    4. Installation
    5. IOBroker startet nicht mehr nach Updates
      thomke67 last edited by thomke67
      ich habe einige Updates durchgeführt. Nach dem letzten Update/Upgrade startet IOBroker nicht mehr.
      Hier die Statusmeldung an der Konsole
      pi@raspberrypi:~ $ iobroker status
      (node:1900) UnhandledPromiseRejectionWarning: Error [ERR_UNKNOWN_BUILTIN_MODULE]: No such built-in module: node:timers/promises
          at new NodeError (internal/errors.js:322:7)
          at Loader.builtinStrategy (internal/modules/esm/translators.js:289:11)
          at new ModuleJob (internal/modules/esm/module_job.js:63:26)
          at Loader.getModuleJob (internal/modules/esm/loader.js:258:11)
          at async ModuleWrap.<anonymous> (internal/modules/esm/module_job.js:78:21)
          at async Promise.all (index 2)
          at async link (internal/modules/esm/module_job.js:83:9)
      (Use `node --trace-warnings ...` to show where the warning was created)
      (node:1900) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 2)
      (node:1900) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
      pi@raspberrypi:~ $
      Kann mir jemand helfen?
      • Samson71
        Samson71 Global Moderator @thomke67 last edited by
        @thomke67
        Mangels näherer Beschreibung wie immer, ggf. mehr mit einem (vollständigen)
        iob diag
        in Code-Tags </>
          thomke67 @Samson71 last edited by
          @samson71
          Schon mal Danke, dass du Hilfe anbietest.
          Hier das Resultat aus iob diag
          Copy text starting here:
          ```bash
                                  v.2024-08-12
             Static hostname: raspberrypi
                   Icon name: computer
            Operating System: Raspbian GNU/Linux 10 (buster)
                      Kernel: Linux 5.10.103-v7l+
                Architecture: arm
          Kernel:                 armv7l
          Userland:               32 bit
          User-ID:                1000
          Display-Server:         true
          Pending OS-Updates:     0
          (node:3171) UnhandledPromiseRejectionWarning: Error [ERR_UNKNOWN_BUILTIN_MODULE]: No such built-in module: node:timers/promises
          (node:3171) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 2)
          (node:3171) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
          Pending iob updates:    0
          Nodejs-Installation:
          /usr/bin/nodejs         v14.21.3
          /usr/bin/node           v14.21.3
          /usr/bin/npm            6.14.18
          /usr/bin/npx            6.14.18
          /usr/bin/corepack       0.15.1
          MEMORY:
          Mem:           3.8G        239M        3.0G         24M        633M        3.4G
          Swap:           99M          0B         99M
          Total:         3.9G        239M        3.1G
          Active iob-Instances:   0
          (node:3238) UnhandledPromiseRejectionWarning: Error [ERR_UNKNOWN_BUILTIN_MODULE]: No such built-in module: node:timers/promises
          (node:3238) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 2)
          (node:3238) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
          (node:3252) UnhandledPromiseRejectionWarning: Error [ERR_UNKNOWN_BUILTIN_MODULE]: No such built-in module: node:timers/promises
          (node:3252) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 2)
          (node:3252) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
          ioBroker Core:          js-controller
          (node:3267) UnhandledPromiseRejectionWarning: Error [ERR_UNKNOWN_BUILTIN_MODULE]: No such built-in module: node:timers/promises
          (node:3267) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 2)
          (node:3267) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
                                  admin
          (node:3281) UnhandledPromiseRejectionWarning: Error [ERR_UNKNOWN_BUILTIN_MODULE]: No such built-in module: node:timers/promises
          (node:3281) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 2)
          (node:3281) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
          ioBroker Status:
          Objects:                0
          States:                 0
          Size of iob-Database:
          19M     /opt/iobroker/iobroker-data/objects.jsonl
          11M     /opt/iobroker/iobroker-data/objects.json.migrated
          11M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
          14M     /opt/iobroker/iobroker-data/states.jsonl
          1.2M    /opt/iobroker/iobroker-data/states.json.migrated
          1.2M    /opt/iobroker/iobroker-data/states.json.bak.migrated
          0       /opt/iobroker/iobroker-data/states.json.broken
          • Samson71
            Samson71 Global Moderator @thomke67 last edited by Samson71
            @thomke67
            Neben der Tatsache, dass ein "Summary" nicht die Langfassung ist, kann man das Problem aber schon sehen. Debian 10 (Buster) ist lange tot. Sofern Du versucht hast auf Nodejs 20 upzudaten ist klar, dass es klemmt. Das läuft nicht mehr mit Buster.
