    2. Русский
    3. ioBroker
    4. Скрипты
    5. ioBroker скрипты
    6. Скрипт для счетчика Меркурий 230
      andrey99986 last edited by
      Адаптер:
      https://ru.aliexpress.com/item/1-pcs-US … 0.0.fzI5Kj
      createState('Uv1');
      createState('Uv2');
      createState('Uv3');
      createState('Ia1');
      createState('Ia2');
      createState('Ia3');
      createState('Pw_total');
      createState('Pw1');
      createState('Pw2');
      createState('Pw3');
      createState('E_total');
      createState('E_T1');
      createState('E_T2');
      var device_port = '/dev/ttyUSB0';
      var buflen = 64;
      var sleep_time = 200; // Sleep time between request and wait for response.
      var SerialPort = require('serialport');
      var ByteLength = SerialPort.parsers.ByteLength;
      var ret = Array();
      var cmd_init = new Buffer ([0x00,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x77,0x81]);
      var cmd_total = new Buffer ([0x00,0x05,0x00,0x00,0x10,0x25]); //общее потребление
      var cmd_T1 = new Buffer ([0x00,0x05,0x00,0x01,0xD1,0xE5]); //потребление T1
      var cmd_T2 = new Buffer ([0x00,0x05,0x00,0x02,0x91,0xE4]); //потребление T2
      var cmd_total_day = new Buffer ([0x00,0x05,0x40,0x00,0x21,0xE5]); //общее потребление за текщие сутки
      var cmd_T1_day = new Buffer ([0x00,0x05,0x40,0x01,0xE0,0x25]); //потребление T1 за текщие сутки
      var cmd_T2_day = new Buffer ([0x00,0x05,0x40,0x02,0xA0,0x24]); //потребление T2 за текщие сутки
      var cmd_pw = new Buffer ([0x00,0x08,0x16,0x00,0x8F,0x86]); //мощность по фазам
      var cmd_uv = new Buffer ([0x00,0x08,0x16,0x11,0x4F,0x8A]); //Напряжение по фазам
      var cmd_ia = new Buffer ([0x00,0x08,0x16,0x21,0x4F,0x9E]); //Сила тока по фазам
      var cmd_cos = new Buffer ([0x00,0x08,0x16,0x30,0x8F,0x92]); //Cosf по фазам
      function crc16MODBUS(string){
          var CrcTable = [
              0X0000, 0XC0C1, 0XC181, 0X0140, 0XC301, 0X03C0, 0X0280, 0XC241,
              0XC601, 0X06C0, 0X0780, 0XC741, 0X0500, 0XC5C1, 0XC481, 0X0440,
              0XCC01, 0X0CC0, 0X0D80, 0XCD41, 0X0F00, 0XCFC1, 0XCE81, 0X0E40,
              0X0A00, 0XCAC1, 0XCB81, 0X0B40, 0XC901, 0X09C0, 0X0880, 0XC841,
              0XD801, 0X18C0, 0X1980, 0XD941, 0X1B00, 0XDBC1, 0XDA81, 0X1A40,
              0X1E00, 0XDEC1, 0XDF81, 0X1F40, 0XDD01, 0X1DC0, 0X1C80, 0XDC41,
              0X1400, 0XD4C1, 0XD581, 0X1540, 0XD701, 0X17C0, 0X1680, 0XD641,
              0XD201, 0X12C0, 0X1380, 0XD341, 0X1100, 0XD1C1, 0XD081, 0X1040,
              0XF001, 0X30C0, 0X3180, 0XF141, 0X3300, 0XF3C1, 0XF281, 0X3240,
              0X3600, 0XF6C1, 0XF781, 0X3740, 0XF501, 0X35C0, 0X3480, 0XF441,
              0X3C00, 0XFCC1, 0XFD81, 0X3D40, 0XFF01, 0X3FC0, 0X3E80, 0XFE41,
              0XFA01, 0X3AC0, 0X3B80, 0XFB41, 0X3900, 0XF9C1, 0XF881, 0X3840,
              0X2800, 0XE8C1, 0XE981, 0X2940, 0XEB01, 0X2BC0, 0X2A80, 0XEA41,
              0XEE01, 0X2EC0, 0X2F80, 0XEF41, 0X2D00, 0XEDC1, 0XEC81, 0X2C40,
              0XE401, 0X24C0, 0X2580, 0XE541, 0X2700, 0XE7C1, 0XE681, 0X2640,
              0X2200, 0XE2C1, 0XE381, 0X2340, 0XE101, 0X21C0, 0X2080, 0XE041,
              0XA001, 0X60C0, 0X6180, 0XA141, 0X6300, 0XA3C1, 0XA281, 0X6240,
              0X6600, 0XA6C1, 0XA781, 0X6740, 0XA501, 0X65C0, 0X6480, 0XA441,
              0X6C00, 0XACC1, 0XAD81, 0X6D40, 0XAF01, 0X6FC0, 0X6E80, 0XAE41,
