    4. FBPresence Adapter - Fehlermeldung bei Update
      Bielefelder81 last edited by
      Hi zusammen,
      ich versuche seit einiger Zeit meinen fbpresence Adapter zu uppen. Bekomme aber ständige folgende Fehlermeldung und versteh sie nicht.
      $ iobroker upgrade fb-checkpresence@1.2.5
      Update fb-checkpresence from @1.2.4 to @1.2.5
      host.ioBroker Adapter "system.adapter.fb-checkpresence.0" is stopped.
      NPM version: 10.2.4Installing iobroker.fb-checkpresence@1.2.5... (System call)
      Try to solve ENOTEMPTY error automatically
      Could not handle ENOTEMPTY, because no deletable files were foundnpm ERR! code ENOTEMPTYnpm ERR! syscall renamenpm ERR! path /opt/iobroker/node_modules/@types/nodenpm ERR! dest /opt/iobroker/node_modules/@types/.node-Bd1x5fmznpm ERR! errno -39npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/@types/node' -> '/opt/iobroker/node_modules/@types/.node-Bd1x5fmz'npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-11-10T14_35_37_794Z-debug-0.loghost.ioBroker Cannot install iobroker.fb-checkpresence@1.2.5: 217
      ERROR: Process exited with code 25
        Thomas Braun Most Active @Bielefelder81 last edited by
        @bielefelder81
        iob stop
        iob fix
        iob start
        iob update
        iob upgrade
          Bielefelder81 @Thomas Braun last edited by
          Funktioniert trotzdem nicht
          This upgrade of "fb-checkpresence" will introduce the following changes:
          -> 1.2.5:
          new filter function implemented (experimental)
          node >=18
          dependencies updated
          repository checker issues fixed
          issue fixed [#294](https://github.com/afuerhoff/ioBroker.fb-checkpresence/issues/294)
          'devicename' as state added [#299](https://github.com/afuerhoff/ioBroker.fb-checkpresence/issues/299)
          Would you like to upgrade fb-checkpresence from @1.2.4 to @1.2.5 now? [(y)es, (n)o]: y
          NPM version: 10.2.4
          host.ioBroker deleted npm temp directory: ".iobroker.javascript-5NZ432mn")
          npm ERR! errno -39
          npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-11-10T14_54_26_247Z-debug-0.log
          afuerhoff created this issue in afuerhoff/ioBroker.fb-checkpresence
          closed [bug]: vpn property will not be set #294
          closed [enhancement]: add device name to fbdevices #299
            Thomas Braun Most Active @Bielefelder81 last edited by Thomas Braun
            @bielefelder81 sagte in FBPresence Adapter - Fehlermeldung bei Update:
            Dann mehr Input...
            Die Langfassung von
            iob diag
            sagt?
            Und den Fix kannst du nochmal ausführen. Muss man ggfls. mehrfach tun.
                                      v.2024-10-19
                 Static hostname: ioBroker
                       Icon name: computer-container
                         Chassis: container
                  Virtualization: lxc
                Operating System: Ubuntu 20.04.6 LTS
                          Kernel: Linux 5.4.55-1-pve
                    Architecture: x86-64
              Installation:           lxc
              oTimezone:              Europe/Berlin (CET, +0100)
              User-ID:                1000
              Display-Server:         false
              Pending OS-Updates:     0
              Pending iob updates:    1
              Nodejs-Installation:
              /usr/bin/nodejs         v18.20.4
              /usr/bin/node           v18.20.4
              /usr/bin/npm            10.7.0
              /usr/bin/npx            10.7.0
              /usr/bin/corepack       0.28.0
              Recommended versions are nodejs 20.18.0 and npm 10.8.2
              nodeJS installation is correct
              MEMORY:
              Mem:           4.1G        1.6G        1.4G        0.0K        1.1G        2.5G
              Swap:          512M          0B        512M
              Total:         4.6G        1.6G        1.9G
              Active iob-Instances:   18
              Upgrade policy: none
              ioBroker Core:          js-controller           6.0.11
                                      admin                   7.1.5
              Objects type: jsonl
              States  type: jsonl
              + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
              + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
              Objects:                5443
              States:                 4491
              Size of iob-Database:
              40M     /opt/iobroker/iobroker-data/objects.jsonl
              6.9M    /opt/iobroker/iobroker-data/objects.json.migrated
              6.9M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
              5.7M    /opt/iobroker/iobroker-data/states.jsonl
              640K    /opt/iobroker/iobroker-data/states.json.migrated
              640K    /opt/iobroker/iobroker-data/states.json.bak.migrated
              Some problems detected, please run iob fix and try to have them fixed
              Operating System codenamed 'focal' is an aging Ubuntu release! Please upgrade to the latest LTS release 'noble' in due time!
