    4. [gelöst] Zigbee Blackout
      Rushmed Most Active last edited by Rushmed
      seit drei Tagen baut mien Zigbee Netzwerk welches vorher solide lief massiv ab. Aktuell funktioniert quasi nichts mehr.
      Im LOG bekomme ich Folgende Meldungen:
      zigbee.0
      2024-10-11 23:41:47.616	info	List of port: [{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"b875aef9f419ec118e7074e5f01c6278","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_b875aef9f419ec118e7074e5f01c6278-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyUSB1","manufacturer":"Silicon Labs","serialNumber":"0063","pnpId":"usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0063-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyUSB2","manufacturer":"Silicon Labs","serialNumber":"0052","pnpId":"usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0052-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyS0"},{"path":"/dev/ttyAMA0"}]
      zigbee.0
      2024-10-11 23:40:05.547	error	Error 225 on send command to 0x000b57fffe349293. Error: Error: ZCL command 0x000b57fffe349293/1 genOnOff.on({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'MAC channel access failure' (225)) at ZStackAdapter.sendZclFrameToEndpointInternal (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:411:23) at Queue.execute (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:35:20) at Request.send (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/helpers/request.ts:79:20) at Endpoint.zclCommand (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:756:28) at Endpoint.command (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:587:24) at Object.convertSet (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/converters/toZigbee.ts:48:17) at Object.convertSet (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/converters/toZigbee.ts:1131:32) at /opt/iobroker/node_modules/iobroker.zigbee/main.js:754:36
      zigbee.0
      2024-10-11 23:39:56.823	error	Error 225 on send command to 0x000b57fffe349293. Error: Error: ZCL command 0x000b57fffe349293/1 genOnOff.on({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'MAC channel access failure' (225)) at ZStackAdapter.sendZclFrameToEndpointInternal (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:411:23) at Queue.execute (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:35:20) at Request.send (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/helpers/request.ts:79:20) at Endpoint.zclCommand (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:756:28) at Endpoint.command (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:587:24) at Object.convertSet (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/converters/toZigbee.ts:48:17) at Object.convertSet (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/converters/toZigbee.ts:1131:32) at /opt/iobroker/node_modules/iobroker.zigbee/main.js:754:36
      zigbee.0
      2024-10-11 23:39:47.653	error	Error 225 on send command to 0x000b57fffe349293. Error: Error: ZCL command 0x000b57fffe349293/1 genLevelCtrl.moveToLevelWithOnOff({"level":2,"transtime":0}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'MAC channel access failure' (225)) at ZStackAdapter.sendZclFrameToEndpointInternal (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:411:23) at Queue.execute (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:35:20) at Request.send (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/helpers/request.ts:79:20) at Endpoint.zclCommand (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:756:28) at Endpoint.command (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:587:24) at Object.convertSet (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/converters/toZigbee.ts:1152:13) at /opt/iobroker/node_modules/iobroker.zigbee/main.js:754:36
      zigbee.0
      2024-10-11 23:39:33.887	error	Error 225 on send command to 0x00178801099f4997. Error: Error: ZCL command 0x00178801099f4997/11 genLevelCtrl.moveToLevelWithOnOff({"level":223,"transtime":0}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'MAC channel access failure' (225)) at ZStackAdapter.sendZclFrameToEndpointInternal (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:411:23) at Queue.execute (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:35:20) at Request.send (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/helpers/request.ts:79:20) at Endpoint.zclCommand (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:756:28) at Endpoint.command (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:587:24) at Object.convertSet (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/converters/toZigbee.ts:1152:13) at /opt/iobroker/node_modules/iobroker.zigbee/main.js:754:36
      zigbee.0
      2024-10-11 23:39:25.229	error	Error 225 on send command to 0x00178801099f4997. Error: Error: ZCL command 0x00178801099f4997/11 genLevelCtrl.moveToLevelWithOnOff({"level":208,"transtime":0}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'MAC channel access failure' (225)) at ZStackAdapter.sendZclFrameToEndpointInternal (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:411:23) at Queue.execute (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:35:20) at Request.send (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/helpers/request.ts:79:20) at Endpoint.zclCommand (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:756:28) at Endpoint.command (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:587:24) at Object.convertSet (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/converters/toZigbee.ts:1152:13) at /opt/iobroker/node_modules/iobroker.zigbee/main.js:754:36
      zigbee.0
      2024-10-11 23:39:16.086	error	Error 225 on send command to 0x00178801099f4997. Error: Error: ZCL command 0x00178801099f4997/11 genLevelCtrl.moveToLevelWithOnOff({"level":106,"transtime":0}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'MAC channel access failure' (225)) at ZStackAdapter.sendZclFrameToEndpointInternal (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:411:23) at Queue.execute (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:35:20) at Request.send (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/helpers/request.ts:79:20) at Endpoint.zclCommand (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:756:28) at Endpoint.command (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:587:24) at Object.convertSet (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/converters/toZigbee.ts:1152:13) at /opt/iobroker/node_modules/iobroker.zigbee/main.js:754:36
      zigbee.0
      2024-10-11 23:39:06.703	error	Error 225 on send command to 0x00178801099f4997. Error: Error: ZCL command 0x00178801099f4997/11 genLevelCtrl.moveToLevelWithOnOff({"level":63,"transtime":0}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'MAC channel access failure' (225)) at ZStackAdapter.sendZclFrameToEndpointInternal (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:411:23) at Queue.execute (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:35:20) at Request.send (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/helpers/request.ts:79:20) at Endpoint.zclCommand (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:756:28) at Endpoint.command (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:587:24) at Object.convertSet (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/converters/toZigbee.ts:1152:13) at /opt/iobroker/node_modules/iobroker.zigbee/main.js:754:36
      zigbee.0
      2024-10-11 23:38:24.568	error	Error 225 on send command to 0x00178801099f4997. Error: Error: ZCL command 0x00178801099f4997/11 genOnOff.on({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'MAC channel access failure' (225)) at ZStackAdapter.sendZclFrameToEndpointInternal (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:411:23) at Queue.execute (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:35:20) at Request.send (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/helpers/request.ts:79:20) at Endpoint.zclCommand (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:756:28) at Endpoint.command (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:587:24) at Object.convertSet (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/converters/toZigbee.ts:48:17) at Object.convertSet (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/converters/toZigbee.ts:1131:32) at /opt/iobroker/node_modules/iobroker.zigbee/main.js:754:36
      zigbee.0
      2024-10-11 23:38:15.820	error	Error 225 on send command to 0x00178801099f4997. Error: Error: ZCL command 0x00178801099f4997/11 genOnOff.off({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'MAC channel access failure' (225)) at ZStackAdapter.sendZclFrameToEndpointInternal (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:411:23) at Queue.execute (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:35:20) at Request.send (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/helpers/request.ts:79:20) at Endpoint.zclCommand (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:756:28) at Endpoint.command (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:587:24) at Object.convertSet (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/converters/toZigbee.ts:48:17) at Object.convertSet (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/converters/toZigbee.ts:1131:32) at /opt/iobroker/node_modules/iobroker.zigbee/main.js:754:36
      zigbee.0
      2024-10-11 23:38:08.976	info	Zigbee: stop joining
      zigbee.0
      2024-10-11 23:37:35.535	info	Device '0x00178801099f4997' announced itself
      zigbee.0
      2024-10-11 23:37:07.717	info	Zigbee: allowing new devices to join.
