    4. npm Fehlermeldung
    npm Fehlermeldung
      MyMeyer last edited by
      Hallo ,
      leider kann ich den Adapter "EgiGeoZone2" nicht aktualisieren.
      Siehe Fehlermeldung:
      $ iobroker upgrade egigeozone2@1.0.7 --debug
      Update egigeozone2 from @1.0.6 to @1.0.7
      NPM version: 10.8.2
      Installing iobroker.egigeozone2@1.0.7... (System call)
      npm error code 1npm error git dep preparation failednpm error command /usr/bin/node /usr/lib/node_modules/npm/bin/npm-cli.js install --force --cache=/home/iobroker/.npm --prefer-offline=false --prefer-online=false --offline=false --no-progress --no-save --no-audit --include=dev --include=peer --include=optional --no-package-lock-only --no-dry-runnpm error > @serialport/bindings@9.2.8 installnpm error > prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuildnpm errornpm errornpm error make: Verzeichnis �/home/iobroker/.npm/_cacache/tmp/git-cloneUJsdpa/node_modules/@serialport/bindings/build� wird betretennpm error CXX(target) Release/obj.target/bindings/src/serialport.onpm error make: Verzeichnis �/home/iobroker/.npm/_cacache/tmp/git-cloneUJsdpa/node_modules/@serialport/bindings/build� wird verlassen
      npm error npm warn using --force Recommended protections disabled.npm error prebuild-install WARN install No prebuilt binaries found (target=20.18.0 runtime=node arch=x64 libc= platform=linux)npm error gyp info it worked if it ends with oknpm error gyp info using node-gyp@10.1.0npm error gyp info using node@20.18.0 | linux | x64npm error gyp info find Python using Python version 3.9.2 found at "/usr/bin/python3"npm error gyp info spawn /usr/bin/python3npm error gyp info spawn args [npm error gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',npm error gyp info spawn args 'binding.gyp',npm error gyp info spawn args '-f',npm error gyp info spawn args 'make',npm error gyp info spawn args '-I',npm error gyp info spawn args '/home/iobroker/.npm/_cacache/tmp/git-cloneUJsdpa/node_modules/@serialport/bindings/build/config.gypi',npm error gyp info spawn args '-I',npm error gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',npm error gyp info spawn args '-I',npm error gyp info spawn args '/home/iobroker/.cache/node-gyp/20.18.0/include/node/common.gypi',npm error gyp info spawn args '-Dlibrary=shared_library',npm error gyp info spawn args '-Dvisibility=default',npm error gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/20.18.0',npm error gyp info spawn args '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',npm error gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/20.18.0/<(target_arch)/node.lib',npm error gyp info spawn args '-Dmodule_root_dir=/home/iobroker/.npm/_cacache/tmp/git-cloneUJsdpa/node_modules/@serialport/bindings',npm error gyp info spawn args '-Dnode_engine=v8',npm error gyp info spawn args '--depth=.',npm error gyp info spawn args '--no-parallel',npm error gyp info spawn args '--generator-output',npm error gyp info spawn args 'build',npm error gyp info spawn args '-Goutput_dir=.'npm error gyp info spawn args ]npm error gyp info spawn makenpm error gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]npm error In file included from ../../../nan/nan.h:180,npm error from ../src/./serialport.h:13,npm error from ../src/serialport.cpp:1:npm error ../../../nan/nan_callbacks.h:55:23: error: 'AccessorSignature' is not a member of 'v8'npm error 55 | typedef v8::Localv8::AccessorSignature Sig;npm error | ^~~~~~~~~~~~~~~~~npm error ../../../nan/nan_callbacks.h:55:40: error: template argument 1 is invalidnpm error 55 | typedef v8::Localv8::AccessorSignature Sig;npm error | ^npm error ../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)':npm error ../src/serialport.cpp:78:51: warning: cast between incompatible function types from 'void ()(uv_work_t)' {aka 'void ()(uv_work_s)'} to 'uv_after_work_cb' {aka 'void ()(uv_work_s, int)'} [-Wcast-function-type]npm error 78 | uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);npm error | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~npm error ../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)':npm error ../src/serialport.cpp:135:53: warning: cast between incompatible function types from 'void ()(uv_work_t)' {aka 'void ()(uv_work_s)'} to 'uv_after_work_cb' {aka 'void ()(uv_work_s, int)'} [-Wcast-function-type]npm error 135 | uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);npm error | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~npm error ../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)':npm error ../src/serialport.cpp:175:52: warning: cast between incompatible function types from 'void ()(uv_work_t)' {aka 'void ()(uv_work_s)'} to 'uv_after_work_cb' {aka 'void ()(uv_work_s, int)'} [-Wcast-function-type]npm error 175 | uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);npm error | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~npm error ../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)':npm error ../src/serialport.cpp:215:52: warning: cast between incompatible function types from 'void ()(uv_work_t)' {aka 'void ()(uv_work_s)'} to 'uv_after_work_cb' {aka 'void ()(uv_work_s, int)'} [-Wcast-function-type]npm error 215 | uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);npm error | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~npm error ../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)':npm error ../src/serialport.cpp:271:50: warning: cast between incompatible function types from 'void ()(uv_work_t)' {aka 'void ()(uv_work_s)'} to 'uv_after_work_cb' {aka 'void ()(uv_work_s, int)'} [-Wcast-function-type]npm error 271 | uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);npm error | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~npm error ../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)':npm error ../src/serialport.cpp:316:50: warning: cast between incompatible function types from 'void ()(uv_work_t)' {aka 'void ()(uv_work_s)'} to 'uv_after_work_cb' {aka 'void ()(uv_work_s, int)'} [-Wcast-function-type]npm error 316 | uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);npm error | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~npm error ../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)':npm error ../src/serialport.cpp:366:58: warning: cast between incompatible function types from 'void ()(uv_work_t)' {aka 'void ()(uv_work_s)'} to 'uv_after_work_cb' {aka 'void ()(uv_work_s, int)'} [-Wcast-function-type]npm error 366 | uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);npm error | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~npm error ../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)':npm error ../src/serialport.cpp:412:52: warning: cast between incompatible function types from 'void ()(uv_work_t)' {aka 'void ()(uv_work_s)'} to 'uv_after_work_cb' {aka 'void ()(uv_work_s, int)'} [-Wcast-function-type]npm error 412 | uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);npm error | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~npm error ../src/serialport.cpp: At global scope:npm error ../src/serialport.cpp:433:28: warning: unnecessary parentheses in declaration of 'ToParityEnum' [-Wparentheses]npm