              === Mark text until here for copying ===
                @bielefelder81
                Das ist nicht die Langfassung.
                Bring aber schon mal nodejs auf die empfohlene Version 20.
                iob nodejs-update
                B 2 Replies Last reply Reply Quote 0
                  Bielefelder81 @Thomas Braun last edited by Bielefelder81
                  @thomas-braun Update auf nodejs läuft. Hatte zwischendurch gesehen, dass angeblich zu wenig Speicher frei war... Noch 600MB oder so. Hab dann per Proxmoxx von 10 GB auf 30 GB erhöht.
                    @thomas-braun ```
                    ========== Start marking the full check here ===========
                    Script v.2024-10-19
                    *** BASE SYSTEM ***
                               Chassis: container
                        Virtualization: lxc
                    OS is similar to: debian
                    model name      : Intel(R) Core(TM) i3-8109U CPU @ 3.00GHz
                    Docker          : false
                    Virtualization  : lxc
                    Kernel          : x86_64
                    Userland        : 64 bit
                    Systemuptime and Load:
                     16:10:05 up 13 min,  1 user,  load average: 0.61, 0.97, 0.84
                    CPU threads: 1
                    *** LIFE CYCLE STATUS ***
                    *** TIME AND TIMEZONES ***
                                   Local time: Sun 2024-11-10 16:10:06 CET
                               Universal time: Sun 2024-11-10 15:10:06 UTC
                                     RTC time: n/a
                                  NTP service: inactive
                              RTC in local TZ: no
                    *** Users and Groups ***
                    User that called 'iob diag':
                    christian
                    HOME=/home/christian
                    GROUPS=christian sudo iobroker
                    js-controller is not running
                    *** DISPLAY-SERVER SETUP ***
                    Desktop:
                    Terminal:
                    System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
                    *** MEMORY ***
                    Mem:           4.1G        262M        1.8G        0.0K        2.1G        3.8G
                    Swap:          512M        0.0K        511M
                    Total:         4.6G        262M        2.3G
                             4096 M total memory
                              262 M used memory
                              620 M active memory
                             1472 M inactive memory
                             1771 M free memory
                                0 M buffer memory
                             2062 M swap cache
                              512 M total swap
                                0 M used swap
                              511 M free swap
                    top - 16:10:06 up 13 min,  1 user,  load average: 0.61, 0.97, 0.84
                    Tasks:  28 total,   1 running,  27 sleeping,   0 stopped,   0 zombie
                    %Cpu(s):  5.3 us,  0.0 sy,  0.0 ni, 94.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                    MiB Mem :   4096.0 total,   1771.1 free,    262.3 used,   2062.6 buff/cache
                    MiB Swap:    512.0 total,    511.9 free,      0.1 used.   3833.7 avail Mem
                    *** FAILED SERVICES ***
                      UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
                    * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
                    * iobroker.service     loaded failed failed ioBroker Server
                    2 loaded units listed.