      zigbee.0
      2024-10-11 23:36:49.360	info	List of port: [{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"b875aef9f419ec118e7074e5f01c6278","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_b875aef9f419ec118e7074e5f01c6278-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyUSB1","manufacturer":"Silicon Labs","serialNumber":"0063","pnpId":"usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0063-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyUSB2","manufacturer":"Silicon Labs","serialNumber":"0052","pnpId":"usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0052-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyS0"},{"path":"/dev/ttyAMA0"}]
      zigbee.0
      2024-10-11 23:28:52.732	error	Error 225 on send command to 0x00178801099f4997. Error: Error: ZCL command 0x00178801099f4997/11 genOnOff.on({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'MAC channel access failure' (225)) at ZStackAdapter.sendZclFrameToEndpointInternal (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:411:23) at Queue.execute (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:35:20) at Request.send (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/helpers/request.ts:79:20) at Endpoint.zclCommand (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:756:28) at Endpoint.command (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:587:24) at Object.convertSet (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/converters/toZigbee.ts:48:17) at Object.convertSet (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/converters/toZigbee.ts:1131:32) at /opt/iobroker/node_modules/iobroker.zigbee/main.js:754:36
      zigbee.0
      2024-10-11 23:27:45.063	info	List of port: [{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"b875aef9f419ec118e7074e5f01c6278","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_b875aef9f419ec118e7074e5f01c6278-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyUSB1","manufacturer":"Silicon Labs","serialNumber":"0063","pnpId":"usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0063-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyUSB2","manufacturer":"Silicon Labs","serialNumber":"0052","pnpId":"usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0052-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyS0"},{"path":"/dev/ttyAMA0"}]
      zigbee.0
      2024-10-11 23:25:50.741	info	List of port: [{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"b875aef9f419ec118e7074e5f01c6278","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_b875aef9f419ec118e7074e5f01c6278-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyUSB1","manufacturer":"Silicon Labs","serialNumber":"0063","pnpId":"usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0063-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyUSB2","manufacturer":"Silicon Labs","serialNumber":"0052","pnpId":"usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0052-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyS0"},{"path":"/dev/ttyAMA0"}]
      zigbee.0
      2024-10-11 23:25:14.606	info	Zigbee: stop joining
      LOG vom Adapterstart:
      zigbee.0
      2024-10-11 23:46:40.087	warn	DeviceAvailability:Failed to ping 0x0017880106c1f6e4 LWE002
      zigbee.0
      2024-10-11 23:46:39.870	warn	DeviceAvailability:Failed to ping 0x50325ffffe452f8f TRADFRI Driver 10W
      zigbee.0
      2024-10-11 23:46:35.273	warn	DeviceAvailability:Failed to ping 0x00178801099a727d LWE002
      zigbee.0
      2024-10-11 23:46:35.209	warn	DeviceAvailability:Failed to ping 0x003c84fffeb5efd7 TRADFRIbulbE27WSglobeclear806lm
      zigbee.0
      2024-10-11 23:46:34.518	warn	DeviceAvailability:Failed to ping 0xec1bbdfffed4493f TRADFRI bulb E27 WW 806lm
      zigbee.0
      2024-10-11 23:46:33.862	warn	DeviceAvailability:Failed to ping 0x003c84fffe2e20b6 TRADFRIbulbE27WSglobeclear806lm
      zigbee.0
      2024-10-11 23:46:33.760	warn	DeviceAvailability:Failed to ping 0x001788010bd75cd7 LWA009
      zigbee.0
      2024-10-11 23:46:33.442	warn	DeviceAvailability:Failed to ping 0xec1bbdfffe94bbcb TRADFRI bulb E14 WS opal 600lm
      zigbee.0
      2024-10-11 23:46:32.964	warn	DeviceAvailability:Failed to ping 0x5c0272fffe92177a TRADFRI Driver 30W
      zigbee.0
      2024-10-11 23:46:32.079	warn	DeviceAvailability:Failed to ping 0xb4e3f9fffea666ae TRADFRI Driver 30W
      zigbee.0
      2024-10-11 23:46:25.655	warn	DeviceAvailability:Failed to ping 0x086bd7fffe3ed067 TRADFRI Driver 30W
      zigbee.0
      2024-10-11 23:46:25.611	warn	DeviceAvailability:Failed to ping 0x50325ffffe35f6e1 TRADFRI Driver 10W
      zigbee.0
      2024-10-11 23:46:18.381	warn	DeviceAvailability:Failed to ping 0x001788010c314523 LWA017
      zigbee.0
      2024-10-11 23:46:18.325	warn	DeviceAvailability:Failed to ping 0x5c0272fffe88b629 FLOALT panel WS 60x60
      zigbee.0
      2024-10-11 23:46:18.294	warn	DeviceAvailability:Failed to ping 0xccccccfffedbebdc TRADFRI bulb E27 WW 806lm
      zigbee.0
      2024-10-11 23:46:18.181	warn	DeviceAvailability:Failed to ping 0xec1bbdfffeb19154 TRADFRI bulb E27 WW 806lm
      zigbee.0
      2024-10-11 23:46:18.103	warn	DeviceAvailability:Failed to ping 0x00178801099f4997 LWA009
      zigbee.0
      2024-10-11 23:46:17.993	warn	DeviceAvailability:Failed to ping 0x0017880108ff0d07 LWA009
      zigbee.0
      2024-10-11 23:46:17.812	warn	DeviceAvailability:Failed to ping 0x000b57fffe349293 TRADFRI bulb E27 opal 1000lm
      zigbee.0
      2024-10-11 23:46:17.753	warn	DeviceAvailability:Failed to ping 0xa4c13830a258e9b4 TS011F
      zigbee.0
      2024-10-11 23:46:07.996	info	Method "deleteDevice" is deprecated and will be removed in js-controller 7, use "delObject" instead
      zigbee.0
      2024-10-11 23:46:07.994	info	Method "deleteDevice" is deprecated and will be removed in js-controller 7, use "delObject" instead
      zigbee.0
      2024-10-11 23:46:07.835	info	Method "deleteDevice" is deprecated and will be removed in js-controller 7, use "delObject" instead
      zigbee.0
      2024-10-11 23:46:05.318	info	debug devices set to []
      zigbee.0
      2024-10-11 23:46:05.285	info	deregister device Ping for deactivated device "0xa4c138fa74651615"
      zigbee.0
      2024-10-11 23:46:05.283	info	deregister device Ping for deactivated device "0xa4c1381f329e8ab8"