              0XAA01, 0X6AC0, 0X6B80, 0XAB41, 0X6900, 0XA9C1, 0XA881, 0X6840,
              0X7800, 0XB8C1, 0XB981, 0X7940, 0XBB01, 0X7BC0, 0X7A80, 0XBA41,
              0XBE01, 0X7EC0, 0X7F80, 0XBF41, 0X7D00, 0XBDC1, 0XBC81, 0X7C40,
              0XB401, 0X74C0, 0X7580, 0XB541, 0X7700, 0XB7C1, 0XB681, 0X7640,
              0X7200, 0XB2C1, 0XB381, 0X7340, 0XB101, 0X71C0, 0X7080, 0XB041,
              0X5000, 0X90C1, 0X9181, 0X5140, 0X9301, 0X53C0, 0X5280, 0X9241,
              0X9601, 0X56C0, 0X5780, 0X9741, 0X5500, 0X95C1, 0X9481, 0X5440,
              0X9C01, 0X5CC0, 0X5D80, 0X9D41, 0X5F00, 0X9FC1, 0X9E81, 0X5E40,
              0X5A00, 0X9AC1, 0X9B81, 0X5B40, 0X9901, 0X59C0, 0X5880, 0X9841,
              0X8801, 0X48C0, 0X4980, 0X8941, 0X4B00, 0X8BC1, 0X8A81, 0X4A40,
              0X4E00, 0X8EC1, 0X8F81, 0X4F40, 0X8D01, 0X4DC0, 0X4C80, 0X8C41,
              0X4400, 0X84C1, 0X8581, 0X4540, 0X8701, 0X47C0, 0X4680, 0X8641,
              0X8201, 0X42C0, 0X4380, 0X8341, 0X4100, 0X81C1, 0X8081, 0X4040
          var crc = 0xFFFF;
          for(var i = 0, l = string.length; i < l; i++){
              crc = ((crc >> 8) ^ CrcTable[(crc ^ string[i]) & 0xFF]);
          return crc.toString(16);
      function toHexString(byteArray) {
        return Array.from(byteArray, function(byte) {
          return ('0' + (byte & 0xFF).toString(16)).slice(-2);
        }).join('');
      function merc_gd(cmd,buflen,factor,total,callback)
          var port = new SerialPort(device_port,{
          baudrate: 9600,
          dataBits: 8,
          parity: 'none'
          const parser = port.pipe(new ByteLength({length: buflen}));
          port.pipe(parser);
          port.write(cmd);
          //sleep(sleep_time);
          setTimeout(readport, sleep_time);
          function readport (){
              parser.on ('data', function (result_double) {
                  var result = result_double.slice(0,buflen/2);
                  var resp_crc=result.slice(0,buflen/2-2);
                  var crc_get=toHexString(result.slice(buflen/2-1,buflen/2)) + toHexString(result.slice(buflen/2-2,buflen/2-1));
                  var crc_calc=crc16MODBUS(resp_crc).toString(16);
                  //log ('CRC='+parseInt(crc_get,16));
                  if (parseInt(crc_get,16) != parseInt(crc_calc,16) ){
                      log ('CRC is ERROR!');
                      log ('resultdouble='+JSON.stringify(result_double));
                      log ('result='+JSON.stringify(result));
                      log('CRCget='+crc_get);
                      log('CRCcalc='+crc_calc);
                  if (cmd == cmd_init)
                      //log ('cmd_init='+JSON.stringify(cmd));
                  if (cmd != cmd_init) {
                      var b1 =  toHexString(result.slice(1,2));
                      var b2 =  toHexString(result.slice(2,3));
                      var b3 =  toHexString(result.slice(3,4));
                      var b4 =  toHexString(result.slice(4,5));
                      var b5 =  toHexString(result.slice(5,6));
                      var b6 =  toHexString(result.slice(6,7));
                      var b7 =  toHexString(result.slice(7,8));
                      var b8 =  toHexString(result.slice(8,9));
                      var b9 =  toHexString(result.slice(9,10));
                      if (total === 0) {
