    4. js-controller Update aus Admin schlägt fehlt
    • Merlin123
      Merlin123 last edited by
      Auf Wunsch von @foxriver76 und @Thomas-Braun hier die Diagausgabe zu dem Problem, dass ein js-controller Update aus dem Admin den Fehler
      SyntaxError: Unexpected token '<', "<!doctype "... is not valid JSON
      bringt
                              v.2024-10-19
       Static hostname: iobrokervm
             Icon name: computer-vm
               Chassis: vm 🖴
        Virtualization: kvm
                Kernel: Linux 6.1.0-27-amd64
          Architecture: x86-64
       Hardware Vendor: QEMU
        Hardware Model: Standard PC _i440FX + PIIX, 1996_
      Firmware Version: rel-1.16.3-0-ga6ed6b701f0a-prebuilt.qemu.org
      Installation:           kvm
      User-ID:                1000
      Display-Server:         false
      Pending OS-Updates:     0
      Pending iob updates:    2
      Nodejs-Installation:
      /usr/bin/nodejs         v20.18.0
      /usr/bin/node           v20.18.0
      /usr/bin/corepack       0.29.3
      Recommended versions are nodejs 20.18.0 and npm 10.8.2
      nodeJS installation is correct
      MEMORY:
      Mem:             12G        4.6G        4.1G        561K        3.9G        7.6G
      Swap:           5.1G          0B        5.1G
      Total:           17G        4.6G        9.2G
      Active iob-Instances:   70
      Upgrade policy: none
      ioBroker Core:          js-controller           7.0.2
                              admin                   7.3.1
      Objects type: jsonl
      States  type: jsonl
      + system.adapter.admin.1                  : admin                 : iobrokervm                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.web.0                    : web                   : iobrokervm                               -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      Objects:                28605
      States:                 23764
      Size of iob-Database:
      36M     /opt/iobroker/iobroker-data/objects.jsonl
      20M     /opt/iobroker/iobroker-data/states.jsonl
      Operating System is the current Debian stable version codenamed 'bookworm'!
        Thomas Braun Most Active @Merlin123 last edited by
        @merlin123
        Die Langfassung bitte.
        Merlin123 1 Reply Last reply Reply Quote 0
        • Merlin123
          Merlin123 @Thomas Braun last edited by Merlin123
          Sorry.... Hier komplett
          Script v.2024-10-19
          *** BASE SYSTEM ***
                   Chassis: vm 🖴
            Virtualization: kvm
          OS is similar to:
          model name	: Common KVM processor
          Docker          : false
          Virtualization  : kvm
          Kernel          : x86_64
          Userland        : 64 bit
          Systemuptime and Load:
           13:50:49 up 5 days, 21:24,  2 users,  load average: 0.47, 0.45, 0.49
          CPU threads: 8
          *** LIFE CYCLE STATUS ***
          *** TIME AND TIMEZONES ***
                         Local time: Fri 2024-11-15 13:50:50 CET
                     Universal time: Fri 2024-11-15 12:50:50 UTC
                           RTC time: Fri 2024-11-15 12:50:50
                        NTP service: active
                    RTC in local TZ: no
          *** Users and Groups ***
          User that called 'iob diag':
          oliver
          HOME=/home/oliver
          GROUPS=oliver cdrom floppy sudo audio dip video plugdev netdev iobroker
          iobroker
          HOME=/home/iobroker
          GROUPS=iobroker tty dialout audio video plugdev
          *** DISPLAY-SERVER SETUP ***
          Desktop:
          Terminal: 	tty
          *** MEMORY ***
          Mem:             12G        4.6G        4.0G        569K        3.9G        7.6G
          Swap:           5.1G          0B        5.1G
                  11676 M total memory
                   4387 M used memory
                   1527 M active memory
                   5476 M inactive memory
                   3852 M free memory
                    455 M buffer memory
                   3298 M swap cache
                   4881 M total swap
                      0 M used swap
                   4881 M free swap
          top - 13:50:50 up 5 days, 21:24,  2 users,  load average: 0.47, 0.45, 0.49
          Tasks: 180 total,   1 running, 179 sleeping,   0 stopped,   0 zombie
          %Cpu(s):  0.0 us, 33.3 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
          MiB Mem :  11676.7 total,   3852.8 free,   4387.0 used,   3754.0 buff/cache
          MiB Swap:   4881.2 total,   4881.2 free,      0.0 used.   7289.7 avail Mem
          *** FAILED SERVICES ***
          0 loaded units listed.