                    *** DMESG CRITICAL ERRORS ***
                    No critical errors detected
                    *** FILESYSTEM ***
                    Filesystem                       Type      Size  Used Avail Use% Mounted on
                    /dev/mapper/pve-vm--103--disk--0 ext4       30G  9.8G   19G  35% /
                    none                             tmpfs     492K  4.0K  488K   1% /dev
                    udev                             devtmpfs  7.8G     0  7.8G   0% /dev/tty
                    tmpfs                            tmpfs     7.8G     0  7.8G   0% /dev/shm
                    tmpfs                            tmpfs     1.6G  120K  1.6G   1% /run
                    tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
                    tmpfs                            tmpfs     7.8G     0  7.8G   0% /sys/fs/cgroup
                    [Fri Aug 23 12:19:21 2024] EXT4-fs (dm-1): mounted filesystem with ordered data mode. Opts: (null)
                    [Fri Aug 23 12:19:21 2024] EXT4-fs (dm-1): re-mounted. Opts: errors=remount-ro
                    [Fri Aug 23 12:19:33 2024] EXT4-fs warning (device dm-7): ext4_multi_mount_protect:322: MMP interval 42 higher than expected, please wait.
                    [Fri Aug 23 12:20:17 2024] EXT4-fs (dm-7): 4 orphan inodes deleted
                    [Fri Aug 23 12:20:17 2024] EXT4-fs (dm-7): recovery complete
                    [Fri Aug 23 12:20:17 2024] EXT4-fs (dm-7): mounted filesystem with ordered data mode. Opts: (null)
                    [Sun Nov 10 15:49:00 2024] EXT4-fs (dm-7): resizing filesystem from 2621440 to 7864320 blocks
                    [Sun Nov 10 15:49:00 2024] EXT4-fs (dm-7): resized filesystem to 7864320
                    [Sun Nov 10 15:52:09 2024] EXT4-fs (dm-7): mounted filesystem with ordered data mode. Opts: (null)
                    Show mounted filesystems:
                    TARGET                           SOURCE                                FSTYPE     OPTIONS
                    /                                /dev/mapper/pve-vm--103--disk--0      ext4       rw,relatime,stripe=16
                    |-/proc/cpuinfo                  lxcfs[/proc/cpuinfo]                  fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                    |-/proc/diskstats                lxcfs[/proc/diskstats]                fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                    |-/proc/loadavg                  lxcfs[/proc/loadavg]                  fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                    |-/proc/meminfo                  lxcfs[/proc/meminfo]                  fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                    |-/proc/stat                     lxcfs[/proc/stat]                     fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                    |-/proc/swaps                    lxcfs[/proc/swaps]                    fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                    |-/proc/uptime                   lxcfs[/proc/uptime]                   fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                    `-/sys/devices/system/cpu/online lxcfs[/sys/devices/system/cpu/online] fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                    /var:
                    1.8G    /var/
                    994M    /var/log
                    993M    /var/log/journal/b354c482f7cc342776f020ee5ea440c3
                    469M    /var/cache
                    Archived and active journals take up 8.0M in the file system.
                    /opt/iobroker/backups:
                    /opt/iobroker/iobroker-data:
                    775M    /opt/iobroker/iobroker-data/
                    617M    /opt/iobroker/iobroker-data/files
                    442M    /opt/iobroker/iobroker-data/files/javascript.admin
                    409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                    408M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                    38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
                    27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
                    24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                    13M     /opt/iobroker/iobroker-data/objects.jsonl
                    9.2M    /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js
                    USB-Devices by-id:
                    No Devices found 'by-id'
                    *** NodeJS-Installation ***
                    /usr/bin/nodejs         v20.18.0
                    /usr/bin/node           v20.18.0
                    /usr/bin/corepack       0.29.3
                    nodejs:
                      Installed: 20.18.0-1nodesource1
                      Candidate: 20.18.0-1nodesource1
                      Version table:
                     *** 20.18.0-1nodesource1 1001
                            500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                            100 /var/lib/dpkg/status
                         20.17.0-1nodesource1 1001
                         20.16.0-1nodesource1 1001
                         20.15.1-1nodesource1 1001
                         20.15.0-1nodesource1 1001
                         20.14.0-1nodesource1 1001
                         20.13.1-1nodesource1 1001
                         20.13.0-1nodesource1 1001
                         20.12.2-1nodesource1 1001
                         20.12.1-1nodesource1 1001
                         20.12.0-1nodesource1 1001
                         20.11.1-1nodesource1 1001
                         20.11.0-1nodesource1 1001
                         20.10.0-1nodesource1 1001
                         20.9.0-1nodesource1 1001
                         20.8.1-1nodesource1 1001
                         20.8.0-1nodesource1 1001
                         20.7.0-1nodesource1 1001
                         20.6.1-1nodesource1 1001
                         20.6.0-1nodesource1 1001
