    4. Iot connection fail
    Iot connection fail
      Biterr28 last edited by
      Hallo zusammen, ich versuche, iot.0 zu installieren und eine Verbindung herzustellen, aber ich erhalte immer wieder ein Protokoll. der Adapter leuchtet immer wieder rot auf. Haben Sie eine Idee?
      host.Smarthome
      2024-10-14 20:32:53.565	info	Restart adapter system.adapter.iot.0 because enabled
      host.Smarthome
      2024-10-14 20:32:53.565	error	instance system.adapter.iot.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.Smarthome
      2024-10-14 20:32:53.565	error	Caught by controller[0]: Node.js v20.13.1
      host.Smarthome
      2024-10-14 20:32:53.565	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
      host.Smarthome
      2024-10-14 20:32:53.565	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1358:14)
      host.Smarthome
      2024-10-14 20:32:53.564	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/aws-iot-device-sdk/node_modules/mqtt/lib/client.js:12:19)
      host.Smarthome
      2024-10-14 20:32:53.564	error	Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
      host.Smarthome
      2024-10-14 20:32:53.564	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1233:19)
      host.Smarthome
      2024-10-14 20:32:53.564	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1024:12)
      host.Smarthome
      2024-10-14 20:32:53.564	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1208:32)
      host.Smarthome
      2024-10-14 20:32:53.564	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
      host.Smarthome
      2024-10-14 20:32:53.563	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1321:27)
      host.Smarthome
      2024-10-14 20:32:53.563	error	Caught by controller[0]: at wrapSafe (node:internal/modules/cjs/loader:1281:20)
      host.Smarthome
      2024-10-14 20:32:53.563	error	Caught by controller[0]: SyntaxError: Invalid or unexpected token
      host.Smarthome
      2024-10-14 20:32:53.562	error	Caught by controller[0]: /opt/iobroker/node_modules/aws-iot-device-sdk/node_modules/mqtt/lib/validations.js:1
      host.Smarthome
      2024-10-14 20:32:53.293	info	instance system.adapter.iot.0 in version "3.3.0" started with pid 137786
      host.Smarthome
      2024-10-14 20:32:22.664	info	Restart adapter system.adapter.iot.0 because enabled
        Thomas Braun Most Active @Biterr28 last edited by
        @biterr28
        Zunächst: Bring dein System auf einen aktuellen Stand.
          Biterr28 @Thomas Braun last edited by
          Hallo, ich habe vor einer Woche ein Update durchgeführt. Ich habe alle Anwendungen erfolgreich aktualisiert.
            Thomas Braun Most Active @Biterr28 last edited by Thomas Braun
            @biterr28
            Dann ist da was falsch bei dir...
            Die Langfassung von
            iob diag
            bitte. Dein Betriebssystem hast du nämlich nicht auf Stand.
              @thomas-braun Hi, Ich habe beigefügt, hier sind die Ergebnisse. leider kann ich die Ursache immer noch nicht erkennen
                 Static hostname: Smarthome
                       Icon name: computer
                Operating System: Debian GNU/Linux 11 (bullseye)
                          Kernel: Linux 6.1.21-v8+
                    Architecture: arm64
              User-ID:                1000
              Display-Server:         false
              Pending OS-Updates:     141
              Pending iob updates:    0
              Nodejs-Installation:
              /usr/bin/nodejs         v20.13.1
              /usr/bin/node           v20.13.1
              /usr/bin/npm            10.5.2
              /usr/bin/npx            10.5.2
              /usr/bin/corepack       0.28.0
              Recommended versions are nodejs 20.18.0 and npm 10.8.2
              MEMORY:
              Mem:            7.8G        2.0G        1.9G        0.0K        3.9G        5.7G
              Swap:            99M          0B         99M
              Total:          7.9G        2.0G        2.0G
              Active iob-Instances:   21
              Upgrade policy: none
              ioBroker Core:          js-controller           6.0.11
                                      admin                   7.1.5
              Objects type: jsonl
              States  type: jsonl
              + system.adapter.admin.0                  : admin                 : Smarthome                                -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
              + system.adapter.web.0                    : web                   : Smarthome                                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
              Objects:                8789
              States:                 7318
