    4. [geloest] npm Cache kann nicht geleert werden
      lessthanmore last edited by lessthanmore
      Moin zusammen,
      per ncdu ist mir aufgefallen, dass der Ordner /home/iobroker/.npm/_cacache immer größer wird und nicht geleert werden kann.
      --- /home/iobroker/.npm -------------------------------------------------------------------------------------------------------
      .   2.7 GiB [##################] /_cacache
         12.9 MiB [                  ] /_libvips
        944.0 KiB [                  ] /_npx
        404.0 KiB [                  ] /_prebuilds
        172.0 KiB [                  ] /_logs
      e   4.0 KiB [                  ] /_locks
          4.0 KiB [                  ]  anonymous-cli-metrics.json
          0.0   B [                  ]  _update-notifier-last-checked
      Ein
      npm cache clean --force
      bringt hier keine Änderung.
      iob diag:
      Skript v.2024-08-12
      *** BASE SYSTEM ***
       Static hostname: iobroker
             Icon name: computer-container
               Chassis: container ☐
        Virtualization: lxc
                Kernel: Linux 6.8.12-2-pve
          Architecture: x86-64
      OS is similar to:
      model name	: 11th Gen Intel(R) Core(TM) i5-1135G7 @ 2.40GHz
      Docker          : false
      Virtualization  : lxc
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
       08:38:54 up 27 days, 21:11,  2 users,  load average: 0.10, 0.18, 0.17
      CPU threads: 4
      *** Time and Time Zones ***
                     Local time: Wed 2024-10-16 08:38:55 CEST
                 Universal time: Wed 2024-10-16 06:38:55 UTC
                       RTC time: n/a
                    NTP service: inactive
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      michael
      HOME=/home/michael
      GROUPS=michael tty dialout sudo iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video plugdev redis
      *** Display-Server-Setup ***
      Display-Server: false
      Desktop:
      Terminal:
      Boot Target: 	multi-user.target
      *** MEMORY ***
      Mem:            8.6G        2.5G        2.5G        184K        3.5G        6.0G
      Swap:           4.3G         24K        4.3G
      Total:           12G        2.5G        6.8G
      Active iob-Instances: 	19
               8192 M total memory
               2428 M used memory
               2055 M active memory
               3201 M inactive memory
               2395 M free memory
                  0 M buffer memory
               3367 M swap cache
               4096 M total swap
                  0 M used swap
               4095 M free swap
      top - 08:38:55 up 27 days, 21:11,  2 users,  load average: 0.10, 0.18, 0.17
      Tasks:  57 total,   1 running,  56 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   8192.0 total,   2394.2 free,   2430.1 used,   3367.9 buff/cache
      MiB Swap:   4096.0 total,   4096.0 free,      0.0 used.   5761.9 avail Mem
      *** FAILED SERVICES ***
        UNIT                                 LOAD   ACTIVE SUB    DESCRIPTION
      * run-rpc_pipefs.mount                 loaded failed failed RPC Pipe File System
      * sys-kernel-config.mount              loaded failed failed Kernel Configuration File System
      * certbot.service                      loaded failed failed Certbot
      * systemd-networkd-wait-online.service loaded failed failed Wait for Network to be Configured
      4 loaded units listed.
      *** FILESYSTEM ***
      Filesystem                       Type      Size  Used Avail Use% Mounted on
      /dev/mapper/pve-vm--100--disk--1 ext4       15G   10G  4.0G  72% /
      none                             tmpfs     492K  4.0K  488K   1% /dev
      /dev/mapper/pve-root             ext4       96G   58G   34G  63% /dev/ttyACM0
      udev                             devtmpfs   32G     0   32G   0% /dev/tty
      tmpfs                            tmpfs      32G     0   32G   0% /dev/shm
      tmpfs                            tmpfs      13G  120K   13G   1% /run
      tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
      dmesg: read kernel buffer failed: Operation not permitted
      Show mounted filesystems:
      TARGET         SOURCE                                                 FSTYPE OPTIONS
      /              /dev/mapper/pve-vm--100--disk--1                       ext4   rw,relatime,stripe=16
      `-/dev/ttyACM0 /dev/mapper/pve-root[/var/lib/lxc/100/devices/ttyACM0] ext4   rw,relatime,errors=remount-ro
      /var:
      636M	/var/
      528M	/var/lib
      275M	/var/lib/redis
      143M	/var/lib/apt/lists
      143M	/var/lib/apt
      Archived and active journals take up 8.0M in the file system.
