    4. Installation
    5. Iobroker auf proxmox funktioniert nicht
      Jan201 last edited by Jan201
      Hallo, nachdem mein System neu installieren möchte auf einer neuen Proxmox installation, funktioniert dies nicht. ich gehe nach folgender anleitung nach: https://www.iobroker.net/#de/documentation/install/proxmox.md .
      Ich bekomme nach apt uptdate && apt upgrade folgende fehler :
      root
      Password:
      Linux iobroker 6.8.4-2-pve #1 SMP PREEMPT_DYNAMIC PMX 6.8.4-2 (2024-04-10T17:36Z) x86_64
      The programs included with the Debian GNU/Linux system are free software;
      the exact distribution terms for each program are described in the
      individual files in /usr/share/doc/*/copyright.
      Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
      permitted by applicable law.
      Last login: Wed Oct 30 20:19:16 CET 2024 on tty1
      root@iobroker:~# apt update && apt upgrade
      Err:1 http://security.debian.org bullseye-security InRelease
        Temporary failure resolving 'security.debian.org'
      Err:2 http://deb.debian.org/debian bullseye InRelease
        Temporary failure resolving 'deb.debian.org'
      Err:3 http://deb.debian.org/debian bullseye-updates InRelease
      Reading package lists... Done
      Building dependency tree... Done
      All packages are up to date.
      W: Failed to fetch http://deb.debian.org/debian/dists/bullseye/InRelease  Temporary failure resolving 'deb.debian.org'
      W: Failed to fetch http://deb.debian.org/debian/dists/bullseye-updates/InRelease  Temporary failure resolving 'deb.debian.org'
      W: Failed to fetch http://security.debian.org/dists/bullseye-security/InRelease  Temporary failure resolving 'security.debian.org'
      W: Some index files failed to download. They have been ignored, or old ones used instead.
      Calculating upgrade... Done
      0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
      System ist ein nuc mit Debian 11.0
      kann mir jemand sagen woran es liegen kann?
      Thomas Braun Codierknecht 2 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @Jan201 last edited by
        @jan201 sagte in Iobroker auf proxmox funktioniert nicht:
        Dein Netzwerk ist falsch aufgesetzt, scheint mir.
        Und im Container hüpft man nicht als root herum.
        Und das aktuelle Release ist Debian 12 'Bookworm'.
        • Codierknecht
          Codierknecht Developer Most Active @Jan201 last edited by
          Wie @Thomas-Braun schon schreibt:
          Du hast ein Problem mit der DNS-Auflösung.
          Bei mir ist das bei neuen Maschinen Standard, da in meinem Netz neue Geräte erstmal keinen Zugang zum Internet erhalten. Hast Du ein ähnliches Setup?
          Kommst Du aus anderen Container dahin?
          Ansonsten gilt das was Thomas sagt: Kein root, OS aktualisieren. Bullseye hat EOL erreicht.
            Shadowhunter23 @Thomas Braun last edited by
            @thomas-braun sagte in Iobroker auf proxmox funktioniert nicht:
            Kannst du das im Text in der Anleitung ändern auf Debian 12?
            Thomas Braun crunchip 2 Replies Last reply Reply Quote 0
              Thomas Braun Most Active @Shadowhunter23 last edited by
              @shadowhunter23 Ich könnte da genauso wie du einen PR stellen.
                Jan201 @Codierknecht last edited by
                @codierknecht said in Iobroker auf proxmox funktioniert nicht:
                Und wie löse ich das Problem? ich habe an meinem Netzwerk nichts verändert.
                Das Problem ist auch unter Debian 12 vorhanden.
                Wenn nicht als root, was dann? In der Anleitung steht : " Hier loggt man sich zunächst als root mit dem zuvor vergebenen Passwort, welches beim LXC erstellen vergeben wurde, ein und bringt diesen erst einmal auf einen aktuellen Stand."
                  Geht das nur so? Hat da niemand Rechte das direkt zu ändern?
                    @shadowhunter23 Die PRs sind dann dokumentiert. Dann kannste nachvollziehen wessen Geistesblitz da wann eingeflossen ist.
                      Alles klar. Das schaue ich mir an wie das geht und versuche mein Glück.
                        @shadowhunter23 Dann kannste auch gleich die Anlage eines users vorziehen.
                        Ist imho die erste und einzige Aktion als root in einem frischen Container.
                        • crunchip
                          crunchip Forum Testing Most Active @Shadowhunter23 last edited by
                          @shadowhunter23 damals gab es noch kein Debian 12,
                          I kann es gerne im Text anpassen, Bebilderung jedoch kann ich nicht aktualisieren, da ich kein Proxmox mehr verwende
                            Thomas Braun Most Active @crunchip last edited by
                            @crunchip sagte in Iobroker auf proxmox funktioniert nicht:
                            Hab eben schon ein wenig geändert. PR liegt vor.
                            • Codierknecht
                              Codierknecht Developer Most Active @crunchip last edited by
                              @crunchip @Thomas-Braun
                              Braucht ihr noch Screenshots?
                              • crunchip
                                crunchip Forum Testing Most Active @Thomas Braun last edited by crunchip
                                PR liegt vor
                                Hab ich mir gerade mal angesehen, hast ein paar Sachen hinzugefügt 👍,allerdings den Part LXC (templates) , um den es hier eigentlich geht, vergessen anzupassen
                                  Hab ich mir gerade mal angesehen, hast ein paar Sachen hinzugefügt ,allerdings den Part LXC (templates) , um den es hier eigentlich geht, vergessen anzupassen
                                  Ich hab doch keine Aktien in LXCs... 🙂
                                    mading last edited by mading
                                    Hast du beim setup des Containers den DNS und Gateway eingetragen? Zeig mal einen Screenshot der Container Konfig.
                                    Bei mir:
                                    Kannst du zb web.de pingen von Container aus?
                                      Jan201 @mading last edited by
                                      @mading said in Iobroker auf proxmox funktioniert nicht:
                                      Bei mir:
                                      Also die Einstellungen sehen genauso aus. Aber er hat bekommt einfach kein kontakt zur Ausenwelt.
                                      Nein, mit pingen von Container kenne ich mich nicht aus.
                                      Meister Mopper Codierknecht crunchip 3 Replies Last reply Reply Quote 0
                                      • Meister Mopper
                                        Meister Mopper @Jan201 last edited by
                                        Welcher Router wird verwendet? Wie sind die Einstellungen? Kann der Knoten ins Internet auflösen?
                                        ping google.com
                                        • Codierknecht
                                          Nicht den Container pingen, sondern in der Konsole des Containers:
                                          ping web.de
                                            ping web.de
                                            Last login: Thu Oct 31 09:36:38 UTC 2024 on tty1
                                            root@ioborker:~# ping google.com
                                            ping: google.com: Temporary failure in name resolution
                                            root@ioborker:~# ping web.de
                                            ping: web.de: Temporary failure in name resolution
                                            root@ioborker:~#
                                            Unter ubuntu 23.10 funktioniert alles problemlos.
                                            1699