              Size of iob-Database:
              16M     /opt/iobroker/iobroker-data/objects.jsonl
              6.0M    /opt/iobroker/iobroker-data/states.jsonl
              • BananaJoe
                BananaJoe Most Active @Biterr28 last edited by
                @biterr28 das ist die Kurzfassung, die Langfassung bitte
                Da fehlen aber ein Menge Updates
                  Biterr28 @BananaJoe last edited by
                  @bananajoe Sie haben Recht, tut mir leid. vollständiger Bericht unten
                  ```bash
                  Skript v.2024-08-12
                  *** BASE SYSTEM ***
                           Icon name: computer
                        Architecture: arm64
                  OS is similar to:
                  Model           : Raspberry Pi 4 Model B Rev 1.4
                  Docker          : false
                  Virtualization  : none
                  Kernel          : aarch64
                  Userland        : 64 bit
                  Systemuptime and Load:
                   18:22:55 up 3 days, 21:52,  2 users,  load average: 2.64, 2.27, 2.11
                  CPU threads: 4
                  *** RASPBERRY THROTTLING ***
                  Current issues:
                  Previously detected issues:
                  *** Time and Time Zones ***
                                 Local time: Wed 2024-10-16 18:22:56 CEST
                             Universal time: Wed 2024-10-16 16:22:56 UTC
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  *** Users and Groups ***
                  User that called 'iob diag':
                  pi
                  HOME=/home/pi
                  GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render ne        tdev lpadmin gpio i2c spi iobroker
                  iobroker
                  HOME=/home/iobroker
                  *** Display-Server-Setup ***
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Mem:            7.8G        1.6G        696M        0.0K        5.6G        6.1G
                  Swap:            99M          0B         99M
                  Total:          7.9G        1.6G        796M
                           7812 M total memory
                           1557 M used memory
                           1838 M active memory
                           4875 M inactive memory
                            696 M free memory
                            287 M buffer memory
                           5270 M swap cache
                             99 M total swap
                              0 M used swap
                             99 M free swap
                  top - 18:22:56 up 3 days, 21:52,  2 users,  load average: 2.64, 2.27, 2.11
                  Tasks: 190 total,   1 running, 189 sleeping,   0 stopped,   0 zombie
                  %Cpu(s):  0.0 us,  1.5 sy,  0.0 ni, 98.5 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                  MiB Mem :   7812.3 total,    695.8 free,   1558.1 used,   5558.4 buff/cache
                  MiB Swap:    100.0 total,    100.0 free,      0.0 used.   6115.5 avail Mem
                  *** FAILED SERVICES ***
                  0 loaded units listed.
                  *** FILESYSTEM ***
                  /dev/root      ext4       30G   13G   16G  44% /
                  devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
                  tmpfs          tmpfs     1.6G  888K  1.6G   1% /run
                  /dev/mmcblk0p1 vfat      253M   31M  222M  13% /boot
                  tmpfs          tmpfs     782M   24K  782M   1% /run/user/1000
                  [Sat Oct 12 20:30:14 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0        snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.ena        ble_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:CF:1C:DF vc_mem.        mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty        1 root=PARTUUID=7022dd96-02 rootfstype=ext4 fsck.repair=yes rootwait
                  [Sat Oct 12 20:30:15 2024] EXT4-fs (mmcblk0p2): INFO: recovery required on reado        nly filesystem
                  [Sat Oct 12 20:30:15 2024] EXT4-fs (mmcblk0p2): write access will be enabled dur        ing recovery
                  [Sat Oct 12 20:30:17 2024] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
                  [Sat Oct 12 20:30:17 2024] EXT4-fs (mmcblk0p2): 1 orphan inode deleted
                  [Sat Oct 12 20:30:17 2024] EXT4-fs (mmcblk0p2): recovery complete
                  [Sat Oct 12 20:30:17 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered        data mode. Quota mode: none.
                  [Sat Oct 12 20:30:17 2024] VFS: Mounted root (ext4 filesystem) readonly on devic        e 179:2.