      /opt/iobroker/backups:
      1.3G	/opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      74M	/opt/iobroker/iobroker-data/
      73M	/opt/iobroker/iobroker-data/node-red
      72M	/opt/iobroker/iobroker-data/node-red/node_modules
      9.8M	/opt/iobroker/iobroker-data/node-red/node_modules/node-red-node-email
      9.7M	/opt/iobroker/iobroker-data/node-red/node_modules/node-red-node-email/node_modules
      2.0M	/opt/iobroker/iobroker-data/node-red/node_modules/node-red-dashboard/dist/js/app.min.js
      620K	/opt/iobroker/iobroker-data/node-red/node_modules/moment/min/moment-with-locales.js
      616K	/opt/iobroker/iobroker-data/node-red/node_modules/node-red-dashboard/dist/css/app.min.css
      552K	/opt/iobroker/iobroker-data/backitup/backitup.0.log
      544K	/opt/iobroker/iobroker-data/node-red/node_modules/node-red-node-email/node_modules/imap/deps/encoding/encoding-indexes.js
      USB-Devices by-id:
      /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2432650-if00
      *** NodeJS-Installation ***
      /usr/bin/nodejs 	v20.18.0
      /usr/bin/node 		v20.18.0
      /usr/bin/npm 		10.8.2
      /usr/bin/npx 		10.8.2
      /usr/bin/corepack 	0.29.3
      nodejs:
        Installed: 20.18.0-1nodesource1
        Candidate: 20.18.0-1nodesource1
        Version table:
       *** 20.18.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
              100 /var/lib/dpkg/status
           20.17.0-1nodesource1 1001
           20.16.0-1nodesource1 1001
           20.15.1-1nodesource1 1001
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           18.19.0+dfsg-6~deb12u2 500
              500 http://deb.debian.org/debian bookworm/main amd64 Packages
           18.19.0+dfsg-6~deb12u1 500
              500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      At least one iobroker host is running.
      Objects type: redis
      States  type: redis
      Core adapters versions
      js-controller: 	6.0.11
      admin: 		7.1.5
      javascript: 	8.8.3
      nodejs modules from github: 	1
      +-- iobroker.bmw@2.8.0 (git+ssh://git@github.com/TA2k/ioBroker.bmw.git#a490aabba5709c560626c225ee3a66d4bb97049f)
      Adapter State
      + system.adapter.accuweather.0            : accuweather           : iobroker                                 -  enabled
      + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
      + system.adapter.bmw.0                    : bmw                   : iobroker                                 -  enabled
        system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
      + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
      + system.adapter.lovelace.0               : lovelace              : iobroker                                 -  enabled, port: 8091, bind: 0.0.0.0, run as: admin
      + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 10.0.1.11
      + system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
      + system.adapter.nut.0                    : nut                   : iobroker                                 -  enabled
      + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
      + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
      + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.tibberlink.0             : tibberlink            : iobroker                                 -  enabled
      + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.yahka.0                  : yahka                 : iobroker                                 -  enabled
      + system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : iobroker                                 -  enabled
      + instance is alive
      ioBroker-Repositories
      │ (index) │ name               │ url                                                     │ auto upgrade │
      │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
      │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
      Upgrade policy: none
      Installed ioBroker-Instances
      Cannot download repository hash file from "http://download.iobroker.net/sources-dist-hash.json":
      Adapter    "accuweather"  : 1.5.0    , installed 1.5.0
      Adapter    "admin"        : 7.1.5    , installed 7.1.5
      Adapter    "backitup"     : 3.0.25   , installed 3.0.25
      Adapter    "ical"         : 1.15.0   , installed 1.15.0
      Adapter    "javascript"   : 8.8.3    , installed 8.8.3
      Controller "js-controller": 6.0.11   , installed 6.0.11
      Adapter    "lovelace"     : 4.1.10   , installed 4.1.10
      Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
      Adapter    "node-red"     : 5.2.1    , installed 5.2.1
      Adapter    "nut"          : 1.6.0    , installed 1.6.0
      Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
      Adapter    "pushover"     : 4.1.0    , installed 4.1.0
      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
      Adapter    "tibberlink"   : 3.4.10   , installed 3.4.10
      Adapter    "ws"           : 2.6.2    , installed 2.6.2
      Adapter    "yahka"        : 1.0.3    , installed 1.0.3