          *** DMESG CRITICAL ERRORS ***
          No critical errors detected
          *** FILESYSTEM ***
          udev           devtmpfs  5.7G     0  5.7G   0% /dev
          tmpfs          tmpfs     1.2G  556K  1.2G   1% /run
          /dev/sda1      ext4      141G   33G  103G  24% /
          tmpfs          tmpfs     5.8G     0  5.8G   0% /dev/shm
          tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
          tmpfs          tmpfs     1.2G     0  1.2G   0% /run/user/1000
          [Sat Nov  9 16:26:43 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
          [Sat Nov  9 16:26:43 2024] EXT4-fs (sda1): re-mounted. Quota mode: none.
          Show mounted filesystems:
          TARGET SOURCE    FSTYPE OPTIONS
          /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
          /var:
          2.7G	/var/
          1.5G	/var/log
          1021M	/var/cache
          1013M	/var/cache/apt
          937M	/var/cache/apt/archives
          Archived and active journals take up 178.1M in the file system.
          /opt/iobroker/backups:
          177M	/opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          2.1G	/opt/iobroker/iobroker-data/
          1.9G	/opt/iobroker/iobroker-data/files
          617M	/opt/iobroker/iobroker-data/files/javascript.admin
          560M	/opt/iobroker/iobroker-data/files/javascript.admin/static
          558M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js
          63M	/opt/iobroker/iobroker-data/states.jsonl
          41M	/opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
          37M	/opt/iobroker/iobroker-data/objects.jsonl
          37M	/opt/iobroker/iobroker-data/files/radar-trap.admin/build/index.js.map
          26M	/opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
          USB-Devices by-id:
          /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_08a893a38329ec11ba4c6f7840c9ce8d-if00-port0
          HINT:
          Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
          /dev/ttyUSB0
          *** NodeJS-Installation ***
          /usr/bin/npm 		10.8.2
          /usr/bin/npx 		10.8.2
          nodejs:
            Installed: 20.18.0-1nodesource1
            Candidate: 20.18.0-1nodesource1
            Version table:
           *** 20.18.0-1nodesource1 1001
                  500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                  100 /var/lib/dpkg/status
               20.17.0-1nodesource1 1001
               20.16.0-1nodesource1 1001
               20.15.1-1nodesource1 1001
               20.15.0-1nodesource1 1001
               20.14.0-1nodesource1 1001
               20.13.1-1nodesource1 1001
               20.13.0-1nodesource1 1001
               20.12.2-1nodesource1 1001
               20.12.1-1nodesource1 1001
               20.12.0-1nodesource1 1001
               20.11.1-1nodesource1 1001
               20.11.0-1nodesource1 1001
               20.10.0-1nodesource1 1001
               20.9.0-1nodesource1 1001
               20.8.1-1nodesource1 1001
               20.8.0-1nodesource1 1001
               20.7.0-1nodesource1 1001
               20.6.1-1nodesource1 1001
               20.6.0-1nodesource1 1001
               20.5.1-1nodesource1 1001
               20.5.0-1nodesource1 1001
               20.4.0-1nodesource1 1001
               20.3.1-1nodesource1 1001
               20.3.0-1nodesource1 1001
               20.2.0-1nodesource1 1001
               20.1.0-1nodesource1 1001
               20.0.0-1nodesource1 1001
               18.19.0+dfsg-6~deb12u2 500
                  500 http://deb.debian.org/debian bookworm/main amd64 Packages
               18.19.0+dfsg-6~deb12u1 500
                  500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
          No problems detected
          Errors in npm tree: 0
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          iobrokervm          iobrokervm (version: 7.0.2, hostname: iobrokervm    , alive, uptime: 3047)
          Core adapters versions
          js-controller: 	7.0.2
          admin: 		7.3.1
          javascript: 	8.8.3
          nodejs modules from github: 	6
          +-- iobroker.drops-weather@0.3.1 (git+ssh://git@github.com/inbux/ioBroker.drops-weather.git#608ed1fcbbde3f59b6a09f2f188b92823481ae90)
          +-- iobroker.energiefluss-erweitert@0.4.1 (git+ssh://git@github.com/SKB-CGN/ioBroker.energiefluss-erweitert.git#f724bf54ab9a69bc6d4533b59f560462e1bb2993)
          +-- iobroker.labcom@0.1.4 (git+ssh://git@github.com/100prznt/ioBroker.labcom.git#2cbc14b6c33d01fcc29003e3648fcb0c4d917f75)
          +-- iobroker.life360@0.2.22 (git+ssh://git@github.com/MiGoller/ioBroker.life360.git#23166aab1b2e36d917a9b7b480d9faa7f73ca2d1)
          | +-- syno@3.0.0 (git+ssh://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
          +-- iobroker.tibberconnect@0.0.10 (git+ssh://git@github.com/Codibris/ioBroker.tibberconnect.git#3d3cb4129718fbaf00fcdc00b23d1a68e35d2c83)
          Adapter State
          + system.adapter.alexa-timer-vis.0        : alexa-timer-vis       : iobrokervm                               -  enabled
          + system.adapter.alexa2.0                 : alexa2                : iobrokervm                               -  enabled
            system.adapter.alias-manager.0          : alias-manager         : iobrokervm                               - disabled
          + system.adapter.awtrix-light.0           : awtrix-light          : iobrokervm                               -  enabled
          + system.adapter.backitup.0               : backitup              : iobrokervm                               -  enabled