                  [Sat Oct 12 20:30:19 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                  [Tue Oct 15 21:33:11 2024] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_t        ree:1101: inode #1322635: block 7455285: comm find: bad entry in directory: rec_        len is smaller than minimal - offset=0, inode=0, rec_len=0, size=4096 fake=0
                  [Tue Oct 15 21:33:41 2024] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_t        ree:1101: inode #1322639: block 7455286: comm find: bad entry in directory: rec_        len is smaller than minimal - offset=0, inode=0, rec_len=0, size=4096 fake=0
                  Show mounted filesystems:
                  TARGET  SOURCE         FSTYPE OPTIONS
                  /       /dev/mmcblk0p2 ext4   rw,noatime
                  `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,ioc        harset=ascii,shortname=mixed,errors=remount-ro
                  /var:
                  3.4G    /var/
                  2.0G    /var/log
                  1.9G    /var/log/journal/bf14957a8fc542ac847a1bfbd4b1e9e4
                  1.1G    /var/cache/apt
                  Archived and active journals take up 1.8G in the file system.
                  /opt/iobroker/backups:
                  193M    /opt/iobroker/backups/
                  /opt/iobroker/iobroker-data:
                  1.2G    /opt/iobroker/iobroker-data/
                  1.1G    /opt/iobroker/iobroker-data/files
                  617M    /opt/iobroker/iobroker-data/files/javascript.admin
                  560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                  558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                  38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.m        ap
                  35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.        js.map
                  24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.m        ap
                  24M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.c9369f6c.j        s.map
                  23M     /opt/iobroker/iobroker-data/objects.jsonl
                  USB-Devices by-id:
                  USB-Sticks -  Avoid direct links to /dev/tty* in your adapter setups, please alw        ays prefer the links 'by-id':
                  /dev/serial/by-id/usb-0658_0200-if00
                  *** NodeJS-Installation ***
                  /usr/bin/nodejs         v20.18.0
                  /usr/bin/node           v20.18.0
                  /usr/bin/corepack       0.29.3
                  nodejs:
                    Installed: 20.18.0-1nodesource1
                    Candidate: 20.18.0-1nodesource1
                    Version table:
                   *** 20.18.0-1nodesource1 600
                          500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                          100 /var/lib/dpkg/status
                       20.17.0-1nodesource1 600
                       20.16.0-1nodesource1 600
                       20.15.1-1nodesource1 600
                       20.15.0-1nodesource1 600
                       20.14.0-1nodesource1 600
                       20.13.1-1nodesource1 600
                       20.13.0-1nodesource1 600
                       20.12.2-1nodesource1 600
                       20.12.1-1nodesource1 600
                       20.12.0-1nodesource1 600
                       20.11.1-1nodesource1 600
                       20.11.0-1nodesource1 600
                       20.10.0-1nodesource1 600
                       20.9.0-1nodesource1 600
                       20.8.1-1nodesource1 600
                       20.8.0-1nodesource1 600
                       20.7.0-1nodesource1 600
                       20.6.1-1nodesource1 600
                       20.6.0-1nodesource1 600
                       20.5.1-1nodesource1 600
                       20.5.0-1nodesource1 600
                       20.4.0-1nodesource1 600
                       20.3.1-1nodesource1 600
                       20.3.0-1nodesource1 600
                       20.2.0-1nodesource1 600
                       20.1.0-1nodesource1 600
                       20.0.0-1nodesource1 600
                       12.22.12~dfsg-1~deb11u5 500
                          500 http://security.debian.org/debian-security bullseye-security/main ar        m64 Packages
                       12.22.12~dfsg-1~deb11u4 500
                          500 http://deb.debian.org/debian bullseye/main arm64 Packages
                  No problems detected
                  Errors in npm tree:
                  *** ioBroker-Installation ***
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  Core adapters versions
                  js-controller:  6.0.11
                  admin:          7.1.5
                  javascript:     8.8.3
                  Adapter State
                  + system.adapter.alexa2.0                 : alexa2                : Smarthome                                -  enabled
                    system.adapter.alias-manager.0          : alias-manager         : Smarthome                                - disabled
                  + system.adapter.backitup.0               : backitup              : Smarthome                                -  enabled
                    system.adapter.cloud.0                  : cloud                 : Smarthome                                - disabled
                  + system.adapter.cloud.1                  : cloud                 : Smarthome                                -  enabled
                    system.adapter.devices.0                : devices               : Smarthome                                - disabled
                  + system.adapter.discovery.0              : discovery             : Smarthome                                -  enabled