error 433 | SerialPortParity NAN_INLINE(ToParityEnum(const v8::Localv8::String& v8str)) {npm error | ^npm error ../src/serialport.cpp:452:30: warning: unnecessary parentheses in declaration of 'ToStopBitEnum' [-Wparentheses]npm error 452 | SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {npm error | ^npm error In file included from ../../../nan/nan.h:60,npm error from ../src/./serialport.h:13,npm error from ../src/serialport.cpp:1:npm error /home/iobroker/.cache/node-gyp/20.18.0/include/node/node.h:1232:7: warning: cast between incompatible function types from 'void ()(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)' {aka 'void ()(v8::Localv8::Object)'} to 'node::addon_register_func' {aka 'void ()(v8::Localv8::Object, v8::Localv8::Value, void)'} [-Wcast-function-type]npm error 1232 | (node::addon_register_func) (regfunc), \npm error | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~npm error /home/iobroker/.cache/node-gyp/20.18.0/include/node/node.h:1266:3: note: in expansion of macro 'NODE_MODULE_X'npm error 1266 | NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage)npm error | ^~~~~~~~~~~~~npm error ../src/serialport.cpp:486:1: note: in expansion of macro 'NODE_MODULE'npm error 486 | NODE_MODULE(serialport, init);npm error | ^~~~~~~~~~~npm error make: *** [bindings.target.mk:111: Release/obj.target/bindings/src/serialport.o] Fehler 1npm error gyp ERR! build error npm error gyp ERR! stack Error: make failed with exit code: 2npm error gyp ERR! stack at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:209:23)npm error gyp ERR! System Linux 5.10.0-33-amd64npm error gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm error gyp ERR! cwd /home/iobroker/.npm/_cacache/tmp/git-cloneUJsdpa/node_modules/@serialport/bindingsnpm error gyp ERR! node -v v20.18.0npm error gyp ERR! node-gyp -v v10.1.0npm error gyp ERR! not ok npm error npm error code 1npm error npm error path /home/iobroker/.npm/_cacache/tmp/git-cloneUJsdpa/node_modules/@serialport/bindingsnpm error npm error command failednpm error npm error command sh -c prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuildnpm error npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-11-09T08_35_15_677Z-debug-0.lognpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-11-09T08_34_58_960Z-debug-0.log
      upload [13] egigeozone2.admin /opt/iobroker/node_modules/iobroker.egigeozone2/admin/egigeozone.png egigeozone.png image/png
      upload [11] egigeozone2.admin /opt/iobroker/node_modules/iobroker.egigeozone2/admin/i18n/en/translations.json i18n/en/translations.json application/json
      upload [10] egigeozone2.admin /opt/iobroker/node_modules/iobroker.egigeozone2/admin/i18n/es/translations.json i18n/es/translations.json application/json
      upload [7] egigeozone2.admin /opt/iobroker/node_modules/iobroker.egigeozone2/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
      upload [6] egigeozone2.admin /opt/iobroker/node_modules/iobroker.egigeozone2/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
      upload [0] egigeozone2.admin /opt/iobroker/node_modules/iobroker.egigeozone2/admin/words.js words.js application/javascript
      Process exited with code 0
      iobroker fix , habe ich bereits laufen lassen. Hat aber nicht gebracht.
      Ich hänge nochmal das Log mit an:
      2024-10-29T20_22_48_970Z-debug-0.log
        Thomas Braun Most Active @MyMeyer last edited by Thomas Braun
        @mymeyer
        Da kann serialport nicht gebaut werden.
        Build Environment vorhanden?
        Grundsätzlich ist der Adapter nämlich installierbar:
        $ iobroker add egigeozone2 auto --host chet --debug
        (node:39336) ExperimentalWarning: CommonJS module /usr/lib/node_modules/npm/node_modules/debug/src/node.js is loading ES Module /usr/lib/node_modules/npm/node_modules/supports-color/index.js using require().
        Support for loading ES Module in require() is an experimental feature and might change at any time(Use `node --trace-warnings ...` to show where the warning was created)
        added 1 package in 25s
        215 packages are looking for funding run `npm fund` for details
        host.chet install adapter egigeozone2
        upload [12] egigeozone2.admin /opt/iobroker/node_modules/iobroker.egigeozone2/admin/i18n/de/translations.json i18n/de/translations.json application/json
        upload [9] egigeozone2.admin /opt/iobroker/node_modules/iobroker.egigeozone2/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
        upload [5] egigeozone2.admin /opt/iobroker/node_modules/iobroker.egigeozone2/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
        upload [4] egigeozone2.admin /opt/iobroker/node_modules/iobroker.egigeozone2/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
        upload [3] egigeozone2.admin /opt/iobroker/node_modules/iobroker.egigeozone2/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
        upload [2] egigeozone2.admin /opt/iobroker/node_modules/iobroker.egigeozone2/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
        upload [1] egigeozone2.admin /opt/iobroker/node_modules/iobroker.egigeozone2/admin/jsonConfig.json jsonConfig.json application/json
        Updating objects from io-package.json for adapter "egigeozone2" with version "1.0.7"
        host.chet object system.adapter.egigeozone2.0.connected created
        host.chet object system.adapter.egigeozone2.0.compactMode created
        host.chet object system.adapter.egigeozone2.0.cpu created
        host.chet object system.adapter.egigeozone2.0.cputime created
        host.chet object system.adapter.egigeozone2.0.memHeapUsed created
        host.chet object system.adapter.egigeozone2.0.memHeapTotal created
        host.chet object system.adapter.egigeozone2.0.memRss created
        host.chet object system.adapter.egigeozone2.0.uptime created
        host.chet object system.adapter.egigeozone2.0.inputCount created
        host.chet object system.adapter.egigeozone2.0.outputCount created
        host.chet object system.adapter.egigeozone2.0.sigKill created
        host.chet object system.adapter.egigeozone2.0.logLevel created
        host.chet object egigeozone2.0.info created
        host.chet object egigeozone2.0.info.connection created
        host.chet object egigeozone2.0.atHome created
        host.chet object egigeozone2.0.atHomeCount created
        host.chet Set default value of egigeozone2.0.info.connection: false
        host.chet Set default value of egigeozone2.0.atHome:
        host.chet Set default value of egigeozone2.0.atHomeCount: 0
        host.chet object system.adapter.egigeozone2.0 created
          MyMeyer @Thomas Braun last edited by
          @thomas-braun sagte in npm Fehlermeldung:
          Build Environment
          Hi Sorry "Build Environment" sagt mir nichts gerade. Was kann ich wo prüfen ?
            @mymeyer
            Wie und wo biste denn da unterwegs? Die Ausgabe von
            iob diag
            wäre hilfreich.
              @thomas-braun 🙂 na dann schaue ich mal. Ähh den "iob diag" kannte ich. ✌
                MyMeyer @Thomas Braun last edited by MyMeyer
                Hmm...sieht für mich alles normal aus.