          + system.adapter.chromecast.0             : chromecast            : iobrokervm                               -  enabled
          + system.adapter.cloud.0                  : cloud                 : iobrokervm                               -  enabled
          + system.adapter.device-reminder.0        : device-reminder       : iobrokervm                               -  enabled
          + system.adapter.device-watcher.0         : device-watcher        : iobrokervm                               -  enabled
            system.adapter.devices.0                : devices               : iobrokervm                               - disabled
          + system.adapter.discovery.0              : discovery             : iobrokervm                               -  enabled
          + system.adapter.doorbird.0               : doorbird              : iobrokervm                               -  enabled
          + system.adapter.drops-weather.0          : drops-weather         : iobrokervm                               -  enabled
            system.adapter.dwd.0                    : dwd                   : iobrokervm                               -  enabled
          + system.adapter.echarts.0                : echarts               : iobrokervm                               -  enabled
          + system.adapter.email.0                  : email                 : iobrokervm                               -  enabled
          + system.adapter.ems-esp.0                : ems-esp               : iobrokervm                               -  enabled
          + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobrokervm                               -  enabled
          + system.adapter.energiefluss-erweitert.1 : energiefluss-erweitert: iobrokervm                               -  enabled
          + system.adapter.evcc.0                   : evcc                  : iobrokervm                               -  enabled, port: 7070
            system.adapter.flot.0                   : flot                  : iobrokervm                               - disabled
          + system.adapter.followthesun.0           : followthesun          : iobrokervm                               -  enabled
          + system.adapter.fritzbox.0               : fritzbox              : iobrokervm                               -  enabled
          + system.adapter.fritzdect.0              : fritzdect             : iobrokervm                               -  enabled
          + system.adapter.fullybrowser.0           : fullybrowser          : iobrokervm                               -  enabled
          + system.adapter.go-e.0                   : go-e                  : iobrokervm                               -  enabled
          + system.adapter.harmony.0                : harmony               : iobrokervm                               -  enabled
          + system.adapter.homeconnect.0            : homeconnect           : iobrokervm                               -  enabled
          + system.adapter.hue.0                    : hue                   : iobrokervm                               -  enabled, port: 80
            system.adapter.ical.0                   : ical                  : iobrokervm                               -  enabled
          + system.adapter.influxdb.0               : influxdb              : iobrokervm                               -  enabled, port: 8086
          + system.adapter.iot.0                    : iot                   : iobrokervm                               -  enabled
          + system.adapter.javascript.0             : javascript            : iobrokervm                               -  enabled
            system.adapter.klipper-moonraker.0      : klipper-moonraker     : iobrokervm                               - disabled
            system.adapter.klipper-moonraker.1      : klipper-moonraker     : iobrokervm                               - disabled
          + system.adapter.knx.0                    : knx                   : iobrokervm                               -  enabled, bind: 192.168.0.251
            system.adapter.labcom.0                 : labcom                : iobrokervm                               -  enabled
          + system.adapter.lg-thinq.0               : lg-thinq              : iobrokervm                               -  enabled
            system.adapter.life360.0                : life360               : iobrokervm                               - disabled
          + system.adapter.linux-control.0          : linux-control         : iobrokervm                               -  enabled
          + system.adapter.logparser.0              : logparser             : iobrokervm                               -  enabled
            system.adapter.material.0               : material              : iobrokervm                               - disabled
            system.adapter.mobile.0                 : mobile                : iobrokervm                               - disabled
          + system.adapter.modbus.0                 : modbus                : iobrokervm                               -  enabled
            system.adapter.mqtt.0                   : mqtt                  : iobrokervm                               - disabled, port: 1884, bind: 0.0.0.0
            system.adapter.netatmo-crawler.0        : netatmo-crawler       : iobrokervm                               - disabled
          + system.adapter.nina.0                   : nina                  : iobrokervm                               -  enabled
            system.adapter.node-red.0               : node-red              : iobrokervm                               - disabled, port: 1880, bind: 0.0.0.0