                          var resp1 = b1.slice(1,2)+b3.slice(0,2)+b2.slice(0,2);
                          var resp2 = b4.slice(1,2)+b6.slice(0,2)+b5.slice(0,2);
                          var resp3 = b7.slice(1,2)+b9.slice(0,2)+b8.slice(0,2);
                          ret[0]= parseInt(resp1, 16)*factor;
                          ret[1]= parseInt(resp2, 16)*factor;
                          ret[2]= parseInt(resp3, 16)*factor;
                          if (cmd == cmd_pw || cmd == cmd_cos){
                              var b10 =  toHexString(result.slice(10,11));
                              var b11 =  toHexString(result.slice(11,12));
                              var b12 =  toHexString(result.slice(12,13));
                              var resp4 = b10.slice(1,2)+b12.slice(0,2)+b11.slice(0,2);
                              ret[3]= parseInt(resp4, 16)*factor;
                      } //if total === 0
                      if (total == 1) {
                          var respt = b2.slice(0,2)+b1.slice(0,2)+b4.slice(0,2)+b3.slice(0,2);
                          ret[0]= parseInt(respt, 16)*factor;
                      } //if total===1
                  } // if cmd != cmd_init
                  if (callback && typeof(callback) === "function") {
                      callback(ret);
              }); //parser.on
              port.pause();
              port.close();
              return (ret);
          } //end function portread
      }  //end function merc_gd
      schedule("* * * * *", function () {
      merc_gd(cmd_init,8,0,0, function(data) {
          //  console.log('data='+data[0]);
          setTimeout(merc_gd(cmd_uv,24,0.01,0, function(data) {
              setState('Uv1',Number(data[0]).toFixed(2));
              setState('Uv2',Number(data[1]).toFixed(2));
              setState('Uv3',Number(data[2]).toFixed(2));
              setTimeout(merc_gd(cmd_ia,24,0.001,0, function(data) {
                  setState('Ia1',Number(data[0]).toFixed(2));
                  setState('Ia2',Number(data[1]).toFixed(2));
                  setState('Ia3',Number(data[2]).toFixed(2));
                  setTimeout(merc_gd(cmd_pw,30,0.01,0, function(data) {
                      setState('Pw_total',Number(data[0]).toFixed(2));
                      setState('Pw1',Number(data[1]).toFixed(2));
                      setState('Pw2',Number(data[2]).toFixed(2));
                      setState('Pw3',Number(data[3]).toFixed(2));
                      setTimeout(merc_gd(cmd_total,38,0.001,1, function(data) {
                          setState('E_total',Number(data[0]).toFixed(2));
                          setTimeout(merc_gd(cmd_T1,38,0.001,1, function(data) {
                              setState('E_T1',Number(data[0]).toFixed(2));
                              setTimeout(merc_gd(cmd_T2,38,0.001,1, function(data) {
                                  setState('E_T2',Number(data[0]).toFixed(2));
                                  }), sleep_time);
                              }), sleep_time);
                          }),sleep_time);
                      }), sleep_time);
                  }), sleep_time);
              }), sleep_time);
      1444_________________________________________________________236___________8.0.0_m234___________9.0.0_v._131211.pdf
        Anzic last edited by
        а через TCP можно использовать этот скрипт? Как он тогда будет выглядит?
