    4. Installation
    5. IOBROKER Neu Installation ...kein Zugriff / Fehler
    • G
      Grisu73 last edited by Homoran
      Hallo zusammen ! Ich habe eben einen Raspi neu installiert, Raspi OS 64 Bit, Lite Version , Verbindung über SSH funktioniert einwanderfrei !!
      Danach habe ich Update & Upgrade gefahren !
      Danach den Iobroker mit Befehl : curl -sSLf https://iobroker.net/install.sh | bash -
      installiert ...lief auch tadelolos durch....
      danach hatte ich keinen Zugriff unter meiner IP und Port 8081und der Status sagt mir :
      ASP@raspberrypi:~ $ iobroker status
      node:internal/modules/package_json_reader:93
              throw error;
      SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.js-controller/package.json: Unexpected end of JSON input
          at parse (<anonymous>)
          at read (node:internal/modules/package_json_reader:80:16)
          at readPackage (node:internal/modules/package_json_reader:141:10)
          at readPackageScope (node:internal/modules/package_json_reader:164:19)
          at shouldUseESMLoader (node:internal/modules/run_main:81:15)
          at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:161:24)
          at node:internal/main/run_main_module:28:49 {
        path: '/opt/iobroker/node_modules/iobroker.js-controller/package.json'
      Node.js v20.18.0
        Homoran Global Moderator Administrators @Grisu73 last edited by
        @grisu73 bitte die Langfassung von iob diag
          Thomas Braun Most Active @Grisu73 last edited by
          @grisu73
          Dann installier es nochmal.
          • G
            Grisu73 @Homoran last edited by
            			v.2024-08-12
             Static hostname: raspberrypi
                   Icon name: computer
                      Kernel: Linux 6.6.31+rpt-rpi-v8
                Architecture: arm64
            Installation: 		native
            Kernel: 		aarch64
            Userland: 		64 bit
            Timezone: 		Europe/Berlin (CEST, +0200)
            User-ID: 		1000
            Display-Server: 	false
            Boot Target: 		multi-user.target
            Pending OS-Updates: 	0
            node:internal/modules/cjs/loader:1228
              throw err;
                at Module._resolveFilename (node:internal/modules/cjs/loader:1225:15)
                at Module._load (node:internal/modules/cjs/loader:1051:27)
                at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:174:12)
              code: 'MODULE_NOT_FOUND',
              requireStack: []
            Node.js v20.18.0
            Pending iob updates: 	0
            Nodejs-Installation:
            /usr/bin/nodejs 	v20.18.0
            /usr/bin/node 		v20.18.0
            /usr/bin/npm 		10.8.2
            /usr/bin/npx 		10.8.2
            /usr/bin/corepack 	0.29.3
            MEMORY:
            Mem:            951M        171M        359M        204K        479M        780M
            Swap:           209M         10M        199M
            Total:          1.2G        181M        558M
            Active iob-Instances: 	0
              throw err;
              requireStack: []
            Node.js v20.18.0
              throw err;
              requireStack: []
            Node.js v20.18.0
            ioBroker Core: 		js-controller
              throw err;
              requireStack: []
            Node.js v20.18.0
            			admin
              throw err;
              requireStack: []
            Node.js v20.18.0
            ioBroker Status:
            Objects: 		0
            States: 		0
            Size of iob-Database:
            16K	/opt/iobroker/iobroker-data/objects.jsonl
            16K	/opt/iobroker/iobroker-data/states.jsonl
            === Mark text until here for copying ===
            Hatte grad nochmal neu installiert ....gleiche Ergebniss
            Ro75 Thomas Braun 2 Replies Last reply Reply Quote 0
            • Ro75
              Ro75 @Grisu73 last edited by
              @grisu73 1GB RAM? Das ist etwas wenig. Mal mit einer frischen SD-Karte versucht?
              Ro75.
                @grisu73 sagte in IOBROKER Neu Installation ...kein Zugriff / Fehler:
                Möglich, dass 1GB RAM schlicht und einfach mittlerweile zu wenig ist.
                Für fluffigen Betrieb ist es das ohnehin schon.
                • G
                  Grisu73 @Thomas Braun last edited by
                  @thomas-braun ok...verstehe ich ja...aber folgene Beobachtungen :
                  1. ...der iobroker lief vorher 18 Monate tadellos auf der Machine....
                  2. ...die Installation wurde abgeschlossen ...
                  3. ...versuche ich dann im Browser ip :8081 auf zu rufen...passiert nichts...kein Zugriff...
                  • G
                    Grisu73 @Ro75 last edited by
                    @ro75 Auf dem Raspi lief der Iobroker unter einer anderen Verwendung 18 Monate...ja hier und da langsam ...aber ohne Probleme....
                    Jetzt neue SD Karte 32 GB, Raspi OS Neu...Iobroker ohne Fehler installiert neu....
                    kein Zugriff....
                    Ro75 Homoran 2 Replies Last reply Reply Quote 0
                    • Codierknecht
                      Codierknecht Developer Most Active @Grisu73 last edited by
                      Kann ja auch nicht:
                      Du kannst nochmal eine Neuinstallation versuchen, aber bei der kleinen Kiste habe ich da wenig Hoffnung.
                      Aber vermutlich auf einem uralten Unterbau.
                      • Ro75
                        und warum eine Neuinstallation?
                        Ro75.
                          was ist das denn für ein Raspi?
                          möglich dass
                          Userland: 64 bit
                          nicht passt.
                          605
