    4. Homeconnect keine Verbindung mehr
      TimoWald last edited by
      Hallo kann mir nochmal jemand einen Tip geben?
      Der Homeconnect Adapter wird nicht mehr grün. Es kommt folgende Fehlermeldung:
      2024-10-19 10:53:49.436 - info: admin.0 (405) <== Disconnect system.user.admin from ::ffff:192.168.9.50
      2024-10-19 10:53:54.704 - error: homeconnect.0 (92683) AxiosError: Request failed with status code 400
      2024-10-19 10:53:54.705 - error: homeconnect.0 (92683) Please check username and password or visit this site for manually login:
      2024-10-19 10:53:54.705 - error: homeconnect.0 (92683) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
      2024-10-19 10:53:54.705 - error: homeconnect.0 (92683) https://api.home-connect.com/security/oauth/device_verify?user_code=YMB1-GUK0
      2024-10-19 10:53:54.706 - error: homeconnect.0 (92683) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
      2024-10-19 10:53:54.706 - info: homeconnect.0 (92683) Wait 10 seconds to retry
      2024-10-19 10:54:04.318 - info: host.iobroker "system.adapter.homeconnect.0" disabled
      2024-10-19 10:54:04.319 - info: host.iobroker stopInstance system.adapter.homeconnect.0 (force=false, process=true)
      2024-10-19 10:54:04.324 - info: homeconnect.0 (92683) Got terminate signal TERMINATE_YOURSELF
      2024-10-19 10:54:04.325 - info: homeconnect.0 (92683) terminating
      2024-10-19 10:54:04.326 - debug: homeconnect.0 (92683) Plugin sentry destroyed
      2024-10-19 10:54:04.326 - info: homeconnect.0 (92683) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2024-10-19 10:54:04.362 - info: host.iobroker stopInstance system.adapter.homeconnect.0 send kill signal
      2024-10-19 10:54:04.815 - error: homeconnect.0 (92683) AxiosError: Request failed with status code 400
      2024-10-19 10:54:04.815 - error: homeconnect.0 (92683) Please check username and password or visit this site for manually login:
      2024-10-19 10:54:04.815 - error: homeconnect.0 (92683) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
      2024-10-19 10:54:04.815 - error: homeconnect.0 (92683) https://api.home-connect.com/security/oauth/device_verify?user_code=YMB1-GUK0
      2024-10-19 10:54:04.816 - error: homeconnect.0 (92683) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
      2024-10-19 10:54:04.816 - info: homeconnect.0 (92683) Wait 10 seconds to retry
      2024-10-19 10:54:04.828 - info: homeconnect.0 (92683) terminating
      2024-10-19 10:54:04.955 - info: host.iobroker instance system.adapter.homeconnect.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      Wäre euch sehr Dankbar.
      Ro75 1 Reply Last reply Reply Quote 0
      • Ro75
        Ro75 @TimoWald last edited by
        @timowald sagte in Homeconnect keine Verbindung mehr:
        Die Seite im Browser aufrufen und entsprechend ausfüllen und bestätigen. ACHTUNG: Unter Umständen ist es notwendig, den Browser zuvor auf "englisch" als Sprache umzustellen.
        Ro75.
          TimoWald @Ro75 last edited by
          @ro75 Ok, jetzt ist er grün aber es kommen wieder mal keine Daten.
          • Ro75
            @timowald Wenn du das Forum beobachtest, wirst du sehen, dass es im Moment bei denen zu "Wartungsarbeiten" kommt und die Dienste nicht online sind.
            Ro75.
            T 2 Replies Last reply Reply Quote 0
              @ro75 OK, vielen Dank.... Dann warte ich mal ab.
                TimoWald @Ro75 last edited by TimoWald
                @ro75 Hallo jetzt kommt folgende Fehlermeldung. Kann mir noch einer einen Rat geben?
                2024-10-20 19:44:46.949 - error: homeconnect.0 (126304) Start Event Stream Error: {"type":"error","status":503,"message":"Service Unavailable"}
                2024-10-20 19:44:46.949 - error: homeconnect.0 (126304) Error: 503
                2024-10-20 19:44:46.949 - error: homeconnect.0 (126304) Error: {"type":"error","status":503,"message":"Service Unavailable"}
                2024-10-20 19:44:46.949 - error: homeconnect.0 (126304) Homeconnect API are not available please try again later
                2024-10-20 19:44:46.949 - debug: homeconnect.0 (126304) EventSource error: {"type":"error"}
                2024-10-20 19:44:46.949 - debug: homeconnect.0 (126304) Undefined Error from Homeconnect this happens sometimes.