      zigbee.0
      2024-10-11 23:46:05.282	info	deregister device Ping for deactivated device "0xa4c13844911e10c6"
      zigbee.0
      2024-10-11 23:46:05.282	info	deregister device Ping for deactivated device "0xa4c1380dab82a533"
      zigbee.0
      2024-10-11 23:46:05.263	info	deregister device Ping for deactivated device "0xa4c138ba26206f69"
      zigbee.0
      2024-10-11 23:46:05.262	info	deregister device Ping for deactivated device "0xa4c1389a9a95cc10"
      zigbee.0
      2024-10-11 23:46:05.260	info	deregister device Ping for deactivated device "0x00158d0002f26d49"
      zigbee.0
      2024-10-11 23:46:05.258	info	deregister device Ping for deactivated device "0x00178801090ed414"
      zigbee.0
      2024-10-11 23:46:05.257	info	deregister device Ping for deactivated device "0x00178801090ed9c2"
      zigbee.0
      2024-10-11 23:46:05.256	info	deregister device Ping for deactivated device "0x00178801090c125a"
      zigbee.0
      2024-10-11 23:46:05.249	info	deregister device Ping for deactivated device "0xa4c138c1782d2a29"
      zigbee.0
      2024-10-11 23:46:05.248	info	deregister device Ping for deactivated device "0x00178801090c0c72"
      zigbee.0
      2024-10-11 23:46:05.233	info	deregister device Ping for deactivated device "0xcc86ecfffe1183fc"
      zigbee.0
      2024-10-11 23:46:05.217	info	deregister device Ping for deactivated device "0xa4c138a481b709c3"
      zigbee.0
      2024-10-11 23:46:04.830	info	Zigbee started
      zigbee.0
      2024-10-11 23:46:04.829	info	0x881a14fffef103da (addr 25258): E2202 - IKEA BADRING water leakage sensor (EndDevice)
      zigbee.0
      2024-10-11 23:46:04.827	info	0x881a14fffef0d0e8 (addr 8978): E2202 - IKEA BADRING water leakage sensor (EndDevice)
      zigbee.0
      2024-10-11 23:46:04.826	info	0x881a14fffef0f450 (addr 3529): E2202 - IKEA BADRING water leakage sensor (EndDevice)
      zigbee.0
      2024-10-11 23:46:04.824	info	0x086bd7fffe3ed067 (addr 29080): ICPSHC24-30EU-IL-1/ICPSHC24-10EU-IL-2 - IKEA TRADFRI LED driver, 30 w (Router)
      zigbee.0
      2024-10-11 23:46:04.822	info	0x00158d000aca4051 (addr 27563): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
      zigbee.0
      2024-10-11 23:46:04.820	info	0xa4c138fa74651615 (addr 26739): A1Z - Nous Smart plug (with power monitoring) (Router)
      zigbee.0
      2024-10-11 23:46:04.818	info	0xa4c1381f329e8ab8 (addr 29515): A1Z - Nous Smart plug (with power monitoring) (Router)
      zigbee.0
      2024-10-11 23:46:04.816	info	0xa4c13844911e10c6 (addr 49722): A1Z - Nous Smart plug (with power monitoring) (Router)
      zigbee.0
      2024-10-11 23:46:04.813	info	0xa4c1380dab82a533 (addr 25470): HG08673 - Lidl Silvercrest smart plug with power monitoring (EU, FR) (Router)
      zigbee.0
      2024-10-11 23:46:04.811	info	0xa4c138ba26206f69 (addr 34894): HG08673 - Lidl Silvercrest smart plug with power monitoring (EU, FR) (Router)
      zigbee.0
      2024-10-11 23:46:04.809	info	0xa4c1389a9a95cc10 (addr 14994): HG08673 - Lidl Silvercrest smart plug with power monitoring (EU, FR) (Router)
      zigbee.0
      2024-10-11 23:46:04.806	info	0x00158d0008d07e4c (addr 47919): RTCGQ11LM - Aqara Motion sensor (EndDevice)
      zigbee.0
      2024-10-11 23:46:04.805	info	0x50325ffffe35f6e1 (addr 11713): ICPSHC24-10EU-IL-1/ICPSHC24-10EU-IL-2 - IKEA TRADFRI LED driver, 10 w (Router)
      zigbee.0
      2024-10-11 23:46:04.803	info	0x00158d0002f26d49 (addr 32660): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
      zigbee.0
      2024-10-11 23:46:04.801	info	0x50325ffffe452f8f (addr 15995): ICPSHC24-10EU-IL-1/ICPSHC24-10EU-IL-2 - IKEA TRADFRI LED driver, 10 w (Router)
      zigbee.0
      2024-10-11 23:46:04.800	info	0x0017880106c1f6e4 (addr 54856): 9290020399 - Philips Hue white E14 (Router)
      zigbee.0
      2024-10-11 23:46:04.799	info	0x00178801090ed414 (addr 51894): 9290022944 - Philips Hue white ambiance E14 (with Bluetooth) (Router)
      zigbee.0
      2024-10-11 23:46:04.797	info	0x00178801090ed9c2 (addr 58928): 9290022944 - Philips Hue white ambiance E14 (with Bluetooth) (Router)
      zigbee.0
      2024-10-11 23:46:04.795	info	0x00178801090c125a (addr 52884): 9290022944 - Philips Hue white ambiance E14 (with Bluetooth) (Router)
      zigbee.0
      2024-10-11 23:46:04.791	info	0x00158d0008d07e48 (addr 11592): RTCGQ11LM - Aqara Motion sensor (EndDevice)
      zigbee.0
      2024-10-11 23:46:04.789	info	0x00158d000838096f (addr 63520): RTCGQ11LM - Aqara Motion sensor (EndDevice)
      zigbee.0
      2024-10-11 23:46:04.788	info	0x54ef44100042afab (addr 58829): WXCJKG12LM - Aqara Opple wireless switch (double band) (EndDevice)
      zigbee.0
      2024-10-11 23:46:04.786	info	0x00158d000587059d (addr 29129): DJT11LM - Aqara Vibration sensor (EndDevice)
      zigbee.0
      2024-10-11 23:46:04.784	info	0x00178801099a727d (addr 20805): 9290020399 - Philips Hue white E14 (Router)
      zigbee.0
      2024-10-11 23:46:04.783	info	0x00158d0003a4860a (addr 1831): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
      zigbee.0
      2024-10-11 23:46:04.782	info	0x00158d0003a351c4 (addr 53515): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
      zigbee.0
      2024-10-11 23:46:04.780	info	0x00158d0004020836 (addr 62856): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
      zigbee.0
      2024-10-11 23:46:04.778	info	0x842e14fffe471ae1 (addr 14292): E2001/E2002 - IKEA STYRBAR remote control (EndDevice)
      zigbee.0
      2024-10-11 23:46:04.775	info	0x003c84fffe2e20b6 (addr 21751): LED2004G8 - IKEA TRADFRI bulb E26/E27, white spectrum, globe, clear, 800/806 lm (Router)
      zigbee.0
      2024-10-11 23:46:04.773	info	0x003c84fffeb5efd7 (addr 22851): LED2004G8 - IKEA TRADFRI bulb E26/E27, white spectrum, globe, clear, 800/806 lm (Router)
      zigbee.0
      2024-10-11 23:46:04.769	info	0x000d6f000fbd8e3c (addr 61010): AC01353010G - OSRAM SMART+ Motion Sensor (EndDevice)
      zigbee.0
      2024-10-11 23:46:04.767	info	0x00158d000a827a14 (addr 54285): RTCGQ11LM - Aqara Motion sensor (EndDevice)
      zigbee.0
      2024-10-11 23:46:04.764	info	0x00158d0003a48625 (addr 34067): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
      zigbee.0
      2024-10-11 23:46:04.762	info	0x001788010c314523 (addr 19382): 929002469202 - Philips Hue white A60 bulb E27 1050lm with Bluetooth (Router)