                         20.5.1-1nodesource1 1001
                         20.5.0-1nodesource1 1001
                         20.4.0-1nodesource1 1001
                         20.3.1-1nodesource1 1001
                         20.3.0-1nodesource1 1001
                         20.2.0-1nodesource1 1001
                         20.1.0-1nodesource1 1001
                         20.0.0-1nodesource1 1001
                         10.19.0~dfsg-3ubuntu1.6 500
                            500 http://archive.ubuntu.com/ubuntu focal-updates/universe amd64 Packages
                            500 http://archive.ubuntu.com/ubuntu focal-security/universe amd64 Packages
                         10.19.0~dfsg-3ubuntu1 500
                            500 http://archive.ubuntu.com/ubuntu focal/universe amd64 Packages
                    Temp directories causing deletion problem: 2
                    Errors in npm tree: 0
                    No problems detected
                    *** ioBroker-Installation ***
                    ioBroker Status
                    iobroker is not running on this host.
                    Objects type: jsonl
                    States  type: jsonl
                    Hosts:
                    ioBroker            ioBroker (version: 6.0.11, hostname: ioBroker      , alive, uptime: 76)
                    Core adapters versions
                    js-controller:  6.0.11
                    admin:          7.1.5
                    javascript:     8.8.3
                    Adapter State
                      system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
                      system.adapter.deconz.0                 : deconz                : ioBroker                                 -  enabled, port: 80
                      system.adapter.discovery.0              : discovery             : ioBroker                                 -  enabled
                      system.adapter.fb-checkpresence.0       : fb-checkpresence      : ioBroker                                 - disabled
                      system.adapter.history.0                : history               : ioBroker                                 -  enabled
                      system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
                      system.adapter.info.0                   : info                  : ioBroker                                 -  enabled
                      system.adapter.iot.0                    : iot                   : ioBroker                                 -  enabled
                      system.adapter.jarvis.0                 : jarvis                : ioBroker                                 -  enabled
                      system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
                      system.adapter.mihome-vacuum.0          : mihome-vacuum         : ioBroker                                 -  enabled, port: 54321
                      system.adapter.sonoff.0                 : sonoff                : ioBroker                                 - disabled, port: 1883, bind: 0.0.0.0
                      system.adapter.spritmonitor.0           : spritmonitor          : ioBroker                                 -  enabled
                      system.adapter.tankerkoenig.0           : tankerkoenig          : ioBroker                                 -  enabled
                      system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                      system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
                      system.adapter.wled.0                   : wled                  : ioBroker                                 -  enabled
                      system.adapter.yeelight-2.0             : yeelight-2            : ioBroker                                 -  enabled
                    + instance is alive
                    ioBroker-Repositories
                    Active repo(s): stable
                    Installed ioBroker-Instances
                    Used repository: stable
                    Adapter    "admin"        : 7.1.5    , installed 7.1.5
                    Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                    Adapter    "deconz"       : 1.4.1    , installed 2.0.5
                    Adapter    "discovery"    : 5.0.0    , installed 5.0.0
                    Adapter    "fb-checkpresence": 1.2.5 , installed 1.2.4  [Updatable]
                    Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
                    Adapter    "ical"         : 1.15.0   , installed 1.15.0
                    Adapter    "iot"          : 3.3.0    , installed 3.3.0
                    Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
                    Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                    Controller "js-controller": 6.0.11   , installed 6.0.11
                    Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
                    Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                    Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
                    Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
                    Adapter    "telegram"     : 3.9.0    , installed 3.9.0
                    Adapter    "trashschedule": 3.3.0    , installed 3.3.0
                    Adapter    "wled"         : 0.7.2    , installed 0.7.2
                    Adapter    "ws"           : 2.6.2    , installed 2.6.2
                    Adapter    "yeelight-2"   : 1.4.0    , installed 1.4.0
                    Objects and States
                    Objects:        5443
                    States:         4330
                    Hit:1 http://archive.ubuntu.com/ubuntu focal InRelease
                    Hit:2 http://archive.ubuntu.com/ubuntu focal-updates InRelease
                    Hit:3 http://archive.ubuntu.com/ubuntu focal-security InRelease
                    Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
                    Reading package lists...