            Downgrade auf Nodejs 18, Rest soweit wie möglich aktuell, Backup machen und das in eine frische ioBroker-Installation in einem neu installierten Debian 12 (64bit ohne Desktop) einspielen. Ein direktes Update von Debian 10 auf 12 funktioniert nicht!
            EDIT
            Sehe gerade, dass Du noch Uralt unterwegs bist mit Nodejs14. Minimum für die meisten Adapter ist mittlerweile 18. Hatte zuerst nach der Anzeige mit Buster nicht weitergelesen. Ich vermute daher, dass da auch jede Menge Systemupdates fehlen.
            Um das bis auf Maximum hochzuziehen bin ich auch nicht fit genug. Da muss unser @Thomas-Braun besser mal mit draufgucken.
              thomke67 @Samson71 last edited by thomke67
              @samson71 Vielen Dank
              @Thomas-Braun Was ist jetzt genau zu tun? Bin nicht so im Linux unterwegs. Ich habe immer mal wieder Updates über die Konsole gemacht. Das ich jetzt so weit hinten liegen soll, ist mir gar nicht aufgefallen.
              • Codierknecht
                Codierknecht Developer Most Active @thomke67 last edited by
                @thomke67 sagte in IOBroker startet nicht mehr nach Updates:
                https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                  thomke67 @Codierknecht last edited by thomke67
                  @codierknecht Wird dabei die alte Version überschrieben, oder muss ich die manuell löschen?
                  Zudem ist bei mir die Installation auf einer SSD. Das habe ich vor langer Zeit mal gemacht und jetzt weiß ich nicht mehr, wie ich damals vorgegangen bin. War bestimmt eine Schritt für Schritt Anleitung.
                  Samson71 T 2 Replies Last reply Reply Quote 0
                  • Samson71
                    @thomke67
                    Wenn Du das direkt auf der alten Karte machst ist alles futsch. Ich würde eine neue SD-Karte nehmen. Dann bleibt die alte zur Sicherheit erhalten. Die Neuinstallation ist ja nur die eine Seite. Die Aktualisierung und das Backup vom Altsystem die andere Seite.
                      @samson71 Da steckt keine Karte mehr drin.
                      Samson71 Thomas Braun 3 Replies Last reply Reply Quote 0
                      • Samson71
                        @thomke67
                        Auf jeden Fall ist das Altsystem futsch, wenn Du da direkt ein neues Bookworm draufklatscht. Deswegen mein Hinweis auf einen alternativen Datenträger oder was auch immer und Aktualisierung des Altsystems soweit wie möglich und davon dann ein Backup.
                          Thomas Braun Most Active @thomke67 last edited by
                          @thomke67
                          iob nodejs-update 18
                          Dann damit den ioBroker auf den aktuellen Stand bringen (und zwar vollständig, inkl. js-controller).
                          Davon dann ein Backup ziehen und damit auf ein frisch von Grundauf neuinstalliertes Betriebssystem umziehen.
                          Hattest du nodejs@20 per
                          iob nodejs-update
                          vorgenommen? Denn eigentlich sollte das nicht möglich sein.
                          Muss ich dann nochmal in den Code schauen, warum das nicht erkannt wurde.
                            Thomas Braun Most Active @thomke67 last edited by Thomas Braun
                            @thomke67
                            Kannst du mir mal aus dem jetzigen System die Ausgabe von
                            cat /etc/debian_version
                            mitteilen?
                              thomke67 @Thomas Braun last edited by
                              Ich habe node.js Version 18 installiert und das System ist wieder da. Vielen Dank!!!!!!
                              Es war aber wohl auf Version 14, oder?
                              ioBroker nodejs fixer 2024-06-20
                              You requested to install latest version from nodejs v18 tree.
                              Your current setup is:
                              We found these nodejs versions available for installation:
                              nodejs:
                                Installed: 14.21.3-deb-1nodesource1
                                Candidate: 14.21.3-deb-1nodesource1
                                Version table:
                               *** 14.21.3-deb-1nodesource1 1001
                                      500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
                                      100 /var/lib/dpkg/status
                                   10.24.0~dfsg-1~deb10u3 500
                              Nothing to do - Your installation is using the correct paths.