      zigbee.0
      2024-10-11 23:46:04.759	info	0xa4c138c1782d2a29 (addr 22396): A1Z - Nous Smart plug (with power monitoring) (Router)
      zigbee.0
      2024-10-11 23:46:04.757	info	0x00178801090c0c72 (addr 13249): 9290022944 - Philips Hue white ambiance E14 (with Bluetooth) (Router)
      zigbee.0
      2024-10-11 23:46:04.754	info	0x00158d0008d07ff2 (addr 47060): RTCGQ11LM - Aqara Motion sensor (EndDevice)
      zigbee.0
      2024-10-11 23:46:04.752	info	0x90fd9ffffed895cf (addr 2822): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
      zigbee.0
      2024-10-11 23:46:04.750	info	0x5c0272fffe88b629 (addr 56924): L1529 - IKEA FLOALT light panel, white spectrum, 60x60 cm (Router)
      zigbee.0
      2024-10-11 23:46:04.745	info	0x00158d0002e34375 (addr 59924): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
      zigbee.0
      2024-10-11 23:46:04.742	info	0x000d6f000fbd45c4 (addr 37996): AC01353010G - OSRAM SMART+ Motion Sensor (EndDevice)
      zigbee.0
      2024-10-11 23:46:04.740	info	0x680ae2fffe0a50c2 (addr 21884): E1743 - IKEA TRADFRI on/off switch (EndDevice)
      zigbee.0
      2024-10-11 23:46:04.737	info	0xb4e3f9fffe0dcce7 (addr 21109): E1812 - IKEA TRADFRI shortcut button (EndDevice)
      zigbee.0
      2024-10-11 23:46:04.734	info	0x84fd27fffe2580df (addr 63575): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
      zigbee.0
      2024-10-11 23:46:04.732	info	0x04cf8cdf3c7d89f6 (addr 45463): WXCJKG13LM - Aqara Opple wireless switch (triple band) (EndDevice)
      zigbee.0
      2024-10-11 23:46:04.729	info	0x00158d0002e33879 (addr 8612): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
      zigbee.0
      2024-10-11 23:46:04.727	info	0x00158d00035389bd (addr 21392): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
      zigbee.0
      2024-10-11 23:46:04.724	info	0x00158d0003c7f9a7 (addr 14395): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
      zigbee.0
      2024-10-11 23:46:04.720	info	0x00158d000847e692 (addr 5547): RTCGQ11LM - Aqara Motion sensor (EndDevice)
      zigbee.0
      2024-10-11 23:46:04.717	info	0x00158d000847cee2 (addr 538): RTCGQ11LM - Aqara Motion sensor (EndDevice)
      zigbee.0
      2024-10-11 23:46:04.715	info	0xccccccfffedbebdc (addr 1415): LED1836G9 - IKEA TRADFRI bulb E26/E27, warm white, globe, opal, 806 lm (Router)
      zigbee.0
      2024-10-11 23:46:04.712	info	0x00158d0001e0d56b (addr 19518): RTCGQ11LM - Aqara Motion sensor (EndDevice)
      zigbee.0
      2024-10-11 23:46:04.709	info	0x00158d00040aa56f (addr 38815): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
      zigbee.0
      2024-10-11 23:46:04.707	info	0x00158d000450d167 (addr 18406): RTCGQ11LM - Aqara Motion sensor (EndDevice)
      zigbee.0
      2024-10-11 23:46:04.704	info	0x001788010bd75cd7 (addr 52586): 9290023349 - Philips Hue white A67 bulb E26 with Bluetooth (1600 Lumen) (Router)
      zigbee.0
      2024-10-11 23:46:04.702	info	0xec1bbdfffed4493f (addr 29043): LED1836G9 - IKEA TRADFRI bulb E26/E27, warm white, globe, opal, 806 lm (Router)
      zigbee.0
      2024-10-11 23:46:04.699	info	0x8cf681fffe03b46b (addr 8686): E1743 - IKEA TRADFRI on/off switch (EndDevice)
      zigbee.0
      2024-10-11 23:46:04.697	info	0x680ae2fffe12f5b2 (addr 32806): E1743 - IKEA TRADFRI on/off switch (EndDevice)
      zigbee.0
      2024-10-11 23:46:04.693	info	0xec1bbdfffe94bbcb (addr 47022): LED1733G7 - IKEA TRADFRI bulb E14, white spectrum, globe, opal, 600 lm (Router)
      zigbee.0
      2024-10-11 23:46:04.691	info	0xa4c1382c8738170e (addr 15166): TS0601_soil - TuYa Soil sensor (EndDevice)
      zigbee.0
      2024-10-11 23:46:04.688	info	0xec1bbdfffea04dd2 (addr 9470): E1525/E1745 - IKEA TRADFRI motion sensor (EndDevice)
      zigbee.0
      2024-10-11 23:46:04.685	info	0xec1bbdfffeb19154 (addr 16801): LED1836G9 - IKEA TRADFRI bulb E26/E27, warm white, globe, opal, 806 lm (Router)
      zigbee.0
      2024-10-11 23:46:04.683	info	0x00178801099f4997 (addr 51279): 9290023349 - Philips Hue white A67 bulb E26 with Bluetooth (1600 Lumen) (Router)
      zigbee.0
      2024-10-11 23:46:04.680	info	0xcc86ecfffe1183fc (addr 63037): HG06104A - Lidl Livarno Lux smart LED light strip 2.5m (Router)
      zigbee.0
      2024-10-11 23:46:04.676	info	0x0017880108ff0d07 (addr 9509): 9290023349 - Philips Hue white A67 bulb E26 with Bluetooth (1600 Lumen) (Router)
      zigbee.0
      2024-10-11 23:46:04.673	info	0x00158d00093e472a (addr 42638): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
      zigbee.0
      2024-10-11 23:46:04.669	info	0x000b57fffe349293 (addr 1015): LED1623G12 - IKEA TRADFRI bulb E27, white, globe, opal, 1000 lm (Router)
      zigbee.0
      2024-10-11 23:46:04.667	info	0xa4c13830a258e9b4 (addr 43754): TS011F_plug_1 - TuYa Smart plug (with power monitoring) (Router)
      zigbee.0
      2024-10-11 23:46:04.663	info	0x5c0272fffe92177a (addr 8037): ICPSHC24-30EU-IL-1/ICPSHC24-10EU-IL-2 - IKEA TRADFRI LED driver, 30 w (Router)
      zigbee.0
      2024-10-11 23:46:04.660	info	0xb4e3f9fffea666ae (addr 5426): ICPSHC24-30EU-IL-1/ICPSHC24-10EU-IL-2 - IKEA TRADFRI LED driver, 30 w (Router)
      zigbee.0
      2024-10-11 23:46:04.655	info	0xcc86ecfffed10c5f (addr 64156): LCZ030 - TuYa Temperature & humidity & illuminance sensor with display (EndDevice)
      zigbee.0
      2024-10-11 23:46:04.651	info	0x00158d0004abe765 (addr 56313): RTCGQ11LM - Aqara Motion sensor (EndDevice)
      zigbee.0
      2024-10-11 23:46:04.648	info	0x000d6f000fbd3eb7 (addr 39112): AC01353010G - OSRAM SMART+ Motion Sensor (EndDevice)
      zigbee.0
      2024-10-11 23:46:04.645	info	0x00158d000421184f (addr 44938): SJCGQ11LM - Aqara Water leak sensor (EndDevice)
      zigbee.0
      2024-10-11 23:46:04.641	info	0x00158d0001e0045e (addr 6318): RTCGQ11LM - Aqara Motion sensor (EndDevice)
      zigbee.0
      2024-10-11 23:46:04.630	info	0xa4c138a481b709c3 (addr 21686): HG08673 - Lidl Silvercrest smart plug with power monitoring (EU, FR) (Router)
      zigbee.0
      2024-10-11 23:46:04.292	info	Currently 76 devices are joined:
      zigbee.0
      2024-10-11 23:46:04.268	info	--> transmitPower : low
      zigbee.0
      2024-10-11 23:46:04.237	info	Unable to disable LED, unsupported function.