                  + system.adapter.email.0                  : email                 : Smarthome                                -  enabled
                  + system.adapter.followthesun.0           : followthesun          : Smarthome                                -  enabled
                  + system.adapter.fritzbox.0               : fritzbox              : Smarthome                                -  enabled
                  + system.adapter.fritzdect.0              : fritzdect             : Smarthome                                -  enabled
                    system.adapter.habpanel.0               : habpanel              : Smarthome                                -  enabled
                  + system.adapter.info.0                   : info                  : Smarthome                                -  enabled
                    system.adapter.iot.0                    : iot                   : Smarthome                                -  enabled
                    system.adapter.iwg-vpn.0                : iwg-vpn               : Smarthome                                - disabled
                    system.adapter.iwg-vpn.1                : iwg-vpn               : Smarthome                                - disabled
                  + system.adapter.javascript.0             : javascript            : Smarthome                                -  enabled
                    system.adapter.lg-thinq.0               : lg-thinq              : Smarthome                                - disabled
                  + system.adapter.linux-control.0          : linux-control         : Smarthome                                -  enabled
                  + system.adapter.nina.0                   : nina                  : Smarthome                                -  enabled
                    system.adapter.openweathermap.0         : openweathermap        : Smarthome                                -  enabled
                  + system.adapter.pushover.0               : pushover              : Smarthome                                -  enabled
                  + system.adapter.scenes.0                 : scenes                : Smarthome                                -  enabled
                  + system.adapter.telegram.0               : telegram              : Smarthome                                -  enabled, port: 8443, bind: 0.0.0.0
                  + system.adapter.vis-2.0                  : vis-2                 : Smarthome                                -  enabled
                    system.adapter.vis.0                    : vis                   : Smarthome                                -  enabled
                  + system.adapter.zwave2.0                 : zwave2                : Smarthome                                -  enabled
                  + system.adapter.zwave2.1                 : zwave2                : Smarthome                                -  enabled
                  + instance is alive
                  ioBroker-Repositories
                  Active repo(s): stable
                  Installed ioBroker-Instances
                  Used repository: stable
                  Adapter    "admin"        : 7.1.5    , installed 7.1.5
                  Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                  Adapter    "backitup"     : 3.0.25   , installed 3.0.25
                  Adapter    "cloud"        : 5.0.1    , installed 5.0.1
                  Adapter    "discovery"    : 5.0.0    , installed 5.0.0
                  Adapter    "email"        : 1.3.1    , installed 1.3.1
                  Adapter    "followthesun" : 0.5.1    , installed 0.5.1
                  Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
                  Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
                  Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
                  Adapter    "iot"          : 3.3.0    , installed 3.3.0
                  Adapter    "iwg-vpn"      : 3.0.0    , installed 3.0.0
                  Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                  Controller "js-controller": 6.0.11   , installed 6.0.11
                  Adapter    "lg-thinq"     : 1.0.2    , installed 1.0.2
                  Adapter    "linux-control": 1.1.5    , installed 1.1.5
                  Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
                  Adapter    "nina"         : 0.0.25   , installed 0.0.25
                  Adapter    "node-red"     : 5.2.1    , installed 5.2.1
                  Adapter    "openweathermap": 1.1.2   , installed 1.1.2
                  Adapter    "pushover"     : 4.1.0    , installed 4.1.0
                  Adapter    "scenes"       : 3.2.3    , installed 3.2.3
                  Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                  Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
                  Adapter    "telegram"     : 3.9.0    , installed 3.9.0
                  Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
                  Adapter    "vis-2"        : 2.9.32   , installed 2.9.32
                  Adapter    "ws"           : 2.6.2    , installed 2.6.2
                  Adapter    "zwave2"       : 3.1.0    , installed 3.1.0
                  Objects and States
                  Objects:        8838
                  States:         7331
                  Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                  Hit:2 http://deb.debian.org/debian bullseye InRelease
                  Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                  Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                  Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                  Reading package lists...