                ========== Start marking the full check here ===========
                Script v.2024-10-19
                *** BASE SYSTEM ***
                   Static hostname: iobroker
                         Icon name: computer-vm
                           Chassis: vm
                    Virtualization: kvm
                  Operating System: Debian GNU/Linux 11 (bullseye)
                            Kernel: Linux 5.10.0-33-amd64
                      Architecture: x86-64
                OS is similar to:
                model name	: Common KVM processor
                Docker          : false
                Virtualization  : kvm
                Kernel          : x86_64
                Userland        : 64 bit
                Systemuptime and Load:
                 20:18:54 up 9 days,  9:43,  0 users,  load average: 0.25, 0.34, 0.34
                CPU threads: 12
                *** LIFE CYCLE STATUS ***
                Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
                *** TIME AND TIMEZONES ***
                               Local time: Sat 2024-11-09 20:18:54 CET
                           Universal time: Sat 2024-11-09 19:18:54 UTC
                                 RTC time: Sat 2024-11-09 19:18:55
                              NTP service: active
                          RTC in local TZ: no
                *** Users and Groups ***
                User that called 'iob diag':
                michael
                HOME=/home/michael
                GROUPS=michael cdrom floppy sudo audio dip video plugdev netdev redis iobroker
                iobroker
                HOME=/home/iobroker
                GROUPS=iobroker tty dialout audio video plugdev redis
                *** DISPLAY-SERVER SETUP ***
                Display-Server: false
                Desktop:
                Terminal: 	tty
                *** MEMORY ***
                Mem:             15G        4.1G        9.7G        0.0K        2.2G         11G
                Swap:           4.1G          0B        4.1G
                Total:           20G        4.1G         13G
                Active iob-Instances: 	52
                        15996 M total memory
                         4140 M used memory
                         1089 M active memory
                         4554 M inactive memory
                         9699 M free memory
                          481 M buffer memory
                         1674 M swap cache
                         4093 M total swap
                            0 M used swap
                         4093 M free swap
                top - 20:18:54 up 9 days,  9:43,  0 users,  load average: 0.25, 0.34, 0.34
                Tasks: 181 total,   1 running, 180 sleeping,   0 stopped,   0 zombie
                %Cpu(s):  2.1 us,  1.1 sy,  0.0 ni, 95.8 id,  0.0 wa,  0.0 hi,  0.0 si,  1.1 st
                MiB Mem :  15996.4 total,   9699.5 free,   4140.7 used,   2156.2 buff/cache
                MiB Swap:   4094.0 total,   4094.0 free,      0.0 used.  11524.8 avail Mem
                *** FAILED SERVICES ***
                0 loaded units listed.
                *** DMESG CRITICAL ERRORS ***
                No critical errors detected
                *** FILESYSTEM ***
                udev           devtmpfs  7.8G     0  7.8G   0% /dev
                tmpfs          tmpfs     1.6G  560K  1.6G   1% /run
                /dev/sda1      ext4       28G   20G  6.6G  75% /
                tmpfs          tmpfs     7.9G     0  7.9G   0% /dev/shm
                tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
                tmpfs          tmpfs     1.6G     0  1.6G   0% /run/user/1000
                [Thu Oct 31 10:35:09 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
                [Thu Oct 31 10:35:10 2024] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
                Show mounted filesystems:
                TARGET SOURCE    FSTYPE OPTIONS
                /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
                /var:
                2.1G	/var/
                993M	/var/cache
                984M	/var/cache/apt
                934M	/var/log
                915M	/var/cache/apt/archives
                      Users in the 'systemd-journal' group can see all messages. Pass -q to
                      turn off this notice.
                Archived and active journals take up 264.0M in the file system.
                /opt/iobroker/backups:
                84M	/opt/iobroker/backups/
                /opt/iobroker/iobroker-data:
                1.8G	/opt/iobroker/iobroker-data/
                1.2G	/opt/iobroker/iobroker-data/files
                617M	/opt/iobroker/iobroker-data/files/javascript.admin
                560M	/opt/iobroker/iobroker-data/files/javascript.admin/static
                558M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js
                78M	/opt/iobroker/iobroker-data/objects.jsonl
                51M	/opt/iobroker/iobroker-data/states.json.old
                46M	/opt/iobroker/iobroker-data/objects.json.migrated
                46M	/opt/iobroker/iobroker-data/objects.json.bak.migrated
                38M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
                USB-Devices by-id:
                No Devices found 'by-id'
                HINT:
                Your zigbee.1 COM-Port is NOT matching 'by-id'. Please check your setting:
                tcp
                *** NodeJS-Installation ***
                /usr/bin/nodejs 	v20.18.0
                /usr/bin/node 		v20.18.0
                /usr/bin/npm 		10.8.2
                /usr/bin/npx 		10.8.2
                /usr/bin/corepack 	0.29.3
                nodejs:
                  Installed: 20.18.0-1nodesource1
                  Candidate: 20.18.0-1nodesource1
                  Version table:
                 *** 20.18.0-1nodesource1 1001
                        500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                        100 /var/lib/dpkg/status
                     20.17.0-1nodesource1 1001
                     20.16.0-1nodesource1 1001
                     20.15.1-1nodesource1 1001
                     20.15.0-1nodesource1 1001
                     20.14.0-1nodesource1 1001
                     20.13.1-1nodesource1 1001
                     20.13.0-1nodesource1 1001
                     20.12.2-1nodesource1 1001
                     20.12.1-1nodesource1 1001
                     20.12.0-1nodesource1 1001
                     20.11.1-1nodesource1 1001
                     20.11.0-1nodesource1 1001
                     20.10.0-1nodesource1 1001
                     20.9.0-1nodesource1 1001
                     20.8.1-1nodesource1 1001
                     20.8.0-1nodesource1 1001
                     20.7.0-1nodesource1 1001
                     20.6.1-1nodesource1 1001
                     20.6.0-1nodesource1 1001
                     20.5.1-1nodesource1 1001
                     20.5.0-1nodesource1 1001
                     20.4.0-1nodesource1 1001
                     20.3.1-1nodesource1 1001
                     20.3.0-1nodesource1 1001
                     20.2.0-1nodesource1 1001
                     20.1.0-1nodesource1 1001
                     20.0.0-1nodesource1 1001
                     12.22.12~dfsg-1~deb11u5 500
                        500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
                     12.22.12~dfsg-1~deb11u4 500
                        500 http://ftp.de.debian.org/debian bullseye/main amd64 Packages
                No problems detected
                Errors in npm tree: 0
                *** ioBroker-Installation ***
                ioBroker Status
                Objects type: jsonl
                States  type: redis
                Hosts:
                iobroker            iobroker (version: 6.0.11, hostname: iobroker      , alive, uptime: 38811)
                iobroker-slave      iobroker-slave (version: 6.0.11, hostname: iobroker-slave, alive, uptime: 812218)
                Core adapters versions
                js-controller: 	6.0.11
                admin: 		7.1.5
                javascript: 	8.8.3
                nodejs modules from github: 	7
                +-- iobroker.blink4home@0.1.1 invalid: "https://github.com/Flashy-GER/ioBroker.blink4home/tarball/37aaf54baf0ac76931d00a71459bcb4e47d96b43" from the root project
                +-- iobroker.broadlink@0.1.5 invalid: "https://github.com/hieblmedia/ioBroker.broadlink/tarball/master" from the root project
                +-- iobroker.fully-tablet-control@0.3.3-beta.0 invalid: "https://github.com/xXBJXx/ioBroker.fully-tablet-control/tarball/e8c40673053e31ce4621d33e3ad38bcaae6b452d" from the root project
                |   `-- xmlbuilder@0.4.2 invalid: "https://github.com/hobbyquaker/xmlbuilder-js/tarball/29fe5030dc6852007dc8d1bfd5109d75f8da58d5" from node_modules/homematic-xmlrpc
                +-- iobroker.repetierserver@0.0.3 invalid: "https://github.com/Baumert7269/ioBroker.repetierserver/tarball/256b927316a6394475c990026b7ce27c5d32abe8" from the root project
                | +-- syno@3.0.0 invalid: "git+https://git@github.com/MeisterTR/syno.git" from node_modules/iobroker.synology
                    `-- @rjsf/bootstrap-5@4.2.0 invalid: "https://github.com/nurikk/fileshare/blob/main/rjsf-bootstrap-5-4.2.0.tgz?raw=true" from node_modules/zigbee2mqtt-frontend
                Adapter State
                + system.adapter.adguard.0                : adguard               : iobroker                                 -  enabled
                + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 192.168.1.39, run as: admin
                + system.adapter.alarm.0                  : alarm                 : iobroker                                 -  enabled
                + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
                  system.adapter.alias-manager.0          : alias-manager         : iobroker                                 -  enabled
                + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                + system.adapter.binance.0                : binance               : iobroker                                 -  enabled
                + system.adapter.broadlink2.0             : broadlink2            : iobroker                                 -  enabled
                  system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
                + system.adapter.discovery.0              : discovery             : iobroker-slave                           -  enabled
                + system.adapter.egigeozone2.0            : egigeozone2           : iobroker                                 -  enabled, port: 7999, bind: 0.0.0.0
                + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