            system.adapter.nuki-extended.0          : nuki-extended         : iobrokervm                               - disabled
          + system.adapter.nuki.0                   : nuki                  : iobrokervm                               -  enabled
          + system.adapter.nut.0                    : nut                   : iobrokervm                               -  enabled
            system.adapter.octoprint.0              : octoprint             : iobrokervm                               - disabled
          + system.adapter.onvif.0                  : onvif                 : iobrokervm                               -  enabled, port: 80, 7575, 8000, 8080, 8081, 8899
            system.adapter.openknx.0                : openknx               : iobrokervm                               - disabled
            system.adapter.openweathermap.0         : openweathermap        : iobrokervm                               -  enabled
          + system.adapter.ping.0                   : ping                  : iobrokervm                               -  enabled
          + system.adapter.proxmox.0                : proxmox               : iobrokervm                               -  enabled, port: 8006
          + system.adapter.pvforecast.0             : pvforecast            : iobrokervm                               -  enabled
          + system.adapter.radar-trap.0             : radar-trap            : iobrokervm                               -  enabled
            system.adapter.reolink.0                : reolink               : iobrokervm                               - disabled
          + system.adapter.reolink.1                : reolink               : iobrokervm                               -  enabled
          + system.adapter.reolink.2                : reolink               : iobrokervm                               -  enabled
          + system.adapter.rest-api.0               : rest-api              : iobrokervm                               -  enabled, port: 8093, bind: 0.0.0.0, run as: admin
          + system.adapter.sainlogic.0              : sainlogic             : iobrokervm                               -  enabled, port: 45000, bind: 0.0.0.0
          + system.adapter.scenes.0                 : scenes                : iobrokervm                               -  enabled
          + system.adapter.scheduler.0              : scheduler             : iobrokervm                               -  enabled
          + system.adapter.shelly.0                 : shelly                : iobrokervm                               -  enabled, port: 1882, bind: 0.0.0.0
          + system.adapter.shelly.1                 : shelly                : iobrokervm                               -  enabled, port: 1882, bind: 0.0.0.0
          + system.adapter.slideshow.0              : slideshow             : iobrokervm                               -  enabled
          + system.adapter.slideshow.1              : slideshow             : iobrokervm                               -  enabled
          + system.adapter.sonoff.0                 : sonoff                : iobrokervm                               -  enabled, port: 1883, bind: 0.0.0.0
          + system.adapter.sonos.0                  : sonos                 : iobrokervm                               -  enabled
            system.adapter.sourceanalytix.0         : sourceanalytix        : iobrokervm                               - disabled
          + system.adapter.synology.0               : synology              : iobrokervm                               -  enabled, port: 5000
          + system.adapter.telegram.0               : telegram              : iobrokervm                               -  enabled, port: 8443, bind: 0.0.0.0
          + system.adapter.text2command.0           : text2command          : iobrokervm                               -  enabled
          + system.adapter.tibberlink.0             : tibberlink            : iobrokervm                               -  enabled
          + system.adapter.tr-064.0                 : tr-064                : iobrokervm                               -  enabled
          + system.adapter.trashschedule.0          : trashschedule         : iobrokervm                               -  enabled
          + system.adapter.tronity.0                : tronity               : iobrokervm                               -  enabled
            system.adapter.uv-protect.0             : uv-protect            : iobrokervm                               -  enabled
            system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : iobrokervm                               -  enabled
            system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : iobrokervm                               -  enabled
            system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: iobrokervm                               -  enabled
            system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobrokervm                               -  enabled
            system.adapter.vis-2-widgets-radar-trap.0: vis-2-widgets-radar-trap: iobrokervm                               -  enabled
          + system.adapter.vis-2.0                  : vis-2                 : iobrokervm                               -  enabled
            system.adapter.vis-bars.0               : vis-bars              : iobrokervm                               - disabled
            system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobrokervm                               - disabled
            system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobrokervm                               - disabled