      zigbee.0
      2024-10-11 23:46:04.205	info	Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20230507}}
      zigbee.0
      2024-10-11 23:46:03.446	info	Installed Version: iobroker.zigbee@1.10.3
      zigbee.0
      2024-10-11 23:46:02.545	info	Starting Zigbee npm ...
      zigbee.0
      2024-10-11 23:46:02.542	info	delete old Backup files. keep only last 10
      zigbee.0
      2024-10-11 23:46:02.396	info	starting. Version 1.10.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.18.0, js-controller: 6.0.11
      Ich habe zwei Sonoff Dongles (die goßen) mit der gleichen FW, das Verhalten tritt bei beiden auf:
      Ich weiß, die FW soll wohl buggy sein. Lief bei mir aber jetzt 1,5 Jahre super.
      Die Geräte lassen sich nicht steuern:
      und alle Verbindungen sind weg.
      Funkkanalüberlagerungen haben sich nicht geändert. Zigbee funkt auf 13; Wlan auf 6 und 11.
      Iob Diag:
      bash
      Skript v.2024-08-12
      *** BASE SYSTEM ***
       Static hostname: Smartazamba
             Icon name: computer
                Kernel: Linux 6.6.51+rpt-rpi-v8
          Architecture: arm64
      OS is similar to:
      Model           : Raspberry Pi 4 Model B Rev 1.4
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : 64 bit
      Systemuptime and Load:
       23:56:56 up  1:25,  2 users,  load average: 1.58, 1.36, 1.40
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Fri 2024-10-11 23:56:57 CEST
                 Universal time: Fri 2024-10-11 21:56:57 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      pi
      HOME=/home/pi
      GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      iobroker
      HOME=/home/iobroker
      *** Display-Server-Setup ***
      Display-Server: false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            8.2G        3.4G        2.0G        3.1M        3.0G        4.8G
      Swap:             0B          0B          0B
      Total:          8.2G        3.4G        2.0G
      Active iob-Instances:   37
               7808 M total memory
               3232 M used memory
               4158 M active memory
               1455 M inactive memory
               1878 M free memory
                405 M buffer memory
               2433 M swap cache
                  0 M total swap
                  0 M used swap
                  0 M free swap
      top - 23:56:57 up  1:25,  2 users,  load average: 1.58, 1.36, 1.40
      Tasks: 217 total,   1 running, 216 sleeping,   0 stopped,   0 zombie
      %Cpu(s): 33.3 us, 16.7 sy,  0.0 ni, 50.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   7809.0 total,   1875.9 free,   3234.6 used,   2839.5 buff/cache
      MiB Swap:      0.0 total,      0.0 free,      0.0 used.   4574.4 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      /dev/root      ext4      110G   29G   79G  27% /
      devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
      tmpfs          tmpfs     1.6G  3.0M  1.6G   1% /run
      /dev/sda1      vfat      253M   44M  209M  18% /boot/firmware
      /dev/sdc       ext4      5.5T  3.5T  1.7T  68% /media/HDD2
      /dev/sdb1      ext4      4.6T  3.5T  825G  82% /media/HDD1
      tmpfs          tmpfs     781M     0  781M   0% /run/user/1000
      [Fri Oct 11 22:31:20 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:E2:C4:A5 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyAMA0,115200 console=tty1 root=PARTUUID=5bc7cbe7-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Fri Oct 11 22:31:23 2024] EXT4-fs (sda2): mounted filesystem 1943b829-a99b-45b8-9fe5-7136dbea4c4a ro with ordered data mode. Quota mode: none.
      [Fri Oct 11 22:31:23 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
      [Fri Oct 11 22:31:40 2024] EXT4-fs (sda2): re-mounted 1943b829-a99b-45b8-9fe5-7136dbea4c4a r/w. Quota mode: none.
      [Fri Oct 11 22:31:43 2024] EXT4-fs (sdc): mounted filesystem b85c7b90-8154-43e5-bcae-a07f1c446bec r/w with ordered data mode. Quota mode: none.
      [Fri Oct 11 22:31:43 2024] EXT4-fs (sdb1): mounted filesystem f79cb025-aab2-4bd5-bd49-84de9b0f60b4 r/w with ordered data mode. Quota mode: none.
      Show mounted filesystems:
      TARGET           SOURCE    FSTYPE OPTIONS
      /                /dev/sda2 ext4   rw,noatime
      |-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
      |-/media/HDD2    /dev/sdc  ext4   rw,nosuid,nodev,noexec,relatime
      `-/media/HDD1    /dev/sdb1 ext4   rw,nosuid,nodev,noexec,relatime
      /var:
      8.0G    /var/
      4.8G    /var/log
      3.7G    /var/log/journal/3dd7c02f298247188f8650087c821e8c
      645M    /var/cache
      Archived and active journals take up 3.6G in the file system.
      /opt/iobroker/backups:
      3.1G    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      1.2G    /opt/iobroker/iobroker-data/
      809M    /opt/iobroker/iobroker-data/files
      617M    /opt/iobroker/iobroker-data/files/javascript.admin
      560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
      558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
      58M     /opt/iobroker/iobroker-data/objects.jsonl
      38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
      24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
      18M     /opt/iobroker/iobroker-data/states.jsonl
      14M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.2cca4954.js
      USB-Devices by-id:
      /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_b875aef9f419ec118e7074e5f01c6278-if00-port0
      /dev/serial/by-id/usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0063-if00-port0
      /dev/serial/by-id/usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0052-if00-port0
      Your zigbee.0 COM-Port is matching 'by-id'. Very good!