                  system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
                + system.adapter.fritzbox.0               : fritzbox              : iobroker                                 -  enabled
                + system.adapter.fully-tablet-control.0   : fully-tablet-control  : iobroker                                 -  enabled
                + system.adapter.heatingcontrol.0         : heatingcontrol        : iobroker                                 -  enabled
                + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
                + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                + system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 80
                  system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                  system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
                  system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 -  enabled
                + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
                + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                  system.adapter.labcom.0                 : labcom                : iobroker                                 -  enabled
                  system.adapter.lgtv11.0                 : lgtv11                : iobroker                                 - disabled, port: 8080
                + system.adapter.logparser.0              : logparser             : iobroker                                 -  enabled
                + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
                + system.adapter.mihome-vacuum.1          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
                + system.adapter.mihome-vacuum.2          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
                + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
                + system.adapter.modbus.1                 : modbus                : iobroker                                 -  enabled
                + system.adapter.modbus.2                 : modbus                : iobroker                                 -  enabled
                + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1886, bind: 0.0.0.0
                + system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1888, bind: 192.168.1.39
                + system.adapter.nuki-extended.0          : nuki-extended         : iobroker                                 -  enabled
                + system.adapter.octoprint.0              : octoprint             : iobroker                                 -  enabled
                + system.adapter.opendtu.0                : opendtu               : iobroker                                 -  enabled
                  system.adapter.ph803w.0                 : ph803w                : iobroker                                 - disabled
                + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
                + system.adapter.ring.0                   : ring                  : iobroker                                 -  enabled
                + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
                + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 192.168.1.39
                + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
                + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 192.168.1.39, run as: admin
                + system.adapter.smartmeter.0             : smartmeter            : iobroker-slave                           -  enabled
                + system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 192.168.1.39
                + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
                + system.adapter.synology.0               : synology              : iobroker                                 -  enabled, port: 5001
                + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
                + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
                + system.adapter.unifi.0                  : unifi                 : iobroker                                 -  enabled
                  system.adapter.vis-bars.0               : vis-bars              : iobroker                                 -  enabled
                  system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 -  enabled
                  system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 -  enabled
                  system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
                  system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 -  enabled
                  system.adapter.vis-material.0           : vis-material          : iobroker                                 -  enabled
                  system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 -  enabled
                  system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
                  system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                  system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
                + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
                + system.adapter.worx.0                   : worx                  : iobroker                                 -  enabled
                + system.adapter.zigbee.1                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.1.175:6638
                + instance is alive
                ioBroker-Repositories
                │ (index) │ name               │ url                                                     │ auto upgrade │
                │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
                │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
                Upgrade policy: none
                Installed ioBroker-Instances
                Adapter    "adguard"      : 0.0.8    , installed 0.0.8
                Adapter    "admin"        : 7.1.5    , installed 7.1.5
                Adapter    "alarm"        : 3.6.2    , installed 3.6.2
                Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                Adapter    "backitup"     : 3.0.25   , installed 3.0.25
                Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
                Adapter    "cloud"        : 5.0.1    , installed 5.0.1
                Adapter    "daswetter"    : 3.1.16   , installed 3.1.16
                Adapter    "egigeozone2"  : 1.0.7    , installed 1.0.6  [Updatable]
                Adapter    "energiefluss" : 3.6.1    , installed 3.6.1
                Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
                Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
                Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
                Adapter    "heatingcontrol": 2.12.10 , installed 2.12.10
                Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
                Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
                Adapter    "hue"          : 3.12.0   , installed 3.12.0
                Adapter    "ical"         : 1.15.0   , installed 1.15.0
                Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
                Adapter    "iot"          : 3.3.0    , installed 3.3.0
                Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                Controller "js-controller": 6.0.11   , installed 6.0.11
                Adapter    "lgtv11"       : 1.0.5    , installed 1.0.5
                Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
                Adapter    "linux-control": 1.1.5    , installed 1.1.5
                Adapter    "logparser"    : 2.2.2    , installed 2.2.2
                Adapter    "mihome"       : 1.4.0    , installed 1.4.0
                Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
                Adapter    "modbus"       : 6.3.2    , installed 6.3.2
                Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
                Adapter    "nina"         : 0.0.25   , installed 0.0.25
                Adapter    "nuki"         : 2.0.0    , installed 2.0.0
                Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
                Adapter    "nut"          : 1.6.0    , installed 1.6.0
                Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
                Adapter    "opendtu"      : 2.0.0    , installed 2.0.0
                Adapter    "ph803w"       : 1.2.0    , installed 1.2.0
                Adapter    "pvforecast"   : 3.0.0    , installed 3.0.0
                Adapter    "ring"         : 6.2.1    , installed 5.1.0  [Updatable]
                Adapter    "scenes"       : 3.2.3    , installed 3.2.3
                Adapter    "shelly"       : 8.2.1    , installed 8.2.1
                Adapter    "shuttercontrol": 1.8.3   , installed 1.8.3
                Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
                Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
                Adapter    "synology"     : 3.1.0    , installed 3.1.0
                Adapter    "telegram"     : 3.9.0    , installed 3.9.0
                Adapter    "terminal"     : 1.0.0    , installed 1.0.0
                Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
                Adapter    "tuya"         : 3.16.0   , installed 3.16.0
                Adapter    "unifi"        : 0.7.0    , installed 0.7.0
                Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
                Adapter    "vis-justgage" : 2.1.7    , installed 2.1.0  [Updatable]
                Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
                Adapter    "vis-material" : 0.1.3    , installed 0.1.3
                Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
                Adapter    "wallpanel"    : 0.3.11   , installed 0.3.11
                Adapter    "weatherunderground": 3.7.0, installed 3.7.0
                Adapter    "wireguard"    : 1.7.0    , installed 1.7.0
                Adapter    "wled"         : 0.7.2    , installed 0.7.2
                Adapter    "worx"         : 3.1.0    , installed 3.1.0
                Adapter    "ws"           : 2.6.2    , installed 2.6.2
                Adapter    "zigbee"       : 1.10.3   , installed 1.10.10
                Objects and States
                Objects: 	47876
                States: 	41930
                Hit:1 http://deb.debian.org/debian bullseye-proposed-updates InRelease
                Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
                Hit:3 http://ftp.de.debian.org/debian bullseye InRelease
                Hit:4 http://ftp.de.debian.org/debian bullseye-updates InRelease
                Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                Reading package lists...