            system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobrokervm                               - disabled
            system.adapter.vis-history.0            : vis-history           : iobrokervm                               - disabled
            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobrokervm                               - disabled
            system.adapter.vis-icontwo.0            : vis-icontwo           : iobrokervm                               - disabled
          + system.adapter.vis-inventwo.0           : vis-inventwo          : iobrokervm                               -  enabled
            system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobrokervm                               - disabled
            system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobrokervm                               -  enabled
            system.adapter.vis-metro.0              : vis-metro             : iobrokervm                               -  enabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobrokervm                               - disabled
            system.adapter.vis.0                    : vis                   : iobrokervm                               -  enabled
          + system.adapter.vw-connect.0             : vw-connect            : iobrokervm                               -  enabled
            system.adapter.weatherunderground.0     : weatherunderground    : iobrokervm                               -  enabled
          + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobrokervm                               -  enabled
          + system.adapter.worx.0                   : worx                  : iobrokervm                               -  enabled
          + system.adapter.ws.0                     : ws                    : iobrokervm                               -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
          + system.adapter.zigbee.0                 : zigbee                : iobrokervm                               -  enabled, port: /dev/ttyUSB0
          + instance is alive
          ioBroker-Repositories
          Active repo(s): beta
          Installed ioBroker-Instances
          Used repository: beta
          Adapter    "admin"        : 7.3.1    , installed 7.3.1
          Adapter    "alexa-timer-vis": 2.0.6  , installed 2.0.6
          Adapter    "alexa2"       : 3.26.7   , installed 3.26.7
          Adapter    "alias-manager": 2.0.0    , installed 2.0.0
          Adapter    "awtrix-light" : 1.3.0    , installed 1.3.0
          Adapter    "backitup"     : 3.0.27   , installed 3.0.27
          Adapter    "chromecast"   : 4.0.0    , installed 4.0.0
          Adapter    "cloud"        : 5.0.1    , installed 5.0.1
          Adapter    "device-reminder": 3.1.2  , installed 3.1.2
          Adapter    "device-watcher": 2.12.1  , installed 2.12.1
          Adapter    "discovery"    : 5.0.0    , installed 5.0.0
          Adapter    "doorbird"     : 2.0.0    , installed 2.0.0
          Adapter    "echarts"      : 1.9.2    , installed 1.9.2
          Adapter    "email"        : 1.3.1    , installed 1.3.1
          Adapter    "ems-esp"      : 5.0.4    , installed 5.0.4
          Adapter    "energiefluss-erweitert": 0.4.1, installed 0.4.1
          Adapter    "evcc"         : 0.1.1    , installed 0.1.1
          Adapter    "fahrplan"     : 1.2.3    , installed 1.2.3
          Adapter    "followthesun" : 0.5.1    , installed 0.5.1
          Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
          Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
          Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
          Adapter    "go-e"         : 1.0.41   , installed 1.0.41
          Adapter    "harmony"      : 1.5.0    , installed 1.5.0
          Adapter    "homeconnect"  : 1.4.2    , installed 1.4.2
          Adapter    "hue"          : 3.13.1   , installed 3.13.1
          Adapter    "ical"         : 1.16.1   , installed 1.16.1
          Adapter    "iot"          : 3.4.3    , installed 3.4.3
          Adapter    "javascript"   : 8.8.3    , installed 8.8.3
          Controller "js-controller": 7.0.3    , installed 7.0.2  [Updatable]
          Adapter    "knx"          : 2.0.28   , installed 2.0.28
          Adapter    "lg-thinq"     : 1.0.2    , installed 1.0.2
          Adapter    "linux-control": 1.1.5    , installed 1.1.5
          Adapter    "logparser"    : 2.2.2    , installed 2.2.2
          Adapter    "material"     : 1.3.1    , installed 1.3.1
          Adapter    "mobile"       : 1.0.1    , installed 1.0.1
          Adapter    "modbus"       : 6.3.2    , installed 6.3.2
          Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
          Adapter    "mytime"       : 1.2.0    , installed 1.2.0
          Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
          Adapter    "nina"         : 0.0.26   , installed 0.0.26
          Adapter    "node-red"     : 5.2.1    , installed 5.2.1
          Adapter    "nuki"         : 2.0.0    , installed 2.0.0
          Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
          Adapter    "nut"          : 1.6.0    , installed 1.6.0
          Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
          Adapter    "onvif"        : 1.1.4    , installed 1.1.4
          Adapter    "openknx"      : 0.9.0    , installed 0.9.0
          Adapter    "openweathermap": 1.1.2   , installed 1.1.2
          Adapter    "ping"         : 1.7.9    , installed 1.7.9
          Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
          Adapter    "pvforecast"   : 4.0.1    , installed 4.0.1
