    4. Installation
    5. Installation von IOB auf Raspi3
    • Flexer
      Flexer last edited by
      Hallo @Thomas-Braun
      ich bin deiner Anleitung gefolgt aber irgendwie bekomme ich den iob nicht auf den raspi.
      Ich soll Nodejs manuell installieren?
      flexer@iobroker:~ $ Linux iobroker 6.6.51+rpt-rpi-v8 #1 SMP PREEMPT Debian 1:6.6.51-1+rpt3 (2024-10-08) aarch64
      The programs included with the Debian GNU/Linux system are free software;
      the exact distribution terms for each program are described in the
      individual files in /usr/share/doc/*/copyright.
      Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
      permitted by applicable law.
      Last login: Fri Nov  1 11:33:02 2024 from 192.168.178.170
      flexer@iobroker:~ $ curl -sSLf https://iobroker.net/install.sh | bash -
      library: loaded
      Library version=2024-10-22
          Welcome to the ioBroker installer!
          Installer version: 2024-10-22
          You might need to enter your password a couple of times.
          Installing prerequisites (1/4)
      Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
      Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists... Error!
      E: Unable to parse package file /var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-updates_contrib_binary-arm64_Packages (1)
      E: Unable to parse package file /var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-updates_contrib_i18n_Translation-en (1)W: You may want to run apt-get update to correct these problems
      E: The package cache file is corrupted
          Node.js not found. Installing...
      deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_20.x nodistro main
      Package: nodejs
      Pin: origin deb.nodesource.com
      Pin-Priority: 1001
      Installed nodejs
      Cannot install Node.js! Please install it manually.
        Thomas Braun Most Active @Flexer last edited by
        @flexer sagte in Installation von IOB auf Raspi3:
        Nein.
        Da stimmt was grundsätzliches nicht mit apt/dpkg und deswegen kann der Installer keine weiteren Pakete wie z. B. nodejs installieren.
        Am besten nochmal ganz von vorne.
        Vor dem ioBroker-Installer bringt man die Kiste auf den letzten Stand:
        sudo apt update
        sudo apt full-upgrade
        sudo reboot
        Flexer 1 Reply Last reply Reply Quote 0
          Homoran Global Moderator Administrators @Flexer last edited by
          nein!
          ist der nagelneu oder ist da schon was drauf?
          • Flexer
            Flexer @Thomas Braun last edited by
            Schon bei sudo apt update schlägt es fehl. Ich mache mal die SD Karte nochmal neu und fange mal von vorne an
            flexer@iobroker:~ $ sudo apt update
            Hit:1 http://archive.raspberrypi.com/debian bookworm InRelease
            Hit:2 https://deb.nodesource.com/node_20.x nodistro InRelease
            Hit:3 http://deb.debian.org/debian bookworm InRelease
            Hit:4 http://deb.debian.org/debian-security bookworm-security InRelease
            Hit:5 http://deb.debian.org/debian bookworm-updates InRelease
            • Flexer
              Flexer @Homoran last edited by
              @homoran Hatte die SD Karte komplett frisch gemacht
              • Flexer
                Also ich habe das ganze jetzt mit einer zweiten neuen SD gemacht. Sobald ich
                sudo apt update && sudo apt full-upgrade mache kommt Reading package lists... Error
                Get:2 http://deb.debian.org/debian-security bookworm-security InRelease [48.0 kB]
                Get:3 http://deb.debian.org/debian bookworm-updates InRelease [55.4 kB]
                Get:4 http://archive.raspberrypi.com/debian bookworm InRelease [39.0 kB]
                Get:5 http://deb.debian.org/debian-security bookworm-security/main armhf Packages [187 kB]
                Get:6 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages [187 kB]
                Get:7 http://deb.debian.org/debian-security bookworm-security/main Translation-en [116 kB]
                Get:8 http://archive.raspberrypi.com/debian bookworm/main armhf Packages [531 kB]
                Get:9 http://archive.raspberrypi.com/debian bookworm/main arm64 Packages [501 kB]
                Fetched 1,665 kB in 3s (646 kB/s)
                  da ist wohl was bein download schief gelaufen.
                  mach die Befehle mal einzeln.
                    Thomas Braun Most Active @Flexer last edited by Thomas Braun
                    @flexer
                    Kann auch sein, das es im Moment bei Debian auf dem Server klemmt.
                    Leere mal den cache:
                    sudo apt clean
                    • Flexer
                      @thomas-braun Habe ich gemacht leider keine Besserung. Ich warte mal ab und versuche es im laufe des Tages nochmal. Vielleicht ist das Problem Serverseitig
                      • Flexer
                        Flexer @Homoran last edited by Flexer
                        Der sudo update teil schlägt fehl upgrade lief durch. Bei der installation von iob kommen aber wieder die fehler
                          Natürlich.
                          • Flexer
                            Hallo an alle. Heute habe ich es nochmal versucht und die Installation lief ohne Probleme durch. Thema kann geschlossen werden. Keine Ahnung woran es gelegen hat.
                            Viele Güße und danke für die schnellen Antworten
                            • Meister Mopper
                              Meister Mopper @Flexer last edited by
                              Wie @Thomas-Braun schon schrieb, manchmal sind es natürlich auch die Probleme am liefernden Server.
                              Das hatte ich heute morgen bei einer MariaDb-Instanz. Zwei Stunden später lief der Server wieder.
                              installation raspberrypi
                              564
