    4. [gelöst] adapter.discovery Exception-Code: EADDRINUSE
      bornholm last edited by bornholm
      In einer neuen ioBroker-Installation auf einem debian bookworm habe ich einen Fehler beim Ausführen von adapter.discovery:
      Exception-Code: EADDRINUSE: addMembership EADDRINUSE
      Welche IP oder welchen Port möchte discovery da verwenden und kann nicht?
      Die Oberfläche unter http://kaczmarek.local:8081 ist erreichbar.
      iob diag:
      bash
      Script v.2024-10-19
      *** BASE SYSTEM ***
       Static hostname: kaczmarek
             Icon name: computer-desktop
               Chassis: desktop 🖥
                Kernel: Linux 6.1.0-26-amd64
          Architecture: x86-64
       Hardware Vendor: PC Engines
        Hardware Model: APU2
      Firmware Version: 4.0.7
      OS is similar to:
      model name      : AMD GX-412TC SOC
      Docker          : false
      Virtualization  : none
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
       20:32:30 up  1:17,  3 users,  load average: 0.46, 0.19, 0.20
      CPU threads: 4
      *** LIFE CYCLE STATUS ***
      Operating System is the current Debian stable version codenamed 'bookworm'!
      *** TIME AND TIMEZONES ***
                     Local time: Tue 2024-11-05 20:32:30 CET
                 Universal time: Tue 2024-11-05 19:32:30 UTC
                       RTC time: Tue 2024-11-05 19:32:30
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      faxel
      OPENHAB_HOME=/usr/share/openhab
      HOME=/home/faxel
      GROUPS=faxel cdrom floppy sudo audio dip video plugdev users netdev iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video plugdev bluetooth
      *** DISPLAY-SERVER SETUP ***
      Display-Server: false
      Desktop:
      Terminal:
      *** MEMORY ***
      Mem:            4.1G        902M        2.0G        3.5M        1.5G        3.2G
      Swap:           1.0G          0B        1.0G
      Total:          5.1G        902M        3.0G
      Active iob-Instances:   5
               3898 M total memory
                860 M used memory
                439 M active memory
               1358 M inactive memory
               1879 M free memory
                 68 M buffer memory
               1342 M swap cache
                974 M total swap
                  0 M used swap
                974 M free swap
      top - 20:32:31 up  1:17,  3 users,  load average: 0.46, 0.19, 0.20
      Tasks: 135 total,   1 running, 134 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  0.0 us, 25.0 sy,  0.0 ni, 75.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   3898.6 total,   1878.2 free,    862.1 used,   1410.6 buff/cache
      MiB Swap:    975.0 total,    975.0 free,      0.0 used.   3036.4 avail Mem
      *** FAILED SERVICES ***
        UNIT            LOAD   ACTIVE SUB    DESCRIPTION
      * openhab.service loaded failed failed openHAB - empowering the smart home
      1 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      3 CRITICAL ERRORS DETECTED!
      Check 'sudo dmesg --level=emerg,alert,crit -T' for details
      *** FILESYSTEM ***
      udev           devtmpfs  1.9G     0  1.9G   0% /dev
      tmpfs          tmpfs     390M  944K  389M   1% /run
      /dev/sda1      ext4       58G  7.5G   48G  14% /
      tmpfs          tmpfs     2.0G     0  2.0G   0% /dev/shm
      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
      tmpfs          tmpfs     390M     0  390M   0% /run/user/0
      [Tue Nov  5 19:15:11 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
      [Tue Nov  5 19:15:12 2024] EXT4-fs (sda1): re-mounted. Quota mode: none.
      Show mounted filesystems:
      TARGET SOURCE    FSTYPE OPTIONS
      /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
      /var:
      919M    /var/
      394M    /var/lib
      245M    /var/log
      226M    /var/log/journal/c78b9d697fbc44ff97e67909f99e0528
      Archived and active journals take up 15.3M in the file system.