          Adapter    "radar-trap"   : 2.2.2    , installed 2.2.2
          Adapter    "reolink"      : 1.1.2    , installed 1.1.2
          Adapter    "rest-api"     : 2.0.3    , installed 2.0.3
          Adapter    "sainlogic"    : 0.11.4   , installed 0.11.4
          Adapter    "scenes"       : 3.2.3    , installed 3.2.3
          Adapter    "scheduler"    : 1.4.1    , installed 1.4.1
          Adapter    "shelly"       : 8.4.0    , installed 8.4.0
          Adapter    "slideshow"    : 0.2.0    , installed 0.1.4  [Updatable]
          Adapter    "socketio"     : 6.7.1    , installed 6.7.1
          Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
          Adapter    "sonos"        : 3.0.0    , installed 3.0.0
          Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
          Adapter    "synology"     : 3.1.0    , installed 3.1.0
          Adapter    "telegram"     : 3.9.0    , installed 3.9.0
          Adapter    "text2command" : 3.0.3    , installed 3.0.3
          Adapter    "tibberlink"   : 3.5.2    , installed 3.5.2
          Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
          Adapter    "trashschedule": 3.4.0    , installed 3.4.0
          Adapter    "tronity"      : 1.1.1    , installed 1.1.1
          Adapter    "uv-protect"   : 0.6.3    , installed 0.6.3
          Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
          Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
          Adapter    "vis-2-widgets-gauges": 1.1.0, installed 1.1.0
          Adapter    "vis-2-widgets-inventwo": 0.1.11, installed 0.1.11
          Adapter    "vis-2-widgets-jaeger-design": 1.3.1, installed 1.3.1
          Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
          Adapter    "vis-2-widgets-radar-trap": 2.3.0, installed 2.3.0
          Adapter    "vis-icontwo"  : 1.6.3    , installed 1.6.3
          Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
          Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
          Adapter    "vw-connect"   : 0.6.1    , installed 0.6.1
          Adapter    "weatherunderground": 3.7.0, installed 3.7.0
          Adapter    "web"          : 6.3.1    , installed 6.3.1
          Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
          Adapter    "worx"         : 3.1.1    , installed 3.1.1
          Adapter    "ws"           : 2.6.2    , installed 2.6.2
          Adapter    "zigbee"       : 1.10.13  , installed 1.10.13
          Objects and States
          Objects: 	28605
          States: 	23764
          Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
          Hit:3 http://security.debian.org/debian-security bookworm-security InRelease
          Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       25804182   1315726/io.sonoff.0
          tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       25804630   1315872/io.shelly.1
          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          14529      1/init
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16710      463/sshd: /usr/sbin
          tcp        0      0 0.0.0.0:45000           0.0.0.0:*               LISTEN      1001       25812761   1316641/io.sainlogi
          tcp        0      0 192.168.0.251:8100      0.0.0.0:*               LISTEN      1001       25806421   1316066/io.doorbird
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       25802820   1315299/iobroker.js
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       25801317   1315299/iobroker.js
          tcp        0      0 192.168.0.251:9092      0.0.0.0:*               LISTEN      1001       25803370   1315628/io.nuki.0
          tcp6       0      0 :::111                  :::*                    LISTEN      0          12965      1/init
          tcp6       0      0 :::22                   :::*                    LISTEN      0          16712      463/sshd: /usr/sbin
          tcp6       0      0 :::3500                 :::*                    LISTEN      1001       25802494   1315741/io.sonos.0
          tcp6       0      0 :::3040                 :::*                    LISTEN      1001       25816844   1317037/io.radar-tr
          tcp6       0      0 :::3000                 :::*                    LISTEN      1001       25808586   1316125/io.fullybro
          tcp6       0      0 :::61991                :::*                    LISTEN      1001       25803154   1315538/io.harmony.
          tcp6       0      0 :::8093                 :::*                    LISTEN      1001       25814158   1316759/io.rest-api
          tcp6       0      0 :::8084                 :::*                    LISTEN      1001       25813914   1316821/io.ws.0
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       25810572   1316610/io.web.0
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       25802013   1315321/io.admin.1
          udp        0      0 192.168.0.251:56134     0.0.0.0:*                           1001       25899271   1315598/io.knx.0
          udp        0      0 192.168.0.251:47945     0.0.0.0:*                           1001       25936324   1315598/io.knx.0
          udp        0      0 192.168.0.251:39820     0.0.0.0:*                           1001       25829580   1315598/io.knx.0
          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          14530      1/init
          udp        0      0 192.168.0.251:51416     0.0.0.0:*                           1001       25905749   1315598/io.knx.0
          udp        0      0 192.168.0.251:44966     0.0.0.0:*                           1001       25924697   1315598/io.knx.0
          udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       25803155   1315538/io.harmony.
