    4. Vis2 Adapter macht Probleme.
      TimoWald last edited by
      Hallo, was ist das für eine Fehlermeldung? Was kann ich da machen?
      2024-11-03 11:32:53.538 - debug: homeconnect.0 (151169) Set event state
      2024-11-03 11:33:41.833 - info: host.iobroker "system.adapter.vis-2.0" enabled
      2024-11-03 11:33:42.628 - error: host.iobroker startInstance vis-2.0: cannot find start file!
      2024-11-03 11:33:45.359 - info: solax.0 (1115) State value to set for "solax.0.data.json" has to be type "string" but received type "number"
      2024-11-03 11:33:52.985 - debug: homeconnect.0 (151169) event: {"type":"NOTIFY","data":"{\"haId\":\"SIEMENS-WM14VG93-68A40E9041F2\",\"items\":[{\"handling\":\"none\",\"key\":\"BSH.Common.Option.ProgramProgress\",\"level\":\"hint\",\"timestamp\":1730630032,\"unit\":\"%\",\"uri\":\"/api/homeappliances/SIEMENS-WM14VG93-68A40E9041F2/programs/active/options/BSH.Common.Option.ProgramProgress\",\"value\":12}]}","lastEventId":"SIEMENS-WM14VG93-68A40E9041F2","origin":"https://api.home-connect.com"}
      2024-11-03 11:33:52.985 - debug: homeconnect.0 (151169) SIEMENS-WM14VG93-68A40E9041F2.programs.active.options.BSH_Common_Option_ProgramProgress:12
      2024-11-03 11:33:52.986 - debug: homeconnect.0 (151169) Set event state
      2024-11-03 11:33:53.531 - debug: homeconnect.0 (151169) event: {"type":"NOTIFY","data":"{\"haId\":\"SIEMENS-WM14VG93-68A40E9041F2\",\"items\":[{\"handling\":\"none\",\"key\":\"BSH.Common.Option.RemainingProgramTime\",\"level\":\"hint\",\"timestamp\":1730630033,\"unit\":\"seconds\",\"uri\":\"/api/homeappliances/SIEMENS-WM14VG93-68A40E9041F2/programs/active/options/BSH.Common.Option.RemainingProgramTime\",\"value\":2520}]}","lastEventId":"SIEMENS-WM14VG93-68A40E9041F2","origin":"https://api.home-connect.com"}
      2024-11-03 11:33:53.532 - debug: homeconnect.0 (151169) SIEMENS-WM14VG93-68A40E9041F2.programs.active.options.BSH_Common_Option_RemainingProgramTime:2520
      2024-11-03 11:33:53.533 - debug: homeconnect.0 (151169) Set event state
      • sigi234
        sigi234 Forum Testing Most Active @TimoWald last edited by
        @timowald
        Adapter Grün? WEB Adapter installiert und konfiguriert?
          TimoWald @sigi234 last edited by
          @sigi234 Adapter wird nicht grün.
          • sigi234
            @timowald
            Haken bei Reine Web-Sockets verwenden mal raus
              @sigi234 Wird auch nicht grün.
              Er meckert wegen Start File.
              • sigi234
                @timowald
                Wie installiert, welche Version ?
                Browser Cache mal komplett geleert?
                VIS-2 Upload mal gemacht?
                  @sigi234 Version ist noch die v2.9.44. Bekomme keine andere drauf. Cache wurde schon geleert. Was ist mit Vis2 Uload gemeint?
                    Homoran Global Moderator Administrators @TimoWald last edited by Homoran
                    @timowald sagte in Vis2 Adapter macht Probleme.:
                    warum nicht?
                    erfüllst du irgendwelche Voraussetzungen nicht?
                      TimoWald @Homoran last edited by TimoWald
                      @homoran Wie soll ich sie am besten installieren? Mit Github URL, NMP, etc?
                      An dieser stelle bleibt er stundenlang stehen.
                        Thomas Braun Most Active @TimoWald last edited by
                        @timowald
                        Das ist vis1.
                        Was sagt die Konsole?