                Pending Updates: 0
                *** Listening Ports ***
                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11528      741/sshd: /usr/sbin
                tcp        0      0 192.168.1.39:8087       0.0.0.0:*               LISTEN      1001       22880486   3440656/io.simple-a
                tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          13006      734/exim4
                tcp        0      0 0.0.0.0:1082            0.0.0.0:*               LISTEN      1000       23807780   3845793/nc
                tcp        0      0 192.168.1.39:2010       0.0.0.0:*               LISTEN      1001       22875511   3438603/io.hm-rpc.1
                tcp        0      0 192.168.1.39:1883       0.0.0.0:*               LISTEN      1001       22874812   3438557/io.sonoff.0
                tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       22870917   3437481/io.mqtt.0
                tcp        0      0 0.0.0.0:1887            0.0.0.0:*               LISTEN      1001       22870918   3437481/io.mqtt.0
                tcp        0      0 192.168.1.39:1888       0.0.0.0:*               LISTEN      1001       22874750   3437564/io.mqtt.1
                tcp        0      0 192.168.1.39:1889       0.0.0.0:*               LISTEN      1001       22874751   3437564/io.mqtt.1
                tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       22867654   3435624/iobroker.js
                tcp        0      0 0.0.0.0:6379            0.0.0.0:*               LISTEN      109        14138      444/redis-server 0.
                tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          13951      1/init
                tcp        0      0 192.168.1.39:2001       0.0.0.0:*               LISTEN      1001       22871328   3436705/io.hm-rpc.0
                tcp        0      0 192.168.1.39:8081       0.0.0.0:*               LISTEN      1001       22870433   3435654/io.admin.0
                tcp6       0      0 :::22                   :::*                    LISTEN      0          11530      741/sshd: /usr/sbin
                tcp6       0      0 ::1:25                  :::*                    LISTEN      0          13007      734/exim4
                tcp6       0      0 :::7999                 :::*                    LISTEN      1001       22878403   3439671/io.egigeozo
                tcp6       0      0 :::111                  :::*                    LISTEN      0          10224      1/init
                tcp6       0      0 :::8082                 :::*                    LISTEN      1001       22880563   3440933/io.web.0
                tcp6       0      0 :::8084                 :::*                    LISTEN      1001       22883504   3441852/io.socketio
                tcp6       0      0 :::51989                :::*                    LISTEN      1001       23790698   3838359/io.nuki-ext
                udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       22874451   3437357/io.mihome-v
                udp        0      0 0.0.0.0:53422           0.0.0.0:*                           1001       22876614   3439250/io.mihome-v
                udp        0      0 0.0.0.0:53423           0.0.0.0:*                           1001       22874993   3439302/io.mihome-v
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       22877109   3441031/io.wled.0
                udp        0      0 192.168.1.39:5353       0.0.0.0:*                           1001       22876423   3438564/io.tr-064.0
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           107        12925      438/avahi-daemon: r
                udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       22875538   3438550/io.shelly.0
                udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       22874839   3438565/io.tuya.0
                udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       22874840   3438565/io.tuya.0
                udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       22870612   3436350/io.broadlin
                udp        0      0 0.0.0.0:48705           0.0.0.0:*                           1001       23628756   3436350/io.broadlin
                udp        0      0 0.0.0.0:57115           0.0.0.0:*                           1001       22866935   3436350/io.broadlin
                udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          11336      1/init
                udp        0      0 0.0.0.0:33498           0.0.0.0:*                           107        12927      438/avahi-daemon: r
                udp6       0      0 :::5353                 :::*                                107        12926      438/avahi-daemon: r
                udp6       0      0 :::111                  :::*                                0          1967       1/init
                udp6       0      0 :::42604                :::*                                107        12928      438/avahi-daemon: r
                2024-11-09 20:17:05.010  - info: labcom.0 (3842960) cleaned everything up...
                2024-11-09 20:17:05.015  - info: labcom.0 (3842960) Terminated (NO_ERROR): Without reason
                2024-11-09 20:17:05.527  - info: host.iobroker instance system.adapter.labcom.0 having pid 3842960 terminated with code 0 (NO_ERROR)
                2024-11-09 20:17:14.006  - info: host.iobroker instance system.adapter.daswetter.0 in version "3.1.16" started with pid 3842976
                2024-11-09 20:17:14.772  - info: daswetter.0 (3842976) starting. Version 3.1.16 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.0, js-controller: 6.0.11
                2024-11-09 20:17:19.421  - info: daswetter.0 (3842976) still wrong data structure from server received! repaired...
                2024-11-09 20:17:20.002  - info: ring.0 (3440535) Device 45172445 ("Haustür"): Cronjob Auto save HD Snapshot starts
                2024-11-09 20:17:20.005  - info: ring.0 (3440535) Device 45172445 ("Haustür"): is offline --> won't take HD Snapshot
                2024-11-09 20:17:20.825  - info: daswetter.0 (3842976) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
                2024-11-09 20:17:21.329  - info: daswetter.0 (3842976) cleaned everything up...
                2024-11-09 20:17:21.336  - info: host.iobroker instance system.adapter.daswetter.0 having pid 3842976 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2024-11-09 20:18:04.051  - info: host.iobroker instance system.adapter.labcom.0 in version "0.1.4" started with pid 3843922
                2024-11-09 20:18:04.883  - info: labcom.0 (3843922) starting. Version 0.1.4 in /opt/iobroker/node_modules/iobroker.labcom, node: v20.18.0, js-controller: 6.0.11
                2024-11-09 20:18:04.891  - info: labcom.0 (3843922) LabCom adapter - started
                2024-11-09 20:18:05.121  - info: labcom.0 (3843922) LabCom adapter - fetching data completed
                2024-11-09 20:18:05.121  - info: labcom.0 (3843922) cleaned everything up...