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       25808193   1316006/io.chromeca
          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       25804143   1315704/io.shelly.0
          udp        0      0 192.168.0.251:55534     0.0.0.0:*                           1001       25801697   1315598/io.knx.0
          udp        0      0 192.168.0.251:55556     0.0.0.0:*                           1001       25846077   1315598/io.knx.0
          udp6       0      0 :::111                  :::*                                0          13452      1/init
              at listOnTimeout (node:internal/timers:581:17)
              at processTimers (node:internal/timers:519:7)
          2024-11-15 13:50:28.257  - info: chromecast.0 (1316006) AI PONT DE - client disconnected
          2024-11-15 13:50:28.258  - info: chromecast.0 (1316006) AI PONT DE - Detached player
          2024-11-15 13:50:28.817  - info: openweathermap.0 (1325167) starting. Version 1.1.2 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v20.18.0, js-controller: 7.0.2
          2024-11-15 13:50:31.320  - info: chromecast.0 (1316006) TVMarleen - Connected client
          2024-11-15 13:50:31.333  - info: chromecast.0 (1316006) AI PONT DE - Connected client
          2024-11-15 13:50:31.368  - info: chromecast.0 (1316006) TVMarleen - Try to join player
          2024-11-15 13:50:31.369  - info: chromecast.0 (1316006) TVMarleen - Connected player
          2024-11-15 13:50:31.369  - info: chromecast.0 (1316006) TVMarleen - Player joint
          2024-11-15 13:50:31.374  - info: chromecast.0 (1316006) AI PONT DE - Try to join player
          2024-11-15 13:50:31.375  - info: chromecast.0 (1316006) AI PONT DE - Connected player
          2024-11-15 13:50:31.375  - info: chromecast.0 (1316006) AI PONT DE - Player joint
          2024-11-15 13:50:31.399  - info: chromecast.0 (1316006) {"appId":"E8C28D3C","appType":"WEB","displayName":"Backdrop","iconUrl":"","isIdleScreen":true,"launchedFromCloud":false,"namespaces":[{"name":"urn:x-cast:com.google.cast.sse"},{"name":"urn:x-cast:com.google.cast.cac"}],"senderConnected":true,"sessionId":"753e6cb6-5cd1-4d50-9a54-adf525a7d85c","statusText":"","transportId":"753e6cb6-5cd1-4d50-9a54-adf525a7d85c","universalAppId":"E8C28D3C"}
          2024-11-15 13:50:31.407  - info: chromecast.0 (1316006) {"appId":"E8C28D3C","appType":"WEB","displayName":"Backdrop","iconUrl":"","isIdleScreen":true,"launchedFromCloud":false,"namespaces":[{"name":"urn:x-cast:com.google.cast.sse"},{"name":"urn:x-cast:com.google.cast.cac"}],"senderConnected":true,"sessionId":"753e6cb6-5cd1-4d50-9a54-adf525a7d85c","statusText":"","transportId":"753e6cb6-5cd1-4d50-9a54-adf525a7d85c","universalAppId":"E8C28D3C"}
          2024-11-15 13:50:31.415  - info: chromecast.0 (1316006) {"appId":"E8C28D3C","appType":"WEB","displayName":"Backdrop","iconUrl":"","isIdleScreen":true,"launchedFromCloud":false,"namespaces":[{"name":"urn:x-cast:com.google.cast.sse"},{"name":"urn:x-cast:com.google.cast.cac"}],"senderConnected":true,"sessionId":"753e6cb6-5cd1-4d50-9a54-adf525a7d85c","statusText":"","transportId":"753e6cb6-5cd1-4d50-9a54-adf525a7d85c","universalAppId":"E8C28D3C"}
          2024-11-15 13:50:31.419  - info: chromecast.0 (1316006) {"appId":"E8C28D3C","appType":"WEB","displayName":"Backdrop","iconUrl":"","isIdleScreen":true,"launchedFromCloud":false,"namespaces":[{"name":"urn:x-cast:com.google.cast.sse"},{"name":"urn:x-cast:com.google.cast.cac"}],"senderConnected":true,"sessionId":"753e6cb6-5cd1-4d50-9a54-adf525a7d85c","statusText":"","transportId":"753e6cb6-5cd1-4d50-9a54-adf525a7d85c","universalAppId":"E8C28D3C"}
          2024-11-15 13:50:32.048  - debug: homeconnect.0 (1315553) [object Object]
