "height": "20px",
            "z-index": "20",
            "bindings": [],
            "background-color": "",
            "color": "rgba(255,255,255,1)"
          "widgetSet": "jqui",
          "_id": "i000001"
      I sigi234 2 Replies Last reply Reply Quote 0
      • I
        iobroker2001 @iobroker2001 last edited by
        @iobroker2001 Nachtrag:
        Auch eine Neuanlage dieses Widgets bringt keine Änderung.
        Könnte jemand bitte bestätigen, dass dieses Widget insofern funktioniert, als dass man die Textfarbe einstellen kann?
        Andernfalls Alternativen?
        Danke!
        • sigi234
          sigi234 Forum Testing Most Active @iobroker2001 last edited by
          @iobroker2001
          nimm das Widget:
          Gestylt
          Zustände steuern
          I 1 Reply Last reply Reply Quote 1
          • I
            iobroker2001 @sigi234 last edited by
            @sigi234 Danke!
              ToK last edited by ToK
              @iobroker2001 @sigi234 Habe genau das idente Problem - der selektierte Text ist auf dem schwarzen Hintergrund nicht lesbar. Die Schriftfarbe lässt sich hierfür nicht verändern - auch nicht im Gestylt - Zustände steuern. ??
              Vis2 V2.11.2
              Gibt´s hierzu eine Lösung?
              • sigi234
                sigi234 Forum Testing Most Active @ToK last edited by sigi234
                @tok sagte in [gelöst] "Gestylt" "Aus Liste ausw...": Textfarbe unwirksam:
                Vis2 V2.11.2
                Farben sind erst in der Runtime sichtbar
                  @sigi234 Danke, das ist die Lösung!
                  Eine Frage hab ich noch: in der Liste (dropdown) möchte ich für das aktive Element nicht die Schriftfarbe sondern die Hintergrundfarbe der jeweiligen Zeile ändern.
                  Ist dies über CSS möglich .. und wenn ja wie ?
                  Zusatz:
                  Konnte ich mir selbst beantworten 🙂
                  .css-18e6bv3.Mui-selected {
                      background-color: #4384D0;