                2024-11-09 20:18:05.126  - info: labcom.0 (3843922) Terminated (NO_ERROR): Without reason
                2024-11-09 20:18:05.637  - info: host.iobroker instance system.adapter.labcom.0 having pid 3843922 terminated with code 0 (NO_ERROR)
                2024-11-09 20:19:04.006  - info: host.iobroker instance system.adapter.labcom.0 in version "0.1.4" started with pid 3845502
                2024-11-09 20:19:04.901  - info: labcom.0 (3845502) starting. Version 0.1.4 in /opt/iobroker/node_modules/iobroker.labcom, node: v20.18.0, js-controller: 6.0.11
                2024-11-09 20:19:04.908  - info: labcom.0 (3845502) LabCom adapter - started
                2024-11-09 20:19:05.147  - info: labcom.0 (3845502) LabCom adapter - fetching data completed
                2024-11-09 20:19:05.147  - info: labcom.0 (3845502) cleaned everything up...
                2024-11-09 20:19:05.152  - info: labcom.0 (3845502) Terminated (NO_ERROR): Without reason
                2024-11-09 20:19:05.662  - info: host.iobroker instance system.adapter.labcom.0 having pid 3845502 terminated with code 0 (NO_ERROR)
                [/s]
                  @mymeyer
                  Sieht für mich nicht normal aus, da fehlt nämlich mindestens 90% der Ausgabe.
                    @thomas-braun Sorry jetzt aber...
                      Homoran Global Moderator Administrators @MyMeyer last edited by
                      @mymeyer sagte in npm Fehlermeldung:
                        @mymeyer
                        Die ganzen
                        Einträge deuten auf eine verschobene npm-Struktur hin.
                        Installier mal einen der dort genannten Adapter ordentlich, d.h. nicht als GitHub-Installation.
                          MyMeyer last edited by Homoran
                          @thomas-braun ich habe jetzt mal alle mit Fehler neuinstalliert "nicht über Git". Nun sagt Diag das:
                           2024-11-09 20:41:31.387  - error: host.iobroker instance system.adapter.blink4home.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                          2024-11-09 20:41:31.387  - info: host.iobroker Restart adapter system.adapter.blink4home.0 because enabled
                          2024-11-09 20:42:01.669  - info: host.iobroker instance system.adapter.blink4home.0 in version "0.1.1" started with pid 3864381
                          2024-11-09 20:42:02.189  - error: host.iobroker Caught by controller[0]: /opt/iobroker/node_modules/iobroker.blink4home/main.js:24
                          2024-11-09 20:42:02.190  - error: host.iobroker Caught by controller[0]: 		this.log.debug('begin setup adapter');
                          2024-11-09 20:42:02.190  - error: host.iobroker Caught by controller[0]: 		         ^
                          2024-11-09 20:42:02.190  - error: host.iobroker Caught by controller[0]: TypeError: Cannot read properties of undefined (reading 'debug')
                          2024-11-09 20:42:02.190  - error: host.iobroker Caught by controller[0]:     at new Blink4home (/opt/iobroker/node_modules/iobroker.blink4home/main.js:24:12)
                          2024-11-09 20:42:02.190  - error: host.iobroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.blink4home/main.js:235:2)
                          2024-11-09 20:42:02.190  - error: host.iobroker Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1469:14)
                          2024-11-09 20:42:02.190  - error: host.iobroker Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
                          2024-11-09 20:42:02.190  - error: host.iobroker Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1288:32)
                          2024-11-09 20:42:02.190  - error: host.iobroker Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1104:12)
                          2024-11-09 20:42:02.190  - error: host.iobroker Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:174:12)
                          2024-11-09 20:42:02.190  - error: host.iobroker Caught by controller[0]:     at node:internal/main/run_main_module:28:49
                          2024-11-09 20:42:02.190  - error: host.iobroker Caught by controller[0]: Node.js v20.18.0
                          2024-11-09 20:42:02.190  - error: host.iobroker instance system.adapter.blink4home.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                          2024-11-09 20:42:02.190  - info: host.iobroker Restart adapter system.adapter.blink4home.0 because enabled
                          2024-11-09 20:42:04.007  - info: host.iobroker instance system.adapter.labcom.0 in version "0.1.4" started with pid 3864665
                          2024-11-09 20:42:05.124  - info: labcom.0 (3864665) starting. Version 0.1.4 in /opt/iobroker/node_modules/iobroker.labcom, node: v20.18.0, js-controller: 6.0.11
                          2024-11-09 20:42:05.132  - info: labcom.0 (3864665) LabCom adapter - started
                          2024-11-09 20:42:05.354  - info: labcom.0 (3864665) LabCom adapter - fetching data completed
                          2024-11-09 20:42:05.355  - info: labcom.0 (3864665) cleaned everything up...
                          2024-11-09 20:42:05.359  - info: labcom.0 (3864665) Terminated (NO_ERROR): Without reason
                          2024-11-09 20:42:05.870  - info: host.iobroker instance system.adapter.labcom.0 having pid 3864665 terminated with code 0 (NO_ERROR)
                            @mymeyer
                            Die ganzen
                            Sach wie kann denn sowas passieren das sich die Struktur verschoben hat ? Habe eigentlich nichts grosses in letzter Zeit gemacht außer die Update. Selbst das deinstallieren von den Adapter geht nicht mehr. Auch manuell nicht.
                            Was kann man jetzt machen ? Neuinstallation ?
                            michael@iobroker:/opt/iobroker$ iob del egigeozone
                            Delete adapter "egigeozone"
                            host.iobroker object egigeozone deleted
                            host.iobroker object egigeozone.admin deleted
                            host.iobroker Deleting 1 object(s).
                            Error deleting adapter egigeozone from disk: Cannot find module 'iobroker.egigeozone/io-package.json'
                            Require stack:
                            - /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/esm/lib/setup/setupInstall.js
                            You might have to delete it yourself!
                              Durch übermäßige Verwendung von GitHub-Installationen...
                              Wie schaut denn nun
                              cd /opt/iobroker && npm ls
                              aus?