                        iob update
                        iob upgrade
                        Oder vielleicht gleich mal die Langfassung von
                        iob diag
                          TimoWald @Thomas Braun last edited by
                          @thomas-braun iob diag sagt folgendes:
                          ========== Start marking the full check here ===========
                          ```bash
                          Script v.2024-10-19
                          *** BASE SYSTEM ***
                             Static hostname: iobroker
                                   Icon name: computer-container
                                     Chassis: container
                              Virtualization: lxc
                            Operating System: Debian GNU/Linux 11 (bullseye)
                                      Kernel: Linux 6.8.12-1-pve
                                Architecture: x86-64
                          OS is similar to:
                          model name      : Intel(R) Core(TM) i3-4010U CPU @ 1.70GHz
                          Docker          : false
                          Virtualization  : lxc
                          Kernel          : x86_64
                          Userland        : 64 bit
                          Systemuptime and Load:
                           12:47:33 up 18 days, 18:57,  2 users,  load average: 0.76, 1.37, 2.90
                          CPU threads: 4
                          *** LIFE CYCLE STATUS ***
                          Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
                          *** TIME AND TIMEZONES ***
                                         Local time: Sun 2024-11-03 12:47:33 CET
                                     Universal time: Sun 2024-11-03 11:47:33 UTC
                                           RTC time: n/a
                                        NTP service: inactive
                                    RTC in local TZ: no
                          *** Users and Groups ***
                          User that called 'iob diag':
                          wald
                          HOME=/home/wald
                          GROUPS=wald sudo
                          js-controller is not running
                          *** DISPLAY-SERVER SETUP ***
                          Display-Server: false
                          Desktop:
                          Terminal:       tty
                          System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
                          *** MEMORY ***
                          Mem:            7.8G        454M        3.6G        0.0K        3.8G        7.3G
                          Swap:           7.0G        8.0M        7.0G
                          Total:           14G        463M         10G
                          Active iob-Instances:   1
                                   7778 M total memory
                                    454 M used memory
                                     84 M active memory
                                   3687 M inactive memory
                                   3569 M free memory
                                      0 M buffer memory
                                   3754 M swap cache
                                   7039 M total swap
                                      8 M used swap
                                   7031 M free swap
                          top - 12:47:33 up 18 days, 18:57,  2 users,  load average: 0.76, 1.37, 2.90
                          Tasks:  29 total,   1 running,  28 sleeping,   0 stopped,   0 zombie
                          %Cpu(s):  1.5 us,  3.1 sy,  0.0 ni, 95.4 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                          MiB Mem :   7778.1 total,   3568.8 free,    454.6 used,   3754.8 buff/cache
                          MiB Swap:   7040.0 total,   7031.3 free,      8.7 used.   7323.5 avail Mem
                          *** FAILED SERVICES ***
                            UNIT                          LOAD   ACTIVE SUB    DESCRIPTION
                          * run-rpc_pipefs.mount          loaded failed failed RPC Pipe File System
                          * sys-kernel-config.mount       loaded failed failed Kernel Configuration File System
                          * iobroker.service              loaded failed failed ioBroker Server
                          * systemd-journald-audit.socket loaded failed failed Journal Audit Socket
                          4 loaded units listed.
                          *** DMESG CRITICAL ERRORS ***
                          dmesg: read kernel buffer failed: Operation not permitted
                          No critical errors detected
                          *** FILESYSTEM ***
                          /dev/loop3     ext4       32G   18G   13G  58% /
                          none           tmpfs     492K  4.0K  488K   1% /dev
                          udev           devtmpfs  3.8G     0  3.8G   0% /dev/tty
                          tmpfs          tmpfs     3.8G     0  3.8G   0% /dev/shm
                          tmpfs          tmpfs     1.6G  116K  1.6G   1% /run
                          tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
                          tmpfs          tmpfs     778M     0  778M   0% /run/user/1005
                          Show mounted filesystems:
                          TARGET SOURCE     FSTYPE OPTIONS
                          /      /dev/loop3 ext4   rw,relatime
                          /var:
                          1.6G    /var/
                          1.2G    /var/log/journal/e42f0ac6b105431aa6e42fb59b1f8fbf
                          1.2G    /var/log
                          348M    /var/cache
                          Archived and active journals take up 24.0M in the file system.