                              You are running nodejs v14.21.3. Do you want to install latest version from nodejs v.18 tree?
                              Press <y> to continue or any other key to quit
                              Trying to fix your installation now. Please be patient.
                              rm: cannot remove '/etc/apt/keyrings/nodesource.gpg'$'\n''/usr/share/keyrings/nodesource.gpg 2> /dev/null': No such file or directory
                              Waiting for ioBroker to shut down - Give me a minute...
                              Removing dfsg-nodejs
                              *** These repos are active on your system:
                              Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                              Hit:2 https://apt.pivccu.de/piVCCU stable InRelease
                              Hit:3 http://archive.raspberrypi.org/debian buster InRelease
                              Reading package lists... Done
                              *** Installing ca-certificates, curl and gnupg, just in case they are missing.
                              *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
                              deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
                              Package: nodejs
                              Pin: origin deb.nodesource.com
                              Pin-Priority: 1001
                              *** These repos are active after the adjustments:
                              Hit:1 http://archive.raspberrypi.org/debian buster InRelease
                              Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                              Hit:3 https://apt.pivccu.de/piVCCU stable InRelease
                              Get:4 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
                              Get:5 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages [10.2 kB]
                              Fetched 22.4 kB in 1s (21.2 kB/s)
                              Installing nodejs now!
                              Exact recommended version unknown, installing a fallback!
                              (Reading database ... 129820 files and directories currently installed.)
                              Preparing to unpack .../nodejs_18.0.0-1nodesource1_armhf.deb ...
                              Detected old npm client, removing...
                              Unpacking nodejs (18.0.0-1nodesource1) over (14.21.3-deb-1nodesource1) ...
                              Setting up nodejs (18.0.0-1nodesource1) ...
                              Processing triggers for man-db (2.8.5-2+deb10u1) ...
                              Updating fallback to latest nodejs v18 release
                              (Reading database ... 130626 files and directories currently installed.)
                              Preparing to unpack .../nodejs_18.20.4-1nodesource1_armhf.deb ...
                              Unpacking nodejs (18.20.4-1nodesource1) over (18.0.0-1nodesource1) ...
                              Setting up nodejs (18.20.4-1nodesource1) ...
                              v18.20.4 has been installed! You are using the latest version now!
                              Installing the nodejs!
                              We tried our best to fix your nodejs. Please run iob diag again to verify.
                              *** RESTARTING ioBroker NOW! ***
                               Please refresh or restart your browser in a few moments.
                              pi@raspberrypi:~ $
                                @thomas-braun Debian Version 10.13
                                  @thomke67
                                  Bitte vollständige Ein- wie Ausgaben in CodeTags zeigen. Also genauso wie es dann auch auf deinem Bildschirm ausgespuckt wird.
                                    @thomas-braun Hier die Ausgabe:
                                    pi@raspberrypi:~ $ cat /etc/debian_version
                                    10.13
                                    pi@raspberrypi:~ $
                                      @thomke67
                                      Jetzt siehst du auch warum ich da so genau nachfrage...
                                      Debian Version 10.13 ist nicht gleich 10.13
                                      Ich muss die Abfrage in nodejs-update dann entsprehend ergänzen.
                                        @thomas-braun Ok!
                                        Und wie komme ich jetzt für mich am Einfachsten von Debian Buster auf die aktuellste Version?
                                        Codierknecht Thomas Braun 2 Replies Last reply Reply Quote 0
                                        • Codierknecht
                                          wurde doch schon mehrfach geschrieben:
                                            thomke67 @thomke67 last edited by
                                            @codierknecht Es wurde genau einmal geschrieben und da waren meine Fragen:
                                            Backitup hat bei mir die Backups auf einen NAS geschrieben. Die stehen mir also jetzt unabhängig von der SSD zur Verfügung.
                                            Ich weiß aber echt nicht mehr, wie ich von der SD Karte auf die SSD umgezogen bin. Das System lief jetzt einige Jahre super stabil! Und wenn ich mich nicht ganz täusche, dann habe ich die Version des Debians schon mal von einer alten Version auf Buster hochgezogen. Ich habe nämlich irgendwo noch in einem Script einen String durch "buster" ersetzt und dann ging es.
                                            Aber das ist alles schon sehr lange her.....
                                            Thomas Braun crunchip 2 Replies Last reply Reply Quote 0
                                            2690