      Adapter    "zigbee2mqtt"  : 2.13.10  , installed 2.13.10
      Objects and States
      Objects: 	4202
      States: 	4244
      Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
      Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:42871         0.0.0.0:*               LISTEN      1000       85894076   38917/io.yahka.0
      tcp        0      0 10.0.1.11:8080          0.0.0.0:*               LISTEN      1001       85895517   39153/node
      tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          39521      830/nginx: master p
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          34219      1/init
      tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      0          39523      830/nginx: master p
      tcp        0      0 127.0.0.1:45901         0.0.0.0:*               LISTEN      1000       85894080   38917/io.yahka.0
      tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1000       85891832   38728/node-red
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       85891909   38796/io.zigbee2mqt
      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          35794      826/master
      tcp        0      0 127.0.0.1:39439         0.0.0.0:*               LISTEN      1000       85894084   38917/io.yahka.0
      tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      107        24496      152/redis-server 12
      tcp6       0      0 ::1:6379                :::*                    LISTEN      107        24497      152/redis-server 12
      tcp6       0      0 :::39251                :::*                    LISTEN      1000       85896241   38917/io.yahka.0
      tcp6       0      0 :::40551                :::*                    LISTEN      1000       85896243   38917/io.yahka.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1000       85893568   38611/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1000       85896216   38902/io.web.0
      tcp6       0      0 :::8087                 :::*                    LISTEN      1000       85895323   38962/io.simple-api
      tcp6       0      0 :::8091                 :::*                    LISTEN      1000       85899279   38932/io.lovelace.0
      tcp6       0      0 :::80                   :::*                    LISTEN      0          39522      830/nginx: master p
      tcp6       0      0 :::111                  :::*                    LISTEN      0          34221      1/init
      tcp6       0      0 :::22                   :::*                    LISTEN      0          24429      1/init
      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          35795      826/master
      tcp6       0      0 :::45057                :::*                    LISTEN      1000       85896245   38917/io.yahka.0
      udp        0      0 10.0.1.11:54336         0.0.0.0:*                           1000       85891864   38728/node-red
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          34220      1/init
      udp        0      0 0.0.0.0:36864           0.0.0.0:*                           110        24475      98/avahi-daemon: ru
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           110        24473      98/avahi-daemon: ru
      udp6       0      0 :::111                  :::*                                0          34222      1/init
      udp6       0      0 :::5353                 :::*                                110        24474      98/avahi-daemon: ru
      udp6       0      0 :::43447                :::*                                110        24476      98/avahi-daemon: ru
      @Thomas-Braun Ist dir so etwas schon einmal untergekommen?
      Lieben Dank vorab!
      arteck Thomas Braun 2 Replies Last reply Reply Quote 0
        arteck Developer Most Active @lessthanmore last edited by arteck
        @lessthanmore sagte in npm Cache kann nicht geleert werden:
        dann machs richtig
        sudo -H -u iobroker npm cache clean --force
        die pakete liegen unnter User iobroker
          lessthanmore @arteck last edited by
          @arteck Vielen Dank!
            Thomas Braun Most Active @lessthanmore last edited by
            @lessthanmore sagte in [geloest] npm Cache kann nicht geleert werden:
            Nein, ich verwende gleich den passenden User. 😄
              lessthanmore @Thomas Braun last edited by
              @thomas-braun root? 😄
              • BananaJoe
                BananaJoe Most Active @lessthanmore last edited by BananaJoe
                @lessthanmore @arteck hatte dir folgendes geschrieben:
                sudo wechselt den Benutzer,
                -H wechselt/nutzt in das Home-Verzeichnis des Benutzers
                -u gibt an zu welchen Benutzer denn gewechselt werden soll
                iobroker => wir haben einen Gewinner!
                npm ... der Befehl der ausgeführt werden soll samt Parameter und Optionen
                Edit: ok, dem Smiley habe ich jetzt erst bewusst gesehen, sorry für die Belehrung. Vielleicht kann der nächste was damit anfangen