                                michael@iobroker:/opt/iobroker$ cd /opt/iobroker && npm ls
                                [sudo] Passwort f�r michael:
                                iobroker.inst@1.1.2 /opt/iobroker
                                +-- @iobroker-javascript.0/country-list-js@npm:country-list-js@3.1.8
                                +-- @iobroker-javascript.0/exec@npm:exec@0.2.1
                                +-- @iobroker-javascript.0/ffmpeg@npm:ffmpeg@0.0.4
                                +-- @iobroker-javascript.0/fs@npm:fs@0.0.1-security
                                +-- @iobroker-javascript.0/node-hue-api@npm:node-hue-api@5.0.0-beta.16
                                +-- @iobroker-javascript.0/require@npm:require@2.4.20
                                +-- @iobroker-javascript.0/simple-ssh@npm:simple-ssh@1.1.1
                                +-- @iobroker-javascript.0/suncalc@npm:suncalc@1.9.0
                                +-- iobroker.adguard@0.0.8
                                +-- iobroker.admin@7.1.5
                                +-- iobroker.alarm@3.6.2
                                +-- iobroker.alexa2@3.26.5
                                +-- iobroker.alias-manager@1.2.6
                                +-- iobroker.apsystems-ecu@0.2.1 invalid: "github:npeter/ioBroker.apsystems-ecu#9d583384f1d72f0147fde2abcd67d4e9281b7347" from the root project
                                +-- iobroker.backitup@3.0.25
                                +-- iobroker.binance@1.1.3 invalid: "github:Kartax/ioBroker.binance#54f362ef6e0775d7cd696a3dff701e2dd6de2404" from the root project
                                +-- iobroker.bosch-ebike@0.1.7 invalid: "github:TA2k/ioBroker.bosch-ebike" from the root project
                                +-- iobroker.broadlink2@2.3.0
                                +-- iobroker.cloud@5.0.1
                                +-- iobroker.daswetter@3.1.16
                                +-- iobroker.egigeozone2@1.0.6
                                +-- iobroker.energiefluss@3.6.1
                                +-- iobroker.feiertage@1.2.0
                                +-- iobroker.flot@1.12.0
                                +-- iobroker.fritzbox@0.6.0
                                +-- iobroker.fullybrowser@3.0.12
                                +-- iobroker.heatingcontrol@2.12.10
                                +-- iobroker.hm-rega@5.1.0
                                +-- iobroker.hm-rpc@2.0.2
                                +-- iobroker.hue@3.12.0
                                +-- iobroker.ical@1.15.0
                                +-- iobroker.icons-addictive-flavour-png@0.1.0
                                +-- iobroker.icons-fatcow-hosting@0.1.0
                                +-- iobroker.icons-icons8@0.0.1
                                +-- iobroker.icons-material-png@0.1.0
                                +-- iobroker.icons-material-svg@0.1.0
                                +-- iobroker.icons-mfd-png@1.2.1
                                +-- iobroker.icons-mfd-svg@1.2.0
                                +-- iobroker.icons-open-icon-library-png@0.1.2
                                +-- iobroker.icons-ultimate-png@1.0.1
                                +-- iobroker.influxdb@4.0.2
                                +-- iobroker.iot@3.3.0
                                +-- iobroker.javascript@8.8.3
                                +-- iobroker.js-controller@6.0.11
                                +-- iobroker.labcom@0.1.4 invalid: "github:100prznt/ioBroker.labcom#2cbc14b6c33d01fcc29003e3648fcb0c4d917f75" from the root project
                                +-- iobroker.landroid@1.0.3
                                +-- iobroker.lgtv11@1.0.5
                                +-- iobroker.life360@0.2.22 invalid: "github:MiGoller/ioBroker.life360#23166aab1b2e36d917a9b7b480d9faa7f73ca2d1" from the root project
                                +-- iobroker.linkeddevices@1.5.5
                                +-- iobroker.linux-control@1.1.5
                                +-- iobroker.logparser@2.2.2
                                +-- iobroker.mihome-vacuum@4.2.0
                                +-- iobroker.mihome@1.4.0
                                +-- iobroker.modbus@6.3.2
                                +-- iobroker.mqtt@6.1.2
                                +-- iobroker.nina@0.0.25
                                +-- iobroker.nuki-extended@2.7.0
                                +-- iobroker.nuki@2.0.0
                                +-- iobroker.nut@1.6.0
                                +-- iobroker.octoprint@5.1.0
                                +-- iobroker.opendtu@2.0.0
                                +-- iobroker.ph803w@1.2.0
                                +-- iobroker.primelab@1.0.2 invalid: "github:Apollon77/iobroker.primelab#95f1af76d05d464b08b8ee3cb40ceb2b20d778d3" from the root project
                                +-- iobroker.pvforecast@3.0.0
                                +-- iobroker.ring@5.1.0
                                +-- iobroker.scenes@3.2.3
                                +-- iobroker.shelly@8.2.1
                                +-- iobroker.shuttercontrol@1.8.3
                                +-- iobroker.simple-api@2.8.0
                                +-- iobroker.smartcontrol@2.0.1
                                +-- iobroker.socketio@6.7.1
                                +-- iobroker.sonoff@3.1.2
                                +-- iobroker.sourceanalytix@0.4.15-alpha.1 invalid: "github:DrozmotiX/ioBroker.sourceanalytix#fd3b7f9f362a348741cbe18d70a130d2bfee6727" from the root project
                                +-- iobroker.synology@3.1.0
                                +-- iobroker.telegram@3.9.0
                                +-- iobroker.terminal@1.0.0
                                +-- iobroker.tr-064@4.3.0
                                +-- iobroker.tuya@3.16.0
                                +-- iobroker.unifi@0.7.0
                                +-- iobroker.vis-bars@0.1.4
                                +-- iobroker.vis-colorpicker@2.0.3
                                +-- iobroker.vis-fancyswitch@1.1.0
                                +-- iobroker.vis-google-fonts@1.0.4
                                +-- iobroker.vis-hqwidgets@1.5.1
                                +-- iobroker.vis-jqui-mfd@1.1.1
                                +-- iobroker.vis-justgage@2.1.0
                                +-- iobroker.vis-map@1.1.2
                                +-- iobroker.vis-material@0.1.3
                                +-- iobroker.vis-materialdesign@0.5.94 invalid: "github:Scrounger/ioBroker.vis-materialdesign#8b7529d493f223dfc4f1d1f632553fcb35bbcc92" from the root project
                                +-- iobroker.vis-metro@1.2.0
                                +-- iobroker.vis-players@0.1.6
                                +-- iobroker.vis-plumb@1.0.2
                                +-- iobroker.vis-rgraph@0.0.2
                                +-- iobroker.vis-timeandweather@1.2.2
                                +-- iobroker.vis@1.5.6
                                +-- iobroker.wallpanel@0.3.11
                                +-- iobroker.weatherunderground@3.7.0
                                +-- iobroker.web@6.2.5
                                +-- iobroker.wireguard@1.7.0
                                +-- iobroker.wled@0.7.2
                                +-- iobroker.worx@3.1.0 invalid: "github:iobroker-community-adapters/ioBroker.worx" from the root project
                                +-- iobroker.ws@2.6.2
