    4. bekomme den Sonoff 3 USB Dongle auch nicht auf grün.
    • werner2000x
      werner2000x last edited by werner2000x
      Ich bekomme den Sonoff 3 USB Dongle auch nicht auf grün.
      Hier der Log:
      2024-10-14 13:15:28.822  - error: zigbee.0 (14782) Starting zigbee-herdsman problem : "Error: No such file or directory, cannot open /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Pl                us_3a137e30f6e6ed11a179cf770b2af5ab-if00-port0"
      2024-10-14 13:15:28.825  - error: zigbee.0 (14782) Failed to start Zigbee
      2024-10-14 13:15:28.825  - error: zigbee.0 (14782) Error herdsman start
      2024-10-14 13:15:28.829  - info: zigbee.0 (14782) Installed Version: iobroker.zigbee@1.10.3
      2024-10-14 13:15:38.829  - info: zigbee.0 (14782) Try to reconnect. 1 attempts left
      2024-10-14 13:15:38.830  - info: zigbee.0 (14782) Starting Zigbee  npm ...
      2024-10-14 13:15:38.845  - error: zigbee.0 (14782) Starting zigbee-herdsman problem : "Error: No such file or directory, cannot open /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Pl                us_3a137e30f6e6ed11a179cf770b2af5ab-if00-port0"
      2024-10-14 13:15:38.846  - error: zigbee.0 (14782) Failed to start Zigbee
      2024-10-14 13:15:38.846  - error: zigbee.0 (14782) Error herdsman start
      2024-10-14 13:15:38.854  - info: zigbee.0 (14782) Installed Version: iobroker.zigbee@1.10.3
      zigbee.0
      2024-10-14 13:59:56.344	error	Error herdsman start
      zigbee.0
      2024-10-14 13:59:56.343	error	Failed to start Zigbee
      zigbee.0
      2024-10-14 13:59:56.342	error	Starting zigbee-herdsman problem : "Error Resource temporarily unavailable Cannot lock port"
      zigbee.0
      2024-10-14 13:59:56.120	info	Installed Version: iobroker.zigbee@1.10.3
      zigbee.0
      2024-10-14 13:59:56.092	info	Starting Zigbee npm ...
      zigbee.0
      2024-10-14 13:59:56.090	info	Try to reconnect. 1 attempts left
      zigbee.0
      2024-10-14 13:59:46.084	error	Error herdsman start
      zigbee.0
      2024-10-14 13:59:46.083	error	Failed to start Zigbee
      zigbee.0
      2024-10-14 13:59:46.082	error	Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
      Ich habe mal testweise auf Version 1.10.9 installiert - leider auch ohne Erfolg. Auch die Baudrate auf 38400 half nicht.
        Thomas Braun Most Active @werner2000x last edited by
        @werner2000x sagte in [gelöst] Sonoff Zigbee 3.0 Dongle E startet nicht (mehr):
        Error: No such file or directory, cannot open /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_3a137e30f6e6ed11a179cf770b2af5ab-if00-port0
        Und wie lautet der Link richtig?
        Steht z. B. in der Langfassung von
        iob diag
        drin.
        werner2000x 1 Reply Last reply Reply Quote 0
        • werner2000x
          werner2000x @Thomas Braun last edited by werner2000x
          @thomas-braun Hier der Log USB:
          USB-Devices by-id:
          USB-Sticks -  Avoid direct links to /dev/tty* in your adapter setups, please always prefer the l                      inks 'by-id':
          /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_3a137e30f6e6ed11a179cf770b2af5ab-i                      f00-port0
          Your zigbee.0 COM-Port is matching 'by-id'. Very good!
          zigbee.0
          2024-10-14 14:58:10.324	info	List of port: [{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"3a137e30f6e6ed11a179cf770b2af5ab","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_3a137e30f6e6ed11a179cf770b2af5ab-if00-port0","vendorId":"10c4","productId":"ea60"}]
          zigbee.0
          2024-10-14 14:58:10.159	error	getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
          zigbee.0
          2024-10-14 15:41:05.058	error	Error herdsman start
          zigbee.0
          2024-10-14 15:41:05.057	error	Failed to start Zigbee
          zigbee.0
          2024-10-14 15:41:05.056	error	Starting zigbee-herdsman problem : "Error Resource temporarily unavailable Cannot lock port"
          zigbee.0
          2024-10-14 15:41:04.879	info	Installed Version: ioBroker/ioBroker.zigbee
          zigbee.0
          2024-10-14 15:41:04.865	info	Starting Zigbee npm ...
