    4. Zigbee keine Werte und Schalter mehr vorhanden
      chrisweber last edited by
      • Adaptername: zigbee
      • Hardwaresystem: vm
      • Arbeitsspeicher: 8xGB
      • Festplattenart: SD-Karte, SSD, HDD, ...
      • Installationsart: Skript
      • Image, Docker genutzt: Nein
        OS: Debian bookworm 6.1.106-3 (2024-08-26) x86_64 GNU/Linux
        npm -v: 10.8.2
        node -v v20.17.0
        zigbee: v1.10.12
        admin: v7.2.6
        nodejs: 20.18.0
        zigbee Stick USB, Texas_Instruments_TI_CC2531
      zigbee.0
      2024-11-08 11:13:59.401 info List of port: [{"path":"/dev/ttyACM0","manufacturer":"Texas Instruments","serialNumber":"__0X00124B001938A1BB","pnpId":"usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001938A1BB-if00","vendorId":"0451","productId":"16a8"},{"path":"/dev/ttyS0"},{"path":"/dev/ttyS1"},{"path":"/dev/ttyS2"},{"path":"/dev/ttyS3"}]
      zigbee.0
      2024-11-08 11:13:48.120 info List of port: [{"path":"/dev/ttyACM0","manufacturer":"Texas Instruments","serialNumber":"__0X00124B001938A1BB","pnpId":"usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001938A1BB-if00","vendorId":"0451","productId":"16a8"},{"path":"/dev/ttyS0"},{"path":"/dev/ttyS1"},{"path":"/dev/ttyS2"},{"path":"/dev/ttyS3"}]
      zigbee.0
      2024-11-08 11:12:37.675 info debug devices set to []
      zigbee.0
      2024-11-08 11:12:37.629 info Zigbee started
      zigbee.0
      2024-11-08 11:12:37.629 info 0x00158d000423457a (addr 64138): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
      zigbee.0
      2024-11-08 11:12:37.629 info 0x00158d00044455e5 (addr 3197): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
      zigbee.0
      2024-11-08 11:12:37.616 info 0x00158d00044b345f (addr 52044): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
      zigbee.0
      2024-11-08 11:12:37.578 info Currently 14 devices are joined:
      zigbee.0
      2024-11-08 11:12:37.573 info --> transmitPower : normal
      zigbee.0
      2024-11-08 11:12:37.572 info Unable to disable LED, unsupported function.
      zigbee.0
      2024-11-08 11:12:37.572 info Coordinator firmware version: {"type":"zStack12","meta":{"transportrev":2,"product":0,"majorrel":2,"minorrel":6,"maintrel":3,"revision":20190608}}
      zigbee.0
      2024-11-08 11:12:37.123 info Installed Version: iobroker.zigbee@1.10.12
      zigbee.0
      2024-11-08 11:12:37.000 info Starting Zigbee npm ...
      zigbee.0
      2024-11-08 11:12:36.998 info delete old Backup files. keep only last 10
      zigbee.0
      2024-11-08 11:12:36.936 info starting. Version 1.10.12 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.18.0, js-controller: 6.0.11
      Zu meinem Problem:
      Im zigbee-tab sind alle Geräte aufgeführt, mit Bildern, aber es sind weder Werte (z.B. Temperatur) noch die Schalter (Steckdosen) zum ein-aus schalten vorhanden.
      Ich habe 2 verschiedene (Hardware-)Systeme mit dem identischen zigbee Problem
      Ich bin nicht ganz sicher, glaube aber nach dem letzten Update von Debian und iobroker ist das Problem aufgetreten.
      woran kann es liegen?
      Danke schon mal vorab für Tips
      crunchip Thomas Braun 2 Replies Last reply Reply Quote 0
      • crunchip
        crunchip Forum Testing Most Active @chrisweber last edited by
        @chrisweber sagte in Zigbee keine Werte und Schalter mehr vorhanden:
        zigbee: v1.10.12
        https://forum.iobroker.net/topic/77517/test-adapter-iobroker-zigbee-1-10-10
          Thomas Braun Most Active @chrisweber last edited by
          Ich würde vielleicht auch ein paar Euro in einen aktuellen ZigBee-Stick investieren.
            chrisweber @Thomas Braun last edited by
            ja, das mag sicher der bessere und aktuellere Stick sein. Aber es sind ja nicht nur die paar Euro. Hauptsächlich muss man ja den ganzen "Anlernaufwand" wieder treiben.
            Wobei ich mir nicht sicher bin, ob das die Lösung ist. Der Stick den ich habe, tut ja seinen Dienst sehr gut.
            Ich kann alles schalten per Script und wenn ich in den Objekten das richtige Gerät gefunden habe, auch dort.
            Hier geht es ja nur um eine "halbe" Anzeige im Adapter selber. 🙂
            black.falcon87 1 Reply Last reply Reply Quote 0
              chrisweber @crunchip last edited by
              @crunchip
              Ja Danke für den Link. Ich habe es gemacht. Falles es dich interessiert, es hat nicht geklappt.
              Downgrade auf 1.10.9 ging nicht, aber 1.10.3 hat funktioniert. Adapter ist nicht gestartet, nach dem Kopieren alter Daten des gesamten zigbee_0 Verzeichnisses vom Backup vor 2 Wochen, startet der Adapter auch wieder. Aber das Problem ist nachwievor das Gleiche, im Adapter werden nur die Geräte gezeigt, keine Daten oder Schalter sind zu sehen.
              Ich denke, ich lass es jetzt so, ist ja nicht funktionslos, sondern nur etwas umständlich 🙂
              • black.falcon87
                black.falcon87 @chrisweber last edited by
                Muss man Zigbee Geräte echt alle manuell komplett neu anlernen wenn der Stick getauscht wird? 😵
                • crunchip
                  @black-falcon87 kommt auf die Stick`s alt/neu(Chipsatz) an
                    Thomas Braun Most Active @black.falcon87 last edited by
                    @black-falcon87 sagte in Zigbee keine Werte und Schalter mehr vorhanden:
                    Klares jein.
                    Hängt davon ab was genau da getauscht werden soll.
                    Bei gleichem Chipsatz geht es ggfls. auch per Backup, wenn komplett andere Hardware verwendet wird muss neu angelernt werden.