      HINT:
      Your zigbee.1 COM-Port is NOT matching 'by-id'. Please check your setting:
      tcp
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.18.0
      /usr/bin/node           v20.18.0
      /usr/bin/corepack       0.29.3
      nodejs:
        Installed: 20.18.0-1nodesource1
        Candidate: 20.18.0-1nodesource1
        Version table:
       *** 20.18.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
              100 /var/lib/dpkg/status
           20.17.0-1nodesource1 1001
           20.16.0-1nodesource1 1001
           20.15.1-1nodesource1 1001
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           18.19.0+dfsg-6~deb12u2 500
           18.19.0+dfsg-6~deb12u1 500
              500 http://security.debian.org/debian-security bookworm-security/main arm64 Packages
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      admin:          7.1.5
      javascript:     8.8.3
      nodejs modules from github:     2
      +-- iobroker.esphome@0.5.0-beta.10 (git+ssh://git@github.com/DrozmotiX/ioBroker.esphome.git#6b97f67d1d1ce6af3a0e598ba77eec8f570a0854)
      | `-- kodi-ws@2.4.4 (git+https://git@github.com/iobroker-community-adapters/kodi-ws.git#ad5a1fdc5cd0a282e6818ff152594b5d32535103)
      Adapter State
      + system.adapter.admin.0                  : admin                 : Smartazamba                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : Smartazamba                              -  enabled
      + system.adapter.awtrix-light.0           : awtrix-light          : Smartazamba                              -  enabled
      + system.adapter.awtrix-light.1           : awtrix-light          : Smartazamba                              -  enabled
      + system.adapter.backitup.0               : backitup              : Smartazamba                              -  enabled
        system.adapter.denon.0                  : denon                 : Smartazamba                              - disabled
      + system.adapter.device-watcher.0         : device-watcher        : Smartazamba                              -  enabled
      + system.adapter.deyeidc.0                : deyeidc               : Smartazamba                              -  enabled, port: 8899
        system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: Smartazamba                              - disabled
      + system.adapter.esphome.0                : esphome               : Smartazamba                              -  enabled
        system.adapter.habpanel.0               : habpanel              : Smartazamba                              - disabled
        system.adapter.hass.0                   : hass                  : Smartazamba                              - disabled, port: 8123
      + system.adapter.hue.0                    : hue                   : Smartazamba                              -  enabled, port: 443
        system.adapter.ical.0                   : ical                  : Smartazamba                              -  enabled
      + system.adapter.influxdb.0               : influxdb              : Smartazamba                              -  enabled, port: 8086
      + system.adapter.iot.0                    : iot                   : Smartazamba                              -  enabled
      + system.adapter.javascript.0             : javascript            : Smartazamba                              -  enabled
        system.adapter.kodi.0                   : kodi                  : Smartazamba                              - disabled, port: 9090
      + system.adapter.logparser.0              : logparser             : Smartazamba                              -  enabled
      + system.adapter.mihome-vacuum.0          : mihome-vacuum         : Smartazamba                              -  enabled, port: 54321
      + system.adapter.mihome-vacuum.1          : mihome-vacuum         : Smartazamba                              -  enabled, port: 54321
      + system.adapter.mqtt.0                   : mqtt                  : Smartazamba                              -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.philips-tv.0             : philips-tv            : Smartazamba                              -  enabled
      + system.adapter.ping.0                   : ping                  : Smartazamba                              -  enabled
      + system.adapter.pixelit.0                : pixelit               : Smartazamba                              -  enabled
        system.adapter.pixelit.1                : pixelit               : Smartazamba                              - disabled
        system.adapter.pixelit.2                : pixelit               : Smartazamba                              - disabled
      + system.adapter.proxmox.0                : proxmox               : Smartazamba                              -  enabled, port: 8006
      + system.adapter.shelly.0                 : shelly                : Smartazamba                              -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.shuttercontrol.0         : shuttercontrol        : Smartazamba                              -  enabled
      + system.adapter.simple-api.0             : simple-api            : Smartazamba                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.smartmeter.0             : smartmeter            : Smartazamba                              -  enabled
      + system.adapter.smartmeter.1             : smartmeter            : Smartazamba                              -  enabled
      + system.adapter.sonoff.0                 : sonoff                : Smartazamba                              -  enabled, port: 1884, bind: 0.0.0.0
      + system.adapter.sourceanalytix.0         : sourceanalytix        : Smartazamba                              -  enabled
      + system.adapter.telegram.0               : telegram              : Smartazamba                              -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.telegram.1               : telegram              : Smartazamba                              -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.unifi.0                  : unifi                 : Smartazamba                              -  enabled
        system.adapter.weatherunderground.0     : weatherunderground    : Smartazamba                              -  enabled
      + system.adapter.web.0                    : web                   : Smartazamba                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.windows-control.0        : windows-control       : Smartazamba                              -  enabled
        system.adapter.wiobrowser.0             : wiobrowser            : Smartazamba                              - disabled, port: 5000
      + system.adapter.wled.0                   : wled                  : Smartazamba                              -  enabled
      + system.adapter.ws.0                     : ws                    : Smartazamba                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
      + system.adapter.zigbee.0                 : zigbee                : Smartazamba                              -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_b875aef9f419ec118e7074e5f01c6278-if00-port0
      + system.adapter.zigbee.1                 : zigbee                : Smartazamba                              -  enabled, port: tcp://192.168.178.42:6638
      + instance is alive
      ioBroker-Repositories
      │ (index) │ name               │ url                                                     │ auto upgrade │
      │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
      │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
      │ 2       │ 'latest live'      │ 'http://iobroker.live/repo/sources-dist-latest.json'    │ false        │
      Upgrade policy: none
      Installed ioBroker-Instances
      Adapter    "admin"        : 7.1.5    , installed 7.1.5
      Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
      Adapter    "awtrix-light" : 1.3.0    , installed 1.3.0
      Adapter    "backitup"     : 3.0.22   , installed 3.0.22
      Adapter    "denon"        : 1.15.12  , installed 1.15.12
      Adapter    "device-watcher": 2.12.1  , installed 2.12.1
      Adapter    "deyeidc"      : 0.1.0    , installed 0.1.0
      Adapter    "energiefluss-erweitert": 0.4.1, installed 0.4.1
      Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
      Adapter    "hass"         : 1.4.0    , installed 1.4.0
      Adapter    "hue"          : 3.12.0   , installed 3.12.0
      Adapter    "ical"         : 1.15.0   , installed 1.15.0
      Adapter    "iot"          : 3.3.0    , installed 3.3.0
      Adapter    "javascript"   : 8.8.3    , installed 8.8.3
      Controller "js-controller": 6.0.11   , installed 6.0.11
      Adapter    "kodi"         : 3.1.0    , installed 3.1.0
      Adapter    "logparser"    : 2.2.2    , installed 2.2.2
      Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
      Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
      Adapter    "philips-tv"   : 0.5.4    , installed 0.5.4
      Adapter    "pixelit"      : 1.1.4    , installed 1.1.4
      Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
      Adapter    "shelly"       : 8.2.1    , installed 8.2.1
      Adapter    "shuttercontrol": 1.7.3   , installed 1.7.3
      Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
      Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
      Adapter    "telegram"     : 3.9.0    , installed 3.9.0
      Adapter    "unifi"        : 0.7.0    , installed 0.7.0
      Adapter    "weatherunderground": 3.7.0, installed 3.7.0
      Adapter    "windows-control": 0.1.5  , installed 0.1.5
      Adapter    "wiobrowser"   : 2.0.2    , installed 2.0.2
      Adapter    "wled"         : 0.7.2    , installed 0.7.2
      Adapter    "ws"           : 2.6.2    , installed 2.6.2
      Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
      Objects and States
      Objects:        25452
      States:         17493
      Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
      Hit:2 http://deb.debian.org/debian bookworm InRelease
      Hit:4 http://archive.raspberrypi.org/debian bookworm InRelease
      Hit:5 https://apt.grafana.com stable InRelease
      Hit:6 https://deb.nodesource.com/node_20.x nodistro InRelease
      Hit:7 https://repos.influxdata.com/debian stable InRelease
      Reading package lists...