                          /opt/iobroker/backups:
                          128M    /opt/iobroker/backups/
                          /opt/iobroker/iobroker-data:
                          2.2G    /opt/iobroker/iobroker-data/
                          1.6G    /opt/iobroker/iobroker-data/files
                          617M    /opt/iobroker/iobroker-data/files/javascript.admin
                          560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                          558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                          38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
                          30M     /opt/iobroker/iobroker-data/objects.jsonl
                          27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
                          26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
                          26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
                          USB-Devices by-id:
                          /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2272728-if00
                          *** NodeJS-Installation ***
                          /usr/bin/nodejs         v20.17.0
                          /usr/bin/node           v20.17.0
                          /usr/bin/corepack       0.29.3
                          nodejs:
                            Installed: 20.17.0-1nodesource1
                            Candidate: 20.18.0-1nodesource1
                            Version table:
                               20.18.0-1nodesource1 1001
                                  500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                           *** 20.17.0-1nodesource1 1001
                                  100 /var/lib/dpkg/status
                               20.16.0-1nodesource1 1001
                               20.15.1-1nodesource1 1001
                               20.15.0-1nodesource1 1001
                               20.14.0-1nodesource1 1001
                               20.13.1-1nodesource1 1001
                               20.13.0-1nodesource1 1001
                               20.12.2-1nodesource1 1001
                               20.12.1-1nodesource1 1001
                               20.12.0-1nodesource1 1001
                               20.11.1-1nodesource1 1001
                               20.11.0-1nodesource1 1001
                               20.10.0-1nodesource1 1001
                               20.9.0-1nodesource1 1001
                               20.8.1-1nodesource1 1001
                               20.8.0-1nodesource1 1001
                               20.7.0-1nodesource1 1001
                               20.6.1-1nodesource1 1001
                               20.6.0-1nodesource1 1001
                               20.5.1-1nodesource1 1001
                               20.5.0-1nodesource1 1001
                               20.4.0-1nodesource1 1001
                               20.3.1-1nodesource1 1001
                               20.3.0-1nodesource1 1001
                               20.2.0-1nodesource1 1001
                               20.1.0-1nodesource1 1001
                               20.0.0-1nodesource1 1001
                               12.22.12~dfsg-1~deb11u5 500
                                  500 http://security.debian.org bullseye-security/main amd64 Packages
                               12.22.12~dfsg-1~deb11u4 500
                                  500 http://ftp.debian.org/debian bullseye/main amd64 Packages
                          No problems detected
                          Errors in npm tree: 0
                          *** ioBroker-Installation ***
                          ioBroker Status
                          iobroker is not running on this host.
                          Objects type: jsonl
                          States  type: jsonl
                          Hosts:
                          iobroker            iobroker (version: 6.0.11, hostname: iobroker      , alive, uptime: 1622837)
                          Core adapters versions
                          js-controller:  6.0.11
                          admin:          7.1.5
                          javascript:     8.8.3
                          nodejs modules from github:     13
                          +-- iobroker.bydhvs@1.5.1 (git+ssh://git@github.com/christianh17/ioBroker.bydhvs.git#55d06a849a015b35995e8e3fdc3c35f57fdd9c0d)
                          +-- iobroker.energiefluss-erweitert@0.5.1-alpha.10 (git+ssh://git@github.com/SKB-CGN/ioBroker.energiefluss-erweitert.git#3a8c53f95ee9a763bf454b74ea986d8eb5991a65)
                          +-- iobroker.fronius@2.1.1 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.fronius.git#392e182ba42b3255cdd84c657c00e7fd8a9c4814)
                          +-- iobroker.icons-ultimate-png@1.0.1 (git+ssh://git@github.com/ioBroker/ioBroker.icons-ultimate-png.git#519f1a7d31416157f8297b6e5b33745a3989a122)
                          +-- iobroker.luxtronik2@0.5.2 (git+ssh://git@github.com/boellner/ioBroker.luxtronik2.git#dc0b80246a75506d7419bc2f6e6fe1b0d34338ef)
                          +-- iobroker.pvforecast@4.0.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.pvforecast.git#3ef9743f113e0c4a53a7f1841748131e5b1d66a3)
                          | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
                          +-- iobroker.vis-2@ (git+ssh://git@github.com/ioBroker/ioBroker.vis-2.git#cabeca3a63207dc71df3504865eccfcef2f22097)
                          +-- iobroker.vis-fancyswitch@1.1.0 (git+ssh://git@github.com/ioBroker/ioBroker.vis-fancyswitch.git#62fe89a9bf646392c6a53e7f91744352409135ae)
                          +-- iobroker.vis-materialdesign@0.5.86 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#cf7fc5b85debcda156a3ec7feb761cff217fa855)
                          +-- iobroker.vis@1.5.6 (git+ssh://git@github.com/iobroker/ioBroker.vis.git#8518f7fbadf76519b3c6bceb5a34e298b9257c0a)
                          +-- iobroker.wiobrowser@2.0.2 (git+ssh://git@github.com/Bettman66/ioBroker.wiobrowser.git#1ce25f0107ab18ad95b5851d4bd96efd4172469d)
                          +-- iobroker.worx@3.1.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.worx.git#4511551fdae7eaa6084c884ad1c2aaa67cef80d2)
                          Adapter State
                            system.adapter.adguard.0                : adguard               : iobroker                                 -  enabled, compact disabled