                2024-10-20 19:44:47.996 - error: homeconnect.0 (126304) 503 Service Temporarily Unavailable
                2024-10-20 19:44:47.996 - error: homeconnect.0 (126304) Start Event Stream Error: {"type":"error","status":503,"message":"Service Temporarily Unavailable"}
                2024-10-20 19:44:47.997 - error: homeconnect.0 (126304) Error: 503
                2024-10-20 19:44:47.997 - error: homeconnect.0 (126304) Error: {"type":"error","status":503,"message":"Service Temporarily Unavailable"}
                2024-10-20 19:44:47.997 - error: homeconnect.0 (126304) Homeconnect API are not available please try again later
                2024-10-20 19:44:47.997 - debug: homeconnect.0 (126304) EventSource error: {"type":"error"}
                2024-10-20 19:44:47.997 - debug: homeconnect.0 (126304) Undefined Error from Homeconnect this happens sometimes.
                2024-10-20 19:44:49.043 - error: homeconnect.0 (126304) 503 Service Temporarily Unavailable
                2024-10-20 19:44:49.043 - error: homeconnect.0 (126304) Start Event Stream Error: {"type":"error","status":503,"message":"Service Temporarily Unavailable"}
                2024-10-20 19:44:49.043 - error: homeconnect.0 (126304) Error: 503
                2024-10-20 19:44:49.044 - error: homeconnect.0 (126304) Error: {"type":"error","status":503,"message":"Service Temporarily Unavailable"}
                2024-10-20 19:44:49.044 - error: homeconnect.0 (126304) Homeconnect API are not available please try again later
                2024-10-20 19:44:49.044 - debug: homeconnect.0 (126304) EventSource error: {"type":"error"}
                2024-10-20 19:44:49.044 - debug: homeconnect.0 (126304) Undefined Error from Homeconnect this happens sometimes.
                2024-10-20 19:44:50.091 - error: homeconnect.0 (126304) 503 Service Temporarily Unavailable
                2024-10-20 19:44:50.091 - error: homeconnect.0 (126304) Start Event Stream Error: {"type":"error","status":503,"message":"Service Temporarily Unavailable"}
                2024-10-20 19:44:50.091 - error: homeconnect.0 (126304) Error: 503
                2024-10-20 19:44:50.091 - error: homeconnect.0 (126304) Error: {"type":"error","status":503,"message":"Service Temporarily Unavailable"}
                2024-10-20 19:44:50.091 - error: homeconnect.0 (126304) Homeconnect API are not available please try again later
                2024-10-20 19:44:50.091 - debug: homeconnect.0 (126304) EventSource error: {"type":"error"}
                2024-10-20 19:44:50.092 - debug: homeconnect.0 (126304) Undefined Error from Homeconnect this happens sometimes.
                2024-10-20 19:44:51.138 - error: homeconnect.0 (126304) 503 Service Temporarily Unavailable
                2024-10-20 19:44:51.138 - error: homeconnect.0 (126304) Start Event Stream Error: {"type":"error","status":503,"message":"Service Temporarily Unavailable"}
                2024-10-20 19:44:51.138 - error: homeconnect.0 (126304) Error: 503
                2024-10-20 19:44:51.138 - error: homeconnect.0 (126304) Error: {"type":"error","status":503,"message":"Service Temporarily Unavailable"}
                2024-10-20 19:44:51.138 - error: homeconnect.0 (126304) Homeconnect API are not available please try again later
                2024-10-20 19:44:51.139 - debug: homeconnect.0 (126304) EventSource error: {"type":"error"}
                2024-10-20 19:44:51.139 - debug: homeconnect.0 (126304) Undefined Error from Homeconnect this happens sometimes.
