    4. Update Fehler - ENOTEMPTY
      Belei last edited by
      Moin,
      ich hab jetzt einige Zeit mein iobroker nicht mehr upgedatet, ca seit Anfang des Jahres.
      Jetzt wollt ich mal paar Updates fahren aber es hagelt bei alles Adapter Updates, folgende Fehler.
      root@ioBrokerNuc:~# iob upgrade self --allow-root
      Update js-controller from @5.0.17 to @6.0.11
      Stopped Objects DB
      Stopped States DB
      NPM version: 10.2.3
      Installing iobroker.js-controller@6.0.11... (System call)
      Try to solve ENOTEMPTY error automatically
      host.ioBrokerNuc deleted npm temp directory: ".diskusage-SbL2R1mm")
      npm ERR! code ENOTEMPTY
      npm ERR! syscall rename
      npm ERR! path /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket
      npm ERR! dest /opt/iobroker/node_modules/@abandonware/.bluetooth-hci-socket-0H6suKAo
      npm ERR! errno -39
      npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket' -> '/opt/iobroker/node_modules/@abandonware/.bluetooth-hci-socket-0H6suKAo'
      npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-10-24T19_07_16_614Z-debug-0.log
      host.ioBrokerNuc Cannot install iobroker.js-controller@6.0.11: 217
      Ich 2x den iob fix durchlaufen lassen, erstmal ohne neuen User und weiterhin mit GUDesktop.
      Aber leider ohne Erfolg.
      Adapter    "admin"        : 7.1.5    , installed 6.12.0 [Updatable]
      Adapter    "alexa2"       : 3.26.5   , installed 3.26.4 [Updatable]
      Adapter    "amazon-dash"  : 1.2.0    , installed 1.2.0
      Adapter    "backitup"     : 3.0.25   , installed 2.9.8  [Updatable]
      Adapter    "ble"          : 0.14.0   , installed 0.13.4 [Updatable]
      Adapter    "cloud"        : 5.0.1    , installed 4.4.1  [Updatable]
      Adapter    "discovery"    : 5.0.0    , installed 4.2.0  [Updatable]
      Adapter    "fb-checkpresence": 1.2.5 , installed 1.2.2  [Updatable]
      Adapter    "feiertage"    : 1.2.0    , installed 1.1.4  [Updatable]
      Adapter    "fhem"         : 3.0.0    , installed 2.0.5  [Updatable]
      Adapter    "fritzdect"    : 2.5.11   , installed 2.5.9  [Updatable]
      Adapter    "hm-rega"      : 5.1.0    , installed 4.0.0  [Updatable]
      Adapter    "hm-rpc"       : 2.0.2    , installed 1.16.0 [Updatable]
      Adapter    "hue"          : 3.12.0   , installed 3.10.1 [Updatable]
      Adapter    "iot"          : 3.3.0    , installed 2.0.11 [Updatable]
      Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
      Adapter    "javascript"   : 8.8.3    , installed 7.1.6  [Updatable]
      Controller "js-controller": 6.0.11   , installed 5.0.17 [Updatable]
      Adapter    "lovelace"     : 4.1.10   , installed 3.0.1  [Updatable]
      Adapter    "mihome-vacuum": 4.2.0    , installed 4.1.0  [Updatable]
      Adapter    "mobile"       : 1.0.1    , installed 1.0.1
      Adapter    "pushover"     : 4.1.0    , installed 3.0.6  [Updatable]
      Adapter    "rflink"       : 2.1.12   , installed 2.1.6  [Updatable]
      Adapter    "scenes"       : 3.2.3    , installed 2.3.9  [Updatable]
      Adapter    "shelly"       : 8.2.1    , installed 6.6.1  [Updatable]
      Adapter    "simple-api"   : 2.8.0    , installed 2.7.2  [Updatable]
      Adapter    "socketio"     : 6.7.1    , installed 6.6.0  [Updatable]
      Adapter    "tr-064"       : 4.3.0    , installed 4.2.18 [Updatable]
      Adapter    "vis"          : 1.5.6    , installed 1.5.4  [Updatable]
      Adapter    "weatherunderground": 3.7.0, installed 3.6.0 [Updatable]
      Adapter    "web"          : 6.2.5    , installed 6.1.10 [Updatable]
      Adapter    "weishaupt-wem": 0.0.15   , installed 0.0.15
      Adapter    "ws"           : 2.6.2    , installed 2.5.8  [Updatable]
      Adapter    "zigbee"       : 1.10.3   , installed 1.9.7  [Updatable]
                              v.2024-10-19
         Static hostname: ioBrokerNuc
               Icon name: computer-vm
                 Chassis: vm
          Virtualization: kvm
        Operating System: Debian GNU/Linux 10 (buster)
                  Kernel: Linux 4.19.0-25-amd64
            Architecture: x86-64
      Installation:           kvm
      User-ID:                0
      Display-Server:         false
      Pending OS-Updates:     74
      Pending iob updates:    0
      Nodejs-Installation:
      /usr/bin/nodejs         v18.19.0
      /usr/bin/node           v18.19.0
      /usr/bin/npm            10.2.3
      /usr/bin/npx            10.2.3
      Recommended versions are nodejs
      ***For security reasons ioBroker should not be run or administrated as root.***
      By default only a user that is member of iobroker group can execute ioBroker commands.
      Please read the Documentation on how to set up such a user, if not done yet.
      Only in very special cases you can run iobroker commands by adding the --allow-root option at the end of the command line.
      Please note that this option may be disabled in the future, so please change your setup accordingly now. and npm
      nodeJS installation is correct
      MEMORY:
      Mem:           2.0G         82M        1.5G        0.0K        451M        1.8G
      Swap:          2.0G         47M        2.0G
      Total:         4.0G        129M        3.5G
      Active iob-Instances:   0
      ioBroker Core:          js-controller
                              admin
      ioBroker Status:
      Objects:                6
      States:                 6
      Size of iob-Database:
      16M     /opt/iobroker/iobroker-data/objects.jsonl
      108K    /opt/iobroker/iobroker-data/objects.json.migrated
      68K     /opt/iobroker/iobroker-data/objects.json.bak.migrated
      8.0K    /opt/iobroker/iobroker-data/states.json.bak
      Some problems detected, please run iob fix and try to have them fixed
      2 CRITICAL ERRORS DETECTED!
      Check 'sudo dmesg --level=emerg,alert,crit -T' for details
      Debian Release codenamed 'buster' reached its END OF LIFE and needs to be updated to the latest stable release 'bookworm' NOW!
      Kann jmd helfen?
        Thomas Braun Most Active @Belei last edited by
        @belei sagte in Update Fehler - ENOTEMPTY:
        Zu alt.
        Du hampelst als root herum.
          Belei @Thomas Braun last edited by Belei
          Danke erstmal für deine Reaktion.
          Dann muss ich wohl als User? erst auf Bullseye updaten dann auf Bookworm, denk ich?
          Hast du einen Link wo das sicher beschrieben wird?
            Thomas Braun Most Active @Belei last edited by Thomas Braun
            @belei
            Installier es neu. Geht am schnellsten. Und dann gleich ohne graphische Umgebung.
              @belei
              Durch die Neuinstallation merzt du vermutlich auch die beiden kritischen Fehler aus:
                heut nicht mehr 🙂 Ich mach morgen weiter. Danke erstmal.