      /opt/iobroker/backups:
      /opt/iobroker/iobroker-data:
      71M     /opt/iobroker/iobroker-data/
      60M     /opt/iobroker/iobroker-data/files
      31M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
      12M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.bd24114f.js
      10M     /opt/iobroker/iobroker-data/objects.jsonl
      7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.0c96b194.chunk.js.map
      5.6M    /opt/iobroker/iobroker-data/files/backitup.admin/custom/static/js/vendors-node_modules_file-saver_dist_FileSaver_min_js-node_modules_react-icons_di_index_mjs-n-f0ed96.6c33ff1f.chunk.js
      5.5M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-2d33e4.42bb0640.chunk.js.map
      USB-Devices by-id:
      No Devices found 'by-id'
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.18.0
      /usr/bin/node           v20.18.0
      /usr/bin/corepack       0.29.3
      nodejs:
        Installed: 20.18.0-1nodesource1
        Candidate: 20.18.0-1nodesource1
        Version table:
       *** 20.18.0-1nodesource1 600
              500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
              100 /var/lib/dpkg/status
           20.17.0-1nodesource1 600
           20.16.0-1nodesource1 600
           20.15.1-1nodesource1 600
           20.15.0-1nodesource1 600
           20.14.0-1nodesource1 600
           20.13.1-1nodesource1 600
           20.13.0-1nodesource1 600
           20.12.2-1nodesource1 600
           20.12.1-1nodesource1 600
           20.12.0-1nodesource1 600
           20.11.1-1nodesource1 600
           20.11.0-1nodesource1 600
           20.10.0-1nodesource1 600
           20.9.0-1nodesource1 600
           20.8.1-1nodesource1 600
           20.8.0-1nodesource1 600
           20.7.0-1nodesource1 600
           20.6.1-1nodesource1 600
           20.6.0-1nodesource1 600
           20.5.1-1nodesource1 600
           20.5.0-1nodesource1 600
           20.4.0-1nodesource1 600
           20.3.1-1nodesource1 600
           20.3.0-1nodesource1 600
           20.2.0-1nodesource1 600
           20.1.0-1nodesource1 600
           20.0.0-1nodesource1 600
           18.19.0+dfsg-6~deb12u2 500
              500 http://deb.debian.org/debian bookworm/main amd64 Packages
           18.19.0+dfsg-6~deb12u1 500
              500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      kaczmarek           kaczmarek (version: 6.0.11, hostname: kaczmarek     , alive, uptime: 3997)
      Core adapters versions
      js-controller:  6.0.11
      admin:          7.1.5
      javascript:     "javascript" not found
      Adapter State
      + system.adapter.admin.0                  : admin                 : kaczmarek                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.backitup.0               : backitup              : kaczmarek                                -  enabled
      + system.adapter.discovery.0              : discovery             : kaczmarek                                -  enabled
      + system.adapter.mqtt-client.0            : mqtt-client           : kaczmarek                                -  enabled, port: 1883
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 7.1.5    , installed 7.1.5
      Adapter    "backitup"     : 3.0.25   , installed 3.0.25
      Adapter    "discovery"    : 5.0.0    , installed 5.0.0
      Controller "js-controller": 6.0.11   , installed 6.0.11
      Adapter    "mqtt-client"  : 2.0.0    , installed 2.0.0
      Objects and States
      Objects:        170
      States:         126
      Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:3 http://deb.debian.org/debian bookworm-backports InRelease
      Hit:4 http://security.debian.org/debian-security bookworm-security InRelease
      Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
      Hit:6 https://openhab.jfrog.io/artifactory/openhab-linuxpkg stable InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:8089            0.0.0.0:*               LISTEN      0          16881      512/node
      tcp        0      0 192.168.0.131:49152     0.0.0.0:*               LISTEN      106        18614      607/gerbera
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      105        690        522/mosquitto
      tcp        0      0 0.0.0.0:5355            0.0.0.0:*               LISTEN      995        529        397/systemd-resolve
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       23211      3420/iobroker.js-co
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       23206      3420/iobroker.js-co
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          18122      521/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          339        1/init
      tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          18679      755/lighttpd
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       26609      3662/io.admin.0
      tcp6       0      0 :::1883                 :::*                    LISTEN      105        691        522/mosquitto
      tcp6       0      0 :::5355                 :::*                    LISTEN      995        537        397/systemd-resolve
      tcp6       0      0 fe80::f7d5:d386:e:49152 :::*                    LISTEN      106        18615      607/gerbera
      tcp6       0      0 :::22                   :::*                    LISTEN      0          18133      521/sshd: /usr/sbin
      tcp6       0      0 :::111                  :::*                    LISTEN      0          14596      1/init
      tcp6       0      0 :::80                   :::*                    LISTEN      0          18678      755/lighttpd
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           106        18619      607/gerbera
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          15446      1/init
      udp        0      0 127.0.0.1:58576         0.0.0.0:*                           106        18616      607/gerbera
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           102        16545      460/avahi-daemon: r