                  Pending Updates: 0
                  *** Listening Ports ***
                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       413471     191964/iobroker.js-
                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       414132     191964/iobroker.js-
                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11878      557/sshd: /usr/sbin
                  tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          422500     195397/cupsd
                  tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          15597      556/vncserver-x11-c
                  tcp6       0      0 ::1:631                 :::*                    LISTEN      0          422499     195397/cupsd
                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       411514     191982/io.admin.0
                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       415928     192271/io.web.0
                  tcp6       0      0 :::44541                :::*                    LISTEN      1001       439348     202043/./pawns-cli
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          11880      557/sshd: /usr/sbin
                  tcp6       0      0 :::5900                 :::*                    LISTEN      0          15596      556/vncserver-x11-c
                  udp        0      0 0.0.0.0:53894           0.0.0.0:*                           108        11851      409/avahi-daemon: r
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11849      409/avahi-daemon: r
                  udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15622      480/dhcpcd
                  udp6       0      0 :::546                  :::*                                0          14830      480/dhcpcd
                  udp6       0      0 :::54442                :::*                                108        11852      409/avahi-daemon: r
                  udp6       0      0 :::5353                 :::*                                108        11850      409/avahi-daemon: r
                  2024-10-16 18:23:04.256  - error: host.Smarthome Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1104:12)
                  2024-10-16 18:23:04.256  - error: host.Smarthome Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1311:19)
                  2024-10-16 18:23:04.256  - error: host.Smarthome Caught by controller[0]:     at require (node:internal/modules/helpers:179:18)
                  2024-10-16 18:23:04.256  - error: host.Smarthome Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/aws-iot-device-sdk/node_modules/mqtt/lib/client.js:12:19)
                  2024-10-16 18:23:04.256  - error: host.Smarthome Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1469:14)
                  2024-10-16 18:23:04.256  - error: host.Smarthome Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
                  2024-10-16 18:23:04.256  - error: host.Smarthome Caught by controller[0]: Node.js v20.18.0
                  2024-10-16 18:23:04.257  - error: host.Smarthome instance system.adapter.iot.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                  2024-10-16 18:23:04.257  - info: host.Smarthome Restart adapter system.adapter.iot.0 because enabled
                  2024-10-16 18:23:34.594  - info: host.Smarthome instance system.adapter.iot.0 in version "3.3.0" started with pid 218934
                  2024-10-16 18:23:34.852  - error: host.Smarthome Caught by controller[0]: /opt/iobroker/node_modules/aws-iot-device-sdk/node_modules/mqtt/lib/validations.js:1
                  2024-10-16 18:23:34.853  - error: host.Smarthome Caught by controller[0]: SyntaxError: Invalid or unexpected token
                  2024-10-16 18:23:34.853  - error: host.Smarthome Caught by controller[0]:     at wrapSafe (node:internal/modules/cjs/loader:1378:20)
                  2024-10-16 18:23:34.853  - error: host.Smarthome Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1428:41)
                  2024-10-16 18:23:34.853  - error: host.Smarthome Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
                  2024-10-16 18:23:34.853  - error: host.Smarthome Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1288:32)
                  2024-10-16 18:23:34.853  - error: host.Smarthome Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1104:12)
                  2024-10-16 18:23:34.854  - error: host.Smarthome Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1311:19)
                  2024-10-16 18:23:34.854  - error: host.Smarthome Caught by controller[0]:     at require (node:internal/modules/helpers:179:18)
                  2024-10-16 18:23:34.854  - error: host.Smarthome Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/aws-iot-device-sdk/node_modules/mqtt/lib/client.js:12:19)
                  2024-10-16 18:23:34.854  - error: host.Smarthome Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1469:14)
                  2024-10-16 18:23:34.854  - error: host.Smarthome Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
                  2024-10-16 18:23:34.854  - error: host.Smarthome Caught by controller[0]: Node.js v20.18.0
                  2024-10-16 18:23:34.854  - error: host.Smarthome instance system.adapter.iot.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                  2024-10-16 18:23:34.854  - info: host.Smarthome Restart adapter system.adapter.iot.0 because enabled
                  iob diag has finished.
                    @biterr28
                    Sauber neustarten. Da war mit Sicherheit bei den 141 Updates das ein oder andere dabei...
                    Dein Dateisystem sieht auchh nicht mehr topfit aus.
                    vncserver und cups sollten auch nicht laufen.