      Pending Updates: 7
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          3068       651/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          5536       824/smbd
      tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          5535       824/smbd
      tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1002       5104       845/iobroker.js-con
      tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1002       5109       845/iobroker.js-con
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1002       10146      1178/io.mqtt.0
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1002       11823      1211/io.shelly.0
      tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1002       10519      1278/io.sonoff.0
      tcp        0      0 0.0.0.0:9999            0.0.0.0:*               LISTEN      1000       293368     78949/nc
      tcp        0      0 0.0.0.0:6052            0.0.0.0:*               LISTEN      1002       13447      1557/python3
      tcp6       0      0 :::21                   :::*                    LISTEN      0          5426       642/vsftpd
      tcp6       0      0 :::22                   :::*                    LISTEN      0          3070       651/sshd: /usr/sbin
      tcp6       0      0 :::139                  :::*                    LISTEN      0          5534       824/smbd
      tcp6       0      0 :::445                  :::*                    LISTEN      0          5533       824/smbd
      tcp6       0      0 :::3000                 :::*                    LISTEN      109        5572       844/grafana
      tcp6       0      0 :::8081                 :::*                    LISTEN      1002       7590       900/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1002       11871      1609/io.web.0
      tcp6       0      0 :::8084                 :::*                    LISTEN      1002       13822      1674/io.ws.0
      tcp6       0      0 :::8087                 :::*                    LISTEN      1002       10931      1573/io.simple-api.
      tcp6       0      0 :::8086                 :::*                    LISTEN      999        6895       744/influxd
      udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          7175       802/nmbd
      udp        0      0 192.168.178.20:137      0.0.0.0:*                           0          7174       802/nmbd
      udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          1018       802/nmbd
      udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          7177       802/nmbd
      udp        0      0 192.168.178.20:138      0.0.0.0:*                           0          7176       802/nmbd
      udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          1019       802/nmbd
      udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1002       10765      1362/io.mihome-vacu
      udp        0      0 0.0.0.0:53422           0.0.0.0:*                           1002       10797      1410/io.mihome-vacu
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1002       10843      1651/io.wled.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1002       11657      1145/io.esphome.0
      udp        0      0 192.168.178.20:5353     0.0.0.0:*                           1002       13453      1557/python3
      udp        0      0 127.0.0.1:5353          0.0.0.0:*                           1002       13452      1557/python3
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1002       13448      1557/python3
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        850        478/avahi-daemon: r
      udp        0      0 0.0.0.0:51543           0.0.0.0:*                           108        852        478/avahi-daemon: r
      udp6       0      0 :::52956                :::*                                108        853        478/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                108        851        478/avahi-daemon: r
      2024-10-11 23:53:53.142  - warn: proxmox.0 (51247) Unable to get disk for node pve: 500 - [object Object]
      2024-10-11 23:54:04.664  - warn: proxmox.0 (51247) Unable to get disk for node pve: 500 - [object Object]
      2024-10-11 23:54:15.884  - warn: proxmox.0 (51247) Unable to get disk for node pve: 500 - [object Object]
      2024-10-11 23:54:27.346  - warn: proxmox.0 (51247) Unable to get disk for node pve: 500 - [object Object]
      2024-10-11 23:54:38.579  - warn: proxmox.0 (51247) Unable to get disk for node pve: 500 - [object Object]
      2024-10-11 23:54:49.941  - warn: proxmox.0 (51247) Unable to get disk for node pve: 500 - [object Object]
      2024-10-11 23:55:01.346  - warn: proxmox.0 (51247) Unable to get disk for node pve: 500 - [object Object]
      2024-10-11 23:55:13.614  - warn: proxmox.0 (51247) Unable to get disk for node pve: 500 - [object Object]
      2024-10-11 23:55:26.539  - warn: proxmox.0 (51247) Unable to get disk for node pve: 500 - [object Object]
      2024-10-11 23:55:38.145  - warn: proxmox.0 (51247) Unable to get disk for node pve: 500 - [object Object]
      2024-10-11 23:55:48.033  - info: host.Smartazamba instance system.adapter.weatherunderground.0 in version "3.7.0" started with pid 75611
      2024-10-11 23:55:49.681  - warn: proxmox.0 (51247) Unable to get disk for node pve: 500 - [object Object]
      2024-10-11 23:55:53.654  - info: weatherunderground.0 (75611) starting. Version 3.7.0 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v20.18.0, js-controller: 6.0.11
      2024-10-11 23:56:00.137  - info: weatherunderground.0 (75611) Terminated (NO_ERROR): Without reason
      2024-10-11 23:56:00.666  - info: host.Smartazamba instance system.adapter.weatherunderground.0 having pid 75611 terminated with code 0 (NO_ERROR)
      2024-10-11 23:56:04.709  - warn: proxmox.0 (51247) Unable to get disk for node pve: 500 - [object Object]
      2024-10-11 23:56:17.296  - warn: proxmox.0 (51247) Unable to get disk for node pve: 500 - [object Object]
      2024-10-11 23:56:28.804  - warn: proxmox.0 (51247) Unable to get disk for node pve: 500 - [object Object]
      2024-10-11 23:56:40.544  - warn: proxmox.0 (51247) Unable to get disk for node pve: 500 - [object Object]
      2024-10-11 23:56:52.733  - warn: proxmox.0 (51247) Unable to get disk for node pve: 500 - [object Object]
      2024-10-11 23:57:04.579  - warn: proxmox.0 (51247) Unable to get disk for node pve: 500 - [object Object]
      2024-10-11 23:57:19.334  - warn: proxmox.0 (51247) Unable to get disk for node pve: 500 - [object Object]
      2024-10-11 23:57:32.240  - warn: proxmox.0 (51247) Unable to get disk for node pve: 500 - [object Object]
      2024-10-11 23:57:44.459  - warn: proxmox.0 (51247) Unable to get disk for node pve: 500 - [object Object]
      2024-10-11 23:57:56.267  - warn: proxmox.0 (51247) Unable to get disk for node pve: 500 - [object Object]
      Was ist da passiert und wie bekomme ich das mit geringstmöglichem Aufwand wieder hin?