          @Anzic:
          а через TCP можно использовать этот скрипт? Как он тогда будет выглядит? `
          Что значит через TCP? У счётчика подключение CAN/RS485.
          Ещё у меня есть кастомная прошивка espeasy для esp8266 с поддержкой Меркурий 230, можно через wifi по mqtt забирать данные.
            RDim last edited by
            @andrey99986:
            Адаптер:
            https://ru.aliexpress.com/item/1-pcs-US … 0.0.fzI5Kj `
            Спасибо за скрипт!
            Взлетел, но не сразу. Хочу добавить пару моментов.
            В настройках адаптера javascript, добавить модуль serialport.
            Вылезла ошибка с предложением > Error in callback: TypeError: "baudrate" is an unknown option, did you mean "baudRate"?
            Мне потребовалось изменить в скрипте функцию merc_gd
                baudRate: 9600,
                dataBits: 8,
                parity: 'none'
            baudrate на baudRate
              solomsv last edited by
              @andrey99986:
              @Anzic:
              Ещё у меня есть кастомная прошивка espeasy для esp8266 с поддержкой Меркурий 230, можно через wifi по mqtt забирать данные. `
              Доброго времени !
              Поделитесь прошивкой для esp8266
                Инструкция по компиляции прошивки espeasy с плагином Меркурий 230.
                1. Ставим atom по инструкции: https://letscontrolit.com/wiki/index.ph … Platformio
                2. Скачиваем последний релиз espeasy https://github.com/letscontrolit/ESPEasy/releases
                3. Разархивируем архив релиза, в папку src записываем файл https://github.com/Andrey2509/ESPEasy/b ... ury230.ino
                4. В файле platformio.ini раскомментировать тип прошивки, например: env_default = normal_ESP8266_4096
                5. В файле define_plugin_sets.h в секции #ifdef PLUGIN_SET_STABLE (соответствует прошивке normal) добавляем строку:
                #define USES_P220 //Mercury 230
                6. Компилируем.
                Так как данных много, а в espeasy жёсткое ограничение по количеству значений для каждого плагина, в плагине меркурий 230 вшита отправка данных только по mqtt. При этом Надо обязательно создать подключение в настройках "Controllers" (OpenHAB MQTT).