                    Pending Updates: 0
                    *** Listening Ports ***
                    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          145815074  301/master
                    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          145808348  1/systemd
                    tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      106        145837324  9263/systemd-resolv
                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          145814728  133/sshd: /usr/sbin
                    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          145815075  301/master
                    tcp6       0      0 :::111                  :::*                    LISTEN      0          145808350  1/systemd
                    tcp6       0      0 :::22                   :::*                    LISTEN      0          145814739  133/sshd: /usr/sbin
                    udp        0      0 127.0.0.53:53           0.0.0.0:*                           106        145837323  9263/systemd-resolv
                    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          145808349  1/systemd
                    udp6       0      0 :::111                  :::*                                0          145808351  1/systemd
                    2024-11-10 16:07:35.028  - info: host.ioBroker instance system.adapter.wled.0 terminated with code 0 (NO_ERROR)
                    2024-11-10 16:07:35.028  - info: host.ioBroker instance system.adapter.spritmonitor.0 terminated with code 0 (NO_ERROR)
                    2024-11-10 16:07:35.107  - info: host.ioBroker instance system.adapter.yeelight-2.0 terminated with code 0 (NO_ERROR)
                    2024-11-10 16:07:35.107  - error: host.ioBroker Caught by controller[0]: /bin/sh: 1: hcitool: not found
                    2024-11-10 16:07:35.107  - info: host.ioBroker instance system.adapter.info.0 terminated with code 0 (NO_ERROR)
                    2024-11-10 16:07:35.108  - info: host.ioBroker instance system.adapter.jarvis.0 terminated with code 0 (NO_ERROR)
                    2024-11-10 16:07:35.108  - info: host.ioBroker stopInstance timeout system.adapter.telegram.0 killing pid 17273
                    2024-11-10 16:07:35.112  - info: host.ioBroker stopInstance timeout system.adapter.web.0 killing pid 17549
                    2024-11-10 16:07:35.137  - error: host.ioBroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                    2024-11-10 16:07:35.137  - error: host.ioBroker Caught by controller[0]: Error: Model yeelink.light.color2 is not supported
                    2024-11-10 16:07:35.137  - error: host.ioBroker Caught by controller[0]:     at Object.createDevice [as device] (/opt/iobroker/node_modules/@iobroker-javascript.0/node-mihome/lib/device.js:8:11)
                    2024-11-10 16:07:35.137  - error: host.ioBroker Caught by controller[0]:     at CreateDevices (script.js.Sonstiges.AllMyMi:936:36)
                    2024-11-10 16:07:35.137  - error: host.ioBroker Caught by controller[0]:     at runNextTicks (node:internal/process/task_queues:60:5)
                    2024-11-10 16:07:35.137  - error: host.ioBroker Caught by controller[0]:     at listOnTimeout (node:internal/timers:538:9)
                    2024-11-10 16:07:35.137  - error: host.ioBroker Caught by controller[0]:     at processTimers (node:internal/timers:512:7)
                    2024-11-10 16:07:35.137  - error: host.ioBroker Caught by controller[0]:     at main (script.js.Sonstiges.AllMyMi:868:5)
                    2024-11-10 16:07:35.137  - info: host.ioBroker instance system.adapter.javascript.0 terminated with code 0 (NO_ERROR)
                    2024-11-10 16:07:35.137  - info: host.ioBroker All instances are stopped.