                            system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, compact disabled, port: 8081, bind: 0.0.0.0, run as: admin
                            system.adapter.alexa2.0                 : alexa2                : iobroker                                 - disabled, compact disabled
                            system.adapter.alexa2.1                 : alexa2                : iobroker                                 -  enabled, compact disabled
                            system.adapter.alias-manager.0          : alias-manager         : iobroker                                 -  enabled, compact disabled
                            system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled, compact disabled
                            system.adapter.birthdays.0              : birthdays             : iobroker                                 -  enabled, compact disabled
                            system.adapter.birthdays.1              : birthdays             : iobroker                                 -  enabled, compact disabled
                            system.adapter.bydhvs.0                 : bydhvs                : iobroker                                 -  enabled, compact disabled
                            system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled, compact disabled
                            system.adapter.device-reminder.0        : device-reminder       : iobroker                                 -  enabled, compact disabled
                            system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled, compact disabled
                            system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled, compact disabled
                            system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 -  enabled, compact disabled
                            system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
                            system.adapter.fronius-solarweb.0       : fronius-solarweb      : iobroker                                 -  enabled, compact disabled
                            system.adapter.fronius-solarweb.1       : fronius-solarweb      : iobroker                                 -  enabled, compact disabled
                            system.adapter.fronius.0                : fronius               : iobroker                                 -  enabled, compact disabled
                            system.adapter.hass.0                   : hass                  : iobroker                                 -  enabled, compact disabled, port: 8123
                            system.adapter.history.0                : history               : iobroker                                 -  enabled, compact disabled
                            system.adapter.hmip.0                   : hmip                  : iobroker                                 -  enabled, compact disabled
                            system.adapter.homeconnect.0            : homeconnect           : iobroker                                 -  enabled, compact disabled
                            system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled, compact disabled
                            system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled, compact disabled
                            system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iobroker                                 - disabled
                            system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 - disabled
                            system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
                            system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 - disabled
                            system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 - disabled
                            system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, compact disabled, port: 8086
                            system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled, compact disabled
                            system.adapter.iot.1                    : iot                   : iobroker                                 -  enabled, compact disabled
                            system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled, compact disabled
                            system.adapter.knx.0                    : knx                   : iobroker                                 - disabled, compact disabled, bind: 192.168.9.254
                            system.adapter.lg-thinq.0               : lg-thinq              : iobroker                                 -  enabled, compact disabled
                            system.adapter.luxtronik2.0             : luxtronik2            : iobroker                                 -  enabled, compact disabled, port: 8214
                            system.adapter.modbus.0                 : modbus                : iobroker                                 - disabled, compact disabled
                            system.adapter.modbus.1                 : modbus                : iobroker                                 -  enabled, compact disabled
                            system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, compact disabled, port: 1883, bind: 0.0.0.0
                            system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, compact disabled, port: 1887, bind: 0.0.0.0
                            system.adapter.mqtt.2                   : mqtt                  : iobroker                                 - disabled, compact disabled, port: 1888, bind: 0.0.0.0
                            system.adapter.mqtt.3                   : mqtt                  : iobroker                                 - disabled, compact disabled, port: 1883, bind: 0.0.0.0
                            system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, compact disabled, port: 1880, bind: 192.168.9.254
                            system.adapter.openknx.0                : openknx               : iobroker                                 -  enabled, compact disabled
                            system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled, compact disabled
                            system.adapter.philips-tv.0             : philips-tv            : iobroker                                 -  enabled, compact disabled
                            system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, compact disabled, port: 8006