                2024-10-20 19:44:52.185 - error: homeconnect.0 (126304) 503 Service Temporarily Unavailable
                2024-10-20 19:44:52.185 - error: homeconnect.0 (126304) Start Event Stream Error: {"type":"error","status":503,"message":"Service Temporarily Unavailable"}
                2024-10-20 19:44:52.185 - error: homeconnect.0 (126304) Error: 503
                2024-10-20 19:44:52.185 - error: homeconnect.0 (126304) Error: {"type":"error","status":503,"message":"Service Temporarily Unavailable"}
                2024-10-20 19:44:52.185 - error: homeconnect.0 (126304) Homeconnect API are not available please try again later
                2024-10-20 19:44:52.185 - debug: homeconnect.0 (126304) EventSource error: {"type":"error"}
                2024-10-20 19:44:52.186 - debug: homeconnect.0 (126304) Undefined Error from Homeconnect this happens sometimes.
                2024-10-20 19:44:53.231 - error: homeconnect.0 (126304) 503 Service Temporarily Unavailable
                2024-10-20 19:44:53.232 - error: homeconnect.0 (126304) Start Event Stream Error: {"type":"error","status":503,"message":"Service Temporarily Unavailable"}
                2024-10-20 19:44:53.232 - error: homeconnect.0 (126304) Error: 503
                2024-10-20 19:44:53.232 - error: homeconnect.0 (126304) Error: {"type":"error","status":503,"message":"Service Temporarily Unavailable"}
                2024-10-20 19:44:53.232 - error: homeconnect.0 (126304) Homeconnect API are not available please try again later
                2024-10-20 19:44:53.233 - debug: homeconnect.0 (126304) EventSource error: {"type":"error"}
                2024-10-20 19:44:53.233 - debug: homeconnect.0 (126304) Undefined Error from Homeconnect this happens sometimes.
                2024-10-20 19:44:54.278 - error: homeconnect.0 (126304) 503 Service Temporarily Unavailable
                2024-10-20 19:44:54.278 - error: homeconnect.0 (126304) Start Event Stream Error: {"type":"error","status":503,"message":"Service Temporarily Unavailable"}
                2024-10-20 19:44:54.278 - error: homeconnect.0 (126304) Error: 503
                2024-10-20 19:44:54.279 - error: homeconnect.0 (126304) Error: {"type":"error","status":503,"message":"Service Temporarily Unavailable"}
                2024-10-20 19:44:54.279 - error: homeconnect.0 (126304) Homeconnect API are not available please try again later
                2024-10-20 19:44:54.279 - debug: homeconnect.0 (126304) EventSource error: {"type":"error"}
                2024-10-20 19:44:54.279 - debug: homeconnect.0 (126304) Undefined Error from Homeconnect this happens sometimes.
                  Matt77CHE last edited by
                  Homeconnect ist wieder online
                    Sonnenkind last edited by
                    Hallo Leute
                    ich häng mich mal hier an, hab einen account erstellt wie im Adapter beschrieben, dann eine api erhalten und diese in den Adapter eingefügt mit den li Daten von der HC App fürs Handy, leider bleibt die Instanz gelb und verbindet sich nicht
                    im log steht dann :
                    Die App und der Zugriff über Handy geht?
                    Hat wer ne Idee oder stelle ich mich zu doof an irgendwo ?
                    Danke Euch
                    No verification_uri_complete in device_authorization
                    Please check your clientID or wait 15 minutes until it is active
                    "error":"unauthorized_client","error_description":"client not authorized for this oauth
                      autom last edited by
                      habe ein ähnlich gelagertes Problem, seit dem ich mein Raspberry neu aufgesetzt habe, läuft mein Home-Connect-Adapter nicht mehr.
                      Fehlermeldungen: "No verification_uri_complete in device_authorization"
                      "Illegal query: Invalid input ' ', expected part, '&' or 'EOI' (line 1, column 11): client_id= 6ECBE62D38337CF1C245FF3EE57BD4833B42E4C8D0DA17B7BFD1D4E1F3334296&scope=IdentifyAppliance%20Monitor%20Settings%20Control\n ^" und
                      "AxiosError: Request failed with status code 400"
                      ich habe die client_id mehrfach neu gemacht, immer mit dem gleichen Ergebnis
                      hat vielleicht einer eine Idee was ich falsch mache?
                      schon mal Danke im Voraus
                      • Ro75
                        Ro75 @autom last edited by
                        @autom was für ein Gerät? Was kommt im Log? Was hast du wie und wo konfiguriert?
                        Ro75
                        983