                    2024-11-10 16:07:35.178  - warn: host.ioBroker instance system.adapter.telegram.0 terminated due to SIGKILL
                    2024-11-10 16:07:35.178  - info: host.ioBroker instance system.adapter.telegram.0 terminated with code null ()
                    2024-11-10 16:07:35.178  - info: host.ioBroker All instances are stopped.
                    2024-11-10 16:07:35.178  - warn: host.ioBroker instance system.adapter.web.0 terminated due to SIGKILL
                    2024-11-10 16:07:35.178  - info: host.ioBroker instance system.adapter.web.0 terminated with code null ()
                    2024-11-10 16:07:35.373  - info: host.ioBroker terminated
                      • iobroker.service loaded failed failed ioBroker Server
                      Da wird der Service nicht gestartet.
                      systemctl status iobroker.service
                      anschauen.
                      Auf dem Dateisystem ist auch was schief:
                      Da 'focal' ohnehin in absehbarer Zeit abgekündigt werden wird: Pack ein Backup ein und zieh damit in ein frisches System um.
                        christian@ioBroker:~$ iob start
                        christian@ioBroker:~$ systemctl status iobroker.service
                        * iobroker.service - ioBroker Server
                             Loaded: loaded (/lib/systemd/system/iobroker.service; enabled; vendor preset: enabled)
                             Active: active (running) since Sun 2024-11-10 16:13:56 CET; 9min ago
                               Docs: http://iobroker.net
                           Main PID: 20605 (iobroker.js-con)
                              Tasks: 209 (limit: 4915)
                             Memory: 1.2G
                             CGroup: /system.slice/iobroker.service
                                     |-20605 iobroker.js-controller
                                     |-20626 io.admin.0
                                     |-20681 io.javascript.0
                                     |-20706 io.telegram.0
                                     |-20747 io.history.0
                                     |-20773 io.alexa2.0
                                     |-20803 io.mihome-vacuum.0
                                     |-20818 io.yeelight-2.0
                                     |-20833 io.deconz.0
                                     |-20872 io.discovery.0
                                     |-20887 io.info.0
                                     |-21235 io.iot.0
                                     |-21250 io.tankerkoenig.0
                                     |-21265 io.web.0
                                     |-21280 io.jarvis.0
                                     |-21295 io.trashschedule.0
                                     |-21310 io.wled.0
                                     |-21325 io.spritmonitor.0
                                     `-21406 io.fb-checkpresence.0
                        christian@ioBroker:~$ iob fix
                        Your system is booting into 'graphical.target', which means that a user interface or desktop is available. Usually a server is running without a desktop to have more RAM available. Do you want to switch to 'multi-user.target'? (y/N)
                        library: loaded
                        Library version=2024-10-22
                            Welcome to the ioBroker installation fixer!
                            Script version: 2024-10-22
                            You might need to enter your password a couple of times.
                            Installing prerequisites (1/5)
                        0% [Working]
                        Hit:1 https://deb.nodesource.com/node_20.x nodistro InRelease
                        Hit:2 http://archive.ubuntu.com/ubuntu focal InRelease
                        Hit:3 http://archive.ubuntu.com/ubuntu focal-updates InRelease
                        Hit:4 http://archive.ubuntu.com/ubuntu focal-security InRelease
                        Reading package lists... Done
                        E: Unable to locate package polkitd
                        Installed polkitd
                            Checking ioBroker user and directory permissions (2/5)
                        Created /etc/sudoers.d/iobroker
                            Check and cleanup npm temporary directories (3/5)
                        Done.
                            Database maintenance (4/5)
                        Checking for uncompressed JSONL databases... This might take a while!
                        Compressing /opt/iobroker/iobroker-data/states.jsonl
                        Compressing /opt/iobroker/iobroker-data/objects.jsonl
                        Compressed 2 JSONL files. Done
                            Checking autostart (5/5)
                        Enabling autostart...
                        Autostart enabled!
                            Your installation was fixed successfully
                            Run iobroker start to start ioBroker again!
                        307