                            system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled, compact disabled
                            system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled, compact disabled
                            system.adapter.roborock.0               : roborock              : iobroker                                 -  enabled, compact enabled (group 1)
                            system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled, compact disabled
                            system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, compact disabled, port: 1883, bind: 0.0.0.0
                            system.adapter.shelly.1                 : shelly                : iobroker                                 - disabled, compact disabled, port: 1887, bind: 0.0.0.0
                            system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, compact disabled, port: 8087, bind: 0.0.0.0, run as: admin
                            system.adapter.solax.0                  : solax                 : iobroker                                 -  enabled, compact disabled
                            system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, compact disabled, port: 1884, bind: 0.0.0.0
                            system.adapter.sonos.0                  : sonos                 : iobroker                                 -  enabled, compact disabled
                            system.adapter.synology.0               : synology              : iobroker                                 -  enabled, compact disabled, port: 5000
                            system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled, compact disabled
                            system.adapter.tradfri.0                : tradfri               : iobroker                                 -  enabled, compact disabled
                            system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled, compact disabled
                            system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : iobroker                                 -  enabled
                            system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : iobroker                                 -  enabled
                            system.adapter.vis-2-widgets-jaeger-design.0: vis-2-widgets-jaeger-design: iobroker                                 -  enabled
                            system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 -  enabled
                            system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled, compact disabled
                            system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
                            system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
                            system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 - disabled
                            system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 - disabled
                            system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 -  enabled, compact disabled
                            system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
                            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
                            system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled, compact disabled
                            system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 - disabled, compact disabled
                            system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
                            system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
                            system.adapter.vis-keyboard.0           : vis-keyboard          : iobroker                                 -  enabled
                            system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 - disabled
                            system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
                            system.adapter.vis-players.0            : vis-players           : iobroker                                 - disabled
                            system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 - disabled
                            system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 - disabled
                            system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
                            system.adapter.vis-weather.0            : vis-weather           : iobroker                                 -  enabled
                            system.adapter.vis.0                    : vis                   : iobroker                                 - disabled, compact disabled
                            system.adapter.web.0                    : web                   : iobroker                                 -  enabled, compact disabled, port: 8082, bind: 0.0.0.0, run as: admin
                            system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker                                 -  enabled, compact disabled
                            system.adapter.whatsapp-cmb.1           : whatsapp-cmb          : iobroker                                 -  enabled, compact disabled
                            system.adapter.whatsapp-cmb.2           : whatsapp-cmb          : iobroker                                 -  enabled, compact disabled
                            system.adapter.windows-control.0        : windows-control       : iobroker                                 - disabled, compact disabled
                            system.adapter.wiobrowser.0             : wiobrowser            : iobroker                                 -  enabled, compact disabled, port: 2208
                            system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled, compact disabled
                            system.adapter.worx.0                   : worx                  : iobroker                                 -  enabled, compact disabled
                          + instance is alive
                          ioBroker-Repositories
                          Active repo(s): stable
                          Upgrade policy: none
                          Installed ioBroker-Instances
                          Used repository: stable
                          Adapter    "adguard"      : 0.0.8    , installed 0.0.8
                          Adapter    "admin"        : 7.1.5    , installed 7.1.5