                                +-- iobroker.zigbee@1.10.10 invalid: "github:ioBroker/ioBroker.zigbee#fedc314a875044c84ff790a19dfd42d7373bb61e" from the root project
                                `-- zigbee2mqtt@1.27.0 invalid: "github:Koenkk/zigbee2mqtt#a9b8808237554316c5c97e9d9c990048733779e8" from the root project
                                npm error code ELSPROBLEMS
                                npm error invalid: iobroker.apsystems-ecu@0.2.1 /opt/iobroker/node_modules/iobroker.apsystems-ecu
                                npm error invalid: iobroker.binance@1.1.3 /opt/iobroker/node_modules/iobroker.binance
                                npm error invalid: iobroker.blink4home@0.1.1 /opt/iobroker/node_modules/iobroker.blink4home
                                npm error invalid: iobroker.bosch-ebike@0.1.7 /opt/iobroker/node_modules/iobroker.bosch-ebike
                                npm error invalid: iobroker.broadlink@0.1.5 /opt/iobroker/node_modules/iobroker.broadlink
                                npm error invalid: iobroker.fully-tablet-control@0.3.3-beta.0 /opt/iobroker/node_modules/iobroker.fully-tablet-control
                                npm error invalid: iobroker.labcom@0.1.4 /opt/iobroker/node_modules/iobroker.labcom
                                npm error invalid: iobroker.life360@0.2.22 /opt/iobroker/node_modules/iobroker.life360
                                npm error invalid: iobroker.primelab@1.0.2 /opt/iobroker/node_modules/iobroker.primelab
                                npm error invalid: iobroker.repetierserver@0.0.3 /opt/iobroker/node_modules/iobroker.repetierserver
                                npm error invalid: iobroker.sourceanalytix@0.4.15-alpha.1 /opt/iobroker/node_modules/iobroker.sourceanalytix
                                npm error invalid: iobroker.vis-materialdesign@0.5.94 /opt/iobroker/node_modules/iobroker.vis-materialdesign
                                npm error invalid: iobroker.worx@3.1.0 /opt/iobroker/node_modules/iobroker.worx
                                npm error invalid: iobroker.zigbee@1.10.10 /opt/iobroker/node_modules/iobroker.zigbee
                                npm error invalid: zigbee2mqtt@1.27.0 /opt/iobroker/node_modules/zigbee2mqtt
                                npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-11-09T20_47_47_845Z-debug-0.log
                                  @mymeyer
                                  Joh...
                                  Siehste selber, oder?
                                  Installier alle Adapter bei denen das möglich ist eine Version aus einem Repo, NICHT aus GitHub.
                                  Warum haste da eigentlich so viel Alpha-Versions-Zeuch drin? Hast du das alles vom Maintainer zum testen gegeben bekommen? Wenn nein, fahr da stabile Versionen.
                                    Kann ich dir gar nicht sagen. Habe vor 3 -4 Jahren angefangen mit iob. Da versucht man schon einiges 🙂 Ich werde mir mal die Tage gedanken machen wie ich die Sache angehe.
                                    Vielleicht einfach mal bei NULL anfangen und das rüber holen was so geht.
                                    Danke Dir erstmal und schönen Abend noch...
                                      @mymeyer
                                      Sauber muss das so aussehen:
                                      echad@chet:~ $ cd /opt/iobroker/ && npm ls
                                      (node:50931) ExperimentalWarning: CommonJS module /usr/lib/node_modules/npm/node_modules/debug/src/node.js is loading ES Module /usr/lib/node_modules/npm/node_modules/supports-color/index.js using require().
                                      iobroker.inst@3.0.0 /opt/iobroker
                                      ├── iobroker.admin@7.2.6
                                      ├── iobroker.alexa2@3.26.7
                                      ├── iobroker.alias-manager@2.0.0
                                      ├── iobroker.awtrix-light@1.3.0
                                      ├── iobroker.backitup@3.0.26
                                      ├── iobroker.cloud@5.0.1
                                      ├── iobroker.devices@1.1.5
                                      ├── iobroker.drops-weather@0.3.1 (git+ssh://git@github.com/inbux/ioBroker.drops-weather.git#608ed1fcbbde3f59b6a09f2f188b92823481ae90)
                                      ├── iobroker.echarts@1.9.2
                                      ├── iobroker.firetv@2.1.0
                                      ├── iobroker.followthesun@0.5.1
                                      ├── iobroker.govee-app@0.0.6 (git+ssh://git@github.com/TA2k/ioBroker.govee-app.git#6a0f84cfb34eb3a0ca647c7a519b9d5a48ccfb85)
                                      ├── iobroker.govee-local@0.2.7
                                      ├── iobroker.history@3.0.1
                                      ├── iobroker.ical@1.16.1
                                      ├── iobroker.iceroad@1.2.1
                                      ├── iobroker.iot@3.4.3
                                      ├── iobroker.javascript@8.8.3
                                      ├── iobroker.js-controller@7.0.2
                                      ├── iobroker.kisshome-research@1.1.1
                                      ├── iobroker.midea@0.1.0 (git+ssh://git@github.com/TA2k/ioBroker.midea.git#0d037c0c9a025b193546f881f747c8f998bfc724)
                                      ├── iobroker.mihome-cloud@0.1.1
                                      ├── iobroker.mihome-vacuum@4.2.0
                                      ├── iobroker.mihome@1.4.0
                                      ├── iobroker.mqtt@6.1.2
                                      ├── iobroker.nina@0.0.26
                                      ├── iobroker.notification-manager@1.3.0
                                      ├── iobroker.nuki-extended@2.7.0
                                      ├── iobroker.nuki@2.0.0
                                      ├── iobroker.nut@1.6.0
                                      ├── iobroker.opendtu@3.0.1
                                      ├── iobroker.openweathermap@1.1.2
                                      ├── iobroker.parcel@0.2.8
                                      ├── iobroker.sainlogic@0.11.4
                                      ├── iobroker.samsung_tizen@1.1.0
                                      ├── iobroker.samsung@0.6.1 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.samsung.git#43d8a6ef3b5af0d6dfe276870f560353d52d0838)
                                      ├── iobroker.simple-api@2.8.0
                                      ├── iobroker.switchbot-hub@0.1.2 (git+ssh://git@github.com/DrozmotiX/ioBroker.switchbot-hub.git#7a05fa59dfc5e3ce8d73018badc4e420996452f8)
                                      ├── iobroker.tado@0.6.1
                                      ├── iobroker.tankerkoenig@3.4.0
                                      ├── iobroker.tr-064@4.3.0
                                      ├── iobroker.tradfri@3.1.3
                                      ├── iobroker.trashschedule@3.4.0
                                      ├── iobroker.tuya@3.16.0
                                      ├── iobroker.weather-warnings@0.6.7
                                      ├── iobroker.web@6.3.1
                                      ├── iobroker.whatsapp-cmb@0.3.0
                                      └── iobroker.zigbee@1.10.12
                                      echad@chet:/opt/iobroker $
                                      Adapter aus dem GitHub sind nicht invalid und es gibt lediglich Einträge in der Form iobroker.adaptername@1.2.3
                                      install install adapter update npm err
                                      574