      udp        0      0 0.0.0.0:5355            0.0.0.0:*                           995        528        397/systemd-resolve
      udp        0      0 0.0.0.0:44283           0.0.0.0:*                           102        16547      460/avahi-daemon: r
      udp6       0      0 :::1900                 :::*                                106        18621      607/gerbera
      udp6       0      0 :::1900                 :::*                                106        18620      607/gerbera
      udp6       0      0 :::36957                :::*                                102        16548      460/avahi-daemon: r
      udp6       0      0 :::111                  :::*                                0          15447      1/init
      udp6       0      0 fe80::f7d5:d386:e1c:546 :::*                                0          18201      475/NetworkManager
      udp6       0      0 :::5353                 :::*                                102        16546      460/avahi-daemon: r
      udp6       0      0 :::5355                 :::*                                995        536        397/systemd-resolve
      udp6       0      0 :::30000                :::*                                107        16640      505/minetestserver
      2024-11-05 19:59:57.112  - info: discovery.0 (4153) Done discovering upnp devices. 49 packages received
      2024-11-05 19:59:57.852  - info: discovery.0 (4153) Done discovering ping devices. 9 packages received
      2024-11-05 19:59:57.879  - info: discovery.0 (4153) Found 15 addresses
      2024-11-05 20:00:56.010  - error: discovery.0 (4153) uncaught exception: addMembership EADDRINUSE
      2024-11-05 20:00:56.016  - error: discovery.0 (4153) Error: addMembership EADDRINUSE
          at Socket.addMembership (node:dgram:865:11)
          at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.discovery/lib/adapters/sma-em.js:94:20)
          at Socket.onListening (node:dgram:261:7)
          at Socket.emit (node:events:519:28)
          at startListening (node:dgram:184:10)
          at node:dgram:375:7
          at process.processTicksAndRejections (node:internal/process/task_queues:83:21)
      2024-11-05 20:00:56.018  - error: discovery.0 (4153) Exception-Code: EADDRINUSE: addMembership EADDRINUSE
      2024-11-05 20:00:56.531  - info: discovery.0 (4153) terminating
      2024-11-05 20:00:56.536  - warn: discovery.0 (4153) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2024-11-05 20:00:57.031  - info: discovery.0 (4153) terminating
      2024-11-05 20:00:57.157  - error: host.kaczmarek instance system.adapter.discovery.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2024-11-05 20:00:57.162  - info: host.kaczmarek Restart adapter system.adapter.discovery.0 because enabled
      2024-11-05 20:01:03.485  - info: admin.0 (3662) <== Disconnect system.user.admin from 2003:cb:5705:1500:3207:e648:b5a:191 admin
      2024-11-05 20:01:03.534  - info: admin.0 (3662) ==> Connected system.user.admin from 2003:cb:5705:1500:3207:e648:b5a:191
      2024-11-05 20:01:03.603  - info: admin.0 (3662) <== Disconnect system.user.admin from 2003:cb:5705:1500:3207:e648:b5a:191 admin
      2024-11-05 20:01:04.089  - info: admin.0 (3662) ==> Connected system.user.admin from 2003:cb:5705:1500:3207:e648:b5a:191
      2024-11-05 20:01:28.010  - info: host.kaczmarek instance system.adapter.discovery.0 in version "5.0.0" started with pid 4458
      2024-11-05 20:01:32.239  - info: discovery.0 (4458) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      2024-11-05 20:01:32.531  - info: discovery.0 (4458) starting. Version 5.0.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v20.18.0, js-controller: 6.0.11
      EADDRINUSE
        Thomas Braun Most Active @bornholm last edited by
        @bornholm sagte in adapter.discovery Exception-Code: EADDRINUSE:
        Schau dir diese Fehler genauer an.
          bornholm @Thomas Braun last edited by
          @thomas-braun sagte in adapter.discovery Exception-Code: EADDRINUSE:
          Danke für den Hinweis.
          dmesg sagt da das Folgende:
          [Di,  5. Nov 2024, 19:15:05] __common_interrupt: 1.55 No irq handler for vector
          [Di,  5. Nov 2024, 19:15:05] __common_interrupt: 2.55 No irq handler for vector
          [Di,  5. Nov 2024, 19:15:05] __common_interrupt: 3.55 No irq handler for vector
          Diese Fehler kann man wohl ignorieren. Sie treten seit Jahren mit bestimmten AMD CPUs auf und haben laut diverser Netzfundstellen keine Auswirkungen.
            Etwas mehr Logbuch:
            2024-11-06 00:04:16.295  - error: discovery.0 (10404) Error: addMembership EADDRINUSE
                at node:dgram:375:7
            2024-11-06 00:04:16.297  - error: discovery.0 (10404) Exception-Code: EADDRINUSE: addMembership EADDRINUSE
            Kann man den Loglevel eigentlich erhöhen um mehr zu sehen?
              Ja, auf debug und als höchste Stufe noch auf silly.
              Da scheint es aber bei sma-em zu haken.
                Wo denn ? 😉
                In sma-em.js:94 scheitert dann wohl ein client.addMembership
                    // Bind socket to the multicast address on all ipv4 devices except localhost
                    client.bind(MULTICAST_PORT, () => {
                        const addresses = tools.getIP4addresses();
                        for (const dev of addresses) {
                            debug && options.log.debug(`Listen via UDP on Device ${dev.name} with IP ${dev.ip} on Port ${MULTICAST_PORT} for Multicast IP ${MULTICAST_IP}`);
                            client.addMembership(MULTICAST_IP, dev.ip);
                Und bei "multicast" dachte ich: komisch, falsches Netzwerk? Und schaute in die Networkmanager Konfiguration, da schau her:
                [ipv4]
                address1=192.168.0.131/32,192.168.0.10
                address2=192.168.0.131/24
                Keine Ahnung wie der Unsinn da rein kommt, die APU Box hatte ich für verschiedenen Basteleien verwendet. War wahrscheinlich mal wieder zu spät 😃
                Nachdem das /24 richtig drin steht ist der discovery Fehler verschwunden.