                      @thomas-braun Was genau sollte ich in dieser Situation tun?
                        @biterr28
                        sudo reboot
                          @thomas-braun immer noch keine Verbindung. unten neue diagnose. können sie bitte helfen? sollte ich versuchen, adpter iot.0 zu deinstallieren und neu zu installieren?
                          ```bash
                          Skript v.2024-08-12
                          *** BASE SYSTEM ***
                                   Icon name: computer
                                Architecture: arm64
                          OS is similar to:
                          Docker          : false
                          Kernel          : aarch64
                          Userland        : 64 bit
                           19:05:02 up 24 min,  2 users,  load average: 0.56, 0.50, 0.44
                          CPU threads: 4
                          Current issues:
                                         Local time: Wed 2024-10-16 19:05:02 CEST
                                     Universal time: Wed 2024-10-16 17:05:02 UTC
                                           RTC time: n/a
                                        NTP service: active
                                    RTC in local TZ: no
                          pi
                          HOME=/home/pi
                          GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                          iobroker
                          HOME=/home/iobroker
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Mem:            7.8G        1.4G        6.0G        0.0K        495M        6.3G
                          Swap:            99M          0B         99M
                          Total:          7.9G        1.4G        6.1G
                                   7812 M total memory
                                   1360 M used memory
                                   1509 M active memory
                                    218 M inactive memory
                                   5956 M free memory
                                     64 M buffer memory
                                    430 M swap cache
                                     99 M total swap
                                      0 M used swap
                                     99 M free swap
                          top - 19:05:03 up 24 min,  2 users,  load average: 0.56, 0.50, 0.44
                          Tasks: 189 total,   1 running, 188 sleeping,   0 stopped,   0 zombie
                          %Cpu(s):  1.4 us,  1.4 sy,  0.0 ni, 97.1 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                          MiB Mem :   7812.3 total,   5956.3 free,   1360.1 used,    496.0 buff/cache
                          MiB Swap:    100.0 total,    100.0 free,      0.0 used.   6330.7 avail Mem
                          *** FILESYSTEM ***
                          /dev/root      ext4       30G   12G   16G  43% /
                          tmpfs          tmpfs     1.6G  884K  1.6G   1% /run
                          [Wed Oct 16 18:40:04 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:CF:1C:DF vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=7022dd96-02 rootfstype=ext4 fsck.repair=yes rootwait
                          [Wed Oct 16 18:40:05 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                          [Wed Oct 16 18:40:05 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                          [Wed Oct 16 18:40:08 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                          `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                          /var:
                          3.4G    /var/
                          2.0G    /var/log
                          1.1G    /var/cache/apt
                          38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
                          35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                          28M     /opt/iobroker/iobroker-data/objects.jsonl
                          24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                          24M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.c9369f6c.js.map
                          USB-Devices by-id:
                          nodejs:
                            Version table:
                                  500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                          Errors in npm tree:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          admin:          7.1.5
                          javascript:     8.8.3
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        8836
                          States:         7329
                          Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
                          Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
                          Pending Updates: 0
                          tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          12804      529/cupsd
                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       15400      537/iobroker.js-con
                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16401      537/iobroker.js-con
                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          1964       563/sshd: /usr/sbin
                          tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          13881      557/vncserver-x11-c
                          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       16816      1114/io.web.0
                          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       15489      802/io.admin.0
                          tcp6       0      0 ::1:631                 :::*                    LISTEN      0          12803      529/cupsd
                          tcp6       0      0 :::22                   :::*                    LISTEN      0          1966       563/sshd: /usr/sbin
                          tcp6       0      0 :::5900                 :::*                    LISTEN      0          13880      557/vncserver-x11-c