          zigbee.0
          2024-10-14 15:41:04.863	info	Try to reconnect. 1 attempts left
          zigbee.0
          2024-10-14 15:40:54.858	error	Error herdsman start
          zigbee.0
          2024-10-14 15:40:54.858	error	Failed to start Zigbee
          zigbee.0
          2024-10-14 15:40:54.857	error	Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
            @werner2000x
            Zieh den Stick mal für 1 bis 2 Minuten raus und schau dann mal.
            • werner2000x
              @thomas-braun Leider kein Erfolg:
              zigbee.0
              2024-10-14 16:11:14.225	error	Error herdsman start
              zigbee.0
              2024-10-14 16:11:14.225	error	Failed to start Zigbee
              zigbee.0
              2024-10-14 16:11:14.224	error	Starting zigbee-herdsman problem : "Error Resource temporarily unavailable Cannot lock port"
              zigbee.0
              2024-10-14 16:11:14.051	info	Installed Version: ioBroker/ioBroker.zigbee
              zigbee.0
              2024-10-14 16:11:14.023	info	Starting Zigbee npm ...
              zigbee.0
              2024-10-14 16:11:14.022	info	Try to reconnect. 1 attempts left
              zigbee.0
              2024-10-14 16:11:04.018	error	Error herdsman start
              zigbee.0
              2024-10-14 16:11:04.018	error	Failed to start Zigbee
              zigbee.0
              2024-10-14 16:11:04.016	error	Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
              Thomas Braun haselchen 2 Replies Last reply Reply Quote 0
                @werner2000x
                Welche Firmware verwendet der Stick und was ist im Adapter eingetragen?
                • haselchen
                  haselchen Most Active @werner2000x last edited by
                  @werner2000x
                  Zeig mal nen Screenshot von den Einstellungen im Zigbee Adapter.
                  • werner2000x
                    @thomas-braun Wie komme ich auf die Firmwareversion?
                    Auf den Button Firmware updaten reagiert das System nicht.
                      @werner2000x
                      Änder mal den Typ auf EZirgendwas.
                      Ich meine der Stick würde nicht den TI-Stack verwenden.
                      • werner2000x
                        @thomas-braun Es Koomen zwar keine Fehlermeldungen, aber Infos.
                        zigbee.0
                        2024-10-14 17:44:38.122	info	Installed Version: ioBroker/ioBroker.zigbee
                        zigbee.0
                        2024-10-14 17:44:37.771	info	Starting Zigbee npm ...
                        zigbee.0
                        2024-10-14 17:44:37.768	info	delete old Backup files. keep only last 10
                        zigbee.0
                        2024-10-14 17:44:37.662	info	starting. Version 1.10.9 (non-npm: ioBroker/ioBroker.zigbee) in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.18.0, js-controller: 6.0.11
                        Der Status bleibt gelb.
                        Jetzt kommen doch noch Fehler.
                        zigbee.0
                        2024-10-14 17:47:09.029	error	Error herdsman start
                        zigbee.0
                        2024-10-14 17:47:09.029	error	Failed to start Zigbee
                        zigbee.0
                        2024-10-14 17:47:09.027	error	Starting zigbee-herdsman problem : "Failure to connect"
                        • haselchen
                          haselchen Most Active @werner2000x last edited by haselchen
                          @werner2000x
                          Also , mehrere Sachen.
                          Angefangen oben links .
                          Drück mal auf den Pfeil und zeig was Du für Auswahlmöglichkeiten hast .
                          Vermutlich musst Du gleich die erste Auswahl nehmen. tty/USB
                          Dann rechts lass mal auf die TI….C…. Einstellung.
                          Unten bei Sendeleistung drückst du auf den Pfeil und stellst Low ein.