                На стороне иоброкера парсим mqtt строку в js:
                on({id: "mqtt.0.Mercury230.Merc_data_json", change: 'any'}, function (obj) {
                  var myjson=JSON.parse(obj.state.val);
                  setState("javascript.0.Uv1",myjson['Uv1']);
                  setState("javascript.0.Uv2",myjson['Uv2']);
                  setState("javascript.0.Uv3",myjson['Uv3']);
                  setState("javascript.0.Ia1",myjson['Ia1']);
                  setState("javascript.0.Ia2",myjson['Ia2']);
                  setState("javascript.0.Ia3",myjson['Ia3']);
                  setState("javascript.0.Pw_total",myjson['Pw0']);
                  setState("javascript.0.Pw1",myjson['Pw1']);
                  setState("javascript.0.Pw2",myjson['Pw2']);
                  setState("javascript.0.Pw3",myjson['Pw3']);
                  setState("javascript.0.E_T1",myjson['T1']);
                  setState("javascript.0.E_T2",myjson['T2']);
                 on({id: "mqtt.0.Mercury230.Merc_stat_json", change: 'any'} || {id: "javascript.0.Energy_tarif", change: 'any'}, function (obj) {
                 var myjson=JSON.parse(getState("mqtt.0.Mercury230.Merc_stat_json").val);
                 var tarrif=getState("javascript.0.Energy_tarif").val;
                 if (JSON.stringify(myjson).length>24)
                    var table_mer230 = [{"month":1,"T1":0,"T2":0,"T1_potr":0,"T2_potr":0,"Total":0},
                    {"month":2,"T1":0,"T2":0,"T1_potr":0,"T2_potr":0,"Total":0},
                    {"month":3,"T1":0,"T2":0,"T1_potr":0,"T2_potr":0,"Total":0},
                    {"month":4,"T1":0,"T2":0,"T1_potr":0,"T2_potr":0,"Total":0},
                    {"month":5,"T1":0,"T2":0,"T1_potr":0,"T2_potr":0,"Total":0},
                    {"month":6,"T1":0,"T2":0,"T1_potr":0,"T2_potr":0,"Total":0},
                    {"month":7,"T1":0,"T2":0,"T1_potr":0,"T2_potr":0,"Total":0},
                    {"month":8,"T1":0,"T2":0,"T1_potr":0,"T2_potr":0,"Total":0},
                    {"month":9,"T1":0,"T2":0,"T1_potr":0,"T2_potr":0,"Total":0},
                    {"month":10,"T1":0,"T2":0,"T1_potr":0,"T2_potr":0,"Total":0},
                    {"month":11,"T1":0,"T2":0,"T1_potr":0,"T2_potr":0,"Total":0},
                    {"month":12,"T1":0,"T2":0,"T1_potr":0,"T2_potr":0,"Total":0}];
                 console.log('start');
                     for(var i=1;i<13;i++)
                    table_mer230[i-1]["month"]=i;
                    table_mer230[i-1]["T1"]=myjson['M'+i+'T1'];;
                    table_mer230[i-1]["T2"]=myjson['M'+i+'T2'];
                    table_mer230[i-1]["T1_potr"]=Math.round(myjson['M'+i+'T1']*tarrif);
                    table_mer230[i-1]["T2_potr"]=Math.round(myjson['M'+i+'T2']*tarrif/2);
                    table_mer230[i-1]["Total"]=Math.round(myjson['M'+i+'T1']*tarrif)+Math.round(myjson['M'+i+'T2']*tarrif/2);
                    //console.log('table='+JSON.stringify(table_mer230));
                    setState("javascript.0.History_mer230", JSON.stringify(table_mer230));
                  ssvvvv last edited by
                  @andrey99986:
                  6. Компилируем.
                  Добрый день, Сергей.
                  Ваш плагин для ESPEASY очень понравился, но у меня не получилось его запустить.
                  Все сделал по пунктам, прошил и достучался до espeasy. Подключил его к домашнему роутеру и даже но MQTT что то увидел НО главное включение плагина MERCURY 230 не происходит. Т.е. при выборе плагина, в его настройках указываю:
                  Device: Mercury 230
                  Enabled: YES
                  Sensor
                  1st GPIO: GPIO 12
                  2nd GPIO: GPIO 14
                  Read month stat: NO
                  Start time to read stat for every month, hour: 0
                  Start time to read stat for every month, min: 0
                  End time to read stat for every month, hour: 0
                  End time to read stat for every month, min: 0
                  Select MQTT controller to publish data in json format : 1
                  Note: MQTT topic to publish runtime data is: "Mercury230/Merc_data_json"
                  Note: MQTT topic to publish history data is: "Mercury230/Merc_stat_json"
                  Note: Interval (below) must be shorter then period between end and start
                  Data Acquisition
                  Send to Controller YES
                  ❶
                  Interval: 5 [sec]
                  Давлю SUBMIT потом возвращаюсь в DEVICES и вижу что у меня напротив плагина Меркурий в столбце ENABLED стоит Х (не включено)
                  В MQTT ничего не видно
                  что делать? `
                    В дополнение у меня Nodemcu V3
                      @ssvvvv:
                      В дополнение у меня Nodemcu V3 `
                      Плагин автодисейблиться может по причине:
                      1.В espeasy должен быть создан MQTT контроллер в соответствующей закладке (тестировал только тип Openhab).