                          Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                          Adapter    "backitup"     : 3.0.25   , installed 3.0.25
                          Adapter    "birthdays"    : 3.0.1    , installed 3.0.1
                          Adapter    "bydhvs"       : 1.5.0    , installed 1.5.1
                          Adapter    "daswetter"    : 3.1.16   , installed 3.1.16
                          Adapter    "device-reminder": 3.1.2  , installed 3.1.2
                          Adapter    "discovery"    : 5.0.0    , installed 5.0.0
                          Adapter    "echarts"      : 1.9.2    , installed 1.9.2
                          Adapter    "energiefluss-erweitert": 0.4.1, installed 0.5.1-alpha.10
                          Adapter    "fronius"      : 2.1.1    , installed 2.1.1
                          Adapter    "fronius-solarweb": 0.0.3 , installed 0.1.0
                          Adapter    "gira-iot"     : 0.5.0    , installed 0.5.0
                          Adapter    "hass"         : 1.4.0    , installed 1.4.0
                          Adapter    "hmip"         : 1.24.3   , installed 1.24.3
                          Adapter    "homeconnect"  : 1.4.1    , installed 1.4.1
                          Adapter    "ical"         : 1.15.0   , installed 1.15.0
                          Adapter    "iot"          : 3.3.0    , installed 3.3.0
                          Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                          Controller "js-controller": 6.0.11   , installed 6.0.11
                          Adapter    "knx"          : 2.0.28   , installed 2.0.28
                          Adapter    "lg-thinq"     : 1.0.2    , installed 1.0.2
                          Adapter    "modbus"       : 6.3.2    , installed 6.3.2
                          Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
                          Adapter    "node-red"     : 5.2.1    , installed 5.2.1
                          Adapter    "openknx"      : 0.9.0    , installed 0.9.0
                          Adapter    "openweathermap": 1.1.2   , installed 1.1.2
                          Adapter    "philips-tv"   : 0.5.4    , installed 0.5.4
                          Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
                          Adapter    "pushover"     : 4.1.0    , installed 4.1.0
                          Adapter    "pvforecast"   : 3.0.0    , installed 4.0.0
                          Adapter    "roborock"     : 0.6.16   , installed 0.6.16
                          Adapter    "rpi2"         : 2.2.1    , installed 2.2.1
                          Adapter    "shelly"       : 8.2.1    , installed 8.2.1
                          Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                          Adapter    "solax"        : 0.9.12   , installed 0.9.12
                          Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
                          Adapter    "sonos"        : 3.0.0    , installed 3.0.0
                          Adapter    "synology"     : 3.1.0    , installed 3.1.0
                          Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
                          Adapter    "tradfri"      : 3.1.3    , installed 3.1.3
                          Adapter    "trashschedule": 3.3.0    , installed 3.3.0
                          Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
                          Adapter    "vis-2-widgets-gauges": 1.1.0, installed 1.1.0
                          Adapter    "vis-2-widgets-jaeger-design": 1.2.7, installed 1.2.7
                          Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
                          Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
                          Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
                          Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
                          Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
                          Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
                          Adapter    "vis-materialdesign": 0.5.9, installed 0.5.86
                          Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
                          Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
                          Adapter    "windows-control": 0.1.5  , installed 0.1.5
                          Adapter    "wiobrowser"   : 2.0.2    , installed 2.0.2
                          Adapter    "wled"         : 0.7.2    , installed 0.7.2
                          Adapter    "worx"         : 3.1.0    , installed 3.1.0
                          Adapter    "ws"           : 2.6.2    , installed 2.6.2
                          Objects and States
                          Objects:        34385
                          States:         27991
                          Hit:1 http://security.debian.org bullseye-security InRelease
                          Hit:2 http://ftp.debian.org/debian bullseye InRelease
                          Hit:3 http://ftp.debian.org/debian bullseye-updates InRelease
                          Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
                          Reading package lists...
                          Pending Updates: 20
                          *** Listening Ports ***
                          tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      104        17344      110/systemd-resolve
                          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          14077      1/init
                          tcp        0      0 0.0.0.0:5355            0.0.0.0:*               LISTEN      104        17338      110/systemd-resolve
                          tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          18446      295/master
                          tcp6       0      0 :::111                  :::*                    LISTEN      0          14079      1/init
                          tcp6       0      0 :::22                   :::*                    LISTEN      0          14198      1/init
                          tcp6       0      0 :::5355                 :::*                    LISTEN      104        17341      110/systemd-resolve
                          tcp6       0      0 ::1:25                  :::*                    LISTEN      0          18447      295/master
                          udp        0      0 127.0.0.53:53           0.0.0.0:*                           104        17343      110/systemd-resolve