                          • werner2000x
                            @haselchen Auswahlmenü:screenshotAuswahl.jpg
                            • haselchen
                              @werner2000x
                              Also mein Bester, wo ist oben links 😉
                              Bei der Auswahl die du jetzt gezeigt hast , nimmst du das Erste.
                              • werner2000x
                                werner2000x @haselchen last edited by
                                @haselchen Also den com anschluss auswählen.
                                Dort gibt es keine Auswahl, nur den bisher installierten.
                                • haselchen
                                  @werner2000x
                                  Wenn du da auf den Pfeil klickst kommt keine Auswahlmöglichkeit ? 🤔
                                  • werner2000x
                                    werner2000x @haselchen last edited by werner2000x
                                    @haselchen wenn ich state cleanup mache kommt noch:
                                    /dev/ttyUSB0
                                    • haselchen
                                      @werner2000x
                                      Den nimmst du .
                                      Und unten noch Low einstellen und dann den Adapter neu starten.
                                      Und dann zeigst du bitte das Log.
                                      • werner2000x
                                        @haselchen Es kommen noch Fehler:
                                        zigbee.0
                                        2024-10-14 18:17:46.104	error	Error herdsman start
                                        zigbee.0
                                        2024-10-14 18:17:46.103	error	Failed to start Zigbee
                                        zigbee.0
                                        2024-10-14 18:17:46.102	error	Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
                                        zigbee.0
                                        2024-10-14 18:21:48.322	info	List of port: [{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"3a137e30f6e6ed11a179cf770b2af5ab","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_3a137e30f6e6ed11a179cf770b2af5ab-if00-port0","vendorId":"10c4","productId":"ea60"}]
                                        zigbee.0
                                        2024-10-14 18:21:48.135	error	getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
                                        zigbee.0
                                        2024-10-14 18:21:45.344	error	Error herdsman start
                                        zigbee.0
                                        2024-10-14 18:21:45.344	error	Failed to start Zigbee
                                        zigbee.0
                                        2024-10-14 18:21:45.343	error	Starting zigbee-herdsman problem : "Error Resource temporarily unavailable Cannot lock port"
                                        • haselchen
                                          @werner2000x
                                          Ok gerade quergelesen .
                                          Nimm bei Coordinator den EZSP.
                                          Und wichtig , es darf nix anderes laufen wo auf den Stick zugegriffen wird , als Beispiel Homeassistant.
                                          Edit: und die URL vom Stick, die du vorher hattest … dev/…..
                                          Mit dem Tool kannste resetten oder die nötige Firmware aufspielen.
                                          https://zig-star.com/radio-docs/zigstar-multi-tool/
                                          • werner2000x
                                            @haselchen Den EZSP gibt es in zwei versionen.
                                            Wieder Fehler:
                                            zigbee.0
                                            2024-10-14 18:27:58.032	info	List of port: [{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"3a137e30f6e6ed11a179cf770b2af5ab","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_3a137e30f6e6ed11a179cf770b2af5ab-if00-port0","vendorId":"10c4","productId":"ea60"}]
                                            zigbee.0
                                            2024-10-14 18:27:57.884	error	getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
                                            zigbee.0
                                            2024-10-14 18:27:08.051	info	Installed Version: ioBroker/ioBroker.zigbee
                                            zigbee.0
                                            2024-10-14 18:27:07.719	info	Starting Zigbee npm ...
                                            zigbee.0
                                            2024-10-14 18:27:07.717	info	delete old Backup files. keep only last 10
                                            zigbee.0
                                            2024-10-14 18:27:07.618	info	starting. Version 1.10.9 (non-npm: ioBroker/ioBroker.zigbee) in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.18.0, js-controller: 6.0.11
                                            zigbee.0
                                            2024-10-14 18:26:52.141	info	terminating
                                            zigbee.0
                                            2024-10-14 18:26:51.658	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                            zigbee.0
                                            2024-10-14 18:26:51.655	info	terminating
                                            zigbee.0
                                            2024-10-14 18:26:51.642	info	Zigbee: disabling joining new devices.
                                            zigbee.0
                                            2024-10-14 18:26:51.637	info	cleaned everything up...
                                            zigbee.0
                                            2024-10-14 18:26:51.634	info	Got terminate signal TERMINATE_YOURSELF
                                            1219