                      2. Не правильно указаны GPIO RX/TX или неправильно подключен к конвертору RS232/RS485.
                      Я использую такой:
                      https://ru.aliexpress.com/item/Single-C … 57602.html
                      Напрямую к счётчику подключать нельзя!
                        Андрей, большое спасибо за быстрый отзыв.
                        У меня такой же модуль 485.
                        Все заработало.
                        Через 6 часов перестал работать опрос, перезагрузка (отключением питания) помогла
                        Сейчас опять стоит испытывается.
                        Скажите получилось победить утечку памяти?
                        В остальном у меня все передается, правда мне нужны были прямые топики в MQTT - переделал передачу отдельными командами.
                        Иногда не успевает передать. Перешел на Domoticz MQTT и убрал все задержки - стало лучше но некоторые параметры не проходят. Но это не проблема - у меня частота передачи сейчас стоит 10с (на 5с больше глюков). На верху у меня RapidScada с драйвером MQTT.
                        В любом случае спасибо за Вашу работу!!!
                        Для меня espeasy новое и с титаном не работал поэтому пришлось помучатся.
                          @ssvvvv:
                          Скажите получилось победить утечку памяти? `
                          Та версия, которая на github (ссылка выше) - без утечки памяти.
                          Проверяется просто - в espeasy ставится девайс "Generic - System Info ". Индикатор "Free RAM". далее штатно передаём через mqtt иоброкеру и сохраняем историю. У меня uptime уже 22 дня, память не уменьшается.
                          Были короткие uptime до замены БП, esp(nodemcu) оказалась очень чувствительна и к самому БП, и к проводам подводящим питание.
                          Сейчас БП и питание RS485 конвертора выставил ровно на 5.0 Вольт.
                          Частота запросов 10 с - на ней не тестировал, у меня 60 сек.
                            Обновил версию на github для espeasy.
                            Изменения:
                            -замена опасных функций (с указателями на данные) на безопасные,
                            -поддержка hardware serial (необходимо убрать галку использования serial самой espeasy),
                            -статистика передаётся в 2-х топиках: по месяцам и по предыдущему дню,
                            -период сбора статистики потребления задаётся в минутах, независимо от сбора оперативных данных.
                            • Сергей Смирнов
                              Сергей Смирнов last edited by
                              Добрый день! Как вы считаете, реально переделать скетч под software serial или hardware? Хочу использовать в связке с Меркурий 231 (с ИК портом) - ествественно, через переходник...
                              • Сергей Смирнов
                                Ау..есть кто живой?
                                  Aleksey31 last edited by
                                  Всем привет!
                                  Пробовал заводской прогой опросить Меркурий 230, все получилось.
                                  Теперь хочу запустить опрос счетчика Меркурий 230 через скрипт, что выше приведен.
                                  Копипастом не заработал...
                                  Сейчас стоит Script Ingine 4.1.12.
                                  В настройках прописал пакет serialport. Перезапустил службу, так же пробовал в ручную ставить через npm install serialport.
                                  В редакторе JS подсвечивает ошибки ca090cec-8d04-4c9e-8179-0e2e4465cd2f-image.png
                                  Подскажите что не так делаю, и как заставить редактор видеть (установить) недостающие пакеты...
                                  В ручную пробовал в папку iobroker ставить, ничего не меняется...
                                  37281