                          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          14078      1/init
                          udp        0      0 0.0.0.0:5355            0.0.0.0:*                           104        17337      110/systemd-resolve
                          udp6       0      0 :::111                  :::*                                0          14080      1/init
                          udp6       0      0 :::5355                 :::*                                104        17340      110/systemd-resolve
                          2024-11-03 12:38:03.521  - warn: host.iobroker instance system.adapter.backitup.0 terminated due to SIGKILL
                          2024-11-03 12:38:03.521  - info: host.iobroker instance system.adapter.backitup.0 terminated with code null ()
                          2024-11-03 12:38:03.586  - warn: host.iobroker instance system.adapter.modbus.1 terminated due to SIGKILL
                          2024-11-03 12:38:03.586  - info: host.iobroker instance system.adapter.modbus.1 terminated with code null ()
                          2024-11-03 12:38:03.586  - warn: host.iobroker instance system.adapter.hass.0 terminated due to SIGKILL
                          2024-11-03 12:38:03.586  - info: host.iobroker instance system.adapter.hass.0 terminated with code null ()
                          2024-11-03 12:38:03.586  - warn: host.iobroker instance system.adapter.pvforecast.0 terminated due to SIGKILL
                          2024-11-03 12:38:03.586  - info: host.iobroker instance system.adapter.pvforecast.0 terminated with code null ()
                          2024-11-03 12:38:03.619  - warn: host.iobroker instance system.adapter.homeconnect.0 terminated due to SIGKILL
                          2024-11-03 12:38:03.619  - info: host.iobroker instance system.adapter.homeconnect.0 terminated with code null ()
                          2024-11-03 12:38:03.620  - warn: host.iobroker instance system.adapter.iot.0 terminated due to SIGKILL
                          2024-11-03 12:38:03.620  - info: host.iobroker instance system.adapter.iot.0 terminated with code null ()
                          2024-11-03 12:38:03.676  - warn: host.iobroker instance system.adapter.iot.1 terminated due to SIGKILL
                          2024-11-03 12:38:03.676  - info: host.iobroker instance system.adapter.iot.1 terminated with code null ()
                          2024-11-03 12:38:03.676  - warn: host.iobroker instance system.adapter.openknx.0 terminated due to SIGKILL
                          2024-11-03 12:38:03.676  - info: host.iobroker instance system.adapter.openknx.0 terminated with code null ()
                          2024-11-03 12:38:03.709  - warn: host.iobroker instance system.adapter.javascript.0 terminated due to SIGKILL
                          2024-11-03 12:38:03.709  - info: host.iobroker instance system.adapter.javascript.0 terminated with code null ()
                          2024-11-03 12:38:03.709  - info: host.iobroker instance system.adapter.influxdb.0 terminated with code 0 (NO_ERROR)
                          2024-11-03 12:38:03.749  - info: host.iobroker.compactgroup1 terminated
                          2024-11-03 12:38:03.959  - info: host.iobroker instance system.adapter.history.0 terminated with code 0 (NO_ERROR)
                          2024-11-03 12:38:03.959  - info: host.iobroker instance system.adapter.node-red.0 terminated with code 0 (NO_ERROR)
                          2024-11-03 12:38:05.051  - info: host.iobroker compactgroup controller 1 terminated with code 1 (JS_CONTROLLER_STOPPED)
                          2024-11-03 12:38:05.170  - info: host.iobroker All instances are stopped.
                          2024-11-03 12:38:05.369  - info: host.iobroker terminated
                          iob diag has finished.
                          Press any key for a summary
                            Beizeiten den Container mit Bookkworm / Debian 12 betreiben. Bullseye ist tot.
                            Setz den User 'wald' in die Gruppe 'adm' und 'iobroker' rein.
                            sudo usermod -a -G adm,iobroker wald
                            exit
                            Warum nicht?
                            Warum hantierst du da mit einer Alpha-Version von vis-2 herum?
                            Gleiche gilt für vis1:
                            Pending Updates: 20
                            System auf Stand bringen.
                            iob stop
                            sudo apt update && sudo apt full-upgrade
                            Dann Container neustarten und die stabilen Versionen von vis2 und vis1 installieren.
                              TimoWald @Thomas Braun last edited by TimoWald
                              @thomas-braun said in Vis2 Adapter macht Probleme.:
                              Wie kann ich diesen Updaten? Und wie installiere ich die stabilen Versionen von Vis2?
                              Thomas Braun OliverIO 3 Replies Last reply Reply Quote 0
                                Muss dir einer der Container-Kapitäne sagen.
                                  iob update
                                  iob upgrade vis@1.5.6
                                  iob upgrade vis-2@2.9.64
                                    Mit diesen Befehlen ist der VIS2 schonmal grün und aktuell.
                                    Jetzt mus ich nur noch rausbekommen wie ich den Container Update.
                                    • OliverIO
                                      OliverIO @TimoWald last edited by
                                      Wie kann ich diesen updaten?
                                      Indem du ein aktuelleres Image auswählst:
                                      https://hub.docker.com/layers/buanet/iobroker/v10.0.0/images/sha256-8261681190598bcaf5483779b1093e8d8a1a64be0d9e73c5df51287cea66b364?context=explore
                                        TimoWald @OliverIO last edited by
                                        @oliverio Sorry hier bin ich überfragt. Wo wähle ich das aus. Mein IOB läuft auf Proxmox.
                                        • OliverIO
                                          OliverIO @TimoWald last edited by OliverIO
                                          @timowald
                                          Als Docker Container oder als LXC Container oder als vm ?
                                            @oliverio LXC
                                            598