      Thomas Braun Asgothian 2 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @Rushmed last edited by
        @rushmed sagte in Zigbee Blackout:
        Wenn du die hochdrehst?
          Rushmed Most Active @Thomas Braun last edited by
          @thomas-braun Da passiert erstmal nichts, aber wie gesagt, das setup lief mit den Einstellungen lange problemfrei.
          • Asgothian
            Asgothian Developer @Rushmed last edited by
            @rushmed bitte ausprobieren:
            • zigbee adapter anhalten
            • stick abziehen
            • 60 s warten
            • Stick anstecken
            • Adapter starten
            A.
              Rushmed Most Active @Asgothian last edited by
              @asgothian Das hat leider auch nichts gebracht.
              • MartinP
                MartinP @Rushmed last edited by
                @rushmed Kanalfrequenz herausfinden, schauen, welche WiFi Kanäle damit kollidieren, und mit dem Smartphone nach der WiFi Nachbarschaft Schauen.
                Vielleicht hat aber auch die Nachbarschaft die Segnungen von Zigbee entdeckt, und sich ausgestattet ...
                  Rushmed Most Active @MartinP last edited by
                  @martinp Danke.
                  Habe soeben versucht ein Fullbackup von bevor die Symptome auftraten wieder her zu stellen. Leider mit dem gleichen Ergebnis.
                  • Jey Cee
                    Jey Cee Developer @Rushmed last edited by Jey Cee
                    @rushmed wenn dein Setup nicht geändert hast, hast du dir neue WLAN oder Bluetooth Geräte zugelegt?
                    Wie ist deine Wohnsituation, Einfamilienhaus oder Wohnblock?
                    Achso wenn du ne Fritzbox hast, schau da mal bei den Wlan Einstellungen. Dort gibt es die Möglichkeit die Auslastung des WLAN Frequenzbandes. Da werden auch Störquellen angezeigt.
                      Rushmed Most Active @Jey Cee last edited by Rushmed
                      @jey-cee Nein, keine neuen Geräte.
                      Einfammlienhaus und die nächsten Nachbarn sind im Urlaub, als installieren die wohl auch gerade keine Geräte.
                      Unify System.
                      Ich kann auch Geräte nicht neu verbinden.
                      • Jey Cee
                        @rushmed auszug aus der FAQ von zigbee2mqtt:
                        MAC_CHANNEL_ACCESS_FAILURE: this happens when the wireless spectrum is too occupied. Mostly happens when a microwave is on or when there are WiFi networks on the same channel. See Reduce Wifi interference by changing the Zigbee channel how to fix this.
                        Irgendwas verstopft also vermutlich dein Zigbee Kanal.
                          Beim Versuch die Geräte neu zu pairen kommt:
                          zigbee.0
                          2024-10-12 10:06:06.246	error	Failed to open the network: Error: Data request failed with error: 'No network route' (205) at ZStackAdapter.sendZclFrameToEndpointInternal (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:411:23) at Queue.execute (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:35:20) at GreenPower.permitJoin (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/greenPower.ts:229:13) at Controller.permitJoinInternal (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/controller.ts:251:13) at Controller.permitJoin (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/controller.ts:238:9) at ZigbeeController.permitJoin (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:525:17)
                          Es sieht so aus als wären alle Zigbee Geräte die mit Netzspannug versorgt werden nicht erreichbar. Die Battariegeräte sind da aber funktionieren auch nicht zu 100%.
                          • black.falcon87
                            black.falcon87 last edited by
                            Ich würde mal testweise nach und nach alle möglichen Geräte aus den Steckdosen ziehen. Z.B. USB Netzteil usw.
                            Im Zweifel halt alles und dann mal ioBroker neu starten und schauen ob es hilft.
                            Wenn ja dann halt anschließend nach und nach Geräte wieder in Betrieb nehmen und schauen wann es wieder schlechter wird
                              Hier noch der LOG vom Zigbee Adapter Neustart:
                              Lässt sich leider nicht einbette wegen seiner Länge.
                              Zigbee LOG.txt
                                Interessant! Ich habe jetzt mal meinen Mini PC der etwa 20 cm neben dem Raspi auf dem der ioBroker läuft ausgeschaltet und jetzt scheint das Problem behoben. Ich beobachte weiter.
                                Das Gerät kam mir erstmal gar nicht in den Sinn, da es weder mit dem ioBroker verbunden ist noch Wlan oder BT hat.
                                MartinP Asgothian BananaJoe 3 Replies Last reply Reply Quote 0
                                • MartinP
                                  Ist das Gehäuse des Mini-PC im normalen Zustand, oder offen?
                                  Bei Zigbee-USB-Sticks wird empfohlen, sie an ein USB -Verlängerungskabel zu hängen, damit sie in etwas Sicherheitsabstand zum System einhalten können.
                                  • Asgothian
                                    WLan und BT sind bei weitem nicht die einzigen Stoerquellen:
                                    • USB3, insbesondere bei Festplatten / SSD stört gerne im 2.4 GHz Band
                                    • Proprietäre Funkadapter arbeiten auch im 2.4 GHz Band (Kopfhörer, Maus/Tastatur, aber auch DECT, etc.)
                                    Dazu kommt das die Summe der Sender zählt - der Mini-PC kann also an der Störung teilhaben, aber auch nicht weiter verantwortlich sein wenn ein anderes Gerät das Funknetz belastet.
                                    A.
                                    • BananaJoe
                                      BananaJoe Most Active @Rushmed last edited by BananaJoe
                                      Diese Teile mit Intel N95 / N100 Prozessor die es für 150 bis 300 Euro im Moment zu Hauf gibt?
                                      Ist mir auch schon aufgefallen das die ja ein reines Kunststoffgehäuse ohne Schirmung (auch keine Metallbeschichtung von innen) haben ... Bei einem stand meine ich auch in der beiliegenden Anleitung das man bestimmte Geräte nicht zu nahe daran stellen soll wegen Störungen (ich meine bezogen auf USB).
                                      • Jey Cee
                                        Jey Cee Developer @Asgothian last edited by
                                        @asgothian sagte in Zigbee Blackout:
                                        Nicht zu vergessen Schaltnetzteile, die heute fast Überall verwendet werden. Wenn die schlecht gebaut oder Kaputt können Stören.
                                          @martinp Das Gehäuse ist geschlossen. Der Stick hängt sowieso an einem Verlängerungskabel und außerhalb vom Serverschrank.
                                          @BananaJoe Der Server ist ein HP Prodesk mini mit nem i5.
                                          Tatsächlich hatte ich gestern eine USB SSD an den Server gesteckt bevor das Netz zusammenbrach.
                                          Was mache ich denn da jetzt am besten? Räumliche Distanz zwischen den Geräten schaffen oder gibts geschirmte USB Kabel?
                                          Meister Mopper Asgothian 2 Replies Last reply Reply Quote 0
                                          • Meister Mopper
                                            Meister Mopper @Rushmed last edited by
                                            Ich würde zu Testzwecken die SSD mal oben ankleben.
                                            problem verbindung zigbee
                                            2083