                          tcp6       0      0 :::34367                :::*                    LISTEN      1001       15712      1013/./pawns-cli
                          udp        0      0 0.0.0.0:50310           0.0.0.0:*                           108        1914       410/avahi-daemon: r
                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        1912       410/avahi-daemon: r
                          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          2002       475/dhcpcd
                          udp6       0      0 :::5353                 :::*                                108        1913       410/avahi-daemon: r
                          udp6       0      0 :::48385                :::*                                108        1915       410/avahi-daemon: r
                          udp6       0      0 :::546                  :::*                                0          15374      475/dhcpcd
                          2024-10-16 19:04:58.360  - error: host.Smarthome Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1311:19)
                          2024-10-16 19:04:58.360  - error: host.Smarthome Caught by controller[0]:     at require (node:internal/modules/helpers:179:18)
                          2024-10-16 19:04:58.360  - error: host.Smarthome Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/aws-iot-device-sdk/node_modules/mqtt/lib/client.js:12:19)
                          2024-10-16 19:04:58.360  - error: host.Smarthome Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1469:14)
                          2024-10-16 19:04:58.360  - error: host.Smarthome Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
                          2024-10-16 19:04:58.360  - error: host.Smarthome Caught by controller[0]: Node.js v20.18.0
                          2024-10-16 19:04:58.361  - error: host.Smarthome instance system.adapter.iot.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                          2024-10-16 19:04:58.361  - info: host.Smarthome Restart adapter system.adapter.iot.0 because enabled
                          2024-10-16 19:05:28.769  - info: host.Smarthome instance system.adapter.iot.0 in version "3.3.0" started with pid 2547
                          2024-10-16 19:05:29.034  - error: host.Smarthome Caught by controller[0]: /opt/iobroker/node_modules/aws-iot-device-sdk/node_modules/mqtt/lib/validations.js:1
                          2024-10-16 19:05:29.034  - error: host.Smarthome Caught by controller[0]: SyntaxError: Invalid or unexpected token
                          2024-10-16 19:05:29.035  - error: host.Smarthome Caught by controller[0]:     at wrapSafe (node:internal/modules/cjs/loader:1378:20)
                          2024-10-16 19:05:29.035  - error: host.Smarthome Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1428:41)
                          2024-10-16 19:05:29.035  - error: host.Smarthome Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
                          2024-10-16 19:05:29.035  - error: host.Smarthome Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1288:32)
                          2024-10-16 19:05:29.035  - error: host.Smarthome Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1104:12)
                          2024-10-16 19:05:29.035  - error: host.Smarthome Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1311:19)
                          2024-10-16 19:05:29.035  - error: host.Smarthome Caught by controller[0]:     at require (node:internal/modules/helpers:179:18)
                          2024-10-16 19:05:29.035  - error: host.Smarthome Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/aws-iot-device-sdk/node_modules/mqtt/lib/client.js:12:19)
                          2024-10-16 19:05:29.035  - error: host.Smarthome Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1469:14)
                          2024-10-16 19:05:29.035  - error: host.Smarthome Caught by controller[1]: Node.js v20.18.0
                          2024-10-16 19:05:29.036  - error: host.Smarthome instance system.adapter.iot.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                          2024-10-16 19:05:29.036  - info: host.Smarthome Restart adapter system.adapter.iot.0 because enabled
                          2024-10-16 19:05:34.135  - info: web.0 (1114) ==> Connected system.user.admin from 2a00:1e:8c84:1901:786b:ecef:7449:b94c
                            @biterr28 sagte in Iot connection fail:
                            Das ist Malware. Die ist hier schon verschiedentlich aufgetaucht.
                            System löschen und komplett frisch neuaufsetzen.
                              @thomas-braun Ich verstehe nicht wirklich, wovon Sie sprechen und wie man das macht. Das ist völlig neu für mich. Ich habe das aktuelle System vom Vorbesitzer übernommen.
                                Dann installier es neu, damit es auch DEIN System ist.
                                https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                                  @thomas-braun Gibt es eine Schritt-für-Schritt-Anleitung, wie man das richtig macht?
                                  • mcm1957
                                    mcm1957 @Biterr28 last edited by
                                    @biterr28 said in Iot connection fail:
                                      Biterr28 @mcm1957 last edited by
                                      @mcm1957 danke 🙂
                                      und wie kann ich das System deinstallieren? Gibt es auch eine Gebrauchsanweisung? Vielen Dank im Voraus für Ihre Hilfe
                                        @biterr28
                                        Eine Neuinstallation überschreibt die alte Installation.
                                        Ich würde aber vermutlich gleich eine neue SD-Karte verwenden.
                                          Herzlichen Dank für Ihre Hilfe. 🙂
                                          306