          2024-11-15 13:50:39.634  - info: web.0 (1316610) <== Disconnect system.user.admin from ::ffff:192.168.0.125
          2024-11-15 13:50:39.753  - info: web.0 (1316610) ==> Connected system.user.admin from ::ffff:192.168.0.125
          2024-11-15 13:50:58.136  - info: openweathermap.0 (1325167) Terminated (NO_ERROR): Without reason
          2024-11-15 13:50:58.647  - info: host.iobrokervm instance system.adapter.openweathermap.0 having pid 1325167 terminated with code 0 (NO_ERROR)
            @merlin123
            Okay, dann bitte noch die Ausgabe von
            egrep 'oliver|iobroker' /etc/passwd
            • Merlin123
              oliver@iobrokervm:~$ egrep 'oliver|iobroker' /etc/passwd
              oliver:x:1000:1000:Oliver,,,:/home/oliver:/bin/bash
              iobroker:x:1001:1001::/home/iobroker:/usr/sbin/nologin
                @merlin123
                Okay, da hatte ich eigentlich was anderes erwartet, aber /usr/sbin/nologin stimmt für den iobroker.
                PAM dürfte dann aber eigentlich auch nicht nach einem Passwort für den user fragen.
                • Merlin123
                  @thomas-braun ok.... Hätte mich auch gewundert, wenn das nicht gestimmt hätte. Hatte mich an die Anleitung gehalten...
                  Und jetzt? Noch eine Idee?
                    @merlin123
                    Ich vermute, rein über die Kommandozeile funktioniert es?
                    • Merlin123
                      @thomas-braun jup. Absolut problemlos bisher. 7.0.2 auf 7.0.3 habe ich jetzt natürlich noch nicht gemacht 😉
                        Thomas Braun Most Active @Merlin123 last edited by Thomas Braun
                        @merlin123
                        Als Testszenario würde ich mal folgendes probieren:
                        Per Kommandozeile wie üblich upgraden.
                        iob update
                        iob stop
                        iob upgrade self
                        Dann im Log anschauen, wie das abgelaufen ist.
                        Danach dann wieder eine der Vorversionen (7.0.2 z. B.) installieren und dann per GUI updaten. Auch hier wieder in das Log schauen, was da im einzelnen passiert.
                        Log am besten per
                        iob logs --watch
                        in Echtzeit in einem zweiten Terminal beobachten.
                        • Merlin123
                          Geht nicht wirklich 😞
                          beim Update via Kommandozeile zeigt iob logs nichts an.
                          Im Systemlog steht bei downgrade auf 7.0.2 und anschließendem auto upgrade auf 7.0.3
                          Nov 15 17:30:13 iobrokervm sudo[1357756]:   oliver : TTY=pts/2 ; PWD=/opt/iobroker ; USER=iobroker ; COMMAND=/usr/bin/npm install iobroker.js-controller@7.0.2
                          Nov 15 17:30:13 iobrokervm sudo[1357756]: pam_unix(sudo:session): session opened for user iobroker(uid=1001) by oliver(uid=1000)
                          Nov 15 17:30:40 iobrokervm sudo[1357756]: pam_unix(sudo:session): session closed for user iobroker
                          Nov 15 17:30:55 iobrokervm sudo[1357806]:   oliver : TTY=pts/2 ; PWD=/opt/iobroker ; USER=iobroker ; COMMAND=/usr/bin/node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js upgrade self
                          Nov 15 17:30:55 iobrokervm sudo[1357806]: pam_unix(sudo:session): session opened for user iobroker(uid=1001) by oliver(uid=1000)
                          Wenn ich nachträglich in iob logs schaue ist für die Zeit kein Eintrag drin.
                          Wenn ich das Update aus der GUI starte steht da:
                          2024-11-15 17:42:45.225  - info: host.iobrokervm Controller will upgrade itself to version 7.0.3
                          1132
